  4. Probleme mit Zigbee.Adapter
29 Beiträge 2 Kommentatoren 4.0k Aufrufe 2 Beobachtet
  • I igor123
    @thomas-braun sagte in Probleme mit Zigbee.Adapter:
    @igor123 sagte in Probleme mit Zigbee.Adapter:
    Hab das mal ausgeführt - soweit fertig -
    Dann jetzt nochmal die Ausgabe von
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.74-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     21:46:24 up 12 days, 13 min,  1 user,  load average: 0.65, 1.11, 1.07
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-12-21 21:46:24 CET
               Universal time: Thu 2023-12-21 20:46:24 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        1.2G        5.9G        0.0K        731M        6.4G
    Swap:            99M          0B         99M
    Total:          8.0G        1.2G        6.0G
             7897 M total memory
             1241 M used memory
              249 M active memory
             1505 M inactive memory
             5925 M free memory
              175 M buffer memory
              556 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      235G   14G  210G   6% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  848K  1.6G   1% /run
    /dev/sda1      vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sat Dec  9 21:32:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238543-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Dec  9 21:32:48 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Dec  9 21:32:48 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Dec  9 21:32:50 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET                SOURCE    FSTYPE OPTIONS
    /                     /dev/sda2 ext4   rw,noatime
    |-/boot               /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    `-/var/lib/piVCCU/dtb /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    4.9G    /var/
    3.0G    /var/log
    2.9G    /var/log/journal/45677fd33dca4b97838c0214e7692911
    1.2G    /var/cache/apt/archives
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    383M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    537M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    331M    /opt/iobroker/iobroker-data/files
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wolke-3/libFrameworkArduino.a
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/libFrameworkArduino.a
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/libFrameworkArduino.a
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   1
    Adapter State
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
    + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.hmip.0                   : hmip                  : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
      system.adapter.material.0               : material              : raspberrypi                              - disabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1299
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1299, bind: 0.0.0.0
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : raspberrypi                              -  enabled, port: 16021
      system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.roomba.0                 : roomba                : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 192.168.1.99
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.1.99, run as: admin
    + system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 1491
    + system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.1.99, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
    + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fuelpricemonitor": 0.4.0 , installed 0.3.6  [Updatable]
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
    Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.73
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        8329
    States:         6957
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:5 https://www.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 56
    *** Listening Ports ***
    tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN      1001       11528397   17301/io.socketio.0
    tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN      1001       11528301   17195/io.web.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12435      765/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11521841   16407/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11521834   16407/iobroker.js-c
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12462      819/dnsmasq
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11524556   16610/io.sonoff.1
    tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN      1001       11526322   16709/io.mqtt.0
    tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN      1001       11526321   16709/io.mqtt.0
    tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN      1001       11523969   16689/io.hm-rpc.0
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       11527566   17290/python3.8
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       11524831   16821/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12437      765/sshd: /usr/sbin
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       11526223   16629/io.sonos.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11524428   16426/io.admin.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11524832   16821/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11523827   16598/io.shelly.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12461      819/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12458      819/dnsmasq
    udp        0      0 192.168.1.99:5353       0.0.0.0:*                           1001       11530289   17290/python3.8
    udp        0      0 10.0.3.1:5353           0.0.0.0:*                           1001       11530288   17290/python3.8
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       11530287   17290/python3.8
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530280   17290/python3.8
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530208   17242/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530155   17211/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9081       399/avahi-daemon: r
    udp        0      0 0.0.0.0:36614           0.0.0.0:*                           108        9083       399/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11526529   16843/io.nanoleaf-l
    udp6       0      0 :::33192                :::*                                108        9084       399/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        9082       399/avahi-daemon: r
    2023-12-21 21:44:39.126  - info: socketio.0 (17301) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.19.0, js-controller: 5.0.17
    2023-12-21 21:44:39.175  - warn: socketio.0 (17301) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2023-12-21 21:44:39.223  - info: socketio.0 (17301) socket.io server listening on port 8084
    2023-12-21 21:44:39.782  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.229
    2023-12-21 21:44:39.830  - info: wled.0 (17211) Initialising : " WLED" on IP :  192.168.1.229
    2023-12-21 21:44:40.091  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.16
    2023-12-21 21:44:40.123  - info: wled.0 (17211) WLED connected
    2023-12-21 21:44:42.499  - info: vis-google-fonts.0 (17321) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
    2023-12-21 21:44:43.096  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.26
    2023-12-21 21:44:43.136  - info: vis-google-fonts.0 (17321) Terminated (NO_ERROR): Without reason
    2023-12-21 21:44:43.756  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
    2023-12-21 21:44:46.103  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.27
    2023-12-21 21:44:48.646  - info: roomba.0 (17265) Subscripe Leafnode: _runCommand.
    2023-12-21 21:44:49.107  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.6
    2023-12-21 21:44:52.112  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.210
    2023-12-21 21:44:55.118  - info: wled.0 (17211) Bonjour service started, new  devices  will  be detected automatically
    2023-12-21 21:45:00.061  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 17385
    2023-12-21 21:45:02.684  - info: tvspielfilm.0 (17385) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.17
    2023-12-21 21:45:04.818  - info: tvspielfilm.0 (17385) objects written
    2023-12-21 21:45:05.143  - info: wled.0 (17211) WLED initialisation finalized, ready to do my job have fun !
    2023-12-21 21:45:15.335  - info: tvspielfilm.0 (17385) Terminated (NO_ERROR): Without reason
    2023-12-21 21:45:15.942  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2023-12-21 21:45:18.473  - info: admin.0 (16426) ==> Connected system.user.admin from ::ffff:192.168.1.22
    2023-12-21 21:45:18.881  - info: zigbee.0 (16677) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2256619","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyS0"}]
    2023-12-21 21:45:30.212  - info: admin.0 (16426) <== Disconnect system.user.admin from ::ffff:192.168.1.22
    Pending Updates: 56
    Da klemmt noch was.
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    I 1 Antwort Letzte Antwort
    • I igor123
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7897 M total memory
               1241 M used memory
                249 M active memory
               5925 M free memory
                175 M buffer memory
                556 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.9G    /var/
      3.0G    /var/log
      USB-Devices by-id:
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      nodejs:
        Version table:
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8329
      States:         6957
      Pending Updates: 56
      Und statt /dev/ttyACM0 trägst du im Zigbee-Adapter das als COM-Port ein:
        Pending Updates: 56
        Da klemmt noch was.
        sudo apt update
        sudo reboot
        I Offline
        I Offline
        igor123
        Pending Updates: 56
        Da klemmt noch was.
        sudo apt update
        sudo reboot
        so - erledigt
        habe ich nun getan
        bleibt dann nur leider auf gelb
        • I igor123
          Pending Updates: 56
          Da klemmt noch was.
          sudo apt update
          sudo reboot
          so - erledigt
          habe ich nun getan
          so - erledigt
          iob diag
          sagt?
            so - erledigt
            iob diag
            sagt?
            I Offline
            I Offline
            igor123
            so - erledigt
            iob diag
            sagt?
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                        Kernel: Linux 6.1.21-v7l+
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
             22:08:16 up 8 min,  1 user,  load average: 0.41, 0.74, 0.50
            CPU threads: 4
            Current issues:
                           Local time: Thu 2023-12-21 22:08:16 CET
                       Universal time: Thu 2023-12-21 21:08:16 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            7.9G        1.3G        6.3G        0.0K        280M        6.4G
            Swap:            99M          0B         99M
            Total:          8.0G        1.3G        6.4G
                     7897 M total memory
                     1294 M used memory
                      120 M active memory
                     1340 M inactive memory
                     6322 M free memory
                       39 M buffer memory
                      241 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            tmpfs          tmpfs     1.6G  852K  1.6G   1% /run
            /dev/sda1      vfat      253M   51M  202M  20% /boot
            [Thu Dec 21 21:59:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238        543-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Thu Dec 21 21:59:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
            [Thu Dec 21 21:59:40 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
            [Thu Dec 21 21:59:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,flush,errors=remount-ro
            /var:
            4.9G    /var/
            3.0G    /var/log
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
            24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wo        lke-3/libFrameworkArduino.a
            24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/        libFrameworkArduino.a
            24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/        libFrameworkArduino.a
            USB-Devices by-id:
            find: '/dev/serial/by-id/': No such file or directory
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
                    500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/serial/by-id/usb-dresden_ele        ktronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
            + instance is alive
            Objects and States
            Objects:        8334
            States:         6960
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
            Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
            Pending Updates: 0
            Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
            tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN        1001       27073      4407/io.hm-rpc.0
            tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN        1001       26964      4351/python3.8
            tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN        1001       19853      3015/io.mqtt.0
            tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN        1001       19854      3015/io.mqtt.0
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN        0          11142      795/dnsmasq
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       17029      2442/io.sonoff.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          1832       766/sshd: /usr/sbin
            tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN        1001       23174      4353/io.socketio.0
            tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN        1001       22993      4247/io.web.0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       14423      728/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       14410      728/iobroker.js-con
            tcp6       0      0 :::8081                 :::*                    LISTEN        1001       15888      1299/io.admin.0
            tcp6       0      0 :::3500                 :::*                    LISTEN        1001       17061      2498/io.sonos.0
            tcp6       0      0 :::22                   :::*                    LISTEN        0          1834       766/sshd: /usr/sbin
            tcp6       0      0 :::61991                :::*                    LISTEN        1001       21723      3646/io.harmony.0
            udp        0      0 0.0.0.0:61991           0.0.0.0:*        1001       21724      3646/io.harmony.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*        1001       16351      2209/io.shelly.0
            udp        0      0 10.0.3.1:53             0.0.0.0:*        0          11141      795/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*        0          11138      795/dnsmasq
            udp        0      0 127.0.0.1:5353          0.0.0.0:*        1001       23116      4351/python3.8
            udp        0      0 10.0.3.1:5353           0.0.0.0:*        1001       23115      4351/python3.8
            udp        0      0 192.168.1.99:5353       0.0.0.0:*        1001       23114      4351/python3.8
            udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       23106      4351/python3.8
            udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       26224      4301/io.esphome.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       22206      4264/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        12268      392/avahi-daemon: r
            udp        0      0 0.0.0.0:41294           0.0.0.0:*        108        12270      392/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*        1001       22597      3717/io.nanoleaf-li
            udp6       0      0 :::5353                 :::*        108        12269      392/avahi-daemon: r
            udp6       0      0 :::57676                :::*        108        12271      392/avahi-daemon: r
            2023-12-21 22:07:43.068  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 (force=false, process=true)
            2023-12-21 22:07:43.240  - info: zigbee.0 (4621) Got terminate signal TERMINATE_        YOURSELF
            2023-12-21 22:07:43.245  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 send kill signal
            2023-12-21 22:07:43.243  - info: zigbee.0 (4621) cleaned everything up...
            2023-12-21 22:07:43.335  - info: zigbee.0 (4621) Zigbee: disabling joining new d        evices.
            2023-12-21 22:07:43.516  - info: zigbee.0 (4621) terminating
            2023-12-21 22:07:43.518  - info: zigbee.0 (4621) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
            2023-12-21 22:07:43.633  - info: admin.0 (1299) <== Disconnect system.user.admin        from ::ffff:192.168.1.22
            2023-12-21 22:07:43.744  - info: zigbee.0 (4621) terminating
            2023-12-21 22:07:44.184  - info: host.raspberrypi instance system.adapter.zigbee        .0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-12-21 22:07:46.494  - info: host.raspberrypi instance system.adapter.zigbee        .0 started with pid 4877
            2023-12-21 22:07:50.386  - info: zigbee.0 (4877) Plugin sentry Sentry Plugin dis        abled for this process because sending of statistic data is disabled for the sys        tem
            2023-12-21 22:07:50.717  - info: zigbee.0 (4877) starting. Version 1.8.24 in /op        t/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
            2023-12-21 22:07:50.811  - info: zigbee.0 (4877) delete old Backup files. keep o        nly last 10
            2023-12-21 22:07:50.813  - info: zigbee.0 (4877) Starting Zigbee  npm ...
            2023-12-21 22:07:51.138  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
            2023-12-21 22:07:51.537  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
            2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Failed to start Zigbee
            2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Error herdsman start
            2023-12-21 22:08:01.539  - info: zigbee.0 (4877) Try to reconnect. 1 attempts le        ft
            2023-12-21 22:08:01.541  - info: zigbee.0 (4877) Starting Zigbee  npm ...
            2023-12-21 22:08:01.555  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
            2023-12-21 22:08:01.704  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
            2023-12-21 22:08:01.705  - error: zigbee.0 (4877) Failed to start Zigbee
            2023-12-21 22:08:01.706  - error: zigbee.0 (4877) Error herdsman start
            • I igor123
              so - erledigt
              iob diag
              sagt?
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : armhf
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7897 M total memory
                       1294 M used memory
                        120 M active memory
                       6322 M free memory
                         39 M buffer memory
                        241 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              4.9G    /var/
              3.0G    /var/log
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        8334
              States:         6960
              Pending Updates: 0
              Hmmm.
              apt policy udev
              sagt?
                Hmmm.
                apt policy udev
                sagt?
                I Offline
                I Offline
                igor123
                Hmmm.
                apt policy udev
                sagt?
                udev:
                  Installiert:           247.3-7+rpi1+deb11u2
                  Installationskandidat: 247.3-7+rpi1+deb11u2
                  Versionstabelle:
                 *** 247.3-7+rpi1+deb11u2 500
                • I igor123
                  Hmmm.
                  apt policy udev
                  sagt?
                  udev:
                    Versionstabelle:
                  @igor123
                  echo "deb http://deb.debian.org/debian bullseye-backports main contrib non-free" | sudo tee /etc/apt/sources.list.d/buster-backports.list
                  sudo apt update
                  Dann die Ausgabe von
                  apt policy udev
                    @igor123
                    sudo apt update
                    apt policy udev
                    I Offline
                    I Offline
                    igor123
                    schrieb am zuletzt editiert von igor123
                    @igor123
                    sudo apt update
                    apt policy udev
                    udev:
                      Versionstabelle:
                    @Thomas-Braun Wobei ich bei sudo apt update glaube ich einen fehler erhalten habe:
                     sudo apt update
                    Holen:1 http://deb.debian.org/debian bullseye-backports InRelease [49,0 kB]
                    OK:2 http://phoscon.de/apt/deconz bullseye InRelease
                    OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                    OK:6 https://apt.pivccu.de/piVCCU stable InRelease
                    Fehl:1 http://deb.debian.org/debian bullseye-backports InRelease
                      Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher                                         Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B8264                                        3E131
                    W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die fo                                        lgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüss                                        el nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                    E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nic                                        ht signiert.
                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur                                        chgeführt werden, daher ist es standardmäßig deaktiviert.
                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur                                        ation finden Sie in der Handbuchseite apt-secure(8).
                    • I igor123
                      @igor123
                      sudo apt update
                      apt policy udev
                      udev:
                        Versionstabelle:
                       sudo apt update
                      sudo apt update
                      apt policy udev
                        sudo apt update
                        apt policy udev
                        I Offline
                        I Offline
                        igor123
                        sudo apt update
                        apt policy udev
                        habe ich bereits getan:
                         sudo apt update
                        OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        OK:4 http://phoscon.de/apt/deconz bullseye InRelease
                          Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                        W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                        E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nicht signiert.
                        N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                        N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                         apt policy udev
                        udev:
                          Versionstabelle:
                        • I igor123
                          sudo apt update
                          apt policy udev
                           sudo apt update
                           apt policy udev
                          udev:
                            Versionstabelle:
                          @igor123
                          Solche Fehler sind natürlich wichtig...
                          sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                          sudo apt update
                          apt policy udev
                          Und mach dein puTTY-Fenster etwas größer, das zerballert die Zeilen sonst.
                            @igor123
                            sudo apt update
                            apt policy udev
                            I Offline
                            I Offline
                            igor123
                            @igor123
                            sudo apt update
                            apt policy udev
                            leider das selbe
                            sudo apt update
                            pi@raspberrypi:~ $ apt policy udev
                            udev:
                              Versionstabelle:
                            edit:
                            Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                            Executing: /tmp/apt-key-gpghome.RyObX1JTYq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                            gpg: Empfangen vom Schlüsselserver fehlgeschlagen: Server indicated a failure
                            empfangsfehler..
                            • I igor123
                              @igor123
                              sudo apt update
                              apt policy udev
                              leider das selbe
                              sudo apt update
                              udev:
                                Versionstabelle:
                              edit:
                              empfangsfehler..
                              sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                I Offline
                                I Offline
                                igor123
                                auch hier ein fehler
                                Executing: /tmp/apt-key-gpghome.yYhlYVJCTc/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                • I igor123
                                  @igor123
                                  Dann zieh ein Backup vom ioBroker und zieh mit dem ganzen Kram auf ein aktuelles Betriebssystem um.
                                  Neuinstallation von
                                  Raspberry 12 'Bookworm' 64Bit Lite
                                    @igor123
                                    Neuinstallation von
                                    I Offline
                                    I Offline
                                    igor123
                                    ich verstehe nur nicht ganz warum
                                    was ist den das problem? was versuchen wir eigentlich die ganze zeit genau? :D
                                    mit /dev/ttyACM0 als COMNamen funkt es ja soweit -
                                    der fehler vom Zigbee-Adapter ist erstmal nicht mehr gekommen
                                    mir fehlen "nurmehr" weiterhin die ganzen states die ich früher hatte.
                                    so wie ich es damals gemacht hatte funktioniert es nun nicht mehr:
                                    https://forum.iobroker.net/topic/50381/busch-jäger-6737-01-es-werden-nicht-alle-objekte-angezeigt?_=1703189610786
                                    • I igor123
                                      Ein veraltetes System.
                                        I Offline
                                        I Offline
                                        igor123
                                        Und deswegen erhalte ich die states nicht?
                                        • I igor123
                                          @igor123
                                          Deswegen erhältst du keinen Link zum USB-Device mehr.
                                          Du hast bei den Updates gepennt und als es ging ein entsprechendes Update nicht eingespielt. Da dein jetziges Release nur noch notdürftig unterstützt wird kommst du da nicht mehr einfach ran.
                                          Und eine Neuinstallation eines 64Bit-Releases wirst du eh irgendwann machen müssen, kannste also auch jetzt machen.
