  4. Diskussion zum HowTo nodejs-Installation und upgrade
nodejs
844 Beiträge 91 Kommentatoren 328.2k Aufrufe 63 Beobachtet
  • D djsirius
    Moin,
    ich habe jetzt aus lauter Verzweiflung Nodejs nochmal neu installiert. Auf meinem Master ist alles OK.
    Auf meinem Slave bekomme ich immer eine Meldung, wenn ich den iob fix drüber laufen lasse.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    npm ERR! code ETIMEDOUT
    npm ERR! syscall connect
    npm ERR! errno ETIMEDOUT
    npm ERR! network request to https://registry.npmjs.org/@iobroker%2fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
    npm ERR! network This is a problem related to network connectivity.
    npm ERR! network In most cases you are behind a proxy or have bad network settings.
    npm ERR! network
    npm ERR! network If you are behind a proxy, please make sure that the
    npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-08T08_12_15_007Z-debug-0.log
    iob diag:
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     09:20:56 up 3 days, 22:17,  1 user,  load average: 0.25, 0.45, 0.80
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Mon 2024-01-08 09:20:56 CET
               Universal time: Mon 2024-01-08 08:20:56 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        212M        138M        0.0K        558M        632M
    Swap:            99M         78M         21M
    Total:          1.0G        290M        160M
              909 M total memory
              212 M used memory
              238 M active memory
              396 M inactive memory
              138 M free memory
               39 M buffer memory
              518 M swap cache
               99 M total swap
               78 M used swap
               21 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4       59G   32G   25G  56% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M 1008K  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    tmpfs          tmpfs      91M     0   91M   0% /run/user/0
    [Thu Jan  4 11:03:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d3cf0315-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Jan  4 11:03:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jan  4 11:03:25 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Jan  4 11:03:29 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    27G     /var/
    22G     /var/lib/mysql/iobroker
    22G     /var/lib/mysql
    22G     /var/lib
    4.2G    /var/log
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18M     /opt/iobroker/iobroker-data/
    14M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.0M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.12.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
    + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
      system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
      system.adapter.devices.0                : devices               : debian                                   -  enabled
    + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
      system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
      system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
      system.adapter.flot.0                   : flot                  : debian                                   -  enabled
    + system.adapter.history.0                : history               : debian                                   -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : debian                                   -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : debian                                   -  enabled
      system.adapter.ical.1                   : ical                  : debian                                   -  enabled
      system.adapter.ical.2                   : ical                  : debian                                   -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
    + system.adapter.info.0                   : info                  : debian                                   -  enabled
    + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
    + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
    + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
    + system.adapter.logparser.0              : logparser             : debian                                   -  enabled
    + system.adapter.meross.0                 : meross                : debian                                   -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
    + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
    + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
    + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
      system.adapter.rpi2.1                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : debian                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
    + system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
    + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
    + system.adapter.tibberlink.0             : tibberlink            : debian                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
    + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
      system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
      system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
      system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
      system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
      system.adapter.vis.0                    : vis                   : debian                                   -  enabled
    + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Controller "js-controller": 5.0.17   , installed 4.0.24 [Updatable]
    Adapter    "unifi"        : 0.6.7    , installed 0.6.7
    Adapter    "zigbee"       : 1.9.7    , installed 1.8.23 [Updatable]
    Objects and States
    Objects:        28092
    States:         22715
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12641      525/sshd: /usr/sbin
    tcp6       0      0 :::3306                 :::*                    LISTEN      110        12676      569/mariadbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12643      525/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13987      780/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13921      394/avahi-daemon: r
    udp        0      0 0.0.0.0:58656           0.0.0.0:*                           108        13923      394/avahi-daemon: r
    udp6       0      0 :::41470                :::*                                108        13924      394/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13999      780/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13922      394/avahi-daemon: r
    2024-01-08 09:11:19.565  - info: zigbee.0 (765235) debug devices set to []
    2024-01-08 09:11:27.300  - info: host.raspberrypi received SIGTERM
    2024-01-08 09:11:27.306  - info: zigbee.0 (765235) cleaned everything up...
    2024-01-08 09:11:27.324  - info: rpi2.1 (765173) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2024-01-08 09:11:27.312  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 (force=false, process=true)
    2024-01-08 09:11:27.314  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-01-08 09:11:27.316  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 (force=false, process=true)
    2024-01-08 09:11:27.337  - info: rpi2.1 (765173) Got terminate signal TERMINATE_YOURSELF
    2024-01-08 09:11:27.336  - info: enigma2.0 (765291) Got terminate signal TERMINATE_YOURSELF
    2024-01-08 09:11:27.379  - info: host.raspberrypi stopInstance system.adapter.rpi2.1 send kill signal
    2024-01-08 09:11:27.384  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2024-01-08 09:11:27.386  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 send kill signal
    2024-01-08 09:11:27.619  - info: zigbee.0 (765235) Zigbee: disabling joining new devices.
    2024-01-08 09:11:27.670  - info: zigbee.0 (765235) Got terminate signal TERMINATE_YOURSELF
    2024-01-08 09:11:27.834  - info: enigma2.0 (765291) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2024-01-08 09:11:27.879  - info: zigbee.0 (765235) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2024-01-08 09:11:28.310  - info: host.raspberrypi instance system.adapter.rpi2.1 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2024-01-08 09:11:28.387  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 765235
    2024-01-08 09:11:28.389  - info: host.raspberrypi stopInstance system.adapter.enigma2.0 killing pid 765291
    2024-01-08 09:11:28.834  - info: host.raspberrypi instance system.adapter.enigma2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2024-01-08 09:11:28.836  - info: host.raspberrypi All instances are stopped.
    2024-01-08 09:11:29.178  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
    2024-01-08 09:11:29.180  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
    2024-01-08 09:11:29.181  - info: host.raspberrypi All instances are stopped.
    2024-01-08 09:11:29.271  - info: host.raspberrypi terminated
    Vielen Dank!
    #742
    @djsirius sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
    npm ERR! network request to https://registry.npmjs.org/@iobroker%2Fjsonltool failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
    Schau mal nach, ob dein Router / Internet-Provider zur Gänze auf IPv6 umgestellt ist.
    Z. B. in der FritzBox muss zum einen IPv6 grundsätzlich angehakt sein, aber auch das Routing nach draußen muss auf IPv6 gestellt werden.
      djsirius
      schrieb am zuletzt editiert von djsirius
      #743
      macht das Sinn, weil das Master System diesen Fehler nicht hat. Die laufen ja beide über den selben Router.
      Ist IPv6 ist aber auch angehakt.
      djsirius
      • D djsirius
        djsirius
        #744
        Ich habe jetzt ein Downgrade von Nodejs gemacht, weil ich nicht weiter komme.
        Wenn noch jemand eine Idee hat, bitte her damit. Ich bin ratlos! :-(
        djsirius
        Thomas BraunT Marc BergM 2 Antworten Letzte Antwort
        • D djsirius
          #745
          @djsirius
          Ist zu 99,9% etwas in deinem Netzwerk.
          • D djsirius
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #746
            mach mal auf master und slave jeweils:
            ping registry.npmjs.org
            ping -4 registry.npmjs.org
            ping -6 registry.npmjs.org
            Thomas BraunT D 3 Antworten Letzte Antwort
            • Marc BergM Marc Berg
              #747
              @marc-berg
              Haste gerade die traceroute commandos für IPv6 und IPv4 parat?
                djsirius
                #748
                @marc-berg said in Diskussion zum HowTo nodejs-Installation und upgrade:
                ping registry.npmjs.org <- geht auf beiden nicht
                ping -4 registry.npmjs.org <- geht auf beiden
                ping -6 registry.npmjs.org <- geht auf beiden nicht
                djsirius
                  @marc-berg
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  #749
                  @thomas-braun sagte in Diskussion zum HowTo nodejs-Installation und upgrade:
                  traceroute6  heise.de
                  traceroute  heise.de
                  • D djsirius
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    #750
                    die Response zumindest für
                    wäre interessant
                    EDIT: und
                    nslookup registry.npmjs.org
                      wäre interessant
                      EDIT: und
                      djsirius
                      #751
                      wäre interessant
                      EDIT: und
                      iobroker@debian:~$ ping registry.npmjs.org
                      PING registry.npmjs.org(2606:4700::6810:23 (2606:4700::6810:23)) 56 data bytes
                      ^C
                      --- registry.npmjs.org ping statistics ---
                      288 packets transmitted, 0 received, 100% packet loss, time 293895ms
                      iobroker@debian:~$ nslookup registry.npmjs.org
                      Server:         192.168.1.1
                      Address:        192.168.1.1#53
                      Non-authoritative answer:
                      Address: 104.16.31.34
                      Address: 104.16.29.34
                      Address: 104.16.0.35
                      Address: 104.16.25.34
                      Address: 104.16.27.34
                      Address: 104.16.30.34
                      Address: 104.16.2.35
                      Address: 104.16.26.34
                      Address: 104.16.24.34
                      Address: 104.16.28.34
                      Address: 104.16.1.35
                      Address: 104.16.3.35
                      Address: 2606:4700::6810:23
                      Address: 2606:4700::6810:1922
                      Address: 2606:4700::6810:1822
                      Address: 2606:4700::6810:1a22
                      Address: 2606:4700::6810:1c22
                      Address: 2606:4700::6810:223
                      Address: 2606:4700::6810:323
                      Address: 2606:4700::6810:1d22
                      Address: 2606:4700::6810:123
                      Address: 2606:4700::6810:1b22
                      Address: 2606:4700::6810:1e22
                      Address: 2606:4700::6810:1f22
                      djsirius
                      Marc BergM D 2 Antworten Letzte Antwort
                      • D djsirius
                        wäre interessant
                        EDIT: und
                        ^C
                        Server:         192.168.1.1
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        #752
                        @djsirius
                        Wie es für mich aussieht, ist IPv6 auf Betriebssystemseite priorisiert (was Standard ist), aber es kommt keine Kommunikation auf dem Protokoll zustande. Da musst du wirklich in deinem Netzwerk suchen, wahrscheinlich bei den Router Einstellungen.
                        • D djsirius
                          wäre interessant
                          EDIT: und
                          ^C
                          Server:         192.168.1.1
                          djsirius
                          #753
                          Auf meinem Windows-Rechner geht!
                          Ping wird ausgeführt für registry.npmjs.org [104.16.29.34] mit 32 Bytes Daten:
                          Antwort von 104.16.29.34: Bytes=32 Zeit=12ms TTL=58
                          Antwort von 104.16.29.34: Bytes=32 Zeit=11ms TTL=58
                          Ping-Statistik für 104.16.29.34:
                              Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                              (0% Verlust),
                          Ca. Zeitangaben in Millisek.:
                              Minimum = 11ms, Maximum = 12ms, Mittelwert = 11ms
                          Aber ping -6 registry.npmjs.org geht nicht!
                          djsirius
                          • D djsirius
                                (0% Verlust),
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            #754
                            Ja wahrscheinlich ist dort IPv6 abgeschaltet.
                            Du könntest jetzt IPv4 auf den beiden Kisten priorisieren, das wäre dann aber nur ein dickes Pflaster auf eine weiter offene Wunde. Das holt dich irgendwann ein.
                              djsirius
                              #755
                              @marc-berg bringt ein Screenshot von den Einstellungen in der Fritzbox was?
                              djsirius
                              • D djsirius
                                #756
                                Von der entsprechenden Seite vielleicht.
                                Welchen Anschluss hast du denn da bei dir?
                                  djsirius
                                  #757
                                  Ich habe einen Anschluß von NetCologne 100 Mbit
                                  djsirius
                                  • D djsirius
                                    #758
                                    @djsirius
                                    Das muss mit höchster Sicherheit auf 'IPv6 nativ' umgestellt werden.
                                    Mit deiner jetzigen Einstellung passiert nämlich genau das, was du jetzt beobachtest:
                                    Der Hostname wird zu einer IPv6 aufgelöst, die Adresse kann aber nicht angefahren werden, weil es da kein Routing hin gibt.
                                      @djsirius
                                      djsirius
                                      #759
                                      Ich habe es jetzt so eingestellt:
                                      Muss man danach die Server neustarten?
                                      djsirius
                                      • D djsirius
                                        #760
                                        Ausprobieren.
                                        Kannst auch nur das Netzwerkinterface neustarten, wenn es nicht von alleine funktioniert. Die Fritzbox würde ich aber mal neustarten.
                                        • D djsirius
                                          #761
                                          @djsirius
                                          Wichtig! Um eine Internetverbindung herstellen zu können, aktiviere bitte die IPv6-Unterstützung deines WLAN-Routers. Stelle deinen WLAN-Router so ein, dass eine native IPv6-Anbindung für den Internetzugang verwendet, die IPv4-Verbindung über DS-Lite hergestellt und die AFTR-Adresse automatisch über DHCPv6 ermittelt wird.
                                          Quelle:
                                          https://www.netcologne.de/privatkunden/hilfe/eigenen-router-einrichten/vdsl/
                                          Deine Fritzbox war/ist also falsch eingestellt.
