  4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
zigbee-adapter
61 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
    @wolkenloser
    Meldungen im Logfile?
    iob diag
    in der Langfassung sagt?
    W Offline
    W Offline
    wolkenloser
    Mehr als 1000 Zeilen, muss ich splitten
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm
        Virtualization: microsoft
      Operating System: Ubuntu 20.04.6 LTS
                Kernel: Linux 5.4.0-166-generic
          Architecture: x86-64
    model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
    Docker          : false
    Virtualization  : microsoft
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:00:09 up 25 min,  1 user,  load average: 0.44, 0.64, 1.09
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2023-11-20 12:00:10 CET
               Universal time: Mon 2023-11-20 11:00:10 UTC
                     RTC time: Mon 2023-11-20 11:00:11
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.9G        2.7G        119M        1.0M        1.1G        1.1G
    Swap:          2.0G        3.0M        2.0G
    Total:         5.9G        2.7G        2.1G
             3919 M total memory
             2689 M used memory
             2743 M active memory
              726 M inactive memory
              119 M free memory
              145 M buffer memory
              965 M swap cache
             1969 M total swap
                3 M used swap
             1966 M free swap
    *** FAILED SERVICES ***
      UNIT           LOAD   ACTIVE SUB    DESCRIPTION
    * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     392M  1.1M  391M   1% /run
    /dev/sda2      ext4       50G   34G   13G  73% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
    /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16091
    /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16202
    /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2796
    /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2790
    /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2015
    /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
    /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
    /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
    /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
    /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
    /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
    tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
    [sudo] password for iobroker:
    [Mon Nov 20 11:34:45 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Nov 20 11:35:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET                SOURCE      FSTYPE   OPTIONS
    /                     /dev/sda2   ext4     rw,relatime
    |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
    |-/snap/core/16091    /dev/loop0  squashfs ro,nodev,relatime
    |-/snap/core/16202    /dev/loop1  squashfs ro,nodev,relatime
    |-/snap/core18/2796   /dev/loop3  squashfs ro,nodev,relatime
    |-/snap/core18/2790   /dev/loop2  squashfs ro,nodev,relatime
    |-/snap/core20/2015   /dev/loop5  squashfs ro,nodev,relatime
    |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
    |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
    |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
    |-/snap/core20/1974   /dev/loop4  squashfs ro,nodev,relatime
    |-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
    `-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
    /var:
    5.6G    /var/
    4.1G    /var/log
    4.0G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
    1.5G    /var/lib
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    12M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    17G     /opt/iobroker/iobroker-data/
    16G     /opt/iobroker/iobroker-data/history
    650M    /opt/iobroker/iobroker-data/files
    170M    /opt/iobroker/iobroker-data/files/javascript.admin
    158M    /opt/iobroker/iobroker-data/backup-objects
    39M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/12.1aeaa68b.chunk.js.map
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/node              v18.9.0
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/npm               8.19.1
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/npx               8.19.1
    /home/iobroker/.nvm/versions/node/v18.9.0/bin/corepack  0.14.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
         10.19.0~dfsg-3ubuntu1.2 500
            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    No problems detected
    W 1 Antwort Letzte Antwort
    • W wolkenloser
      Skript v.2023-10-10
      *** BASE SYSTEM ***
                 Chassis: vm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 2
                    NTP service: active
                RTC in local TZ: no
      iobroker
      /home/iobroker
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
               3919 M total memory
               2689 M used memory
                119 M free memory
                145 M buffer memory
                965 M swap cache
               1969 M total swap
                  3 M used swap
               1966 M free swap
      *** FILESYSTEM ***
      /var:
      5.6G    /var/
      4.1G    /var/log
      1.5G    /var/lib
      USB-Devices by-id:
      nodejs:
        Version table:
      W Offline
      W Offline
      wolkenloser
      Dann ganz viele hiervon, und das ist nur die Hälfte
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.energiefluss@3.6.0 /opt/iobroker/node_modules/iobroker.energiefluss
      npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius
      npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom
      npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! extraneous: @aashutoshrathi/word-wrap@1.2.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
      npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
      npm ERR! extraneous: @alcalzone/release-script-core@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
      npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
      npm ERR! extraneous: @alcalzone/release-script-plugin-exec@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
      npm ERR! extraneous: @alcalzone/release-script-plugin-git@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
      npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
      npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
      npm ERR! extraneous: @alcalzone/release-script-plugin-package@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
      npm ERR! extraneous: @alcalzone/release-script-plugin-version@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
      npm ERR! extraneous: @alcalzone/release-script@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
      npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
      npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
      npm ERR! extraneous: @eslint/eslintrc@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrcnpm ERR! extraneous: @eslint/js@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
      npm ERR! extraneous: @humanwhocodes/config-array@0.11.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
      npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
      npm ERR! extraneous: @humanwhocodes/object-schema@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
      npm ERR! extraneous: @iobroker/dev-server@0.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
      npm ERR! extraneous: @iobroker/testing@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
      npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
      npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.statnpm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walknpm ERR! extraneous: @sinonjs/commons@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commonsnpm ERR! extraneous: @sinonjs/fake-timers@9.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
      npm ERR! extraneous: @sinonjs/samsam@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
      npm ERR! extraneous: @sinonjs/text-encoding@0.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
      npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
      npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
      npm ERR! extraneous: @types/cors@2.8.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
      npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
      npm ERR! extraneous: @types/http-proxy@1.17.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
      npm ERR! extraneous: @types/vinyl@2.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
      npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
      npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
      npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
      npm ERR! extraneous: acorn-globals@1.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
      npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
      npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
      npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-sharednpm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
      npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
      npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
      npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
      npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
      npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
      npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
      npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
      npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
      npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
      npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
      npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
      npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
      npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
      npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
      npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
      npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
      npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
      npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
      npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
      npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
      npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
      npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
      npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
      npm ERR! extraneous: astral-regex@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
      npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
      npm ERR! extraneous: async-each-series@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
      npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
      npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
      npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
      npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
      npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
      npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
      npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
      npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
      npm ERR! extraneous: batch@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
      npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
      npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensionsnpm ERR! extraneous: body-parser@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
      npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
      npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
      npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
      npm ERR! extraneous: browser-request@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
      npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
      npm ERR! extraneous: browser-sync-client@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
      npm ERR! extraneous: browser-sync-ui@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
      npm ERR! extraneous: browser-sync@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
      npm ERR! extraneous: bs-html-injector@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injectornpm ERR! extraneous: bs-recipes@1.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
      npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
      npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
      npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
      npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
      npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
      npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
      npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
      npm ERR! extraneous: chai-as-promised@7.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promisednpm ERR! extraneous: chai@4.3.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
      npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
      npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
      npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
      npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
      npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
      npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
      npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
      npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
      npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
      npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
      npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
      npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
      npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visitnpm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
      npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
      npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
      npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
      npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
      npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
      npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
      npm ERR! extraneous: connect-history-api-fallback@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
      npm ERR! extraneous: connect@3.6.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
      npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
      npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
      npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
      npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signaturenpm ERR! extraneous: cookie@0.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
      npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
      npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
      npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
      npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
      npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
      npm ERR! extraneous: cssstyle@0.2.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
      npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
      npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
      npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
      npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
      npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
      npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
      npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
      npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
      npm ERR! extraneous: define-properties@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
      npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
      npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
      npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
      npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
      npm ERR! extraneous: dev-ip@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
      npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
      npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
      npm ERR! extraneous: dom-compare-temp@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-tempnpm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
      npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
      npm ERR! extraneous: domhandler@2.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
      npm ERR! extraneous: domutils@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
      npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
      npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
      npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
      npm ERR! extraneous: easy-extender@2.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
      npm ERR! extraneous: eazy-logger@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
      npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
      npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
      npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
      npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
      npm ERR! extraneous: engine.io-client@6.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-clientnpm ERR! extraneous: engine.io-parser@5.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parsernpm ERR! extraneous: engine.io@6.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
      npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
      npm ERR! extraneous: entities@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
      npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
      npm ERR! extraneous: es5-ext@0.10.62 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
      npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
      npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
      npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
      npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
      npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
      npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
      npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
      npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
      npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
      npm ERR! extraneous: eslint@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
      npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
      npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
      npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
      npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
      npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
      npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
      npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
      npm ERR! extraneous: event-stream@3.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
      npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
      npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
      npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
      npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
      npm ERR! extraneous: express@4.18.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
      npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
      npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
      npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
      npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
      npm ERR! extraneous: fast-glob@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
      npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshteinnpm ERR! extraneous: fastq@1.15.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
      npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cachenpm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
      npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
      npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
      • W wolkenloser
        Errors in npm tree:
        W Offline
        W Offline
        wolkenloser
        Hier der Rest...
        npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_09_978Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.2.23
        javascript:     6.2.0
        npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_43_451Z-debug-0.log
        Adapters from github:   3
        Adapter State
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
          system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
        + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
          system.adapter.labcom.0                 : labcom                : iobroker                                 - disabled
        + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
        + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
        + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
          system.adapter.parser.0                 : parser                : iobroker                                 - disabled
          system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
        + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
          system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.2.23 [Updatable]
        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
        Adapter    "backitup"     : 2.8.7    , installed 2.9.1
        Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
        Adapter    "bydhvs"       : 1.4.0    , installed 1.5.0
        Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
        Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
        Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
        Adapter    "easee"        : 1.0.10   , installed 1.0.10
        Adapter    "echarts"      : 1.5.4    , installed 1.0.12 [Updatable]
        Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "harmony"      : 1.2.2    , installed 1.2.2
        Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.4    , installed 6.2.0  [Updatable]
        Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
        Adapter    "knx"          : 2.0.23   , installed 2.0.13 [Updatable]
        Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
        Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
        Adapter    "midea"        : 0.0.7    , installed 0.0.7
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-vacuum": 4.1.0    , installed 3.8.6  [Updatable]
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
        Adapter    "openweathermap": 0.4.5   , installed 0.3.11 [Updatable]
        Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
        Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pvforecast"   : 2.9.0    , installed 2.7.1  [Updatable]
        Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
        Adapter    "schwoerer-ventcube": 1.4.2, installed 1.4.2
        Adapter    "shelly"       : 6.6.1    , installed 6.0.0  [Updatable]
        Adapter    "shuttercontrol": 1.6.2   , installed 1.6.3
        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
        Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
        Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
        Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
        Adapter    "trashschedule": 2.3.0    , installed 2.0.3  [Updatable]
        Adapter    "tuya"         : 3.14.2   , installed 3.9.4  [Updatable]
        Adapter    "unifi"        : 0.6.6    , installed 0.5.10 [Updatable]
        Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
        Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.90.0 [Updatable]
        Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "wled"         : 0.7.1    , installed 0.6.7  [Updatable]
        Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
        Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
        Objects and States
        Objects:        11799
        States:         10540
        Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
        Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
        Hit:5 https://deb.nodesource.com/node_18.x focal InRelease
        Reading package lists...
        Pending Updates: 15
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       35070      2326/io.shelly.0
        tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       35419      2573/io.fakeroku.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       32795      1756/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       32532      1756/iobroker.js-co
        tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28197      1027/perl
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21935      641/systemd-resolve
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25514      811/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        31602      1777/influxd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34927      2333/io.sonoff.0
        tcp6       0      0 :::61991                :::*                    LISTEN      1000       36326      2653/io.harmony.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34086      2132/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37649      2882/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        32766      1777/influxd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          25516      811/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       37894      3013/io.simple-api.
        tcp6       0      0 :::3000                 :::*                    LISTEN      111        27368      783/grafana-server
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       37506      2935/io.wled.0
        udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28198      1027/perl
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       35420      2573/io.fakeroku.0
        udp        0      0 192.168.8.67:53249      0.0.0.0:*                           1000       35708      2690/io.knx.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21934      641/systemd-resolve
        udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        21920      635/systemd-network
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       35977      2473/io.mihome-vacu
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       36336      2494/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       36337      2494/io.tuya.0
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       36327      2653/io.harmony.0
        udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        20383      635/systemd-network
        2023-11-20 12:02:11.075  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:11+00:00"}}
        2023-11-20 12:02:40.671  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MinMaxInverterData: {"Body":{"Data":{}},"Head":{"RequestArguments":{"DataCollection":"MinMaxInverterData","Scope":"Device"},"Status":{"Code":11,"Reason":"Parameter 'MinMaxInverterData' for attribute 'DataCollection' not supported. Use one of 'CumulationInverterData', 'CommonInverterData', '3PInverterData'.","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:40.683  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Current_AC_Phase_1":0.732,"Current_AC_Phase_2":-0.69,"Current_AC_Phase_3":1.231,"Current_AC_Sum":1.2730000000000001,"Details":{"Manufacturer":"Fronius","Model":"Smart Meter TS 65A-3","Serial":"1659699688"},"Enable":1,"EnergyReactive_VArAC_Sum_Consumed":787465,"EnergyReactive_VArAC_Sum_Produced":5086507,"EnergyReal_WAC_Minus_Absolute":7490523,"EnergyReal_WAC_Plus_Absolute":4746701,"EnergyReal_WAC_Sum_Consumed":4746701,"EnergyReal_WAC_Sum_Produced":7490523,"Frequency_Phase_Average":50,"Meter_Location_Current":0,"PowerApparent_S_Phase_1":54.5,"PowerApparent_S_Phase_2":151.6,"PowerApparent_S_Phase_3":195.1,"PowerApparent_S_Sum":401.4,"PowerFactor_Phase_1":0.714,"PowerFactor_Phase_2":-0.881,"PowerFactor_Phase_3":0.515,"PowerFactor_Sum":0.019,"PowerReactive_Q_Phase_1":-38.2,"PowerReactive_Q_Phase_2":-71.5,"PowerReactive_Q_Phase_3":-166.6,"PowerReactive_Q_Sum":-276.4,"PowerReal_P_Phase_1":38.9,"PowerReal_P_Phase_2":-133.6,"PowerReal_P_Phase_3":101.6,"PowerReal_P_Sum":6.8,"TimeStamp":1700478159,"Visible":1,"Voltage_AC_PhaseToPhase_12":410.1,"Voltage_AC_PhaseToPhase_23":411,"Voltage_AC_PhaseToPhase_31":406.1,"Voltage_AC_Phase_1":241.2,"Voltage_AC_Phase_2":230,"Voltage_AC_Phase_3":237.7}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:40.726  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetStorageRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Controller":{"Capacity_Maximum":10240,"Current_DC":1.2981114032990677,"DesignedCapacity":10240,"Details":{"Manufacturer":"BYD","Model":"BYD Battery-Box Premium HV","Serial":"P030T020Z2010263183     "},"Enable":1,"StateOfCharge_Relative":17.8,"Status_BatteryCell":3,"Temperature_Cell":12,"TimeStamp":1700478156,"Voltage_DC":418.3},"Modules":[]}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:40.767  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetPowerFlowRealtimeData.fcgi: {"Body":{"Data":{"Inverters":{"1":{"Battery_Mode":"normal","DT":1,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"P":460.24041748046875,"SOC":17.8}},"SecondaryMeters":{},"Site":{"BackupMode":false,"BatteryStandby":true,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"Meter_Location":"grid","Mode":"bidirectional","P_Akku":-666.0352783203125,"P_Grid":6.8,"P_Load":-467.79334716796876,"P_PV":1129.3310546875,"rel_Autonomy":98.54636667212833,"rel_SelfConsumption":100},"Smartloads":{"Ohmpilots":{}},"Version":"12"}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:40.769  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetOhmPilotRealtimeData.cgi?Scope=System: {"Body":{"Data":{}},"Head":{"RequestArguments":{"Scope":"System"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:40.773  - debug: fronius.0 (2593) API Objekt E_Day is null, object inverter.1.E_Day will be set to 0!
        2023-11-20 12:02:40.782  - debug: fronius.0 (2593) API Objekt E_Year is null, object inverter.1.E_Year will be set to 0!2023-11-20 12:02:40.783  - debug: fronius.0 (2593) API Objekt E_Day is null, object site.E_Day will be set to 0!
        2023-11-20 12:02:40.784  - debug: fronius.0 (2593) API Objekt E_Year is null, object site.E_Year will be set to 0!
        2023-11-20 12:02:40.928  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:41.004  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData: {"Body":{"Data":{"DAY_ENERGY":{"Unit":"Wh","Value":null},"DeviceStatus":{"ErrorCode":1130,"InverterState":"Running","StatusCode":7},"FAC":{"Unit":"Hz","Value":50.00504684448242},"IAC":{"Unit":"A","Value":1.970382273197174},"IDC":{"Unit":"A","Value":1.233007550239563},"IDC_2":{"Unit":"A","Value":1.0074610710144043},"IDC_3":{"Unit":"A","Value":null},"IDC_4":{"Unit":"A","Value":null},"PAC":{"Unit":"W","Value":463.17767333984375},"SAC":{"Unit":"VA","Value":463.22857666015625},"TOTAL_ENERGY":{"Unit":"Wh","Value":23263193.850555554},"UAC":{"Unit":"V","Value":234.6595916748047},"UDC":{"Unit":"V","Value":528.879150390625},"UDC_2":{"Unit":"V","Value":555.4661254882812},"UDC_3":{"Unit":"V","Value":null},"UDC_4":{"Unit":"V","Value":null},"YEAR_ENERGY":{"Unit":"Wh","Value":null}}},"Head":{"RequestArguments":{"DataCollection":"CommonInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
        2023-11-20 12:02:41.041  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=3PInverterData: {"Body":{"Data":{"IAC_L1":{"Unit":"A","Value":0.6535905599594116},"IAC_L2":{"Unit":"A","Value":0.6578454971313477},"IAC_L3":{"Unit":"A","Value":0.6589462161064148},"UAC_L1":{"Unit":"V","Value":234.55113220214844},"UAC_L2":{"Unit":"V","Value":236.23095703125},"UAC_L3":{"Unit":"V","Value":234.4892120361328}}},"Head":{"RequestArguments":{"DataCollection":"3PInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:41+00:00"}}
        2023-11-20 12:03:00.036  - warn: javascript.0 (2207) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
        2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1729:20)
        2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
        2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1605:34)
        2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
        2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
        2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
        2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at listOnTimeout (node:internal/timers:564:17)
        2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at processTimers (node:internal/timers:507:7)
        2023-11-20 12:03:00.040  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: 25.2
        2023-11-20 12:03:00.041  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
        2023-11-20 12:03:02.105  - warn: sonoff.0 (2333) Client [] has invalid password or username
        iob diag has finished.
        Press any key for a summary
        Thomas BraunT W 2 Antworten Letzte Antwort
        • W wolkenloser
          Hier der Rest...
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.2.23
          javascript:     6.2.0
          Adapter State
          + instance is alive
          Objects and States
          Objects:        11799
          States:         10540
          Pending Updates: 15
          @wolkenloser
          Dein nodejs ist noch schief.
          Kratz das alles raus.
          rm -rf /home/iobroker/.nvm
          Danach
          iob fix
          iob nodejs-update
          • W wolkenloser
            Hier der Rest...
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.2.23
            javascript:     6.2.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        11799
            States:         10540
            Pending Updates: 15
            W Offline
            W Offline
            wolkenloser
            Wie gesagt, die ganzen Updateable Adapters lassen sich nicht updaten.
            Das Problem fing vor 2 Monaten an, als ich den Energiefluss Adapter installiert hatte....
            • W wolkenloser
              @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
              Nein, das fing damit an, dass du da per nvm ein nodejs 18.9.0 reingeklatscht hast...
                W Offline
                W Offline
                wolkenloser
                schrieb am zuletzt editiert von wolkenloser
                wie gesagt, ich bin auch nur Benutzer.
                Aber ich lerne gerne dazu, weil interessieren tut es mich ja.
                Man nennt das wohl auchg auch "gefährliches Halbwissen"
                Wenn das so ist wie Du es sagst habe ich das wohl aus irgendeiner Intention, oder wegen einer Anleitung im Internet gemacht.
                Der Energiefluss Adapter lies sich damals nicht über die Oberfläche installieren, dann hab ich gesucht wie es noch geht. Irgendwann war er drin.
                Ich versuch jetzzt das was Du oben geschrieben hast...
                Thomas BraunT 3 Antworten Letzte Antwort
                • W wolkenloser
                  Was kann ich denn jetzt am besten machen ohne bei Null anzufangen ?
                  Hab ich doch vor 15 Minuten oben geschrieben...
                  Den Kram löschen und nodejs ordentlich installieren wäre schon mal ein erster Schritt.
                  • W wolkenloser
                    @wolkenloser
                    Und schalt den
                    debug: fronius.0
                    aus. Der kübelt dir sonst zu viel in das Log rein.
                    • W wolkenloser
                      @wolkenloser
                      Wenn nodejs sauber installiert ist und die ganzen npm-Fehler dann immer noch aufkreuzen:
                      Installier mindestens diese drei Adapter nochmal:
                      Sind alle über github und nicht 'ordentlich' installiert, oder?
                        @wolkenloser
                        W Offline
                        W Offline
                        wolkenloser
                        Energiefluss auf jeden Fall
                        den Labcom brauch ich nicht mehr den deinstalliere ich.
                        Fronius ist mit am wichtigsten wegen diverser Scripte.... ich schau mal.
                        Wenn ich den neu installiere sollten die Datenpunkte ja wieder so wie bisher aktualisiert werden.....
                        • W wolkenloser
                          W Offline
                          W Offline
                          wolkenloser
                          Labcom ist weg....
                          Hast Du dafür auch eine Lösung ?
                          • W wolkenloser
                            Labcom ist weg....
                            @wolkenloser
                            Ich seh nix. Text auch als Text in CodeTags eingebettet hier rein.
                              @wolkenloser
                              W Offline
                              W Offline
                              wolkenloser
                              Kommt gleich..
                              Zwischenstand:
                                                      v.2023-10-10
                                         Chassis: vm
                              Installation:           microsoft
                              Kernel:                 x86_64
                              Userland:               amd64
                              Timezone:               Europe/Berlin (CET, +0100)
                              User-ID:                1000
                              X-Server:               false
                              Pending OS-Updates:     0
                              node:internal/modules/cjs/loader:1080
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                                  at Module._load (node:internal/modules/cjs/loader:922:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:86:12)
                                  at node:internal/main/run_main_module:23:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              Node.js v18.18.2
                              Pending iob updates:    0
                              Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                                                      /usr/bin/node           v18.18.2
                                                      /usr/bin/npm            9.8.1
                                                      /usr/bin/npx            9.8.1
                                                      /usr/bin/corepack       0.19.0
                              Recommended versions are nodejs  and npm
                              MEMORY:
                              Mem:           3.9G        423M        2.3G        0.0K        1.2G        3.2G
                              Swap:          2.0G         43M        1.9G
                              Total:         5.9G        467M        4.2G
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              Active iob-Instances:   0
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              ioBroker Core:          js-controller
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                                                      admin
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              ioBroker Status:
                                throw err;
                                requireStack: []
                              Node.js v18.18.2
                              Objects:                0
                              States:                 0
                              Size of iob-Database:
                              16M     /opt/iobroker/iobroker-data/objects.jsonl
                              9.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/objects.json.broken
                              2.6M    /opt/iobroker/iobroker-data/states.jsonl
                              1.3M    /opt/iobroker/iobroker-data/states.json.migrated
                              1.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/states.json.broken
                              • W wolkenloser
                                Kommt gleich..
                                Zwischenstand:
                                                        v.2023-10-10
                                           Chassis: vm
                                Kernel:                 x86_64
                                Userland:               amd64
                                User-ID:                1000
                                X-Server:               false
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                                        /usr/bin/npm            9.8.1
                                                        /usr/bin/npx            9.8.1
                                MEMORY:
                                Swap:          2.0G         43M        1.9G
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                                        admin
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                ioBroker Status:
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                Objects:                0
                                States:                 0
                                W Offline
                                W Offline
                                wolkenloser
                                ich kann Dir den Text vom Energieflussadapter nicht reinkopieren, im moment kann ich nichtmal den Admin Adapter aufrufen. Hab versucht den manuell zu starten, Dann kommt das
                                iob start admin
                                  throw err;
                                  requireStack: []
                                Node.js v18.18.2
                                • W wolkenloser
                                  iob start admin
                                    throw err;
                                    requireStack: []
                                  Node.js v18.18.2
                                  @wolkenloser
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.js-controller
                                    @wolkenloser
                                    W Offline
                                    W Offline
                                    wolkenloser
                                    /opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                    (#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.(#####⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠸ idealTree:@root/greenlock: sill placeDep ROOT @root/keypairs@0.9.0 OK for: greenlock@4.0.npm WARN skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                                    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                    npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
                                    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                    npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                                    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                    npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                    npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                    npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                                    npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                                    npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                    npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                    npm WARN deprecated phantomjs-prebuilt@2.1.16: this package is now deprecated
                                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
                                    npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
                                    added 6 packages, and changed 1963 packages in 15m
                                    176 packages are looking for funding
                                      run `npm fund` for details
                                    iobroker@iobroker:/opt/iobroker$ npm fund
                                    iobroker.inst@2.0.3
                                    ├── https://github.com/sponsors/jaredhanson
                                    │   └── passport@0.5.3
                                    ├── https://github.com/sponsors/RubenVerborgh
                                    │   └── follow-redirects@1.15.3
                                    ├── https://github.com/sponsors/ljharb
                                    │   └── qs@6.11.0, side-channel@1.0.4, call-bind@1.0.5, function-bind@1.1.2, gopd@1.0.1, has-property-descriptors@1.0.1, get-intrinsic@1.2.2, has-proto@1.0.1, has-symbols@1.0.3, object-inspect@1.13.1, is-arguments@1.1.1, has-tostringtag@1.0.0, is-generator-function@1.0.10, is-typed-array@1.1.12, which-typed-array@1.1.13, available-typed-arrays@1.0.5, is-callable@1.2.7, resolve@1.22.8, is-core-module@2.13.1, supports-preserve-symlinks-flag@1.0.0, minimist@1.2.8, is-nan@1.3.2, define-properties@1.2.1, object-is@1.1.5, traverse@0.6.7, is-object@1.0.2, deep-equal@1.1.2, is-date-object@1.0.5, is-regex@1.1.4, regexp.prototype.flags@1.5.1, functions-have-names@1.2.3, object.assign@4.1.4
                                    ├── https://github.com/sponsors/feross
                                    │   └── safe-buffer@5.2.1, base64-js@1.5.1, ieee754@1.2.1, simple-concat@1.0.1, buffer@6.0.3, run-parallel@1.2.0, queue-microtask@1.2.3
                                    ├── https://github.com/sponsors/broofa
                                    │   └── uuid@9.0.1
                                    ├── https://github.com/sponsors/sindresorhus
                                    │   └── is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, component-emitter@1.3.1, make-dir@3.1.0, mimic-response@2.1.0, onetime@5.1.2, multimatch@5.0.0, throttleit@1.0.1, sort-keys@4.2.0, p-limit@2.3.0, p-queue@6.6.2, any-observable@0.5.1, del@6.1.1, globby@11.1.0, p-map@4.0.0, escape-goat@3.0.0, escape-string-regexp@4.0.0, import-local@3.1.0, is-installed-globally@0.3.2, global-dirs@2.1.0, log-symbols@4.1.0, is-unicode-supported@0.1.0, meow@8.1.2, camelcase-keys@6.2.2, map-obj@4.3.0, decamelize-keys@1.1.1, type-fest@0.18.1, npm-name@6.0.1, p-event@4.2.0, type-fest@0.10.0, is-url-superb@4.0.0, open@7.4.2, is-docker@2.2.1, ow@0.21.0, dot-prop@6.0.1, type-fest@0.20.2, p-settle@4.1.1, read-pkg-up@7.0.1, terminal-link@2.1.1, boxen@5.1.2, camelcase@6.3.0, cli-boxes@2.2.1, is-installed-globally@0.4.0, global-dirs@3.0.1, is-npm@5.0.0, import-fresh@3.3.0, parse-json@5.2.0, ansi-escapes@4.3.2, type-fest@0.21.3, figures@3.2.0, find-up@5.0.0, locate-path@6.0.0, p-locate@5.0.0, p-limit@3.1.0, yocto-queue@0.1.0, hex-rgb@4.3.0
                                    ├─┬ https://github.com/sindresorhus/got?sponsor=1
                                    │ │ └── got@11.8.6, got@10.7.0
                                    │ └── https://github.com/sindresorhus/is?sponsor=1
                                    │     └── @sindresorhus/is@4.6.0, @sindresorhus/is@2.1.1
                                    ├── https://github.com/sponsors/epoberezkin
                                    │   └── ajv@6.12.6
                                    ├── https://github.com/sponsors/NaturalIntelligence
                                    │   └── fast-xml-parser@4.3.2
                                    ├── https://github.com/sponsors/isaacs
                                    │   └── minimatch@9.0.3, rimraf@3.0.2, glob@7.2.3
                                    ├─┬ https://opencollective.com/node-fetch
                                    │ │ └── node-fetch@3.3.2
                                    │ └── https://github.com/sponsors/jimmywarting
                                    │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                                    ├── https://opencollective.com/serialport/donate
                                    │   └── serialport@10.5.0, @serialport/bindings-cpp@10.8.0, @serialport/parser-byte-length@10.5.0, @serialport/parser-cctalk@10.5.0, @serialport/parser-delimiter@10.5.0, @serialport/parser-inter-byte-timeout@10.5.0, @serialport/parser-readline@10.5.0, @serialport/parser-ready@10.5.0, @serialport/parser-regex@10.5.0, @serialport/parser-slip-encoder@10.5.0, @serialport/parser-spacepacket@10.5.0, @serialport/stream@10.5.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-delimiter@12.0.0, @serialport/stream@12.0.0
                                    ├── https://www.buymeacoffee.com/systeminfo
                                    │   └── systeminformation@5.21.17
                                    ├── https://opencollective.com/date-fns
                                    │   └── date-fns@2.30.0
                                    ├── https://opencollective.com/ioredis
                                    │   └── ioredis@4.28.5
                                    ├── https://github.com/sindresorhus/execa?sponsor=1
                                    │   └── execa@5.1.1
                                    ├─┬ https://paulmillr.com/funding/
                                    │ │ └── chokidar@3.5.3
                                    │ └── https://github.com/sponsors/jonschlinkert
                                    │     └── picomatch@2.3.1, set-value@4.1.0
                                    ├── https://github.com/sponsors/sibiraj-s
                                    │   └── ci-info@3.9.0
                                    ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                    │ │ └── wrap-ansi@7.0.0
                                    │ └── https://github.com/chalk/ansi-styles?sponsor=1
                                    │     └── ansi-styles@4.3.0
                                    ├── https://opencollective.com/browserslist
                                    │   └── browserslist@4.22.1, caniuse-lite@1.0.30001563, update-browserslist-db@1.0.13
                                    ├── https://opencollective.com/core-js
                                    │   └── core-js@3.33.3, core-js-compat@3.33.3
                                    ├─┬ https://opencollective.com/javascript-obfuscator
                                    │ │ └── javascript-obfuscator@3.2.7
                                    │ └── https://github.com/chalk/chalk?sponsor=1
                                    │     └── chalk@4.1.2
                                    ├── https://github.com/sponsors/wooorm
                                    │   └── levenshtein-edit-distance@2.0.5
                                    ├── https://opencollective.com/js-sdsl
                                    │   └── js-sdsl@4.3.0
                                    └─┬ https://github.com/sindresorhus/np?sponsor=1
                                      │ └── np@7.7.0
                                      ├── https://github.com/sindresorhus/p-memoize?sponsor=1
                                      │   └── p-memoize@4.0.4
                                      └── https://github.com/yeoman/update-notifier?sponsor=1
                                          └── update-notifier@5.1.0
                                    • W wolkenloser
                                      iobroker.inst@2.0.3
                                      │   └── uuid@9.0.1
                                      │   └── ajv@6.12.6
                                      │   └── execa@5.1.1
                                      │   └── ci-info@3.9.0
                                      │     └── chalk@4.1.2
                                      │   └── js-sdsl@4.3.0
                                        │ └── np@7.7.0
                                      W Offline
                                      W Offline
                                      wolkenloser
                                      Die Web Oberfläche klappt wieder , ENERGIEFLUSS läßt sich deinstallieren.
                                      Dann bleibt noch der fronius
                                      • W wolkenloser
                                        W Offline
                                        W Offline
                                        wolkenloser
                                        Kurzes Status Update.
                                        Ich update gerade 30 Adapter, pro Adapter dauert es anscheinend mehr als 5 Minuten.
                                        • W wolkenloser
                                          @wolkenloser
                                          Ja, das ist möglich.
