  4. Test Adapter KNX v2.x
421 Beiträge 70 Kommentatoren 148.1k Aufrufe 62 Beobachtet
    blacksheep587
    #378
    Hallo Zusammen, ich habe seit einem Neustart meines RasPi das Problem, dass der KNX-Adapter nicht mehr startet.
    Folgende Logs werden angezeigt:
    2023-11-17 10:03:46.932  - debug: knx.0 (17897) States connected to redis: 127.0.0.1:9000
    2023-11-17 10:03:46.984  - debug: knx.0 (17897) Plugin sentry Initialize Plugin (enabled=true)
    2023-11-17 10:03:47.726  - info: knx.0 (17897) starting. Version 2.0.23 in /opt/iobroker/node_modules/iobroker.knx, node: v18.17.1, js-controller: 5.0.16
    2023-11-17 10:04:03.310  - warn: knx.0 (17897) stateChange: not ready
    2023-11-17 10:04:07.775  - info: knx.0 (17897) knx license is OK.
    2023-11-17 10:04:07.779  - info: knx.0 (17897) Connecting to knx GW: 192.168.178.100:3671 with phy. Adr: 1.0.7
    2023-11-17 10:04:08.165  - error: knx.0 (17897) uncaught exception: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.166  - error: knx.0 (17897) TypeError: Cannot read properties of null (reading 'val')
        at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
        at processImmediate (node:internal/timers:478:21)
    2023-11-17 10:04:08.167  - error: knx.0 (17897) Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.198  - error: knx.0 (17897) uncaught exception: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.200  - error: knx.0 (17897) TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.200  - error: knx.0 (17897) Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.203  - error: knx.0 (17897) uncaught exception: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.203  - error: knx.0 (17897) TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.204  - error: knx.0 (17897) Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.206  - error: knx.0 (17897) uncaught exception: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.207  - error: knx.0 (17897) TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.207  - error: knx.0 (17897) Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.211  - error: knx.0 (17897) uncaught exception: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.212  - error: knx.0 (17897) TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.212  - error: knx.0 (17897) Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.239  - debug: knx.0 (17897) Adapter close
    2023-11-17 10:04:08.240  - info: knx.0 (17897) terminating
    2023-11-17 10:04:08.241  - debug: knx.0 (17897) Plugin sentry destroyed
    2023-11-17 10:04:08.241  - warn: knx.0 (17897) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-11-17 10:04:08.758  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.758  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[2]: TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[2]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
    2023-11-17 10:04:08.759  - error: host.raspberrypi Caught by controller[2]:     at processImmediate (node:internal/timers:478:21)
    2023-11-17 10:04:08.760  - error: host.raspberrypi Caught by controller[3]: TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.760  - error: host.raspberrypi Caught by controller[3]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
    2023-11-17 10:04:08.760  - error: host.raspberrypi Caught by controller[3]:     at processImmediate (node:internal/timers:478:21)
    2023-11-17 10:04:08.760  - error: host.raspberrypi Caught by controller[4]: TypeError: Cannot read properties of null (reading 'val')
    2023-11-17 10:04:08.760  - error: host.raspberrypi Caught by controller[4]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
    2023-11-17 10:04:08.760  - error: host.raspberrypi Caught by controller[4]:     at processImmediate (node:internal/timers:478:21)
    2023-11-17 10:04:08.760  - error: host.raspberrypi instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-11-17 10:04:08.760  - info: host.raspberrypi Restart adapter system.adapter.knx.0 because enabled
    Kann mir jemand einen Tip geben, woran es liegen kann?
    Danke vielmals schon vorab!
    • B blacksheep587
      #379
      @blacksheep587 sagte in Test Adapter KNX v2.x:
      node: v18.17.1
      Auf die 18.18.2 bringen.
      iob stop
      iob fix
      iob nodejs-update
      Dann weiterschauen.
      B 2 Antworten Letzte Antwort
        node: v18.17.1
        iob stop
        iob fix
        iob nodejs-update
        Dann weiterschauen.
        blacksheep587
        #380
        ich hatte bis heute zum Restart noch 16.20.4 laufen und habe das Update nach dieser Vorgabe: https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18 gemacht. Die gezeigte 18.17.1 wurde dabei installiert.
        • B blacksheep587
          #381
          @blacksheep587
          Die Vorgehensweise ist veraltet.
            @blacksheep587
            #382
            @Dutchman @Homoran
            Bitte den Thread
            als veraltet kennzeichnen und für Debian & Co. auf 'iob nodejs-update' verweisen.
              node: v18.17.1
              iob stop
              iob fix
              iob nodejs-update
              Dann weiterschauen.
              blacksheep587
              #383
              @thomas-braun said in Test Adapter KNX v2.x:
              iob nodejs-update
              Done.
              Ergebnis ist leider das gleiche.
              P 1 Antwort Letzte Antwort
                @Dutchman @Homoran
                Bitte den Thread
                DutchmanD Offline
                DutchmanD Offline
                Dutchman
                #384
                @thomas-braun sagte in Test Adapter KNX v2.x:
                @Dutchman @Homoran
                Bitte den Thread
                hmm veraltet wuerde ich nicht sagen es ist die Variante ausserhalb des Job Befehl aber ja wir sollten den jetzt explizite benennen.
                werde bei Gelegenheit (heute mittag/morgen) den thread abändern und standard auf den Befehl verweisen die regulären Sachen sollten aber drin bleiben wuerde ich sagen.
                Werde es intern auch mal in der dev Gruppe nachfragen nach den Meinungen anderer dazu
                • DutchmanD Dutchman
                  @Dutchman @Homoran
                  Bitte den Thread
                  #385
                  @dutchman sagte in Test Adapter KNX v2.x:
                  Das Vorgehen führt aber in eine Sackgasse, weil das alte Repository von nodesource keine aktuellen Versionen mehr erhält. Deswegen ist das veraltet.
                  Siehe auch:
                  https://github.com/nodesource/distributions
                  Package Changes: DEB and RPM packages are now available under the nodistro codename. We no longer package the installer coupled to specific versions. This means you can install Node.js on almost any distro that meets the minimum requirements.
                  Eine angepasste Variante für Installationen 'zu Fuß' findet sich hier:
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                  • B blacksheep587
                    iob nodejs-update
                    Done.
                    peer69
                    Forum Testing
                    #386
                    @blacksheep587 Vielleicht hilft noch ein Rebuld des Adapters nach dem NodeJS Update? Sollte mit 'iobroker rebuild knx‘ angestoßen werden können.
                    • P peer69
                      blacksheep587
                      #387
                      @peer69 war leider auch nicht erfolgreich. Wenn ich eine neue Instanz hinzufüge, dann funktioniert diese. Die alte aber nachwievor nicht. Ich habe mal noch die Logstufe vom KNX-Adapter erweitert:
                      2023-11-17 12:34:08.811  - info: host.raspberrypi instance system.adapter.knx.0 started with pid 31285
                      2023-11-17 12:34:12.629  - debug: knx.0 (31285) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-11-17 12:34:12.708  - debug: knx.0 (31285) Objects client ready ... initialize now
                      2023-11-17 12:34:12.712  - debug: knx.0 (31285) Objects create System PubSub Client
                      2023-11-17 12:34:12.714  - debug: knx.0 (31285) Objects create User PubSub Client
                      2023-11-17 12:34:12.774  - debug: knx.0 (31285) Objects client initialize lua scripts
                      2023-11-17 12:34:12.785  - debug: knx.0 (31285) Objects connected to redis: 127.0.0.1:9001
                      2023-11-17 12:34:12.834  - debug: knx.0 (31285) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-11-17 12:34:12.853  - debug: knx.0 (31285) States create System PubSub Client
                      2023-11-17 12:34:12.855  - debug: knx.0 (31285) States create User PubSub Client
                      2023-11-17 12:34:12.932  - debug: knx.0 (31285) States connected to redis: 127.0.0.1:9000
                      2023-11-17 12:34:12.985  - debug: knx.0 (31285) Plugin sentry Initialize Plugin (enabled=true)
                      2023-11-17 12:34:13.795  - info: knx.0 (31285) starting. Version 2.0.23 in /opt/iobroker/node_modules/iobroker.knx, node: v18.18.2, js-controller: 5.0.16
                      2023-11-17 12:34:20.308  - info: host.raspberrypi stopInstance system.adapter.knx.0 (force=false, process=true)
                      2023-11-17 12:34:20.417  - info: knx.0 (31285) Got terminate signal TERMINATE_YOURSELF
                      2023-11-17 12:34:20.425  - info: host.raspberrypi stopInstance system.adapter.knx.0 send kill signal
                      2023-11-17 12:34:20.424  - debug: knx.0 (31285) Adapter close
                      2023-11-17 12:34:20.426  - info: knx.0 (31285) terminating
                      2023-11-17 12:34:20.427  - debug: knx.0 (31285) Plugin sentry destroyed
                      2023-11-17 12:34:20.428  - info: knx.0 (31285) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2023-11-17 12:34:20.930  - info: knx.0 (31285) terminating
                      2023-11-17 12:34:20.951  - error: knx.0 (31285) Cannot get objects: Error: Connection is closed.
                      2023-11-17 12:34:21.069  - info: host.raspberrypi instance system.adapter.knx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-11-17 12:34:23.688  - info: host.raspberrypi instance system.adapter.knx.0 started with pid 31300
                      2023-11-17 12:34:27.588  - debug: knx.0 (31300) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-11-17 12:34:27.662  - debug: knx.0 (31300) Objects client ready ... initialize now
                      2023-11-17 12:34:27.666  - debug: knx.0 (31300) Objects create System PubSub Client
                      2023-11-17 12:34:27.668  - debug: knx.0 (31300) Objects create User PubSub Client
                      2023-11-17 12:34:27.727  - debug: knx.0 (31300) Objects client initialize lua scripts
                      2023-11-17 12:34:27.737  - debug: knx.0 (31300) Objects connected to redis: 127.0.0.1:9001
                      2023-11-17 12:34:27.786  - debug: knx.0 (31300) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-11-17 12:34:27.806  - debug: knx.0 (31300) States create System PubSub Client
                      2023-11-17 12:34:27.808  - debug: knx.0 (31300) States create User PubSub Client
                      2023-11-17 12:34:27.888  - debug: knx.0 (31300) States connected to redis: 127.0.0.1:9000
                      2023-11-17 12:34:27.943  - debug: knx.0 (31300) Plugin sentry Initialize Plugin (enabled=true)
                      2023-11-17 12:34:28.821  - info: knx.0 (31300) starting. Version 2.0.23 in /opt/iobroker/node_modules/iobroker.knx, node: v18.18.2, js-controller: 5.0.16
                      2023-11-17 12:34:38.769  - warn: knx.0 (31300) stateChange: not ready
                      2023-11-17 12:34:40.283  - warn: knx.0 (31300) stateChange: not ready
                      2023-11-17 12:34:40.361  - warn: knx.0 (31300) stateChange: not ready
                      2023-11-17 12:34:49.161  - info: knx.0 (31300) knx license is OK.
                      2023-11-17 12:34:49.164  - info: knx.0 (31300) Connecting to knx GW: 192.168.178.100:3671 with phy. Adr: 1.0.7
                      2023-11-17 12:34:49.176  - info: knx.0 (31300) Debuglevel: 2    3
                      2023-11-17 12:34:49.182  - info: knx.0 (31300) Event : UDP - listening
                      2023-11-17 12:34:49.188  - info: knx.0 (31300) Connected  - local UDP Server listening on 192.168.178.59:51521
                      2023-11-17 12:34:49.192  - info: knx.0 (31300) Send : description Request :        06 10 02 03 00 0e 08 01 c0 a8 b2 3b c9 41        sent to 192.168.178.100:3671
                      2023-11-17 12:34:49.203  - info: knx.0 (31300) Send : searchReqExt Request :        06 10 02 0b 00 14 08 01 c0 a8 b2 3b c9 41 06 04 01 02 08 06        sent to 192.168.178.100:3671
                      2023-11-17 12:34:49.204  - info: knx.0 (31300)  STATE_SEARCH_EXT_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_RESPONSE(18) to STATE_SEARCH_EXT_REQUEST(19).
                      2023-11-17 12:34:49.209  - info: knx.0 (31300)  receiving descrExtResp
                      2023-11-17 12:34:49.211  - info: knx.0 (31300) Send : UDP Connection Request :        06 10 02 05 00 1a 08 01 c0 a8 b2 3b c9 41 08 01 00 00 00 00 c9 41 04 04 02 00        sent to 192.168.178.100:3671
                      2023-11-17 12:34:49.222  - info: knx.0 (31300) Received  CONNECTION_RESPONSE : 06 10 02 06 00 14 02 00 08 01 c0 a8 b2 64 0e 57 04 04 10 04    GW-IP: 192.168.178.100:3671 -  ChannelID: 2 cnt IN/OUT: 0/0
                      #Hier wurden dann diverse Datenpunkte erzeugt...
                      2023-11-17 12:34:49.306  - info: knx.0 (31300) Connected! :-)
                      2023-11-17 12:34:49.542  - info: knx.0 (31300)  Has todo still 309 tasks, just processing : false
                      2023-11-17 12:34:49.545  - info: knx.0 (31300) ( 1 ) Sending : GroupValueRead :   06 10 04 20 00 15 04 02 00 00 11 00 bc e0 10 07 38 01 01 00 00    sent to 192.168.178.100:3671  ChID: 2 SeqCntIN : 0 SeqCntOUT : 0 GA : 7/0/1 conCheck.conected : true
                      2023-11-17 12:34:49.547  - info: knx.0 (31300) easy-knx: task.data : 06 10 04 20 00 15 04 02 00 00 11 00 bc e0 10 07 38 01 01 00 00  byteLen : 21
                      2023-11-17 12:34:49.549  - info: knx.0 (31300) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 02 00 00    from 192.168.178.100:3671 SeqCntIN : 0 SeqCntOUT : 1 GA : 0/0/0
                      2023-11-17 12:34:49.550  - info: knx.0 (31300)  ==>  successful acknowledged previous package... processing next of 308
                      2023-11-17 12:34:49.551  - info: knx.0 (31300)  ==> easy-knx.js: signal runtime : 0s  7.266345ms
                      2023-11-17 12:34:49.552  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.587  - info: knx.0 (31300) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 02 00 00 2e 00 bc e0 10 07 38 01 01 00 00  was successfully processed by receiver.
                      2023-11-17 12:34:49.588  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.597  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 00 00   ChID : 2 SeqCntIN : 0 SeqCntOUT : 1 queue length : 308
                      2023-11-17 12:34:49.598  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.599  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.600  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 01 00 29 00 bc e0 10 1e 10 01 03 00 80 00 2e   ChID: 2
                      2023-11-17 12:34:49.607  - info: knx.0 (31300) WRITE : mappedName : Warmwasserzapftemperatur-soll    dest : 2/0/1  val: 46   (DPT7.000) Warmwasserzapftemperatur-soll
                      2023-11-17 12:34:49.610  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.612  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 01 00   ChID : 2 SeqCntIN : 1 SeqCntOUT : 1 queue length : 308
                      2023-11-17 12:34:49.612  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.613  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.622  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 02 00 29 00 bc e0 10 1e 10 0d 03 00 80 00 00   ChID: 2
                      2023-11-17 12:34:49.624  - info: knx.0 (31300) WRITE : mappedName : Waermepumpe Stoerung Puls    dest : 2/0/13  val: 0   (DPT7.001) Waermepumpe_Stoerung_Puls
                      2023-11-17 12:34:49.625  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.627  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 02 00   ChID : 2 SeqCntIN : 2 SeqCntOUT : 1 queue length : 308
                      2023-11-17 12:34:49.628  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.628  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.633  - info: knx.0 (31300) main.js :  tGA.write on Statechange : 2/0/51   P-032E-0_GA-1378  typeof val: number  5.475  DPT9.024
                      2023-11-17 12:34:49.642  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  5.475    dpt : DPT9.024{"type":"Buffer","data":[6,16,4,32,0,23,4,2,1,0,17,0,188,224,16,7,16,51,3,0,128,2,35]}
                      2023-11-17 12:34:49.651  - info: knx.0 (31300) ( 1 ) Sending : GroupValueRead :   06 10 04 20 00 15 04 02 01 00 11 00 bc e0 10 07 38 02 01 00 00    sent to 192.168.178.100:3671  ChID: 2 SeqCntIN : 2 SeqCntOUT : 1 GA : 7/0/2 conCheck.conected : true
                      2023-11-17 12:34:49.652  - info: knx.0 (31300) easy-knx: task.data : 06 10 04 20 00 15 04 02 01 00 11 00 bc e0 10 07 38 02 01 00 00  byteLen : 21
                      2023-11-17 12:34:49.656  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 03 00 29 00 bc e0 10 1e 10 05 03 00 80 00 01   ChID: 2
                      2023-11-17 12:34:49.657  - info: knx.0 (31300) WRITE : mappedName : Heizkreis A Betriebsart    dest : 2/0/5  val: 1   (DPT7.000) Heizkreis_A_Betriebsart
                      2023-11-17 12:34:49.659  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK newState: deferred
                      2023-11-17 12:34:49.660  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 03 00   ChID : 2 SeqCntIN : 3 SeqCntOUT : 2 queue length : 308
                      2023-11-17 12:34:49.661  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.662  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.662  - info: knx.0 (31300) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 02 01 00    from 192.168.178.100:3671 SeqCntIN : 3 SeqCntOUT : 2 GA : 0/0/0
                      2023-11-17 12:34:49.663  - info: knx.0 (31300)  ==>  successful acknowledged previous package... processing next of 308
                      2023-11-17 12:34:49.664  - info: knx.0 (31300)  ==> easy-knx.js: signal runtime : 0s  13.023492ms
                      2023-11-17 12:34:49.665  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.666  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 15 04 02 04 00 29 00 bc e0 10 03 10 0e 01 00 80   ChID: 2
                      2023-11-17 12:34:49.668  - info: knx.0 (31300) WRITE : mappedName : Waermepumpe Stoerung bool    dest : 2/0/14  val: 0   (DPT1.001) Waermepumpe_Stoerung_bool
                      2023-11-17 12:34:49.670  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.671  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 04 00   ChID : 2 SeqCntIN : 4 SeqCntOUT : 2 queue length : 308
                      2023-11-17 12:34:49.671  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.672  - info: knx.0 (31300)  Has todo still 308 tasks, just processing : false
                      2023-11-17 12:34:49.683  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  5    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,1,3,0,128,1,244]}
                      2023-11-17 12:34:49.687  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  23    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,0,3,0,128,12,126]}
                      2023-11-17 12:34:49.690  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.009{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,9,3,0,128,0,0]}
                      2023-11-17 12:34:49.693  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0.562    dpt : DPT14.076{"type":"Buffer","data":[6,16,4,32,0,25,4,2,2,0,17,0,188,224,16,7,3,7,5,0,128,63,15,223,59]}
                      2023-11-17 12:34:49.696  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  80    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,8,3,0,128,23,208]}
                      2023-11-17 12:34:49.698  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  365    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,17,3,0,128,44,116]}
                      2023-11-17 12:34:49.700  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  99    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,16,3,0,128,28,213]}
                      2023-11-17 12:34:49.703  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  685    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,4,3,0,128,52,46]}
                      2023-11-17 12:34:49.706  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,2,3,0,128,0,0]}
                      2023-11-17 12:34:49.709  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.000{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,3,3,3,0,128,0,0]}
                      2023-11-17 12:34:49.724  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.725  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.725  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.752  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.753  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.753  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.757  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.757  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.758  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.761  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.762  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.762  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.765  - error: knx.0 (31300) uncaught exception: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.765  - error: knx.0 (31300) TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.766  - error: knx.0 (31300) Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:49.770  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  12    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,2,0,17,0,188,224,16,7,2,13,3,0,128,4,176]}
                      2023-11-17 12:34:49.771  - info: knx.0 (31300) ( 1 ) Sending : GroupValueRead :   06 10 04 20 00 15 04 02 02 00 11 00 bc e0 10 07 38 04 01 00 00    sent to 192.168.178.100:3671  ChID: 2 SeqCntIN : 4 SeqCntOUT : 2 GA : 7/0/4 conCheck.conected : true
                      2023-11-17 12:34:49.773  - info: knx.0 (31300) easy-knx: task.data : 06 10 04 20 00 15 04 02 02 00 11 00 bc e0 10 07 38 04 01 00 00  byteLen : 21
                      2023-11-17 12:34:49.776  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  80    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,15,3,0,128,23,208]}
                      2023-11-17 12:34:49.779  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  1758    dpt : DPT9.004{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,12,3,0,128,61,93]}
                      2023-11-17 12:34:49.783  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  13    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,11,3,0,128,5,20]}
                      2023-11-17 12:34:49.785  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  30    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,10,3,0,128,13,220]}
                      2023-11-17 12:34:49.787  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  57    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,16,3,0,128,21,145]}
                      2023-11-17 12:34:49.789  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  4    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,23,3,0,128,1,144]}
                      2023-11-17 12:34:49.791  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  90    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,25,3,0,128,28,101]}
                      2023-11-17 12:34:49.793  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.004{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,22,3,0,128,0,0]}
                      2023-11-17 12:34:49.795  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  8    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,21,3,0,128,3,32]}
                      2023-11-17 12:34:49.798  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  85    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,20,3,0,128,28,38]}
                      2023-11-17 12:34:49.801  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,26,3,0,128,0,0]}
                      2023-11-17 12:34:49.803  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  50    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,35,3,0,128,20,226]}
                      2023-11-17 12:34:49.805  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  12    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,31,3,0,128,4,176]}
                      2023-11-17 12:34:49.807  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,30,3,0,128,0,0]}
                      2023-11-17 12:34:49.809  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  12    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,36,3,0,128,4,176]}
                      2023-11-17 12:34:49.811  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  60    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,45,3,0,128,21,220]}
                      2023-11-17 12:34:49.820  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 05 00 29 00 bc e0 10 1e 10 09 03 00 80 00 01   ChID: 2
                      2023-11-17 12:34:49.821  - info: knx.0 (31300) WRITE : mappedName : Zonenmodul Modus    dest : 2/0/9  val: 1   (DPT7.000) Zonenmodul_Modus
                      2023-11-17 12:34:49.822  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK newState: deferred
                      2023-11-17 12:34:49.823  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 05 00   ChID : 2 SeqCntIN : 5 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.824  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.824  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.825  - info: knx.0 (31300) ( 2 ) Received TUNNEL_ACK      :             06 10 04 21 00 0a 04 02 02 00    from 192.168.178.100:3671 SeqCntIN : 5 SeqCntOUT : 3 GA : 0/0/0
                      2023-11-17 12:34:49.826  - info: knx.0 (31300)  ==>  successful acknowledged previous package... processing next of 334
                      2023-11-17 12:34:49.826  - info: knx.0 (31300)  ==> easy-knx.js: signal runtime : 0s  55.111437ms
                      2023-11-17 12:34:49.827  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.828  - info: knx.0 (31300) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 02 06 00 2e 00 bc e0 10 07 38 02 01 00 00  was successfully processed by receiver.
                      2023-11-17 12:34:49.828  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.829  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 06 00   ChID : 2 SeqCntIN : 6 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.830  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.830  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.831  - info: knx.0 (31300) ( 3.3 ) Received TUNNEL_REQUEST (RESPONSE  - send ACK)      :    06 10 04 20 00 17 04 02 07 00 29 00 bc d0 11 0a 38 01 03 00 40 0c b6                2
                      2023-11-17 12:34:49.833  - info: knx.0 (31300) main.js: onGroupValue_Response from 7/0/1
                      2023-11-17 12:34:49.834  - info: knx.0 (31300) RESPONSE : mappedName : Windgeschwindigkeit    dest : 7/0/1  val: 24.12   (DPT9.005) Windgeschwindigkeit
                      2023-11-17 12:34:49.835  - info: knx.0 (31300) RESPONSE single-array value : 24.12 auf knx.0.Wetter.Wetterstation.Windgeschwindigkeit
                      2023-11-17 12:34:49.836  - info: knx.0 (31300) ( 3.4 ) Received TUNNEL_REQUEST for unexpected address
                      2023-11-17 12:34:49.837  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.838  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 07 00   ChID : 2 SeqCntIN : 7 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.839  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.839  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.841  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 08 00 29 00 bc e0 10 1e 12 03 03 00 80 0c 1a   ChID: 2
                      2023-11-17 12:34:49.842  - info: knx.0 (31300) WRITE : mappedName : A3_Raumtemperatur EG Flur -Soll    dest : 2/2/3  val: 21   (DPT9.001) A3_Raumtemperatur_EG_Flur_-Soll
                      2023-11-17 12:34:49.843  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.844  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 08 00   ChID : 2 SeqCntIN : 8 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.845  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.846  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.847  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 09 00 29 00 bc e0 10 1e 12 04 03 00 80 07 6c   ChID: 2
                      2023-11-17 12:34:49.848  - info: knx.0 (31300) WRITE : mappedName : A4_Raumtemperatur EG WC -Soll    dest : 2/2/4  val: 19   (DPT9.001) A4_Raumtemperatur_EG_WC_-Soll
                      2023-11-17 12:34:49.848  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.850  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 09 00   ChID : 2 SeqCntIN : 9 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.850  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.851  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.852  - info: knx.0 (31300) ( 3.6a ) Received L_DATA.con  06 10 04 20 00 15 04 02 0a 00 2e 00 bc e0 10 07 38 04 01 00 00  was successfully processed by receiver.
                      2023-11-17 12:34:49.852  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.854  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 0a 00   ChID : 2 SeqCntIN : 10 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.855  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.855  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.856  - info: knx.0 (31300) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 02 0b 00 29 00 bc e0 10 1e 10 34 03 00 80 00 00   ChID: 2
                      2023-11-17 12:34:49.857  - info: knx.0 (31300) WRITE : mappedName : PV_WP_Elektrische_Leistungsaufnahme    dest : 2/0/52  val: 0   (DPT9.001) PV_WP_Elektrische_Leistungsaufnahme
                      2023-11-17 12:34:49.858  - info: knx.0 (31300) =====> STATE_TUNNELING_ACK
                      2023-11-17 12:34:49.859  - info: knx.0 (31300) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 02 0b 00   ChID : 2 SeqCntIN : 11 SeqCntOUT : 3 queue length : 334
                      2023-11-17 12:34:49.860  - info: knx.0 (31300) ( 4.b ) return to STATE_READY, processing : false
                      2023-11-17 12:34:49.860  - info: knx.0 (31300)  Has todo still 334 tasks, just processing : false
                      2023-11-17 12:34:49.871  - info: knx.0 (31300)  Connection persists.....closing now
                      2023-11-17 12:34:49.872  - info: knx.0 (31300)  ... not able to close connection, because already closed
                      2023-11-17 12:34:49.873  - info: knx.0 (31300)  STATE_NOT_CONNECTED : Try to connect / reconnect :  STATE_READY(7) to STATE_NOT_CONNECTED(0).
                      2023-11-17 12:34:49.874  - debug: knx.0 (31300) Adapter close
                      2023-11-17 12:34:49.875  - info: knx.0 (31300) terminating
                      2023-11-17 12:34:49.876  - debug: knx.0 (31300) Plugin sentry destroyed
                      2023-11-17 12:34:49.876  - warn: knx.0 (31300) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-11-17 12:34:49.878  - info: knx.0 (31300) ( END ) Sending DISCONNECT_REQUEST :           06 10 02 09 00 10 02 00 08 01 c0 a8 b2 3b c9 41                                                        ChID : 0 SeqCntIN : 11 SeqCntOUT : 3  msgCode : [object Object]
                      2023-11-17 12:34:49.879  - info: knx.0 (31300)  STATE_DISCONNECT_REQUEST : Transition from State:  STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_REQUEST(15) not possible because of cancelled connection.
                      2023-11-17 12:34:49.879  - info: knx.0 (31300)  Connection persists.....closing now
                      2023-11-17 12:34:49.880  - info: knx.0 (31300)  ... not able to close connection, because already closed
                      2023-11-17 12:34:49.881  - info: knx.0 (31300)  STATE_NOT_CONNECTED : Stop connection :  STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
                      2023-11-17 12:34:49.914  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  11    dpt : DPT9.001{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,41,3,0,128,4,76]}
                      2023-11-17 12:34:49.916  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  60    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,40,3,0,128,21,220]}
                      2023-11-17 12:34:49.919  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  51    dpt : DPT9.007{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,2,46,3,0,128,20,251]}
                      2023-11-17 12:34:49.922  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  0.055    dpt : DPT9.024{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,16,50,3,0,128,0,5]}
                      2023-11-17 12:34:49.925  - info: knx.0 (31300) easy-knx.js groupValueWrite  value:  5.475    dpt : DPT9.024{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,16,7,16,51,3,0,128,2,35]}
                      2023-11-17 12:34:49.935  - info: knx.0 (31300)  STATE_DISCONNECT_RESPONSE : from State:  STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_RESPONSE(16) ... connection closed
                      2023-11-17 12:34:49.936  - info: knx.0 (31300) Received DISCONNECT_RESPONSE06 10 02 0a 00 08 02 00
                      2023-11-17 12:34:49.937  - info: knx.0 (31300)  Connection persists.....closing now
                      2023-11-17 12:34:49.939  - info: knx.0 (31300)  ... not able to close connection, because already closed
                      2023-11-17 12:34:49.940  - info: knx.0 (31300)  STATE_NOT_CONNECTED : Stop connection :  STATE_DISCONNECT_RESPONSE(16) to STATE_NOT_CONNECTED(0).
                      2023-11-17 12:34:50.418  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
                      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
                      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[1]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
                      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
                      2023-11-17 12:34:50.420  - error: host.raspberrypi Caught by controller[2]: TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[2]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
                      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[2]:     at processImmediate (node:internal/timers:478:21)
                      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[3]: TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[3]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
                      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[3]:     at processImmediate (node:internal/timers:478:21)
                      2023-11-17 12:34:50.421  - error: host.raspberrypi Caught by controller[4]: TypeError: Cannot read properties of null (reading 'val')
                      2023-11-17 12:34:50.422  - error: host.raspberrypi Caught by controller[4]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:380948)
                      2023-11-17 12:34:50.422  - error: host.raspberrypi Caught by controller[4]:     at processImmediate (node:internal/timers:478:21)
                      2023-11-17 12:34:50.422  - error: host.raspberrypi instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2023-11-17 12:34:50.422  - info: host.raspberrypi Restart adapter system.adapter.knx.0 because enabled
                      • B blacksheep587
                        DutchmanD Offline
                        DutchmanD Offline
                        Dutchman
                        #388
                        es sieht so aus also er sich hier komplett zerschossen hat, da eine 2te Instanz geht waehre es eine option die fehlerhafte zu löschen und neu an zu legen ?
                          blacksheep587
                          #389
                          @dutchman Ja, das habe ich gerade gemacht. Es hat aber nicht geholfen, die 0er Instanz zu deinstallieren und eine neue 0er zu erstellen. Ich baue jetzt auf 1. Instanz auf. Jetzt die Frage: kann ich InfluxDB Logs umhängen in eine andere Instanz?
                          • B blacksheep587
                            DutchmanD Offline
                            DutchmanD Offline
                            Dutchman
                            schrieb am zuletzt editiert von Dutchman
                            #390
                            hmm ja aber damit bekämpfen wir ein symptom und mache es komplex da wir mit aliassen arbeiten müssen.
                            (die Datenpunkte ändern sich nämlich von knx.0 nach knx.1)
                            Wieso lässt sich die erste Instanz nicht löschen, kommt da was im log oder ?
                              blacksheep587
                              #391
                              @dutchman said in Test Adapter KNX v2.x:
                              Ja, ich bekomme die gleiche Logschleife wie vorher.
                              • B blacksheep587
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                #392
                                @ChefSache behällt der Adapter noch irgendwo anders Daten? Kannst du eventueel helfen als maintainer des Adapter ?
                                @blacksheep587 alternatief koelte ich dich dabei unterstützen es auf einen knx.1 Instanz um zu setzen.
                                Wen du Datenpunkte mit logging aktiv hast, muesste diese auf dem 2ten wieder aktiviert werden un der vorige als alias eingetragen (damit laufen das logging auf deine Datenbank weiter wie gehabt, sonst werden es neue Einträge)
                                eventuelle scripte, visu Verweisungen usw müssten auch geändert werden. das das eventuell viel aufwand ist doch die frage ob wir die Instanz 0 nicht reanimieren/neu aufsetzen koennten
                                  blacksheep587
                                  #393
                                  @dutchman ja, das wäre gut, wenn wir die InfluxDB über Aliase umhängen könnten. Die Skripte habe ich gestern bereits geändert und als Visu habe ich eine native KNX Umgebung, da gibts nichts zu tun.
                                  • B blacksheep587
                                    DutchmanD Offline
                                    DutchmanD Offline
                                    Dutchman
                                    #394
                                    Wie wollen wir vorgehen? Bin gerne bereit dich hier im Forum, also das wir die Schritte durchgehen auch zum mitlesen für anderen, oder per discord/Teams dabei zu unterstützen
                                      mibr85
                                      #395
                                      Hallo zusammen
                                      enventuel gibt es ja hier eine ANtwort zu meinem Problem:
                                      ich habe in meinem KNX Projekt über die Jahre einige GAs umbenannt oder gelöscht, im Objektbaum des ioBroker sind aber noch alle vorhanden und noch schlimmer ist, dass umbenannte GAs quasi nochmal im Objektbaum angelegt werden aber das neue Objekt hört nicht auf die GA, sondern immer das alte.
                                      Das möchtre ich gern so einfach wie möglich bereinigen.
                                      Welche Optionen habe ich dafür?
                                      ganzen KNX adapter Objektbaum löschen und neu anlegen? Bleiben dabei verbindungen zB in Blockly bestehen oder muss ich alle neu anlegen?
                                      Gibt es bessere Möglichkeiten? über 2000 GAs einzeln durchgehen ist sehr ineffektiv.
                                      • M mibr85
                                        Hallo zusammen
                                        marlan99
                                        #396
                                        @mibr85 ich denke die einfachste Methode ist tatsächlich ganzen Baum löschen und Instanz neu starten.
                                        Die Objekte in den Blockly werden beibehalten.
                                        Eine andere Variante wäre ein Script zu schreiben um im KNX Baum nach Objekten zu suchen die seit einem bestimmten Datum nie mehr aktualisiert wurden. Sicher aufwändiger und je nachdem nicht so zuverlässig wie das löschen des Baums
                                        • M marlan99
                                          mpl1338
                                          #397
                                          @marlan99 said in Test Adapter KNX v2.x:
                                          Ich habe das selbe Problem. Ich habe das löschen und neu anlegen lassen mal versucht(IOB Kopie) ging leider schief.
                                          In vielen KNX Datenpunkten waren die Flags danach falsch. Bei knapp 1000DP machts das keinen Spaß. Solch eine Funktion gehört in den Adapter rein.
