  3. Einsteigerfragen
  4. Installation
  5. vermurkste Installation
120 Beiträge 4 Kommentatoren 17.0k Aufrufe 2 Beobachtet
  • R Radix75
    @thomas-braun opy text starting here:
    			v.2023-10-10
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Installation: 		native
    Kernel: 		armv7l
    Userland: 		armhf
    Timezone: 		Europe/Berlin (CET, +0100)
    User-ID: 		1000
    X-Server: 		true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    Pending iob updates: 	0
    This system needs to be REBOOTED NOW!
    Nodejs-Installation: 	/usr/bin/nodejs 	v14.21.3
    			/usr/bin/node 		v14.21.3
    			/usr/bin/npm 		6.14.18
    			/usr/bin/npx 		6.14.18
    			/usr/bin/corepack 	0.15.1
    Recommended versions are nodejs  and npm
    MEMORY:
    Mem:           3.8G        1.9G        785M        174M        1.1G        1.7G
    Swap:           99M         99M          0B
    Total:         3.9G        2.0G        785M
    Active iob-Instances: 	41
    Active repo(s): stable
    ioBroker Core: 		js-controller 		4.0.21
    			admin 			5.3.1
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		9350
    States: 		7445
    Size of iob-Database:
    13M	/opt/iobroker/iobroker-data/objects.jsonl
    8.2M	/opt/iobroker/iobroker-data/objects.json.migrated
    8.2M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    13M	/opt/iobroker/iobroker-data/states.jsonl
    1.7M	/opt/iobroker/iobroker-data/states.json.migrated
    1.7M	/opt/iobroker/iobroker-data/states.json.bak.migrated
    Thomas BraunT Offline
    @radix75 sagte in Daikin Adapter:
    Ist bei 4GB UND dem mitrumpelnden Desktop-Quatsch auch zu viel. Dein SWAP läuft über.
    Load ist auch zu hoch...
    R 1 Antwort Letzte Antwort
    • R Radix75
      @thomas-braun said in Daikin Adapter:
      @radix75
      Ist nicht vollständig...
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       20:01:59 up 51 days,  1:07,  2 users,  load average: 3.98, 3.66, 3.98
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      ~ Throttling has occurred
      ~ Soft temperature limit has occurred
      This system needs to be REBOOTED!
      *** Time and Time Zones ***
                     Local time: Wed 2023-12-13 20:01:59 CET
                 Universal time: Wed 2023-12-13 19:01:59 UTC
                       RTC time: Wed 2023-12-13 19:01:59
      System clock synchronized: no
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Mem:           3.8G        2.0G        678M        174M        1.1G        1.6G
      Swap:           99M         99M          0B
      Total:         3.9G        2.1G        678M
               3787 M total memory
               2025 M used memory
                588 M active memory
               2246 M inactive memory
                678 M free memory
                192 M buffer memory
                891 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-wifi.service loaded failed failed deCONZ: ZigBee gateway -- WIFI Service
      * dhcpcd.service      loaded failed failed dhcpcd on all interfaces
      2 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   27G   29G  49% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G  183M  1.7G  10% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     379M  4.0K  379M   1% /run/user/1000
      [Mon Oct 23 19:54:16 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1280x1024M@60 smsc95xx.macaddr=DC:A6:32:49:AE:73 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=2fef1976-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Oct 23 19:54:16 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Mon Oct 23 19:54:16 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): 7 orphan inodes deleted
      [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): recovery complete
      [Mon Oct 23 19:54:18 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Oct 23 19:54:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Oct 23 19:54:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [Wed Dec 13 19:48:30 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET                SOURCE         FSTYPE          OPTIONS
      /                     /dev/mmcblk0p2 ext4            rw,noatime
      |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/var/lib/lxcfs      lxcfs          fuse.lxcfs      rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      du: cannot access '/var/lib/lxcfs/cgroup/cpu,cpuacct/system.slice/nodered.service': No such file or directory
      5.5G	/var/
      4.4G	/var/cache/apt
      4.4G	/var/cache
      4.3G	/var/cache/apt/archives
      749M	/var/lib
      Archived and active journals take up 181.7M in the file system.
      /opt/iobroker/backups:
      9.6G	/opt/iobroker/backups/
      4.0K	/opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      641M	/opt/iobroker/iobroker-data/
      462M	/opt/iobroker/iobroker-data/files
      120M	/opt/iobroker/iobroker-data/files/javascript.admin
      102M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      101M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      18M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.3257a139.chunk.js.map
      12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
      9.8M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
      *** NodeJS-Installation ***
      nodejs:
        Installed: 14.21.3-deb-1nodesource1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
       *** 14.21.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.21
      admin: 		5.3.1
      javascript: 	5.2.21
      Adapters from github: 	4
      Adapter State
      + system.adapter.alexa2.1                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      + system.adapter.daikin.0                 : daikin                : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
        system.adapter.hue-extended.1           : hue-extended          : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 80
      + system.adapter.hue.1                    : hue                   : raspberrypi                              -  enabled, port: 443
      + system.adapter.i2c.0                    : i2c                   : raspberrypi                              -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
      + system.adapter.iot.1                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
        system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.nina.0                   : nina                  : raspberrypi                              -  enabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.1.221 (SSL)
      + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
      + system.adapter.sia.0                    : sia                   : raspberrypi                              -  enabled, port: 50001, bind: 0.0.0.0
      + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
      + system.adapter.solax.1                  : solax                 : raspberrypi                              -  enabled
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tr-064.1                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tr-064.2                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.tr-064.3                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.tr-064.4                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      + system.adapter.velux.0                  : velux                 : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      + system.adapter.windows-control.0        : windows-control       : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 5.3.1    , installed 5.3.1
      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
      Adapter    "amazon-dash"  : 1.1.0    , installed 1.1.0
      Adapter    "backitup"     : 2.3.3    , installed 2.3.3
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "cloud"        : 4.1.0    , installed 4.1.0
      Adapter    "daikin"       : 1.3.3    , installed 1.3.3
      Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
      Adapter    "deconz"       : 1.3.20   , installed 1.3.20
      Adapter    "devices"      : 1.0.9    , installed 1.0.9
      Adapter    "discovery"    : 2.7.5    , installed 2.7.5
      Adapter    "firetv"       : 1.0.0    , installed 1.0.0
      Adapter    "flot"         : 1.10.7   , installed 1.10.7
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "history"      : 1.10.5   , installed 1.10.5
      Adapter    "hm-rega"      : 3.0.39   , installed 3.0.39
      Adapter    "hm-rpc"       : 1.15.11  , installed 1.15.11
      Adapter    "hmip"         : 1.15.4   , installed 1.15.4
      Adapter    "hue"          : 3.6.5    , installed 3.6.5
      Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
      Adapter    "i2c"          : 1.2.1    , installed 1.2.1
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 1.9.8    , installed 1.9.8
      Adapter    "iot"          : 1.8.24   , installed 1.8.24
      Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
      Adapter    "javascript"   : 5.2.21   , installed 5.2.21
      Controller "js-controller": 4.0.21   , installed 4.0.21
      Adapter    "meross"       : 1.10.1   , installed 1.10.1
      Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 2.4.2    , installed 2.4.2
      Adapter    "onvif"        : 0.4.4    , installed 0.4.4
      Adapter    "ping"         : 1.5.0    , installed 1.5.0
      Adapter    "rpi2"         : 1.3.1    , installed 1.3.1
      Adapter    "samsung"      : 0.2.9    , installed 0.2.9
      Adapter    "sia"          : 1.0.4    , installed 1.0.4
      Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
      Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
      Adapter    "socketio"     : 4.1.4    , installed 4.1.4
      Adapter    "solax"        : 0.3.7    , installed 0.3.7
      Adapter    "text2command" : 2.1.1    , installed 2.1.1
      Adapter    "tr-064"       : 4.2.15   , installed 4.2.15
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "velux"        : 0.0.7    , installed 0.0.7
      Adapter    "vis"          : 1.4.5    , installed 1.4.5
      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
      Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
      Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
      Adapter    "web"          : 4.2.0    , installed 4.2.0
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "ws"           : 1.2.0    , installed 1.2.0
      Objects and States
      Objects: 	9350
      States: 	7445
      W: GPG error: https://apt.pivccu.de/piVCCU stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 541230BA05C38BC4
      E: The repository 'https://apt.pivccu.de/piVCCU stable InRelease' is not signed.
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       710268300  12768/io.jarvis.0
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       20751      445/deCONZ
      tcp        0      0 0.0.0.0:50001           0.0.0.0:*               LISTEN      1001       710261634  11645/io.sia.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        15943      415/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          711437637  30282/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          711439926  30859/cupsd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       22096      445/deCONZ
      tcp        0      0 192.168.1.221:12002     0.0.0.0:*               LISTEN      1001       711473005  10727/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       710249984  9627/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       710249977  9627/iobroker.js-co
      tcp        0      0 192.168.1.221:12010     0.0.0.0:*               LISTEN      1001       711480777  11259/io.hm-rpc.1
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        15932      415/systemd-resolve
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          21754      780/vncserver-x11-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       710249260  9714/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       710270042  12661/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          711437639  30282/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          711439925  30859/cupsd
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       710274458  11986/io.upnp.0
      tcp6       0      0 :::5355                 :::*                    LISTEN      102        15935      415/systemd-resolve
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          21753      780/vncserver-x11-c
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        15942      415/systemd-resolve
      udp        0      0 0.0.0.0:44150           0.0.0.0:*                           1001       710994379  11423/io.broadlink2
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          711451900  30916/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       710263244  11423/io.broadlink2
      udp        0      0 0.0.0.0:49876           0.0.0.0:*                           1001       710265501  11986/io.upnp.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        711440939  31347/avahi-daemon:
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        15931      415/systemd-resolve
      udp        0      0 0.0.0.0:50001           0.0.0.0:*                           1001       710261635  11645/io.sia.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       710271145  12987/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       710269968  11986/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       22803      445/deCONZ
      udp        0      0 0.0.0.0:34175           0.0.0.0:*                           108        711440941  31347/avahi-daemon:
      udp6       0      0 :::60452                :::*                                108        711440942  31347/avahi-daemon:
      udp6       0      0 :::5353                 :::*                                108        711440940  31347/avahi-daemon:
      udp6       0      0 :::5355                 :::*                                102        15934      415/systemd-resolve
      udp6       0      0 :::1900                 :::*                                1001       710271150  12987/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       710271149  12987/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       710271148  12987/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       710271147  12987/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       710271146  12987/io.deconz.0
      2023-12-13 20:04:47.297  - error: node-red.0 (31052) Error: Huejay: Request failed with status code 403
          at /opt/iobroker/iobroker-data/node-red/node_modules/huejay/lib/Transport.js:106:15
          at processTicksAndRejections (internal/process/task_queues.js:95:5)
      2023-12-13 20:04:47.297  - error: node-red.0 (31052) Huejay: Request failed with status code 403
      2023-12-13 20:04:47.766  - info: node-red.0 (31052) terminating
      2023-12-13 20:04:47.767  - warn: node-red.0 (31052) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2023-12-13 20:04:48.320  - info: node-red.0 (9829) node-red exited with 6
      2023-12-13 20:04:51.421  - error: hue.0 (9964) connect EHOSTUNREACH 192.168.1.229:80
      2023-12-13 20:04:51.422  - warn: hue.0 (9964) Could not get configuration from HUE bridge (192.168.1.229:80)
      2023-12-13 20:04:51.878  - error: hue.1 (10446) Client network socket disconnected before secure TLS connection was established
      2023-12-13 20:04:51.879  - warn: hue.1 (10446) Could not get configuration from HUE bridge (192.168.1.221:443)
      2023-12-13 20:04:51.953  - error: hue.1 (10446) Could not poll all: Cannot read property 'configuration' of undefined
      2023-12-13 20:04:53.321  - info: node-red.0 (9829) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      2023-12-13 20:04:56.913  - error: hue.1 (10446) Client network socket disconnected before secure TLS connection was established
      2023-12-13 20:04:56.917  - warn: hue.1 (10446) Could not get configuration from HUE bridge (192.168.1.221:443)
      2023-12-13 20:04:57.477  - error: hm-rpc.2 (29960) Init not possible, going to stop: response timeout
      2023-12-13 20:04:57.482  - info: hm-rpc.2 (29960) binrpc -> 192.168.1.220:2001/ init ["xmlrpc_bin://192.168.1.221:12001",""]
      2023-12-13 20:04:57.894  - info: host.raspberrypi instance system.adapter.tr-064.4 started with pid 32313
      2023-12-13 20:04:58.590  - info: hm-rpc.2 (29960) terminating
      2023-12-13 20:04:58.594  - info: hm-rpc.2 (29960) Terminated (NO_ERROR): Without reason
      2023-12-13 20:04:59.502  - info: hm-rpc.2 (29960) terminating with timeout
      2023-12-13 20:04:59.582  - error: hue.0 (9964) connect EHOSTUNREACH 192.168.1.229:80
      2023-12-13 20:04:59.583  - warn: hue.0 (9964) Could not get configuration from HUE bridge (192.168.1.229:80)
      2023-12-13 20:05:00.017  - info: host.raspberrypi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
      2023-12-13 20:05:00.018  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.2 because enabled
      iob diag has finished.
      Press any key for a summary
      @radix75
      Das pivccu-Repo ist nicht korrekt angelegt.
        Radix75
        @thomas-braun : Raspberry Pi 5, 8GB RAM ? Ich hätte echt gerne eine Grafische Oberfläche.
        Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
        • R Radix75
          Wozu? Wo in diesem Thread hast du denn beispielsweise jetzt ein graphisches Tool benötigt?
          Sind eh alles Kommandozeilenbefehle oder in der Web-Oberfläche/im Browser. Also wozu ein komplettes Desktop-Environment durchschleppen?
          • R Radix75
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @radix75
            Versuch uns bitte wirklich zu erklären wozu die grafische Oberfläche denn gerne hättest.
            Die Eingabeaufforderung (Commandline) erreichts du leicht auch via ssh von jedem (aktuellen) Windows PC aus.
            Welche Aktionen soll dein Vater auf dem Pi durchführen? (Bin auch schon 65+) 73 ist wirklich kein Alter, aber Linux Grundkenntnisse braucht man halt wenn man am Pi was machen will. Und wenn der "Nebenbei" auch als Webbrowser, Mail Client und ... dienen sollte wirds wohl auch mit nem Pi5 eng.
            Ich kann heir Thomas nur unterstützen:
            Backup machen
            Neue SD rein und neues OS + aktuellen ioBroker installieren
            Backup einspielen.
            Wenn du die alte Karte nicht überschreibst und auch die Backups sicherst hast du beliebig viele Versuche wenn was schief geht.
            UND -da bisher nicht werwähnt
            Da stimmt auch was nicht...
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
              Radix75
              @thomas-braun ich benutze das Programm SD Card Copier zur Sicherung für meinen Vater hängt der Monitor und die Maus / Tastatur im Hausanschlussraum dies ist der einzige gemeinsame Raum er kann von dort den Webbrowser öffnen und so z. B in der Homematic etwas schalten außerdem hat er so die Möglichkeit eines Neustarts der Raspberry falls Garnichts mehr geht.
              • mcm1957M mcm1957
                @radix75
                Backup machen
                Backup einspielen.
                @mcm57 sagte in Daikin Adapter:
                Das dürfte mit dem nicht richtig laufenden dhcpcd zusammenhängen.
                • R Radix75
                  @radix75
                  Das sind alles keine Gründe für einen Desktop.
                  • R Radix75
                    @radix75
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                    Docker          : false
                    Kernel          : armv7l
                    Userland        : armhf
                    CPU threads: 4
                    Current issues:
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server: 	true
                    Desktop: 	LXDE-pi
                    Terminal: 	x11
                    *** MEMORY ***
                    Swap:           99M         99M          0B
                             3787 M total memory
                             2025 M used memory
                              588 M active memory
                              678 M free memory
                              192 M buffer memory
                              891 M swap cache
                               99 M total swap
                               99 M used swap
                                0 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    5.5G	/var/
                    4.4G	/var/cache/apt
                    4.4G	/var/cache
                    749M	/var/lib
                    USB-Devices by-id:
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin: 		5.3.1
                    javascript: 	5.2.21
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects: 	9350
                    States: 	7445
                    Pending Updates: 0
                    @radix75 na geht doch!
                    da hab ich jetztcwas zu lesen
                      @radix75
                      Radix75
                      @thomas-braun du musst davon ausgehen das mein Vater nicht mit der ganzen Homematic Steuerung klar kommt er wollte am liebsten das ich alles wieder über Schalter laufen lasse so wie früher. Ich hätte gerne ein Smart Home und er eben nicht.
                      Es gab schon öfter Probleme mit dem Smart Home deswegen der Monitor für den Reset sonst besteht wieder das Risiko das Probleme mit dem Hammer gelöst werden ist leider schon vorgekommen fand ich nicht so toll.
                        @homoran @Radix75
                        wie die anderen schon schrieben ist da einiges auch in der Unterkonstruktion krumm.
                        Kann sein, dass das mit den verwaisten Dateifragmentrn zusammenhängt. Ist aber egal.
                        Das System muss sauber neu aufgesetzt werden.
                        Möglich dass du mit einem iobroker Backup noch deine Konfigurationen retten kannst.
                        piVCCU musst du nach der Anleitung von Alex auf Github neu installieten, aber auch da kannst du ein Backup wiederherstellen.
                        • R Radix75
                          schliesst einander doch nicht aus.
                          ich habe übersll die Aktoren für Markenschalter, da geht beides
                          • R Radix75
                            Den Konflikt bekommst du aber nicht durch einen unnötigen Desktop gelöst.
                            Da wäre ein ordentlich aufgesetztes und dadurch stabil funktionierendes System wesentlich hilfreicher.
                              Radix75
                              schrieb am zuletzt editiert von Radix75
                              @homoran Habe leider nur die für die Verteilerdosen im Einsatz .
                              Ich würde mich erstmal abmelden für heute.
                              Währe nett wenn mir jemand die Links zur Neuinstallation und Sicherung posten könnte.
                              Ich schaue morgen nochmal rein bis dann und vielen Dank für die Hilfe
                              https://www.debian.org/releases/bookworm/debian-installer/ welches ist der richtige downloade ?
                              • R Radix75
                                @radix75
                                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                Ich würde aber zuerst den Kram auf Stand bringen und dann mit dem aktuellen Kram auf das neue System umziehen.
                                  @radix75
                                  Radix75
                                  @thomas-braun r
                                  radix1975@raspberrypi5:~ $ curl -sLf https://iobroker.net/install.sh | bash -
                                  library: loaded
                                  Library version=2023-10-13
                                      Welcome to the ioBroker installer!
                                      Installer version: 2023-10-13
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/4)
                                  OK:1 http://deb.debian.org/debian bookworm InRelease
                                  OK:2 http://phoscon.de/apt/deconz bookworm InRelease
                                  OK:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                  OK:4 http://deb.debian.org/debian bookworm-updates InRelease
                                  OK:5 http://archive.raspberrypi.com/debian bookworm InRelease
                                  OK:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                                      Creating ioBroker user and directory (2/4)
                                  Directory /opt/iobroker created
                                      Installing ioBroker (3/4)
                                  npm ERR! code 1
                                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                  npm ERR! command failed
                                  npm ERR! command sh -c node iobroker.js setup first
                                  npm ERR! node:internal/modules/cjs/loader:1137
                                  npm ERR!   throw err;
                                  npm ERR!   ^
                                  npm ERR!
                                  npm ERR! Error: Cannot find module '@colors/colors/safe'
                                  npm ERR! Require stack:
                                  npm ERR! - /opt/iobroker/node_modules/logform/colorize.js
                                  npm ERR! - /opt/iobroker/node_modules/logform/levels.js
                                  npm ERR! - /opt/iobroker/node_modules/logform/index.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/winston/lib/winston.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/logger.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js
                                  npm ERR! - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
                                  npm ERR! - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                  npm ERR!     at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                                  npm ERR!     at Module._load (node:internal/modules/cjs/loader:975:27)
                                  npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19)
                                  npm ERR!     at require (node:internal/modules/helpers:177:18)
                                  npm ERR!     at Object.<anonymous> (/opt/iobroker/node_modules/logform/colorize.js:3:16)
                                  npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1356:14)
                                  npm ERR!     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
                                  npm ERR!     at Module.load (node:internal/modules/cjs/loader:1197:32)
                                  npm ERR!     at Module._load (node:internal/modules/cjs/loader:1013:12)
                                  npm ERR!     at Module.require (node:internal/modules/cjs/loader:1225:19) {
                                  npm ERR!   code: 'MODULE_NOT_FOUND',
                                  npm ERR!   requireStack: [
                                  npm ERR!     '/opt/iobroker/node_modules/logform/colorize.js',
                                  npm ERR!     '/opt/iobroker/node_modules/logform/levels.js',
                                  npm ERR!     '/opt/iobroker/node_modules/logform/index.js',
                                  npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-common/node_modules/winston/lib/winston.js',
                                  npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/logger.js',
                                  npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-common/build/index.js',
                                  npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup.js',
                                  npm ERR!     '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
                                  npm ERR!     '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  npm ERR!   ]
                                  npm ERR! }
                                  npm ERR!
                                  npm ERR! Node.js v18.19.0
                                  npm ERR! A complete log of this run can be found in: /home/radix1975/.npm/_logs/2023-12-23T08_03_27_029Z-debug-0.log
                                      Finalizing installation (4/4)
                                  Enabling autostart...
                                  Autostart enabled!
                                      ioBroker was installed successfully
                                      Open http://192.168.1.225:8081 in a browser and start configuring!
                                  You need to re-login before doing anything else on the console!
                                  Ist die installation so richtig???
                                  ich habe zahlreiche Fehlermeldungen und komme auch nicht auf die Webseite
                                  Die Website ist nicht erreichbar
                                  192.168.1.225 hat die Verbindung abgelehnt.
                                  Versuche Folgendes:
                                  Verbindung prüfen
                                  Checking the proxy and the firewall
                                  ERR_CONNECTION_REFUSED
                                  Überprüfen Sie Ihre Internetverbindung.
                                  Check any cables and reboot any routers, modems, or other network devices you may be using.
                                  Erlauben Sie Opera den Netzwerkzugriff in den Firewall- oder Antivirus-Einstellungen.
                                  Falls das Programm schon in der Liste mit erlaubtem Netzwerkzugriff eingetragen ist, entferne es aus der Liste und füge es noch einmal hinzu.
                                  Falls du einen Proxyserver verwendest…
                                  Überprüfen Sie Ihre Proxyservereinstellungen oder kontaktieren Sie Ihren Netzwerkadministrator, um sicherzustellen, dass der Proxyserver funktioniert. Wenn Sie glauben, dass Sie keinen Proxyserver verwenden sollten: Rufen Sie das Hauptmenü und dann > Einstellungen > Proxyeinstellungen ändern… > LAN-Einstellungen auf. Deaktivieren Sie »Proxyserver für LAN verwenden«.
                                  • R Radix75
                                    @thomas-braun r
                                    library: loaded
                                    npm ERR! code 1
                                    npm ERR!   throw err;
                                    npm ERR!   ^
                                    npm ERR!
                                    npm ERR!   ]
                                    npm ERR! }
                                    npm ERR!
                                    Autostart enabled!
                                    Versuche Folgendes:
                                    Verbindung prüfen
                                    Dann ist die Installation auch nicht richtig...
                                      Radix75
                                      @thomas-braun mit welchen Befehlen kann ich es nochmal neu machen?
                                      • R Radix75
                                        @radix75
                                        Mach es komplett neu, lass die Sprache dann auf Englisch und leg das phoscon-Repository nach aktuellem Stand an.
                                        Was da allerdings genau klemmt sehr ich auch nicht. Netzwerk läuft mit IPv6?
                                          @radix75
                                          Radix75
                                          @thomas-braun Netzwerk kann IP6 die Rasp. hat aber derzeit eine IP 4 Adresse.
                                          "Mach es komplett neu, lass die Sprache dann auf Englisch und leg das phoscon-Repository nach aktuellem Stand an."
                                          Das bitte mal genau mit Befehlen erklären wie bekomme ich die def . Installation deinstalliert ?
