  3. Einsteigerfragen
  4. Installation
  5. Backup aus älterer Version einspielen
54 Beiträge 4 Kommentatoren 7.7k Aufrufe 2 Beobachtet
  • F firefighter166
    @marc-berg
    ich bin jetzt nochmal auf die Docker-Image 6.0 zurück gegangen und jetzt müsste es mit Node.js 14x passen oder?
    -------------------------     2023-12-07 14:19:06      -------------------------
    -----                 Welcome to your ioBroker-container!                  -----
    -----                    Startupscript is now running.                     -----
    -----                          Please be patient!                          -----
    -----                        Debugging information                         -----
    -----                                System                                -----
    -----                    arch:                x86_64                       -----
    -----                             Docker-Image                             -----
    -----                    image:               v6.0.0                       -----
    -----                    build:               2022-02-25T23:46:04+00:00    -----
    -----                               Versions                               -----
    -----                    node:                v14.21.3                     -----
    -----                    npm:                 6.14.18                      -----
    -----                                 ENV                                  -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    -----                  Step 1 of 5: Preparing container                   -----
    Nothing to do here.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in /opt/iobroker.
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)Setting folder permissions (This might take a while! Please be patient!)...
    Done.
    Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
    Done.
    -----                Step 4 of 5: Applying special settings                -----
    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    For more information take a look at readme.md on Github!
    -----                    Step 5 of 5: ioBroker startup                     -----
    Starting ioBroker...
    host.3b2fadb26f50 check instance "system.adapter.admin.0" for host "3b2fadb26f50"
    host.3b2fadb26f50 check instance "system.adapter.discovery.0" for host "3b2fadb26f50"
    host.3b2fadb26f50 check instance "system.adapter.backitup.0" for host "3b2fadb26f50"
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @firefighter166
    sieht gut aus, versuch dein Glück.
    F 1 Antwort Letzte Antwort
    • Marc BergM Marc Berg
      @firefighter166
      firefighter166
      schrieb am zuletzt editiert von firefighter166
      @marc-berg
      ich habe jetzt nochmal auf die Docker Version 7 umgeschwenkt, da ich eine neuere Backupdatei gefunden haben.
      installedVersion ist hier 4.0.23
      Die Backup Datei lässt sich auch einspielen nur beim Container Neustart hängt er sich dann auf.
      -------------------------     2023-12-07 14:54:41      -------------------------
      -----              Welcome to your ioBroker Docker container!              -----
      -----                    Startupscript is now running!                     -----
      -----                          System Information                          -----
      -----                    hostname:            5e92feb257f9                 -----
      -----                          Version Information                         -----
      -----                    image:               v7.2.0                       -----
      -----                    build:               2023-02-10T23:45:25+00:00    -----
      -----                    node:                v16.20.2                     -----
      -----                    npm:                 8.19.4                       -----
      -----                        Environment Variables                         -----
      This is not the first run of this container. Skipping first run preparation.
      Existing installation of ioBroker detected in "/opt/iobroker".
      (Re)setting permissions (This might take a while! Please be patient!)... Done.
      Fixing "sudo-bug" by replacing sudo with gosu... Done.
      Hostname in ioBroker matches the hostname of this container.
      No action required.
      For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
      ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
      ================================== > LOG REDIRECT system.adapter.admin.0 => true [starting]
      host.iobroker-1 check instance "system.adapter.admin.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.history.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.influxdb.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.influxdb.1" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.javascript.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.node-red.0" for host "slavestrom"
      host.iobroker-1 check instance "system.adapter.telegram.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.alexa2.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.alexa2.1" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.hm-rega.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.hm-rpc.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.hue.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.modbus.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.mqtt.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.smartmeter.0" for host "slavestrom"
      host.iobroker-1 check instance "system.adapter.sonoff.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.sonos.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.sony-bravia.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.discovery.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.backitup.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.daswetter.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.device-reminder.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.echarts.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.energymanager.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.fritzdect.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.fronius.1" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.habpanel.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.info.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.kecontact.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.pvforecast.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.smartgarden.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.vis.0" for host "5e92feb257f9"
      host.iobroker-1 check instance "system.adapter.web.0" for host "5e92feb257f9"
      • F firefighter166
        @marc-berg
        No action required.
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        @firefighter166
        Ja, so ganz ohne Fehlermeldung ...
        Versuch mal folgendes:
        In den Container gehen und
        iob fix
        pkill -u iobroker
        iob host this
        Neustart des Containers.
          @firefighter166
          iob fix
          pkill -u iobroker
          iob host this
          firefighter166
          @marc-berg
          Keine Chance der Container bleibt an der selben Stelle hängen.
          • F firefighter166
            @marc-berg
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            @firefighter166 sagte in Backup aus älterer Version einspielen:
            @marc-berg
            Der Container-/Hostname ist jetzt scheinbar ein anderer als in der Sicherung.
            Benenne den mal wie vorher (also "iobroker-1"), und dann nochmal mit leerem Ordner starten.
              @marc-berg
              firefighter166
              @marc-berg said in Backup aus älterer Version einspielen:
              Wie beschrieben habe ich den Container Namen auf iobroker-1 angepasst, was auch hier nicht zum Erfolg geführt hat. Der Container bleibt immer wieder an der selben Stelle hängen. Habe es jetzt auch mal mit einer Backup Datei versucht die nur zwei Tage älter ist, keine Chance.
              • F firefighter166
                Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                keine Chance.
                so ganz ohne Fehlermeldungen ist das jetzt Fischen im Trüben. Wie sieht es denn im Ordner /iobroker/log aus?
                  keine Chance.
                  firefighter166
                  Welchen Ordner muss ich denn leeren, damit ich den Container erneute starten kann?
                  Hier ist mal der Log:
                  2023-12-08 09:48:33.700  - info: host.db4cbef0bc80 iobroker.js-controller version 4.0.24 js-controller starting
                  2023-12-08 09:48:33.706  - info: host.db4cbef0bc80 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-12-08 09:48:33.707  - info: host.db4cbef0bc80 hostname: db4cbef0bc80, node: v16.20.2
                  2023-12-08 09:48:33.708  - info: host.db4cbef0bc80 ip addresses: 10.0.1.126
                  2023-12-08 09:48:33.957  - info: host.db4cbef0bc80 connected to Objects and States
                  2023-12-08 09:48:33.994  - info: host.db4cbef0bc80 Node.js version has changed from unknown to 16.20.2
                  2023-12-08 09:48:34.033  - info: host.db4cbef0bc80 added notifications configuration of host
                  2023-12-08 09:48:34.251  - info: host.db4cbef0bc80 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                  2023-12-08 09:48:34.289  - info: host.db4cbef0bc80 3 instances found
                  2023-12-08 09:48:34.299  - info: host.db4cbef0bc80 starting 3 instances
                  2023-12-08 09:48:34.360  - info: host.db4cbef0bc80 instance system.adapter.admin.0 started with pid 2206
                  2023-12-08 09:48:34.553  - info: host.db4cbef0bc80 Created UUID: ee7c0d0e-d418-4da2-bc87-b8432405ee7b
                  2023-12-08 09:48:36.403  - info: admin.0 (2206) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.2, js-controller: 4.0.24
                  2023-12-08 09:48:36.460  - info: admin.0 (2206) requesting all states
                  2023-12-08 09:48:36.461  - info: admin.0 (2206) requesting all objects
                  2023-12-08 09:48:36.562  - info: admin.0 (2206) received all objects
                  2023-12-08 09:48:36.599  - info: admin.0 (2206) Request actual repository...
                  2023-12-08 09:48:36.622  - info: host.db4cbef0bc80 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2023-12-08 09:48:36.711  - info: admin.0 (2206) http server listening on port 8081
                  2023-12-08 09:48:36.712  - info: admin.0 (2206) Use link "http://localhost:8081" to configure.
                  2023-12-08 09:48:36.720  - info: admin.0 (2206) socket.io server listening on port 8081
                  2023-12-08 09:48:36.782  - warn: admin.0 (2206) Repository cannot be read: Active repo - stable
                  2023-12-08 09:48:36.783  - warn: admin.0 (2206) Active repository "stable" cannot be read
                  2023-12-08 09:48:36.802  - error: admin.0 (2206) Cannot update news: TypeError: newNews.forEach is not a function
                  2023-12-08 09:48:39.179  - info: host.db4cbef0bc80 instance system.adapter.discovery.0 started with pid 2233
                  2023-12-08 09:48:39.381  - info: admin.0 (2206) Repository received successfully.
                  2023-12-08 09:48:40.900  - info: discovery.0 (2233) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.2, js-controller: 4.0.24
                  2023-12-08 09:48:42.335  - info: host.db4cbef0bc80 instance system.adapter.backitup.0 started with pid 2248
                  2023-12-08 09:48:44.139  - info: backitup.0 (2248) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.2, js-controller: 4.0.24
                  2023-12-08 09:48:44.262  - info: backitup.0 (2248) [iobroker] backup was activated at 02:40 every 1 day(s)
                  2023-12-08 09:51:09.032  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
                  2023-12-08 09:51:10.922  - info: admin.0 (2206) <== Disconnect system.user.admin from ::ffff:10.0.2.171 admin
                  2023-12-08 09:51:19.847  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
                  2023-12-08 09:52:35.912  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
                  2023-12-08 09:52:38.526  - info: admin.0 (2206) <== Disconnect system.user.admin from ::ffff:10.0.2.171
                  2023-12-08 09:52:54.495  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
                  2023-12-08 09:53:52.048  - info: host.db4cbef0bc80 received SIGTERM
                  2023-12-08 09:53:52.053  - info: host.db4cbef0bc80 stopInstance system.adapter.admin.0 (force=false, process=true)
                  2023-12-08 09:53:52.054  - info: host.db4cbef0bc80 stopInstance system.adapter.discovery.0 (force=false, process=true)
                  2023-12-08 09:53:52.054  - info: host.db4cbef0bc80 stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2023-12-08 09:53:52.065  - info: admin.0 (2206) Got terminate signal TERMINATE_YOURSELF
                  2023-12-08 09:53:52.065  - info: discovery.0 (2233) Got terminate signal TERMINATE_YOURSELF
                  2023-12-08 09:53:52.069  - info: backitup.0 (2248) Got terminate signal TERMINATE_YOURSELF
                  2023-12-08 09:53:52.066  - info: admin.0 (2206) terminating http server on port 8081
                  2023-12-08 09:53:52.070  - info: admin.0 (2206) terminating
                  2023-12-08 09:53:52.072  - info: admin.0 (2206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-12-08 09:53:52.067  - info: discovery.0 (2233) terminating
                  2023-12-08 09:53:52.078  - info: discovery.0 (2233) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-12-08 09:53:52.085  - info: host.db4cbef0bc80 stopInstance system.adapter.admin.0 send kill signal
                  2023-12-08 09:53:52.071  - info: backitup.0 (2248) cleaned everything up...
                  2023-12-08 09:53:52.082  - info: backitup.0 (2248) terminating
                  2023-12-08 09:53:52.083  - info: backitup.0 (2248) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-12-08 09:53:52.088  - info: host.db4cbef0bc80 stopInstance system.adapter.discovery.0 send kill signal
                  2023-12-08 09:53:52.090  - info: host.db4cbef0bc80 stopInstance system.adapter.backitup.0 send kill signal
                  2023-12-08 09:53:52.683  - info: host.db4cbef0bc80 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-12-08 09:53:52.684  - info: host.db4cbef0bc80 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-12-08 09:53:52.685  - info: host.db4cbef0bc80 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-12-08 09:53:52.685  - info: host.db4cbef0bc80 All instances are stopped.
                  2023-12-08 09:53:52.879  - info: host.db4cbef0bc80 terminated
                  2023-12-08 09:55:57.094  - info: host.iobroker-1 iobroker.js-controller version 4.0.24 js-controller starting
                  2023-12-08 09:55:57.101  - info: host.iobroker-1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-12-08 09:55:57.102  - info: host.iobroker-1 hostname: iobroker-1, node: v16.20.2
                  2023-12-08 09:55:57.103  - info: host.iobroker-1 ip addresses: 10.0.1.126
                  2023-12-08 09:55:58.041  - warn: host.iobroker-1-Server Objects 10.0.1.65:42936 Error from InMemDB: Error: Unknown Script
                  2023-12-08 09:55:58.670  - info: host.iobroker-1 connected to Objects and States
                  2023-12-08 09:55:58.727  - info: host.iobroker-1 added notifications configuration of host
                  2023-12-08 09:55:58.742  - info: host.iobroker-1 Node.js version has changed from 14.20.0 to 16.20.2
                  2023-12-08 09:55:58.932  - info: host.iobroker-1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                  2023-12-08 09:56:00.160  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeCurrent"
                  2023-12-08 09:56:00.163  - info: host.iobroker-1 34 instances found
                  2023-12-08 09:56:00.182  - warn: host.iobroker-1 does not start any instances on this host
                  2023-12-08 09:56:00.218  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeNewest"
                  2023-12-08 09:56:00.228  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeNewestNext"
                  2023-12-08 09:56:00.238  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmCurrent"
                  2023-12-08 09:56:00.247  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmNewest"
                  2023-12-08 09:56:00.298  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmNewestNext"
                  2023-12-08 09:56:00.309  - info: host.iobroker-1 Some obsolete host states deleted.
                  2023-12-08 10:01:31.417  - info: host.iobroker-1 received SIGTERM
                  2023-12-08 10:01:31.460  - info: host.iobroker-1 terminated
                  2023-12-08 10:02:12.098  - info: host.iobroker-1 iobroker.js-controller version 4.0.24 js-controller starting
                  2023-12-08 10:02:12.104  - info: host.iobroker-1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-12-08 10:02:12.105  - info: host.iobroker-1 hostname: iobroker-1, node: v16.20.2
                  2023-12-08 10:02:12.106  - info: host.iobroker-1 ip addresses: 10.0.1.126
                  2023-12-08 10:02:13.373  - info: host.iobroker-1 connected to Objects and States
                  2023-12-08 10:02:13.424  - info: host.iobroker-1 added notifications configuration of host
                  2023-12-08 10:02:14.131  - info: host.iobroker-1 34 instances found
                  2023-12-08 10:02:14.150  - warn: host.iobroker-1 does not start any instances on this host
                  2023-12-08 10:10:19.617  - info: host.iobroker-1 received SIGTERM
                  2023-12-08 10:10:19.661  - info: host.iobroker-1 terminated
                  2023-12-08 10:11:04.261  - info: host.iobroker-1 iobroker.js-controller version 4.0.24 js-controller starting
                  2023-12-08 10:11:04.270  - info: host.iobroker-1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2023-12-08 10:11:04.271  - info: host.iobroker-1 hostname: iobroker-1, node: v16.20.2
                  2023-12-08 10:11:04.272  - info: host.iobroker-1 ip addresses: 10.0.1.126
                  2023-12-08 10:11:05.632  - info: host.iobroker-1 connected to Objects and States
                  2023-12-08 10:11:05.688  - info: host.iobroker-1 added notifications configuration of host
                  2023-12-08 10:11:06.486  - info: host.iobroker-1 34 instances found
                  2023-12-08 10:11:06.505  - warn: host.iobroker-1 does not start any instances on this host
                  • F firefighter166
                    Marc BergM Offline
                    Marc BergM Offline
                    Marc Berg
                    Ich sehe da immer noch den Hostnamen "db4cbef0bc80". Wie erstellst du den Container, und was hat der Befehl von oben
                    iob host this
                    ausgegeben?
                    • F Offline
                      firefighter166
                      @Marc-Berg
                      Also den Hostname bekomme ich ja von der Container Station vorgegeben ist die ID. Ich habe jetzt mal den oberen Befehlt ausgeführt und hier das Ergebnis.
                      # iob fix
                      library: loaded
                      Library version=2023-10-13
                          Welcome to the ioBroker installation fixer!
                          Script version: 2023-10-13
                          Installing prerequisites (1/5)
                      Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                      Get:2 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                      Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
                      Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8.062 kB]
                      Get:6 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [776 B]
                      Get:7 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages [260 kB]
                      Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [17,7 kB]
                      Fetched 8.553 kB in 4s (2.130 kB/s)
                      Reading package lists... Done
                      Docker detected!
                      If you have any adapters that need the CAP_NET_ADMIN capability,
                      you need to start the docker container with the option --cap-add=NET_ADMIN
                      and manually add that capability to node
                          Checking ioBroker user and directory permissions (2/5)
                      This system does not support setting default permissions.
                      Do not use npm to manually install adapters unless you know what you are doing!
                          Check and cleanup npm temporary directories (3/5)
                      Done.
                          Database maintenance (4/5)
                      Checking for uncompressed JSONL databases... This might take a while!
                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                      Cannot compress states.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                          at JsonlDB.open (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alcalzone/jsonl-db/build/lib/db.js:185:19)
                          at async compressDB (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:37:9)
                          at async main (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:78:17)
                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                      Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                          at async main (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:93:17)
                      No relevant JSONL files found to compress, skip
                          Checking autostart (5/5)
                      Unsupported init system, cannot enable autostart!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      # pkill -u iobroker
                      # iob host this
                      Cannot use this command in multihost!
                      iobroker host this
                      Initialize current host
                      Options:
                        --help  Show help  [boolean]
                      • F firefighter166
                        @Marc-Berg
                        # iob fix
                        library: loaded
                        Docker detected!
                        Done.
                        # pkill -u iobroker
                        # iob host this
                        iobroker host this
                        Options:
                        Marc BergM Offline
                        Marc BergM Offline
                        Marc Berg
                        Ich kenne die Containerstation nicht, aber das Internet sagt mir:
                        Um einen Containernamen in der QNAP Container Station zu vergeben, können Sie die folgenden Schritte befolgen:
                        • Wechseln Sie im Menü zu Container.
                        • Klicken Sie auf Erstellen. Das Fenster “Container erstellen” wird geöffnet.
                        • Wählen Sie ein Image aus.
                        • Klicken Sie auf Weiter.
                        • Geben Sie einen Containernamen an, der 2-64 Zeichen enthält, mit einem Buchstaben oder einer Zahl beginnt und nur die folgenden Zeichen enthält:
                          Gültige Zeichen: A-Z , a-z , 0-9
                          Gültige Sonderzeichen: Bindestrich (-) , Unterstrich (_) oder Punkt (.)1
                          firefighter166
                          @marc-berg
                          Sorry habe mich wohl falsch ausgedrückt das mit dem Hostnamen kann ich natürlich selbst bestimmt der lautet aktuell iobroker-1. Was ich nicht vorgeben kann, ist die Container ID.
                          • F firefighter166
                            @marc-berg
                            Marc BergM Offline
                            Marc BergM Offline
                            Marc Berg
                            @firefighter166
                            Zeig' mal Screenshots von deiner Containererstellung
                            F 2 Antworten Letzte Antwort
                              @firefighter166
                              firefighter166
                              @marc-berg
                              und dann auf Fertig stellen und der Container wird erzeugt.
                                @firefighter166
                                firefighter166
                                @marc-berg
                                jetzt habe ich das gefunden mit dem Hostnamen und den muss ich mir jetzt aus dem Backup suchen, wenn ich es richtig verstanden habe.
                                • F firefighter166
                                  @marc-berg
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  Genau, wie ich das jetzt sehe, hast du den Namen immer leer gelassen, dann wird wohl die ID vergeben. Stattdessen sollte da der alte Name rein. Müsste "iobroker-1" sein.
                                    firefighter166
                                    @marc-berg
                                    Jetzt sollte es mit dem Hostnamen doch passen, jetzt mal abwarten was passiert, wenn ich versuche das Backup einzuspielen.
                                    -------------------------     2023-12-08 11:42:07      -------------------------
                                    -----                    hostname:            iobroker-1                   -----
                                    No action required.
                                    host.iobroker-1 check instance "system.adapter.admin.0" for host "iobroker-1"
                                    host.iobroker-1 check instance "system.adapter.discovery.0" for host "iobroker-1"
                                    host.iobroker-1 check instance "system.adapter.backitup.0" for host "iobroker-1"
                                    Send diag info: {"uuid":"f53b18b4-a546-4bd5-8027-f5107b97e1d9","language":"de","country":"","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.20.2","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.5.12","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"AMD GX-424CC SOC with Radeon(TM) R5E Graphics","cpus":4,"mem":15734272000,"ostype":"Linux","city":""}
                                    • F firefighter166
                                      @marc-berg
                                      No action required.
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      ich bin zuversichtlich.
                                        firefighter166
                                        @marc-berg
                                        Das ist mal der Log beim Backup einspielen.
                                        ioBroker Backitup Restore
                                        Restore and Restart completed successfully!!
                                        [DEBUG] [iobroker] Start ioBroker Restore ...
                                        [DEBUG] [iobroker] iobroker controller daemon is not running
                                        [DEBUG] [iobroker] host.iobroker-1 OK.
                                        [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup.
                                        [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.
                                        [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change!
                                        [DEBUG] [iobroker] Removing current installation of iobroker.admin
                                        [DEBUG] [iobroker] removed 22 packages in 3s
                                        [DEBUG] [iobroker] 35 packages are looking for funding
                                        [DEBUG] [iobroker] run `npm fund` for details
                                        [DEBUG] [iobroker] Removing current installation of iobroker.backitup
                                        [DEBUG] [iobroker] removed 124 packages in 3s
                                        [DEBUG] [iobroker] 25 packages are looking for funding
                                        [DEBUG] [iobroker] Removing current installation of iobroker.discovery
                                        [DEBUG] [iobroker] removed 43 packages in 2s
                                        [DEBUG] [iobroker] 13 packages are looking for funding
                                        [DEBUG] [iobroker] host.iobroker-1 Clear all objects and states...
                                        [DEBUG] [iobroker] clean 144 objects...
                                        [DEBUG] [iobroker] clean 101 states...
                                        [DEBUG] [iobroker] host.iobroker-1 done.
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 0/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8800/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 9000/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 9200/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 9400/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 9600/9998 objects
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 9800/9998 objects
                                        [DEBUG] [iobroker] 9998 objects restored.
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 0/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 1800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 2800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 3800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 4800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 5800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 6800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7400/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7600/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 7800/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8000/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8200/8477 states
                                        [DEBUG] [iobroker] host.iobroker-1 Processed 8400/8477 states
                                        [DEBUG] [iobroker] 8477 states restored.
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cache.manifest
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cordova.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/add_kian.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/app.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/backgrounds.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/doc.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/montserrat-regular-webfont.woff
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/styles.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-common-user.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-editor.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.src.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/add.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-height.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-center-2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-left.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-right-2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-bottom-2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-center-2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-top-2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-width.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/bar.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/cancel.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/checkbox.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/container.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/control.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/copy.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/delete.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/dialog.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-horizontal-equal.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-vertical-equal.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/door.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/filter.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupFixed.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupVisibility.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/info.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lamp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lock.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lockIcon.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/navigation.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/ok.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/refresh-4.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rename.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rgb.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/shutter.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/state.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/stateful.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/static.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/table.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/temperature.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/timestamp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/tools.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/value.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/window.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Heating.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Lamp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/OutsideTemp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Window.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/box-radial.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/flowers.jpg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/oblique-line-bk.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-10.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-15.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-20.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-25.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-30.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-40.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-5.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-50.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOff.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOn.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_off.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_on.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/camera.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/cc-nc-by.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/disconnect.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/door-bell.mp3
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/editmode-pattern.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/eg_trans.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/favicon.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/faviconEdit.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-closed.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-opened.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/gear-icon-md.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/hexabump.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/kde_folder.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/no_filter.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/sound.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/tank.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/vis.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/zip.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.src.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/app.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/config.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/conn.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/connSignalR.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/add.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/back.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/delete.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/down.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/edit-rename.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new-7.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/icons.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/list.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/play.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/refresh.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/stop.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/up.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/circleLeftIcon.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/JS.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/bmp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/css.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-blue.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-brown.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-green.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/gif.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/img2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/jpg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/misc.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/mp3.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/png.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/prg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/svg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/undef.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/wav.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/zip.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/bmp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/css.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-blue.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-brown.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-green.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/gif.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/img2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/jpg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/js.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/misc.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/mp3.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/png.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/prg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/svg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/undef.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/wav.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/zip.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/vis.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visAbout.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEdit.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditExt.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditInspect.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditTemplates.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditWelcome.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visUtils.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visWizard.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/words.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ace.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-language_tools.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-searchbox.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-css.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-html.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-javascript.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-css.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-html.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-javascript.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/add2home-2.0.8.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/channel.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/device.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/icons.gif
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/loading.gif
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/state.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.jquery.min.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.min.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/farbtastic.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.jgrowl.min.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect-1.13.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect.filter.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/megafish.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-navbar.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-vertical.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/delete.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/edit-undo-8.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/logout.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/marker.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/mask.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_bottom.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_left.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_right.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_top.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/wheel.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/add2home-2.0.8.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/can.custom.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/colResizable-1.5.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/dropzone.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/farbtastic.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/html2canvas.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ba-resize.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.base64.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.fancytree-all.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.inputmask.bundle.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.map
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect-1.13.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect.filter-1.5pre.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.datepicker.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.touch-punch.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.wakeup.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jqueryui.selectmenu.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/loStorage.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/moment-with-locales.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/quo.standalone.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/superclick.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/translate.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//manifest.webmanifest
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//offline.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fire.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fireColor.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/lowbattery.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motion.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motionColor.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/online.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterColor.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterDrops.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColor.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColorRed.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/css/table.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/doc.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_AckBool.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BasicState.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BulbOnOffCtrl.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ContainerView.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FilterDropdown.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FullScreen.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTML.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTMLnavigation.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HtmlLogout.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Image.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Note.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_RedNumber.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ScreenResolution.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Shape.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Speech2Text.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulContainerView8.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulIFrame8.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulImage.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TableBody.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TimeValue.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBool.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCheckbox.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrl.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrlSvg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolSelect.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloat.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloatBar.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueGesture.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueInput.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueLastchange.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueList.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml8.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueString.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringImg.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringRaw.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueTimestamp.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_iFrame.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplFrame.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplLink.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/doc_example_hm_val_number.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micActive.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micDetected.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micInactive.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micSent.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micStarted.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/pin_red5.svg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/js/table.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts/img/Prev_tplEchartsChart.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/css/style.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/js/fritzdect.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/css/style.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/calendar.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/messages.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/info.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/words.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/css/jquery.jqplot.min.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/doc.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/img/Prev_MeterGauge.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/js/jquery.jqplot.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/doc.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerButtonDialog.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialog.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialogExternal.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerIconDialog.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiDialog.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiIconDialog.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/ct.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/hue.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/internet-web-browser-2.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/doc.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Carousel.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Swipe.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/noSwipe.jpg
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout-shapes.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.touchSwipe.min.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/jquery.sliderTabs.js
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicator.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicatorActive.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftArrow.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftPanelArrow.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightArrow.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightPanelArrow.png
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css.orig
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.min.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/dev.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/homematic.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/special.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/weather.html
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-user.css
                                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-views.json
                                        [DEBUG] [iobroker] Reinstalling adapter "admin" from "iobroker.admin@6.2.22"
                                        [DEBUG] [iobroker] added 87 packages, and changed 1 package in 12s
                                        [DEBUG] [iobroker] 24 packages are looking for funding
                                        [DEBUG] [iobroker] Reinstalling adapter "backitup" from "iobroker.backitup@2.4.12"
                                        [DEBUG] [iobroker] added 76 packages, and removed 9 packages in 9s
                                        [DEBUG] [iobroker] 28 packages are looking for funding
                                        [DEBUG] [iobroker] Forced restore - executing setup ...
                                        [DEBUG] [iobroker] System successfully restored!
                                        [DEBUG] [iobroker] ioBroker Restore completed successfully
                                        [EXIT] 0 **** Restore completed successfully!! ****
                                        [EXIT] **** Docker Container restart now... ****
                                        • F firefighter166
                                          @marc-berg
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          @firefighter166
                                          Die VIS wird wegen eines Bugs erstmal nicht funktionieren, hier muss erstmal ein Downgrade gemacht werden.
                                          Guck mal hier: https://forum.iobroker.net/topic/70838/vis-kann-nach-restore-nicht-installiert-werden/3
                                          Danach machst du ein Upgrade aller Adapter und des js-controllers auf die Version 5.0.x. Dieses Backup kannst du dann auch auf einem aktuellen Image einspielen.
