  4. ioBroker Docker Synology startet nicht
56 Beiträge 9 Kommentatoren 7.9k Aufrufe 6 Beobachtet
  • GlasfaserG Glasfaser
    @sweatchuck sagte in ioBroker Docker Synology startet nicht:
    Anbei ein Screenshot vom Log. Bitte um hilfe!
    ist das gleich LOG wie oben !
    Also bricht der Container zusammen , was kommt als Fehlermeldung wenn du Ihn startetst "?
    Sweatchuck
    schrieb am zuletzt editiert von Sweatchuck
    @glasfaser
    Unselect
    -----              Welcome to your ioBroker Docker container!              -----
    -----                    Startupscript is now running!                     -----
    -----                          Please be patient!                          -----
    -----                          System Information                          -----
    -----                    arch:                x86_64                       -----
    -----                    hostname:            iobroker                     -----
    -----                          Version Information                         -----
    -----                    image:               v8.1.0                       -----
    -----                    build:               2023-09-21T23:45:32+00:00    -----
    -----                    node:                v18.17.1                     -----
    -----                    npm:                 9.6.7                        -----
    -----                        Environment Variables                         -----
    -----                    AVAHI:               false                        -----
    -----                    DEBUG:               true                         -----
    -----                    PACKAGES:            nano                         -----
    -----                    SETGID:              1000                         -----
    -----                    SETUID:              1000                         -----
    !!!!                            DEBUG LOG ACTIVE                            !!!!
    !!!!               Environment variable DEBUG is set to true.               !!!!
    !!!! This will extend the logging output and may slow down container start. !!!!
    !!!!          Please make sure to deactivate if no longer needed.           !!!!
    !!!!     For more information see ioBroker Docker image documentation:      !!!!
    !!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
    -----                   Step 1 of 5: Preparing container                   -----
    Updating Linux packages on first run... Done.
    PACKAGES is set. Installing the following additional Linux packages: nano
    nano is not installed. Installing... Done.
    Registering maintenance script as command... Done.
    -----             Step 2 of 5: Detecting ioBroker installation             -----
    Existing installation of ioBroker detected in "/opt/iobroker".
    -----             Step 3 of 5: Checking ioBroker installation              -----
    (Re)setting permissions (This might take a while! Please be patient!)... Done.
    Fixing "sudo-bug" by replacing sudo with gosu... Done.
    [DEBUG] Checking multihost settings...
    [DEBUG] No multihost settings detected.
    [DEBUG] Done.
    [DEBUG] Checking custom objects db settings...
    [DEBUG] No custom objects db settings detected.
    [DEBUG] Done.
    [DEBUG] Checking custom states db settings...
    [DEBUG] No custom states db settings detected.
    [DEBUG] Done.
    Checking Database connection... Failed.
    [DEBUG] Error message:
    [DEBUG] node:internal/modules/cjs/loader:1080
    [DEBUG]   throw err;
    [DEBUG]   ^
    [DEBUG]
    [DEBUG] Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    [DEBUG]     at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
    [DEBUG]     at Module._load (node:internal/modules/cjs/loader:922:27)
    [DEBUG]     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
    [DEBUG]     at node:internal/main/run_main_module:23:47 {
    [DEBUG]   code: 'MODULE_NOT_FOUND',
    BUG]   requireStack: []
    [DEBUG]
    [DEBUG] Node.js v18.17.1
    Please check your configuration and try again.
    For more information see ioBroker Docker Image Docs (https://docs.buanet.de/iobroker-docker-image/docs).
    [DEBUG] Debug mode prevents the container from exiting on errors.
    [DEBUG] This enables you to investigate or fix your issue on the command line.
    [DEBUG] If you want to stop or restart your container you have to do it manually.
    [DEBUG] IoBroker is not running!
    Diesmal läuft er wohl weiter aber ich komme nicht auf die ioBroker Seite
      @sweatchuck
      Du kannst auch einen neuen Container erstellen und mounte dann auch die
      docker/iobroker_data
      in den Einstellungen vom neuen Container .
      Hast du das auch schon versucht !?
      Sweatchuck
      @glasfaser
      Ja, kein Erfolg.
      Wenn ich eine leeren Ordner anlege z.B. iobroker_data_neu dann funktioniert das ganze wieder…allerdings natürlich ohne meine Daten
      • S Sweatchuck
        @glasfaser
        Unselect
        [DEBUG] Done.
        [DEBUG] Done.
        [DEBUG] Done.
        [DEBUG]   throw err;
        [DEBUG]   ^
        [DEBUG]
        [DEBUG]
        GlasfaserG Offline
        GlasfaserG Offline
        @sweatchuck
        OK , der Container startet .
        dann melde dich im Terminal an im Portainer oder im Synology Docker Terminal und
        dann
        cd /opt/iobroker
        und
        sudo -H -u iobroker npm install iobroker.js-controller
        S 2 Antworten Letzte Antwort
        • S Sweatchuck
          @glasfaser
          Unselect
          [DEBUG] Done.
          [DEBUG] Done.
          [DEBUG] Done.
          [DEBUG]   throw err;
          [DEBUG]   ^
          [DEBUG]
          [DEBUG]
          GlasfaserG Offline
          GlasfaserG Offline
          Brauchst kein EDIT im Beitrag machen .. ich habe es schon gesehn , das er läuft !
          siehe oben ..
            @sweatchuck
            dann
            cd /opt/iobroker
            und
            Sweatchuck
            @glasfaser
            • S Sweatchuck
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @sweatchuck
              find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
              dann nochmal versuchen
              • S Sweatchuck
                @oliverio
                Ich verwende eine Synolgy DS 218+ mit Docker und Portainer.
                Was genau meinst du?
                Ich habe da nichts spezielles gemacht.
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @oliverio
                Das Skript meckert darüber das die Verbindung zur Datenbank nicht klappt.
                Dann zeige mal deine Konfiguration für den Container.
                Hast du ein docker-compose/stacks?
                Meine Adapter und Widgets
                Links im Profil
                  @sweatchuck
                  dann
                  cd /opt/iobroker
                  und
                  Sweatchuck
                  @glasfaser
                  526877D7-9996-474E-8271-D50C80556EE5.jpeg BCAE95E2-A35D-4D95-9B3B-D378D38D49C3.jpeg 556CBEF0-0435-49CB-91BA-E47C52A0793D.jpeg
                  • S Sweatchuck
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @sweatchuck
                    Ja ... alles gut .. ist nur Werbung
                    Dann noch zusätzlich
                    pkill -u iobroker
                    iob fix
                    Container neu starten in der Synology Weboberfläche
                      @sweatchuck
                      pkill -u iobroker
                      iob fix
                      Sweatchuck
                      @glasfaser
                      Es geht wieder!!!
                      Wie kann ich dir Danken?
                      • S Sweatchuck
                        @glasfaser
                        Es geht wieder!!!
                        GlasfaserG Offline
                        GlasfaserG Offline
                        ... damit , das du den Adapter Backitup nutzt !!!!
                          Sweatchuck
                          @glasfaser
                          Was war jetzt passiert? Und warum?
                          Nur für mich zur Info
                          • S Sweatchuck
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @sweatchuck
                            Kann ich so nicht erkennen bzw. weiß ja nicht was du zuvor genau gemacht hast ,
                            nur das dann der JS-Controller zerschossen wurde.
                              @sweatchuck
                              Sweatchuck
                              @glasfaser
                              Die javascript-Instanz bleibt rot
                              • S Sweatchuck
                                @glasfaser
                                GlasfaserG Offline
                                GlasfaserG Offline
                                ioBroker log dazu hier posten ...
                                mit der Aussage kann ich nicht viele anfangen !
                                  Sweatchuck
                                  @glasfaser
                                  • S Sweatchuck
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @sweatchuck
                                    Stoppe den Adapter , dann lösche die Javascript Instanz , dann den Adapter Javascript , dann wieder den Adapter Javascript installieren und die Instanz dazu .
                                    Könnte jetzt noch dir ein Befehl geben aber mache es erstmal so !
                                      @sweatchuck
                                      Sweatchuck
                                      @glasfaser
                                      Adapter läuft wieder.
                                      Allerdings meckert er etwas…
                                      Ich vermute es fehlen NPM Module
                                      • S Sweatchuck
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @sweatchuck
                                        nicht ganz richtig
                                        es fehlen Datenpunkte // not found
                                        usw,
                                        • S Sweatchuck
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @sweatchuck
                                          Wird durch das Script
                                          erzeugt , die Datenpunkte fehlen dazu ... siehe oben
