  4. TESTER gesucht / Backup auf Fritz.nas - node 18.18.0
204 Beiträge 10 Kommentatoren 42.1k Aufrufe 13 Beobachtet
  • F fastfoot
    @thomas-braun das ist was ich sehen wollte! Mit create local/copy to nas funktioniert das Ganze. Könntest du mal das nocompression testen, files = 0 sieht aus wie korrupt aber die Gösse könnte stimmen. tar -tf backups/test_nocompression.tar
    #70
    @fastfoot
    echad@chet:/opt/iobroker $ tar -tf backups/test_nocompression.tar
    echad@chet:/opt/iobroker $ ls -lAh backups/
    total 36M
    -rwxrwxrwx 1 root root    0 Oct  4 18:16 01_FREIGABE_FRITZ_NAS
    -rwxrwxrwx 1 root root  16K Oct  4 18:46 2023_10_04-18_46_20_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  16K Oct  4 19:08 2023_10_04-19_07_57_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  16K Oct  4 19:11 2023_10_04-19_11_08_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 19:26 historyDB_2023_10_04-19_26_02_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 20:05 historyDB_2023_10_04-20_04_52_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  16K Oct  4 20:07 historyDB_2023_10_04-20_06_45_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  29M Oct  4 20:24 historyDB_2023_10_04-20_23_55_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 19:26 iobroker_2023_10_04-19_25_51_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 20:05 iobroker_2023_10_04-20_04_41_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  16K Oct  4 20:06 iobroker_2023_10_04-20_06_34_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root 5.8M Oct  4 20:23 iobroker_2023_10_04-20_23_39_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 19:26 javascripts_2023_10_04-19_26_28_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 20:05 javascripts_2023_10_04-20_05_20_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  14K Oct  4 20:07 javascripts_2023_10_04-20_07_12_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  73K Oct  4 20:24 javascripts_2023_10_04-20_24_23_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root 151K Oct  4 20:41 test_alternative.tar.gz
    -rwxrwxrwx 1 root root 247K Oct  4 20:41 test_nocompression.tar
    -rwxrwxrwx 1 root root  16K Oct  4 20:41 test_standard.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 19:26 zigbee.0_2023_10_04-19_26_28_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root    0 Oct  4 20:05 zigbee.0_2023_10_04-20_05_19_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  955 Oct  4 20:07 zigbee.0_2023_10_04-20_07_11_chet_backupiobroker.tar.gz
    -rwxrwxrwx 1 root root  969 Oct  4 20:24 zigbee.0_2023_10_04-20_24_22_chet_backupiobroker.tar.gz
    F 1 Antwort Letzte Antwort
      @fastfoot
      total 36M
      F Online
      F Online
      fastfoot
      #71
      @thomas-braun gibts ja gar nicht, gar kein output? mach mal -tvf
      • F fastfoot
        #72
        @fastfoot
        Nö, nix:
        echad@chet:/opt/iobroker $ tar -tvf backups/test_nocompression.tar
          @fastfoot
          Nö, nix:
          F Online
          F Online
          fastfoot
          #73
          @thomas-braun ok, verbucht als Fehler der tar Implementation. Müsste eh 800Kb gross sein so wie unter 18.17. Damit wäre aber auch gzip ausgeschlossen weil es mit und ohne nicht klappt. Bleibt der pipe() Mechanismus. Jetzt erstell Du mal ein issue bei node und erkläre denen das :-)
          welche fritz box hast du denn? evtl liegt es tatsächlich an der smb implementierung, bin ratlos
          • F fastfoot
            @simatec sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
            @thomas-braun dann kann eigentlich auch der js-controller ausgeschlossen werden
            das verstehe ich jetzt nicht iob backup macht doch der js-controller, auch die Datei in node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js deutet auf den controller?
            simatecS Offline
            simatecS Offline
            simatec
            #74
            @fastfoot sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
            Aber der js-controller hat nix mit den Backup Optionen wie JavaScript Influx usw. zu tun.
            • Besuche meine Github Seite
            • HowTo Restore ioBroker
            • F fastfoot
              #75
              Ist eine FRITZ!Box 6660 Cable mit FRITZ!OS:7.57-Version aktuell.
              • F fastfoot
                #76
                Könnte schwierig werden.
                • simatecS simatec
                  F Online
                  F Online
                  fastfoot
                  #77
                  Aber der js-controller hat nix mit den Backup Optionen wie JavaScript Influenza usw. zu tun.
                  ja das stimmt natürlich, aber wenn wir es schaffen die iobroker backups zuverlässig zu schreiben dann wäre das auch die Lösung für den Rest.
                    F Online
                    F Online
                    fastfoot
                    #78
                    @thomas-braun sagte in TESTER gesucht / Backup auf Fritz.nas - node 18.18.0:
                    ich arbeite dran das zu vermeiden:-) weiss auch nicht wie man so ein issue formulieren sollte
                    Thomas BraunT 3 Antworten Letzte Antwort
                    • F fastfoot
                      #79
                      @fastfoot
                      Ey, euer tar macht komische Dinge seit 18.18.0, aber nur auf ein per CIFS gemountetes FritzNAS? Und das auch nicht bei jedem/immer.
                      Ich glaube das wird nicht weiter beachtet werden...
                      • F fastfoot
                        #80
                        @fastfoot
                        Mit welchem js-Kommando wird denn das nocompression.tar getart?
                        Ich verhedder mich schon dabei im Skript zu lesen...
                        • F fastfoot
                          #81
                          @fastfoot
                          Der Vollständigkeit halber.
                          Skript V2 mit nodejs 20.8.0:
                          /opt/iobroker/backups unmounted
                          //fritz.box/fritz.nas/Hitachi-HTS545012B9SA00-01/iobbackups/chet mounted into /opt/iobroker/backups
                          file test_standard.tar.gz created
                          file test_standard.tar.gz done
                          number of files in test_standard.tar.gz: 0
                          file test_nocompression.tar created
                          file test_nocompression.tar done
                          number of files in test_nocompression.tar: 0
                          file test_alternative.tar.gz created
                          file test_alternative.tar.gz done
                          number of files in test_alternative.tar.gz: 115
                          listing of created files in /opt/iobroker/backups
                          -rwxrwxrwx 1 root root 154384 Oct  4 22:42 /opt/iobroker/backups/test_alternative.tar.gz
                          -rwxrwxrwx 1 root root 252928 Oct  4 22:42 /opt/iobroker/backups/test_nocompression.tar
                          -rwxrwxrwx 1 root root  16384 Oct  4 22:42 /opt/iobroker/backups/test_standard.tar.gz
                          Was ist denn test_alternative.tar.gz genau?
                          Das scheint ja zu funktionieren.
                          Ist das der Schlingel?
                          echad@chet:/opt/iobroker $ npm ls tar
                          iobroker.inst@3.0.0 /opt/iobroker
                          ├─┬ iobroker.echarts@1.5.4
                          │ └─┬ canvas@2.11.2
                          │   └─┬ @mapbox/node-pre-gyp@1.0.11
                          │     └── tar@6.1.15 deduped
                          ├─┬ iobroker.js-controller@5.0.12
                          │ └── tar@6.1.15
                          └─┬ iobroker.zigbee@1.8.24
                          F simatecS 2 Antworten Letzte Antwort
                            @fastfoot
                            │ └─┬ canvas@2.11.2
                            │ └── tar@6.1.15
                            F Online
                            F Online
                            fastfoot
                            #82
                            @thomas-braun die alternative function macht das erstellen und kopieren was funktioniert. denke nicht dass es das tar ist. das nocompression wird mit standard und 2tem parameter false aufgerufen.
                              @fastfoot
                              │ └─┬ canvas@2.11.2
                              │ └── tar@6.1.15
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #83
                              @thomas-braun Jaein… js-controller nutzt tar direkt.
                              Backitup nutzt allerdings tar-fs ….
                              tar-fs hat aber wiederum tar mit integriert…
                              Nur um die Verwirrung mal komplett zu machen 😂
                              https://www.npmjs.com/package/tar
                              • simatecS simatec
                                #84
                                :-( Jetzt weiß ich gar nicht mehr wie ich den Pudding an die Wand nageln soll...
                                Das bekomme ich nie verständlich und wasserdicht in ein Issue gegossen.
                                  F Online
                                  F Online
                                  fastfoot
                                  #85
                                  nee, das mit dem issue sollte ein Gag sein. Ich arbeite an V3!
                                  • Thomas BraunT Online
                                    #86
                                    @fastfoot
                                    Ich muss morgen mal direkt mit tar experimentieren.
                                    Aber wenn es am deb-Paket liegen sollte, warum rappelte es erst ab nodejs 18.18.0?
                                      @fastfoot
                                      F Online
                                      F Online
                                      fastfoot
                                      #87
                                      tar -cvzf test.tar.gz ./node_modules/iobroker.js-controller
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #88
                                        Eventuell mit Sekundenkleber versuchen 😊
                                          @fastfoot
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #89
                                          Das hat nichts mit dem Deb-Packet zu tun... Es handelt sich um das Paket node-tar.
                                          Der Name ist etwas verwirrend, hat aber keine Verbindung zum DEB Paket
