  4. Probleme mit Zigbee.Adapter
29 Beiträge 2 Kommentatoren 4.0k Aufrufe 2 Beobachtet
  • I igor123
    @thomas-braun sagte in Probleme mit Zigbee.Adapter:
    iob diag
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.74-v7l+
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     21:21:06 up 11 days, 23:48,  1 user,  load average: 0.85, 0.69, 0.63
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Thu 2023-12-21 21:21:06 CET
               Universal time: Thu 2023-12-21 20:21:06 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CET, +0100)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        1.7G        4.3G        0.0K        2.0G        6.0G
    Swap:            99M          0B         99M
    Total:          8.0G        1.7G        4.4G
             7897 M total memory
             1660 M used memory
             1046 M active memory
             2377 M inactive memory
             4273 M free memory
              206 M buffer memory
             1756 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      235G   13G  210G   6% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  848K  1.6G   1% /run
    /dev/sda1      vfat      253M   50M  203M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    [Sat Dec  9 21:32:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238543-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Dec  9 21:32:48 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Dec  9 21:32:48 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Dec  9 21:32:50 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    du: cannot access '/var/lib/lxcfs/cgroup': Input/output error
    4.5G    /var/
    3.0G    /var/log
    2.9G    /var/log/journal/45677fd33dca4b97838c0214e7692911
    822M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    /opt/iobroker/backups:
    383M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    537M    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
    331M    /opt/iobroker/iobroker-data/files
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wolke-3/libFrameworkArduino.a
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/libFrameworkArduino.a
    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/libFrameworkArduino.a
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.5.1
    /usr/bin/node           v20.5.1
    /usr/bin/npm            9.8.0
    /usr/bin/npx            9.8.0
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 20.5.1-deb-1nodesource1
      Candidate: 20.5.1-deb-1nodesource1
      Version table:
     *** 20.5.1-deb-1nodesource1 100
         16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    Adapters from github:   1
    Adapter State
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
    + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : raspberrypi                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      system.adapter.hmip.0                   : hmip                  : raspberrypi                              - disabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
      system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
      system.adapter.material.0               : material              : raspberrypi                              - disabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
    + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1299
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1299, bind: 0.0.0.0
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : raspberrypi                              -  enabled, port: 16021
      system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.roomba.0                 : roomba                : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 192.168.1.99
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.1.99, run as: admin
    + system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
      system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 1491
    + system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.1.99, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
    + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
    + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "deconz"       : 1.3.23   , installed 1.3.23
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "fuelpricemonitor": 0.4.0 , installed 0.3.6  [Updatable]
    Adapter    "harmony"      : 1.3.0    , installed 1.3.0
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "roomba"       : 1.2.2    , installed 1.2.2
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
    Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
    Adapter    "vis"          : 1.5.4    , installed 1.4.16 [Updatable]
    Adapter    "vis-icontwo"  : 1.0.0    , installed 1.0.0
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.73
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wled"         : 0.7.1    , installed 0.7.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    Objects and States
    Objects:        8329
    States:         6939
    Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:5 https://www.pivccu.de/piVCCU stable InRelease
    Reading package lists...
    Pending Updates: 128
    *** Listening Ports ***
    tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN      1001       5727015    2925/io.socketio.0
    tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN      1001       5726928    2783/io.web.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12435      765/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5722808    1678/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5722803    1678/iobroker.js-co
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          12462      819/dnsmasq
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       5726272    1993/io.sonoff.1
    tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN      1001       5727509    2165/io.mqtt.0
    tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN      1001       5727508    2165/io.mqtt.0
    tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN      1001       11456098   4789/io.hm-rpc.0
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       5729169    2907/python3.8
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       5728354    2341/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12437      765/sshd: /usr/sbin
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       7245397    13935/io.sonos.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5722866    1701/io.admin.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       5728355    2341/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       5727392    1979/io.shelly.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          12461      819/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          12458      819/dnsmasq
    udp        0      0 192.168.1.99:5353       0.0.0.0:*                           1001       5731427    2907/python3.8
    udp        0      0 10.0.3.1:5353           0.0.0.0:*                           1001       5731426    2907/python3.8
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       5731425    2907/python3.8
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5731418    2907/python3.8
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5731369    2842/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5726938    2803/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9081       399/avahi-daemon: r
    udp        0      0 0.0.0.0:36614           0.0.0.0:*                           108        9083       399/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5727715    2367/io.nanoleaf-li
    udp6       0      0 :::33192                :::*                                108        9084       399/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        9082       399/avahi-daemon: r
    2023-12-21 21:12:53.984  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:12:54.263  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:15:00.026  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 6308
    2023-12-21 21:15:02.442  - info: tvspielfilm.0 (6308) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.5.1, js-controller: 5.0.17
    2023-12-21 21:15:04.573  - info: tvspielfilm.0 (6308) objects written
    2023-12-21 21:15:15.087  - info: tvspielfilm.0 (6308) Terminated (NO_ERROR): Without reason
    2023-12-21 21:15:15.653  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2023-12-21 21:15:57.855  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:16:10.635  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:16:20.732  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:16:26.604  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:16:32.160  - warn: sonos.0 (13935) State "sonos.0.root.192_168_1_7.current_track_number" has no existing object, this might lead to an error in future versions
    2023-12-21 21:20:00.055  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 6757
    2023-12-21 21:20:02.425  - info: tvspielfilm.0 (6757) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.5.1, js-controller: 5.0.17
    2023-12-21 21:20:04.544  - info: tvspielfilm.0 (6757) objects written
    2023-12-21 21:20:15.058  - info: tvspielfilm.0 (6757) Terminated (NO_ERROR): Without reason
    2023-12-21 21:20:15.615  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
    2023-12-21 21:20:25.026  - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 started with pid 6786
    2023-12-21 21:20:27.164  - info: fuelpricemonitor.0 (6786) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2023-12-21 21:20:27.327  - info: fuelpricemonitor.0 (6786) starting. Version 0.3.6 in /opt/iobroker/node_modules/iobroker.fuelpricemonitor, node: v20.5.1, js-controller: 5.0.17
    2023-12-21 21:20:27.349  - info: fuelpricemonitor.0 (6786) Started with JSON-Explorer version 0.1.12
    2023-12-21 21:20:27.444  - info: fuelpricemonitor.0 (6786) Delay execution by 23744ms to better spread API calls
    2023-12-21 21:20:57.406  - info: fuelpricemonitor.0 (6786) Terminated (NO_ERROR): Without reason
    2023-12-21 21:20:57.932  - info: fuelpricemonitor.0 (6786) cleaned everything up...
    2023-12-21 21:20:57.972  - info: host.raspberrypi instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
    @igor123 sagte in Probleme mit Zigbee.Adapter:
    Ernsthaft?
    nodejs ist auch falsch installiert.
    iob stop
    iob fix
    iob nodejs-update
    sollte das wieder auf Spur bringen.
    I 1 Antwort Letzte Antwort
      Ernsthaft?
      iob stop
      iob fix
      iob nodejs-update
      I Offline
      I Offline
      igor123
      iob stop iob fix iob nodejs-update
      da sieht man mal wieder wie wenig ahnung von dem ganzen habe und es doch irgendwie so halb funkt :D
      Hab das mal ausgeführt - soweit fertig - den fehler vom Zigbee-Adapter erhielt ich nun nicht mehr - danke für die rasche hilfe!
      Das Problem mit dem states habe ich nur leider weiterhin :-/
      • I igor123
        Dann jetzt nochmal die Ausgabe von
        iob diag
          iob diag
          I Offline
          I Offline
          igor123
          iob diag
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
           21:46:24 up 12 days, 13 min,  1 user,  load average: 0.65, 1.11, 1.07
          CPU threads: 4
          Current issues:
                         Local time: Thu 2023-12-21 21:46:24 CET
                     Universal time: Thu 2023-12-21 20:46:24 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.9G        1.2G        5.9G        0.0K        731M        6.4G
          Swap:            99M          0B         99M
          Total:          8.0G        1.2G        6.0G
                   7897 M total memory
                   1241 M used memory
                    249 M active memory
                   1505 M inactive memory
                   5925 M free memory
                    175 M buffer memory
                    556 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /dev/root      ext4      235G   14G  210G   6% /
          `-/var/lib/piVCCU/dtb /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          4.9G    /var/
          3.0G    /var/log
          1.2G    /var/cache/apt/archives
          USB-Devices by-id:
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8329
          States:         6957
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 56
          tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN      1001       11528397   17301/io.socketio.0
          tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN      1001       11528301   17195/io.web.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11521841   16407/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11521834   16407/iobroker.js-c
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11524556   16610/io.sonoff.1
          tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN      1001       11526322   16709/io.mqtt.0
          tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN      1001       11526321   16709/io.mqtt.0
          tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN      1001       11523969   16689/io.hm-rpc.0
          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       11527566   17290/python3.8
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       11524831   16821/io.harmony.0
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       11526223   16629/io.sonos.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11524428   16426/io.admin.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11524832   16821/io.harmony.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11523827   16598/io.shelly.0
          udp        0      0 192.168.1.99:5353       0.0.0.0:*                           1001       11530289   17290/python3.8
          udp        0      0 10.0.3.1:5353           0.0.0.0:*                           1001       11530288   17290/python3.8
          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       11530287   17290/python3.8
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530280   17290/python3.8
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530208   17242/io.esphome.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11530155   17211/io.wled.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11526529   16843/io.nanoleaf-l
          2023-12-21 21:44:39.126  - info: socketio.0 (17301) starting. Version 6.6.0 in /opt/iobroker/node_modules/iobroker.socketio, node: v18.19.0, js-controller: 5.0.17
          2023-12-21 21:44:39.175  - warn: socketio.0 (17301) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
          2023-12-21 21:44:39.223  - info: socketio.0 (17301) socket.io server listening on port 8084
          2023-12-21 21:44:39.782  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.229
          2023-12-21 21:44:39.830  - info: wled.0 (17211) Initialising : " WLED" on IP :  192.168.1.229
          2023-12-21 21:44:40.091  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.16
          2023-12-21 21:44:40.123  - info: wled.0 (17211) WLED connected
          2023-12-21 21:44:42.499  - info: vis-google-fonts.0 (17321) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis-google-fonts, node: v18.19.0, js-controller: 5.0.17
          2023-12-21 21:44:43.096  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.26
          2023-12-21 21:44:43.136  - info: vis-google-fonts.0 (17321) Terminated (NO_ERROR): Without reason
          2023-12-21 21:44:43.756  - info: host.raspberrypi instance system.adapter.vis-google-fonts.0 terminated while should be started once
          2023-12-21 21:44:46.103  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.27
          2023-12-21 21:44:48.646  - info: roomba.0 (17265) Subscripe Leafnode: _runCommand.
          2023-12-21 21:44:49.107  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.6
          2023-12-21 21:44:52.112  - info: wled.0 (17211) Try to contact : "WLED" on IP : 192.168.1.210
          2023-12-21 21:44:55.118  - info: wled.0 (17211) Bonjour service started, new  devices  will  be detected automatically
          2023-12-21 21:45:00.061  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 started with pid 17385
          2023-12-21 21:45:02.684  - info: tvspielfilm.0 (17385) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.19.0, js-controller: 5.0.17
          2023-12-21 21:45:04.818  - info: tvspielfilm.0 (17385) objects written
          2023-12-21 21:45:05.143  - info: wled.0 (17211) WLED initialisation finalized, ready to do my job have fun !
          2023-12-21 21:45:15.335  - info: tvspielfilm.0 (17385) Terminated (NO_ERROR): Without reason
          2023-12-21 21:45:15.942  - info: host.raspberrypi instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
          2023-12-21 21:45:18.473  - info: admin.0 (16426) ==> Connected system.user.admin from ::ffff:192.168.1.22
          2023-12-21 21:45:18.881  - info: zigbee.0 (16677) List of port: [{"path":"/dev/ttyACM0","manufacturer":"dresden elektronik ingenieurtechnik GmbH","serialNumber":"DE2256619","pnpId":"usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00","vendorId":"1cf1","productId":"0030"},{"path":"/dev/ttyS0"}]
          2023-12-21 21:45:30.212  - info: admin.0 (16426) <== Disconnect system.user.admin from ::ffff:192.168.1.22
          • I igor123
            iob diag
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7897 M total memory
                     1241 M used memory
                      249 M active memory
                     5925 M free memory
                      175 M buffer memory
                      556 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            4.9G    /var/
            3.0G    /var/log
            USB-Devices by-id:
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        8329
            States:         6957
            Pending Updates: 56
            Pending Updates: 56
            Da klemmt noch was.
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            • I igor123
              iob diag
              Skript v.2023-10-10
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : armhf
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       7897 M total memory
                       1241 M used memory
                        249 M active memory
                       5925 M free memory
                        175 M buffer memory
                        556 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              4.9G    /var/
              3.0G    /var/log
              USB-Devices by-id:
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.12.0
              javascript:     7.1.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        8329
              States:         6957
              Pending Updates: 56
              Und statt /dev/ttyACM0 trägst du im Zigbee-Adapter das als COM-Port ein:
                Pending Updates: 56
                Da klemmt noch was.
                sudo apt update
                sudo reboot
                I Offline
                I Offline
                igor123
                Pending Updates: 56
                Da klemmt noch was.
                sudo apt update
                sudo reboot
                so - erledigt
                habe ich nun getan
                bleibt dann nur leider auf gelb
                • I igor123
                  Pending Updates: 56
                  Da klemmt noch was.
                  sudo apt update
                  sudo reboot
                  so - erledigt
                  habe ich nun getan
                  so - erledigt
                  iob diag
                  sagt?
                    so - erledigt
                    iob diag
                    sagt?
                    I Offline
                    I Offline
                    igor123
                    so - erledigt
                    iob diag
                    sagt?
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                                Kernel: Linux 6.1.21-v7l+
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                     22:08:16 up 8 min,  1 user,  load average: 0.41, 0.74, 0.50
                    CPU threads: 4
                    Current issues:
                                   Local time: Thu 2023-12-21 22:08:16 CET
                               Universal time: Thu 2023-12-21 21:08:16 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.9G        1.3G        6.3G        0.0K        280M        6.4G
                    Swap:            99M          0B         99M
                    Total:          8.0G        1.3G        6.4G
                             7897 M total memory
                             1294 M used memory
                              120 M active memory
                             1340 M inactive memory
                             6322 M free memory
                               39 M buffer memory
                              241 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    tmpfs          tmpfs     1.6G  852K  1.6G   1% /run
                    /dev/sda1      vfat      253M   51M  202M  20% /boot
                    [Thu Dec 21 21:59:38 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:47:61:6D vc_mem.        mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=79238        543-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Thu Dec 21 21:59:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Quota mode: none.
                    [Thu Dec 21 21:59:40 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
                    [Thu Dec 21 21:59:42 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,flush,errors=remount-ro
                    /var:
                    4.9G    /var/
                    3.0G    /var/log
                    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.ma        p
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
                    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/wolke-3/.pioenvs/wo        lke-3/libFrameworkArduino.a
                    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/test/.pioenvs/test/        libFrameworkArduino.a
                    24M     /opt/iobroker/iobroker-data/esphome.0/.esphome/build/rfid/.pioenvs/rfid/        libFrameworkArduino.a
                    USB-Devices by-id:
                    find: '/dev/serial/by-id/': No such file or directory
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                            500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/serial/by-id/usb-dresden_ele        ktronik_ingenieurtechnik_GmbH_ConBee_II_DE2256619-if00
                    + instance is alive
                    Objects and States
                    Objects:        8334
                    States:         6960
                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 http://phoscon.de/apt/deconz bullseye InRelease
                    Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
                    Pending Updates: 0
                    Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
                    tcp        0      0 192.168.1.99:42010      0.0.0.0:*               LISTEN        1001       27073      4407/io.hm-rpc.0
                    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN        1001       26964      4351/python3.8
                    tcp        0      0 0.0.0.0:1299            0.0.0.0:*               LISTEN        1001       19853      3015/io.mqtt.0
                    tcp        0      0 0.0.0.0:1300            0.0.0.0:*               LISTEN        1001       19854      3015/io.mqtt.0
                    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN        0          11142      795/dnsmasq
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN        1001       17029      2442/io.sonoff.1
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          1832       766/sshd: /usr/sbin
                    tcp        0      0 192.168.1.99:8084       0.0.0.0:*               LISTEN        1001       23174      4353/io.socketio.0
                    tcp        0      0 192.168.1.99:8082       0.0.0.0:*               LISTEN        1001       22993      4247/io.web.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       14423      728/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       14410      728/iobroker.js-con
                    tcp6       0      0 :::8081                 :::*                    LISTEN        1001       15888      1299/io.admin.0
                    tcp6       0      0 :::3500                 :::*                    LISTEN        1001       17061      2498/io.sonos.0
                    tcp6       0      0 :::22                   :::*                    LISTEN        0          1834       766/sshd: /usr/sbin
                    tcp6       0      0 :::61991                :::*                    LISTEN        1001       21723      3646/io.harmony.0
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*        1001       21724      3646/io.harmony.0
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*        1001       16351      2209/io.shelly.0
                    udp        0      0 10.0.3.1:53             0.0.0.0:*        0          11141      795/dnsmasq
                    udp        0      0 0.0.0.0:67              0.0.0.0:*        0          11138      795/dnsmasq
                    udp        0      0 127.0.0.1:5353          0.0.0.0:*        1001       23116      4351/python3.8
                    udp        0      0 10.0.3.1:5353           0.0.0.0:*        1001       23115      4351/python3.8
                    udp        0      0 192.168.1.99:5353       0.0.0.0:*        1001       23114      4351/python3.8
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       23106      4351/python3.8
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       26224      4301/io.esphome.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*        1001       22206      4264/io.wled.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        12268      392/avahi-daemon: r
                    udp        0      0 0.0.0.0:41294           0.0.0.0:*        108        12270      392/avahi-daemon: r
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*        1001       22597      3717/io.nanoleaf-li
                    udp6       0      0 :::5353                 :::*        108        12269      392/avahi-daemon: r
                    udp6       0      0 :::57676                :::*        108        12271      392/avahi-daemon: r
                    2023-12-21 22:07:43.068  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 (force=false, process=true)
                    2023-12-21 22:07:43.240  - info: zigbee.0 (4621) Got terminate signal TERMINATE_        YOURSELF
                    2023-12-21 22:07:43.245  - info: host.raspberrypi stopInstance system.adapter.zi        gbee.0 send kill signal
                    2023-12-21 22:07:43.243  - info: zigbee.0 (4621) cleaned everything up...
                    2023-12-21 22:07:43.335  - info: zigbee.0 (4621) Zigbee: disabling joining new d        evices.
                    2023-12-21 22:07:43.516  - info: zigbee.0 (4621) terminating
                    2023-12-21 22:07:43.518  - info: zigbee.0 (4621) Terminated (ADAPTER_REQUESTED_T        ERMINATION): Without reason
                    2023-12-21 22:07:43.633  - info: admin.0 (1299) <== Disconnect system.user.admin        from ::ffff:192.168.1.22
                    2023-12-21 22:07:43.744  - info: zigbee.0 (4621) terminating
                    2023-12-21 22:07:44.184  - info: host.raspberrypi instance system.adapter.zigbee        .0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2023-12-21 22:07:46.494  - info: host.raspberrypi instance system.adapter.zigbee        .0 started with pid 4877
                    2023-12-21 22:07:50.386  - info: zigbee.0 (4877) Plugin sentry Sentry Plugin dis        abled for this process because sending of statistic data is disabled for the sys        tem
                    2023-12-21 22:07:50.717  - info: zigbee.0 (4877) starting. Version 1.8.24 in /op        t/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                    2023-12-21 22:07:50.811  - info: zigbee.0 (4877) delete old Backup files. keep o        nly last 10
                    2023-12-21 22:07:50.813  - info: zigbee.0 (4877) Starting Zigbee  npm ...
                    2023-12-21 22:07:51.138  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
                    2023-12-21 22:07:51.537  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
                    2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Failed to start Zigbee
                    2023-12-21 22:07:51.538  - error: zigbee.0 (4877) Error herdsman start
                    2023-12-21 22:08:01.539  - info: zigbee.0 (4877) Try to reconnect. 1 attempts le        ft
                    2023-12-21 22:08:01.541  - info: zigbee.0 (4877) Starting Zigbee  npm ...
                    2023-12-21 22:08:01.555  - info: zigbee.0 (4877) Installed Version: iobroker.zig        bee@1.8.24
                    2023-12-21 22:08:01.704  - error: zigbee.0 (4877) Starting zigbee-herdsman probl        em : "Error while opening serialport 'Error: Error: No such file or directory, c        annot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee        _II_DE2256619-if00'"
                    2023-12-21 22:08:01.705  - error: zigbee.0 (4877) Failed to start Zigbee
                    2023-12-21 22:08:01.706  - error: zigbee.0 (4877) Error herdsman start
                    • I igor123
                      so - erledigt
                      iob diag
                      sagt?
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      /home/pi
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M          0B         99M
                               7897 M total memory
                               1294 M used memory
                                120 M active memory
                               6322 M free memory
                                 39 M buffer memory
                                241 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /var:
                      4.9G    /var/
                      3.0G    /var/log
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.12.0
                      javascript:     7.1.6
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        8334
                      States:         6960
                      Pending Updates: 0
                      Hmmm.
                      apt policy udev
                      sagt?
                        Hmmm.
                        apt policy udev
                        sagt?
                        I Offline
                        I Offline
                        igor123
                        Hmmm.
                        apt policy udev
                        sagt?
                        udev:
                          Installiert:           247.3-7+rpi1+deb11u2
                          Installationskandidat: 247.3-7+rpi1+deb11u2
                          Versionstabelle:
                         *** 247.3-7+rpi1+deb11u2 500
                        • I igor123
                          Hmmm.
                          apt policy udev
                          sagt?
                          udev:
                            Versionstabelle:
                          @igor123
                          echo "deb http://deb.debian.org/debian bullseye-backports main contrib non-free" | sudo tee /etc/apt/sources.list.d/buster-backports.list
                          sudo apt update
                          Dann die Ausgabe von
                          apt policy udev
                            @igor123
                            sudo apt update
                            apt policy udev
                            I Offline
                            I Offline
                            igor123
                            schrieb am zuletzt editiert von igor123
                            @igor123
                            sudo apt update
                            apt policy udev
                            udev:
                              Versionstabelle:
                            @Thomas-Braun Wobei ich bei sudo apt update glaube ich einen fehler erhalten habe:
                             sudo apt update
                            Holen:1 http://deb.debian.org/debian bullseye-backports InRelease [49,0 kB]
                            OK:2 http://phoscon.de/apt/deconz bullseye InRelease
                            OK:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                            OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            OK:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                            OK:6 https://apt.pivccu.de/piVCCU stable InRelease
                            Fehl:1 http://deb.debian.org/debian bullseye-backports InRelease
                              Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher                                         Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B8264                                        3E131
                            W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die fo                                        lgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüss                                        el nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                            E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nic                                        ht signiert.
                            N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art dur                                        chgeführt werden, daher ist es standardmäßig deaktiviert.
                            N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfigur                                        ation finden Sie in der Handbuchseite apt-secure(8).
                            • I igor123
                              @igor123
                              sudo apt update
                              apt policy udev
                              udev:
                                Versionstabelle:
                               sudo apt update
                              sudo apt update
                              apt policy udev
                                sudo apt update
                                apt policy udev
                                I Offline
                                I Offline
                                igor123
                                sudo apt update
                                apt policy udev
                                habe ich bereits getan:
                                 sudo apt update
                                OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                OK:4 http://phoscon.de/apt/deconz bullseye InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                W: GPG-Fehler: http://deb.debian.org/debian bullseye-backports InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
                                E: Das Depot »http://deb.debian.org/debian bullseye-backports InRelease« ist nicht signiert.
                                N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
                                N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                 apt policy udev
                                udev:
                                  Versionstabelle:
                                • I igor123
                                  sudo apt update
                                  apt policy udev
                                   sudo apt update
                                   apt policy udev
                                  udev:
                                    Versionstabelle:
                                  @igor123
                                  Solche Fehler sind natürlich wichtig...
                                  sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                                  sudo apt update
                                  apt policy udev
                                  Und mach dein puTTY-Fenster etwas größer, das zerballert die Zeilen sonst.
                                    @igor123
                                    sudo apt update
                                    apt policy udev
                                    I Offline
                                    I Offline
                                    igor123
                                    @igor123
                                    sudo apt update
                                    apt policy udev
                                    leider das selbe
                                    sudo apt update
                                    pi@raspberrypi:~ $ apt policy udev
                                    udev:
                                      Versionstabelle:
                                    edit:
                                    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                    Executing: /tmp/apt-key-gpghome.RyObX1JTYq/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 6ED0E7B82643E131
                                    gpg: Empfangen vom Schlüsselserver fehlgeschlagen: Server indicated a failure
                                    empfangsfehler..
                                    • I igor123
                                      @igor123
                                      sudo apt update
                                      apt policy udev
                                      leider das selbe
                                      sudo apt update
                                      udev:
                                        Versionstabelle:
                                      edit:
                                      empfangsfehler..
                                      sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                        I Offline
                                        I Offline
                                        igor123
                                        auch hier ein fehler
                                        Executing: /tmp/apt-key-gpghome.yYhlYVJCTc/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys 0E98404D386FA1D9
                                        • I igor123
                                          @igor123
                                          Dann zieh ein Backup vom ioBroker und zieh mit dem ganzen Kram auf ein aktuelles Betriebssystem um.
                                          Neuinstallation von
                                          Raspberry 12 'Bookworm' 64Bit Lite
