  4. ioBroker Docker Synology startet nicht
56 Beiträge 9 Kommentatoren 7.9k Aufrufe 6 Beobachtet
  • S Sweatchuck
    @glasfaser
    Unselect
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                x86_64                       -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v8.1.0                       -----
    -----                    build:               2023-09-21T23:45:32+00:00    -----
    -----                    node:                v18.17.1                     -----
    -----                    npm:                 9.6.7                        -----
    -----                        Environment Variables                         -----
    -----                    AVAHI:               false                        -----
    -----                    DEBUG:               true                         -----
    -----                    PACKAGES:            nano                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    !!!!                            DEBUG LOG ACTIVE                            !!!!
    !!!!               Environment variable DEBUG is set to true.               !!!!
    !!!! This will extend the logging output and may slow down container start. !!!!
    !!!!          Please make sure to deactivate if no longer needed.           !!!!
    !!!!     For more information see ioBroker Docker image documentation:      !!!!
    !!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
    -----                   Step 1 of 5: Preparing container                   -----
    Updating Linux packages on first run... Done.
    PACKAGES is set. Installing the following additional Linux packages: nano
    nano is not installed. Installing... Done.
    Registering maintenance script as command... Done.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo with gosu... Done.
    [DEBUG] Checking multihost settings...
    [DEBUG] No multihost settings detected.
    [DEBUG] Done.
    [DEBUG] Checking custom objects db settings...
    [DEBUG] No custom objects db settings detected.
    [DEBUG] Done.
    [DEBUG] Checking custom states db settings...
    [DEBUG] No custom states db settings detected.
    [DEBUG] Done.
    Checking Database connection... Failed.
    [DEBUG] Error message:
    [DEBUG] node:internal/modules/cjs/loader:1080
    [DEBUG]   throw err;
    [DEBUG]   ^
    [DEBUG]
    [DEBUG] Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    [DEBUG]     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    [DEBUG]     at Module._load (node:internal/modules/cjs/loader:922:27)
    [DEBUG]     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    [DEBUG]     at node:internal/main/run_main_module:23:47 {
    [DEBUG]   code: 'MODULE_NOT_FOUND',
    BUG]   requireStack: []
    [DEBUG]
    [DEBUG] Node.js v18.17.1
    Please check your configuration and try again.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
    [DEBUG] Debug mode prevents the container from exiting on errors.
    [DEBUG] This enables you to investigate or fix your issue on the command line.
    [DEBUG] If you want to stop or restart your container you have to do it manually.
    [DEBUG] IoBroker is not running!
    Diesmal läuft er wohl weiter aber ich komme nicht auf die ioBroker Seite
    GlasfaserG Offline
    GlasfaserG Offline
    @sweatchuck sagte in ioBroker Docker Synology startet nicht:
    Brauchst kein EDIT im Beitrag machen .. ich habe es schon gesehn , das er läuft !
    siehe oben ..
    • GlasfaserG Glasfaser
      @sweatchuck
      OK , der Container startet .
      dann melde dich im Terminal an im Portainer oder im Synology Docker Terminal und
      dann
      cd /opt/iobroker
      und
      sudo -H -u iobroker npm install iobroker.js-controller
      Sweatchuck
      @glasfaser
      • S Sweatchuck
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        @sweatchuck
        find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
        dann nochmal versuchen
        • S Sweatchuck
          @oliverio
          Ich verwende eine Synolgy DS 218+ mit Docker und Portainer.
          Was genau meinst du?
          Ich habe da nichts spezielles gemacht.
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @oliverio
          Das Skript meckert darüber das die Verbindung zur Datenbank nicht klappt.
          Dann zeige mal deine Konfiguration für den Container.
          Hast du ein docker-compose/stacks?
          Meine Adapter und Widgets
          Links im Profil
            @sweatchuck
            dann
            cd /opt/iobroker
            und
            Sweatchuck
            @glasfaser
            526877D7-9996-474E-8271-D50C80556EE5.jpeg BCAE95E2-A35D-4D95-9B3B-D378D38D49C3.jpeg 556CBEF0-0435-49CB-91BA-E47C52A0793D.jpeg
            • S Sweatchuck
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @sweatchuck
              Ja ... alles gut .. ist nur Werbung
              Dann noch zusätzlich
              pkill -u iobroker
              iob fix
              Container neu starten in der Synology Weboberfläche
                @sweatchuck
                pkill -u iobroker
                iob fix
                Sweatchuck
                @glasfaser
                Es geht wieder!!!
                Wie kann ich dir Danken?
                • S Sweatchuck
                  @glasfaser
                  Es geht wieder!!!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  ... damit , das du den Adapter Backitup nutzt !!!!
                    Sweatchuck
                    @glasfaser
                    Was war jetzt passiert? Und warum?
                    Nur für mich zur Info
                    • S Sweatchuck
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @sweatchuck
                      Kann ich so nicht erkennen bzw. weiß ja nicht was du zuvor genau gemacht hast ,
                      nur das dann der JS-Controller zerschossen wurde.
                        @sweatchuck
                        Sweatchuck
                        schrieb am zuletzt editiert von Sweatchuck
                        @glasfaser
                        Die javascript-Instanz bleibt rot
                        • S Sweatchuck
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          ioBroker log dazu hier posten ...
                          mit der Aussage kann ich nicht viele anfangen !
                            Sweatchuck
                            @glasfaser
                            • S Sweatchuck
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @sweatchuck
                              Stoppe den Adapter , dann lösche die Javascript Instanz , dann den Adapter Javascript , dann wieder den Adapter Javascript installieren und die Instanz dazu .
                              Könnte jetzt noch dir ein Befehl geben aber mache es erstmal so !
                                @sweatchuck
                                Sweatchuck
                                @glasfaser
                                Adapter läuft wieder.
                                Allerdings meckert er etwas…
                                Ich vermute es fehlen NPM Module
                                • S Sweatchuck
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @sweatchuck
                                  nicht ganz richtig
                                  es fehlen Datenpunkte // not found
                                  usw,
                                  • S Sweatchuck
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @sweatchuck
                                    Wird durch das Script
                                    erzeugt , die Datenpunkte fehlen dazu ... siehe oben
                                      @sweatchuck
                                      Sweatchuck
                                      @glasfaser
                                      Was ist das mit sandbox.js … ?
                                      Hab das javascript neu gestartet, bislang keine Fehler mehr.
                                      • S Sweatchuck
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        sandbox.js … ?
                                        ist kein NPM MODUL was fehlt , es wird wie gesagt das Log erzeugt , da die Datenpunkte fehlen !
                                        EDIT :
                                        bzw. jetzt erzeugt wurde oder kein Inhalt hatte .
