  4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
zigbee-adapter
61 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
  • W wolkenloser
    Mehr als 1000 Zeilen, muss ich splitten
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: microsoft
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.0-166-generic
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : microsoft
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:00:09 up 25 min,  1 user,  load average: 0.44, 0.64, 1.09
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2023-11-20 12:00:10 CET
               Universal time: Mon 2023-11-20 11:00:10 UTC
                     RTC time: Mon 2023-11-20 11:00:11
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.9G        2.7G        119M        1.0M        1.1G        1.1G
    Swap:          2.0G        3.0M        2.0G
    Total:         5.9G        2.7G        2.1G
             3919 M total memory
             2689 M used memory
             2743 M active memory
              726 M inactive memory
              119 M free memory
              145 M buffer memory
              965 M swap cache
             1969 M total swap
                3 M used swap
             1966 M free swap
    *** FAILED SERVICES ***
      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
    * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     392M  1.1M  391M   1% /run
    /dev/sda2      ext4       50G   34G   13G  73% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
    /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16091
    /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16202
    /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2796
    /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2790
    /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2015
    /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
    /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
    /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
    /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
    /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
    /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
    tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
    [sudo] password for iobroker:
    [Mon Nov 20 11:34:45 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Nov 20 11:35:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET                SOURCE      FSTYPE   OPTIONS
    /                     /dev/sda2   ext4     rw,relatime
    |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
    |-/snap/core/16091    /dev/loop0  squashfs ro,nodev,relatime
    |-/snap/core/16202    /dev/loop1  squashfs ro,nodev,relatime
    |-/snap/core18/2796   /dev/loop3  squashfs ro,nodev,relatime
    |-/snap/core18/2790   /dev/loop2  squashfs ro,nodev,relatime
    |-/snap/core20/2015   /dev/loop5  squashfs ro,nodev,relatime
    |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
    |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
    |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
    |-/snap/core20/1974   /dev/loop4  squashfs ro,nodev,relatime
    |-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
    `-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
    /var:
    5.6G    /var/
    4.1G    /var/log
    4.0G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
    1.5G    /var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    12M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    17G     /opt/iobroker/iobroker-data/
    16G     /opt/iobroker/iobroker-data/history
    650M    /opt/iobroker/iobroker-data/files
    170M    /opt/iobroker/iobroker-data/files/javascript.admin
    158M    /opt/iobroker/iobroker-data/backup-objects
    39M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/12.1aeaa68b.chunk.js.map
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/node              v18.9.0
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/npm               8.19.1
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/npx               8.19.1
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/corepack  0.14.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1.2 500
            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    W Offline
    W Offline
    wolkenloser
    Dann ganz viele hiervon, und das ist nur die Hälfte
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.energiefluss@3.6.0 /opt/iobroker/node_modules/iobroker.energiefluss
    npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius
    npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom
    npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
    npm ERR! extraneous: @aashutoshrathi/word-wrap@1.2.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
    npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
    npm ERR! extraneous: @alcalzone/release-script-core@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
    npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
    npm ERR! extraneous: @alcalzone/release-script-plugin-exec@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
    npm ERR! extraneous: @alcalzone/release-script-plugin-git@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
    npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
    npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
    npm ERR! extraneous: @alcalzone/release-script-plugin-package@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
    npm ERR! extraneous: @alcalzone/release-script-plugin-version@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
    npm ERR! extraneous: @alcalzone/release-script@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
    npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
    npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
    npm ERR! extraneous: @eslint/eslintrc@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrcnpm ERR! extraneous: @eslint/js@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
    npm ERR! extraneous: @humanwhocodes/config-array@0.11.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
    npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
    npm ERR! extraneous: @humanwhocodes/object-schema@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
    npm ERR! extraneous: @iobroker/dev-server@0.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
    npm ERR! extraneous: @iobroker/testing@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
    npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
    npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.statnpm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walknpm ERR! extraneous: @sinonjs/commons@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commonsnpm ERR! extraneous: @sinonjs/fake-timers@9.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
    npm ERR! extraneous: @sinonjs/samsam@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
    npm ERR! extraneous: @sinonjs/text-encoding@0.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
    npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
    npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
    npm ERR! extraneous: @types/cors@2.8.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
    npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
    npm ERR! extraneous: @types/http-proxy@1.17.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
    npm ERR! extraneous: @types/vinyl@2.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
    npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
    npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
    npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
    npm ERR! extraneous: acorn-globals@1.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
    npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
    npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
    npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-sharednpm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
    npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
    npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
    npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
    npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
    npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
    npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
    npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
    npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
    npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
    npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
    npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
    npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
    npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
    npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
    npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
    npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
    npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
    npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
    npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
    npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
    npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
    npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
    npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
    npm ERR! extraneous: astral-regex@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
    npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
    npm ERR! extraneous: async-each-series@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
    npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
    npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
    npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
    npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
    npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
    npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
    npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
    npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
    npm ERR! extraneous: batch@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
    npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
    npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensionsnpm ERR! extraneous: body-parser@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
    npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
    npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
    npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
    npm ERR! extraneous: browser-request@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
    npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
    npm ERR! extraneous: browser-sync-client@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
    npm ERR! extraneous: browser-sync-ui@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
    npm ERR! extraneous: browser-sync@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
    npm ERR! extraneous: bs-html-injector@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injectornpm ERR! extraneous: bs-recipes@1.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
    npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
    npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
    npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
    npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
    npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
    npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
    npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
    npm ERR! extraneous: chai-as-promised@7.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promisednpm ERR! extraneous: chai@4.3.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
    npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
    npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
    npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
    npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
    npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
    npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
    npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
    npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
    npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
    npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
    npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
    npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
    npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visitnpm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
    npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
    npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
    npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
    npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
    npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
    npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
    npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
    npm ERR! extraneous: connect-history-api-fallback@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
    npm ERR! extraneous: connect@3.6.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
    npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
    npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
    npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
    npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signaturenpm ERR! extraneous: cookie@0.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
    npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
    npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
    npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
    npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
    npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
    npm ERR! extraneous: cssstyle@0.2.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
    npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
    npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
    npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
    npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
    npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
    npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
    npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
    npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
    npm ERR! extraneous: define-properties@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
    npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
    npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
    npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
    npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
    npm ERR! extraneous: dev-ip@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
    npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
    npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
    npm ERR! extraneous: dom-compare-temp@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-tempnpm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
    npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
    npm ERR! extraneous: domhandler@2.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
    npm ERR! extraneous: domutils@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
    npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
    npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
    npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
    npm ERR! extraneous: easy-extender@2.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
    npm ERR! extraneous: eazy-logger@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
    npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
    npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
    npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
    npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
    npm ERR! extraneous: engine.io-client@6.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-clientnpm ERR! extraneous: engine.io-parser@5.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parsernpm ERR! extraneous: engine.io@6.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
    npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
    npm ERR! extraneous: entities@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
    npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
    npm ERR! extraneous: es5-ext@0.10.62 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
    npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
    npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
    npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
    npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
    npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
    npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
    npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
    npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
    npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
    npm ERR! extraneous: eslint@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
    npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
    npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
    npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
    npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
    npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
    npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
    npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
    npm ERR! extraneous: event-stream@3.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
    npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
    npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
    npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
    npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
    npm ERR! extraneous: express@4.18.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
    npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
    npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
    npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
    npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
    npm ERR! extraneous: fast-glob@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
    npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshteinnpm ERR! extraneous: fastq@1.15.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
    npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cachenpm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
    npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
    npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
    W 1 Antwort Letzte Antwort
    • W wolkenloser
      Errors in npm tree:
      W Offline
      W Offline
      wolkenloser
      Hier der Rest...
      npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_09_978Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.2.23
      javascript:     6.2.0
      npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_43_451Z-debug-0.log
      Adapters from github:   3
      Adapter State
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
      + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
        system.adapter.labcom.0                 : labcom                : iobroker                                 - disabled
      + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
      + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
        system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
      + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.2.23 [Updatable]
      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
      Adapter    "backitup"     : 2.8.7    , installed 2.9.1
      Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
      Adapter    "bydhvs"       : 1.4.0    , installed 1.5.0
      Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
      Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
      Adapter    "easee"        : 1.0.10   , installed 1.0.10
      Adapter    "echarts"      : 1.5.4    , installed 1.0.12 [Updatable]
      Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
      Adapter    "fronius"      : 2.0.2    , installed 2.0.2
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.4    , installed 6.2.0  [Updatable]
      Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
      Adapter    "knx"          : 2.0.23   , installed 2.0.13 [Updatable]
      Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
      Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
      Adapter    "midea"        : 0.0.7    , installed 0.0.7
      Adapter    "mihome"       : 1.4.0    , installed 1.4.0
      Adapter    "mihome-vacuum": 4.1.0    , installed 3.8.6  [Updatable]
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "openweathermap": 0.4.5   , installed 0.3.11 [Updatable]
      Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
      Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "pvforecast"   : 2.9.0    , installed 2.7.1  [Updatable]
      Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
      Adapter    "schwoerer-ventcube": 1.4.2, installed 1.4.2
      Adapter    "shelly"       : 6.6.1    , installed 6.0.0  [Updatable]
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.3
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
      Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
      Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
      Adapter    "trashschedule": 2.3.0    , installed 2.0.3  [Updatable]
      Adapter    "tuya"         : 3.14.2   , installed 3.9.4  [Updatable]
      Adapter    "unifi"        : 0.6.6    , installed 0.5.10 [Updatable]
      Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
      Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.90.0 [Updatable]
      Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "wled"         : 0.7.1    , installed 0.6.7  [Updatable]
      Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        11799
      States:         10540
      Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
      Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x focal InRelease
      Reading package lists...
      Pending Updates: 15
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       35070      2326/io.shelly.0
      tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       35419      2573/io.fakeroku.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       32795      1756/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       32532      1756/iobroker.js-co
      tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28197      1027/perl
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21935      641/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25514      811/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        31602      1777/influxd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34927      2333/io.sonoff.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       36326      2653/io.harmony.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34086      2132/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37649      2882/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        32766      1777/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          25516      811/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       37894      3013/io.simple-api.
      tcp6       0      0 :::3000                 :::*                    LISTEN      111        27368      783/grafana-server
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       37506      2935/io.wled.0
      udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28198      1027/perl
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       35420      2573/io.fakeroku.0
      udp        0      0 192.168.8.67:53249      0.0.0.0:*                           1000       35708      2690/io.knx.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21934      641/systemd-resolve
      udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        21920      635/systemd-network
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       35977      2473/io.mihome-vacu
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       36336      2494/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       36337      2494/io.tuya.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       36327      2653/io.harmony.0
      udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        20383      635/systemd-network
      2023-11-20 12:02:11.075  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:11+00:00"}}
      2023-11-20 12:02:40.671  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MinMaxInverterData: {"Body":{"Data":{}},"Head":{"RequestArguments":{"DataCollection":"MinMaxInverterData","Scope":"Device"},"Status":{"Code":11,"Reason":"Parameter 'MinMaxInverterData' for attribute 'DataCollection' not supported. Use one of 'CumulationInverterData', 'CommonInverterData', '3PInverterData'.","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:40.683  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Current_AC_Phase_1":0.732,"Current_AC_Phase_2":-0.69,"Current_AC_Phase_3":1.231,"Current_AC_Sum":1.2730000000000001,"Details":{"Manufacturer":"Fronius","Model":"Smart Meter TS 65A-3","Serial":"1659699688"},"Enable":1,"EnergyReactive_VArAC_Sum_Consumed":787465,"EnergyReactive_VArAC_Sum_Produced":5086507,"EnergyReal_WAC_Minus_Absolute":7490523,"EnergyReal_WAC_Plus_Absolute":4746701,"EnergyReal_WAC_Sum_Consumed":4746701,"EnergyReal_WAC_Sum_Produced":7490523,"Frequency_Phase_Average":50,"Meter_Location_Current":0,"PowerApparent_S_Phase_1":54.5,"PowerApparent_S_Phase_2":151.6,"PowerApparent_S_Phase_3":195.1,"PowerApparent_S_Sum":401.4,"PowerFactor_Phase_1":0.714,"PowerFactor_Phase_2":-0.881,"PowerFactor_Phase_3":0.515,"PowerFactor_Sum":0.019,"PowerReactive_Q_Phase_1":-38.2,"PowerReactive_Q_Phase_2":-71.5,"PowerReactive_Q_Phase_3":-166.6,"PowerReactive_Q_Sum":-276.4,"PowerReal_P_Phase_1":38.9,"PowerReal_P_Phase_2":-133.6,"PowerReal_P_Phase_3":101.6,"PowerReal_P_Sum":6.8,"TimeStamp":1700478159,"Visible":1,"Voltage_AC_PhaseToPhase_12":410.1,"Voltage_AC_PhaseToPhase_23":411,"Voltage_AC_PhaseToPhase_31":406.1,"Voltage_AC_Phase_1":241.2,"Voltage_AC_Phase_2":230,"Voltage_AC_Phase_3":237.7}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:40.726  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetStorageRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Controller":{"Capacity_Maximum":10240,"Current_DC":1.2981114032990677,"DesignedCapacity":10240,"Details":{"Manufacturer":"BYD","Model":"BYD Battery-Box Premium HV","Serial":"P030T020Z2010263183     "},"Enable":1,"StateOfCharge_Relative":17.8,"Status_BatteryCell":3,"Temperature_Cell":12,"TimeStamp":1700478156,"Voltage_DC":418.3},"Modules":[]}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:40.767  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetPowerFlowRealtimeData.fcgi: {"Body":{"Data":{"Inverters":{"1":{"Battery_Mode":"normal","DT":1,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"P":460.24041748046875,"SOC":17.8}},"SecondaryMeters":{},"Site":{"BackupMode":false,"BatteryStandby":true,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"Meter_Location":"grid","Mode":"bidirectional","P_Akku":-666.0352783203125,"P_Grid":6.8,"P_Load":-467.79334716796876,"P_PV":1129.3310546875,"rel_Autonomy":98.54636667212833,"rel_SelfConsumption":100},"Smartloads":{"Ohmpilots":{}},"Version":"12"}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:40.769  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetOhmPilotRealtimeData.cgi?Scope=System: {"Body":{"Data":{}},"Head":{"RequestArguments":{"Scope":"System"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:40.773  - debug: fronius.0 (2593) API Objekt E_Day is null, object inverter.1.E_Day will be set to 0!
      2023-11-20 12:02:40.782  - debug: fronius.0 (2593) API Objekt E_Year is null, object inverter.1.E_Year will be set to 0!2023-11-20 12:02:40.783  - debug: fronius.0 (2593) API Objekt E_Day is null, object site.E_Day will be set to 0!
      2023-11-20 12:02:40.784  - debug: fronius.0 (2593) API Objekt E_Year is null, object site.E_Year will be set to 0!
      2023-11-20 12:02:40.928  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:41.004  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData: {"Body":{"Data":{"DAY_ENERGY":{"Unit":"Wh","Value":null},"DeviceStatus":{"ErrorCode":1130,"InverterState":"Running","StatusCode":7},"FAC":{"Unit":"Hz","Value":50.00504684448242},"IAC":{"Unit":"A","Value":1.970382273197174},"IDC":{"Unit":"A","Value":1.233007550239563},"IDC_2":{"Unit":"A","Value":1.0074610710144043},"IDC_3":{"Unit":"A","Value":null},"IDC_4":{"Unit":"A","Value":null},"PAC":{"Unit":"W","Value":463.17767333984375},"SAC":{"Unit":"VA","Value":463.22857666015625},"TOTAL_ENERGY":{"Unit":"Wh","Value":23263193.850555554},"UAC":{"Unit":"V","Value":234.6595916748047},"UDC":{"Unit":"V","Value":528.879150390625},"UDC_2":{"Unit":"V","Value":555.4661254882812},"UDC_3":{"Unit":"V","Value":null},"UDC_4":{"Unit":"V","Value":null},"YEAR_ENERGY":{"Unit":"Wh","Value":null}}},"Head":{"RequestArguments":{"DataCollection":"CommonInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
      2023-11-20 12:02:41.041  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=3PInverterData: {"Body":{"Data":{"IAC_L1":{"Unit":"A","Value":0.6535905599594116},"IAC_L2":{"Unit":"A","Value":0.6578454971313477},"IAC_L3":{"Unit":"A","Value":0.6589462161064148},"UAC_L1":{"Unit":"V","Value":234.55113220214844},"UAC_L2":{"Unit":"V","Value":236.23095703125},"UAC_L3":{"Unit":"V","Value":234.4892120361328}}},"Head":{"RequestArguments":{"DataCollection":"3PInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:41+00:00"}}
      2023-11-20 12:03:00.036  - warn: javascript.0 (2207) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
      2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1729:20)
      2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
      2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1605:34)
      2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
      2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
      2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
      2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at listOnTimeout (node:internal/timers:564:17)
      2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at processTimers (node:internal/timers:507:7)
      2023-11-20 12:03:00.040  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: 25.2
      2023-11-20 12:03:00.041  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
      2023-11-20 12:03:02.105  - warn: sonoff.0 (2333) Client [] has invalid password or username
      iob diag has finished.
      Press any key for a summary
      Thomas BraunT W 2 Antworten Letzte Antwort
      • W wolkenloser
        Hier der Rest...
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.2.23
        javascript:     6.2.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        11799
        States:         10540
        Pending Updates: 15
        @wolkenloser
        Dein nodejs ist noch schief.
        Kratz das alles raus.
        rm -rf /home/iobroker/.nvm
        Danach
        iob fix
        iob nodejs-update
        • W wolkenloser
          Hier der Rest...
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.2.23
          javascript:     6.2.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11799
          States:         10540
          Pending Updates: 15
          W Offline
          W Offline
          wolkenloser
          Wie gesagt, die ganzen Updateable Adapters lassen sich nicht updaten.
          Das Problem fing vor 2 Monaten an, als ich den Energiefluss Adapter installiert hatte....
          • W wolkenloser
            @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
            Nein, das fing damit an, dass du da per nvm ein nodejs 18.9.0 reingeklatscht hast...
              W Offline
              W Offline
              wolkenloser
              schrieb am zuletzt editiert von wolkenloser
              wie gesagt, ich bin auch nur Benutzer.
              Aber ich lerne gerne dazu, weil interessieren tut es mich ja.
              Man nennt das wohl auchg auch "gefährliches Halbwissen"
              Wenn das so ist wie Du es sagst habe ich das wohl aus irgendeiner Intention, oder wegen einer Anleitung im Internet gemacht.
              Der Energiefluss Adapter lies sich damals nicht über die Oberfläche installieren, dann hab ich gesucht wie es noch geht. Irgendwann war er drin.
              Ich versuch jetzzt das was Du oben geschrieben hast...
              Thomas BraunT 3 Antworten Letzte Antwort
              • W wolkenloser
                Was kann ich denn jetzt am besten machen ohne bei Null anzufangen ?
                Hab ich doch vor 15 Minuten oben geschrieben...
                Den Kram löschen und nodejs ordentlich installieren wäre schon mal ein erster Schritt.
                • W wolkenloser
                  @wolkenloser
                  Und schalt den
                  debug: fronius.0
                  aus. Der kübelt dir sonst zu viel in das Log rein.
                  • W wolkenloser
                    @wolkenloser
                    Wenn nodejs sauber installiert ist und die ganzen npm-Fehler dann immer noch aufkreuzen:
                    Installier mindestens diese drei Adapter nochmal:
                    Sind alle über github und nicht 'ordentlich' installiert, oder?
                      @wolkenloser
                      W Offline
                      W Offline
                      wolkenloser
                      Energiefluss auf jeden Fall
                      den Labcom brauch ich nicht mehr den deinstalliere ich.
                      Fronius ist mit am wichtigsten wegen diverser Scripte.... ich schau mal.
                      Wenn ich den neu installiere sollten die Datenpunkte ja wieder so wie bisher aktualisiert werden.....
                      • W wolkenloser
                        W Offline
                        W Offline
                        wolkenloser
                        Labcom ist weg....
                        Hast Du dafür auch eine Lösung ?
                        • W wolkenloser
                          Labcom ist weg....
                          @wolkenloser
                          Ich seh nix. Text auch als Text in CodeTags eingebettet hier rein.
                            @wolkenloser
                            W Offline
                            W Offline
                            wolkenloser
                            Kommt gleich..
                            Zwischenstand:
                                                    v.2023-10-10
                                       Chassis: vm
                            Installation:           microsoft
                            Kernel:                 x86_64
                            Userland:               amd64
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     0
                            node:internal/modules/cjs/loader:1080
                              throw err;
                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                at Module._load (node:internal/modules/cjs/loader:922:27)
                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
                                at node:internal/main/run_main_module:23:47 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                            Node.js v18.18.2
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                    /usr/bin/node           v18.18.2
                                                    /usr/bin/npm            9.8.1
                                                    /usr/bin/npx            9.8.1
                                                    /usr/bin/corepack       0.19.0
                            Recommended versions are nodejs  and npm
                            MEMORY:
                            Mem:           3.9G        423M        2.3G        0.0K        1.2G        3.2G
                            Swap:          2.0G         43M        1.9G
                            Total:         5.9G        467M        4.2G
                              throw err;
                              requireStack: []
                            Node.js v18.18.2
                            Active iob-Instances:   0
                              throw err;
                              requireStack: []
                            Node.js v18.18.2
                              throw err;
                              requireStack: []
                            Node.js v18.18.2
                            ioBroker Core:          js-controller
                              throw err;
                              requireStack: []
                            Node.js v18.18.2
                                                    admin
                              throw err;
                              requireStack: []
                            Node.js v18.18.2
                            ioBroker Status:
                              throw err;
                              requireStack: []
                            Node.js v18.18.2
                            Objects:                0
                            States:                 0
                            Size of iob-Database:
                            16M     /opt/iobroker/iobroker-data/objects.jsonl
                            9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            0       /opt/iobroker/iobroker-data/objects.json.broken
                            2.6M    /opt/iobroker/iobroker-data/states.jsonl
                            1.3M    /opt/iobroker/iobroker-data/states.json.migrated
                            1.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                            0       /opt/iobroker/iobroker-data/states.json.broken
                            • W wolkenloser
                              Kommt gleich..
                              Zwischenstand:
                                                      v.2023-10-10
                                         Chassis: vm
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1000
                              X-Server:               false
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                                      /usr/bin/npm            9.8.1
                                                      /usr/bin/npx            9.8.1
                              MEMORY:
                              Swap:          2.0G         43M        1.9G
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                                      admin
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              ioBroker Status:
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              Objects:                0
                              States:                 0
                              W Offline
                              W Offline
                              wolkenloser
                              ich kann Dir den Text vom Energieflussadapter nicht reinkopieren, im moment kann ich nichtmal den Admin Adapter aufrufen. Hab versucht den manuell zu starten, Dann kommt das
                              iob start admin
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              • W wolkenloser
                                iob start admin
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                @wolkenloser
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller
                                  @wolkenloser
                                  W Offline
                                  W Offline
                                  wolkenloser
                                  /opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                  (#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.(#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.npm WARN skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                  npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                  npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                  npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                                  npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                  npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                  npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                  npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                                  npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                                  npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                  npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                  npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
                                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                  npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
                                  npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                  added 6 packages, and changed 1963 packages in 15m
                                  176 packages are looking for funding
                                    run `npm fund` for details
                                  iobroker@iobroker:/opt/iobroker$ npm fund
                                  iobroker.inst@2.0.3
                                  ├── https://github.com/sponsors/jaredhanson
                                  │   └── passport@0.5.3
                                  ├── https://github.com/sponsors/RubenVerborgh
                                  │   └── follow-redirects@1.15.3
                                  ├── https://github.com/sponsors/ljharb
                                  │   └── qs@6.11.0, side-channel@1.0.4, call-bind@1.0.5, function-bind@1.1.2, gopd@1.0.1, has-property-descriptors@1.0.1, get-intrinsic@1.2.2, has-proto@1.0.1, has-symbols@1.0.3, object-inspect@1.13.1, is-arguments@1.1.1, has-tostringtag@1.0.0, is-generator-function@1.0.10, is-typed-array@1.1.12, which-typed-array@1.1.13, available-typed-arrays@1.0.5, is-callable@1.2.7, resolve@1.22.8, is-core-module@2.13.1, supports-preserve-symlinks-flag@1.0.0, minimist@1.2.8, is-nan@1.3.2, define-properties@1.2.1, object-is@1.1.5, traverse@0.6.7, is-object@1.0.2, deep-equal@1.1.2, is-date-object@1.0.5, is-regex@1.1.4, regexp.prototype.flags@1.5.1, functions-have-names@1.2.3, object.assign@4.1.4
                                  ├── https://github.com/sponsors/feross
                                  │   └── safe-buffer@5.2.1, base64-js@1.5.1, ieee754@1.2.1, simple-concat@1.0.1, buffer@6.0.3, run-parallel@1.2.0, queue-microtask@1.2.3
                                  ├── https://github.com/sponsors/broofa
                                  │   └── uuid@9.0.1
                                  ├── https://github.com/sponsors/sindresorhus
                                  │   └── is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, component-emitter@1.3.1, make-dir@3.1.0, mimic-response@2.1.0, onetime@5.1.2, multimatch@5.0.0, throttleit@1.0.1, sort-keys@4.2.0, p-limit@2.3.0, p-queue@6.6.2, any-observable@0.5.1, del@6.1.1, globby@11.1.0, p-map@4.0.0, escape-goat@3.0.0, escape-string-regexp@4.0.0, import-local@3.1.0, is-installed-globally@0.3.2, global-dirs@2.1.0, log-symbols@4.1.0, is-unicode-supported@0.1.0, meow@8.1.2, camelcase-keys@6.2.2, map-obj@4.3.0, decamelize-keys@1.1.1, type-fest@0.18.1, npm-name@6.0.1, p-event@4.2.0, type-fest@0.10.0, is-url-superb@4.0.0, open@7.4.2, is-docker@2.2.1, ow@0.21.0, dot-prop@6.0.1, type-fest@0.20.2, p-settle@4.1.1, read-pkg-up@7.0.1, terminal-link@2.1.1, boxen@5.1.2, camelcase@6.3.0, cli-boxes@2.2.1, is-installed-globally@0.4.0, global-dirs@3.0.1, is-npm@5.0.0, import-fresh@3.3.0, parse-json@5.2.0, ansi-escapes@4.3.2, type-fest@0.21.3, figures@3.2.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0, hex-rgb@4.3.0
                                  ├─┬ https://github.com/sindresorhus/got?sponsor=1
                                  │ │ └── got@11.8.6, got@10.7.0
                                  │ └── https://github.com/sindresorhus/is?sponsor=1
                                  │     └── @sindresorhus/is@4.6.0, @sindresorhus/is@2.1.1
                                  ├── https://github.com/sponsors/epoberezkin
                                  │   └── ajv@6.12.6
                                  ├── https://github.com/sponsors/NaturalIntelligence
                                  │   └── fast-xml-parser@4.3.2
                                  ├── https://github.com/sponsors/isaacs
                                  │   └── minimatch@9.0.3, rimraf@3.0.2, glob@7.2.3
                                  ├─┬ https://opencollective.com/node-fetch
                                  │ │ └── node-fetch@3.3.2
                                  │ └── https://github.com/sponsors/jimmywarting
                                  │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                                  ├── https://opencollective.com/serialport/donate
                                  │   └── serialport@10.5.0, @serialport/bindings-cpp@10.8.0, @serialport/parser-byte-length@10.5.0, @serialport/parser-cctalk@10.5.0, @serialport/parser-delimiter@10.5.0, @serialport/parser-inter-byte-timeout@10.5.0, @serialport/parser-readline@10.5.0, @serialport/parser-ready@10.5.0, @serialport/parser-regex@10.5.0, @serialport/parser-slip-encoder@10.5.0, @serialport/parser-spacepacket@10.5.0, @serialport/stream@10.5.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-delimiter@12.0.0, @serialport/stream@12.0.0
                                  ├── https://www.buymeacoffee.com/systeminfo
                                  │   └── systeminformation@5.21.17
                                  ├── https://opencollective.com/date-fns
                                  │   └── date-fns@2.30.0
                                  ├── https://opencollective.com/ioredis
                                  │   └── ioredis@4.28.5
                                  ├── https://github.com/sindresorhus/execa?sponsor=1
                                  │   └── execa@5.1.1
                                  ├─┬ https://paulmillr.com/funding/
                                  │ │ └── chokidar@3.5.3
                                  │ └── https://github.com/sponsors/jonschlinkert
                                  │     └── picomatch@2.3.1, set-value@4.1.0
                                  ├── https://github.com/sponsors/sibiraj-s
                                  │   └── ci-info@3.9.0
                                  ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                  │ │ └── wrap-ansi@7.0.0
                                  │ └── https://github.com/chalk/ansi-styles?sponsor=1
                                  │     └── ansi-styles@4.3.0
                                  ├── https://opencollective.com/browserslist
                                  │   └── browserslist@4.22.1, caniuse-lite@1.0.30001563, update-browserslist-db@1.0.13
                                  ├── https://opencollective.com/core-js
                                  │   └── core-js@3.33.3, core-js-compat@3.33.3
                                  ├─┬ https://opencollective.com/javascript-obfuscator
                                  │ │ └── javascript-obfuscator@3.2.7
                                  │ └── https://github.com/chalk/chalk?sponsor=1
                                  │     └── chalk@4.1.2
                                  ├── https://github.com/sponsors/wooorm
                                  │   └── levenshtein-edit-distance@2.0.5
                                  ├── https://opencollective.com/js-sdsl
                                  │   └── js-sdsl@4.3.0
                                  └─┬ https://github.com/sindresorhus/np?sponsor=1
                                    │ └── np@7.7.0
                                    ├── https://github.com/sindresorhus/p-memoize?sponsor=1
                                    │   └── p-memoize@4.0.4
                                    └── https://github.com/yeoman/update-notifier?sponsor=1
                                        └── update-notifier@5.1.0
                                  • W wolkenloser
                                    iobroker.inst@2.0.3
                                    │   └── uuid@9.0.1
                                    │   └── ajv@6.12.6
                                    │   └── execa@5.1.1
                                    │   └── ci-info@3.9.0
                                    │     └── chalk@4.1.2
                                    │   └── js-sdsl@4.3.0
                                      │ └── np@7.7.0
                                    W Offline
                                    W Offline
                                    wolkenloser
                                    Die Web Oberfläche klappt wieder , ENERGIEFLUSS läßt sich deinstallieren.
                                    Dann bleibt noch der fronius
                                    • W wolkenloser
                                      W Offline
                                      W Offline
                                      wolkenloser
                                      Kurzes Status Update.
                                      Ich update gerade 30 Adapter, pro Adapter dauert es anscheinend mehr als 5 Minuten.
                                      • W wolkenloser
                                        @wolkenloser
                                        Ja, das ist möglich.
                                          @wolkenloser
                                          W Offline
                                          W Offline
                                          wolkenloser
                                          das Updaten der Adapter dauert leider sehr lange.
                                          Es gibt bei einigen Adaptern Fehlermeldungen sowohl beim Updaten, als auch beim löschen wie z.B. hier bei Openweather Map.
                                          Da steht man soll den Adapter von Hand löschen, aber trotz intensiver suche weiss ich nicht wo die Dateien liegen. Da brauch ich noch einmal Hilfe:
                                          ERROR: Process exited with code 25
                                          weniger
                                          mehr
                                          $ iobroker upgrade openweathermap@0.4.5
                                          Update openweathermap from @0.3.11 to @0.4.5
                                          NPM version: 9.8.1
                                          Installing iobroker.openweathermap@0.4.5... (System call)
                                          host.iobroker Cannot install iobroker.openweathermap@0.4.5: 217
                                          Ich hab die meisten Module hier gefunden, aber nicht openweathermap
                                          /opt/iobroker/iobroker-data/files$ ls
                                          admin.admin                        javascript.admin          vis-2-beta
                                          alias-manager.admin                knx.admin                 vis-2-beta.0
                                          backitup.admin                     lg-thinq.admin            vis-2-beta.admin
                                          bydbatt.admin                      lgtv.admin                vis.admin
                                          bydhvs.admin                       midea.admin               vis-bars.admin
                                          cloud.admin                        mihome.admin              vis-canvas-gauges.admin
                                          daswetter.admin                    mihome-vacuum.admin       vis-colorpicker.admin
                                          device-reminder.admin              mobile                    vis-fancyswitch.admin
                                          discovery.admin                    mobile.admin              vis-google-fonts.admin
                                          dwd.admin                          moma.admin                vis-history.admin
                                          easee.admin                        onkyo.admin               vis-hqwidgets.admin
                                          echarts                            parser.admin              vis-icontwo
                                          echarts.admin                      phantomjs.admin           vis-icontwo.admin
                                          fakeroku.admin                     pi-hole.admin             vis-inventwo.admin
                                          feiertage.admin                    ping.admin                vis-jqui-mfd.admin
                                          flot                               pvforecast.admin          vis-justgage.admin
                                          flot.admin                         sayit.0                   vis-keyboard.admin
                                          fronius.admin                      sayit.admin               vis-lcars.admin
                                          fronius-solarweb.admin             scenes.admin              vis-map.admin
                                          habpanel                           schwoerer-ventcube.admin  vis-material.admin
                                          habpanel.admin                     shelly.0                  vis-material-advanced.admin
                                          harmony.admin                      shelly.admin              vis-metro.admin
                                          history.admin                      shuttercontrol.admin      vis-players.admin
                                          ical.admin                         simple-api.admin          vis-plumb.admin
                                          icons-addictive-flavour-png        socketio.admin            vis-rgraph.admin
                                          icons-addictive-flavour-png.admin  sonoff.admin              vis-timeandweather.admin
                                          icons-mfd-svg                      sourceanalytix.admin      vis-weather.admin
                                          icons-mfd-svg.admin                tado.admin                web
                                          icons-open-icon-library-png        tankerkoenig.admin        web.admin
                                          icons-open-icon-library-png.admin  tr-064.admin              web-speedy.admin
                                          influxdb.admin                     trashschedule.admin       wifilight.admin
                                          info.admin                         tuya.admin                wled.admin
                                          iqontrol.meta                      unifi.admin               zigbee.admin
                                          jarvis                             vis
                                          jarvis.admin                       vis.0
