  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • arteckA arteck
    @skb das geht nicht... Widgets bestätigen ein DP auch nicht
    das hab ich dir hier
    https://forum.iobroker.net/topic/64734/test-adapter-energiefluss-erweitert-v0-0-x-github-latest/1452?_=1695321282176
    geschrieben
    wo hast du die logik her... ?? das ist niergends so in admin oder iobroker implementiert
    das kannst du auch selber testen.. mach in der VIS ein widget
    [{"tpl":"tplVis-materialdesign-Button-Toggle-vertical","data":{"oid":"0_userdata.0.strom.batterieLadenManuell","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"outlined","toggleType":"boolean","stateIfNotTrueValue":"on","vibrateOnMobilDevices":"50","buttontext":"starten","textFontFamily":"RobotoCondensed-Bold","textFontSize":"25","alignment":"center","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.vertical.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.vertical.secondary","image":"battery-charging-10","iconPosition":"top","iconHeight":"53","autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockIconColor":"#mdwTheme:vis-materialdesign.0.colors.button.lock_icon","lockFilterGrayscale":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"valueOff":"false","valueOn":"true","labelTrue":"gestartet","labelColorTrue":"lime","labelColorFalse":"yellow","distanceBetweenTextAndImage":"12"},"style":{"left":"43px","top":"75px","width":"144px","height":"106px","z-index":"2"},"widgetSet":"materialdesign"}]
    und ordne dem mal ein DP zu
    SKBS Offline
    SKBS Offline
    SKB
    #1487
    @arteck https://forum.iobroker.net/post/448606
    Ich werde es so machen, das userdata und Javascript kein ACK benötigen. Alle Anderen aber schon.
    • P Offline
      photographix
      #1488
      Hallo und guten Abend,
      an welcher Stelle kann ich dieses Feature "Added: Count up/down Animation for numbers added. Instead of directly changing numbers, they are animated." abschalten?
      Wenn ich die Seite neu Lade zählt es jedesmal alle Zähler hoch das ist für mich eher verwirrend als hilfreich.
      Liebe Grüße
      ioBroker in Docker auf Raspberry PI 4 / 4GB
      CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
      SKBS 1 Antwort Letzte Antwort
      • P photographix
        Liebe Grüße
        SKBS Offline
        SKBS Offline
        SKB
        #1489
        @photographix was ist denn daran verwirrend, wenn Zahlen animiert werden?
        Dies ist pro DatenElement im Tab 'Erweitert' an- oder abschaltbar.
        P 1 Antwort Letzte Antwort
        • SKBS SKB
          photographix
          #1490
          @SKB
          Wenn meine Heizung an ist oder ein anderer Großverbraucher, dann zählt es leicht bis 1250 Watt. Ich möchte aber nicht auf kW umstellen. Es dauert dann teilweise 2 oder mehr Sekunden so dauert, bis der korrekte Wert da ist.
          Ich habe jetzt Bspw. eine Datenquelle ausgewählt - finde aber unter Erweitert nur "Berechnung", "Rahmenoption", "Aktionsoptionen", "CSS Klassen"
          Nichts was auf Animation von Zählerwerten schließen lässt.
          • P photographix
            @SKB
            SKBS Offline
            SKBS Offline
            SKB
            #1491
            @photographix Die Animation Dauer genau 1 Sekunde +/- 200ms.
            Wenn die Einstellung nicht sichtbar ist, dann hast Du nicht die letzte Version installiert.
            Diese bietet die Möglichkeit, dies ein- oder auszuschalten.
            • SKBS SKB
              photographix
              #1492
              @skb Bildschirmfoto 2023-09-21 um 23.31.21.png Bildschirmfoto 2023-09-21 um 23.32.00.png
              Der Adapter ist aktuell. 0.0.2.19
              Screenshot vom erweitert Menü einer Datenquelle.
              Chrome auf Macos 10.14
              Ist unter Safari aber identisch.
              • P photographix
                SKBS Offline
                SKBS Offline
                SKB
                #1493
                @photographix ist natürlich im Basic Tab, relativ am Ende :)
                • SKBS SKB
                  photographix
                  #1494
                  @skb Danke 👍
                  • arteckA arteck
                    geschrieben
                    SKBS Offline
                    SKBS Offline
                    SKB
                    #1495
                    @arteck Wenn Zeit findest, kannst Du nochmal drüber installieren. Ich habe das refresh nun wie folgt gelöst:
                    // The state was changed
                    if (id && state) {
                    	// The state is acknowledged
                    	if (state.ack) {
                    		this.log.debug('Refreshing ACK state from foreign state!');
                    		this.refreshData(id, state);
                    	// For userdata and Javascript
                    	if (id.toLowerCase().includes('0_userdata.') || id.toLowerCase().includes('javascript.')) {
                    		this.log.debug('Refreshing state from user environment!');
                    • SKBS SKB
                      if (id && state) {
                      	if (state.ack) {
                      arteckA Offline
                      arteckA Offline
                      arteck
                      #1496
                      @skb jo sieht gut aus...
                      • SKBS Offline
                        SKBS Offline
                        SKB
                        #1497
                        Hallo Zusammen,
                        ich habe soeben eine neue Version auf Github geladen - Version 0.0.2-alpha.20.
                        Folgendes ist neu bzw. behoben:
                        • FIX: Zustände in der Benutzerumgebung (userdata und Javascript) benötigen keine ACK-Flags mehr
                        • FIX: Darkmode-Bereinigungen und einige Layout-Verbesserungen
                        • FIX: Einige CSS-Stile wurden geändert
                        • Hinzugefügt: Version Checker, um die Version auf Github zu überprüfen und den Benutzer zu informieren
                        Viel Spaß damit ;)
                          m4rgott
                          #1498
                          nachdem ich von @SKB den Hinweis bekommen habe, dass das mit dem "alten" Adapter nicht funktionieren wird, frage ich hier noch einmal nach...
                          Ich bräuchte einmal Eure Hilfe.
                          Ich habe aufgrund verschiedener Tarife 2 Stromzähler verbaut. Einen für den Verbrauch der Wärmepumpe und einen für den Haushaltsstrom. Zusätzlich gibt es noch eine PV-Anlage.
                          Aufbau wie folgt:
                          6ddc5199-6203-407d-aa4e-129f1a99883f-Bildschirmfoto vom 2023-09-23 10-43-36.png
                          Ich habe nun folgende Datenpunkte im Iobroker:
                          Leistung PV-Anlage aus dem Modbus "Produktion"
                          Durchfluss Zähler 1: wenn negativ fließt der Strom weiter an Zähler 2, wenn positiv wird Strom von Zähler 2 bezogen
                          Durchfluss Zähler 2: wenn negativ wird ins öffentliche Netz eingespeist, wenn positiv bezogen
                          Ist es richtig, dass ich den Datenpunkt für Durchfluss Zähler 2 bei Öffentliche Netzeinspeisung (negativ) und Verbrauch (positiv) eintrage? Dann erhalte ich den Gesamtverbrauch, richtig?
                          Kann ich in dem Adapter auch direkt den Verbrauch der Heizung (Zähler 2 - Zähler 1) bzw. für den Haushalt (Produktion - Zähler 1) berechnen? Oder muss ich das über externe Scripte machen und der Adapter visualisiert die
                          Danke vorab für Eure Tipps.
                          • M m4rgott
                            Aufbau wie folgt:
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #1499
                            @m4rgott Hast Du dir den Adapter denn schon angeschaut?
                            Vieles kommt, wenn man ihn benutzt - wenn Werte vorliegen, kannst Du sie direkt darstellen.
                            Wenn nicht, kommen eigene Skripte zum Einsatz.
                            Du kannst ja erstmal langsam beginnen und dann die Fragen präzisieren.
                            • H Offline
                              Hohenbostler
                              #1500
                              Moin,
                              irgendwie startet meine Instanz nicht mehr.
                              Ich habe ein wenig am Design rumgespielt und unter Datenquellen etwas umbenannt. Nach dem SPeichern war mein neuer Name aber wieder weg. Dann habe ich das Update auf deine neuste Version gemacht. Leider erfolglos. Jetzt lese ich im log das hier.
                              SKBS HomoranH 2 Antworten Letzte Antwort
                              • H Hohenbostler
                                Moin,
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #1501
                                @hohenbostler Log Mitteilungen bitte nicht als Screenshot, sondern in Code-Tags (</>).
                                Die aktuelle Version ist die Alpha 20 und nicht 19, wie von dir installiert.
                                Auch steht im Log, das keine Adapter Konfig vorhanden ist. Ein Upload des Adapters sollte hier Abhilfe schaffen.
                                H 1 Antwort Letzte Antwort
                                • H Hohenbostler
                                  Moin,
                                  #1502
                                  @hohenbostler bitte logs als Text in code-tags posten!
                                  ich kann's nicht entziffern, nur als allgemeiner tipp:
                                  geh noch mal in den Editor und speicher neu ab.
                                  • SKBS SKB
                                    Hohenbostler
                                    #1503
                                    @skb
                                    ein Upload hat leider abhilfe geschaffen. Die Version die ich installiert habe kommt von Github . Installiert über die Katze.
                                    WIe kann ich denn die Version installieren die du vorschlägst ?
                                    und Sorry hier das log
                                    energiefluss-erweitert.0
                                    2023-09-25 08:28:23.686	info	terminating
                                    2023-09-25 08:28:23.185	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-09-25 08:28:23.184	info	terminating
                                    2023-09-25 08:28:23.183	info	Cleared interval for relative values!
                                    2023-09-25 08:28:23.178	error	Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:28:23.177	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                                    2023-09-25 08:28:23.176	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:28:23.175	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-09-25 08:28:22.805	info	Adapter started. Loading config!
                                    2023-09-25 08:28:22.702	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                                    2023-09-25 08:27:49.432	info	terminating
                                    2023-09-25 08:27:48.931	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-09-25 08:27:48.929	info	terminating
                                    2023-09-25 08:27:48.927	info	Cleared interval for relative values!
                                    2023-09-25 08:27:48.923	error	Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:27:48.922	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                                    2023-09-25 08:27:48.921	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:27:48.920	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-09-25 08:27:48.638	info	Adapter started. Loading config!
                                    2023-09-25 08:27:48.474	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                                    2023-09-25 08:14:12.044	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                    2023-09-25 08:14:11.985	error	adapter disabled
                                    2023-09-25 08:13:38.619	info	terminating
                                    2023-09-25 08:13:38.116	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-09-25 08:13:38.115	info	terminating
                                    2023-09-25 08:13:38.114	info	Cleared interval for relative values!
                                    2023-09-25 08:13:38.110	error	Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:13:38.109	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                                    2023-09-25 08:13:38.108	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:13:38.107	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-09-25 08:13:37.764	info	Adapter started. Loading config!
                                    2023-09-25 08:13:37.635	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                                    2023-09-25 08:13:04.760	info	terminating
                                    2023-09-25 08:13:04.257	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-09-25 08:13:04.256	info	terminating
                                    2023-09-25 08:13:04.255	info	Cleared interval for relative values!
                                    2023-09-25 08:13:04.241	error	Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:13:04.240	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                                    2023-09-25 08:13:04.239	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                                    2023-09-25 08:13:04.238	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-09-25 08:13:04.071	info	Adapter started. Loading config!
                                    2023-09-25 08:13:03.942	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                                    2023-09-25 07:59:44.164	info	terminating
                                    2023-09-25 07:59:43.661	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2023-09-25 07:59:43.660	info	terminating
                                    2023-09-25 07:59:43.658	info	Cleared interval for relative values!
                                    2023-09-25 07:59:43.655	error	Cannot read properties of undefined (reading 'source')
                                    2023-09-25 07:59:43.654	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                                    2023-09-25 07:59:43.653	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                                    2023-09-25 07:59:43.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2023-09-25 07:59:43.297	info	Adapter started. Loading config!
                                    2023-09-25 07:59:43.211	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                                    • H Hohenbostler
                                      @skb
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #1504
                                      @Hohenbostler Nun bist Du auf der 20.
                                      Schau mal bitte in die Objekte -> energiefluss-erweitert.<Instanz>.configuration.
                                      Dies kannst Du mit einem Klick auf den Wert rechts öffnen. Hier ganz ans Ende scrollen, bis Sowas kommt wie:
                                      "datasources": {
                                          "1": {
                                            "source": "sonnen.0.status.userSoc",
                                            "alias": "Battery-%"
                                      Hier bitte den Inhalt bis zum Ende kopieren und hier einfügen.
                                      • SKBS SKB
                                        "datasources": {
                                            "1": {
                                        Hohenbostler
                                        #1505
                                        @skb
                                        "datasources": {
                                            "0": {
                                              "source": "0_userdata.0.allgemeine_Datenpunkte.Balkonkraftwerk.aktueller_Verbrauch",
                                              "alias": "Verbrauch"
                                            "1": {
                                              "source": "sonoff.0.DVES_253BD9.Strom_P_total",
                                              "alias": "Einspeisung"
                                            "2": {
                                              "source": "sonoff.0.Tasmota_Steckdose_geflashed-5.ENERGY_Power",
                                              "alias": "TV-Verbrauch"
                                            "3": {
                                              "source": "zigbee2mqtt.0.0x84fd27fffe5f0cb1.load_power",
                                              "alias": "Justin"
                                            "4": {
                                              "source": "zigbee2mqtt.0.0x04cd15fffe02e130.load_power",
                                              "alias": "Serverschrank"
                                            "5": {
                                              "source": "zigbee2mqtt.0.0x5c0272fffe0431ac.load_power",
                                              "alias": "FirmenPC"
                                            "6": {
                                              "source": "zigbee2mqtt.0.0x60a423fffed2f147.load_power",
                                              "alias": "Trockner"
                                            "7": {
                                              "source": "zigbee2mqtt.0.0x60a423fffead7b47.load_power",
                                              "alias": "Waschmaschine"
                                            "8": {
                                              "source": "sonoff.0.Tasmota_Steckdose_geflashed-4.ENERGY_Power",
                                              "alias": "Backofen"
                                            "9": {
                                              "source": "sonoff.0.DVES_0430E1.ENERGY_Power",
                                              "alias": "Lea TV"
                                            "10": {
                                              "source": "zigbee2mqtt.0.0x04cd15fffe067ca3.load_power",
                                              "alias": "Bad TV"
                                            "11": {
                                              "source": "sonoff.0.Tasmota_Steckdose_geflashed-2.ENERGY_Power",
                                              "alias": "Bassbox"
                                            "12": {
                                              "source": "sonoff.0.Tasmota_Steckdose_geflashed-1.ENERGY_Power",
                                              "alias": "Verstärker"
                                            "13": {
                                              "source": "zigbee2mqtt.0.0x84ba20fffe77b5c2.load_power",
                                              "alias": "PS5"
                                            "14": {
                                              "source": "zigbee2mqtt.0.0x84ba20fffe77b37f.load_power",
                                              "alias": "PS5 Ladestation"
                                            "15": {
                                              "source": "sonoff.0.Tasmota_Steckdose_geflashed-3.ENERGY_Power",
                                              "alias": "Kühlschrank"
                                            "16": {
                                              "source": "shelly.0.SHSW-25#00B75C#1.Relay1.Power",
                                              "alias": "Gastherme"
                                            "17": {
                                              "source": "zigbee2mqtt.0.0x84ba20fffe80c958.load_power",
                                              "alias": "Schlafzimmer TV"
                                            "18": {
                                              "source": "0_userdata.0.allgemeine_Datenpunkte.Balkonkraftwerk.Einspeisung_Balkonkraftwerk",
                                              "alias": "Erzeugung_BKW"
                                            "19": {
                                              "source": "0_userdata.0.allgemeine_Datenpunkte.Balkonkraftwerk.Bezug_netzbetreiber",
                                              "alias": "Bezug_Netzbetreiber"
                                            "20": {
                                              "source": "zigbee2mqtt.0.0x60a423fffe7ebde4.load_power",
                                              "alias": "Spülmaschine"
                                            "21": {
                                              "source": "opendtu.0.116190758269.ac.phase_1.yieldtotal",
                                              "alias": "Gesamtertrag"
                                            "22": {
                                              "source": "opendtu.0.116190758269.ac.phase_1.yieldday",
                                              "alias": "Ertrag_heute"
                                            "23": {
                                              "source": "opendtu.0.116190758269.power_control.current_limit_absolute",
                                              "alias": "Aktuelle_Freigabe"
                                            "24": {
                                              "source": "sonoff.0.DVES_253BD9.Strom_W_total",
                                              "alias": "StromZählerstand"
                                        • H Hohenbostler
                                          @skb
                                          "datasources": {
                                              "0": {
                                              "1": {
                                              "2": {
                                              "3": {
                                                "alias": "Justin"
                                              "4": {
                                              "5": {
                                                "alias": "FirmenPC"
                                              "6": {
                                                "alias": "Trockner"
                                              "7": {
                                              "8": {
                                                "alias": "Backofen"
                                              "9": {
                                                "alias": "Lea TV"
                                              "10": {
                                                "alias": "Bad TV"
                                              "11": {
                                                "alias": "Bassbox"
                                              "12": {
                                              "13": {
                                                "alias": "PS5"
                                              "14": {
                                              "15": {
                                              "16": {
                                              "17": {
                                              "18": {
                                              "19": {
                                              "20": {
                                              "21": {
                                              "22": {
                                              "23": {
                                              "24": {
                                          SKBS Offline
                                          SKBS Offline
                                          SKB
                                          #1506
                                          @hohenbostler Danke, ich habe an der Version auf Git etwas angepasst.
                                          Du kannst nochmal drüber installieren, dann solltest Du eine Info bekommen, das eine Datenquelle, die Du verwenden möchtest, nicht vorhanden ist.
                                          Melde dich gerne zurück.
