  3. Off Topic
  4. Proxmox
  5. Proxmox LXC mit Frigate
    6.3k
Geplant Angeheftet Gesperrt Verschoben Proxmox
176 Beiträge 16 Kommentatoren 67.1k Aufrufe 21 Beobachtet
  • E Offline
    exitus
    mein coral cpu ist das was habe ich gemacht habe unter proxmox wie auf der seite von coral installiert
    ausgabe lsusb
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 002: ID 1a6e:089a Global Unichip Corp.
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 003: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
    Bus 001 Device 002: ID 0451:16c8 Texas Instruments, Inc. CC2538 USB CDC
    ls -l /dev/bus/usb/002/002
    crw-rw-r-- 1 root plugdev 189, 129 May 24 16:13 /dev/bus/usb/002/002
    lxc 117.conf
    arch: amd64
    cores: 6
    hostname: frigate
    memory: 8096
    net0: name=eth0,bridge=vmbr0,firewall=1,gw=172.16.0.1,hwaddr=22:88:33:2D:28:77,ip=172.1>
    ostype: debian
    rootfs: local-lvm:vm-117-disk-1,size=30G
    swap: 512
    lxc.cgroup.devices.allow: c 226:0 rwm
    lxc.cgroup.devices.allow: c 226:128 rwm
    lxc.cgroup.devices.allow: c 29:0 rwm
    lxc.cgroup.devices.allow: c 189:* rwm
    lxc.apparmor.profile: unconfined
    lxc.cgroup.devices.allow: a
    lxc.mount.entry: /dev/dri/renderD128 dev/dri/renderD128 none bind,optional,create=file >
    lxc.mount.entry: /dev/bus/usb/002/ dev/bus/usb/002/ none bind,optional,create=dir 0, 0
    lxc.cap.drop:
    lxc.mount.auto: cgroup:rw
    frigate conf
    database:
      path: /media/frigate/db/frigate.db
    detectors:
      coral:
        type: edgetpu
        device: usb
    ui:
      use_experimental: false
      live_mode: mse
    mqtt:
      host: 172.16.0.10
      port: 1689
      user: so
      password: xxxxx
    record:
      enabled: True
      retain:
        days: 7
        mode: all
      events:
        retain:
          default: 30
    snapshots:
      enabled: True
      timestamp: False
      bounding_box: true
      retain:
        default: 90
    detect:
      stationary:
        max_frames:
          objects:
            person: 1200
    cameras:
      back1:
        ffmpeg:
          inputs:
            - path: rtsp://admin:xxxxxx@172.16.0.177:554/channel=2
              roles:
                - detect
                - rtmp
            - path: rtsp://admin:xxxxx@172.16.0.177:554/channel=1
              roles:
                - record
          output_args:
            record: -f segment -segment_time 10 -segment_format mp4 -reset_timestamps 1 -strftime 1 -c:v copy -c:a aac
        detect:
          width: 1280
          height: 720
        objects:
          track:
            - person
            - car
        record:
          events:
            required_zones:
              - street
              - all
        zones:
          street:
            coordinates: 352,544,416,519,476,513,502,334,472,199,391,107,325,127,261,136,62,162,45,347,59,430,207,535
            objects:
              - car
          all:
            objects:
              - person
        motion:
          mask:
            - 254,79,503,44,848,24,1113,43,1111,0,439,0,291,0,226,0,0,0,0,159
      back:
        ffmpeg:
          inputs:
            - path: rtsp://admin:xxxxxx@172.16.0.147:554/Streaming/Channels/102?transportmode=unicast&profile=Profile_2
              roles:
                - detect
                - rtmp
              roles:
                - record
        detect:
          width: 1280
          height: 720
        objects:
          track:
            - person
            - car
        record:
          events:
            required_zones:
              - street
              - all
        zones:
          street:
            coordinates: 470,676,592,583,1051,569,1257,341,1147,254,1063,247,779,299,536,378,476,471,389,399,332,473,241,427,293,647
            objects:
              - person
          #all:
            #coordinates: 472,57,526,64,1031,129,1060,95,941,30,504,26,376,0,175,0,0,0,33,169,191,143,360,110
            #objects:
             # - person
    ohne edge tpu ging es , habe detector auf edgetpu geänder seit dem habe ich kein bild kommt so für 1 sekunde und wider alles schwarz wie auf dem bild
    mein log vom docker
    2023-05-24 16:34:48.086320180
    2023-05-24 16:34:53.211082426  [2023-05-24 16:34:53] frigate.watchdog               INFO    : Detection appears to have stopped. Exiting Frigate...
    s6-rc: info: service legacy-services: stopping
    s6-rc: info: service legacy-services successfully stopped
    s6-rc: info: service nginx: stopping
    s6-rc: info: service go2rtc-healthcheck: stopping
    2023-05-24 16:34:53.227039323  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
    s6-rc: info: service go2rtc-healthcheck successfully stopped
    2023-05-24 16:34:53.305962172  [INFO] Service NGINX exited with code 0 (by signal 0)
    s6-rc: info: service nginx successfully stopped
    s6-rc: info: service nginx-log: stopping
    s6-rc: info: service frigate: stopping
    2023-05-24 16:34:53.309352767  [2023-05-24 16:34:53] frigate.app                    INFO    : Stopping...
    s6-rc: info: service nginx-log successfully stopped
    2023-05-24 16:34:53.311354844  [2023-05-24 16:34:53] frigate.watchdog               INFO    : Exiting watchdog...
    2023-05-24 16:34:53.312088389  [2023-05-24 16:34:53] frigate.storage                INFO    : Exiting storage maintainer...
    2023-05-24 16:34:53.312100611  [2023-05-24 16:34:53] frigate.stats                  INFO    : Exiting stats emitter...
    2023-05-24 16:34:53.312107805  [2023-05-24 16:34:53] frigate.record                 INFO    : Exiting recording maintenance...
    2023-05-24 16:34:53.320612754  [2023-05-24 16:34:53] frigate.record                 INFO    : Exiting recording cleanup...
    2023-05-24 16:34:53.321374794  [2023-05-24 16:34:53] frigate.events                 INFO    : Exiting event cleanup...
    2023-05-24 16:34:53.321393162  [2023-05-24 16:34:53] frigate.object_processing      INFO    : Exiting object processor...
    2023-05-24 16:34:53.571418465  [2023-05-24 16:34:53] frigate.comms.ws               INFO    : Exiting websocket client...
    2023-05-24 16:34:54.249977376  [2023-05-24 16:34:54] frigate.events                 INFO    : Exiting event processor...
    2023-05-24 16:34:54.250550076  [2023-05-24 16:34:54] peewee.sqliteq                 INFO    : writer received shutdown request, exiting.
    2023-05-24 16:34:54.259106288  [2023-05-24 16:34:54] watchdog.back                  INFO    : Terminating the existing ffmpeg process...
    2023-05-24 16:34:54.259777814  [2023-05-24 16:34:54] watchdog.back                  INFO    : Waiting for ffmpeg to exit gracefully...
    2023-05-24 16:34:54.266624376  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Terminating the existing ffmpeg process...
    2023-05-24 16:34:54.266775374  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Waiting for ffmpeg to exit gracefully...
    2023-05-24 16:34:54.383145698  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Terminating the existing ffmpeg process...
    2023-05-24 16:34:54.383311572  [2023-05-24 16:34:54] watchdog.back1                 INFO    : Waiting for ffmpeg to exit gracefully...
    2023-05-24 16:34:54.415749456  [2023-05-24 16:34:54] watchdog.back                  INFO    : Terminating the existing ffmpeg process...
    2023-05-24 16:34:54.415853799  [2023-05-24 16:34:54] watchdog.back                  INFO    : Waiting for ffmpeg to exit gracefully...
    2023-05-24 16:34:54.637141769  [2023-05-24 16:34:54] frigate.output                 INFO    : exiting output process...
    2023-05-24 16:34:58.559268884  /usr/lib/python3.9/multiprocessing/resource_tracker.py:216: UserWarning: resource_tracker: There appear to be 13 leaked shared_memory objects to clean up at shutdown
    2023-05-24 16:34:58.559280338    warnings.warn('resource_tracker: There appear to be %d '
    2023-05-24 16:34:58.560386418  [INFO] Service Frigate exited with code 0 (by signal 0)
    s6-rc: info: service frigate successfully stopped
    s6-rc: info: service go2rtc: stopping
    s6-rc: info: service frigate-log: stopping
    2023-05-24 16:34:58.563280091  exit OK
    s6-rc: info: service frigate-log successfully stopped
    2023-05-24 16:34:58.570563372  [INFO] The go2rtc service exited with code 0 (by signal 0)
    s6-rc: info: service go2rtc successfully stopped
    s6-rc: info: service go2rtc-log: stopping
    s6-rc: info: service go2rtc-log successfully stopped
    s6-rc: info: service log-prepare: stopping
    s6-rc: info: service s6rc-fdholder: stopping
    s6-rc: info: service log-prepare successfully stopped
    s6-rc: info: service legacy-cont-init: stopping
    s6-rc: info: service s6rc-fdholder successfully stopped
    s6-rc: info: service legacy-cont-init successfully stopped
    s6-rc: info: service fix-attrs: stopping
    s6-rc: info: service fix-attrs successfully stopped
    s6-rc: info: service s6rc-oneshot-runner: stopping
    s6-rc: info: service s6rc-oneshot-runner successfully stopped
    s6-rc: info: service s6rc-fdholder: starting
    s6-rc: info: service s6rc-oneshot-runner: starting
    s6-rc: info: service s6rc-oneshot-runner successfully started
    s6-rc: info: service fix-attrs: starting
    s6-rc: info: service s6rc-fdholder successfully started
    s6-rc: info: service fix-attrs successfully started
    s6-rc: info: service legacy-cont-init: starting
    s6-rc: info: service legacy-cont-init successfully started
    s6-rc: info: service log-prepare: starting
    s6-rc: info: service log-prepare successfully started
    s6-rc: info: service nginx-log: starting
    s6-rc: info: service go2rtc-log: starting
    s6-rc: info: service frigate-log: starting
    s6-rc: info: service nginx-log successfully started
    s6-rc: info: service go2rtc-log successfully started
    s6-rc: info: service go2rtc: starting
    s6-rc: info: service frigate-log successfully started
    s6-rc: info: service go2rtc successfully started
    s6-rc: info: service go2rtc-healthcheck: starting
    s6-rc: info: service frigate: starting
    s6-rc: info: service go2rtc-healthcheck successfully started
    s6-rc: info: service frigate successfully started
    s6-rc: info: service nginx: starting
    2023-05-24 16:35:03.269511637  [INFO] Preparing go2rtc config...
    s6-rc: info: service nginx successfully started
    s6-rc: info: service legacy-services: starting
    2023-05-24 16:35:03.274350536  [INFO] Starting Frigate...
    2023-05-24 16:35:03.274655883  [INFO] Starting NGINX...
    s6-rc: info: service legacy-services successfully started
    2023-05-24 16:35:03.544117376  [INFO] Starting go2rtc...
    2023-05-24 16:35:03.635953359  16:35:03.635 INF go2rtc version 1.2.0 linux/amd64
    2023-05-24 16:35:03.636486320  16:35:03.636 INF [api] listen addr=:1984
    2023-05-24 16:35:03.636814435  16:35:03.636 INF [rtsp] listen addr=:8554
    2023-05-24 16:35:03.637127674  16:35:03.637 INF [srtp] listen addr=:8443
    2023-05-24 16:35:03.637534711  16:35:03.637 INF [webrtc] listen addr=:8555
    2023-05-24 16:35:04.485742533  [2023-05-24 16:35:04] frigate.app                    INFO    : Starting Frigate (0.12.0-da3e197)
    2023-05-24 16:35:04.527219793  [2023-05-24 16:35:04] peewee_migrate                 INFO    : Starting migrations
    2023-05-24 16:35:04.531970132  [2023-05-24 16:35:04] peewee_migrate                 INFO    : There is nothing to migrate
    2023-05-24 16:35:04.549606158  [2023-05-24 16:35:04] detector.coral                 INFO    : Starting detection process: 429
    2023-05-24 16:35:04.554122319  [2023-05-24 16:35:04] frigate.app                    INFO    : Output process started: 431
    2023-05-24 16:35:04.561305867  [2023-05-24 16:35:04] frigate.app                    INFO    : Camera processor started for back1: 437
    2023-05-24 16:35:04.570196340  [2023-05-24 16:35:04] frigate.app                    INFO    : Camera processor started for back: 439
    2023-05-24 16:35:04.576351891  [2023-05-24 16:35:04] frigate.app                    INFO    : Capture process started for back1: 440
    2023-05-24 16:35:04.582484533  [2023-05-24 16:35:04] frigate.app                    INFO    : Capture process started for back: 444
    2023-05-24 16:35:13.274499111  [INFO] Starting go2rtc healthcheck service...
    WalW 1 Antwort Letzte Antwort
    • E exitus
      ausgabe lsusb
      lxc 117.conf
      arch: amd64
      cores: 6
      hostname: frigate
      memory: 8096
      ostype: debian
      swap: 512
      lxc.cap.drop:
      frigate conf
      database:
      detectors:
        coral:
          type: edgetpu
          device: usb
      ui:
        live_mode: mse
      mqtt:
        host: 172.16.0.10
        port: 1689
        user: so
        password: xxxxx
      record:
        enabled: True
        retain:
          days: 7
          mode: all
        events:
          retain:
            default: 30
      snapshots:
        enabled: True
        timestamp: False
        bounding_box: true
        retain:
          default: 90
      detect:
        stationary:
          max_frames:
            objects:
              person: 1200
      cameras:
        back1:
          ffmpeg:
            inputs:
                roles:
                  - detect
                  - rtmp
                roles:
                  - record
            output_args:
          detect:
            width: 1280
            height: 720
          objects:
            track:
              - person
              - car
          record:
            events:
              required_zones:
                - street
                - all
          zones:
            street:
              objects:
                - car
            all:
              objects:
                - person
          motion:
            mask:
        back:
          ffmpeg:
            inputs:
                roles:
                  - detect
                  - rtmp
                roles:
                  - record
          detect:
            width: 1280
            height: 720
          objects:
            track:
              - person
              - car
          record:
            events:
              required_zones:
                - street
                - all
          zones:
            street:
              objects:
                - person
            #all:
              #objects:
               # - person
      mein log vom docker
      WalW Offline
      WalW Offline
      Wal
      schrieb am zuletzt editiert von Wal
      @exitus ,
      in der docker.yml hast du die coral usb auch durchgereicht ?
      Die Treiber im Proxmox-Host sind auch installiert ?
      Walter
      DoorIO-Adapter
      E 1 Antwort Letzte Antwort
      • WalW Wal
        @exitus ,
        exitus
        schrieb am zuletzt editiert von exitus
        @wal proxmox host sind die treiber installiert die ausgabe von lsusb ist vom host
        mit der rechte meinst du doch
        /dev/bus/usb:/dev/bus/usb
        habe frigate so getstartet
        docker run --name frigate --privileged --shm-size=1g --mount type=tmpfs,target=/tmp/cache,tmpfs-size=2000000000 -v /shared/frigate/config:/config:rw -v /dev/bus/usb:/dev/bus/usb -v /etc/localtime:/etc/localtime:ro -v /shared/frigate:/media/frigate/clips:rw -v /shared/frigate/recordings:/media/frigate/recordings:rw -v /home/frigate:/media/frigate/db:rw --device-cgroup-rule="c 189:* rmw" --device=/dev/dri/renderD128 -d -p 5000:5000 -e FRIGATE_RTSP_PASSWORD='elajelaj-61' ghcr.io/blakeblackshear/frigate:stable
        • E exitus
          WalW Offline
          WalW Offline
          Wal
          @exitus sagte in Proxmox LXC mit Frigate:
          das ist mir schon klar, heisst aber nicht das du das gemacht hast:
          echo "deb https://packages.cloud.google.com/apt coral-edgetpu-stable main" | sudo tee /etc/apt/sources.list.d/coral-edgetpu.list
          curl https://packages.cloud.google.com/apt/doc/apt-key.gpg | sudo apt-key add -
          sudo apt-get update
          sudo apt-get install libedgetpu1-std gasket-dkms
          und der aktuelle pve-kernel-header muss vorher auch installiert sein, wobei der gasket-dkms evtl. auch nur für die PCI Version installiert werden muss, weiß ich aber nicht da ich keine USB-Verdion habe.
          Walter
          DoorIO-Adapter
          • WalW Wal
            sudo apt-get update
            exitus
            #66
            @wal
            sudo apt-get update
            Install the Edge TPU runtime:
            das habe ich gemacht unter proxmox host und im container
            • E exitus
              @wal
              sudo apt-get update
              WalW Offline
              WalW Offline
              Wal
              #67
              @exitus ,
              ok da würde ich mal auf github beim frigate Projekt nachfragen, da man aus dem Log nicht viel herausziehen kann.
              Walter
              DoorIO-Adapter
              • R Radi
                @wal sagte in Proxmox LXC mit Frigate:
                cat /config/config.yml
                Hallo Walter,
                das ganze verwirrt mich jetzt etwas. Die Ausgabe ist:
                cat: /config/config.yml: No such file or directory
                will ich das Verzeichnis erzeugen, kommt das:
                mkdir config
                mkdir: cannot create directory 'config': File exists
                Will ich mit nano eine neue config erzeugen kommt:
                  GNU nano 6.4                        /config/config.yml
                                         [ Directory '/config' does not exist ]
                ^G Help       ^O Write Out  ^W Where Is   ^K Cut        ^T Execute    ^C Location
                ^X Exit       ^R Read File  ^\ Replace    ^U Paste      ^J Justify    ^/ Go To Line
                Wechsel ich dann zu Fuß in das Verzeichnis config und gebe dann deinen cat-Befehl angepasst ein kommt das:
                ~/config# cat config.yml
                detectors:
                  cpu1:
                    type: cpu
                mqtt:
                  host: 192.168.69.159
                  user: user
                  password: xxx
                cameras:
                  back:
                    ffmpeg:
                      hwaccel_args: preset-vaapi
                      inputs:
                        - path: rtsp:/XXX:xxx@192.168.69.162:554/h264Preview_01_sub
                          roles:
                            - detect
                        - path: rtsp://XXX.xxx@192.168.69.162:554/h264Preview_01_main
                          roles:
                            - record
                    detect:
                      width: 640
                      height: 360
                    mqtt:
                      enabled: False
                   objects:
                      track:
                        - person
                        - car
                        - truck
                        - bicycle
                        - motorcycle
                        - dog
                        - cat
                snapshots:
                  enabled: True
                  timestamp: False
                  bounding_box: False
                  crop: False
                  height: 175
                  required_zones: []
                  retain:
                    default: 10
                    objects:
                          person: 15
                record:
                  enabled: True
                  retain:
                    days: 7
                    mode: motion
                  events:
                    retain:
                      default: 14
                      mode: active_objects
                      objects:
                        person: 14
                        dog: 2
                        car: 7
                holzapfelaugeH Offline
                holzapfelauge
                #68
                @radi Hast du das ganze zum laufen bekommen? ich hab das selbe Problem wie du. Hab den Ladebildschirm und sonst tut sich nix.
                H 1 Antwort Letzte Antwort
                • holzapfelaugeH holzapfelauge
                  H Nicht stören
                  H Nicht stören
                  Hansi1234
                  #69
                  @holzapfelauge
                  @Radi
                  Habt ihr zu eurem Endlosloop schon eine Lösung gefunden? Habe es vorhin für Testzwecke auch installiert und stehe nun vor dem gleichen Problem.
                  @Wal kannst du hier vielleicht helfen?
                  • H Hansi1234
                    @holzapfelauge
                    @Radi
                    WalW Offline
                    WalW Offline
                    Wal
                    #70
                    @hansi1234 ,
                    wenn du möchtest können wir die Installation heute Abend Schritt für Schritt gemeinsam durchführen.
                    Walter
                    DoorIO-Adapter
                    • WalW Wal
                      @hansi1234 ,
                      H Nicht stören
                      H Nicht stören
                      Hansi1234
                      #71
                      @wal gerne. Hast du die Installation zufällig in letzter Zeit auch versucht?
                      Könnte es bei mir am nicht aktuellen proxmox Host liegen?
                      • H Hansi1234
                        WalW Offline
                        WalW Offline
                        Wal
                        #72
                        @hansi1234 sagte in Proxmox LXC mit Frigate:
                        Denke ich nicht.
                        Wäre so um 19Uhr bereit.
                        Walter
                        DoorIO-Adapter
                        • WalW Wal
                          Denke ich nicht.
                          H Nicht stören
                          H Nicht stören
                          Hansi1234
                          #73
                          @wal super, ich schreibe dich dann im Chat an
                          WalW 2 Antworten Letzte Antwort
                          • H Hansi1234
                            WalW Offline
                            WalW Offline
                            Wal
                            #74
                            @hansi1234 ,
                            wir könnten es auch hier machen, da hätten die anderen auch was davon.
                            Wenn du unter Windows auf Proxmox zugreifst, installier bitte den Bitvise SSH-Client.
                            Da geht Copy-Paste hervorragend, nehm ich lieber als Putty und die Proxmox-Konsole geht gar nicht.
                            Walter
                            DoorIO-Adapter
                            • WalW Wal
                              @hansi1234 ,
                              H Nicht stören
                              H Nicht stören
                              Hansi1234
                              #75
                              @wal alles klar. Bis später
                              • H Hansi1234
                                WalW Offline
                                WalW Offline
                                Wal
                                #76
                                @hansi1234 ,
                                habe ich eben getestet, mit der alten Anleitung geht es nicht ;-)
                                Neue Anleitung auf Seite 1 !!!
                                Walter
                                DoorIO-Adapter
                                H 2 Antworten Letzte Antwort
                                • WalW Wal
                                  @hansi1234 ,
                                  H Nicht stören
                                  H Nicht stören
                                  Hansi1234
                                  #77
                                  @wal said in Proxmox LXC mit Frigate:
                                  exit
                                  Funktioniert, danke dir :-)
                                  • WalW Wal
                                    @hansi1234 ,
                                    H Nicht stören
                                    H Nicht stören
                                    Hansi1234
                                    #78
                                    @wal ich hätte noch zwei offene Punkte.
                                    1. Bei mir wird unter /media/frigate/recordings nichts gespeichert. Events usw. sehe ich auf der Weboberfläche. Auch mit deinem Adapter passt alles. Wenn ich aber den Container neu starte, ist alles weg. Scheint so, als ob Frigate alles in einen tmp Ordner speichert. Das ist meine config:
                                    detectors:
                                      coral:
                                        type: edgetpu
                                        device: usb
                                    mqtt:
                                     host: 192.168.179.***
                                     user: ***
                                     password: ****
                                    cameras:
                                      Einfahrt: # <------ Name the camera
                                        ffmpeg:
                                          inputs:
                                            # High Resolution Stream
                                            - path: rtsp://***:***@192.168.179.***:554/h264Preview_01_main
                                              roles:
                                                - record
                                            # Low Resolution Stream
                                            - path: rtsp://***:***@192.168.179.***:554/h264Preview_01_sub
                                              roles:
                                                - detect
                                        record: # <----- Enable recording
                                          enabled: True
                                        objects:
                                          track:
                                            - person
                                            - car
                                    database:
                                      path: /config/frigate.db
                                    1. Kann ich iegendwo definieren, dass die "detects" und "snapshots" automatisch bei einem Neustart eingeschaltet sind? Diese muss ich nach jedem Neustart wieder manuell auf der Weboberfläche aktivieren.
                                    • H Hansi1234
                                      detectors:
                                        coral:
                                          type: edgetpu
                                          device: usb
                                      mqtt:
                                       user: ***
                                       password: ****
                                      cameras:
                                          ffmpeg:
                                            inputs:
                                                roles:
                                                  - record
                                                roles:
                                                  - detect
                                            enabled: True
                                          objects:
                                            track:
                                              - person
                                              - car
                                      database:
                                      WalW Offline
                                      WalW Offline
                                      Wal
                                      #79
                                      Das hatten wir schon, du hast bestimmt im MQTT-Adapter "Eigene States beim Verbinden publizieren" eingeschaltet.
                                      Walter
                                      DoorIO-Adapter
                                      • WalW Wal
                                        H Nicht stören
                                        H Nicht stören
                                        Hansi1234
                                        #80
                                        @wal danke. Ich glaub ich setze später nochmal alles auf. Fürs erste Problem find ich keine Lösung
                                        • H Hansi1234
                                          WalW Offline
                                          WalW Offline
                                          Wal
                                          #81
                                          @hansi1234 ,
                                          habe bei mir eine USB-Platte in Proxmox zum speichern eingebunden die ich mit Samba im Netzwerk freigebe.
                                          Ich denke es ist ein Rechte Problem bei dir, das hat nichts mit der Frigate-Config zu tun.
                                          In Proxmox ist die Platte so in der fstab eingebunden:
                                          UUID=xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxxxxx /media/usbhdd ext4 auto,nofail,sync,users,rw 0 0
                                          so im Frigate LXC:
                                          mp0: /media/usbhdd/frigate,mp=/media/frigate
                                          da ich noch mehr auf der USB-Platte speichere, habe ich den Unterordner frigate für Frigate in Proxmox erzeugt.
                                          Walter
                                          DoorIO-Adapter
