  3. Einsteigerfragen
  4. Installation
  5. Raspberry Pi 5 8Gb Iobroker Installation
    apollon77A
48 Beiträge 12 Kommentatoren 17.6k Aufrufe 8 Beobachtet
    @hg6806
    Der Hase liegt dort im Pfeffer:
    2229 verbose stack FetchError: Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fdb-states-file: Socket timeout
    2229 verbose stack     at /usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:170:15
    2229 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    2229 verbose stack     at async Response.json (/usr/lib/node_modules/npm/node_modules/minipass-fetch/lib/body.js:75:17)
    2229 verbose stack     at async RegistryFetcher.packument (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:94:25)
    2229 verbose stack     at async RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:118:23)
    2229 verbose stack     at async Promise.all (index 43)
    2229 verbose stack     at async #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1034:5)
    2229 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
    2229 verbose stack     at async Promise.all (index 1)
    2229 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
    2230 verbose cwd /opt/iobroker
    2231 verbose Linux 6.1.0-rpi4-rpi-2712
    2232 verbose node v18.18.2
    2233 verbose npm  v9.8.1
    2234 error code ERR_SOCKET_TIMEOUT
    2235 error errno ERR_SOCKET_TIMEOUT
    2236 error network Invalid response body while trying to fetch https://registry.npmjs.org/@iobroker%2fdb-states-file: Socket timeout
    2237 error network This is a problem related to network connectivity.
    2237 error network In most cases you are behind a proxy or have bad network settings.
    2237 error network
    2237 error network If you are behind a proxy, please make sure that the
    2237 error network 'proxy' config is set properly.  See: 'npm help config'
    2238 verbose exit 1
    Warum es an der Stelle hakt, bei den anderen Modulen aber nicht kann ich dir nicht sagen.
    hg6806H
    hg6806H
    hg6806
    Ok
    Da es ja nach mehrfachen Versuchen bei @teletapi geklappt hat, liegt es doch nahe, dass das Timeout der ersten Zeile vielleicht nur höher gesetzt werden muss?
    @teletapi Läuft bei dir ioBroker nun auf dem Pi5?
    teletapiT 1 Antwort Letzte Antwort
    • Marc BergM
      Marc BergM
      Marc Berg
      Wenn man das hier so liest, könnte man glauben, dass der Pi 5 grundsätzliche Netzwerkprobleme hat, oder?
      Drei Leute mit ähnlichen Konnektivitätsfehlern ...
      • hg6806H
        hg6806H
        hg6806
        Bei mir läuft es jetzt auch.
        Nach dem 3. Installationsversuch.
        • hg6806H hg6806
          Ok
          teletapiT
          teletapiT
          teletapi
          schrieb am zuletzt editiert von teletapi
          @hg6806 Ja läuft ist zwar noch nicht produktiv im Einsatz aber läuft
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: Raspberrypi5
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi6-rpi-2712
              Architecture: arm64
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           00:31:49 up 24 min,  2 users,  load average: 0.61, 0.37, 0.25
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2023-11-11 00:31:49 CET
                     Universal time: Fri 2023-11-10 23:31:49 UTC
                           RTC time: Fri 2023-11-10 23:31:49
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.4G        2.9G        4.3G        5.3M        1.4G        5.6G
          Swap:           104M          0B        104M
          Total:          8.5G        2.9G        4.4G
                   8053 M total memory
                   2721 M used memory
                   2616 M active memory
                    887 M inactive memory
                   4120 M free memory
                     75 M buffer memory
                   1237 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          vc_gencmd_read_response returned -1
          error=1 error_msg="Command not registered"
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.8G     0  3.8G   0% /dev
          tmpfs          tmpfs     806M  5.1M  801M   1% /run
          /dev/mmcblk0p2 ext4       59G  5.4G   50G  10% /
          tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
          tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
          [Sat Nov 11 00:07:42 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
          [Sat Nov 11 00:07:44 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Nov 11 00:07:46 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          939M    /var/
          542M    /var/lib
          361M    /var/lib/influxdb/engine/data/2a3f1759f802b32d/autogen
          Archived and active journals take up 80.0M in the file system.
          /opt/iobroker/backups:
          447M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          302M    /opt/iobroker/iobroker-data/
          220M    /opt/iobroker/iobroker-data/files
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          62M     /opt/iobroker/iobroker-data/node-red.0
          61M     /opt/iobroker/iobroker-data/node-red.0/node_modules
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          14M     /opt/iobroker/iobroker-data/objects.jsonl
          8.9M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js
          USB-Devices by-id:
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.16
          admin:          6.12.2
          javascript:     7.1.6
          Adapters from github:   2
          Adapter State
          + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
            system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             - disabled
          + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
          + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
          + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             - disabled
          + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
          + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12001
          + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12010
          + system.adapter.hm-rpc.3                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
          + system.adapter.hue-extended.0           : hue-extended          : Raspberrypi5                             -  enabled
            system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
          + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : Raspberrypi5                             -  enabled
          + system.adapter.iot.0                    : iot                   : Raspberrypi5                             -  enabled
          + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
          + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
            system.adapter.modbus.0                 : modbus                : Raspberrypi5                             - disabled
          + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
          + system.adapter.node-red.0               : node-red              : Raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nuki.0                   : nuki                  : Raspberrypi5                             -  enabled
          + system.adapter.opendtu.0                : opendtu               : Raspberrypi5                             -  enabled
          + system.adapter.panasonic-viera.0        : panasonic-viera       : Raspberrypi5                             -  enabled
          + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
          + system.adapter.shelly.0                 : shelly                : Raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
            system.adapter.smartmeter.0             : smartmeter            : Raspberrypi5                             - disabled
            system.adapter.smartmeter.1             : smartmeter            : Raspberrypi5                             - disabled
          + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
          + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.12.2   , installed 6.12.2
          Adapter    "alexa2"       : 3.26.1   , installed 3.26.1
          Adapter    "alias-manager": 1.2.6    , installed 1.2.6
          Adapter    "backitup"     : 2.9.1    , installed 2.9.1
          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
          Adapter    "discovery"    : 4.2.0    , installed 4.2.0
          Adapter    "fritzdect"    : 2.5.8    , installed 2.5.8
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "ical"         : 1.13.3   , installed 1.13.3
          Adapter    "info"         : 2.0.0    , installed 2.0.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.16   , installed 5.0.16
          Adapter    "modbus"       : 6.0.1    , installed 6.0.1
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
          Adapter    "node-red"     : 4.0.3    , installed 4.0.3
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
          Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
          Adapter    "socketio"     : 6.6.0    , installed 6.6.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "telegram"     : 3.0.0    , installed 3.0.0
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Objects and States
          Objects:        9004
          States:         8403
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16637      968/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16630      968/iobroker.js-con
          tcp        0      0 192.168.178.121:12001   0.0.0.0:*               LISTEN      1001       17859      1336/io.hm-rpc.1
          tcp        0      0 192.168.178.121:12010   0.0.0.0:*               LISTEN      1001       14188      1351/io.hm-rpc.2
          tcp        0      0 192.168.178.121:18701   0.0.0.0:*               LISTEN      1001       17824      1306/io.hm-rpc.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17696      1113/node-red
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18673      1433/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        961        794/mosquitto
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18048      1454/io.sonoff.0
          tcp        0      0 192.168.178.121:2001    0.0.0.0:*               LISTEN      1001       17887      1366/io.hm-rpc.3
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23565      2264/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          975        807/sshd: /usr/sbin
          tcp        0      0 192.168.178.121:9092    0.0.0.0:*               LISTEN      1001       23892      2310/io.nuki.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17483      996/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25013      2451/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23369      2432/io.socketio.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        16591      891/influxd
          tcp6       0      0 :::3000                 :::*                    LISTEN      107        15958      967/grafana
          tcp6       0      0 :::1883                 :::*                    LISTEN      106        962        794/mosquitto
          tcp6       0      0 :::22                   :::*                    LISTEN      0          977        807/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15696      677/avahi-daemon: r
          udp        0      0 0.0.0.0:60563           0.0.0.0:*                           104        15698      677/avahi-daemon: r
          udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          17446      758/NetworkManager
          udp6       0      0 fe80::38be:beb2:fe6:546 :::*                                0          16559      758/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        15697      677/avahi-daemon: r
          udp6       0      0 :::34544                :::*                                104        15699      677/avahi-daemon: r
          2023-11-11 00:10:01.823  - info: simple-api.0 (2409) Allow states only when user is owner: false
          2023-11-11 00:10:05.024  - info: host.Raspberrypi5 instance system.adapter.socketio.0 started with pid 2432
          2023-11-11 00:10:05.985  - info: socketio.0 (2432) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.18.2, js-controller: 5.0.16
          2023-11-11 00:10:06.016  - warn: socketio.0 (2432) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
          2023-11-11 00:10:06.044  - info: socketio.0 (2432) socket.io server listening on port 8084
          2023-11-11 00:10:09.006  - info: host.Raspberrypi5 instance system.adapter.web.0 started with pid 2451
          2023-11-11 00:10:09.929  - info: web.0 (2451) starting. Version 6.1.10 in /opt/iobroker/node_modules/iobroker.web, node: v18.18.2, js-controller: 5.0.16
          2023-11-11 00:10:10.067  - info: web.0 (2451) socket.io server listening on port 8082
          2023-11-11 00:10:10.072  - info: web.0 (2451) http server listening on port 8082
          2023-11-11 00:10:22.543  - info: cloud.0 (1526) Trying to connect as system.user.admin to cloud
          2023-11-11 00:10:22.667  - info: cloud.0 (1526) Connection changed: connect
          2023-11-11 00:21:24.723  - info: admin.0 (996) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
          2023-11-11 00:30:00.108  - info: host.Raspberrypi5 instance system.adapter.ical.0 started with pid 4855
          2023-11-11 00:30:01.141  - info: ical.0 (4855) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.18.2, js-controller: 5.0.16
          xxxxxxxxxxxxxxxx
          2023-11-11 00:30:06.664  - info: ical.0 (4855) Terminated (NO_ERROR): Without reason
          2023-11-11 00:30:07.183  - info: host.Raspberrypi5 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2023-11-11 00:30:56.211  - info: admin.0 (996) ==> Connected system.user.admin from ::ffff:192.168.178.63
          2023-11-11 00:31:04.428  - info: host.Raspberrypi5 "system.adapter.telegram.0" enabled
          2023-11-11 00:31:04.554  - info: host.Raspberrypi5 instance system.adapter.telegram.0 started with pid 5016
          2023-11-11 00:31:05.767  - info: telegram.0 (5016) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v18.18.2, js-controller: 5.0.16
          2023-11-11 00:31:24.629  - info: admin.0 (996) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
          • hg6806H
            hg6806H
            hg6806
            schrieb am zuletzt editiert von hg6806
            Die Fehler haben evtl. etwas mit einer zu langsamen SD Karte zu tun.
            Ich habe jetzt bestimmte 4-5x auf dem Pi5 neu installiert und mit einer Sandisk Extreme pro KEINE Probleme gehabt.
            Nur mit einer langsameren Karte hatte ich die von allen beschriebenen Fehler.
            Vielleicht ein Zufall, aber bei solchen Sachen glaube ich nicht an Zufälle :-)
            Also, bitte das mal checken.
            ioBroker auf einer SD Karte zu installieren ist natürlich nur zulange von Dauer bis es ein PCIe HAT dafür gibt.
            • hg6806H hg6806
              teletapiT
              teletapiT
              teletapi
              @hg6806 said in Raspberry Pi 5 8Gb Iobroker Installation:
              PCIe
              Ich halte schon dauernd Ausschau danach abernoch tut sich nix besonderes was die neuen M.2 angeht, wobei mir ein System ähnlich wie mit dem Argon one M.2 Gehäuse schon reichen würde.
              Ich hab gerade mal so eine sandisk Extreme Pro geordert
              und wenn die da ist werde ich das auch mal testen
              hg6806H 1 Antwort Letzte Antwort
              • teletapiT teletapi
                PCIe
                hg6806H
                hg6806H
                hg6806
                @teletapi
                Genau, die habe ich auch. Die höhere Geschwindigkeit merkt man definitiv!
                Auf jeden Fall macht der 5er echt Laune.
                • hg6806H hg6806
                  @teletapi
                  teletapiT
                  teletapiT
                  teletapi
                  @hg6806
                  Ich hab heute die sd Karte bekommen und hab das gleich getestet und es hat auf Anhieb funktioniert.
                  • I
                    I
                    itwegner72
                    Der Raspberry 5 macht Richtig Laune.
                    Habe meine ioBroker Installation nun komplett fertig auf dem Raspberry 5 mit dem Pineberry Pi BM1L HatDrive! Bottom NVMe Adapter und einer SAMSUNG 980 Festplatte Retail 1 TB SSD M.2 NVMe intern.
                    Läuft alles Super Flüssig und sowas von fix gegenüber dem RPi4, bin einfach nur Begeistert.
                    Kann ich allen nur empfehlen, wer mit dem Raspberry arbeitet.
                    mcm1957M Meister MopperM S 3 Antworten Letzte Antwort
                    • I itwegner72
                      mcm1957M
                      mcm1957M
                      mcm1957
                      @itwegner72
                      Welches Gehäuse hast du im Einsatz?
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      I 1 Antwort Letzte Antwort
                      • I itwegner72
                        Meister MopperM
                        Meister MopperM
                        Meister Mopper
                        @itwegner72 sagte in Raspberry Pi 5 8Gb Iobroker Installation:
                        Wieviel Energie zieht der im ioBroker-Betrieb bei dir?
                        Proxmox und HA ...
                        WinniW I 2 Antworten Letzte Antwort
                          WinniW
                          WinniW
                          Winni
                          @meister-mopper schau hier:
                          https://forum.iobroker.net/topic/68665/rasperry-5-im-anrollen/52
                          • I itwegner72
                            S
                            S
                            Snopy_16
                            Hast du eventuell Links von deinen Komponenten?
                            Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
                            LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
                            iobroker auf Proxmox VM
                            Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
                            FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
                            • mcm1957M mcm1957
                              @itwegner72
                              I
                              I
                              itwegner72
                              schrieb am zuletzt editiert von itwegner72
                              @mcm57
                              Ein Selbstgebautes aus Holz und dem 3D Drucker. Kann die Tage mal ein Foto hochladen. Ist mit Display.
                              Er ist auf 2900Mhz getaktet und hat einen zusätzlichen Lüfter an der Oberseite plus folgenden Kühler auf dem Raspberry.
                              https://www.kaufland.de/product/480466071/?search_value=raspberry pi 5
                              Temperatur liegt immer so bei 40 Grad im Normalbetrieb.
                              Anzeige läuft allerdings noch nicht auf dem Raspi5 mit Bockworm, da sich das bei Bockworm mit Python was geändert hat und ich noch nicht dazu gekommen bin mich da reinzufuchsen.
                              Deshalb sind die Bilder mit dem Display von meinem Raspi4 8Gb (im gleichen Gehäuse) aufgenommen. Der Pi4 läuft allerdings gefühlt 8x langsammer als der Pi5.
                              • S Snopy_16
                                I
                                I
                                itwegner72
                                @snopy_16
                                Den Raspberry 5 8Gb hatte ich bei Kaufland gekauft (weil er zu dem Zeitpunkt nicht überall so schnell erhältlich war und ich ihn unbedingt haben wollte).
                                https://www.kaufland.de/product/482626171/?search_value=raspberry pi 5
                                Dazu dann zur besseren Kühlung folgendes.
                                Das Hat ist folgendes.
                                https://www.welectron.com/Pineberry-Pi-BM1L-HatDrive-Bottom-NVMe-Adapter-fuer-Raspberry-Pi-5
                                Und die SSD kommt von MediaMarkt (Hatte für eine Woche eine von Samsung drin wie oben schon mal beschrieben ; habe die durch folgende ausgetauscht).
                                https://www.mediamarkt.de/de/product/_crucial-p5-plus-ssd-intern-500-gb-ssd-m2-via-nvme-intern-2749350.html
                                  I
                                  I
                                  itwegner72
                                  @meister-mopper
                                  Messe ich die Tage mal aus.
                                  • I itwegner72
                                    @mcm57
                                    I
                                    I
                                    itwegner72
                                    @itwegner72
                                    • I itwegner72
                                      @mcm57
                                      I
                                      I
                                      itwegner72
                                      84.0k
