  4. iob diag - Skript
iob diag - Skript
863 Beiträge 52 Kommentatoren 308.6k Aufrufe 40 Beobachtet
  • P pk68
    Ok, danke.
    #591
    Kann mir jemand mit einem Docker mal die aktuelle Ausgabe von
    iob diag
    posten? Danke schön!
    • Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      #592
      @thomas-braun sagte in iob diag - Skript:
      Ist eine kleine Test-Installation. Hoffe, das reicht.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : Intel(R) Client Systems
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.0.1
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:20:37 up 16 days,  1:21,  0 user,  load average: 0.58, 0.76, 0.64
      CPU threads: 4
      *** Time and Time Zones ***
      Thu Oct 26 19:20:37 UTC 2023
      Thu Oct 26 21:20:37 CEST 2023
      CEST +0200
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             16G        5.9G        434M        108M         10G         10G
      Swap:           4.3G         16M        4.3G
      Total:           20G        6.0G        4.7G
              15718 M total memory
               5665 M used memory
               4923 M active memory
               8757 M inactive memory
                414 M free memory
               1187 M buffer memory
               8783 M swap cache
               4095 M total swap
                 16 M used swap
               4079 M free swap
      *** FILESYSTEM ***
      Filesystem     Type     Size  Used Avail Use% Mounted on
      overlay        overlay   63G   20G   41G  33% /
      tmpfs          tmpfs     64M     0   64M   0% /dev
      shm            tmpfs     64M     0   64M   0% /dev/shm
      /dev/nvme0n1p3 ext4      63G   14G   47G  23% /opt/iobroker
      /dev/nvme0n1p2 ext4      63G   20G   41G  33% /etc/hosts
      tmpfs          tmpfs    7.7G     0  7.7G   0% /proc/acpi
      tmpfs          tmpfs    7.7G     0  7.7G   0% /proc/scsi
      tmpfs          tmpfs    7.7G     0  7.7G   0% /sys/firmware
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET           SOURCE        FSTYPE OPTIONS
      /opt/iobroker    /dev/nvme0n1p3[/iobroker2]        ext4   rw,relatime
      /opt/userscripts /dev/nvme0n1p3[/userscripts]        ext4   rw,relatime
      /etc/resolv.conf /dev/nvme0n1p2[/var/lib/docker/containers/1692bf02133947c23fc1042a4cdfa5caf0fcc3ece1c5f76e03a4a84b7cf3d709/resolv.conf] ext4   rw,relatime
      /etc/hostname    /dev/nvme0n1p2[/var/lib/docker/containers/1692bf02133947c23fc1042a4cdfa5caf0fcc3ece1c5f76e03a4a84b7cf3d709/hostname]    ext4   rw,relatime
      /etc/hosts       /dev/nvme0n1p2[/var/lib/docker/containers/1692bf02133947c23fc1042a4cdfa5caf0fcc3ece1c5f76e03a4a84b7cf3d709/hosts]       ext4   rw,relatime
      /var:
      16M     /var/
      13M     /var/lib/dpkg
      13M     /var/lib
      12M     /var/lib/dpkg/info
      1.9M    /var/cache
      /opt/iobroker/backups:
      1.3M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      34M     /opt/iobroker/iobroker-data/
      14M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      20M     /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      USB-Devices by-id:
      find: '/dev/serial/by-id/': No such file or directory
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
        Installed: 18.18.2-1nodesource1
        Candidate: 18.18.2-1nodesource1
        Version table:
       *** 18.18.2-1nodesource1 100
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  5.0.14
      admin:          6.11.0
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker2                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker2                                -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker2                                -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable, beta
      Installed ioBroker-Instances
      Used repositories: stable, beta
      Adapter    "admin"        : 6.12.0   , installed 6.11.0 [Updatable]
      Adapter    "awtrix-light" : 0.10.0   , installed 0.9.2  [Updatable]
      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
      Controller "js-controller": 5.0.14   , installed 5.0.14
      Objects and States
      Objects:        202
      States:         128
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.11:42087        0.0.0.0:*               LISTEN      0          69068993   -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       69072792   -
      udp        0      0 127.0.0.11:41594        0.0.0.0:*                           0          69068992   -
      2023-10-26 21:17:14.559  - info: host.iobroker2 instance system.adapter.admin.0 started with pid 840
      2023-10-26 21:17:14.561  - info: host.iobroker2 Delete state "system.host.iobroker2.versions.npmNewestNext"
      2023-10-26 21:17:14.562  - info: host.iobroker2 Delete state "system.host.iobroker2.versions.nodeCurrent"
      2023-10-26 21:17:14.563  - info: host.iobroker2 Some obsolete host states deleted.
      2023-10-26 21:17:15.057  - info: admin.0 (840) starting. Version 6.11.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.18.2, js-controller: 5.0.14
      2023-10-26 21:17:15.072  - info: admin.0 (840) requesting all objects
      2023-10-26 21:17:15.251  - info: admin.0 (840) received all objects
      2023-10-26 21:17:15.340  - info: admin.0 (840) Request actual repository...
      2023-10-26 21:17:15.348  - info: admin.0 (840) socket.io server listening on port 8081
      2023-10-26 21:17:15.349  - info: admin.0 (840) http server listening on port 8081
      2023-10-26 21:17:15.349  - info: admin.0 (840) Use link "http://127.0.0.1:8081" to configure.
      2023-10-26 21:17:15.497  - info: host.iobroker2 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2023-10-26 21:17:15.574  - error: admin.0 (840) Cannot update news: TypeError: newNews.forEach is not a function
      2023-10-26 21:17:16.743  - info: host.iobroker2 Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2023-10-26 21:17:18.313  - info: admin.0 (840) Repository received successfully.
      2023-10-26 21:17:18.581  - info: host.iobroker2 instance system.adapter.backitup.0 started with pid 879
      2023-10-26 21:17:19.016  - info: backitup.0 (879) starting. Version 2.8.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.18.2, js-controller: 5.0.14
      2023-10-26 21:17:19.038  - info: backitup.0 (879) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2023-10-26 21:17:19.888  - info: admin.0 (840) ==> Connected system.user.admin from ::ffff:192.168.1.98
      2023-10-26 21:17:22.577  - info: host.iobroker2 instance system.adapter.awtrix-light.0 started with pid 894
      2023-10-26 21:17:22.998  - info: awtrix-light.0 (894) starting. Version 0.9.2 in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.18.2, js-controller: 5.0.14
      2023-10-26 21:17:23.028  - info: awtrix-light.0 (894) Starting - connecting to http://192.168.0.111:80/
      2023-10-26 21:17:23.052  - info: awtrix-light.0 (894) error ENETUNREACH from stats: connect ENETUNREACH 192.168.0.111:80
      2023-10-26 21:17:44.896  - info: admin.0 (840) <== Disconnect system.user.admin from ::ffff:192.168.1.98 admin
      2023-10-26 21:18:04.555  - info: admin.0 (840) ==> Connected system.user.admin from ::ffff:192.168.1.98
                              v.2023-10-10
      model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.0.1
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Etc/UTC
      User-ID:                0
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    2
      Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      Recommended versions are nodejs 18.18.2 and npm 9.8.1
      MEMORY:
      Mem:             16G        6.0G        388M        108M         10G         10G
      Swap:           4.3G         16M        4.3G
      Active iob-Instances:   4
      ioBroker Core:          js-controller           5.0.14
                              admin                   6.11.0
      Objects type: redis
      States  type: redis
      Objects:                202
      States:                 128
      Size of iob-Database:
      404K    /opt/iobroker/iobroker-data/states.jsonl
      • Marc BergM Marc Berg
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.0.1
        Kernel          : x86_64
        Userland        : amd64
        CPU threads: 4
        CEST +0200
        Etc/UTC
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           4.3G         16M        4.3G
                 5665 M used memory
                  414 M free memory
                 8783 M swap cache
                 4095 M total swap
                   16 M used swap
                 4079 M free swap
        *** FILESYSTEM ***
        /var:
        16M     /var/
        13M     /var/lib/dpkg
        13M     /var/lib
        1.9M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        Errors in npm tree:
        ioBroker Status
        Objects type: redis
        States  type: redis
        admin:          6.11.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        202
        States:         128
        Pending Updates: 0
                                v.2023-10-10
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.0.1
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
        MEMORY:
        Swap:           4.3G         16M        4.3G
                                admin                   6.11.0
        Objects type: redis
        States  type: redis
        Objects:                202
        States:                 128
        #593
        @marc-berg sagte in iob diag - Skript:
        Ja, ich will nur mal sehen was auf dem Docker nicht funktioniert und das dann ausklammern.
        Danke schön!
        • H Offline
          Hc-Yami
          #594
          ich versuche gerade einzugrenzen warum ich nicht von node.js 18.17 auf die 18.18 komme.
          Leider bekomme ich das Skript so nicht ausgeführt, weil er das Kennwort für den ioBroker user verlangt.
          Ich melde mich via. "normal" Account und SSH an. Wechsle dann auf den root, weil der normal Account keine Rechte hat und führe das Skript wie folgt aus:
          root@ioBroker:/home/administrator# sudo --user=iobroker iob diag
          Wenn ich es mit dem administrator ausführe, steht dort, dass dieser keine Rechte hat im Namen von iobroker etwas auszuführen.
          Was mache ich hier falsch? :/
          • H Hc-Yami
            apollon77A Online
            apollon77A Online
            #595
            @hc-yami Also wenn du es normal aufgesetzt hast dann sollte sudo für deinen user eingerichtet sein und du kannst das skript normal starten und er fragt nach dem Passwort des users
            H 1 Antwort Letzte Antwort
            • apollon77A apollon77
              Hc-Yami
              schrieb am zuletzt editiert von Hc-Yami
              #596
              @apollon77 die Installation ist leider schon sehr lange her. Nutze ioBroker schon seit den anfängen.
              Ich denke die Installation war durch eine damalige Vorlage auf der Webseite.
              Wenn ich das Skript via. "normalen" User, in meinem Fall administrator starte, bekomme ich folgende Meldung:
              administrator@ioBroker:~$ sudo iob fix
              [sudo] Passwort für administrator:
              Leider darf der Benutzer administrator »/usr/bin/iob fix« als root auf ioBroker nicht ausführen.
              Starte ich das Skript als root, erhalte ich folgende Meldung:
              root@ioBroker:/home/administrator# iob diag
              This script must not be run as root!
              Please use your standard user!
              iob fix hatte ich schon ausgeführt. Auch ein reboot ist durch.
              • H Hc-Yami
                #597
                @hc-yami
                In welchen Gruppen ist der 'administrator' drin?
                groups
                anschauen.
                  @hc-yami
                  groups
                  anschauen.
                  Hc-Yami
                  #598
                  @thomas-braun said in iob diag - Skript:
                  groups
                  schön, dass es die kleinen Dinge sind. :)
                  Hab den Nutzer nun über
                  su -
                  usermod -aG iobroker administrator
                  hinzugefügt.
                  administrator@ioBroker:~$ groups
                  administrator cdrom floppy audio dip video plugdev netdev iobroker
                  Leider darf er dadurch immer noch nicht:
                  administrator@ioBroker:~$ sudo iob diag
                  Leider darf der Benutzer administrator »/usr/bin/iob diag« als root auf ioBroker nicht ausführen.
                  Meister MopperM Thomas BraunT 2 Antworten Letzte Antwort
                  • H Hc-Yami
                    groups
                    su -
                    hinzugefügt.
                    Meister MopperM Offline
                    Meister Mopper
                    #599
                    @hc-yami sagte in iob diag - Skript:
                    sudo iob diag
                    Niemals ein sudo vor einen ioBroker-Befehl!!!
                    Proxmox und HA ...
                    • H Hc-Yami
                      groups
                      su -
                      hinzugefügt.
                      #600
                      Logisch. Der ist ja auch nicht in der Gruppe sudo drin.
                      Als root:
                      usermod -aG sudo administrator
                      Und dann NIE, NIE, NIE MEHR direkt als root herumkaspern.
                        Als root:
                        Hc-Yami
                        #601
                        @Meister-Mopper
                        administrator@ioBroker:~$ iob diag
                        Leider darf der Benutzer administrator »/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh« als iobroker auf ioBroker nicht ausführen.
                        administrator@ioBroker:~$ su -
                        Passwort:
                        root@ioBroker:~# usermod -aG sudo administrator
                        root@ioBroker:~# exit
                        Abgemeldet
                        • H Hc-Yami
                          @Meister-Mopper
                          Passwort:
                          Abgemeldet
                          #602
                          @hc-yami
                          Den 'administrator' aus- und wieder einloggen.
                          Geänderte Gruppen werden erst beim nächsten Login eingelesen.
                            @hc-yami
                            Hc-Yami
                            #603
                            @thomas-braun wieder etwas gelernt, vielen Dank dafür. Leider löst das mein Update Problem noch nicht, weil iob diag eigentlichr echt gut aussieht:
                                                    v.2023-10-10
                               Static hostname: ioBroker
                                     Icon name: computer-vm
                                       Chassis: vm
                                Virtualization: microsoft
                              Operating System: Debian GNU/Linux 11 (bullseye)
                                        Kernel: Linux 5.10.0-19-amd64
                                  Architecture: x86-64
                            Installation:           microsoft
                            Kernel:                 x86_64
                            Userland:               amd64
                            Timezone:               Europe/Berlin (CET, +0100)
                            User-ID:                1000
                            X-Server:               false
                            Pending OS-Updates:     133
                            Pending iob updates:    0
                            Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                    /usr/bin/node           v18.17.1
                                                    /usr/bin/npm            9.6.7
                                                    /usr/bin/npx            9.6.7
                                                    /usr/bin/corepack       0.18.0
                            MEMORY:
                            Mem:            3.9G        2.3G        911M        0.0K        675M        1.3G
                            Swap:           974M          0B        974M
                            Total:          4.9G        2.3G        1.9G
                            Active iob-Instances:   30
                            ioBroker Core:          js-controller           5.0.12
                                                    admin                   6.12.0
                            Objects type: jsonl
                            States  type: jsonl
                            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            Objects:                9722
                            States:                 7869
                            26M     /opt/iobroker/iobroker-data/objects.jsonl
                            8.3M    /opt/iobroker/iobroker-data/objects.json.migrated
                            8.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                            2.5M    /opt/iobroker/iobroker-data/states.jsonl
                            1020K   /opt/iobroker/iobroker-data/states.json.migrated
                            1020K   /opt/iobroker/iobroker-data/states.json.bak.migrated
                            0       /opt/iobroker/iobroker-data/states.json.broken
                            • H Hc-Yami
                                                      v.2023-10-10
                                         Chassis: vm
                              Kernel:                 x86_64
                              Userland:               amd64
                              User-ID:                1000
                              X-Server:               false
                                                      /usr/bin/npm            9.6.7
                                                      /usr/bin/npx            9.6.7
                              MEMORY:
                              Swap:           974M          0B        974M
                                                      admin                   6.12.0
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                9722
                              States:                 7869
                              #604
                              HUST
                              Das ist auch ein Update-Problem...
                              sudo apt update
                              sudo apt full-upgrade
                              iob stop
                              iob fix
                              iob nodejs-update
                              sudo systemctl set-default multi-user.target
                              sudo reboot
                                HUST
                                sudo apt update
                                iob stop
                                iob fix
                                iob nodejs-update
                                sudo reboot
                                Hc-Yami
                                #605
                                @thomas-braun hatte tatsächlich nie manuell apt upgrade ausgeführt. Habe das nun nachgeholt. Irgendwie hatte ich im Kopf, dass man das nicht tun sollte, weil ioBroker das für einen erledigt. Faktisch praktisch ist aber apt update / upgrade und full-upgrade im ioBroker Umfeld okay?
                                Gehe gerade die Befehle durch. Nach apt upgrad ehabe ich schonmal keine Updates mehr. Jetzt möchte er aber gerade einen Neustart. :)
                                • H Hc-Yami
                                  #606
                                  Quatsch. Das wurde noch nie von einer Anwendung übernommen, die dafür gar nicht gedacht ist.
                                  Das hat mit dem Umfeld nix zu tun, das ist eine reine Sache des Betriebssystems.
                                  Natürlich. Deswegen hatte ich den oben schon vorweggenommen.
                                  H Thomas BraunT 2 Antworten Letzte Antwort
                                    Hc-Yami
                                    #607
                                    @thomas-braun läuft wie ein Länderspiel, dankeschön. :)
                                    Wo findet man die obligatorische Kaffeedose?
                                      #608
                                      Könnte mal einer der Raspberry 5 User einen vollständigen Lauf zeigen?
                                      Ich glaube das hakelt da noch an ein paar Stellen. Die würde ich gerne noch ausbügeln.
                                      L 1 Antwort Letzte Antwort
                                        L Online
                                        L Online
                                        Lucky_ESA
                                        #609
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                         Static hostname: iobroker
                                               Icon name: computer
                                                  Kernel: Linux 6.6.20+rpt-rpi-2712
                                            Architecture: arm64
                                        Model           : Raspberry Pi 5 Model B Rev 1.0
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : arm64
                                         23:01:51 up 4 days,  8:55,  1 user,  load average: 0.22, 0.38, 0.34
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                                       Local time: Mon 2024-04-01 23:01:51 CEST
                                                   Universal time: Mon 2024-04-01 21:01:51 UTC
                                                         RTC time: Mon 2024-04-01 21:01:51
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        /home/pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:            8.4G        5.5G        1.5G        5.5M        1.5G        2.9G
                                        Swap:           104M          0B        104M
                                        Total:          8.5G        5.5G        1.6G
                                                 8052 M total memory
                                                 5246 M used memory
                                                 4928 M active memory
                                                 1077 M inactive memory
                                                 1431 M free memory
                                                  161 M buffer memory
                                                 1314 M swap cache
                                                   99 M total swap
                                                    0 M used swap
                                                   99 M free swap
                                        Raspberry only:
                                        vc_gencmd_read_response returned -1
                                        error=1 error_msg="Command not registered"
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** FILESYSTEM ***
                                        udev                           devtmpfs  3.8G     0  3.8G   0% /dev
                                        tmpfs                          tmpfs     806M  5.2M  801M   1% /run
                                        /dev/mmcblk0p2                 ext4      117G  9.3G  102G   9% /
                                        tmpfs                          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                        tmpfs                          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                        /dev/mmcblk0p1                 vfat      510M   63M  448M  13% /boot/firmware
                                        192.168.2.56:/volume1/iobroker nfs       3.5T  2.8T  776G  79% /opt/iobroker/backups
                                        tmpfs                          tmpfs     806M     0  806M   0% /run/user/1000
                                        [Thu Mar 28 13:06:18 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Thu Mar 28 13:06:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
                                        [Thu Mar 28 13:06:22 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
                                        /                       /dev/mmcblk0p2                 ext4   rw,noatime
                                        |-/boot/firmware        /dev/mmcblk0p1                 vfat   rw,relatime,fmask=
                                        `-/opt/iobroker/backups 192.168.2.56:/volume1/iobroker nfs    rw,relatime,vers=3
                                        /var:
                                        2.0G    /var/
                                        1.4G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
                                        1.4G    /var/log
                                        343M    /var/cache
                                        Archived and active journals take up 1.3G in the file system.
                                        9.9G    /opt/iobroker/backups/
                                        951M    /opt/iobroker/iobroker-data/
                                        595M    /opt/iobroker/iobroker-data/files
                                        266M    /opt/iobroker/iobroker-data/backup-objects
                                        166M    /opt/iobroker/iobroker-data/files/vis-2
                                        82M     /opt/iobroker/iobroker-data/files/vis-2/static
                                        78M     /opt/iobroker/iobroker-data/objects.jsonl
                                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.3c875f4c.js.map
                                        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.b4e310b6.js.map
                                        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.6aba9d5c.js.map
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
                                        /usr/bin/nodejs         v18.20.0
                                        /usr/bin/node           v18.20.0
                                        /usr/bin/npm            10.5.0
                                        /usr/bin/npx            10.5.0
                                        /usr/bin/corepack       0.25.2
                                        nodejs:
                                          Installed: 18.20.0-1nodesource1
                                          Candidate: 18.20.0-1nodesource1
                                          Version table:
                                         *** 18.20.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                                             18.19.1-1nodesource1 1001
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                             18.19.0-1nodesource1 1001
                                             18.18.2-1nodesource1 1001
                                             18.18.1-1nodesource1 1001
                                             18.18.0-1nodesource1 1001
                                             18.17.1-1nodesource1 1001
                                             18.17.0-1nodesource1 1001
                                             18.16.1-1nodesource1 1001
                                             18.16.0-1nodesource1 1001
                                             18.15.0-1nodesource1 1001
                                             18.14.2-1nodesource1 1001
                                             18.14.1-1nodesource1 1001
                                             18.14.0-1nodesource1 1001
                                             18.13.0+dfsg1-1 500
                                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                             18.13.0-1nodesource1 1001
                                             18.12.0-1nodesource1 1001
                                             18.11.0-1nodesource1 1001
                                             18.10.0-1nodesource1 1001
                                             18.9.1-1nodesource1 1001
                                             18.9.0-1nodesource1 1001
                                             18.8.0-1nodesource1 1001
                                             18.7.0-1nodesource1 1001
                                             18.6.0-1nodesource1 1001
                                             18.5.0-1nodesource1 1001
                                             18.4.0-1nodesource1 1001
                                             18.3.0-1nodesource1 1001
                                             18.2.0-1nodesource1 1001
                                             18.1.0-1nodesource1 1001
                                             18.0.0-1nodesource1 1001
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        js-controller:  5.0.19
                                        admin:          6.15.2
                                        javascript:     7.11.1
                                        Adapters from github:   9
                                        Adapter State
                                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                        + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
                                        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                                        + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                                        + system.adapter.hekr.0                   : hekr                  : iobroker                                 -  enabled
                                        + system.adapter.hiob.0                   : hiob                  : iobroker                                 -  enabled, port: 8097
                                        + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
                                        + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                                        + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                                        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                        + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                        + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
                                        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                        + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
                                          system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
                                        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
                                        + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                                        + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
                                        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                                        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                                          system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                        + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                                        + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                        + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                                        + instance is alive
                                        Active repo(s): beta
                                        Used repository: beta
                                        Adapter    "admin"        : 6.15.2   , installed 6.15.2
                                        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                        Adapter    "email"        : 1.2.2    , installed 1.2.2
                                        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                                        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                        Adapter    "hekr"         : 0.0.6    , installed 0.0.6
                                        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                        Adapter    "ical"         : 1.14.3   , installed 1.14.3
                                        Adapter    "imap"         : 0.1.3    , installed 0.1.3
                                        Adapter    "info"         : 2.0.0    , installed 2.0.0
                                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                        Adapter    "javascript"   : 7.11.1   , installed 7.11.1
                                        Controller "js-controller": 5.0.19   , installed 5.0.19
                                        Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
                                        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
                                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                        Adapter    "onvif"        : 1.1.3    , installed 1.1.3
                                        Adapter    "parcel"       : 0.2.7    , installed 0.2.7
                                        Adapter    "socketio"     : 6.6.1    , installed 6.6.1
                                        Adapter    "telegram"     : 3.1.0    , installed 3.1.0
                                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                        Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                                        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
                                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                                        Adapter    "vis-2"        : 2.9.48   , installed 2.9.47 [Updatable]
                                        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                                        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                        Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                                        Adapter    "web"          : 6.2.5    , installed 6.2.4  [Updatable]
                                        Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                        Adapter    "ws"           : 2.5.11   , installed 2.5.11
                                        Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
                                        Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
                                        Objects and States
                                        Objects:        29996
                                        States:         25284
                                        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                        Reading package lists... Done
                                        Pending Updates: 16
                                        tcp        0      0 0.0.0.0:38893           0.0.0.0:*               LISTEN      103        6574       1059/rpc.statd
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7524       1181/io.mqtt.0
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3950       815/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6370       815/iobroker.js-con
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8253       1/init
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6304       828/sshd: /usr/sbin
                                        tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       4583563    939275/io.hm-rpc.1
                                        tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       4583690    939361/io.hm-rpc.2
                                        tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       4578722    938471/io.hm-rpc.0
                                        tcp        0      0 0.0.0.0:35019           0.0.0.0:*               LISTEN      0          7907678    -
                                        tcp6       0      0 :::45649                :::*                    LISTEN      0          7907680    -
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          7274       1/init
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6306       828/sshd: /usr/sbin
                                        tcp6       0      0 :::8095                 :::*                    LISTEN      1001       10781      2307/io.hiobs.0
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9186       1977/io.simple-api.
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9713       1325/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6447       912/io.admin.0
                                        tcp6       0      0 :::8097                 :::*                    LISTEN      1001       562465     120279/io.hiob.0
                                        tcp6       0      0 :::35675                :::*                    LISTEN      103        6578       1059/rpc.statd
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9289       1/init
                                        udp        0      0 127.0.0.1:811           0.0.0.0:*                           0          8263       1059/rpc.statd
                                        udp        0      0 0.0.0.0:42082           0.0.0.0:*                           104        6217       687/avahi-daemon: r
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6215       687/avahi-daemon: r
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       8520       1212/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       8521       1212/io.tuya.0
                                        udp        0      0 0.0.0.0:35386           0.0.0.0:*                           0          7907677    -
                                        udp        0      0 0.0.0.0:44296           0.0.0.0:*                           103        6572       1059/rpc.statd
                                        udp6       0      0 :::40946                :::*                                103        6576       1059/rpc.statd
                                        udp6       0      0 :::111                  :::*                                0          7276       1/init
                                        udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          9281930    788/NetworkManager
                                        udp6       0      0 :::5353                 :::*                                104        6216       687/avahi-daemon: r
                                        udp6       0      0 :::47552                :::*                                0          7907679    -
                                        udp6       0      0 :::43790                :::*                                104        6218       687/avahi-daemon: r
                                        2024-04-01 22:57:59.799  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
                                        2024-04-01 22:57:59.836  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
                                        2024-04-01 23:00:00.006  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Gartenbeleuchtung: Gartenbeleuchtung
                                        2024-04-01 23:00:00.009  - info: javascript.0 (960) script.js.Scripts.Allgemein.Prüfung_Regen: Start Regen Check
                                        2024-04-01 23:00:00.024  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 2030238
                                        2024-04-01 23:00:00.049  - info: javascript.0 (960) script.js.Scripts.Allgemein.Astro: Astro: Gültige Zeiten: [aktueller Tag: 0] | [nächster Tag: 14] | [Aktualisiert: 0] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht
                                        2024-04-01 23:00:00.891  - info: javascript.0 (960) script.js.Scripts.Allgemein.Dachfenster_automatisch: Der Server Karte ist Online!!!
                                        2024-04-01 23:00:01.531  - info: daswetter.0 (2030238) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.0, js-controller: 5.0.19
                                        2024-04-01 23:00:04.032  - info: host.iobroker instance system.adapter.ical.0 started with pid 2030479
                                        2024-04-01 23:00:05.135  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
                                        2024-04-01 23:00:05.560  - info: ical.0 (2030479) starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.0, js-controller: 5.0.19
                                        2024-04-01 23:00:06.323  - info: ical.0 (2030479) processing URL: Muell https://calendar.google.com/calendar/ical/c241cf4fcd482c213a45430df0868c1653d1e8d1b854ece0b0863fdc99bb146b%40group.calendar.google.com/public/basic.ics
                                        2024-04-01 23:00:06.428  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
                                        2024-04-01 23:00:11.538  - info: ical.0 (2030479) Terminated (NO_ERROR): Without reason
                                        2024-04-01 23:00:12.062  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                        2024-04-01 23:00:12.071  - info: daswetter.0 (2030238) still wrong data structure from server received! repaired...
                                        2024-04-01 23:00:14.767  - info: daswetter.0 (2030238) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2024-04-01 23:00:15.272  - info: daswetter.0 (2030238) cleaned everything up...
                                        2024-04-01 23:00:15.278  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2024-04-01 23:00:21.417  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Klingenarbeitszeit wurde aktualisiert:  531.9
                                        2024-04-01 23:00:21.440  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Temperatur Akku hat sich geändert: 11.6
                                        2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Worx: HTML Aktualisierung: worx.0.202130266301009363E0.mower.status - 1
                                        2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Trigger Aktualisierung Worx!1
                                        2024-04-01 23:00:21.463  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
                                        2024-04-01 23:00:21.498  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
                                        iob diag has finished.
                                        Press any key for a summary
        v.2023-10-10
                                               Icon name: computer
                                            Architecture: arm64
                                        Kernel:                 aarch64
                                        Userland:               arm64
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending OS-Updates:     16
                                        Nodejs-Installation:    /usr/bin/nodejs         v18.20.0
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
                                        Recommended versions are nodejs 18.20.0 and npm 10.5.0
                                        MEMORY:
                                        Mem:            8.4G        5.4G        1.4G        5.5M        1.8G        3.1G
                                        Swap:           104M          0B        104M
                                        Total:          8.5G        5.4G        1.5G
                                        Active iob-Instances:   47
                                        ioBroker Core:          js-controller           5.0.19
        admin                   6.15.2
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                29996
                                        States:                 25284
                                        87M     /opt/iobroker/iobroker-data/objects.jsonl
                                        15M     /opt/iobroker/iobroker-data/states.jsonl
                                        === Mark text until here for copying ===
                                        pi@iobroker:~ $
                                        • L Lucky_ESA
                                          Skript v.2023-10-10
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : arm64
                                          CPU threads: 4
                                          Current issues:
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          /home/pi
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           104M          0B        104M
                                                   8052 M total memory
                                                   5246 M used memory
                                                   1431 M free memory
                                                    161 M buffer memory
                                                   1314 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          *** FILESYSTEM ***
                                          /var:
                                          2.0G    /var/
                                          1.4G    /var/log
                                          343M    /var/cache
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.5.0
                                          /usr/bin/npx            10.5.0
                                          nodejs:
                                            Version table:
                                               18.13.0+dfsg1-1 500
                                          Errors in npm tree:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.15.2
                                          javascript:     7.11.1
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        29996
                                          States:         25284
                                          Pending Updates: 16
        v.2023-10-10
                                                 Icon name: computer
                                              Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               arm64
                                          User-ID:                1000
                                          X-Server:               false
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
                                          MEMORY:
                                          Swap:           104M          0B        104M
        admin                   6.15.2
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                29996
                                          States:                 25284
                                          pi@iobroker:~ $
                                          #610
                                          @lucky_esa
                                          Das kommt vermutlich bei dir mit Fehler um die Ecke, oder?
                                          vcgencmd mem_oom
