- ioBroker Community Home
- Deutsch
- ioBroker Allgemein
- Iobroker Oberfläche langsam. Störmeldungen
Der Befehl lautet iob diag, war ein Tippfehler. Bitte nochmal probieren und Ausgabe posten.
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : aarch64 Userland : armhf Systemuptime and Load: 08:02:46 up 1:37, 3 users, load average: 1.78, 2.35, 2.34 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Sun 2023-12-24 08:02:46 CET Universal time: Sun 2023-12-24 07:02:46 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: true Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 2.1G 1.2G 35M 4.5G 5.5G Swap: 99M 0B 99M Total: 7.9G 2.1G 1.3G 7811 M total memory 2123 M used memory 4157 M active memory 2150 M inactive memory 1153 M free memory 158 M buffer memory 4376 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 459G 19G 422G 5% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 936K 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/sda1 vfat 253M 51M 202M 20% /boot tmpfs tmpfs 782M 24K 782M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sun Dec 24 06:25:29 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:DB:2E:50 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=6b8e45ad-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles [Sun Dec 24 06:25:32 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none. [Sun Dec 24 06:25:32 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2. [Sun Dec 24 06:25:35 2023] EXT4-fs (sda2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime `-/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro Files in neuralgic directories: /var: 2.3G /var/ 2.0G /var/log 1.9G /var/log/journal/3e23e34d17484a28b9473f69f7d9d21c 1.9G /var/log/journal 151M /var/cache Archived and active journals take up 1.8G in the file system. /opt/iobroker/backups: 5.0G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 2.2G /opt/iobroker/iobroker-data/ 1.3G /opt/iobroker/iobroker-data/esphome.0/.esphome/build 1.3G /opt/iobroker/iobroker-data/esphome.0/.esphome 1.3G /opt/iobroker/iobroker-data/esphome.0 366M /opt/iobroker/iobroker-data/history The five largest files in iobroker-data are: 34M /opt/iobroker/iobroker-data/objects.jsonl 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 24M /opt/iobroker/iobroker-data/esphome.0/.esphome/build/heizstab/.pioenvs/heizstab/libFrameworkArduino.a 24M /opt/iobroker/iobroker-data/esphome.0/.esphome/build/heizstab-148/.pioenvs/heizstab-148/libFrameworkArduino.a 24M /opt/iobroker/iobroker-data/esphome.0/.esphome/build/heizstab-147/.pioenvs/heizstab-147/libFrameworkArduino.a USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 0 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled system.adapter.alias-manager.0 : alias-manager : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled + system.adapter.email.0 : email : raspberrypi - enabled + system.adapter.esphome.0 : esphome : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - disabled system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - disabled + system.adapter.heizoel.0 : heizoel : raspberrypi - enabled + system.adapter.history.0 : history : raspberrypi - enabled system.adapter.ical.1 : ical : raspberrypi - enabled system.adapter.ical.2 : ical : raspberrypi - enabled + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.javascript.1 : javascript : raspberrypi - enabled + system.adapter.javascript.2 : javascript : raspberrypi - enabled + system.adapter.logparser.0 : logparser : raspberrypi - enabled system.adapter.mqtt.0 : mqtt : raspberrypi - disabled, port: 1884, bind: 0.0.0.0 + system.adapter.opendtu.0 : opendtu : raspberrypi - enabled + system.adapter.operating-hours.0 : operating-hours : raspberrypi - enabled + system.adapter.ping.0 : ping : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.s7.0 : s7 : raspberrypi - enabled + system.adapter.scenes.0 : scenes : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.smartthings.0 : smartthings : raspberrypi - enabled + system.adapter.snmp.0 : snmp : raspberrypi - enabled + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.synology.0 : synology : raspberrypi - enabled, port: 5000 + system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - enabled + system.adapter.tankerkoenig.1 : tankerkoenig : raspberrypi - enabled + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.time-switch.0 : time-switch : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - enabled system.adapter.vis-history.0 : vis-history : raspberrypi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspberrypi - disabled system.adapter.vis-justgage.0 : vis-justgage : raspberrypi - disabled system.adapter.vis-material-webfont.0 : vis-material-webfont : raspberrypi - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - enabled + system.adapter.vw-connect.0 : vw-connect : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.wled.0 : wled : raspberrypi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.synology.0 : synology : raspberrypi - enabled, port: 5000 + system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.telegram.1 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): beta Installed ioBroker-Instances Used repository: beta Adapter "admin" : 6.13.5 , installed 6.12.0 [Updatable] Adapter "alexa2" : 3.26.3 , installed 3.26.3 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "backitup" : 2.9.8 , installed 2.8.7 [Updatable] Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "email" : 1.2.1 , installed 1.2.0 [Updatable] Adapter "esphome" : 0.5.0-beta.8, installed 0.2.4 [Updatable] Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fullybrowser" : 3.0.9 , installed 3.0.6 [Updatable] Adapter "heizoel" : 1.0.3 , installed 1.0.3 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.13.5 , installed 1.13.3 [Updatable] Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.5.1 , installed 7.1.6 [Updatable] Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "logparser" : 2.2.1 , installed 2.2.0 [Updatable] Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "opendtu" : 1.0.1 , installed 1.0.1 Adapter "operating-hours": 1.0.6 , installed 1.0.6 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "s7" : 1.4.2 , installed 1.3.15 [Updatable] Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.7.0 , installed 6.6.1 [Updatable] Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartthings" : 0.1.1 , installed 0.0.4 [Updatable] Adapter "snmp" : 3.1.0 , installed 3.1.0 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sourceanalytix": 0.4.14 , installed 0.4.12 [Updatable] Adapter "synology" : 3.0.1 , installed 3.0.1 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.0 [Updatable] Adapter "time-switch" : 2.2.2 , installed 2.2.2 Adapter "trashschedule": 3.1.2 , installed 2.3.0 [Updatable] Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-justgage" : 2.1.0 , installed 2.0.2 [Updatable] Adapter "vis-material-webfont": 0.0.3, installed 0.0.3 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "vw-connect" : 0.5.1 , installed 0.5.1 Adapter "web" : 6.2.3 , installed 6.1.10 [Updatable] Adapter "welcome" : 0.3.0 , installed 0.1.0 [Updatable] Adapter "wled" : 0.7.2 , installed 0.7.1 [Updatable] Adapter "ws" : 2.5.10 , installed 2.5.8 [Updatable] Objects and States Please stand by - This may take a while Objects: 14551 States: 12801 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 12 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 67953 6980/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 67548 6980/iobroker.js-co tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 15814 500/cupsd tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 69486 7339/io.shelly.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 70930 7232/io.sonoff.0 tcp 0 0 0.0.0.0:6052 0.0.0.0:* LISTEN 1001 71801 7577/python3 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12285 560/sshd: /usr/sbin tcp6 0 0 ::1:631 :::* LISTEN 0 15813 500/cupsd tcp6 0 0 :::22 :::* LISTEN 0 16391 560/sshd: /usr/sbin tcp6 0 0 :::8081 :::* LISTEN 1001 67976 7011/io.admin.0 tcp6 0 0 :::8082 :::* LISTEN 1001 74776 7727/io.web.0 udp 0 0 0.0.0.0:52670 0.0.0.0:* 1001 73237 7954/io.snmp.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15073 476/dhcpcd udp 0 0 0.0.0.0:631 0.0.0.0:* 0 16516 598/cups-browsed udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 71678 7748/io.wled.0 udp 0 0 192.168.178.142:5353 0.0.0.0:* 1001 71810 7577/python3 udp 0 0 127.0.0.1:5353 0.0.0.0:* 1001 71809 7577/python3 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 71804 7577/python3 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 71762 7438/io.esphome.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 12757 394/avahi-daemon: r udp 0 0 0.0.0.0:51252 0.0.0.0:* 108 12759 394/avahi-daemon: r udp6 0 0 :::36109 :::* 108 12760 394/avahi-daemon: r udp6 0 0 :::546 :::* 0 15182 476/dhcpcd udp6 0 0 :::5353 :::* 108 12758 394/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-12-24 07:55:50.611 - info: javascript.0 (7073) script.js.IoBroker.Aktive_Ausgänge: ['{\'name\':\'Umwelzpumpe Heizkreislauf AnAus\'}','{\'name\':\'Außensteckdose Straße EinAus\'}'] 2023-12-24 07:57:56.322 - info: heizoel.0 (7499) State value to set for "heizoel.0.2000.data01.dealer.rating.averageRatingLastYear" has to be type "string" but received type "number" 2023-12-24 07:57:56.330 - info: heizoel.0 (7499) State value to set for "heizoel.0.2000.data02.dealer.rating.averageRating" has to be type "number" but received type "string" 2023-12-24 07:57:56.332 - info: heizoel.0 (7499) State value to set for "heizoel.0.2000.data02.dealer.rating.averageRatingLastYear" has to be type "number" but received type "string" 2023-12-24 07:57:57.125 - info: heizoel.0 (7499) State value to set for "heizoel.0.3000.data01.dealer.rating.averageRating" has to be type "number" but received type "string" 2023-12-24 07:57:57.130 - info: heizoel.0 (7499) State value to set for "heizoel.0.3000.data02.pricing.bestPriceDiff" has to be type "number" but received type "string" 2023-12-24 07:57:57.151 - info: heizoel.0 (7499) State value to set for "heizoel.0.3000.data03.pricing.bestPriceDiff" has to be type "number" but received type "string" 2023-12-24 08:00:00.059 - info: javascript.0 (7073) script.js.IoBroker.Astro_Zeiten: Astro: Gültige Zeiten: [aktueller Tag: 10] | [nächster Tag: 4] | [Aktualisiert: 0] | Aktuelle Tageszeit: Morgendämmerung | Kommende Tageszeit: Sonnenaufgang 2023-12-24 08:00:00.243 - info: host.raspberrypi instance system.adapter.ical.2 started with pid 18919 2023-12-24 08:00:01.106 - info: javascript.0 (7073) script.js.IoBroker.Aktive_Ausgänge: ['{\'name\':\'Umwelzpumpe Heizkreislauf AnAus\'}','{\'name\':\'Außensteckdose Straße EinAus\'}'] 2023-12-24 08:00:01.107 - info: javascript.0 (7073) script.js.IoBroker.Aktive_Meldungen: ['{\'name\':\'ESP Smartshunt Keine Verbindung\'}','{\'name\':\'ESP MPPT Keine Verbindung\'}','{\'name\':\'ESP_Batterie keine Verbindung\'}','{\'name\':\'ET200SP Gartenhaus Störung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP WLED GH keine Verbindung\'}','{\'name\':\'ESP GHWC kein Verbindung\'}','{\'name\':\'Alexa Tobi keine Verbindung\'}','{\'name\':\'Störung3 Heizstab hat keine Leistung\'}'] 2023-12-24 08:00:02.205 - info: javascript.0 (7073) script.js.IoBroker.Aktive_Ausgänge: ['{\'name\':\'Umwelzpumpe Heizkreislauf AnAus\'}','{\'name\':\'Außensteckdose Straße EinAus\'}'] 2023-12-24 08:00:02.206 - info: javascript.0 (7073) script.js.IoBroker.Aktive_Meldungen: ['{\'name\':\'ESP Smartshunt Keine Verbindung\'}','{\'name\':\'ESP MPPT Keine Verbindung\'}','{\'name\':\'ESP_Batterie keine Verbindung\'}','{\'name\':\'ET200SP Gartenhaus Störung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP Display Keine Verbindung\'}','{\'name\':\'ESP WLED GH keine Verbindung\'}','{\'name\':\'ESP GHWC kein Verbindung\'}','{\'name\':\'Alexa Tobi keine Verbindung\'}','{\'name\':\'Störung3 Heizstab hat keine Leistung\'}'] 2023-12-24 08:00:04.283 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 18936 2023-12-24 08:00:06.161 - info: ical.2 (18919) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17 2023-12-24 08:00:06.777 - warn: trashschedule.0 (7792) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule! 2023-12-24 08:00:07.460 - info: ical.2 (18919) processing URL: Geburtstage https://calendar.google.com/calendar/ical/ca71d79fa6dfafec51b6cdcad9b68860f246a5d698139d735d1e234c34b4aa9f%40group.calendar.google.com/private-6c3abd24a81c173d80389123ef459bda/basic.ics 2023-12-24 08:00:09.260 - info: ical.2 (18919) processing URL: Termine https://calendar.google.com/calendar/ical/tobiasbangert78%40gmail.com/private-af20b004c69d83ed1022fdbbd00428fd/basic.ics 2023-12-24 08:00:11.594 - info: ical.1 (18936) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17 2023-12-24 08:00:12.520 - info: ical.1 (18936) processing URL: Müll Kalender https://calendar.google.com/calendar/ical/19c4e1646ead3d18594fe439767c040fbf2e1f7c910b7c8b7a60247a416747e7%40group.calendar.google.com/private-88175afa823e06bf5e818e919d73f0f9/basic.ics 2023-12-24 08:00:12.741 - warn: trashschedule.0 (7792) (5) nextAfter has no entries. Check configuration of ical (increase preview) and trashschedule! 2023-12-24 08:00:16.721 - info: ical.2 (18919) Terminated (NO_ERROR): Without reason 2023-12-24 08:00:17.263 - info: host.raspberrypi instance system.adapter.ical.2 terminated with code 0 (NO_ERROR) 2023-12-24 08:00:17.657 - info: ical.1 (18936) Terminated (NO_ERROR): Without reason 2023-12-24 08:00:18.214 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)============ Mark until here for C&P =============
@tourer4778 schon auf die Idee gekommen, vllt mal sämtliche Updates auszuführen?
vor allem als beta User@tourer4778 sagte in Iobroker Oberfläche langsam. Störmeldungen:
X-Server: true
ausschalten
X-Server: true
ausschalten
@crunchip
Die Updates werden nur angezeigt, weil "Latest" ausgewählt ist. Aber ich kann es ja nicht mehr ändern, weil ich nicht in die Einstellungen komme. Latest wegen vw-connect, den ich aktualisieren habe.X-Server, wo kann ich das einstellen ?
@crunchip
@tourer4778 https://forum.iobroker.net/topic/42952/der-kleine-iobroker-linux-werkzeugkasten?_=1703405292873&lang=de
@crunchip
Okay, Stabil konnte ich einstellen.
Wo kann ich das mit dem X-Server einstellen? -
@crunchip
Wo kann ich das mit dem X-Server einstellen?Steht auch in dem Link von @crunchip
Gruß Tom
Public Transport
https://github.com/tt-tom17/ioBroker.public-transport/wikiNSPanel Adapter Wiki
https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/wiki -
@tt-tom
Tut mir leid, auf dem link finde ich nichts in verbindung mit X-Server, wo nach muss ich dort suchen ? -
@tt-tom
Tut mir leid, auf dem link finde ich nichts in verbindung mit X-Server, wo nach muss ich dort suchen ?kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
der Installationsfixer: curl -fsL https://iobroker.net/fix.sh | bash - -
@tt-tom
Tut mir leid, auf dem link finde ich nichts in verbindung mit X-Server, wo nach muss ich dort suchen ?@tourer4778 ab RunLevel 5 / graphische Oberfläche(nennt sich x-server)
@crunchip
Aber bei steht er auf 3, was ja laut dem schreiben okay ist.
@crunchip
@tourer4778
Hast du trotzdem ein full Raspbian mit Desktop installiert, statt der lite Version?kein Support per PN! - Fragen im Forum stellen - Benutzt das Voting rechts unten im Beitrag wenn er euch geholfen hat.
@tourer4778
Hast du trotzdem ein full Raspbian mit Desktop installiert, statt der lite Version?@homoran
Das kann sein, ich weiß es nicht mehr genau.
Schluckt das so viel mehr Leistung? -
Schluckt das so viel mehr Leistung?sudo apt update sudo apt full-upgrade sudo systemctl set-default multi-user target sudo rebootDann nochmal
iob diagLinux-Werkzeugkasten:
iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -
iob diag@thomas-braun sagte in Iobroker Oberfläche langsam. Störmeldungen:
iob diag
Danke, hat funktioniert. Werde jetzt mal beobachten ...
Copy text starting here:======================= SUMMARY ======================= v.2023-10-10 Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Installation: native Kernel: aarch64 Userland: armhf Timezone: Europe/Berlin (CET, +0100) User-ID: 1000 X-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 4 Nodejs-Installation: /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 Recommended versions are nodejs 18.19.0 and npm 10.2.3 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 7.8G 1.9G 4.9G 0.0K 970M 5.8G Swap: 99M 0B 99M Total: 7.9G 1.9G 5.0G Active iob-Instances: 37 Active repo(s): stable ioBroker Core: js-controller 5.0.17 admin 6.12.0 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 14724 States: 13024 Size of iob-Database: 23M /opt/iobroker/iobroker-data/objects.jsonl 9.0M /opt/iobroker/iobroker-data/objects.json.migrated 9.0M /opt/iobroker/iobroker-data/objects.json.bak.migrated 4.6M /opt/iobroker/iobroker-data/states.jsonl 680K /opt/iobroker/iobroker-data/states.json.migrated 680K /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.broken =================== END OF SUMMARY ======================= Mark text until here for copying ===
iob diagDanke, mein System läuft schon wesentlich besser.
