  4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
zigbee-adapter
61 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
  • W wolkenloser
    @thomas-braun sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
    iob update
    Mein System hab ich 2019 aufgesetzt.
    ICh wäre froh wenn das mal "bereinigt ist.
    Aber mein Linux Wissen ist leider begrenzt....
    iob update
    Used repository: stable
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.7    , installed 2.9.3
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "bydhvs"       : 1.4.0    , installed 1.5.0
    Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.11
    Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "echarts"      : 1.5.4    , installed 1.0.12 [Updatable]
    Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "harmony"      : 1.2.2    , installed 1.3.0
    Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
    Adapter    "knx"          : 2.0.23   , installed 2.0.13 [Updatable]
    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
    Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.1.0    , installed 3.8.6  [Updatable]
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openweathermap": 0.4.5   , installed 0.3.11 [Updatable]
    Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pvforecast"   : 2.9.0    , installed 2.7.1  [Updatable]
    Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
    Adapter    "schwoerer-ventcube": 1.4.2, installed 1.4.2
    Adapter    "shelly"       : 6.6.1    , installed 6.0.0  [Updatable]
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.3
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
    Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
    Adapter    "trashschedule": 2.3.0    , installed 2.0.3  [Updatable]
    Adapter    "tuya"         : 3.14.2   , installed 3.9.4  [Updatable]
    Adapter    "unifi"        : 0.6.6    , installed 0.5.10 [Updatable]
    Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
    Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
    Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wled"         : 0.7.1    , installed 0.6.7  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    iob upgrade all
    This upgrade of "ws" will at least introduce the following changes:
    -> 2.5.8:
    Corrected adapter termination if the alias has no target
    -> 2.5.7:
    upgraded socket-classes to fix vis problems
    -> 2.5.6:
    upgraded socket-classes to correct the error by unsubscribing on client disconnect
    -> 2.5.5:
    upgraded socket-classes to fix crash cases
    -> 2.5.4:
    added missing node16 requirement
    -> 2.5.3:
    Added the subscribing on the specific instance messages
    -> 2.4.0:
    (bluefox) extended the getObjects function with the possibility to read the list of IDs
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade ws from @1.3.0 to @2.5.8 now? [(y)es, (n)o]:
    W Offline
    W Offline
    wolkenloser
    Ich hab mal y gewählt.... jetzt Installiert er....
    W 1 Antwort Letzte Antwort
    • W wolkenloser
      W Offline
      W Offline
      wolkenloser
      schrieb am zuletzt editiert von wolkenloser
      Anscheinden dauert das ein Weilchen:
        @wolkenloser
        Dann hau die Updates rein.
        Und warum ist da kein admin installiert?
        W Offline
        W Offline
        wolkenloser
        @wolkenloser
        Kann ich nicht sagen....
        Hat aber heute Nachmittag noch funktioniert..
        Er hat jetzt erst drei Updates installier.....
        • W wolkenloser
          @wolkenloser
          W Offline
          W Offline
          wolkenloser
          was kann ich denn jetzt machen um den Admin wieder hinzuzufügen......?
          • W wolkenloser
            @wolkenloser
            iob add admin
              @wolkenloser
              iob add admin
              W Offline
              W Offline
              wolkenloser
              iob add admin
              bis hier schon mal ein großes Dankeschönfür den Support.
              Ich kann erst morgen weitermachen.
              • W Offline
                W Offline
                wolkenloser
                ich aber Ich habe die Updates gemacht, bei den Adaptern habe kein Chance, schon beim ersten schlägt das Fehl, sowohl über die Konsole und auch über die WEB Oberfläche.
                Dann habe ich noch gesehen das es ein Host Update gibt, das habe ich auch gemacht.
                Damnach war dann alles auf aktuellstem Stand bis auf die 23 Adapter.
                Im Endergebnis läuft der IOBROKER gar nicht mehr.
                Wennn ich nach dem reboot nach 5 Minuten iob start all eingebe kommt eine Meldung
                iob start all
                iob status
                iobroker is not running on this host.
                Ich habe jetzt den Snapshot von gesten abend wieder eingespielt.
                Das letzte was ich danach versucht habe war das Update vom Host gemäß Anleitung
                Danach hab ich keinen IOBROKER mehr :-(
                • W wolkenloser
                  iob start all
                  iob status
                  @wolkenloser
                  Meldungen im Logfile?
                  iob diag
                  in der Langfassung sagt?
                    @wolkenloser
                    iob diag
                    W Offline
                    W Offline
                    wolkenloser
                    Mehr als 1000 Zeilen, muss ich splitten
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: iobroker
                             Icon name: computer-vm
                               Chassis: vm
                        Virtualization: microsoft
                      Operating System: Ubuntu 20.04.6 LTS
                                Kernel: Linux 5.4.0-166-generic
                          Architecture: x86-64
                    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                    Docker          : false
                    Virtualization  : microsoft
                    Kernel          : x86_64
                    Userland        : amd64
                    Systemuptime and Load:
                     12:00:09 up 25 min,  1 user,  load average: 0.44, 0.64, 1.09
                    CPU threads: 2
                    *** Time and Time Zones ***
                                   Local time: Mon 2023-11-20 12:00:10 CET
                               Universal time: Mon 2023-11-20 11:00:10 UTC
                                     RTC time: Mon 2023-11-20 11:00:11
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    iobroker
                    /home/iobroker
                    iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           3.9G        2.7G        119M        1.0M        1.1G        1.1G
                    Swap:          2.0G        3.0M        2.0G
                    Total:         5.9G        2.7G        2.1G
                             3919 M total memory
                             2689 M used memory
                             2743 M active memory
                              726 M inactive memory
                              119 M free memory
                              145 M buffer memory
                              965 M swap cache
                             1969 M total swap
                                3 M used swap
                             1966 M free swap
                    *** FAILED SERVICES ***
                      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
                    * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
                    1 loaded units listed.
                    *** FILESYSTEM ***
                    udev           devtmpfs  1.9G     0  1.9G   0% /dev
                    tmpfs          tmpfs     392M  1.1M  391M   1% /run
                    /dev/sda2      ext4       50G   34G   13G  73% /
                    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
                    /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16091
                    /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16202
                    /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2796
                    /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2790
                    /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2015
                    /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
                    /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
                    /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
                    /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
                    /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
                    /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
                    tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                    [sudo] password for iobroker:
                    [Mon Nov 20 11:34:45 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                    [Mon Nov 20 11:35:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                    TARGET                SOURCE      FSTYPE   OPTIONS
                    /                     /dev/sda2   ext4     rw,relatime
                    |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
                    |-/snap/core/16091    /dev/loop0  squashfs ro,nodev,relatime
                    |-/snap/core/16202    /dev/loop1  squashfs ro,nodev,relatime
                    |-/snap/core18/2796   /dev/loop3  squashfs ro,nodev,relatime
                    |-/snap/core18/2790   /dev/loop2  squashfs ro,nodev,relatime
                    |-/snap/core20/2015   /dev/loop5  squashfs ro,nodev,relatime
                    |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
                    |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
                    |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
                    |-/snap/core20/1974   /dev/loop4  squashfs ro,nodev,relatime
                    |-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
                    `-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
                    /var:
                    5.6G    /var/
                    4.1G    /var/log
                    4.0G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
                    1.5G    /var/lib
                    Archived and active journals take up 3.9G in the file system.
                    /opt/iobroker/backups:
                    12M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    17G     /opt/iobroker/iobroker-data/
                    16G     /opt/iobroker/iobroker-data/history
                    650M    /opt/iobroker/iobroker-data/files
                    170M    /opt/iobroker/iobroker-data/files/javascript.admin
                    158M    /opt/iobroker/iobroker-data/backup-objects
                    39M     /opt/iobroker/iobroker-data/objects.jsonl
                    12M     /opt/iobroker/iobroker-data/states.jsonl
                    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/12.1aeaa68b.chunk.js.map
                    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                    9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.17.1
                    /home/iobroker/.nvm/versions/node/v18.9.0/bin/node              v18.9.0
                    /home/iobroker/.nvm/versions/node/v18.9.0/bin/npm               8.19.1
                    /home/iobroker/.nvm/versions/node/v18.9.0/bin/npx               8.19.1
                    /home/iobroker/.nvm/versions/node/v18.9.0/bin/corepack  0.14.0
                    *** nodejs is NOT correctly installed ***
                    nodejs:
                      Installed: 18.17.1-deb-1nodesource1
                      Candidate: 18.17.1-deb-1nodesource1
                      Version table:
                     *** 18.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
                         10.19.0~dfsg-3ubuntu1.2 500
                            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                            500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                         10.19.0~dfsg-3ubuntu1 500
                            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                    No problems detected
                    • W wolkenloser
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                                 Chassis: vm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : amd64
                      CPU threads: 2
                                    NTP service: active
                                RTC in local TZ: no
                      iobroker
                      /home/iobroker
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                               3919 M total memory
                               2689 M used memory
                                119 M free memory
                                145 M buffer memory
                                965 M swap cache
                               1969 M total swap
                                  3 M used swap
                               1966 M free swap
                      *** FILESYSTEM ***
                      /var:
                      5.6G    /var/
                      4.1G    /var/log
                      1.5G    /var/lib
                      USB-Devices by-id:
                      nodejs:
                        Version table:
                      W Offline
                      W Offline
                      wolkenloser
                      Dann ganz viele hiervon, und das ist nur die Hälfte
                      Errors in npm tree:
                      npm ERR! code ELSPROBLEMS
                      npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
                      npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
                      npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
                      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                      npm ERR! invalid: iobroker.energiefluss@3.6.0 /opt/iobroker/node_modules/iobroker.energiefluss
                      npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius
                      npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom
                      npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                      npm ERR! extraneous: @aashutoshrathi/word-wrap@1.2.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
                      npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
                      npm ERR! extraneous: @alcalzone/release-script-core@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
                      npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
                      npm ERR! extraneous: @alcalzone/release-script-plugin-exec@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
                      npm ERR! extraneous: @alcalzone/release-script-plugin-git@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
                      npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
                      npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
                      npm ERR! extraneous: @alcalzone/release-script-plugin-package@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
                      npm ERR! extraneous: @alcalzone/release-script-plugin-version@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
                      npm ERR! extraneous: @alcalzone/release-script@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                      npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                      npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                      npm ERR! extraneous: @eslint/eslintrc@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrcnpm ERR! extraneous: @eslint/js@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                      npm ERR! extraneous: @humanwhocodes/config-array@0.11.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                      npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                      npm ERR! extraneous: @humanwhocodes/object-schema@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                      npm ERR! extraneous: @iobroker/dev-server@0.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
                      npm ERR! extraneous: @iobroker/testing@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
                      npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                      npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.statnpm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walknpm ERR! extraneous: @sinonjs/commons@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commonsnpm ERR! extraneous: @sinonjs/fake-timers@9.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
                      npm ERR! extraneous: @sinonjs/samsam@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
                      npm ERR! extraneous: @sinonjs/text-encoding@0.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
                      npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
                      npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
                      npm ERR! extraneous: @types/cors@2.8.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
                      npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                      npm ERR! extraneous: @types/http-proxy@1.17.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
                      npm ERR! extraneous: @types/vinyl@2.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                      npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
                      npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
                      npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
                      npm ERR! extraneous: acorn-globals@1.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
                      npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                      npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                      npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-sharednpm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
                      npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                      npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                      npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                      npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                      npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                      npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                      npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                      npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                      npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                      npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                      npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                      npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                      npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                      npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                      npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                      npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
                      npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                      npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                      npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                      npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                      npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                      npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                      npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                      npm ERR! extraneous: astral-regex@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
                      npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                      npm ERR! extraneous: async-each-series@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
                      npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                      npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                      npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
                      npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                      npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                      npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                      npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                      npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
                      npm ERR! extraneous: batch@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
                      npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                      npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensionsnpm ERR! extraneous: body-parser@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
                      npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
                      npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                      npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                      npm ERR! extraneous: browser-request@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
                      npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                      npm ERR! extraneous: browser-sync-client@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
                      npm ERR! extraneous: browser-sync-ui@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
                      npm ERR! extraneous: browser-sync@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
                      npm ERR! extraneous: bs-html-injector@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injectornpm ERR! extraneous: bs-recipes@1.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
                      npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                      npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                      npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
                      npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                      npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
                      npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                      npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                      npm ERR! extraneous: chai-as-promised@7.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promisednpm ERR! extraneous: chai@4.3.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                      npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                      npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                      npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                      npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                      npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
                      npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                      npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                      npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                      npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                      npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                      npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                      npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                      npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visitnpm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                      npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                      npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
                      npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
                      npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                      npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                      npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                      npm ERR! extraneous: connect-history-api-fallback@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
                      npm ERR! extraneous: connect@3.6.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
                      npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
                      npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
                      npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                      npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signaturenpm ERR! extraneous: cookie@0.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
                      npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                      npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                      npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
                      npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                      npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
                      npm ERR! extraneous: cssstyle@0.2.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
                      npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                      npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                      npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                      npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                      npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                      npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                      npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                      npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
                      npm ERR! extraneous: define-properties@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
                      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                      npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
                      npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
                      npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                      npm ERR! extraneous: dev-ip@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
                      npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                      npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                      npm ERR! extraneous: dom-compare-temp@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-tempnpm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
                      npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
                      npm ERR! extraneous: domhandler@2.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
                      npm ERR! extraneous: domutils@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
                      npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
                      npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                      npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                      npm ERR! extraneous: easy-extender@2.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
                      npm ERR! extraneous: eazy-logger@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
                      npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
                      npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                      npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
                      npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                      npm ERR! extraneous: engine.io-client@6.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-clientnpm ERR! extraneous: engine.io-parser@5.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parsernpm ERR! extraneous: engine.io@6.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
                      npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                      npm ERR! extraneous: entities@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
                      npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                      npm ERR! extraneous: es5-ext@0.10.62 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                      npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                      npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                      npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                      npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                      npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
                      npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                      npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
                      npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                      npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                      npm ERR! extraneous: eslint@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                      npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                      npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
                      npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                      npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                      npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                      npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                      npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
                      npm ERR! extraneous: event-stream@3.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
                      npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
                      npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                      npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                      npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                      npm ERR! extraneous: express@4.18.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
                      npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                      npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                      npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                      npm ERR! extraneous: fast-glob@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                      npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshteinnpm ERR! extraneous: fastq@1.15.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                      npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cachenpm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                      npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
                      npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                      • W wolkenloser
                        Errors in npm tree:
                        W Offline
                        W Offline
                        wolkenloser
                        Hier der Rest...
                        npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_09_978Z-debug-0.log
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  4.0.24
                        admin:          6.2.23
                        javascript:     6.2.0
                        npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_43_451Z-debug-0.log
                        Adapters from github:   3
                        Adapter State
                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                          system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
                        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                        + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
                          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
                        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                          system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                        + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
                          system.adapter.labcom.0                 : labcom                : iobroker                                 - disabled
                        + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                          system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                        + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                        + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                          system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                          system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
                        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                          system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                        + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                          system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Installed ioBroker-Instances
                        Adapter    "admin"        : 6.12.0   , installed 6.2.23 [Updatable]
                        Adapter    "backitup"     : 2.8.7    , installed 2.9.1
                        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                        Adapter    "javascript"   : 7.1.4    , installed 6.2.0  [Updatable]
                        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.90.0 [Updatable]
                        Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
                        Objects and States
                        Objects:        11799
                        States:         10540
                        Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
                        Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                        Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                        Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
                        Hit:5 https://deb.nodesource.com/node_18.x focal InRelease
                        Reading package lists...
                        Pending Updates: 15
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       35070      2326/io.shelly.0
                        tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       35419      2573/io.fakeroku.0
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       32795      1756/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       32532      1756/iobroker.js-co
                        tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28197      1027/perl
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21935      641/systemd-resolve
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25514      811/sshd: /usr/sbin
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        31602      1777/influxd
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34927      2333/io.sonoff.0
                        tcp6       0      0 :::61991                :::*                    LISTEN      1000       36326      2653/io.harmony.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34086      2132/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37649      2882/io.web.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        32766      1777/influxd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          25516      811/sshd: /usr/sbin
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       37894      3013/io.simple-api.
                        tcp6       0      0 :::3000                 :::*                    LISTEN      111        27368      783/grafana-server
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       37506      2935/io.wled.0
                        udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28198      1027/perl
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       35420      2573/io.fakeroku.0
                        udp        0      0 192.168.8.67:53249      0.0.0.0:*                           1000       35708      2690/io.knx.0
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21934      641/systemd-resolve
                        udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        21920      635/systemd-network
                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       35977      2473/io.mihome-vacu
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       36336      2494/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       36337      2494/io.tuya.0
                        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       36327      2653/io.harmony.0
                        udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        20383      635/systemd-network
                        2023-11-20 12:02:11.075  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:11+00:00"}}
                        2023-11-20 12:02:40.671  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MinMaxInverterData: {"Body":{"Data":{}},"Head":{"RequestArguments":{"DataCollection":"MinMaxInverterData","Scope":"Device"},"Status":{"Code":11,"Reason":"Parameter 'MinMaxInverterData' for attribute 'DataCollection' not supported. Use one of 'CumulationInverterData', 'CommonInverterData', '3PInverterData'.","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:40.683  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Current_AC_Phase_1":0.732,"Current_AC_Phase_2":-0.69,"Current_AC_Phase_3":1.231,"Current_AC_Sum":1.2730000000000001,"Details":{"Manufacturer":"Fronius","Model":"Smart Meter TS 65A-3","Serial":"1659699688"},"Enable":1,"EnergyReactive_VArAC_Sum_Consumed":787465,"EnergyReactive_VArAC_Sum_Produced":5086507,"EnergyReal_WAC_Minus_Absolute":7490523,"EnergyReal_WAC_Plus_Absolute":4746701,"EnergyReal_WAC_Sum_Consumed":4746701,"EnergyReal_WAC_Sum_Produced":7490523,"Frequency_Phase_Average":50,"Meter_Location_Current":0,"PowerApparent_S_Phase_1":54.5,"PowerApparent_S_Phase_2":151.6,"PowerApparent_S_Phase_3":195.1,"PowerApparent_S_Sum":401.4,"PowerFactor_Phase_1":0.714,"PowerFactor_Phase_2":-0.881,"PowerFactor_Phase_3":0.515,"PowerFactor_Sum":0.019,"PowerReactive_Q_Phase_1":-38.2,"PowerReactive_Q_Phase_2":-71.5,"PowerReactive_Q_Phase_3":-166.6,"PowerReactive_Q_Sum":-276.4,"PowerReal_P_Phase_1":38.9,"PowerReal_P_Phase_2":-133.6,"PowerReal_P_Phase_3":101.6,"PowerReal_P_Sum":6.8,"TimeStamp":1700478159,"Visible":1,"Voltage_AC_PhaseToPhase_12":410.1,"Voltage_AC_PhaseToPhase_23":411,"Voltage_AC_PhaseToPhase_31":406.1,"Voltage_AC_Phase_1":241.2,"Voltage_AC_Phase_2":230,"Voltage_AC_Phase_3":237.7}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:40.726  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetStorageRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Controller":{"Capacity_Maximum":10240,"Current_DC":1.2981114032990677,"DesignedCapacity":10240,"Details":{"Manufacturer":"BYD","Model":"BYD Battery-Box Premium HV","Serial":"P030T020Z2010263183     "},"Enable":1,"StateOfCharge_Relative":17.8,"Status_BatteryCell":3,"Temperature_Cell":12,"TimeStamp":1700478156,"Voltage_DC":418.3},"Modules":[]}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:40.767  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetPowerFlowRealtimeData.fcgi: {"Body":{"Data":{"Inverters":{"1":{"Battery_Mode":"normal","DT":1,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"P":460.24041748046875,"SOC":17.8}},"SecondaryMeters":{},"Site":{"BackupMode":false,"BatteryStandby":true,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"Meter_Location":"grid","Mode":"bidirectional","P_Akku":-666.0352783203125,"P_Grid":6.8,"P_Load":-467.79334716796876,"P_PV":1129.3310546875,"rel_Autonomy":98.54636667212833,"rel_SelfConsumption":100},"Smartloads":{"Ohmpilots":{}},"Version":"12"}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:40.769  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetOhmPilotRealtimeData.cgi?Scope=System: {"Body":{"Data":{}},"Head":{"RequestArguments":{"Scope":"System"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:40.773  - debug: fronius.0 (2593) API Objekt E_Day is null, object inverter.1.E_Day will be set to 0!
                        2023-11-20 12:02:40.782  - debug: fronius.0 (2593) API Objekt E_Year is null, object inverter.1.E_Year will be set to 0!2023-11-20 12:02:40.783  - debug: fronius.0 (2593) API Objekt E_Day is null, object site.E_Day will be set to 0!
                        2023-11-20 12:02:40.784  - debug: fronius.0 (2593) API Objekt E_Year is null, object site.E_Year will be set to 0!
                        2023-11-20 12:02:40.928  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:41.004  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData: {"Body":{"Data":{"DAY_ENERGY":{"Unit":"Wh","Value":null},"DeviceStatus":{"ErrorCode":1130,"InverterState":"Running","StatusCode":7},"FAC":{"Unit":"Hz","Value":50.00504684448242},"IAC":{"Unit":"A","Value":1.970382273197174},"IDC":{"Unit":"A","Value":1.233007550239563},"IDC_2":{"Unit":"A","Value":1.0074610710144043},"IDC_3":{"Unit":"A","Value":null},"IDC_4":{"Unit":"A","Value":null},"PAC":{"Unit":"W","Value":463.17767333984375},"SAC":{"Unit":"VA","Value":463.22857666015625},"TOTAL_ENERGY":{"Unit":"Wh","Value":23263193.850555554},"UAC":{"Unit":"V","Value":234.6595916748047},"UDC":{"Unit":"V","Value":528.879150390625},"UDC_2":{"Unit":"V","Value":555.4661254882812},"UDC_3":{"Unit":"V","Value":null},"UDC_4":{"Unit":"V","Value":null},"YEAR_ENERGY":{"Unit":"Wh","Value":null}}},"Head":{"RequestArguments":{"DataCollection":"CommonInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                        2023-11-20 12:02:41.041  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=3PInverterData: {"Body":{"Data":{"IAC_L1":{"Unit":"A","Value":0.6535905599594116},"IAC_L2":{"Unit":"A","Value":0.6578454971313477},"IAC_L3":{"Unit":"A","Value":0.6589462161064148},"UAC_L1":{"Unit":"V","Value":234.55113220214844},"UAC_L2":{"Unit":"V","Value":236.23095703125},"UAC_L3":{"Unit":"V","Value":234.4892120361328}}},"Head":{"RequestArguments":{"DataCollection":"3PInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:41+00:00"}}
                        2023-11-20 12:03:00.036  - warn: javascript.0 (2207) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
                        2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1729:20)
                        2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
                        2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1605:34)
                        2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
                        2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
                        2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
                        2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at listOnTimeout (node:internal/timers:564:17)
                        2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at processTimers (node:internal/timers:507:7)
                        2023-11-20 12:03:00.040  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: 25.2
                        2023-11-20 12:03:00.041  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
                        2023-11-20 12:03:02.105  - warn: sonoff.0 (2333) Client [] has invalid password or username
                        iob diag has finished.
                        Press any key for a summary
                        Thomas BraunT W 2 Antworten Letzte Antwort
                        • W wolkenloser
                          Hier der Rest...
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.2.23
                          javascript:     6.2.0
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        11799
                          States:         10540
                          Pending Updates: 15
                          @wolkenloser
                          Dein nodejs ist noch schief.
                          Kratz das alles raus.
                          rm -rf /home/iobroker/.nvm
                          Danach
                          iob fix
                          iob nodejs-update
                          • W wolkenloser
                            Hier der Rest...
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.2.23
                            javascript:     6.2.0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        11799
                            States:         10540
                            Pending Updates: 15
                            W Offline
                            W Offline
                            wolkenloser
                            Wie gesagt, die ganzen Updateable Adapters lassen sich nicht updaten.
                            Das Problem fing vor 2 Monaten an, als ich den Energiefluss Adapter installiert hatte....
                            • W wolkenloser
                              @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
                              Nein, das fing damit an, dass du da per nvm ein nodejs 18.9.0 reingeklatscht hast...
                                W Offline
                                W Offline
                                wolkenloser
                                wie gesagt, ich bin auch nur Benutzer.
                                Aber ich lerne gerne dazu, weil interessieren tut es mich ja.
                                Man nennt das wohl auchg auch "gefährliches Halbwissen"
                                Wenn das so ist wie Du es sagst habe ich das wohl aus irgendeiner Intention, oder wegen einer Anleitung im Internet gemacht.
                                Der Energiefluss Adapter lies sich damals nicht über die Oberfläche installieren, dann hab ich gesucht wie es noch geht. Irgendwann war er drin.
                                Ich versuch jetzzt das was Du oben geschrieben hast...
                                Thomas BraunT 3 Antworten Letzte Antwort
                                • W wolkenloser
                                  Was kann ich denn jetzt am besten machen ohne bei Null anzufangen ?
                                  Hab ich doch vor 15 Minuten oben geschrieben...
                                  Den Kram löschen und nodejs ordentlich installieren wäre schon mal ein erster Schritt.
                                  • W wolkenloser
                                    @wolkenloser
                                    Und schalt den
                                    debug: fronius.0
                                    aus. Der kübelt dir sonst zu viel in das Log rein.
                                    • W wolkenloser
                                      @wolkenloser
                                      Wenn nodejs sauber installiert ist und die ganzen npm-Fehler dann immer noch aufkreuzen:
                                      Installier mindestens diese drei Adapter nochmal:
                                      Sind alle über github und nicht 'ordentlich' installiert, oder?
                                        @wolkenloser
                                        W Offline
                                        W Offline
                                        wolkenloser
                                        Energiefluss auf jeden Fall
                                        den Labcom brauch ich nicht mehr den deinstalliere ich.
                                        Fronius ist mit am wichtigsten wegen diverser Scripte.... ich schau mal.
                                        Wenn ich den neu installiere sollten die Datenpunkte ja wieder so wie bisher aktualisiert werden.....
                                        • W wolkenloser
                                          W Offline
                                          W Offline
                                          wolkenloser
                                          Labcom ist weg....
                                          Hast Du dafür auch eine Lösung ?
