  4. Support Adapter Energiefluss-erweitert
vis
4.6k Beiträge 206 Kommentatoren 6.5m Aufrufe 178 Beobachtet
  • SKBS SKB
    @photographix ist natürlich im Basic Tab, relativ am Ende :)
    photographix
    #1494
    @skb Danke 👍
    ioBroker in Docker auf Raspberry PI 4 / 4GB
    CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
    • arteckA arteck
      @skb das geht nicht... Widgets bestätigen ein DP auch nicht
      das hab ich dir hier
      https://forum.iobroker.net/topic/64734/test-adapter-energiefluss-erweitert-v0-0-x-github-latest/1452?_=1695321282176
      geschrieben
      wo hast du die logik her... ?? das ist niergends so in admin oder iobroker implementiert
      das kannst du auch selber testen.. mach in der VIS ein widget
      [{"tpl":"tplVis-materialdesign-Button-Toggle-vertical","data":{"oid":"0_userdata.0.strom.batterieLadenManuell","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttonStyle":"outlined","toggleType":"boolean","stateIfNotTrueValue":"on","vibrateOnMobilDevices":"50","buttontext":"starten","textFontFamily":"RobotoCondensed-Bold","textFontSize":"25","alignment":"center","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.vertical.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.vertical.secondary","image":"battery-charging-10","iconPosition":"top","iconHeight":"53","autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockIconColor":"#mdwTheme:vis-materialdesign.0.colors.button.lock_icon","lockFilterGrayscale":"30","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"valueOff":"false","valueOn":"true","labelTrue":"gestartet","labelColorTrue":"lime","labelColorFalse":"yellow","distanceBetweenTextAndImage":"12"},"style":{"left":"43px","top":"75px","width":"144px","height":"106px","z-index":"2"},"widgetSet":"materialdesign"}]
      und ordne dem mal ein DP zu
      SKBS Offline
      SKBS Offline
      SKB
      #1495
      @arteck Wenn Zeit findest, kannst Du nochmal drüber installieren. Ich habe das refresh nun wie folgt gelöst:
      // The state was changed
      if (id && state) {
      	// The state is acknowledged
      	if (state.ack) {
      		this.log.debug('Refreshing ACK state from foreign state!');
      		this.refreshData(id, state);
      	// For userdata and Javascript
      	if (id.toLowerCase().includes('0_userdata.') || id.toLowerCase().includes('javascript.')) {
      		this.log.debug('Refreshing state from user environment!');
      • SKBS SKB
        if (id && state) {
        	if (state.ack) {
        arteckA Offline
        arteckA Offline
        arteck
        #1496
        @skb jo sieht gut aus...
        • SKBS Offline
          SKBS Offline
          SKB
          #1497
          Hallo Zusammen,
          ich habe soeben eine neue Version auf Github geladen - Version 0.0.2-alpha.20.
          Folgendes ist neu bzw. behoben:
          • FIX: Zustände in der Benutzerumgebung (userdata und Javascript) benötigen keine ACK-Flags mehr
          • FIX: Darkmode-Bereinigungen und einige Layout-Verbesserungen
          • FIX: Einige CSS-Stile wurden geändert
          • Hinzugefügt: Version Checker, um die Version auf Github zu überprüfen und den Benutzer zu informieren
          Viel Spaß damit ;)
            m4rgott
            #1498
            nachdem ich von @SKB den Hinweis bekommen habe, dass das mit dem "alten" Adapter nicht funktionieren wird, frage ich hier noch einmal nach...
            Ich bräuchte einmal Eure Hilfe.
            Ich habe aufgrund verschiedener Tarife 2 Stromzähler verbaut. Einen für den Verbrauch der Wärmepumpe und einen für den Haushaltsstrom. Zusätzlich gibt es noch eine PV-Anlage.
            Aufbau wie folgt:
            6ddc5199-6203-407d-aa4e-129f1a99883f-Bildschirmfoto vom 2023-09-23 10-43-36.png
            Ich habe nun folgende Datenpunkte im Iobroker:
            Leistung PV-Anlage aus dem Modbus "Produktion"
            Durchfluss Zähler 1: wenn negativ fließt der Strom weiter an Zähler 2, wenn positiv wird Strom von Zähler 2 bezogen
            Durchfluss Zähler 2: wenn negativ wird ins öffentliche Netz eingespeist, wenn positiv bezogen
            Ist es richtig, dass ich den Datenpunkt für Durchfluss Zähler 2 bei Öffentliche Netzeinspeisung (negativ) und Verbrauch (positiv) eintrage? Dann erhalte ich den Gesamtverbrauch, richtig?
            Kann ich in dem Adapter auch direkt den Verbrauch der Heizung (Zähler 2 - Zähler 1) bzw. für den Haushalt (Produktion - Zähler 1) berechnen? Oder muss ich das über externe Scripte machen und der Adapter visualisiert die
            Danke vorab für Eure Tipps.
            SKBS 1 Antwort Letzte Antwort
            • M m4rgott
              Aufbau wie folgt:
              SKBS Offline
              SKBS Offline
              SKB
              #1499
              @m4rgott Hast Du dir den Adapter denn schon angeschaut?
              Vieles kommt, wenn man ihn benutzt - wenn Werte vorliegen, kannst Du sie direkt darstellen.
              Wenn nicht, kommen eigene Skripte zum Einsatz.
              Du kannst ja erstmal langsam beginnen und dann die Fragen präzisieren.
              • H Offline
                Hohenbostler
                #1500
                Moin,
                irgendwie startet meine Instanz nicht mehr.
                Ich habe ein wenig am Design rumgespielt und unter Datenquellen etwas umbenannt. Nach dem SPeichern war mein neuer Name aber wieder weg. Dann habe ich das Update auf deine neuste Version gemacht. Leider erfolglos. Jetzt lese ich im log das hier.
                SKBS HomoranH 2 Antworten Letzte Antwort
                • H Hohenbostler
                  Moin,
                  SKBS Offline
                  SKBS Offline
                  SKB
                  #1501
                  @hohenbostler Log Mitteilungen bitte nicht als Screenshot, sondern in Code-Tags (</>).
                  Die aktuelle Version ist die Alpha 20 und nicht 19, wie von dir installiert.
                  Auch steht im Log, das keine Adapter Konfig vorhanden ist. Ein Upload des Adapters sollte hier Abhilfe schaffen.
                  H 1 Antwort Letzte Antwort
                  • H Hohenbostler
                    Moin,
                    #1502
                    @hohenbostler bitte logs als Text in code-tags posten!
                    ich kann's nicht entziffern, nur als allgemeiner tipp:
                    geh noch mal in den Editor und speicher neu ab.
                    • SKBS SKB
                      Hohenbostler
                      #1503
                      @skb
                      ein Upload hat leider abhilfe geschaffen. Die Version die ich installiert habe kommt von Github . Installiert über die Katze.
                      WIe kann ich denn die Version installieren die du vorschlägst ?
                      und Sorry hier das log
                      energiefluss-erweitert.0
                      2023-09-25 08:28:23.686	info	terminating
                      2023-09-25 08:28:23.185	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-09-25 08:28:23.184	info	terminating
                      2023-09-25 08:28:23.183	info	Cleared interval for relative values!
                      2023-09-25 08:28:23.178	error	Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:28:23.177	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                      2023-09-25 08:28:23.176	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:28:23.175	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-09-25 08:28:22.805	info	Adapter started. Loading config!
                      2023-09-25 08:28:22.702	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                      2023-09-25 08:27:49.432	info	terminating
                      2023-09-25 08:27:48.931	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-09-25 08:27:48.929	info	terminating
                      2023-09-25 08:27:48.927	info	Cleared interval for relative values!
                      2023-09-25 08:27:48.923	error	Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:27:48.922	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                      2023-09-25 08:27:48.921	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:27:48.920	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-09-25 08:27:48.638	info	Adapter started. Loading config!
                      2023-09-25 08:27:48.474	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                      2023-09-25 08:14:12.044	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                      2023-09-25 08:14:11.985	error	adapter disabled
                      2023-09-25 08:13:38.619	info	terminating
                      2023-09-25 08:13:38.116	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-09-25 08:13:38.115	info	terminating
                      2023-09-25 08:13:38.114	info	Cleared interval for relative values!
                      2023-09-25 08:13:38.110	error	Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:13:38.109	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                      2023-09-25 08:13:38.108	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:13:38.107	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-09-25 08:13:37.764	info	Adapter started. Loading config!
                      2023-09-25 08:13:37.635	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                      2023-09-25 08:13:04.760	info	terminating
                      2023-09-25 08:13:04.257	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-09-25 08:13:04.256	info	terminating
                      2023-09-25 08:13:04.255	info	Cleared interval for relative values!
                      2023-09-25 08:13:04.241	error	Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:13:04.240	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                      2023-09-25 08:13:04.239	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                      2023-09-25 08:13:04.238	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-09-25 08:13:04.071	info	Adapter started. Loading config!
                      2023-09-25 08:13:03.942	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                      2023-09-25 07:59:44.164	info	terminating
                      2023-09-25 07:59:43.661	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-09-25 07:59:43.660	info	terminating
                      2023-09-25 07:59:43.658	info	Cleared interval for relative values!
                      2023-09-25 07:59:43.655	error	Cannot read properties of undefined (reading 'source')
                      2023-09-25 07:59:43.654	error	TypeError: Cannot read properties of undefined (reading 'source') at EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1092:96)
                      2023-09-25 07:59:43.653	error	unhandled promise rejection: Cannot read properties of undefined (reading 'source')
                      2023-09-25 07:59:43.652	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-09-25 07:59:43.297	info	Adapter started. Loading config!
                      2023-09-25 07:59:43.211	info	starting. Version 0.0.2-alpha.20 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 5.0.12
                      • H Hohenbostler
                        @skb
                        SKBS Offline
                        SKBS Offline
                        SKB
                        #1504
                        @Hohenbostler Nun bist Du auf der 20.
                        Schau mal bitte in die Objekte -> energiefluss-erweitert.<Instanz>.configuration.
                        Dies kannst Du mit einem Klick auf den Wert rechts öffnen. Hier ganz ans Ende scrollen, bis Sowas kommt wie:
                        "datasources": {
                            "1": {
                              "source": "sonnen.0.status.userSoc",
                              "alias": "Battery-%"
                        Hier bitte den Inhalt bis zum Ende kopieren und hier einfügen.
                        • SKBS SKB
                          "datasources": {
                              "1": {
                          Hohenbostler
                          #1505
                          @skb
                          "datasources": {
                              "0": {
                                "source": "0_userdata.0.allgemeine_Datenpunkte.Balkonkraftwerk.aktueller_Verbrauch",
                                "alias": "Verbrauch"
                              "1": {
                                "source": "sonoff.0.DVES_253BD9.Strom_P_total",
                                "alias": "Einspeisung"
                              "2": {
                                "source": "sonoff.0.Tasmota_Steckdose_geflashed-5.ENERGY_Power",
                                "alias": "TV-Verbrauch"
                              "3": {
                                "source": "zigbee2mqtt.0.0x84fd27fffe5f0cb1.load_power",
                                "alias": "Justin"
                              "4": {
                                "source": "zigbee2mqtt.0.0x04cd15fffe02e130.load_power",
                                "alias": "Serverschrank"
                              "5": {
                                "source": "zigbee2mqtt.0.0x5c0272fffe0431ac.load_power",
                                "alias": "FirmenPC"
                              "6": {
                                "source": "zigbee2mqtt.0.0x60a423fffed2f147.load_power",
                                "alias": "Trockner"
                              "7": {
                                "source": "zigbee2mqtt.0.0x60a423fffead7b47.load_power",
                                "alias": "Waschmaschine"
                              "8": {
                                "source": "sonoff.0.Tasmota_Steckdose_geflashed-4.ENERGY_Power",
                                "alias": "Backofen"
                              "9": {
                                "source": "sonoff.0.DVES_0430E1.ENERGY_Power",
                                "alias": "Lea TV"
                              "10": {
                                "source": "zigbee2mqtt.0.0x04cd15fffe067ca3.load_power",
                                "alias": "Bad TV"
                              "11": {
                                "source": "sonoff.0.Tasmota_Steckdose_geflashed-2.ENERGY_Power",
                                "alias": "Bassbox"
                              "12": {
                                "source": "sonoff.0.Tasmota_Steckdose_geflashed-1.ENERGY_Power",
                                "alias": "Verstärker"
                              "13": {
                                "source": "zigbee2mqtt.0.0x84ba20fffe77b5c2.load_power",
                                "alias": "PS5"
                              "14": {
                                "source": "zigbee2mqtt.0.0x84ba20fffe77b37f.load_power",
                                "alias": "PS5 Ladestation"
                              "15": {
                                "source": "sonoff.0.Tasmota_Steckdose_geflashed-3.ENERGY_Power",
                                "alias": "Kühlschrank"
                              "16": {
                                "source": "shelly.0.SHSW-25#00B75C#1.Relay1.Power",
                                "alias": "Gastherme"
                              "17": {
                                "source": "zigbee2mqtt.0.0x84ba20fffe80c958.load_power",
                                "alias": "Schlafzimmer TV"
                              "18": {
                                "source": "0_userdata.0.allgemeine_Datenpunkte.Balkonkraftwerk.Einspeisung_Balkonkraftwerk",
                                "alias": "Erzeugung_BKW"
                              "19": {
                                "source": "0_userdata.0.allgemeine_Datenpunkte.Balkonkraftwerk.Bezug_netzbetreiber",
                                "alias": "Bezug_Netzbetreiber"
                              "20": {
                                "source": "zigbee2mqtt.0.0x60a423fffe7ebde4.load_power",
                                "alias": "Spülmaschine"
                              "21": {
                                "source": "opendtu.0.116190758269.ac.phase_1.yieldtotal",
                                "alias": "Gesamtertrag"
                              "22": {
                                "source": "opendtu.0.116190758269.ac.phase_1.yieldday",
                                "alias": "Ertrag_heute"
                              "23": {
                                "source": "opendtu.0.116190758269.power_control.current_limit_absolute",
                                "alias": "Aktuelle_Freigabe"
                              "24": {
                                "source": "sonoff.0.DVES_253BD9.Strom_W_total",
                                "alias": "StromZählerstand"
                          • H Hohenbostler
                            @skb
                            "datasources": {
                                "0": {
                                "1": {
                                "2": {
                                "3": {
                                  "alias": "Justin"
                                "4": {
                                "5": {
                                  "alias": "FirmenPC"
                                "6": {
                                  "alias": "Trockner"
                                "7": {
                                "8": {
                                  "alias": "Backofen"
                                "9": {
                                  "alias": "Lea TV"
                                "10": {
                                  "alias": "Bad TV"
                                "11": {
                                  "alias": "Bassbox"
                                "12": {
                                "13": {
                                  "alias": "PS5"
                                "14": {
                                "15": {
                                "16": {
                                "17": {
                                "18": {
                                "19": {
                                "20": {
                                "21": {
                                "22": {
                                "23": {
                                "24": {
                            SKBS Offline
                            SKBS Offline
                            SKB
                            #1506
                            @hohenbostler Danke, ich habe an der Version auf Git etwas angepasst.
                            Du kannst nochmal drüber installieren, dann solltest Du eine Info bekommen, das eine Datenquelle, die Du verwenden möchtest, nicht vorhanden ist.
                            Melde dich gerne zurück.
                            • SKBS SKB
                              Hohenbostler
                              #1507
                              @skb
                              Wie installiere ich die neuste version am besten ? Über die Katze im iobroker oder brauche ich dafür einen direkten LInk?
                              • H Hohenbostler
                                @skb
                                SKBS Offline
                                SKBS Offline
                                SKB
                                #1508
                                @hohenbostler Katze und den allgemeinen Link. Es wird automatisch drüber installiert. Die Version bleibt erstmal dieselbe - der Code ändert sich nur.
                                • SKBS SKB
                                  Hohenbostler
                                  #1509
                                  @skb
                                  Danke Instanz läuft wieder.
                                  Müsste ich jetzt einen Fehler irgendwo bekommen ?
                                  • H Hohenbostler
                                    @skb
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #1510
                                    @hohenbostler Es könnte eine Warnung in gelb erscheinen, die sowas aussagt:
                                    	2023-09-25 08:55:51.437	warn	Element with ID 57 of Type text is using source 118, which ist not available!
                                    So werden Sources dann abgefangen, die sich wohl geändert habe bzw. noch aktiv genutzt sind, aber eine andere ID haben.
                                    • SKBS SKB
                                      Hohenbostler
                                      #1511
                                      @skb
                                      ah ok gefunden.
                                      2023-09-25 09:15:25.247	warn	Element with ID 109 of Type rect is using source , which ist not available!
                                      • H Hohenbostler
                                        @skb
                                        ah ok gefunden.
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #1512
                                        @hohenbostler Wenn Du nun dem Element die richtige Source einstellst, verschwindet auch die Warnung :)
                                        • SKBS SKB
                                          Hohenbostler
                                          #1513
                                          @skb
                                          Danke ich schau gerade schon. Da aber bei den Quellen nirgends die ID steht wird es dann eher ei Rätselraten.
                                          Kannst du die irgendwo mit einblenden ?
