  4. Node-Red
  5. [HowTo] Huawei SUN2000 WR Modbus mit node-red (read + write)
574 Beiträge 110 Kommentatoren 281.3k Aufrufe 108 Beobachtet
  • B badsnoopy667
    @torbennw
    Versuch mal den Flow aus Post 1 Update 2:
    Update 2: Ich habe den Flow noch angepasst und z.B. um die Batterie-Daten erweitert. Außerdem frage ich die unwichtigen Sachen wie Seriennummer etc. nur 1x pro Minute ab, dafür aber die wichtigen Dinge wie Erzeugung und Verbrauch alle 3 Sekunden. Hier der neue Flow:
    node-red-SUN2000.txt
    Fridolin01
    #381
    Brauche kurz eure Hilfe
    Mein Nodered spamt mir den Log voll mit folgenden Meldungen.
    node-red.0
    	2023-09-01 21:21:03.115	info	State value to set for "0_userdata.0.Huawei.Dongle.Load_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:21:03.063	info	State value to set for "0_userdata.0.Huawei.Dongle.Total_input_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:21:00.569	info	State value to set for "0_userdata.0.Huawei.Meter.Active_Power" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:55.675	info	State value to set for "0_userdata.0.Huawei.Inverter.Peak_Active_Power_of_current_Day" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:53.798	info	State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Current" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:53.181	info	State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Voltage" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:52.511	info	State value to set for "0_userdata.0.Huawei.Dongle.Total_active_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:52.493	info	State value to set for "0_userdata.0.Huawei.Dongle.Grid_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:52.439	info	State value to set for "0_userdata.0.Huawei.Dongle.Load_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:52.396	info	State value to set for "0_userdata.0.Huawei.Dongle.Total_input_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:46.342	info	State value to set for "0_userdata.0.Huawei.Inverter.Input_Power" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:42.775	info	State value to set for "0_userdata.0.Huawei.Dongle.Total_active_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:42.714	info	State value to set for "0_userdata.0.Huawei.Dongle.Grid_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:42.614	info	State value to set for "0_userdata.0.Huawei.Dongle.Load_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:42.574	info	State value to set for "0_userdata.0.Huawei.Dongle.Total_input_power" has to be type "string" but received type "number"
    node-red.0
    	2023-09-01 21:20:35.957	info	State value to set for "0_userdata.0.Huawei.Inverter.Peak_Active_Power_of_current_Day" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:34.209	info	State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Current" has to be stringified but received type "number"
    node-red.0
    	2023-09-01 21:20:33.203	info	State value to set for "0_userdata.0.Huawei.Inverter.Power_Grid_Voltage" has to be stringified but received type "number"
    Was genau muss ich ändern damit die Werte passend empfangen werden?
    • F Fridolin01
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      node-red.0
      mickymM Offline
      mickymM Offline
      mickym
      #382
      @fridolin01 Du hast die ganzen Datenpunkte als Strings deklariert, schreibst aber Zahlen da rein. Also den Typ ändern.
        Benutzer0815
        #383
        ich bin noch neu bei iobroker und neuer als neu bei node red. Ich habe eines der Skripte nun bei Node Red importiert, die IP-Adresse des WR angepasst und auch Übernahme (deploy) geklickt.
        Es passiert allerdings nichts. Unter 0_userdata.0 wird nichts angelegt. Im Protokoll sieht es folgendemaßen aus:
        "Verschlüsselte Credentials nicht gefunden" klingt so als müsste ich noch Logindaten angeben?
        • B Benutzer0815
          mickymM Offline
          mickymM Offline
          mickym
          #384
          Nein hat damit nichts zu tun. Du musst das Erstellen von Fremdobjekten im Adapter zulassen
          • mickymM mickym
            Benutzer0815
            #385
            @mickym In den Instanzeinstellungen von Node Red, richtig?
            Das hatte ich schon gelesen und auch gemacht. Hat aber nicht geholfen.
            • B Benutzer0815
              mickymM Offline
              mickymM Offline
              mickym
              #386
              @benutzer0815 Diese Fehlermeldung hat zwar damit zu tun, dass die Datei mit den credentials nicht gefunden wurde, aber das sollte mit dem Erstellen von Datenpunkten nichts zu tun haben. Zeig halt mal Deine iobroker-out node.
              • mickymM mickym
                Benutzer0815
                #387
                @mickym Bin nicht ganz sicher. Meinst du das?
                • B Benutzer0815
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #388
                  @benutzer0815 Also wenn Du die Fremdobjekte angeklickt hast, muss in den iobroker out Objekten halt stehen, dass die Datenpunkte angelegt werden dürfen, wenn sie nicht vorhanden sind:
                  Die Fehlermeldung mit den credentials kommt wenn die Datei mit den credentials fehlt. Die wird aber automatisch angelegt, wenn man irgendwelche Credentials zum Beispiel in mqtt etc. einträgt-
                  • A alexander85
                    @christiansr said in [HowTo] Huawei SUN2000 WR Modbus mit node-red (read + write):
                    also ein Problem habe ich identifiziert: Der Inverter 2 liefert keine Daten. (dann ist ganz logisch, dass der Gesamtertrag nicht passt)
                    Ich konnte allerdings noch nicht klären, warum ich von Inverter 2 keine Daten bekomme. Die Einstellungen im Modbus-Getter müssten identisch sein und nur die Unit-ID eins mehr - oder?
                    Unit-ID 0 oder 3 liefert auch nix - habe ich probiert.
                    Kann das noch ein Einstellungsproblem in Node-Red sein oder liegt der Fehler im Inverter?
                    Bei kaskadierten Wechselrichtern bekommt der Master-WR und der SmartMeter offenbar die UnitID 16.
                    ChristianSrC Offline
                    ChristianSr
                    #389
                    @alexander85 danke. das wars.
                    • mickymM mickym
                      Benutzer0815
                      #390
                      @mickym gnauso sieht es bei mir auch aus
                      Aber das zweite Bild sagt mir nichts. Wie komme ich zu den Werkzeugen?
                      Mal so nebenbei habe ich neuerdings auch Fehler bei der Anbindung meiner Wärmepumpe:
                      Falls das vllt. auch etwas damit zu tun haben könnte.
                      • B Benutzer0815
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #391
                        @benutzer0815 Nun bei dem 2. Fehler sagt dieser einfach, dass das Gerät nicht geantwortet hat. Dann kann natürlich auch nichts geschrieben werden. Warum dieser Timeout kommt, kann ich Dir nicht beantworten.
                        • mickymM mickym
                          Benutzer0815
                          #392
                          @mickym Ok hätte ja sein können das das eine evtl. mit dem anderen zu tun hat.
                          • B Benutzer0815
                            memme
                            #393
                            kurze Frage, ich stehe gerade vor dem Kauf eines Huawei Sun2000-20KTL-M2. Dass ich den Lan/Wlan Dongle brauche ist klar, aber brauche ich dafür auch den Huawei Smart Power Sensor DTSU666-H 3P ?
                            Mein Elektriker meinte, wenn ich die Daten vom Hausverbrauch auch dazu haben möchste sollte ich den installieren.
                            Danke und Grüße
                            • M memme
                              Danke und Grüße
                              B Online
                              B Online
                              badsnoopy667
                              #394
                              @memme
                              Soweit ich das sehe, brauchst Du den Power Sensor damit der Wechselrichter weiß, wie viel Strom gerade eingespeist oder aus dem Netz gezogen wird. Darüber wird dann ja auch die Batterie gesteuert wenn man eine hat. Ob das System auch ohne Power Sensor läuft hab ich mich bisher noch nie gefragt. Ich würde ihn schon aus Neugier installieren, damit ich weiß, was ich so verbrauche.
                              • B badsnoopy667
                                @memme
                                memme
                                #395
                                @badsnoopy667
                                ok, dann habe ich das ja richtig verstanden. Wenn ich den Smart power sensor installiere kann ich die Werte im IoBroker verarbeiten, richtig?
                                Batterie habe ich nicht. Wird wohl dann auf eine Darstellung alla was verbrauche ich gerade, was wird von der pv bezogen und was vom netzt und was wird eingespeist.
                                B Hant0rH 2 Antworten Letzte Antwort
                                • M memme
                                  @badsnoopy667
                                  B Online
                                  B Online
                                  badsnoopy667
                                  #396
                                  @memme
                                  Ja, das sollte dann gehen!
                                  • M memme
                                    @badsnoopy667
                                    Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    #397
                                    @memme brauchen tust du ihn aber nicht. Habe den SUN2000-30KTL-M3 auch ohne. Ja, der WR weiß nicht, was du verbrauchst und was du einspeist, aber das muss er auch gar nicht wissen. Ich weiß das ja, weil ich die Daten per infrarot am Stromzähler abgreife. 😎
                                    Sammel alle Daten, speicher sie in influx und greife diese mit Grafana ab.
                                    Die Huawei App brauche ich dafür nicht.
                                    Anders wäre es wohl, wenn du einen Akku hast.
                                    • 0 Offline
                                      0 Offline
                                      0815_Peter
                                      #398
                                      Hallo in die Runde,
                                      erstmal Mega großen Dank für eure Mühen das ihr die Huawei Sun Geräte per Modbus im iobroker abbildet.
                                      Ich hab noch gar keine Erfahrungen mit den Node-Red sammeln können hab den Flow dann doch zu laufen bekommen. Fürn Anfänger ist das schon nicht so einfach :-)
                                      Nach einer Weile wo der Flow seine Arbeit macht kommen langsam neue Ideen oder Wünsche hoch.
                                      Laut Beschreibung der Register können auch die Optimierer ausgelesen werden. Könnte mir jemand Unterstützung leisten oder mir ein Grundmodel eines Flows bauen wie man die Optimierer Solar Inverter Modbus Interface Definitions.pdf ausliest?
                                      Und noch eine Frage...wie schreibt man auf bestimmte Register? Wie z.B. aufs Register 47075 --> [Energy storage]Maximum charging power RW UINT32 ?
                                      Habt vielen Dank.
                                      Sonnige Grüße aus Sachsen
                                      Peter
                                      • 0 0815_Peter
                                        Hallo in die Runde,
                                        Habt vielen Dank.
                                        Peter
                                        B Online
                                        B Online
                                        badsnoopy667
                                        #399
                                        @0815_peter
                                        Hallo Peter,
                                        das mit den Optimizern vermute ich wird nix. Die Dokumentation von Huawei zu dem Thema ist (aus meiner Sicht) so unvollständig, das kriegt man nicht ans laufen.
                                        Zum Thema schreiben: Guck mal im 1. Post, da habe ich einen Link zu einer Anleitung, wie man bestimmte Register schreiben kann. Das funktioniert.
                                        • 0 Offline
                                          0 Offline
                                          0815_Peter
                                          #400
                                          @badsnoopy667
                                          Hey badsnoopy,
                                          cool danke für deine schnelle Antwort.
                                          mh schade...der Adapter für die API ins Fusion Portal liest da auch nix richtiges aus und die App ist mir echt zu langsam... da wäre es echt cool die Optimierer gleich mit dem Modbus auszulesen...
                                          Okay ich schau mal in dein Post...das habe ich bestimmt übersehen :-) --> Danke dir...
