  3. Einsteigerfragen
  4. Installation
  5. Backup aus älterer Version einspielen
54 Beiträge 4 Kommentatoren 7.8k Aufrufe 2 Beobachtet
  • F firefighter166
    @marc-berg said in Backup aus älterer Version einspielen:
    so ganz ohne Fehlermeldungen ist das jetzt Fischen im Trüben. Wie sieht es denn im Ordner /iobroker/log aus?
    Welchen Ordner muss ich denn leeren, damit ich den Container erneute starten kann?
    Hier ist mal der Log:
    2023-12-08 09:48:33.700  - info: host.db4cbef0bc80 iobroker.js-controller version 4.0.24 js-controller starting
    2023-12-08 09:48:33.706  - info: host.db4cbef0bc80 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-08 09:48:33.707  - info: host.db4cbef0bc80 hostname: db4cbef0bc80, node: v16.20.2
    2023-12-08 09:48:33.708  - info: host.db4cbef0bc80 ip addresses: 10.0.1.126
    2023-12-08 09:48:33.957  - info: host.db4cbef0bc80 connected to Objects and States
    2023-12-08 09:48:33.994  - info: host.db4cbef0bc80 Node.js version has changed from unknown to 16.20.2
    2023-12-08 09:48:34.033  - info: host.db4cbef0bc80 added notifications configuration of host
    2023-12-08 09:48:34.251  - info: host.db4cbef0bc80 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-12-08 09:48:34.289  - info: host.db4cbef0bc80 3 instances found
    2023-12-08 09:48:34.299  - info: host.db4cbef0bc80 starting 3 instances
    2023-12-08 09:48:34.360  - info: host.db4cbef0bc80 instance system.adapter.admin.0 started with pid 2206
    2023-12-08 09:48:34.553  - info: host.db4cbef0bc80 Created UUID: ee7c0d0e-d418-4da2-bc87-b8432405ee7b
    2023-12-08 09:48:36.403  - info: admin.0 (2206) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.20.2, js-controller: 4.0.24
    2023-12-08 09:48:36.460  - info: admin.0 (2206) requesting all states
    2023-12-08 09:48:36.461  - info: admin.0 (2206) requesting all objects
    2023-12-08 09:48:36.562  - info: admin.0 (2206) received all objects
    2023-12-08 09:48:36.599  - info: admin.0 (2206) Request actual repository...
    2023-12-08 09:48:36.622  - info: host.db4cbef0bc80 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-12-08 09:48:36.711  - info: admin.0 (2206) http server listening on port 8081
    2023-12-08 09:48:36.712  - info: admin.0 (2206) Use link "http://localhost:8081" to configure.
    2023-12-08 09:48:36.720  - info: admin.0 (2206) socket.io server listening on port 8081
    2023-12-08 09:48:36.782  - warn: admin.0 (2206) Repository cannot be read: Active repo - stable
    2023-12-08 09:48:36.783  - warn: admin.0 (2206) Active repository "stable" cannot be read
    2023-12-08 09:48:36.802  - error: admin.0 (2206) Cannot update news: TypeError: newNews.forEach is not a function
    2023-12-08 09:48:39.179  - info: host.db4cbef0bc80 instance system.adapter.discovery.0 started with pid 2233
    2023-12-08 09:48:39.381  - info: admin.0 (2206) Repository received successfully.
    2023-12-08 09:48:40.900  - info: discovery.0 (2233) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.2, js-controller: 4.0.24
    2023-12-08 09:48:42.335  - info: host.db4cbef0bc80 instance system.adapter.backitup.0 started with pid 2248
    2023-12-08 09:48:44.139  - info: backitup.0 (2248) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.2, js-controller: 4.0.24
    2023-12-08 09:48:44.262  - info: backitup.0 (2248) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-12-08 09:51:09.032  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
    2023-12-08 09:51:10.922  - info: admin.0 (2206) <== Disconnect system.user.admin from ::ffff:10.0.2.171 admin
    2023-12-08 09:51:19.847  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
    2023-12-08 09:52:35.912  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
    2023-12-08 09:52:38.526  - info: admin.0 (2206) <== Disconnect system.user.admin from ::ffff:10.0.2.171
    2023-12-08 09:52:54.495  - info: admin.0 (2206) ==> Connected system.user.admin from ::ffff:10.0.2.171
    2023-12-08 09:53:52.048  - info: host.db4cbef0bc80 received SIGTERM
    2023-12-08 09:53:52.053  - info: host.db4cbef0bc80 stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-12-08 09:53:52.054  - info: host.db4cbef0bc80 stopInstance system.adapter.discovery.0 (force=false, process=true)
    2023-12-08 09:53:52.054  - info: host.db4cbef0bc80 stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-12-08 09:53:52.065  - info: admin.0 (2206) Got terminate signal TERMINATE_YOURSELF
    2023-12-08 09:53:52.065  - info: discovery.0 (2233) Got terminate signal TERMINATE_YOURSELF
    2023-12-08 09:53:52.069  - info: backitup.0 (2248) Got terminate signal TERMINATE_YOURSELF
    2023-12-08 09:53:52.066  - info: admin.0 (2206) terminating http server on port 8081
    2023-12-08 09:53:52.070  - info: admin.0 (2206) terminating
    2023-12-08 09:53:52.072  - info: admin.0 (2206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-08 09:53:52.067  - info: discovery.0 (2233) terminating
    2023-12-08 09:53:52.078  - info: discovery.0 (2233) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-08 09:53:52.085  - info: host.db4cbef0bc80 stopInstance system.adapter.admin.0 send kill signal
    2023-12-08 09:53:52.071  - info: backitup.0 (2248) cleaned everything up...
    2023-12-08 09:53:52.082  - info: backitup.0 (2248) terminating
    2023-12-08 09:53:52.083  - info: backitup.0 (2248) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-12-08 09:53:52.088  - info: host.db4cbef0bc80 stopInstance system.adapter.discovery.0 send kill signal
    2023-12-08 09:53:52.090  - info: host.db4cbef0bc80 stopInstance system.adapter.backitup.0 send kill signal
    2023-12-08 09:53:52.683  - info: host.db4cbef0bc80 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-08 09:53:52.684  - info: host.db4cbef0bc80 instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-08 09:53:52.685  - info: host.db4cbef0bc80 instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-12-08 09:53:52.685  - info: host.db4cbef0bc80 All instances are stopped.
    2023-12-08 09:53:52.879  - info: host.db4cbef0bc80 terminated
    2023-12-08 09:55:57.094  - info: host.iobroker-1 iobroker.js-controller version 4.0.24 js-controller starting
    2023-12-08 09:55:57.101  - info: host.iobroker-1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-08 09:55:57.102  - info: host.iobroker-1 hostname: iobroker-1, node: v16.20.2
    2023-12-08 09:55:57.103  - info: host.iobroker-1 ip addresses: 10.0.1.126
    2023-12-08 09:55:58.041  - warn: host.iobroker-1-Server Objects 10.0.1.65:42936 Error from InMemDB: Error: Unknown Script
    2023-12-08 09:55:58.670  - info: host.iobroker-1 connected to Objects and States
    2023-12-08 09:55:58.727  - info: host.iobroker-1 added notifications configuration of host
    2023-12-08 09:55:58.742  - info: host.iobroker-1 Node.js version has changed from 14.20.0 to 16.20.2
    2023-12-08 09:55:58.932  - info: host.iobroker-1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2023-12-08 09:56:00.160  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeCurrent"
    2023-12-08 09:56:00.163  - info: host.iobroker-1 34 instances found
    2023-12-08 09:56:00.182  - warn: host.iobroker-1 does not start any instances on this host
    2023-12-08 09:56:00.218  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeNewest"
    2023-12-08 09:56:00.228  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeNewestNext"
    2023-12-08 09:56:00.238  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmCurrent"
    2023-12-08 09:56:00.247  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmNewest"
    2023-12-08 09:56:00.298  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmNewestNext"
    2023-12-08 09:56:00.309  - info: host.iobroker-1 Some obsolete host states deleted.
    2023-12-08 10:01:31.417  - info: host.iobroker-1 received SIGTERM
    2023-12-08 10:01:31.460  - info: host.iobroker-1 terminated
    2023-12-08 10:02:12.098  - info: host.iobroker-1 iobroker.js-controller version 4.0.24 js-controller starting
    2023-12-08 10:02:12.104  - info: host.iobroker-1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-08 10:02:12.105  - info: host.iobroker-1 hostname: iobroker-1, node: v16.20.2
    2023-12-08 10:02:12.106  - info: host.iobroker-1 ip addresses: 10.0.1.126
    2023-12-08 10:02:13.373  - info: host.iobroker-1 connected to Objects and States
    2023-12-08 10:02:13.424  - info: host.iobroker-1 added notifications configuration of host
    2023-12-08 10:02:14.131  - info: host.iobroker-1 34 instances found
    2023-12-08 10:02:14.150  - warn: host.iobroker-1 does not start any instances on this host
    2023-12-08 10:10:19.617  - info: host.iobroker-1 received SIGTERM
    2023-12-08 10:10:19.661  - info: host.iobroker-1 terminated
    2023-12-08 10:11:04.261  - info: host.iobroker-1 iobroker.js-controller version 4.0.24 js-controller starting
    2023-12-08 10:11:04.270  - info: host.iobroker-1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-12-08 10:11:04.271  - info: host.iobroker-1 hostname: iobroker-1, node: v16.20.2
    2023-12-08 10:11:04.272  - info: host.iobroker-1 ip addresses: 10.0.1.126
    2023-12-08 10:11:05.632  - info: host.iobroker-1 connected to Objects and States
    2023-12-08 10:11:05.688  - info: host.iobroker-1 added notifications configuration of host
    2023-12-08 10:11:06.486  - info: host.iobroker-1 34 instances found
    2023-12-08 10:11:06.505  - warn: host.iobroker-1 does not start any instances on this host
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @firefighter166 sagte in Backup aus älterer Version einspielen:
    Ich sehe da immer noch den Hostnamen "db4cbef0bc80". Wie erstellst du den Container, und was hat der Befehl von oben
    iob host this
    ausgegeben?
    • F Offline
      firefighter166
      @Marc-Berg
      Also den Hostname bekomme ich ja von der Container Station vorgegeben ist die ID. Ich habe jetzt mal den oberen Befehlt ausgeführt und hier das Ergebnis.
      # iob fix
      library: loaded
      Library version=2023-10-13
          Welcome to the ioBroker installation fixer!
          Script version: 2023-10-13
          Installing prerequisites (1/5)
      Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Get:2 http://deb.debian.org/debian-security bullseye-security InRelease [48,4 kB]
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
      Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
      Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8.062 kB]
      Get:6 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [776 B]
      Get:7 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages [260 kB]
      Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [17,7 kB]
      Fetched 8.553 kB in 4s (2.130 kB/s)
      Reading package lists... Done
      Docker detected!
      If you have any adapters that need the CAP_NET_ADMIN capability,
      you need to start the docker container with the option --cap-add=NET_ADMIN
      and manually add that capability to node
          Checking ioBroker user and directory permissions (2/5)
      This system does not support setting default permissions.
      Do not use npm to manually install adapters unless you know what you are doing!
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Cannot compress states.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
          at JsonlDB.open (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alcalzone/jsonl-db/build/lib/db.js:185:19)
          at async compressDB (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:37:9)
          at async main (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:78:17)
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
          at async main (/opt/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:93:17)
      No relevant JSONL files found to compress, skip
          Checking autostart (5/5)
      Unsupported init system, cannot enable autostart!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      # pkill -u iobroker
      # iob host this
      Cannot use this command in multihost!
      iobroker host this
      Initialize current host
      Options:
        --help  Show help  [boolean]
      • F firefighter166
        @Marc-Berg
        # iob fix
        library: loaded
        Docker detected!
        Done.
        # pkill -u iobroker
        # iob host this
        iobroker host this
        Options:
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        Ich kenne die Containerstation nicht, aber das Internet sagt mir:
        Um einen Containernamen in der QNAP Container Station zu vergeben, können Sie die folgenden Schritte befolgen:
        • Wechseln Sie im Menü zu Container.
        • Klicken Sie auf Erstellen. Das Fenster “Container erstellen” wird geöffnet.
        • Wählen Sie ein Image aus.
        • Klicken Sie auf Weiter.
        • Geben Sie einen Containernamen an, der 2-64 Zeichen enthält, mit einem Buchstaben oder einer Zahl beginnt und nur die folgenden Zeichen enthält:
          Gültige Zeichen: A-Z , a-z , 0-9
          Gültige Sonderzeichen: Bindestrich (-) , Unterstrich (_) oder Punkt (.)1
        F 1 Antwort Letzte Antwort
        • Marc BergM Marc Berg
          firefighter166
          @marc-berg
          Sorry habe mich wohl falsch ausgedrückt das mit dem Hostnamen kann ich natürlich selbst bestimmt der lautet aktuell iobroker-1. Was ich nicht vorgeben kann, ist die Container ID.
          • F firefighter166
            @marc-berg
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            @firefighter166
            Zeig' mal Screenshots von deiner Containererstellung
            F 2 Antworten Letzte Antwort
              @firefighter166
              firefighter166
              @marc-berg
              und dann auf Fertig stellen und der Container wird erzeugt.
                @firefighter166
                firefighter166
                @marc-berg
                jetzt habe ich das gefunden mit dem Hostnamen und den muss ich mir jetzt aus dem Backup suchen, wenn ich es richtig verstanden habe.
                • F firefighter166
                  @marc-berg
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  Genau, wie ich das jetzt sehe, hast du den Namen immer leer gelassen, dann wird wohl die ID vergeben. Stattdessen sollte da der alte Name rein. Müsste "iobroker-1" sein.
                    firefighter166
                    @marc-berg
                    Jetzt sollte es mit dem Hostnamen doch passen, jetzt mal abwarten was passiert, wenn ich versuche das Backup einzuspielen.
                    -------------------------     2023-12-08 11:42:07      -------------------------
                    -----              Welcome to your ioBroker Docker container!              -----
                    -----                    Startupscript is now running!                     -----
                    -----                          Please be patient!                          -----
                    -----                          System Information                          -----
                    -----                    arch:                x86_64                       -----
                    -----                    hostname:            iobroker-1                   -----
                    -----                          Version Information                         -----
                    -----                    image:               v7.2.0                       -----
                    -----                    build:               2023-02-10T23:45:25+00:00    -----
                    -----                    node:                v16.20.2                     -----
                    -----                    npm:                 8.19.4                       -----
                    -----                        Environment Variables                         -----
                    -----                    SETGID:              1000                         -----
                    -----                    SETUID:              1000                         -----
                    -----                  Step 1 of 5: Preparing container                   -----
                    This is not the first run of this container. Skipping first run preparation.
                    -----             Step 2 of 5: Detecting ioBroker installation             -----
                    Existing installation of ioBroker detected in "/opt/iobroker".
                    -----             Step 3 of 5: Checking ioBroker installation              -----
                    (Re)setting permissions (This might take a while! Please be patient!)... Done.
                    Fixing "sudo-bug" by replacing sudo with gosu... Done.
                    Hostname in ioBroker matches the hostname of this container.
                    No action required.
                    -----                Step 4 of 5: Applying special settings                -----
                    Some adapters have special requirements/ settings which can be activated by the use of environment variables.
                    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs/).
                    -----                    Step 5 of 5: ioBroker startup                     -----
                    Starting ioBroker...
                    ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
                    host.iobroker-1 check instance "system.adapter.admin.0" for host "iobroker-1"
                    host.iobroker-1 check instance "system.adapter.discovery.0" for host "iobroker-1"
                    host.iobroker-1 check instance "system.adapter.backitup.0" for host "iobroker-1"
                    Send diag info: {"uuid":"f53b18b4-a546-4bd5-8027-f5107b97e1d9","language":"de","country":"","hosts":[{"version":"4.0.24","platform":"Javascript/Node.js","type":"linux"}],"node":"v16.20.2","arch":"x64","docker":true,"adapters":{"admin":{"version":"6.3.5","platform":"Javascript/Node.js"},"discovery":{"version":"3.1.0","platform":"Javascript/Node.js"},"backitup":{"version":"2.5.12","platform":"Javascript/Node.js"}},"statesType":"jsonl","objectsType":"jsonl","noInstances":3,"compactMode":false,"noCompactInstances":0,"model":"AMD GX-424CC SOC with Radeon(TM) R5E Graphics","cpus":4,"mem":15734272000,"ostype":"Linux","city":""}
                    ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
                    • F firefighter166
                      @marc-berg
                      No action required.
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      ich bin zuversichtlich.
                        firefighter166
                        @marc-berg
                        Das ist mal der Log beim Backup einspielen.
                        ioBroker Backitup Restore
                        Restore and Restart completed successfully!!
                        [DEBUG] [iobroker] Start ioBroker Restore ...
                        [DEBUG] [iobroker] iobroker controller daemon is not running
                        [DEBUG] [iobroker] host.iobroker-1 OK.
                        [DEBUG] [iobroker] The current version of js-controller differs from the version in the backup.
                        [DEBUG] [iobroker] The js-controller version of the backup can not be restored automatically.
                        [DEBUG] [iobroker] Note, that your backup might differ in behavior due to this version change!
                        [DEBUG] [iobroker] Removing current installation of iobroker.admin
                        [DEBUG] [iobroker] removed 22 packages in 3s
                        [DEBUG] [iobroker] 35 packages are looking for funding
                        [DEBUG] [iobroker] run `npm fund` for details
                        [DEBUG] [iobroker] Removing current installation of iobroker.backitup
                        [DEBUG] [iobroker] removed 124 packages in 3s
                        [DEBUG] [iobroker] 25 packages are looking for funding
                        [DEBUG] [iobroker] Removing current installation of iobroker.discovery
                        [DEBUG] [iobroker] removed 43 packages in 2s
                        [DEBUG] [iobroker] 13 packages are looking for funding
                        [DEBUG] [iobroker] host.iobroker-1 Clear all objects and states...
                        [DEBUG] [iobroker] clean 144 objects...
                        [DEBUG] [iobroker] clean 101 states...
                        [DEBUG] [iobroker] host.iobroker-1 done.
                        [DEBUG] [iobroker] host.iobroker-1 Processed 0/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8800/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 9000/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 9200/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 9400/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 9600/9998 objects
                        [DEBUG] [iobroker] host.iobroker-1 Processed 9800/9998 objects
                        [DEBUG] [iobroker] 9998 objects restored.
                        [DEBUG] [iobroker] host.iobroker-1 Processed 0/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 1800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 2800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 3800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 4800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 5800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 6800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7400/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7600/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 7800/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8000/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8200/8477 states
                        [DEBUG] [iobroker] host.iobroker-1 Processed 8400/8477 states
                        [DEBUG] [iobroker] 8477 states restored.
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cache.manifest
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//cordova.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/add_kian.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/app.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/backgrounds.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/doc.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/montserrat-regular-webfont.woff
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/styles.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-common-user.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis-editor.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/css/vis.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//edit.src.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/add.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-height.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-center-2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-left.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-horizontal-right-2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-bottom-2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-center-2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-vertical-top-2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/align-width.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/bar.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/cancel.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/checkbox.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/container.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/control.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/copy.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/delete.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/dialog.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-horizontal-equal.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/distribute-vertical-equal.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/door.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/filter.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupFixed.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/groupVisibility.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/info.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lamp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lock.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/lockIcon.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/navigation.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/ok.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/refresh-4.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rename.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/rgb.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/shutter.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/state.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/stateful.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/static.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/table.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/temperature.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/timestamp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/tools.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/value.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/icon/window.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Heating.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Lamp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/OutsideTemp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/Window.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/box-radial.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/flowers.jpg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/back/oblique-line-bk.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-10.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-15.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-20.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-25.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-30.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-40.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-5.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bg-dots-50.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOff.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulbOn.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_off.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/bulb_on.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/camera.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/cc-nc-by.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/disconnect.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/door-bell.mp3
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/editmode-pattern.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/eg_trans.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/favicon.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/faviconEdit.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-closed.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/garage-door-opened.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/gear-icon-md.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/hexabump.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/kde_folder.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/no_filter.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/sound.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/tank.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/vis.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/img/zip.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//index.src.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/app.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/config.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/conn.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/connSignalR.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/fileManager.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/add.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/back.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/delete.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/down.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/edit-rename.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new-7.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/folder-new.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/icons.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/list.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/play.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/refresh.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/stop.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/actions/up.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/circleLeftIcon.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/JS.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/bmp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/css.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-blue.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-brown.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/folder-green.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/gif.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/img2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/jpg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/misc.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/mp3.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/png.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/prg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/svg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/undef.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/wav.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/128/zip.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/bmp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/css.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-blue.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-brown.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/folder-green.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/gif.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/img2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/jpg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/js.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/misc.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/mp3.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/png.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/prg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/svg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/undef.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/wav.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/fm/icon/mine/24/zip.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/vis.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visAbout.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEdit.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditExt.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditInspect.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditTemplates.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visEditWelcome.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visUtils.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/visWizard.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/js/words.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ace.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-language_tools.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/ext-searchbox.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-css.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-html.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/mode-javascript.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-css.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-html.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/ace/worker-javascript.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/add2home-2.0.8.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/channel.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/device.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/icons.gif
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/loading.gif
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/state.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.jquery.min.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/fancytree/ui.fancytree.min.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/farbtastic.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery-ui-timepicker-addon-1.6.3.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.jgrowl.min.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect-1.13.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/jquery.multiselect.filter.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/megafish.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-navbar.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish-vertical.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/css/superfish/superfish.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/delete.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/edit-undo-8.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/logout.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/marker.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/mask.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_bottom.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_left.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_right.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/shape_align_top.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/img/wheel.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/add2home-2.0.8.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/can.custom.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/colResizable-1.5.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/dropzone.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/farbtastic.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/html2canvas.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-1.10.3.dragdropsort.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ba-resize.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.base64.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.fancytree-all.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.inputmask.bundle.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.map
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.jgrowl.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect-1.13.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.multiselect.filter-1.5pre.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.datepicker.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.ui.touch-punch.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jquery.wakeup.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/jqueryui.selectmenu.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/loStorage.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/moment-with-locales.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/quo.standalone.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/superclick.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/lib/js/translate.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//manifest.webmanifest
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis//offline.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fire.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/fireColor.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/lowbattery.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motion.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/motionColor.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/online.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterColor.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/waterDrops.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColor.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/signals/wifiColorRed.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/css/table.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/doc.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_AckBool.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BasicState.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_BulbOnOffCtrl.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ContainerView.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FilterDropdown.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_FullScreen.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTML.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HTMLnavigation.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_HtmlLogout.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Image.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Note.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_RedNumber.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ScreenResolution.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Shape.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_Speech2Text.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulContainerView8.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulIFrame8.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_StatefulImage.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TableBody.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_TimeValue.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBool.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCheckbox.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrl.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolCtrlSvg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueBoolSelect.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloat.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueFloatBar.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueGesture.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueInput.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueLastchange.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueList.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueListHtml8.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueString.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringImg.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueStringRaw.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_ValueTimestamp.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_iFrame.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplFrame.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/Prev_tplLink.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/doc_example_hm_val_number.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micActive.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micDetected.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micInactive.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micSent.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/micStarted.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/img/pin_red5.svg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic/js/table.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/basic.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts/img/Prev_tplEchartsChart.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/echarts.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/css/style.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect/js/fritzdect.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/fritzdect.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/css/style.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/calendar.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/img/messages.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/info.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info/js/words.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/info.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/css/jquery.jqplot.min.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/doc.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/img/Prev_MeterGauge.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot/js/jquery.jqplot.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqplot.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/doc.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerButtonDialog.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialog.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerDialogExternal.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_ContainerIconDialog.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiDialog.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/Prev_JquiIconDialog.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/ct.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/hue.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui/img/internet-web-browser-2.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/jqui.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/doc.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Carousel.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/Prev_Swipe.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/img/noSwipe.jpg
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout-shapes.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.roundabout.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe/js/jquery.touchSwipe.min.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/swipe.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/jquery.sliderTabs.js
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicator.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/indicatorActive.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftArrow.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/leftPanelArrow.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightArrow.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/images/rightPanelArrow.png
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.css.orig
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs/styles/jquery.sliderTabs.min.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/tabs.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/dev.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/homematic.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/special.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis/widgets/todo/weather.html
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-user.css
                        [DEBUG] [iobroker] host.iobroker-1 Upload user file "vis.0/main/vis-views.json
                        [DEBUG] [iobroker] Reinstalling adapter "admin" from "iobroker.admin@6.2.22"
                        [DEBUG] [iobroker] added 87 packages, and changed 1 package in 12s
                        [DEBUG] [iobroker] 24 packages are looking for funding
                        [DEBUG] [iobroker] Reinstalling adapter "backitup" from "iobroker.backitup@2.4.12"
                        [DEBUG] [iobroker] added 76 packages, and removed 9 packages in 9s
                        [DEBUG] [iobroker] 28 packages are looking for funding
                        [DEBUG] [iobroker] Forced restore - executing setup ...
                        [DEBUG] [iobroker] System successfully restored!
                        [DEBUG] [iobroker] ioBroker Restore completed successfully
                        [EXIT] 0 **** Restore completed successfully!! ****
                        [EXIT] **** Docker Container restart now... ****
                        • F firefighter166
                          @marc-berg
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          @firefighter166
                          Die VIS wird wegen eines Bugs erstmal nicht funktionieren, hier muss erstmal ein Downgrade gemacht werden.
                          Guck mal hier: https://forum.iobroker.net/topic/70838/vis-kann-nach-restore-nicht-installiert-werden/3
                          Danach machst du ein Upgrade aller Adapter und des js-controllers auf die Version 5.0.x. Dieses Backup kannst du dann auch auf einem aktuellen Image einspielen.
                            @firefighter166
                            firefighter166
                            schrieb am zuletzt editiert von firefighter166
                            Ich glaube es nicht es ist wieder da. Jetzt mache ich mal Stück für Stück weiter damit ich auf die neue Version umziehen kann.
                            Wo finde ich nochmal den Befehl für das Upgrade des js-controllers?
                            • F firefighter166
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              In dieser alten Versionskonstellation so:
                              pkill -u iobroker
                              iobroker update
                              iobroker upgrade self
                              • F Offline
                                firefighter166
                                @marc-berg
                                Vielen Dank bis hierhin für die super Unterstützung. Ich habe jetzt bis auf dem Raspberry welcher als Slave läuft alles auf dem neusten Stand.
                                Marc BergM Thomas BraunT 2 Antworten Letzte Antwort
                                • F firefighter166
                                  @marc-berg
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  @firefighter166
                                  In Zukunft bitte mit allen relevanten Infos gleich rausrücken. Dass du eine Multihost-Umgebung hast, wäre wichtig gewesen zu wissen.
                                  @homoran sagte in Backup aus älterer Version einspielen:
                                  @firefighter166
                                  jetzt bring mal alle notwendigen Informationen strukturiert bei.
                                  • F Offline
                                    firefighter166
                                    @marc-berg
                                    Also ich habe im Keller einen Raspberry der in der Unterverteilung sitzt und mittels Node Red meine Zählerstände abliest. Diese wurde dann in einer Influx DB gespeichert.
                                    • F firefighter166
                                      @marc-berg
                                      Dann bring den auch auf Stand.
                                        firefighter166
                                        Habe ich über zwei Wege versucht, er lässt sich nicht Updaten. Egal ob über dem Update Button in der Oberfläche oder über die Konsole
                                        • F firefighter166
                                          Marc BergM Offline
                                          Marc BergM Offline
                                          Marc Berg
                                          Und der Raspi sagt dann "ich hab' kein Bock auf 'n Upgrade", oder gibt's auch eine Fehlermeldung? :-)
