  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • arteckA arteck
    @skb ich hab da einen
    host.iobroker
    2023-11-30 01:23:59.585	warn	instance system.adapter.energiefluss-erweitert.0 terminated due to SIGABRT
    host.iobroker
    2023-11-30 01:23:59.585	error	Caught by controller[16]: 16: 0x17036b9 [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.584	error	Caught by controller[15]: 15: 0xdc3def v8::internal::Builtin_HandleApiCall(int, unsigned long*, v8::internal::Isolate*) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.584	error	Caught by controller[14]: 14: 0xdc28b0 [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.583	error	Caught by controller[13]: 13: 0xc68795 void node::StreamBase::JSMethod<&node::StreamBase::Writev>(v8::FunctionCallbackInfo<v8::Value> const&) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.582	error	Caught by controller[12]: 12: 0xc64ccf node::StreamBase::Writev(v8::FunctionCallbackInfo<v8::Value> const&) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.582	error	Caught by controller[11]: 11: 0xc6ca31 node::StringBytes::Size(v8::Isolate*, v8::Local<v8::Value>, node::encoding) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.573	error	Caught by controller[10]: 10: 0xd705cc v8::String::Utf8Length(v8::Isolate*) const [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.572	error	Caught by controller[9]: 9: 0x11e7bb5 v8::internal::String::SlowFlatten(v8::internal::Isolate*, v8::internal::Handle<v8::internal::ConsString>, v8::internal::AllocationType) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.572	error	Caught by controller[8]: 8: 0xf0a568 v8::internal::FactoryBase<v8::internal::Factory>::NewRawTwoByteString(int, v8::internal::AllocationType) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.571	error	Caught by controller[7]: 7: 0xf081d4 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.570	error	Caught by controller[6]: 6: 0xf10760 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.570	error	Caught by controller[5]: 5: 0xf3039f v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.569	error	Caught by controller[4]: 4: 0xd64b67 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.558	error	Caught by controller[3]: 3: 0xd647c0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.558	error	Caught by controller[2]: 2: 0xa94834 [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.557	error	Caught by controller[1]: 1: 0xb83f50 node::Abort() [io.energiefluss-erweitert.0]
    host.iobroker
    2023-11-30 01:23:59.557	error	Caught by controller[0]: FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
    host.iobroker
    2023-11-30 01:23:59.556	error	Caught by controller[0]: <--- JS stacktrace --->
    host.iobroker
    2023-11-30 01:23:59.556	error	Caught by controller[0]: [1347552:0x5cab1c0] 46124513 ms: Mark-sweep (reduce) 2041.2 (2049.9) -> 2041.2 (2049.9) MB, 14.8 / 0.0 ms (average mu = 0.775, current mu = 0.003) last resort; GC in old space requested
    host.iobroker
    2023-11-30 01:23:59.555	error	Caught by controller[0]: [1347552:0x5cab1c0] 46124499 ms: Mark-sweep (reduce) 2041.4 (2050.0) -> 2041.2 (2049.9) MB, 15.9 / 0.0 ms (average mu = 0.868, current mu = 0.007) last resort; GC in old space requested
    host.iobroker
    2023-11-30 01:23:59.554	error	Caught by controller[0]: <--- Last few GCs --->
    hierdrauf läuft der Adapter
    SKBS Offline
    SKBS Offline
    SKB
    #1944
    @arteck Anscheinend wegen zu wenig RAM beendet worden.
    Wieviel RAM hat der Adapter denn verbraucht?
    • SKBS SKB
      arteckA Offline
      arteckA Offline
      arteck
      #1945
      @skb muss ich mal memRss beobachten.. kein Plan was der zu dem Zeitpunkt verballert hat
      U66U 1 Antwort Letzte Antwort
      • arteckA arteck
        U66U Offline
        U66U Offline
        U66
        #1946
        @SBK
        Hallo
        hattest Du mal geschaut wegen der iframe Geschichte ?
        SKBS 1 Antwort Letzte Antwort
        • U66U U66
          @SBK
          Hallo
          SKBS Offline
          SKBS Offline
          SKB
          #1947
          @u66 Bin ich aktuell noch nicht zu gekommen.
          U66U 2 Antworten Letzte Antwort
          • SKBS SKB
            U66U Offline
            U66U Offline
            U66
            #1948
            @skb
            jo kein Problem
            • SKBS SKB
              U66U Offline
              U66U Offline
              U66
              schrieb am zuletzt editiert von U66
              #1949
              @skb
              Habe es jetzt geschafft einen Schalter im Objekt einzubauen wo eine einfache fritzdect Steckdose geschaltet wird.
              habe dazu ein Symbol genommen was auch die Farbe beim schalten wechselt.Soweit so gut.Wie funktioniert das mit Schriften wenn ich zB. ON / OFF anzeigen lassen will ? da komme ich noch nicht dahinter.
              EDIT : lässt sich den auch die Füllfarbe des Objekts beim schalten ändern........
              SKBS H 2 Antworten Letzte Antwort
              • U66U U66
                @skb
                SKBS Offline
                SKBS Offline
                SKB
                #1950
                @u66 welches Symbol, welcher Text?
                Farben der Füllungen habe ich schonmal erklärt.
                • SKBS SKB
                  U66U Offline
                  U66U Offline
                  U66
                  #1951
                  @skb
                  Ja da hab ich mich wieder schlecht ausgedrückt
                  Das Auto Icon sollte beim laden grün sein oder blinken
                  SKBS HomoranH 2 Antworten Letzte Antwort
                  • U66U U66
                    @skb
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #1952
                    @u66 blinkende Icons stehen weiter oben auch.
                    • U66U U66
                      @skb
                      #1953
                      @u66 sagte in Test Adapter Energiefluss-erweitert v0.1.x GitHub/Latest:
                        U66U Offline
                        U66U Offline
                        U66
                        #1954
                        Vielen Dank
                          duk64
                          #1955
                          ich würde gerne auch etwas mit der Erweiterung probieren. Habe sie installiert, kann aber keine Instance sehen. Ich habe versucht das manuell im Browser eingegeben:
                          http://192.168.1.230:8082/energiefluss-erweitert/
                          geht leider auch nicht.
                          Im Web-Adapter habe ich folgende Einstellungen, siehe Bild:
                          Was mache ich falsch? kann jemand helfen?
                          LG
                          Hans-Werner
                          • D duk64
                            LG
                            Hans-Werner
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #1956
                            @duk64 Bei manuell installierten Adaptern musst Du die Instanz selbst hinzufügen.
                            • SKBS SKB
                              duk64
                              #1957
                              @skb Ahh gesehen, Danke das wußte ich nicht. Mal sehen wie weit ich komme.👍
                                duk64
                                #1958
                                @SKB : Wie geil ist das denn?!? Ich habe den Adapter einfach ausprobieren wollen.
                                Jetzt hat es mich gepackt. Ich bin (fast) reiner Anwender und habe von CSS und so weiter keine Ahnung. Meine Visu ist in VIS gemacht und ich teste gerade Lovelance als Visu zu nehmen. Bei deinem Adapter ist das föllig egal, wenn das animierte Bild mit deinem Editor fertig ist. Es gab einige Hürden, die mir für eine Erstellung nicht ganz klar waren, aber wenn man weiß, wie ich was einstellen kann, geht das prima.
                                Ich werde noch weiter testen und sicherlich noch einige Fragen haben aber:
                                Das ist eine tolle Arbeit, vielen vielen Dank dafür!!!
                                Eine kleine Spende ist dir gewiss!
                                • D duk64
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  #1959
                                  @duk64 freut mich.
                                  Vielen Dank!
                                  Kannst du die Hürden aufzeigen? Dann könnte ich dies erläutern.
                                    duk64
                                    #1960
                                    @skb Ich werde es versuchen, aber nicht böse sein, wenn es sich auch um missverständliche Doku handelt oder Vorgänge die für einen Profi selbstverstänlich sind.
                                    Ich melde mich zum Thema später.
                                    • D duk64
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #1961
                                      @duk64 mir würde es helfen, wenn du deine anfänglichen Probleme formulieren könntest - dann kann man daraus sicher einen Hinweis schreiben.
                                        duk64
                                        schrieb am zuletzt editiert von duk64
                                        #1962
                                        Manchmal lassen sich die kleinen Symbole nicht ändern. Im Beispiel mdi:house-city angezeigt aber mdi:fridge-industrial gewünscht. Oben hat es funktioniert!
                                        Die Auswahl im Symbolfeld kommt manchmal nicht. Ein hinein kopieren geht auch nicht.
                                          duk64
                                          #1963
                                          Wenn ich Elemente einfügen möchte, stehen die immer oben links. Das ist manchmal schwierig diese anzuwählen und einzustellen.
                                          in diesem Beispiel habe ich ein SVG-Element eingefügt.
                                          Vielleicht könnte man das Element an den Pfeil hängen und nach einem klick absetzen.
                                          Ich habe allerdings keine Ahnung wir man sowas programmieren könnte.
