  3. Einsteigerfragen
  4. Installation
  5. Backup aus älterer Version einspielen
54 Beiträge 4 Kommentatoren 7.8k Aufrufe 2 Beobachtet
  • F firefighter166
    @Marc-Berg
    Also den Hostname bekomme ich ja von der Container Station vorgegeben ist die ID. Ich habe jetzt mal den oberen Befehlt ausgeführt und hier das Ergebnis.
    # iob fix
    library: loaded
    Library version=2023-10-13
        Welcome to the ioBroker installation fixer!
        Script version: 2023-10-13
        Installing prerequisites (1/5)
    Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
    Get:2 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
    Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
    Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8.062 kB]
    Get:6 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [776 B]
    Get:7 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages [260 kB]
    Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [17,7 kB]
    Fetched 8.553 kB in 4s (2.130 kB/s)
    Reading package lists... Done
    Docker detected!
    If you have any adapters that need the CAP_NET_ADMIN capability,
    you need to start the docker container with the option --cap-add=NET_ADMIN
    and manually add that capability to node
        Checking ioBroker user and directory permissions (2/5)
    This system does not support setting default permissions.
    Do not use npm to manually install adapters unless you know what you are doing!
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Cannot compress states.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
        at JsonlDB.open (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alcalzone/jsonl-db/build/lib/db.js:185:19)
        at async compressDB (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:37:9)
        at async main (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:78:17)
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
        at async main (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:93:17)
    No relevant JSONL files found to compress, skip
        Checking autostart (5/5)
    Unsupported init system, cannot enable autostart!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    # pkill -u iobroker
    # iob host this
    Cannot use this command in multihost!
    iobroker host this
    Initialize current host
    Options:
      --help  Show help  [boolean]
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @firefighter166 sagte in Backup aus älterer Version einspielen:
    Ich kenne die Containerstation nicht, aber das Internet sagt mir:
    Um einen Containernamen in der QNAP Container Station zu vergeben, können Sie die folgenden Schritte befolgen:
    • Wechseln Sie im Menü zu Container.
    • Klicken Sie auf Erstellen. Das Fenster “Container erstellen” wird geöffnet.
    • Wählen Sie ein Image aus.
    • Klicken Sie auf Weiter.
    • Geben Sie einen Containernamen an, der 2-64 Zeichen enthält, mit einem Buchstaben oder einer Zahl beginnt und nur die folgenden Zeichen enthält:
      Gültige Zeichen: A-Z , a-z , 0-9
      Gültige Sonderzeichen: Bindestrich (-) , Unterstrich (_) oder Punkt (.)1
    F 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      firefighter166
      @marc-berg
      Sorry habe mich wohl falsch ausgedrückt das mit dem Hostnamen kann ich natürlich selbst bestimmt der lautet aktuell iobroker-1. Was ich nicht vorgeben kann, ist die Container ID.
      • F firefighter166
        @marc-berg
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        @firefighter166
        Zeig' mal Screenshots von deiner Containererstellung
        F 2 Antworten Letzte Antwort
          @firefighter166
          firefighter166
          @marc-berg
          und dann auf Fertig stellen und der Container wird erzeugt.
            @firefighter166
            firefighter166
            @marc-berg
            jetzt habe ich das gefunden mit dem Hostnamen und den muss ich mir jetzt aus dem Backup suchen, wenn ich es richtig verstanden habe.
            • F firefighter166
              @marc-berg
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              Genau, wie ich das jetzt sehe, hast du den Namen immer leer gelassen, dann wird wohl die ID vergeben. Stattdessen sollte da der alte Name rein. Müsste "iobroker-1" sein.
                firefighter166
                @marc-berg
                Jetzt sollte es mit dem Hostnamen doch passen, jetzt mal abwarten was passiert, wenn ich versuche das Backup einzuspielen.
                -------------------------     2023-12-08 11:42:07      -------------------------
                -----              Welcome to your ioBroker Docker container!              -----
                -----                    Startupscript is now running!                     -----
                -----                          Please be patient!                          -----
                -----                          System Information                          -----
                -----                    arch:                x86_64                       -----
                -----                    hostname:            iobroker-1                   -----
                -----                          Version Information                         -----
                -----                    image:               v7.2.0                       -----
                -----                    build:               2023-02-10T23:45:25+00:00    -----
                -----                    node:                v16.20.2                     -----
                -----                    npm:                 8.19.4                       -----
                -----                        Environment Variables                         -----
                -----                    SETGID:              1000                         -----
                -----                    SETUID:              1000                         -----
                -----                  Step 1 of 5: Preparing container                   -----
                This is not the first run of this container. Skipping first run preparation.
                -----             Step 2 of 5: Detecting ioBroker installation             -----
                Existing installation of ioBroker detected in "/opt/iobroker".
                -----             Step 3 of 5: Checking ioBroker installation              -----
                (Re)setting permissions (This might take a while! Please be patient!)... Done.
                Fixing "sudo-bug" by replacing sudo with gosu... Done.
                Hostname in ioBroker matches the hostname of this container.
                No action required.
                -----                Step 4 of 5: Applying special settings                -----
                Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                -----                    Step 5 of 5: ioBroker startup                     -----
                Starting ioBroker...
                ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                host.iobroker-1 check instance "system.adapter.admin.0" for host "iobroker-1"
                host.iobroker-1 check instance "system.adapter.discovery.0" for host "iobroker-1"
                host.iobroker-1 check instance "system.adapter.backitup.0" for host "iobroker-1"
                Send diag info: {"uuid":"f53b18b4-a546-4bd5-8027-f5107b97e1d9","language":"de","country":"","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.20.2","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.5.12","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"AMD GX-424CC SOC with Radeon(TM) R5E Graphics","cpus":4,"mem":15734272000,"ostype":"Linux","city":""}
                ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                • F firefighter166
                  @marc-berg
                  No action required.
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  ich bin zuversichtlich.
                    firefighter166
                    @marc-berg
                    Das ist mal der Log beim Backup einspielen.
                    ioBroker Backitup Restore
                    Restore and Restart completed successfully!!
                    [DEBUG] [iobroker] Start ioBroker Restore ...
                    [DEBUG] [iobroker] iobroker controller daemon is not running
                    [DEBUG] [iobroker] host.iobroker-1 OK.
                    [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup.
                    [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.
                    [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change!
                    [DEBUG] [iobroker] Removing current installation of iobroker.admin
                    [DEBUG] [iobroker] removed 22 packages in 3s
                    [DEBUG] [iobroker] 35 packages are looking for funding
                    [DEBUG] [iobroker] run `npm fund` for details
                    [DEBUG] [iobroker] Removing current installation of iobroker.backitup
                    [DEBUG] [iobroker] removed 124 packages in 3s
                    [DEBUG] [iobroker] 25 packages are looking for funding
                    [DEBUG] [iobroker] Removing current installation of iobroker.discovery
                    [DEBUG] [iobroker] removed 43 packages in 2s
                    [DEBUG] [iobroker] 13 packages are looking for funding
                    [DEBUG] [iobroker] host.iobroker-1 Clear all objects and states...
                    [DEBUG] [iobroker] clean 144 objects...
                    [DEBUG] [iobroker] clean 101 states...
                    [DEBUG] [iobroker] host.iobroker-1 done.
                    [DEBUG] [iobroker] host.iobroker-1 Processed 0/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8800/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 9000/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 9200/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 9400/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 9600/9998 objects
                    [DEBUG] [iobroker] host.iobroker-1 Processed 9800/9998 objects
                    [DEBUG] [iobroker] 9998 objects restored.
                    [DEBUG] [iobroker] host.iobroker-1 Processed 0/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 1800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 2800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 3800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 4800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 5800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 6800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7400/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7600/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 7800/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8000/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8200/8477 states
                    [DEBUG] [iobroker] host.iobroker-1 Processed 8400/8477 states
                    [DEBUG] [iobroker] 8477 states restored.
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cache.manifest
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cordova.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/add_kian.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/app.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/backgrounds.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/doc.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/montserrat-regular-webfont.woff
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/styles.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-common-user.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-editor.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.src.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/add.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-height.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-center-2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-left.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-right-2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-bottom-2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-center-2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-top-2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-width.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/bar.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/cancel.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/checkbox.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/container.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/control.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/copy.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/delete.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/dialog.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-horizontal-equal.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-vertical-equal.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/door.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/filter.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupFixed.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupVisibility.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/info.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lamp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lock.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lockIcon.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/navigation.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/ok.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/refresh-4.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rename.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rgb.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/shutter.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/state.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/stateful.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/static.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/table.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/temperature.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/timestamp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/tools.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/value.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/window.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Heating.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Lamp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/OutsideTemp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Window.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/box-radial.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/flowers.jpg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/oblique-line-bk.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-10.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-15.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-20.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-25.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-30.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-40.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-5.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-50.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOff.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOn.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_off.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_on.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/camera.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/cc-nc-by.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/disconnect.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/door-bell.mp3
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/editmode-pattern.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/eg_trans.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/favicon.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/faviconEdit.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-closed.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-opened.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/gear-icon-md.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/hexabump.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/kde_folder.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/no_filter.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/sound.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/tank.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/vis.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/zip.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.src.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/app.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/config.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/conn.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/connSignalR.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/add.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/back.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/delete.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/down.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/edit-rename.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new-7.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/icons.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/list.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/play.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/refresh.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/stop.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/up.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/circleLeftIcon.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/JS.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/bmp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/css.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-blue.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-brown.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-green.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/gif.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/img2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/jpg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/misc.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/mp3.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/png.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/prg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/svg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/undef.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/wav.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/zip.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/bmp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/css.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-blue.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-brown.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-green.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/gif.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/img2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/jpg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/js.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/misc.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/mp3.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/png.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/prg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/svg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/undef.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/wav.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/zip.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/vis.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visAbout.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEdit.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditExt.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditInspect.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditTemplates.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditWelcome.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visUtils.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visWizard.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/words.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ace.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-language_tools.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-searchbox.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-css.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-html.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-javascript.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-css.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-html.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-javascript.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/add2home-2.0.8.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/channel.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/device.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/icons.gif
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/loading.gif
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/state.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.jquery.min.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.min.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/farbtastic.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.jgrowl.min.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect-1.13.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect.filter.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/megafish.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-navbar.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-vertical.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/delete.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/edit-undo-8.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/logout.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/marker.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/mask.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_bottom.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_left.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_right.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_top.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/wheel.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/add2home-2.0.8.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/can.custom.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/colResizable-1.5.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/dropzone.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/farbtastic.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/html2canvas.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ba-resize.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.base64.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.fancytree-all.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.inputmask.bundle.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.map
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect-1.13.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect.filter-1.5pre.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.datepicker.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.touch-punch.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.wakeup.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jqueryui.selectmenu.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/loStorage.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/moment-with-locales.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/quo.standalone.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/superclick.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/translate.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//manifest.webmanifest
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//offline.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fire.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fireColor.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/lowbattery.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motion.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motionColor.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/online.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterColor.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterDrops.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColor.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColorRed.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/css/table.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/doc.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_AckBool.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BasicState.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BulbOnOffCtrl.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ContainerView.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FilterDropdown.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FullScreen.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTML.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTMLnavigation.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HtmlLogout.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Image.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Note.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_RedNumber.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ScreenResolution.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Shape.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Speech2Text.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulContainerView8.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulIFrame8.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulImage.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TableBody.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TimeValue.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBool.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCheckbox.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrl.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrlSvg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolSelect.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloat.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloatBar.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueGesture.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueInput.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueLastchange.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueList.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml8.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueString.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringImg.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringRaw.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueTimestamp.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_iFrame.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplFrame.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplLink.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/doc_example_hm_val_number.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micActive.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micDetected.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micInactive.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micSent.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micStarted.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/pin_red5.svg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/js/table.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts/img/Prev_tplEchartsChart.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/css/style.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/js/fritzdect.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/css/style.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/calendar.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/messages.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/info.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/words.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/css/jquery.jqplot.min.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/doc.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/img/Prev_MeterGauge.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/js/jquery.jqplot.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/doc.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerButtonDialog.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialog.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialogExternal.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerIconDialog.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiDialog.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiIconDialog.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/ct.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/hue.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/internet-web-browser-2.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/doc.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Carousel.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Swipe.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/noSwipe.jpg
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout-shapes.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.touchSwipe.min.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/jquery.sliderTabs.js
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicator.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicatorActive.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftArrow.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftPanelArrow.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightArrow.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightPanelArrow.png
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css.orig
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.min.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/dev.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/homematic.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/special.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/weather.html
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-user.css
                    [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-views.json
                    [DEBUG] [iobroker] Reinstalling adapter "admin" from "iobroker.admin@6.2.22"
                    [DEBUG] [iobroker] added 87 packages, and changed 1 package in 12s
                    [DEBUG] [iobroker] 24 packages are looking for funding
                    [DEBUG] [iobroker] Reinstalling adapter "backitup" from "iobroker.backitup@2.4.12"
                    [DEBUG] [iobroker] added 76 packages, and removed 9 packages in 9s
                    [DEBUG] [iobroker] 28 packages are looking for funding
                    [DEBUG] [iobroker] Forced restore - executing setup ...
                    [DEBUG] [iobroker] System successfully restored!
                    [DEBUG] [iobroker] ioBroker Restore completed successfully
                    [EXIT] 0 **** Restore completed successfully!! ****
                    [EXIT] **** Docker Container restart now... ****
                    • F firefighter166
                      @marc-berg
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      @firefighter166
                      Die VIS wird wegen eines Bugs erstmal nicht funktionieren, hier muss erstmal ein Downgrade gemacht werden.
                      Guck mal hier: https://forum.iobroker.net/topic/70838/vis-kann-nach-restore-nicht-installiert-werden/3
                      Danach machst du ein Upgrade aller Adapter und des js-controllers auf die Version 5.0.x. Dieses Backup kannst du dann auch auf einem aktuellen Image einspielen.
                        @firefighter166
                        firefighter166
                        schrieb am zuletzt editiert von firefighter166
                        @marc-berg said in Backup aus älterer Version einspielen:
                        Ich glaube es nicht es ist wieder da. Jetzt mache ich mal Stück für Stück weiter damit ich auf die neue Version umziehen kann.
                        Wo finde ich nochmal den Befehl für das Upgrade des js-controllers?
                        • F firefighter166
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          In dieser alten Versionskonstellation so:
                          pkill -u iobroker
                          iobroker update
                          iobroker upgrade self
                          • F Offline
                            firefighter166
                            @marc-berg
                            Vielen Dank bis hierhin für die super Unterstützung. Ich habe jetzt bis auf dem Raspberry welcher als Slave läuft alles auf dem neusten Stand.
                            Marc BergM Thomas BraunT 2 Antworten Letzte Antwort
                            • F firefighter166
                              @marc-berg
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              @firefighter166
                              In Zukunft bitte mit allen relevanten Infos gleich rausrücken. Dass du eine Multihost-Umgebung hast, wäre wichtig gewesen zu wissen.
                              @homoran sagte in Backup aus älterer Version einspielen:
                              @firefighter166
                              jetzt bring mal alle notwendigen Informationen strukturiert bei.
                              • F Offline
                                firefighter166
                                @marc-berg
                                Also ich habe im Keller einen Raspberry der in der Unterverteilung sitzt und mittels Node Red meine Zählerstände abliest. Diese wurde dann in einer Influx DB gespeichert.
                                • F firefighter166
                                  @marc-berg
                                  Dann bring den auch auf Stand.
                                    firefighter166
                                    Habe ich über zwei Wege versucht, er lässt sich nicht Updaten. Egal ob über dem Update Button in der Oberfläche oder über die Konsole
                                    • F firefighter166
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      Und der Raspi sagt dann "ich hab' kein Bock auf 'n Upgrade", oder gibt's auch eine Fehlermeldung? :-)
                                      • F firefighter166
                                        Das glaube ich nicht.
                                          firefighter166
                                          @marc-berg
                                          Mit folgendem Befehl habe ich es direkt auf dem Pi mittels Putty probiert.
                                          cd /opt/iobroker/
                                          sudo iobroker stop
                                          sudo iobroker update
                                          sudo iobroker upgrade self
                                          sudo iobroker start
                                          Das macht er dann folgendes:
                                          pi@iobrokerstrom:/opt/iobroker $ sudo iobroker stop
                                          pi@iobrokerstrom:/opt/iobroker $ sudo iobroker update
                                          Used repository: stable
                                          Adapter    "admin"        : 6.12.0   , installed 5.3.4  [Updatable]
                                          Adapter    "backitup"     : 2.8.7    , installed 2.3.3  [Updatable]
                                          Adapter    "devices"      : 1.1.5    , installed 1.0.12 [Updatable]
                                          Adapter    "discovery"    : 4.2.0    , installed 2.8.0  [Updatable]
                                          Controller "js-controller": 5.0.16   , installed 4.0.23 [Updatable]
                                          Adapter    "node-red"     : 4.0.3    , installed 3.3.1  [Updatable]
                                          Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                                          pi@iobrokerstrom:/opt/iobroker $ sudo iobroker upgrade self
                                          Update js-controller from @4.0.23 to @5.0.16
                                          Stopped Objects DB
                                          Stopped States DB
                                          NPM version: 6.14.16
                                          Installing iobroker.js-controller@5.0.16... (System call)
                                          pi@iobrokerstrom:/opt/iobroker $ sudo iobroker start
