  4. Solarman PV, Bosswerk MI & Deye
jetz
565 Beiträge 68 Kommentatoren 261.6k Aufrufe 65 Beobachtet
  • Rene55R Rene55
    @ralle Die Meldungen kommen daher, dass Solarman in einer Änderung (vor einigen Wochen) die Werte statt numerisch jetzt im Klartext ausgibt. Die Lösung: im Objektbaum die drei oder vier betroffenen Werte löschen. Der Adapter legt die dann wieder neu (und richtig) an.
    ralleR
    ralleR
    ralle
    #488
    @rene55
    Danke, hat wohl geklappt, kannst du zu den nächsten Fehlern auch was sagen, die kommen von deinem anderen Adapter:
    deyeidc.1
    17713	2023-11-12 12:08:28.554	error	Error: Frame CheckSum faulty! be|28 | Error: Frame CheckSum faulty! be|28 at idcCore.checkDataFrame (/opt/iobroker/node_modules/iobroker.deyeidc/lib/idc-core.js:70:10) at Deyeidc.onData (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:170:24) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:158:10) at Socket.emit (node:events:517:28) at addChunk (node:internal/streams/readable:335:12) at readableAddChunk (node:internal/streams/readable:308:9) at Readable.push (node:internal/streams/readable:245:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    deyeidc.1
    17713	2023-11-12 11:38:30.051	error	Error: Frame CheckSum faulty! c2|cf | Error: Frame CheckSum faulty! c2|cf at idcCore.checkDataFrame (/opt/iobroker/node_modules/iobroker.deyeidc/lib/idc-core.js:70:10) at Deyeidc.onData (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:170:24) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:158:10) at Socket.emit (node:events:517:28) at addChunk (node:internal/streams/readable:335:12) at readableAddChunk (node:internal/streams/readable:308:9) at Readable.push (node:internal/streams/readable:245:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    deyeidc.1
    17713	2023-11-12 15:24:29.327	error	Error: Frame CheckSum faulty! be|dd | Error: Frame CheckSum faulty! be|dd at idcCore.checkDataFrame (/opt/iobroker/node_modules/iobroker.deyeidc/lib/idc-core.js:70:10) at Deyeidc.onData (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:170:24) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.deyeidc/main.js:158:10) at Socket.emit (node:events:517:28) at addChunk (node:internal/streams/readable:335:12) at readableAddChunk (node:internal/streams/readable:308:9) at Readable.push (node:internal/streams/readable:245:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
    • ralleR ralle
      @rene55
      deyeidc.1
      deyeidc.1
      deyeidc.1
      Rene55R
      Rene55R
      Rene55
      schrieb am zuletzt editiert von Rene55
      #489
      @ralle Die kommen nicht von meinem Adapter, der deckt die nur auf. Aber echt, die Checksumme wird im WR berechnet und der Adapter prüft die gegen. Machmal stimmt die eben nicht. Warum das so ist: keine Ahnung, aber bitte keine Panik und schauen wie oft dieser Fehler kommt.
      BTW: falscher Thread.
      • AutomationNicoA
        AutomationNicoA
        AutomationNico
        #490
        @Rene55 Hi, vielen Dank erstmal für den Adapter und für die Mühen die du da reingesteckt hast. Ich benutze den Adapter seit ca. einem halben Jahr und alles hat auch auf anhieb funktioniert. Seit ca. 3 Wochen habe ich aber folgendes Problem:
        host.iobroker
        2023-12-27 20:45:04.114	info	instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        solarmanpv.0
        2023-12-27 20:45:03.577	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
        solarmanpv.0
        2023-12-27 20:45:03.576	debug	[onReady] finished - stopping instance
        solarmanpv.0
        2023-12-27 20:45:03.575	debug	[main] catch "could not retrieve token."
        solarmanpv.0
        2023-12-27 20:45:03.574	warn	[initializeStation] error: undefined
        solarmanpv.0
        2023-12-27 20:45:01.982	debug	[checkUserData] Crc 8b9025b974a7394c32d8714c081bee50
        solarmanpv.0
        2023-12-27 20:45:01.947	debug	[onReady] started: solarmanpv.0
        solarmanpv.0
        2023-12-27 20:45:01.923	info	starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v18.19.0, js-controller: 5.0.17
        host.iobroker
        2023-12-27 20:45:00.044	info	instance system.adapter.solarmanpv.0 started with pid 170917
        Hab den Adapter schon einmal gelöscht, die Zugangsdaten, API-Token und App-ID neu eingetragen, aber keine Reaktion. Der Objektbaum ist natürlich jetzt leer durch das Löschen. So sehe ich ob er einmal Daten abgeholt hat. Sollte ich nochmal die App-ID und den API-Token anfragen? Weil eigentlich hat sich ja nichts geändert.
        Hat mal jemand ausprobiert, ob sich der Token ändert, wenn man das Login-Passwort ändert?
        Vielleicht kannst du mir weiter helfen.
        Gruß Nico
        • AutomationNicoA AutomationNico
          host.iobroker
          solarmanpv.0
          solarmanpv.0
          solarmanpv.0
          solarmanpv.0
          solarmanpv.0
          solarmanpv.0
          solarmanpv.0
          host.iobroker
          Gruß Nico
          Rene55R
          Rene55R
          Rene55
          #491
          @automationnico Es ist mit Sicherheit so, dass bei einem neuem Passwort auch ein neuer Token generiert werden muss. Eigentlich macht der Adapter das automatisch, weil so ein Token auch nach einiger Zeit (ich meine nach 90 Tagen) ungültig wird. Als Test kannst du bitte mal den Datenpunkt "checksumUserData" löschen.
          Wenn das nicht funktioniert - und deine Daten richtig sind - ist in der Cloud was verbogen und du musst dazu den Support von Solarman bemühen.
          AutomationNicoA 1 Antwort Letzte Antwort
          • Rene55R Rene55
            AutomationNicoA
            AutomationNicoA
            AutomationNico
            #492
            @rene55 Hi Rene, danke für deine schnelle Antwort. Ja, die Checksumme wird wieder erzeugt und als Objekt angelegt. Ich werde mal den Support von Solarman schreiben und fragen, ob die mir nochmal App-ID und Token schicken können.
            Dank dir erstmal.
            Gruß Nico
              Dank dir erstmal.
              Gruß Nico
              Rene55R
              Rene55R
              Rene55
              #493
              @automationnico Ja mach das so. Hatte ich vor zwei Monaten auch. Da war irgendendetwas bei Solarman im Argen. Hat etwa eine Woche gedauert - dann lief es wieder.
              • Rene55R Rene55
                AutomationNicoA
                AutomationNicoA
                AutomationNico
                schrieb am zuletzt editiert von AutomationNico
                #494
                @rene55 ok, hat daran gelegen. App-ID und Token wurden mir vom Support nochmal zugeschickt. Die haben dann funktioniert.
                Danke nochmal für die Verifizierung das alles normal laufen sollte. Das hilft manchmal schon zur Eingrenzung des Fehlers.
                Gruß Nico
                Edit: Achso und Gesundes neues Jahr ;-)
                • Rene55R
                  Rene55R
                  Rene55
                  #495
                  @automationnico Danke für dir Rückmeldung, und ebenfalls Gutes Neues Jahr.
                  • R
                    R
                    Ralf Topas
                    #496
                    Salü,
                    folgende Email habe ich von Solarman bekommen. Evtl. von Relevanz für den Adapter?
                    Dear valued user,
                    In order to provide you with a better experience, SOLARMAN will upgrade data centers from 2024-01-15 09:00 to 2024-01-15 17:00 (UTC+8). During the upgrade, OPENAPI service will be unavailable.
                    After the upgrade, please use the new OPENAPI domain https://globalapi.solarmanpv.com to replace previous domain https://api.solarmanpv.com . Your APPID and APPSECRET will remain the same, but you will need to request for a new token to access all your data under SOLARMAN account.
                    If you need historical data during the upgrade, we recommend that you use the historical data API (API 3.4 and API 4.3) to supplement it after the upgrade is completed.
                    Should you have any questions or concerns, please do not hesitate to contact us at customerservice@solarmanpv.com.
                    Thank you for choosing SOLARMAN platform, and we look forward to providing you with an even better user experience.
                    Sincerely,
                    The SOLARMAN Team
                    • R Ralf Topas
                      Salü,
                      Dear valued user,
                      Sincerely,
                      The SOLARMAN Team
                      Rene55R
                      Rene55R
                      Rene55
                      #497
                      @ralf-topas Die Mail habe ich auch bekommen. Allerdings verstehe ich den Sinn dahinter nicht. Die hier angegebene URL benutzen wir schon seit April vorigen Jahres!
                      Vielleicht wollen die uns nur sagen, dass an diesem Tag die Anwendung nicht funktionieren wird. Mal sehen.
                      • Rene55R Rene55
                        Aktuelle Test Version 0.5.1
                        Veröffentlichungsdatum 23.06.2022
                        Github Link https://github.com/raschy/ioBroker.solarmanpv
                        SolarmanPV, Adapter für Bosswerk MIxxx, Deyexxx.
                        Dieser Adapter dient dazu, Daten eines Balkonkraftwerks, die durch einen Wechselrichter "Bosswerk MI600" bereit gestellt werden, in ioBroker darzustellen. Nach Hinweisen ist dieser Adapter auch mit "Deye SUN300G3-EU-230" kompatibel. Er läuft ab Admin Version >5.
                        Ich gehe davon aus, dass die Anlage bisher durch die App "Solarman" beobachtet wird. Der Adapter holt die Daten aus dieser Cloud.
                        Zunächst muss beim Solarman-Support service@solarmanpv.com die benötigten Credentials (app_id & app_secret) beantragt werden. Möglicherweise kommt noch eine Rückfrage der Art: "Ich muss fragen, welche Plattform Sie verwenden? Welche Rolle spielen Sie? Sind Sie Einzelperson, OEM-Anbieter, Hersteller oder Distributor? Können Sie mir Ihre E-Mail-Adresse für die API mitteilen?".
                        Bei mir kam dann noch eine weitere Rückfrage: "Warum bewerben Sie sich für API?". Auch diese Frage habe ich höflich beantwortet und bekam dann am nächsten Tag die notwendigen Daten zugesendet.
                        Auf der Admin-Seite müssen die 4 Felder der Beschreibung entsprechend ausgefüllt
                        werden. Dieser Adapter ist als "scheduled" Adapter angelegt. Da die Daten in der Cloud nur ca. alle 6 Minuten aktualisiert werden, ist es nicht sinnvoll, den Adapter häufiger starten zu lassen.
                        Ich bin kein Profi-Programmierer und habe dies vor allem deswegen gemacht, weil die anderen Lösungen die ich bisher gefunden habe, mich nicht zufrieden gestellt haben.
                        Es ist mein erster Adapter, der sicher noch nicht perfekt programmiert ist oder evtl. noch kleinere Fehler enthält. Der Adapter läuft bei mir und macht was er soll. Mehr sollte es auch nicht werden.
                        Version 0.1.0 Nachdem ich lernen durfte, dass auch mehrere Stationen unter einem Account laufen können und dass sogar mehrere Wechselrichter innerhalb einer Station sein können, habe ich den Adapter dahingehend angepasst und auch die Datenstruktur um die 'Wechselrichter ID' erweitert.
                        Version 0.1.5 Ich hab den Adapter noch ein wenig erweitert, so dass er auch größere Wechselrichter mit 4 MPPTs verarbeiten kann. Auf der Admin-Seite ist ein Checkbutton "Inverter" hinzugekommen, der es auch ermöglicht, Hybrid-Wechselrichter auszulesen. Mangels Geräte (bzw. Zugriff auf ein Remote-Gerät) ist das aber noch nicht vollständig ausgetestet.
                        Version 0.2.0 Seit dieser Ausbaustufe werden auch die Daten aus den angeschlossenen Akkumulatoren, so denn der Wechselrichter das unterstützt, im ioBroker abgelegt. Auch hier gilt, da ich keine Akkus habe, dass ich auch hierfür die Unterstützung von netten Usern angewiesen war. Danke dafür.
                        Version 0.3.0 Seit dieser Version wird im Gegensatz zu den Vorgängerversionen keine Liste der zu ermittelnden Werte geführt, sondern es werden zunächst "alle" von der Api gelieferten Werte eingelesen. Das kann zu einer Flut neuer Datenpunkte werden. Der Benutzer kann über eine Blacklist die nicht benötigten Werte herausfiltern. Dazu trägt man im Userinterface unter Blacklist die Werte der ersten Spalte der Objekte durch Komma separiert ein, die man nicht sehen will. Die entsprechenden Datenpunkte können dann beherzt gelöscht werden, was die Anzahl der Objekte übersichtlicher macht.
                        Mein Credo von oben ('Mehr sollte es auch nicht werden.') kann ich wohl nicht mehr aufrecht erhalten. Durch die vielen Rückmeldungen ist der Adapter sehr vielfältig geworden, so dass er jetzt nicht nur die Daten von den Invertern lesen kann sondern auch vom Collector und den Batterien.
                        Somit ist es nicht verwunderlich, dass es auch die Versionen 0.4.x gab. aktuell ist die
                        Version 0.5.0 die folgende Veränderungen erfahren hat.
                        War es in der Version 0.3.0 schon möglich, dass aus der Flut der Daten, die aus der Cloud kommen, über "ausgeschlossene Werte" (vormals Blacklist) unwichtige Daten nicht mehr aktualisiert wurden, werden sie Datenpunkte jetzt auch direkt gelöscht. Manuelles löschen ist also nicht mehr notwendig. Dennoch ist die Auswahl der Datenpunkte individuelle Handarbeit. Dabei hat sich aber das Handling verbessert, so dass man die Werte jetzt besser sieht und auch wieder einzeln aktivieren kann.
                        Was ja auch noch auf der ToDo-Liste stand war, dass komplette Verzeichnisse ausgeblendet bzw. gelöscht werden können. Dazu gibt es jetzt einen neuen Tab "Systemmodule". Hier werden nach dem Start des Adapters die von der Cloud auslesbaren Module eingetragen und der User kann dann per Haken entscheiden, ob die Module interessant sind oder nicht.
                        Als letzte Neuerung ist hinzugekommen, dass ausgewählte Datenpunkte auf Null gesetzt werden können. Es mag für verschiedene Dashboards oder Grafiken befremdlich erscheinen, wenn bei völliger Dunkelheit noch 3-10 W Ertrag (letzter an die Cloud übermittelter Wert) angezeigt werden. Das kann man jetzt über
                        entsprechend dem eigenen Anspruch anpassen.
                        Für Fragen und Anregungen habe ich immer ein offenes Ohr. Bin mal gespannt, wie viele User diesen Adapter einsetzen werden.
                        spicerS
                        spicerS
                        spicer
                        schrieb am zuletzt editiert von spicer
                        #498
                        @rene55
                        Von wegen "Ich bin kein Profi-Programmierer und habe dies vor allem deswegen gemacht, weil die anderen Lösungen die ich bisher gefunden habe, mich nicht zufrieden gestellt haben."
                        Du hast mir mehr als nur den Tag gerettet mit Deinem Adapter.
                        Gute Arbeit. Vielen Dank
                        Wenn es mehrere Möglichkeiten gibt, eine Aufgabe zu erledigen, und eine davon in einer Katastrophe endet oder sonstwie unerwünschte Konsequenzen nach sich zieht, dann wird es jemand genau so machen. Alles, was schiefgehen kann, wird auch schiefgehen.
                        (Murphys Gesetz)
                        • spicerS spicer
                          @rene55
                          Rene55R
                          Rene55R
                          Rene55
                          #499
                          @spicer sagte in Solarman PV, Bosswerk MI & Deye:
                          Danke für das Lob, aber ich bin wirklich kein professioneller Programmierer aber ich gebe mein bestes und lerne jeden Tag noch dazu.
                          • K
                            K
                            kte
                            #500
                            kann es sein, dass sich mit der Umstellung auch die E-Mail geändert hat? Ich bekommen immer einen Serverfehler beim Abschicken der Nachricht. Ich habe jetzt alternativ customerservice@solarmanpv.com genutzt. Da ging die Nachricht zumindest raus.
                            • K kte
                              Rene55R
                              Rene55R
                              Rene55
                              #501
                              @kte Das wird wohl nichts mit der Umstellung zu tun haben. Alternativ kenn ich auch nur noch die 'upgrade@solarmanpv.com'.
                              • Rene55R Rene55
                                Klaus BeckK
                                Klaus BeckK
                                Klaus Beck
                                #502
                                @rene55 Der Adapter lief bis zum 09.02.2024 absolut problemlos. Seit diesem Datum bekomme ich nun keine Werte mehr, Es kommt nur:
                                solarmanpv.0 2024-02-14 15:54:04.657 warn [initializeStation] error: undefined
                                im Logfile.
                                Zum Testen habe ich nun in einer VM den Iobroker neu aufgesetzt und nur diesen Adapter installiert. Gleiches Ergebnis.
                                Hat jemand den gleichen Effekt oder einen guten Tip wie ich wieder an Werte komme.
                                In der App sind alle Werte vorhanden. Die Übertragung vom WR zur Cloud läuft also.
                                • Klaus BeckK Klaus Beck
                                  im Logfile.
                                  Rene55R
                                  Rene55R
                                  Rene55
                                  #503
                                  @klaus-beck Da vermute ich mal, dass irgendetwas bei SolarmanPV schief gelaufen ist. Hier wird ja seid Wochen intensiv gearbeitet. Wie bei AutomationNico (siehe #494) musst du wahrscheinlich den Support anschreiben, dass sie dir den Account wieder gerade rücken oder du bekommst neue APP-ID und APP-Secret. Dann wird es wohl wieder funktionieren.
                                  Klaus BeckK 1 Antwort Letzte Antwort
                                  • Rene55R Rene55
                                    Klaus BeckK
                                    Klaus BeckK
                                    Klaus Beck
                                    #504
                                    @rene55 Die Adresse customerservice@solarmanpv.com läuft bei mir immer wieder auf Fehler. Auf der Webseite gibt es auch keine andere Adresse. Ich habe es jetzt mal über das Kontaktformular der Webseite versucht, mal sehen ob ich Antwort erhalte.
                                      Rene55R
                                      Rene55R
                                      Rene55
                                      #505
                                      @klaus-beck Am 15.01.2024 gings noch mit der Adresse. Wenns per Formular nicht geht, kann man auch noch unter upgrade@solarmanpv.com versuchen.
                                      • Rene55R Rene55
                                        Klaus BeckK
                                        Klaus BeckK
                                        Klaus Beck
                                        #506
                                        @rene55 Die haben offentsichlich grössere Probleme. Diesen Fehler bekomme ich:
                                        This message was created automatically by mail delivery software.
                                        A message that you sent could not be delivered to one or more of
                                        its recipients. This is a permanent error.
                                        The following address failed:
                                        customerservice@solarmanpv.com:
                                            non-existent domain
                                        Auch deine Adresse upgrade@solarmanpv.com läuft, da gleiche Domäne, auf den gleiche Fehler.
                                              non-existent domain
                                          Rene55R
                                          Rene55R
                                          Rene55
                                          #507
                                          @klaus-beck Please hold the line . . .
                                          83.8k
