  4. Problem Deconz Bookworm
73 Beiträge 7 Kommentatoren 11.3k Aufrufe 6 Beobachtet
    @vandura sagte in Problem Deconz Bookworm:
    aber kann ja nicht sein, das ich keinen reboot mehr machen kann......
    Nö, das sollte aber auch damit nix zu tun haben.
    systemctl status deconz*
    sagt?
    VanduraV Offline
    VanduraV Offline
    Vandura
    @thomas-braun sagte in Problem Deconz Bookworm:
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabl>
         Active: active (running) since Sat 2023-10-28 12:57:19 CEST; 2h 7min ago
       Main PID: 552 (deCONZ)
          Tasks: 5 (limit: 8740)
            CPU: 4min 40.254s
         CGroup: /system.slice/deconz.service
                 └─552 /usr/bin/deCONZ -platform minimal --http-port=80
    Oct 28 12:57:19 raspberrypi systemd[1]: Started deconz.service - deCONZ: ZigBee>
    Oct 28 12:57:23 raspberrypi deCONZ[552]: QStandardPaths: XDG_RUNTIME_DIR not se>
    Oct 28 12:57:25 raspberrypi deCONZ[552]: libpng warning: iCCP: known incorrect >
    Oct 28 12:57:31 raspberrypi deCONZ[552]: This plugin does not support propagate>
    Oct 28 12:57:33 raspberrypi deCONZ[552]: This plugin does not support propagate>
    lines 1-15/15 (END)...skipping...
         Loaded: loaded (/lib/systemd/system/deconz.service; enabled; preset: enabled)
            CPU: 4min 40.254s
    Oct 28 12:57:19 raspberrypi systemd[1]: Started deconz.service - deCONZ: ZigBee gateway -- REST API.
    Oct 28 12:57:23 raspberrypi deCONZ[552]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
    Oct 28 12:57:25 raspberrypi deCONZ[552]: libpng warning: iCCP: known incorrect sRGB profile
    Oct 28 12:57:31 raspberrypi deCONZ[552]: This plugin does not support propagateSizeHints()
    Oct 28 12:57:33 raspberrypi deCONZ[552]: This plugin does not support propagateSizeHints()
    Raspberry 4 - 8GB / 500 GB Festplatte mit IoBroker! 1xConbee 2, 15xAQARA Door Sensoren,2xSonoff Door Sensor, 2xSonoff Pov2, 2xAQARA Watersensoren, 3xIKEA TRÅDFRI Bewegungsmelder, 5xIKEA TRÅDFRI Repeater, 1x IKEA TRÅDFRI Treiber 10w, 10xTeckin Steckdosen mit Tasmota-Flash, 1xShelly SHSW-1, 2xAQARA Taster, 4xAlexa...usw.
    • VanduraV Vandura
              CPU: 4min 40.254s
              CPU: 4min 40.254s
      @vandura
      Okay.
      Und nach einem Reboot fehlen da Zigbee-Geräte?
      VanduraV 1 Antwort Letzte Antwort
        @vandura
        Okay.
        VanduraV Offline
        VanduraV Offline
        Vandura
        @thomas-braun Nein, sie sind alle noch vorhanden, aber reagieren nicht mehr und gehen alle auf open / true.....rechable sind alle aber müssen dur knöpfendrücken neu registriert werden behalten aber zum Glück die alte Bezeichnung und Adresse
        • VanduraV Vandura
          @vandura
          Und wie sieht das in der Phoscon App aus?
            @vandura
            VanduraV Offline
            VanduraV Offline
            Vandura
            @thomas-braun Auch alle vorhanden und nicht augegraut, also das sie nicht erreichbar wäre......alles wie es sein muß
            • VanduraV Vandura
              Den Satz verstehe ich nicht.
                VanduraV Offline
                VanduraV Offline
                Vandura
                Beispiel.......sollten sie nicht erreichbar sein, werden sie schwach grau.....
                • VanduraV Vandura
                  @vandura
                  Und die Sensoren, die hier als 'geschlossen' geführt werden tauchen im Adapter als 'geöffnet' auf?
                    @vandura
                    VanduraV Offline
                    VanduraV Offline
                    Vandura
                    @thomas-braun nein, sie tauchen überall als geöffnet auf, ist ein Bild, wo ich sie schon wieder angelernt habe
                    • VanduraV Vandura
                      Dann ist es ein Ding für Phoscon/Deconz. Der Adapter verarbeitet ja nur das was da vom Stick angeliefert wird. Wenn das nicht stimmt...
                        VanduraV Offline
                        VanduraV Offline
                        Vandura
                        @thomas-braun ok, dann werde ich mal dort den Kundendienst kontaktieren.....hätte ja sein können das in der Konfiguration irgend etwas krumm ist....Danke trotzdem für deine Geduld und Hilfe.....👍
                        Thomas BraunT W 2 Antworten Letzte Antwort
                        • VanduraV Vandura
                          @vandura
                          Nur der Neugierde halber:
                          sudo apt update
                          apt policy deconz*
                          sagt?
                            @vandura
                            sudo apt update
                            apt policy deconz*
                            sagt?
                            VanduraV Offline
                            VanduraV Offline
                            Vandura
                            pi@raspberrypi:~ $ sudo apt update
                            Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB        ]
                            Hit:4 http://phoscon.de/apt/deconz bookworm InRelease
                            Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                            Get:7 http://deb.debian.org/debian-security bookworm-security/main armhf Package        s [83.7 kB]
                            Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 Package        s [86.1 kB]
                            Fetched 218 kB in 3s (84.0 kB/s)
                            Reading package lists... Done
                            All packages are up to date.
                            W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                            pi@raspberrypi:~ $ apt policy deconz*
                            deconz:
                             Installed: 2.23.02-debian-buster-stable
                             Candidate: 2.23.02-debian-buster-stable
                             Version table:
                            *** 2.23.02-debian-buster-stable 500
                                   500 http://phoscon.de/apt/deconz bookworm/main arm64 Packages
                            deconz-dev:
                             Installed: (none)
                             Version table:
                            pi@raspberrypi:~ $
                            • VanduraV Vandura
                              W Online
                              W Online
                              Wildbill
                              @vandura Nur zur Info. Auch mit dem Conbee und Phoscon/Deconz brauchen batteriebetriebene Geräte (wie Sensoren beispielsweise) teilweise längere Zeit, bis sie sich wieder mit dem aktuellen Stand bei Deconz melden. Ich habe da zwei Ikea-Schalter, die erst nach Stunden wieder mal einen Zustand melden. Danach dann aber zuverlässig.
                              Wenn Du sofort nach einem Neustart den aktuellen Status eines Sensors willst, musst Du entweder die Pairung-taste einmal kurz drücken oder eben das Fenster einmal auf- und wieder zumachen.
                              Wenn die Sensoren im Sekundentakt immer senden würden, könntest Du viermal am Tag die Batterien wechseln. So wird eben über längere Zeit mal ein Status gesendet, ansonsten nur bei Status-Änderungen.
                              Das ist weder ein fehler von Deconz oder iobroker, sondern ganz normal.
                              Gruss, Jürgen
                              Thomas BraunT VanduraV 2 Antworten Letzte Antwort
                              • W Wildbill
                                Gruss, Jürgen
                                @wildbill
                                Das stimmt. Hatte ich aber als bekannt vorausgesetzt.
                                • W Wildbill
                                  Gruss, Jürgen
                                  VanduraV Offline
                                  VanduraV Offline
                                  Vandura
                                  schrieb am zuletzt editiert von Vandura
                                  @wildbill Ist ja richtig, aber das war vorher nicht so, da waren nach einem reboot alle Betriebsbereit und haben reagiert.
                                  und das öffnen und schließen, hat auch nichts gebracht.....Pairingtaste kurz auch nicht sondern erst ein langer Druck als wenn ich einen neuen anlernen möchte......
                                  W 1 Antwort Letzte Antwort
                                  • VanduraV Vandura
                                    W Online
                                    W Online
                                    Wildbill
                                    @vandura Das war schon immer so und war nie anders. Batteriebetriebene Geräte reagieren auf ihre Status-Änderung oder wenn man sie manuell anstößt, indem man die Pairing-Taste drückt. Daran hat sich nie was geändert. Wie sollte es auch? Wenn es je anders gewesen wäre, dann hättest Du einen Berg leerer Batterien bei Dir rumliegen.
                                    Also entweder meinst Du etwas komplett anderes als wir, oder wir verstehen nicht, worum es Dir genau geht. Dann versuch doch bitte mal genau zu beschreiben, worin Dein jetziges Problem besteht, dass erst nach einem Update aufgetreten ist und vor allem, wie es vor dem Update genau war.
                                    Gruss, Jürgen
                                    • W Wildbill
                                      Gruss, Jürgen
                                      VanduraV Offline
                                      VanduraV Offline
                                      Vandura
                                      @wildbill
                                      Wir verstehen uns schon richtig.
                                      Der Zustand vor dem Update, war: Status der Sensoren auch nach einem reboot wie vor dem reboot, kein einziger Sensor hat seinen Zustand von false auf true geändert und war auch Betriebsbereit und hat reagiert wenn er benutzt wurde.
                                      Zustand jetzt: nach dem reboot gehen alle Sensoren auf true und reagieren auch nicht wenn sie benutzt werden oder auf kurzen Druck auf pairing. Erst ein langer Druck auf pairing mit deinschalten in der Deconz Oberfläche erweckt den Sensor wieder zum leben.
                                      Und großen Batterie Verbrauch habe ich nie gehabt und das System lief vorher schon über zwei Jahren mit diversen reboots.
                                      • VanduraV Vandura
                                        @wildbill
                                        W Online
                                        W Online
                                        Wildbill
                                        @vandura Redest Du von "falschen" Zuständen nach einem reboot in iobroker oder schon in Deconz/Phoscon?
                                        Was rebootest Du dabei? iobroker oder deconz? Oder ist es egal, welches davon?
                                        Gruss, Jürgen
                                        • W Wildbill
                                          Gruss, Jürgen
                                          VanduraV Offline
                                          VanduraV Offline
                                          Vandura
                                          @wildbill Es kam als ich den Iobroker rebootet habe und danach als test auch wo ich den deconz rebootet habe.
                                          Kann es sein das der Deconz jetzt von irgendwo her sich auch rebootet wenn ich den Iobroker reboote....kann ja sein das es daran liegt.....?
