  4. keine Geräte im Zigbee Adapter [gelöst - Vielen Dank]
zigbee-adapter
61 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
  • W wolkenloser
    @thomas-braun sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
    iob update
    Mein System hab ich 2019 aufgesetzt.
    ICh wäre froh wenn das mal "bereinigt ist.
    Aber mein Linux Wissen ist leider begrenzt....
    iob update
    Used repository: stable
    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
    Adapter    "backitup"     : 2.8.7    , installed 2.9.3
    Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
    Adapter    "bydhvs"       : 1.4.0    , installed 1.5.0
    Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.11
    Adapter    "device-reminder": 3.0.0  , installed 1.2.9  [Updatable]
    Adapter    "discovery"    : 4.2.0    , installed 3.2.0  [Updatable]
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "echarts"      : 1.5.4    , installed 1.0.12 [Updatable]
    Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
    Adapter    "fronius"      : 2.0.2    , installed 2.0.2
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "harmony"      : 1.2.2    , installed 1.3.0
    Adapter    "history"      : 3.0.1    , installed 2.2.6  [Updatable]
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Controller "js-controller": 5.0.16   , installed 4.0.24 [Updatable]
    Adapter    "knx"          : 2.0.23   , installed 2.0.13 [Updatable]
    Adapter    "lg-thinq"     : 0.1.4    , installed 0.1.4
    Adapter    "lgtv"         : 2.1.2    , installed 1.1.12 [Updatable]
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 4.1.0    , installed 3.8.6  [Updatable]
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "openweathermap": 0.4.5   , installed 0.3.11 [Updatable]
    Adapter    "parser"       : 2.0.7    , installed 1.3.2  [Updatable]
    Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "pvforecast"   : 2.9.0    , installed 2.7.1  [Updatable]
    Adapter    "sayit"        : 3.0.5    , installed 1.13.0 [Updatable]
    Adapter    "schwoerer-ventcube": 1.4.2, installed 1.4.2
    Adapter    "shelly"       : 6.6.1    , installed 6.0.0  [Updatable]
    Adapter    "shuttercontrol": 1.6.2   , installed 1.6.3
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.5    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.0.3    , installed 2.5.7  [Updatable]
    Adapter    "tankerkoenig" : 3.3.7    , installed 2.1.1  [Updatable]
    Adapter    "trashschedule": 2.3.0    , installed 2.0.3  [Updatable]
    Adapter    "tuya"         : 3.14.2   , installed 3.9.4  [Updatable]
    Adapter    "unifi"        : 0.6.6    , installed 0.5.10 [Updatable]
    Adapter    "vis-canvas-gauges": 1.0.1, installed 0.1.5  [Updatable]
    Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
    Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "wled"         : 0.7.1    , installed 0.6.7  [Updatable]
    Adapter    "ws"           : 2.5.8    , installed 1.3.0  [Updatable]
    Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
    iob upgrade all
    This upgrade of "ws" will at least introduce the following changes:
    -> 2.5.8:
    Corrected adapter termination if the alias has no target
    -> 2.5.7:
    upgraded socket-classes to fix vis problems
    -> 2.5.6:
    upgraded socket-classes to correct the error by unsubscribing on client disconnect
    -> 2.5.5:
    upgraded socket-classes to fix crash cases
    -> 2.5.4:
    added missing node16 requirement
    -> 2.5.3:
    Added the subscribing on the specific instance messages
    -> 2.4.0:
    (bluefox) extended the getObjects function with the possibility to read the list of IDs
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade ws from @1.3.0 to @2.5.8 now? [(y)es, (n)o]:
    @wolkenloser
    Dann hau die Updates rein.
    Und warum ist da kein admin installiert?
    W 1 Antwort Letzte Antwort
    • W wolkenloser
      iob update
      iob update
      iob upgrade all
      -> 2.5.8:
      -> 2.5.7:
      -> 2.5.6:
      -> 2.5.5:
      -> 2.5.4:
      -> 2.5.3:
      -> 2.4.0:
      W Offline
      W Offline
      wolkenloser
      Ich hab mal y gewählt.... jetzt Installiert er....
      • W wolkenloser
        W Offline
        W Offline
        wolkenloser
        schrieb am zuletzt editiert von wolkenloser
        Anscheinden dauert das ein Weilchen:
          @wolkenloser
          W Offline
          W Offline
          wolkenloser
          @wolkenloser
          Kann ich nicht sagen....
          Hat aber heute Nachmittag noch funktioniert..
          Er hat jetzt erst drei Updates installier.....
          • W wolkenloser
            @wolkenloser
            W Offline
            W Offline
            wolkenloser
            was kann ich denn jetzt machen um den Admin wieder hinzuzufügen......?
            • W wolkenloser
              @wolkenloser
              iob add admin
                @wolkenloser
                iob add admin
                W Offline
                W Offline
                wolkenloser
                iob add admin
                bis hier schon mal ein großes Dankeschönfür den Support.
                Ich kann erst morgen weitermachen.
                • W Offline
                  W Offline
                  wolkenloser
                  ich aber Ich habe die Updates gemacht, bei den Adaptern habe kein Chance, schon beim ersten schlägt das Fehl, sowohl über die Konsole und auch über die WEB Oberfläche.
                  Dann habe ich noch gesehen das es ein Host Update gibt, das habe ich auch gemacht.
                  Damnach war dann alles auf aktuellstem Stand bis auf die 23 Adapter.
                  Im Endergebnis läuft der IOBROKER gar nicht mehr.
                  Wennn ich nach dem reboot nach 5 Minuten iob start all eingebe kommt eine Meldung
                  iob start all
                  iob status
                  iobroker is not running on this host.
                  Ich habe jetzt den Snapshot von gesten abend wieder eingespielt.
                  Das letzte was ich danach versucht habe war das Update vom Host gemäß Anleitung
                  Danach hab ich keinen IOBROKER mehr :-(
                  • W wolkenloser
                    iob start all
                    iob status
                    @wolkenloser
                    Meldungen im Logfile?
                    iob diag
                    in der Langfassung sagt?
                      @wolkenloser
                      iob diag
                      W Offline
                      W Offline
                      wolkenloser
                      Mehr als 1000 Zeilen, muss ich splitten
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                         Static hostname: iobroker
                               Icon name: computer-vm
                                 Chassis: vm
                          Virtualization: microsoft
                        Operating System: Ubuntu 20.04.6 LTS
                                  Kernel: Linux 5.4.0-166-generic
                            Architecture: x86-64
                      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                      Docker          : false
                      Virtualization  : microsoft
                      Kernel          : x86_64
                      Userland        : amd64
                      Systemuptime and Load:
                       12:00:09 up 25 min,  1 user,  load average: 0.44, 0.64, 1.09
                      CPU threads: 2
                      *** Time and Time Zones ***
                                     Local time: Mon 2023-11-20 12:00:10 CET
                                 Universal time: Mon 2023-11-20 11:00:10 UTC
                                       RTC time: Mon 2023-11-20 11:00:11
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      iobroker
                      /home/iobroker
                      iobroker adm tty dialout cdrom sudo audio dip video plugdev lxd
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           3.9G        2.7G        119M        1.0M        1.1G        1.1G
                      Swap:          2.0G        3.0M        2.0G
                      Total:         5.9G        2.7G        2.1G
                               3919 M total memory
                               2689 M used memory
                               2743 M active memory
                                726 M inactive memory
                                119 M free memory
                                145 M buffer memory
                                965 M swap cache
                               1969 M total swap
                                  3 M used swap
                               1966 M free swap
                      *** FAILED SERVICES ***
                        UNIT           LOAD   ACTIVE SUB    DESCRIPTION
                      * fstrim.service loaded failed failed Discard unused blocks on filesystems from /etc/fstab
                      1 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.9G     0  1.9G   0% /dev
                      tmpfs          tmpfs     392M  1.1M  391M   1% /run
                      /dev/sda2      ext4       50G   34G   13G  73% /
                      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs          tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
                      /dev/loop0     squashfs  106M  106M     0 100% /snap/core/16091
                      /dev/loop1     squashfs  106M  106M     0 100% /snap/core/16202
                      /dev/loop3     squashfs   56M   56M     0 100% /snap/core18/2796
                      /dev/loop2     squashfs   56M   56M     0 100% /snap/core18/2790
                      /dev/loop5     squashfs   64M   64M     0 100% /snap/core20/2015
                      /dev/loop6     squashfs   92M   92M     0 100% /snap/lxd/23991
                      /dev/loop7     squashfs   92M   92M     0 100% /snap/lxd/24061
                      /dev/loop8     squashfs  128K  128K     0 100% /snap/ncdu/62
                      /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
                      /dev/loop10    squashfs  4.3M  4.3M     0 100% /snap/tree/18
                      /dev/loop9     squashfs  128K  128K     0 100% /snap/ncdu/64
                      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                      [sudo] password for iobroker:
                      [Mon Nov 20 11:34:45 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                      [Mon Nov 20 11:35:02 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
                      TARGET                SOURCE      FSTYPE   OPTIONS
                      /                     /dev/sda2   ext4     rw,relatime
                      |-/sys/kernel/tracing tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
                      |-/snap/core/16091    /dev/loop0  squashfs ro,nodev,relatime
                      |-/snap/core/16202    /dev/loop1  squashfs ro,nodev,relatime
                      |-/snap/core18/2796   /dev/loop3  squashfs ro,nodev,relatime
                      |-/snap/core18/2790   /dev/loop2  squashfs ro,nodev,relatime
                      |-/snap/core20/2015   /dev/loop5  squashfs ro,nodev,relatime
                      |-/snap/lxd/23991     /dev/loop6  squashfs ro,nodev,relatime
                      |-/snap/lxd/24061     /dev/loop7  squashfs ro,nodev,relatime
                      |-/snap/ncdu/62       /dev/loop8  squashfs ro,nodev,relatime
                      |-/snap/core20/1974   /dev/loop4  squashfs ro,nodev,relatime
                      |-/snap/tree/18       /dev/loop10 squashfs ro,nodev,relatime
                      `-/snap/ncdu/64       /dev/loop9  squashfs ro,nodev,relatime
                      /var:
                      5.6G    /var/
                      4.1G    /var/log
                      4.0G    /var/log/journal/4c4f1c196fd742fb8ea78816d6e03b15
                      1.5G    /var/lib
                      Archived and active journals take up 3.9G in the file system.
                      /opt/iobroker/backups:
                      12M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      17G     /opt/iobroker/iobroker-data/
                      16G     /opt/iobroker/iobroker-data/history
                      650M    /opt/iobroker/iobroker-data/files
                      170M    /opt/iobroker/iobroker-data/files/javascript.admin
                      158M    /opt/iobroker/iobroker-data/backup-objects
                      39M     /opt/iobroker/iobroker-data/objects.jsonl
                      12M     /opt/iobroker/iobroker-data/states.jsonl
                      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/12.1aeaa68b.chunk.js.map
                      9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
                      9.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.17.1
                      /home/iobroker/.nvm/versions/node/v18.9.0/bin/node              v18.9.0
                      /home/iobroker/.nvm/versions/node/v18.9.0/bin/npm               8.19.1
                      /home/iobroker/.nvm/versions/node/v18.9.0/bin/npx               8.19.1
                      /home/iobroker/.nvm/versions/node/v18.9.0/bin/corepack  0.14.0
                      *** nodejs is NOT correctly installed ***
                      nodejs:
                        Installed: 18.17.1-deb-1nodesource1
                        Candidate: 18.17.1-deb-1nodesource1
                        Version table:
                       *** 18.17.1-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_18.x focal/main amd64 Packages
                           10.19.0~dfsg-3ubuntu1.2 500
                              500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                              500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                           10.19.0~dfsg-3ubuntu1 500
                              500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
                      No problems detected
                      • W wolkenloser
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                   Chassis: vm
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                        CPU threads: 2
                                      NTP service: active
                                  RTC in local TZ: no
                        iobroker
                        /home/iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                                 3919 M total memory
                                 2689 M used memory
                                  119 M free memory
                                  145 M buffer memory
                                  965 M swap cache
                                 1969 M total swap
                                    3 M used swap
                                 1966 M free swap
                        *** FILESYSTEM ***
                        /var:
                        5.6G    /var/
                        4.1G    /var/log
                        1.5G    /var/lib
                        USB-Devices by-id:
                        nodejs:
                          Version table:
                        W Offline
                        W Offline
                        wolkenloser
                        Dann ganz viele hiervon, und das ist nur die Hälfte
                        Errors in npm tree:
                        npm ERR! code ELSPROBLEMS
                        npm ERR! extraneous: @types/caseless@0.12.4 /opt/iobroker/node_modules/@types/caseless
                        npm ERR! extraneous: @types/request@2.48.11 /opt/iobroker/node_modules/@types/request
                        npm ERR! extraneous: @types/tough-cookie@4.0.4 /opt/iobroker/node_modules/@types/tough-cookie
                        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                        npm ERR! invalid: iobroker.energiefluss@3.6.0 /opt/iobroker/node_modules/iobroker.energiefluss
                        npm ERR! invalid: iobroker.fronius@2.0.2 /opt/iobroker/node_modules/iobroker.fronius
                        npm ERR! invalid: iobroker.labcom@0.1.1 /opt/iobroker/node_modules/iobroker.labcom
                        npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
                        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                        npm ERR! extraneous: @aashutoshrathi/word-wrap@1.2.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
                        npm ERR! extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
                        npm ERR! extraneous: @alcalzone/release-script-core@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
                        npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
                        npm ERR! extraneous: @alcalzone/release-script-plugin-exec@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
                        npm ERR! extraneous: @alcalzone/release-script-plugin-git@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
                        npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
                        npm ERR! extraneous: @alcalzone/release-script-plugin-license@3.5.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
                        npm ERR! extraneous: @alcalzone/release-script-plugin-package@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
                        npm ERR! extraneous: @alcalzone/release-script-plugin-version@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
                        npm ERR! extraneous: @alcalzone/release-script@3.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                        npm ERR! extraneous: @eslint-community/eslint-utils@4.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                        npm ERR! extraneous: @eslint-community/regexpp@4.10.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                        npm ERR! extraneous: @eslint/eslintrc@2.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrcnpm ERR! extraneous: @eslint/js@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                        npm ERR! extraneous: @humanwhocodes/config-array@0.11.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                        npm ERR! extraneous: @humanwhocodes/module-importer@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                        npm ERR! extraneous: @humanwhocodes/object-schema@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                        npm ERR! extraneous: @iobroker/dev-server@0.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
                        npm ERR! extraneous: @iobroker/testing@4.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
                        npm ERR! extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                        npm ERR! extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.statnpm ERR! extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walknpm ERR! extraneous: @sinonjs/commons@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commonsnpm ERR! extraneous: @sinonjs/fake-timers@9.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
                        npm ERR! extraneous: @sinonjs/samsam@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
                        npm ERR! extraneous: @sinonjs/text-encoding@0.7.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
                        npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
                        npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
                        npm ERR! extraneous: @types/cors@2.8.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
                        npm ERR! extraneous: @types/expect@1.20.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                        npm ERR! extraneous: @types/http-proxy@1.17.13 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
                        npm ERR! extraneous: @types/vinyl@2.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                        npm ERR! extraneous: @ungap/structured-clone@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@ungap/structured-clone
                        npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
                        npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
                        npm ERR! extraneous: acorn-globals@1.0.9 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
                        npm ERR! extraneous: acorn-jsx@5.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                        npm ERR! extraneous: acorn@8.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                        npm ERR! extraneous: alcalzone-shared@4.0.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-sharednpm ERR! extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
                        npm ERR! extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                        npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                        npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                        npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                        npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                        npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                        npm ERR! extraneous: append-buffer@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                        npm ERR! extraneous: archy@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                        npm ERR! extraneous: argparse@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                        npm ERR! extraneous: arr-diff@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                        npm ERR! extraneous: arr-filter@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                        npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                        npm ERR! extraneous: arr-map@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                        npm ERR! extraneous: arr-union@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                        npm ERR! extraneous: array-each@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                        npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
                        npm ERR! extraneous: array-initial@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                        npm ERR! extraneous: array-last@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                        npm ERR! extraneous: array-slice@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                        npm ERR! extraneous: array-sort@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                        npm ERR! extraneous: array-unique@0.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                        npm ERR! extraneous: assertion-error@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                        npm ERR! extraneous: assign-symbols@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                        npm ERR! extraneous: astral-regex@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
                        npm ERR! extraneous: async-done@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                        npm ERR! extraneous: async-each-series@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
                        npm ERR! extraneous: async-each@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                        npm ERR! extraneous: async-settle@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                        npm ERR! extraneous: async@2.6.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
                        npm ERR! extraneous: atob@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                        npm ERR! extraneous: bach@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                        npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                        npm ERR! extraneous: base@0.11.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                        npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
                        npm ERR! extraneous: batch@0.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
                        npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                        npm ERR! extraneous: binaryextensions@2.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensionsnpm ERR! extraneous: body-parser@1.20.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
                        npm ERR! extraneous: boxen@5.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
                        npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                        npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                        npm ERR! extraneous: browser-request@0.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
                        npm ERR! extraneous: browser-stdout@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                        npm ERR! extraneous: browser-sync-client@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
                        npm ERR! extraneous: browser-sync-ui@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
                        npm ERR! extraneous: browser-sync@2.29.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
                        npm ERR! extraneous: bs-html-injector@3.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injectornpm ERR! extraneous: bs-recipes@1.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
                        npm ERR! extraneous: buffer-equal@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                        npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                        npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
                        npm ERR! extraneous: cache-base@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                        npm ERR! extraneous: call-bind@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
                        npm ERR! extraneous: callsites@3.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                        npm ERR! extraneous: camelcase@6.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                        npm ERR! extraneous: chai-as-promised@7.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promisednpm ERR! extraneous: chai@4.3.10 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                        npm ERR! extraneous: chalk@4.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                        npm ERR! extraneous: check-error@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                        npm ERR! extraneous: chokidar@3.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                        npm ERR! extraneous: class-utils@0.3.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                        npm ERR! extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
                        npm ERR! extraneous: cliui@8.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                        npm ERR! extraneous: clone-buffer@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                        npm ERR! extraneous: clone-stats@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                        npm ERR! extraneous: clone@2.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                        npm ERR! extraneous: cloneable-readable@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                        npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                        npm ERR! extraneous: collection-map@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                        npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visitnpm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                        npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                        npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                        npm ERR! extraneous: colors@1.4.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
                        npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
                        npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                        npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                        npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                        npm ERR! extraneous: connect-history-api-fallback@1.6.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
                        npm ERR! extraneous: connect@3.6.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
                        npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
                        npm ERR! extraneous: content-type@1.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
                        npm ERR! extraneous: convert-source-map@1.9.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                        npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signaturenpm ERR! extraneous: cookie@0.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
                        npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                        npm ERR! extraneous: copy-props@2.0.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                        npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
                        npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                        npm ERR! extraneous: cssom@0.3.8 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
                        npm ERR! extraneous: cssstyle@0.2.37 /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
                        npm ERR! extraneous: d@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                        npm ERR! extraneous: decamelize@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                        npm ERR! extraneous: decode-uri-component@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                        npm ERR! extraneous: deep-eql@4.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                        npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                        npm ERR! extraneous: default-compare@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                        npm ERR! extraneous: default-resolution@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                        npm ERR! extraneous: define-data-property@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
                        npm ERR! extraneous: define-properties@1.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
                        npm ERR! extraneous: define-property@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                        npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
                        npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
                        npm ERR! extraneous: detect-file@1.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                        npm ERR! extraneous: dev-ip@1.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
                        npm ERR! extraneous: diff@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                        npm ERR! extraneous: doctrine@3.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                        npm ERR! extraneous: dom-compare-temp@0.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-tempnpm ERR! extraneous: dom-serializer@0.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
                        npm ERR! extraneous: domelementtype@1.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
                        npm ERR! extraneous: domhandler@2.4.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
                        npm ERR! extraneous: domutils@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
                        npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
                        npm ERR! extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                        npm ERR! extraneous: each-props@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                        npm ERR! extraneous: easy-extender@2.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
                        npm ERR! extraneous: eazy-logger@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
                        npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
                        npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                        npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
                        npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                        npm ERR! extraneous: engine.io-client@6.5.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-clientnpm ERR! extraneous: engine.io-parser@5.2.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parsernpm ERR! extraneous: engine.io@6.5.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
                        npm ERR! extraneous: enquirer@2.4.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                        npm ERR! extraneous: entities@1.1.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
                        npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                        npm ERR! extraneous: es5-ext@0.10.62 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                        npm ERR! extraneous: es6-iterator@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                        npm ERR! extraneous: es6-symbol@3.1.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                        npm ERR! extraneous: es6-weak-map@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                        npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                        npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
                        npm ERR! extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                        npm ERR! extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
                        npm ERR! extraneous: eslint-scope@7.2.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                        npm ERR! extraneous: eslint-visitor-keys@3.4.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                        npm ERR! extraneous: eslint@8.53.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                        npm ERR! extraneous: espree@9.6.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                        npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
                        npm ERR! extraneous: esquery@1.5.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                        npm ERR! extraneous: esrecurse@4.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                        npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                        npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                        npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
                        npm ERR! extraneous: event-stream@3.3.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
                        npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
                        npm ERR! extraneous: execa@5.1.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                        npm ERR! extraneous: expand-brackets@2.1.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                        npm ERR! extraneous: expand-tilde@2.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                        npm ERR! extraneous: express@4.18.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
                        npm ERR! extraneous: ext@1.7.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                        npm ERR! extraneous: extend-shallow@3.0.2 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                        npm ERR! extraneous: extglob@2.0.4 /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                        npm ERR! extraneous: fancy-log@1.3.3 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                        npm ERR! extraneous: fast-glob@3.3.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                        npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshteinnpm ERR! extraneous: fastq@1.15.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                        npm ERR! extraneous: file-entry-cache@6.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cachenpm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                        npm ERR! extraneous: finalhandler@1.1.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
                        npm ERR! extraneous: find-up@5.0.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                        • W wolkenloser
                          Errors in npm tree:
                          W Offline
                          W Offline
                          wolkenloser
                          Hier der Rest...
                          npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_09_978Z-debug-0.log
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Core adapters versions
                          js-controller:  4.0.24
                          admin:          6.2.23
                          javascript:     6.2.0
                          npm ERR!     /home/iobroker/.npm/_logs/2023-11-20T11_01_43_451Z-debug-0.log
                          Adapters from github:   3
                          Adapter State
                            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                            system.adapter.easee.0                  : easee                 : iobroker                                 - disabled
                          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                          + system.adapter.fakeroku.0               : fakeroku              : iobroker                                 -  enabled
                            system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled
                          + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                            system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                          + system.adapter.history.0                : history               : iobroker                                 -  enabled
                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                          + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.8.67
                            system.adapter.labcom.0                 : labcom                : iobroker                                 - disabled
                          + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                            system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                          + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                          + system.adapter.onkyo.0                  : onkyo                 : iobroker                                 -  enabled
                            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                            system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                            system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
                          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                          + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                            system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, port: 0
                          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                            system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                          + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                            system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
                            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                          + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Adapter    "admin"        : 6.12.0   , installed 6.2.23 [Updatable]
                          Adapter    "backitup"     : 2.8.7    , installed 2.9.1
                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                          Adapter    "javascript"   : 7.1.4    , installed 6.2.0  [Updatable]
                          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.90.0 [Updatable]
                          Adapter    "web"          : 6.1.10   , installed 4.3.0  [Updatable]
                          Objects and States
                          Objects:        11799
                          States:         10540
                          Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
                          Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                          Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                          Hit:4 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
                          Hit:5 https://deb.nodesource.com/node_18.x focal InRelease
                          Reading package lists...
                          Pending Updates: 15
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       35070      2326/io.shelly.0
                          tcp        0      0 192.168.8.67:9093       0.0.0.0:*               LISTEN      1000       35419      2573/io.fakeroku.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       32795      1756/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       32532      1756/iobroker.js-co
                          tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          28197      1027/perl
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        21935      641/systemd-resolve
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25514      811/sshd: /usr/sbin
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        31602      1777/influxd
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34927      2333/io.sonoff.0
                          tcp6       0      0 :::61991                :::*                    LISTEN      1000       36326      2653/io.harmony.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34086      2132/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       37649      2882/io.web.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        32766      1777/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          25516      811/sshd: /usr/sbin
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       37894      3013/io.simple-api.
                          tcp6       0      0 :::3000                 :::*                    LISTEN      111        27368      783/grafana-server
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       37506      2935/io.wled.0
                          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          28198      1027/perl
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       35420      2573/io.fakeroku.0
                          udp        0      0 192.168.8.67:53249      0.0.0.0:*                           1000       35708      2690/io.knx.0
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        21934      641/systemd-resolve
                          udp        0      0 192.168.8.67:68         0.0.0.0:*                           100        21920      635/systemd-network
                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       35977      2473/io.mihome-vacu
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       36336      2494/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       36337      2494/io.tuya.0
                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       36327      2653/io.harmony.0
                          udp6       0      0 fe80::11:32ff:fe2d::546 :::*                                100        20383      635/systemd-network
                          2023-11-20 12:02:11.075  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:11+00:00"}}
                          2023-11-20 12:02:40.671  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=MinMaxInverterData: {"Body":{"Data":{}},"Head":{"RequestArguments":{"DataCollection":"MinMaxInverterData","Scope":"Device"},"Status":{"Code":11,"Reason":"Parameter 'MinMaxInverterData' for attribute 'DataCollection' not supported. Use one of 'CumulationInverterData', 'CommonInverterData', '3PInverterData'.","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:40.683  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetMeterRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Current_AC_Phase_1":0.732,"Current_AC_Phase_2":-0.69,"Current_AC_Phase_3":1.231,"Current_AC_Sum":1.2730000000000001,"Details":{"Manufacturer":"Fronius","Model":"Smart Meter TS 65A-3","Serial":"1659699688"},"Enable":1,"EnergyReactive_VArAC_Sum_Consumed":787465,"EnergyReactive_VArAC_Sum_Produced":5086507,"EnergyReal_WAC_Minus_Absolute":7490523,"EnergyReal_WAC_Plus_Absolute":4746701,"EnergyReal_WAC_Sum_Consumed":4746701,"EnergyReal_WAC_Sum_Produced":7490523,"Frequency_Phase_Average":50,"Meter_Location_Current":0,"PowerApparent_S_Phase_1":54.5,"PowerApparent_S_Phase_2":151.6,"PowerApparent_S_Phase_3":195.1,"PowerApparent_S_Sum":401.4,"PowerFactor_Phase_1":0.714,"PowerFactor_Phase_2":-0.881,"PowerFactor_Phase_3":0.515,"PowerFactor_Sum":0.019,"PowerReactive_Q_Phase_1":-38.2,"PowerReactive_Q_Phase_2":-71.5,"PowerReactive_Q_Phase_3":-166.6,"PowerReactive_Q_Sum":-276.4,"PowerReal_P_Phase_1":38.9,"PowerReal_P_Phase_2":-133.6,"PowerReal_P_Phase_3":101.6,"PowerReal_P_Sum":6.8,"TimeStamp":1700478159,"Visible":1,"Voltage_AC_PhaseToPhase_12":410.1,"Voltage_AC_PhaseToPhase_23":411,"Voltage_AC_PhaseToPhase_31":406.1,"Voltage_AC_Phase_1":241.2,"Voltage_AC_Phase_2":230,"Voltage_AC_Phase_3":237.7}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:40.726  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetStorageRealtimeData.cgi?Scope=Device&DeviceId=0: {"Body":{"Data":{"Controller":{"Capacity_Maximum":10240,"Current_DC":1.2981114032990677,"DesignedCapacity":10240,"Details":{"Manufacturer":"BYD","Model":"BYD Battery-Box Premium HV","Serial":"P030T020Z2010263183     "},"Enable":1,"StateOfCharge_Relative":17.8,"Status_BatteryCell":3,"Temperature_Cell":12,"TimeStamp":1700478156,"Voltage_DC":418.3},"Modules":[]}},"Head":{"RequestArguments":{"DeviceId":"0","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:40.767  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetPowerFlowRealtimeData.fcgi: {"Body":{"Data":{"Inverters":{"1":{"Battery_Mode":"normal","DT":1,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"P":460.24041748046875,"SOC":17.8}},"SecondaryMeters":{},"Site":{"BackupMode":false,"BatteryStandby":true,"E_Day":null,"E_Total":23263193.850555554,"E_Year":null,"Meter_Location":"grid","Mode":"bidirectional","P_Akku":-666.0352783203125,"P_Grid":6.8,"P_Load":-467.79334716796876,"P_PV":1129.3310546875,"rel_Autonomy":98.54636667212833,"rel_SelfConsumption":100},"Smartloads":{"Ohmpilots":{}},"Version":"12"}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:40.769  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetOhmPilotRealtimeData.cgi?Scope=System: {"Body":{"Data":{}},"Head":{"RequestArguments":{"Scope":"System"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:40.773  - debug: fronius.0 (2593) API Objekt E_Day is null, object inverter.1.E_Day will be set to 0!
                          2023-11-20 12:02:40.782  - debug: fronius.0 (2593) API Objekt E_Year is null, object inverter.1.E_Year will be set to 0!2023-11-20 12:02:40.783  - debug: fronius.0 (2593) API Objekt E_Day is null, object site.E_Day will be set to 0!
                          2023-11-20 12:02:40.784  - debug: fronius.0 (2593) API Objekt E_Year is null, object site.E_Year will be set to 0!
                          2023-11-20 12:02:40.928  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterInfo.cgi: {"Body":{"Data":{"1":{"CustomName":"Sonnenstudio360","DT":1,"ErrorCode":1130,"InverterState":"Running","PVPower":11600,"Show":1,"StatusCode":7,"UniqueID":"31558765"}}},"Head":{"RequestArguments":{},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:41.004  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=CommonInverterData: {"Body":{"Data":{"DAY_ENERGY":{"Unit":"Wh","Value":null},"DeviceStatus":{"ErrorCode":1130,"InverterState":"Running","StatusCode":7},"FAC":{"Unit":"Hz","Value":50.00504684448242},"IAC":{"Unit":"A","Value":1.970382273197174},"IDC":{"Unit":"A","Value":1.233007550239563},"IDC_2":{"Unit":"A","Value":1.0074610710144043},"IDC_3":{"Unit":"A","Value":null},"IDC_4":{"Unit":"A","Value":null},"PAC":{"Unit":"W","Value":463.17767333984375},"SAC":{"Unit":"VA","Value":463.22857666015625},"TOTAL_ENERGY":{"Unit":"Wh","Value":23263193.850555554},"UAC":{"Unit":"V","Value":234.6595916748047},"UDC":{"Unit":"V","Value":528.879150390625},"UDC_2":{"Unit":"V","Value":555.4661254882812},"UDC_3":{"Unit":"V","Value":null},"UDC_4":{"Unit":"V","Value":null},"YEAR_ENERGY":{"Unit":"Wh","Value":null}}},"Head":{"RequestArguments":{"DataCollection":"CommonInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:40+00:00"}}
                          2023-11-20 12:02:41.041  - debug: fronius.0 (2593) Response to http://192.168.8.54/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceId=1&DataCollection=3PInverterData: {"Body":{"Data":{"IAC_L1":{"Unit":"A","Value":0.6535905599594116},"IAC_L2":{"Unit":"A","Value":0.6578454971313477},"IAC_L3":{"Unit":"A","Value":0.6589462161064148},"UAC_L1":{"Unit":"V","Value":234.55113220214844},"UAC_L2":{"Unit":"V","Value":236.23095703125},"UAC_L3":{"Unit":"V","Value":234.4892120361328}}},"Head":{"RequestArguments":{"DataCollection":"3PInverterData","DeviceId":"1","Scope":"Device"},"Status":{"Code":0,"Reason":"","UserMessage":""},"Timestamp":"2023-11-20T11:02:41+00:00"}}
                          2023-11-20 12:03:00.036  - warn: javascript.0 (2207) State "sonoff.0.WIFI-STECKDOSE-5.POWER" not found
                          2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1729:20)
                          2023-11-20 12:03:00.038  - warn: javascript.0 (2207)     at Object.<anonymous> (script.js.Heizung.Gartenhütte_Heizung:15:5)
                          2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1605:34)
                          2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Job.js:171:15)
                          2023-11-20 12:03:00.039  - warn: javascript.0 (2207)     at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:268:28
                          2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/Invocation.js:228:7)
                          2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at listOnTimeout (node:internal/timers:564:17)
                          2023-11-20 12:03:00.040  - warn: javascript.0 (2207)     at processTimers (node:internal/timers:507:7)
                          2023-11-20 12:03:00.040  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: 25.2
                          2023-11-20 12:03:00.041  - info: javascript.0 (2207) script.js.Heizung.Gartenhütte_Heizung: E-Heizung Gartenhütte - AUS
                          2023-11-20 12:03:02.105  - warn: sonoff.0 (2333) Client [] has invalid password or username
                          iob diag has finished.
                          Press any key for a summary
                          Thomas BraunT W 2 Antworten Letzte Antwort
                          • W wolkenloser
                            Hier der Rest...
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.2.23
                            javascript:     6.2.0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        11799
                            States:         10540
                            Pending Updates: 15
                            @wolkenloser
                            Dein nodejs ist noch schief.
                            Kratz das alles raus.
                            rm -rf /home/iobroker/.nvm
                            Danach
                            iob fix
                            iob nodejs-update
                            • W wolkenloser
                              Hier der Rest...
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.2.23
                              javascript:     6.2.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        11799
                              States:         10540
                              Pending Updates: 15
                              W Offline
                              W Offline
                              wolkenloser
                              Wie gesagt, die ganzen Updateable Adapters lassen sich nicht updaten.
                              Das Problem fing vor 2 Monaten an, als ich den Energiefluss Adapter installiert hatte....
                              • W wolkenloser
                                @wolkenloser sagte in keine Geräte im Zigbee Adapter - funktioniert aber.:
                                Nein, das fing damit an, dass du da per nvm ein nodejs 18.9.0 reingeklatscht hast...
                                  W Offline
                                  W Offline
                                  wolkenloser
                                  wie gesagt, ich bin auch nur Benutzer.
                                  Aber ich lerne gerne dazu, weil interessieren tut es mich ja.
                                  Man nennt das wohl auchg auch "gefährliches Halbwissen"
                                  Wenn das so ist wie Du es sagst habe ich das wohl aus irgendeiner Intention, oder wegen einer Anleitung im Internet gemacht.
                                  Der Energiefluss Adapter lies sich damals nicht über die Oberfläche installieren, dann hab ich gesucht wie es noch geht. Irgendwann war er drin.
                                  Ich versuch jetzzt das was Du oben geschrieben hast...
                                  Thomas BraunT 3 Antworten Letzte Antwort
                                  • W wolkenloser
                                    Was kann ich denn jetzt am besten machen ohne bei Null anzufangen ?
                                    Hab ich doch vor 15 Minuten oben geschrieben...
                                    Den Kram löschen und nodejs ordentlich installieren wäre schon mal ein erster Schritt.
                                    • W wolkenloser
                                      @wolkenloser
                                      Und schalt den
                                      debug: fronius.0
                                      aus. Der kübelt dir sonst zu viel in das Log rein.
                                      • W wolkenloser
                                        @wolkenloser
                                        Wenn nodejs sauber installiert ist und die ganzen npm-Fehler dann immer noch aufkreuzen:
                                        Installier mindestens diese drei Adapter nochmal:
                                        Sind alle über github und nicht 'ordentlich' installiert, oder?
                                          @wolkenloser
                                          W Offline
                                          W Offline
                                          wolkenloser
                                          Energiefluss auf jeden Fall
                                          den Labcom brauch ich nicht mehr den deinstalliere ich.
                                          Fronius ist mit am wichtigsten wegen diverser Scripte.... ich schau mal.
                                          Wenn ich den neu installiere sollten die Datenpunkte ja wieder so wie bisher aktualisiert werden.....
