  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.7k Aufrufe 40 Beobachtet
  • Marc BergM Marc Berg
    @thomas-braun sagte in iob diag - Skript:
    Kann mir jemand mit einem Docker mal die aktuelle Ausgabe von
    Ist eine kleine Test-Installation. Hoffe, das reicht.
    Skript v.2023-10-10
    *** BASE SYSTEM ***
    Hardware Vendor : Intel(R) Client Systems
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.0.1
    Virtualization  : Docker
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     21:20:37 up 16 days,  1:21,  0 user,  load average: 0.58, 0.76, 0.64
    CPU threads: 4
    *** Time and Time Zones ***
    Thu Oct 26 19:20:37 UTC 2023
    Thu Oct 26 21:20:37 CEST 2023
    CEST +0200
    Etc/UTC
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             16G        5.9G        434M        108M         10G         10G
    Swap:           4.3G         16M        4.3G
    Total:           20G        6.0G        4.7G
            15718 M total memory
             5665 M used memory
             4923 M active memory
             8757 M inactive memory
              414 M free memory
             1187 M buffer memory
             8783 M swap cache
             4095 M total swap
               16 M used swap
             4079 M free swap
    *** FILESYSTEM ***
    Filesystem     Type     Size  Used Avail Use% Mounted on
    overlay        overlay   63G   20G   41G  33% /
    tmpfs          tmpfs     64M     0   64M   0% /dev
    shm            tmpfs     64M     0   64M   0% /dev/shm
    /dev/nvme0n1p3 ext4      63G   14G   47G  23% /opt/iobroker
    /dev/nvme0n1p2 ext4      63G   20G   41G  33% /etc/hosts
    tmpfs          tmpfs    7.7G     0  7.7G   0% /proc/acpi
    tmpfs          tmpfs    7.7G     0  7.7G   0% /proc/scsi
    tmpfs          tmpfs    7.7G     0  7.7G   0% /sys/firmware
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/nvme0n1p3[/iobroker2]        ext4   rw,relatime
    /opt/userscripts /dev/nvme0n1p3[/userscripts]        ext4   rw,relatime
    /etc/resolv.conf /dev/nvme0n1p2[/var/lib/docker/containers/1692bf02133947c23fc1042a4cdfa5caf0fcc3ece1c5f76e03a4a84b7cf3d709/resolv.conf] ext4   rw,relatime
    /etc/hostname    /dev/nvme0n1p2[/var/lib/docker/containers/1692bf02133947c23fc1042a4cdfa5caf0fcc3ece1c5f76e03a4a84b7cf3d709/hostname]    ext4   rw,relatime
    /etc/hosts       /dev/nvme0n1p2[/var/lib/docker/containers/1692bf02133947c23fc1042a4cdfa5caf0fcc3ece1c5f76e03a4a84b7cf3d709/hosts]       ext4   rw,relatime
    /var:
    16M     /var/
    13M     /var/lib/dpkg
    13M     /var/lib
    12M     /var/lib/dpkg/info
    1.9M    /var/cache
    /opt/iobroker/backups:
    1.3M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    34M     /opt/iobroker/iobroker-data/
    14M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 100
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  5.0.14
    admin:          6.11.0
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker2                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.awtrix-light.0           : awtrix-light          : iobroker2                                -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker2                                -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable, beta
    Installed ioBroker-Instances
    Used repositories: stable, beta
    Adapter    "admin"        : 6.12.0   , installed 6.11.0 [Updatable]
    Adapter    "awtrix-light" : 0.10.0   , installed 0.9.2  [Updatable]
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Controller "js-controller": 5.0.14   , installed 5.0.14
    Objects and States
    Objects:        202
    States:         128
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.11:42087        0.0.0.0:*               LISTEN      0          69068993   -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       69072792   -
    udp        0      0 127.0.0.11:41594        0.0.0.0:*                           0          69068992   -
    2023-10-26 21:17:14.559  - info: host.iobroker2 instance system.adapter.admin.0 started with pid 840
    2023-10-26 21:17:14.561  - info: host.iobroker2 Delete state "system.host.iobroker2.versions.npmNewestNext"
    2023-10-26 21:17:14.562  - info: host.iobroker2 Delete state "system.host.iobroker2.versions.nodeCurrent"
    2023-10-26 21:17:14.563  - info: host.iobroker2 Some obsolete host states deleted.
    2023-10-26 21:17:15.057  - info: admin.0 (840) starting. Version 6.11.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.14
    2023-10-26 21:17:15.072  - info: admin.0 (840) requesting all objects
    2023-10-26 21:17:15.251  - info: admin.0 (840) received all objects
    2023-10-26 21:17:15.340  - info: admin.0 (840) Request actual repository...
    2023-10-26 21:17:15.348  - info: admin.0 (840) socket.io server listening on port 8081
    2023-10-26 21:17:15.349  - info: admin.0 (840) http server listening on port 8081
    2023-10-26 21:17:15.349  - info: admin.0 (840) Use link "http://127.0.0.1:8081" to configure.
    2023-10-26 21:17:15.497  - info: host.iobroker2 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-10-26 21:17:15.574  - error: admin.0 (840) Cannot update news: TypeError: newNews.forEach is not a function
    2023-10-26 21:17:16.743  - info: host.iobroker2 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    2023-10-26 21:17:18.313  - info: admin.0 (840) Repository received successfully.
    2023-10-26 21:17:18.581  - info: host.iobroker2 instance system.adapter.backitup.0 started with pid 879
    2023-10-26 21:17:19.016  - info: backitup.0 (879) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.14
    2023-10-26 21:17:19.038  - info: backitup.0 (879) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-10-26 21:17:19.888  - info: admin.0 (840) ==> Connected system.user.admin from ::ffff:192.168.1.98
    2023-10-26 21:17:22.577  - info: host.iobroker2 instance system.adapter.awtrix-light.0 started with pid 894
    2023-10-26 21:17:22.998  - info: awtrix-light.0 (894) starting. Version 0.9.2 in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.18.2, js-controller: 5.0.14
    2023-10-26 21:17:23.028  - info: awtrix-light.0 (894) Starting - connecting to http://192.168.0.111:80/
    2023-10-26 21:17:23.052  - info: awtrix-light.0 (894) error ENETUNREACH from stats: connect ENETUNREACH 192.168.0.111:80
    2023-10-26 21:17:44.896  - info: admin.0 (840) <== Disconnect system.user.admin from ::ffff:192.168.1.98 admin
    2023-10-26 21:18:04.555  - info: admin.0 (840) ==> Connected system.user.admin from ::ffff:192.168.1.98
                            v.2023-10-10
    model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
    Kernel          : x86_64
    Userland        : amd64
    Docker          : v9.0.1
    Installation:           Docker
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Etc/UTC
    User-ID:                0
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:             16G        6.0G        388M        108M         10G         10G
    Swap:           4.3G         16M        4.3G
    Active iob-Instances:   4
    ioBroker Core:          js-controller           5.0.14
                            admin                   6.11.0
    Objects type: redis
    States  type: redis
    Objects:                202
    States:                 128
    Size of iob-Database:
    404K    /opt/iobroker/iobroker-data/states.jsonl
    #593
    @marc-berg sagte in iob diag - Skript:
    Ja, ich will nur mal sehen was auf dem Docker nicht funktioniert und das dann ausklammern.
    Danke schön!
    • H Offline
      Hc-Yami
      #594
      ich versuche gerade einzugrenzen warum ich nicht von node.js 18.17 auf die 18.18 komme.
      Leider bekomme ich das Skript so nicht ausgeführt, weil er das Kennwort für den ioBroker user verlangt.
      Ich melde mich via. "normal" Account und SSH an. Wechsle dann auf den root, weil der normal Account keine Rechte hat und führe das Skript wie folgt aus:
      root@ioBroker:/home/administrator# sudo --user=iobroker iob diag
      Wenn ich es mit dem administrator ausführe, steht dort, dass dieser keine Rechte hat im Namen von iobroker etwas auszuführen.
      Was mache ich hier falsch? :/
      • H Hc-Yami
        apollon77A Online
        apollon77A Online
        #595
        @hc-yami Also wenn du es normal aufgesetzt hast dann sollte sudo für deinen user eingerichtet sein und du kannst das skript normal starten und er fragt nach dem Passwort des users
        H 1 Antwort Letzte Antwort
        • apollon77A apollon77
          Hc-Yami
          schrieb am zuletzt editiert von Hc-Yami
          #596
          @apollon77 die Installation ist leider schon sehr lange her. Nutze ioBroker schon seit den anfängen.
          Ich denke die Installation war durch eine damalige Vorlage auf der Webseite.
          Wenn ich das Skript via. "normalen" User, in meinem Fall administrator starte, bekomme ich folgende Meldung:
          administrator@ioBroker:~$ sudo iob fix
          [sudo] Passwort für administrator:
          Leider darf der Benutzer administrator »/usr/bin/iob fix« als root auf ioBroker nicht ausführen.
          Starte ich das Skript als root, erhalte ich folgende Meldung:
          root@ioBroker:/home/administrator# iob diag
          This script must not be run as root!
          Please use your standard user!
          iob fix hatte ich schon ausgeführt. Auch ein reboot ist durch.
          • H Hc-Yami
            #597
            @hc-yami
            In welchen Gruppen ist der 'administrator' drin?
            groups
            anschauen.
              @hc-yami
              groups
              anschauen.
              Hc-Yami
              #598
              @thomas-braun said in iob diag - Skript:
              groups
              schön, dass es die kleinen Dinge sind. :)
              Hab den Nutzer nun über
              su -
              usermod -aG iobroker administrator
              hinzugefügt.
              administrator@ioBroker:~$ groups
              administrator cdrom floppy audio dip video plugdev netdev iobroker
              Leider darf er dadurch immer noch nicht:
              administrator@ioBroker:~$ sudo iob diag
              Leider darf der Benutzer administrator »/usr/bin/iob diag« als root auf ioBroker nicht ausführen.
              Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
              • H Hc-Yami
                groups
                su -
                hinzugefügt.
                Meister MopperM Offline
                Meister Mopper
                #599
                @hc-yami sagte in iob diag - Skript:
                sudo iob diag
                Niemals ein sudo vor einen ioBroker-Befehl!!!
                Proxmox und HA ...
                • H Hc-Yami
                  groups
                  su -
                  hinzugefügt.
                  #600
                  Logisch. Der ist ja auch nicht in der Gruppe sudo drin.
                  Als root:
                  usermod -aG sudo administrator
                  Und dann NIE, NIE, NIE MEHR direkt als root herumkaspern.
                    Als root:
                    Hc-Yami
                    #601
                    @Meister-Mopper
                    administrator@ioBroker:~$ iob diag
                    Leider darf der Benutzer administrator »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf ioBroker nicht ausführen.
                    administrator@ioBroker:~$ su -
                    Passwort:
                    root@ioBroker:~# usermod -aG sudo administrator
                    root@ioBroker:~# exit
                    Abgemeldet
                    • H Hc-Yami
                      @Meister-Mopper
                      Passwort:
                      Abgemeldet
                      #602
                      @hc-yami
                      Den 'administrator' aus- und wieder einloggen.
                      Geänderte Gruppen werden erst beim nächsten Login eingelesen.
                        @hc-yami
                        Hc-Yami
                        #603
                        @thomas-braun wieder etwas gelernt, vielen Dank dafür. Leider löst das mein Update Problem noch nicht, weil iob diag eigentlichr echt gut aussieht:
                                                v.2023-10-10
                           Static hostname: ioBroker
                                 Icon name: computer-vm
                                   Chassis: vm
                            Virtualization: microsoft
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 5.10.0-19-amd64
                              Architecture: x86-64
                        Installation:           microsoft
                        Kernel:                 x86_64
                        Userland:               amd64
                        Timezone:               Europe/Berlin (CET, +0100)
                        User-ID:                1000
                        X-Server:               false
                        Pending OS-Updates:     133
                        Pending iob updates:    0
                        Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                /usr/bin/node           v18.17.1
                                                /usr/bin/npm            9.6.7
                                                /usr/bin/npx            9.6.7
                                                /usr/bin/corepack       0.18.0
                        MEMORY:
                        Mem:            3.9G        2.3G        911M        0.0K        675M        1.3G
                        Swap:           974M          0B        974M
                        Total:          4.9G        2.3G        1.9G
                        Active iob-Instances:   30
                        ioBroker Core:          js-controller           5.0.12
                                                admin                   6.12.0
                        Objects type: jsonl
                        States  type: jsonl
                        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        Objects:                9722
                        States:                 7869
                        26M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                        8.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                        2.5M    /opt/iobroker/iobroker-data/states.jsonl
                        1020K   /opt/iobroker/iobroker-data/states.json.migrated
                        1020K   /opt/iobroker/iobroker-data/states.json.bak.migrated
                        0       /opt/iobroker/iobroker-data/states.json.broken
                        • H Hc-Yami
                                                  v.2023-10-10
                                     Chassis: vm
                          Kernel:                 x86_64
                          Userland:               amd64
                          User-ID:                1000
                          X-Server:               false
                                                  /usr/bin/npm            9.6.7
                                                  /usr/bin/npx            9.6.7
                          MEMORY:
                          Swap:           974M          0B        974M
                                                  admin                   6.12.0
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                9722
                          States:                 7869
                          #604
                          HUST
                          Das ist auch ein Update-Problem...
                          sudo apt update
                          sudo apt full-upgrade
                          iob stop
                          iob fix
                          iob nodejs-update
                          sudo systemctl set-default multi-user.target
                          sudo reboot
                            HUST
                            sudo apt update
                            iob stop
                            iob fix
                            iob nodejs-update
                            sudo reboot
                            Hc-Yami
                            #605
                            @thomas-braun hatte tatsächlich nie manuell apt upgrade ausgeführt. Habe das nun nachgeholt. Irgendwie hatte ich im Kopf, dass man das nicht tun sollte, weil ioBroker das für einen erledigt. Faktisch praktisch ist aber apt update / upgrade und full-upgrade im ioBroker Umfeld okay?
                            Gehe gerade die Befehle durch. Nach apt upgrad ehabe ich schonmal keine Updates mehr. Jetzt möchte er aber gerade einen Neustart. :)
                            • H Hc-Yami
                              #606
                              Quatsch. Das wurde noch nie von einer Anwendung übernommen, die dafür gar nicht gedacht ist.
                              Das hat mit dem Umfeld nix zu tun, das ist eine reine Sache des Betriebssystems.
                              Natürlich. Deswegen hatte ich den oben schon vorweggenommen.
                              H Thomas BraunT 2 Antworten Letzte Antwort
                                Hc-Yami
                                #607
                                @thomas-braun läuft wie ein Länderspiel, dankeschön. :)
                                Wo findet man die obligatorische Kaffeedose?
                                  #608
                                  Könnte mal einer der Raspberry 5 User einen vollständigen Lauf zeigen?
                                  Ich glaube das hakelt da noch an ein paar Stellen. Die würde ich gerne noch ausbügeln.
                                  L 1 Antwort Letzte Antwort
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    #609
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                           Icon name: computer
                                              Kernel: Linux 6.6.20+rpt-rpi-2712
                                        Architecture: arm64
                                    Model           : Raspberry Pi 5 Model B Rev 1.0
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     23:01:51 up 4 days,  8:55,  1 user,  load average: 0.22, 0.38, 0.34
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                                   Local time: Mon 2024-04-01 23:01:51 CEST
                                               Universal time: Mon 2024-04-01 21:01:51 UTC
                                                     RTC time: Mon 2024-04-01 21:01:51
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            8.4G        5.5G        1.5G        5.5M        1.5G        2.9G
                                    Swap:           104M          0B        104M
                                    Total:          8.5G        5.5G        1.6G
                                             8052 M total memory
                                             5246 M used memory
                                             4928 M active memory
                                             1077 M inactive memory
                                             1431 M free memory
                                              161 M buffer memory
                                             1314 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    vc_gencmd_read_response returned -1
                                    error=1 error_msg="Command not registered"
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    udev                           devtmpfs  3.8G     0  3.8G   0% /dev
                                    tmpfs                          tmpfs     806M  5.2M  801M   1% /run
                                    /dev/mmcblk0p2                 ext4      117G  9.3G  102G   9% /
                                    tmpfs                          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                    tmpfs                          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                    /dev/mmcblk0p1                 vfat      510M   63M  448M  13% /boot/firmware
                                    192.168.2.56:/volume1/iobroker nfs       3.5T  2.8T  776G  79% /opt/iobroker/backups
                                    tmpfs                          tmpfs     806M     0  806M   0% /run/user/1000
                                    [Thu Mar 28 13:06:18 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Thu Mar 28 13:06:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                                    [Thu Mar 28 13:06:22 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                                    /                       /dev/mmcblk0p2                 ext4   rw,noatime
                                    |-/boot/firmware        /dev/mmcblk0p1                 vfat   rw,relatime,fmask=
                                    `-/opt/iobroker/backups 192.168.2.56:/volume1/iobroker nfs    rw,relatime,vers=3
                                    /var:
                                    2.0G    /var/
                                    1.4G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
                                    1.4G    /var/log
                                    343M    /var/cache
                                    Archived and active journals take up 1.3G in the file system.
                                    9.9G    /opt/iobroker/backups/
                                    951M    /opt/iobroker/iobroker-data/
                                    595M    /opt/iobroker/iobroker-data/files
                                    266M    /opt/iobroker/iobroker-data/backup-objects
                                    166M    /opt/iobroker/iobroker-data/files/vis-2
                                    82M     /opt/iobroker/iobroker-data/files/vis-2/static
                                    78M     /opt/iobroker/iobroker-data/objects.jsonl
                                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.3c875f4c.js.map
                                    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.b4e310b6.js.map
                                    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.6aba9d5c.js.map
                                    USB-Devices by-id:
                                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                                    /usr/bin/nodejs         v18.20.0
                                    /usr/bin/node           v18.20.0
                                    /usr/bin/npm            10.5.0
                                    /usr/bin/npx            10.5.0
                                    /usr/bin/corepack       0.25.2
                                    nodejs:
                                      Installed: 18.20.0-1nodesource1
                                      Candidate: 18.20.0-1nodesource1
                                      Version table:
                                     *** 18.20.0-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                         18.19.1-1nodesource1 1001
                                         18.19.0+dfsg-6~deb12u1 500
                                            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                         18.19.0-1nodesource1 1001
                                         18.18.2-1nodesource1 1001
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0+dfsg1-1 500
                                            500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                    Errors in npm tree:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    js-controller:  5.0.19
                                    admin:          6.15.2
                                    javascript:     7.11.1
                                    Adapters from github:   9
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                    + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
                                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                    + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                                    + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
                                    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                    + system.adapter.hekr.0                   : hekr                  : iobroker                                 -  enabled
                                    + system.adapter.hiob.0                   : hiob                  : iobroker                                 -  enabled, port: 8097
                                    + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
                                    + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                                    + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                                    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                    + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
                                      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                                    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
                                    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                                    + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                    + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                                      system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                                    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                                    + instance is alive
                                    Active repo(s): beta
                                    Used repository: beta
                                    Adapter    "admin"        : 6.15.2   , installed 6.15.2
                                    Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                    Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                    Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                    Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                    Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                    Adapter    "email"        : 1.2.2    , installed 1.2.2
                                    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                    Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                                    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                    Adapter    "hekr"         : 0.0.6    , installed 0.0.6
                                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                    Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                    Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                    Adapter    "imap"         : 0.1.3    , installed 0.1.3
                                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                    Adapter    "javascript"   : 7.11.1   , installed 7.11.1
                                    Controller "js-controller": 5.0.19   , installed 5.0.19
                                    Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
                                    Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                    Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                    Adapter    "onvif"        : 1.1.3    , installed 1.1.3
                                    Adapter    "parcel"       : 0.2.7    , installed 0.2.7
                                    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                                    Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                                    Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                                    Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                    Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                    Adapter    "vis-2"        : 2.9.48   , installed 2.9.47 [Updatable]
                                    Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                                    Adapter    "web"          : 6.2.5    , installed 6.2.4  [Updatable]
                                    Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                    Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                                    Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
                                    Objects and States
                                    Objects:        29996
                                    States:         25284
                                    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                    Reading package lists... Done
                                    Pending Updates: 16
                                    tcp        0      0 0.0.0.0:38893           0.0.0.0:*               LISTEN      103        6574       1059/rpc.statd
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7524       1181/io.mqtt.0
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3950       815/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6370       815/iobroker.js-con
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8253       1/init
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6304       828/sshd: /usr/sbin
                                    tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       4583563    939275/io.hm-rpc.1
                                    tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       4583690    939361/io.hm-rpc.2
                                    tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       4578722    938471/io.hm-rpc.0
                                    tcp        0      0 0.0.0.0:35019           0.0.0.0:*               LISTEN      0          7907678    -
                                    tcp6       0      0 :::45649                :::*                    LISTEN      0          7907680    -
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          7274       1/init
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6306       828/sshd: /usr/sbin
                                    tcp6       0      0 :::8095                 :::*                    LISTEN      1001       10781      2307/io.hiobs.0
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9186       1977/io.simple-api.
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9713       1325/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6447       912/io.admin.0
                                    tcp6       0      0 :::8097                 :::*                    LISTEN      1001       562465     120279/io.hiob.0
                                    tcp6       0      0 :::35675                :::*                    LISTEN      103        6578       1059/rpc.statd
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9289       1/init
                                    udp        0      0 127.0.0.1:811           0.0.0.0:*                           0          8263       1059/rpc.statd
                                    udp        0      0 0.0.0.0:42082           0.0.0.0:*                           104        6217       687/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6215       687/avahi-daemon: r
                                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       8520       1212/io.tuya.0
                                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       8521       1212/io.tuya.0
                                    udp        0      0 0.0.0.0:35386           0.0.0.0:*                           0          7907677    -
                                    udp        0      0 0.0.0.0:44296           0.0.0.0:*                           103        6572       1059/rpc.statd
                                    udp6       0      0 :::40946                :::*                                103        6576       1059/rpc.statd
                                    udp6       0      0 :::111                  :::*                                0          7276       1/init
                                    udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          9281930    788/NetworkManager
                                    udp6       0      0 :::5353                 :::*                                104        6216       687/avahi-daemon: r
                                    udp6       0      0 :::47552                :::*                                0          7907679    -
                                    udp6       0      0 :::43790                :::*                                104        6218       687/avahi-daemon: r
                                    2024-04-01 22:57:59.799  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
                                    2024-04-01 22:57:59.836  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
                                    2024-04-01 23:00:00.006  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Gartenbeleuchtung: Gartenbeleuchtung
                                    2024-04-01 23:00:00.009  - info: javascript.0 (960) script.js.Scripts.Allgemein.Prüfung_Regen: Start Regen Check
                                    2024-04-01 23:00:00.024  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 2030238
                                    2024-04-01 23:00:00.049  - info: javascript.0 (960) script.js.Scripts.Allgemein.Astro: Astro: Gültige Zeiten: [aktueller Tag: 0] | [nächster Tag: 14] | [Aktualisiert: 0] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht
                                    2024-04-01 23:00:00.891  - info: javascript.0 (960) script.js.Scripts.Allgemein.Dachfenster_automatisch: Der Server Karte ist Online!!!
                                    2024-04-01 23:00:01.531  - info: daswetter.0 (2030238) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.0, js-controller: 5.0.19
                                    2024-04-01 23:00:04.032  - info: host.iobroker instance system.adapter.ical.0 started with pid 2030479
                                    2024-04-01 23:00:05.135  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
                                    2024-04-01 23:00:05.560  - info: ical.0 (2030479) starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.0, js-controller: 5.0.19
                                    2024-04-01 23:00:06.323  - info: ical.0 (2030479) processing URL: Muell https://calendar.google.com/calendar/ical/c241cf4fcd482c213a45430df0868c1653d1e8d1b854ece0b0863fdc99bb146b%40group.calendar.google.com/public/basic.ics
                                    2024-04-01 23:00:06.428  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
                                    2024-04-01 23:00:11.538  - info: ical.0 (2030479) Terminated (NO_ERROR): Without reason
                                    2024-04-01 23:00:12.062  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                    2024-04-01 23:00:12.071  - info: daswetter.0 (2030238) still wrong data structure from server received! repaired...
                                    2024-04-01 23:00:14.767  - info: daswetter.0 (2030238) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                    2024-04-01 23:00:15.272  - info: daswetter.0 (2030238) cleaned everything up...
                                    2024-04-01 23:00:15.278  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-04-01 23:00:21.417  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Klingenarbeitszeit wurde aktualisiert:  531.9
                                    2024-04-01 23:00:21.440  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Temperatur Akku hat sich geändert: 11.6
                                    2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Worx: HTML Aktualisierung: worx.0.202130266301009363E0.mower.status - 1
                                    2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Trigger Aktualisierung Worx!1
                                    2024-04-01 23:00:21.463  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
                                    2024-04-01 23:00:21.498  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
                                    iob diag has finished.
                                    Press any key for a summary
                                                            v.2023-10-10
                                           Icon name: computer
                                        Architecture: arm64
                                    Kernel:                 aarch64
                                    Userland:               arm64
                                    User-ID:                1000
                                    X-Server:               false
                                    Pending OS-Updates:     16
                                    Nodejs-Installation:    /usr/bin/nodejs         v18.20.0
                                                            /usr/bin/npm            10.5.0
                                                            /usr/bin/npx            10.5.0
                                    Recommended versions are nodejs 18.20.0 and npm 10.5.0
                                    MEMORY:
                                    Mem:            8.4G        5.4G        1.4G        5.5M        1.8G        3.1G
                                    Swap:           104M          0B        104M
                                    Total:          8.5G        5.4G        1.5G
                                    Active iob-Instances:   47
                                    ioBroker Core:          js-controller           5.0.19
                                                            admin                   6.15.2
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects:                29996
                                    States:                 25284
                                    87M     /opt/iobroker/iobroker-data/objects.jsonl
                                    15M     /opt/iobroker/iobroker-data/states.jsonl
                                    === Mark text until here for copying ===
                                    pi@iobroker:~ $
                                    • L Lucky_ESA
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                      CPU threads: 4
                                      Current issues:
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:           104M          0B        104M
                                               8052 M total memory
                                               5246 M used memory
                                               1431 M free memory
                                                161 M buffer memory
                                               1314 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      *** FILESYSTEM ***
                                      /var:
                                      2.0G    /var/
                                      1.4G    /var/log
                                      343M    /var/cache
                                      USB-Devices by-id:
                                      /usr/bin/npm            10.5.0
                                      /usr/bin/npx            10.5.0
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.15.2
                                      javascript:     7.11.1
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        29996
                                      States:         25284
                                      Pending Updates: 16
                                                              v.2023-10-10
                                             Icon name: computer
                                          Architecture: arm64
                                      Kernel:                 aarch64
                                      Userland:               arm64
                                      User-ID:                1000
                                      X-Server:               false
                                                              /usr/bin/npm            10.5.0
                                                              /usr/bin/npx            10.5.0
                                      MEMORY:
                                      Swap:           104M          0B        104M
                                                              admin                   6.15.2
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                29996
                                      States:                 25284
                                      pi@iobroker:~ $
                                      #610
                                      @lucky_esa
                                      Das kommt vermutlich bei dir mit Fehler um die Ecke, oder?
                                      vcgencmd mem_oom
                                        @lucky_esa
                                        vcgencmd mem_oom
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #611
                                        @thomas-braun Natürlich.
                                        pi@iobroker:~ $ vcgencmd mem_oom
                                        pi@iobroker:~ $ ^C
                                        pi@iobroker:~ $ vcgencmd commands
                                        commands="commands, set_logging, bootloader_config, bootloader_version, cache_flush, codec_enabled, get_mem, get_rsts, measure_clock, measure_temp, measure_volts, get_hvs_asserts, get_config, get_throttled, pmicrd, pmicwr, read_ring_osc, version, readmr, otp_dump, pmic_read_adc, power_monitor"
                                        pi@iobroker:~ $
                                        Verwende doch get_throttled.
                                        Gruß//Lucky
                                        • L Lucky_ESA
                                          pi@iobroker:~ $ ^C
                                          pi@iobroker:~ $
                                          Gruß//Lucky
                                          #612
                                          @lucky_esa
                                          Dann ist 'mem_oom' wohl aus der Firmware für den RPi5 geflogen. Ich hab den Code jetzt aus dem Skript herausgenommen, die Info war eh nicht so wirklich aussagekräftig.
                                          'get_throttled' wird an anderer Stelle natürlich abgefragt.
