  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
    @michaelxhoffmann
    Laufen die Adaper?
    Zeig mal
    iob diag
    in der Langfassung.
    michaelxhoffmann
    @thomas-braun ======== Start marking the full check here =========
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     22:38:25 up 14 min,  1 user,  load average: 1.72, 1.76, 1.22
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=65.7'C
    volt=0.8625V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-29 22:38:25 CEST
               Universal time: Tue 2023-08-29 20:38:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        446M        2.1G        1.0M        1.2G        3.3G
    Swap:            99M          0B         99M
    Total:          3.9G        446M        2.2G
             3794 M total memory
              446 M used memory
              545 M active memory
              923 M inactive memory
             2126 M free memory
              124 M buffer memory
             1096 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  4.6G   23G  17% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Aug 29 22:24:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:BB:67 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7332932-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 29 22:24:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Aug 29 22:24:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug 29 22:24:18 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G	/var/
    1.1G	/var/log
    993M	/var/log/journal/d25d733f60db4f059662faf3a610222b
    178M	/var/cache
    Archived and active journals take up 992.2M in the file system.
    /opt/iobroker/backups:
    209M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    614M	/opt/iobroker/iobroker-data/
    494M	/opt/iobroker/iobroker-data/files
    100M	/opt/iobroker/iobroker-data/backup-objects
    88M	/opt/iobroker/iobroker-data/files/echarts.admin
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.17.1
    /usr/bin/node 		v18.17.1
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	5.0.12
    admin: 		"admin" not found
    javascript: 	"javascript" not found
    Adapters from github: 	1
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
      system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.logparser.0              : logparser             : raspberrypi                              - disabled
      system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.material.0               : material              : raspberrypi                              - disabled
      system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
      system.adapter.milight.0                : milight               : raspberrypi                              -  enabled, port: 5987
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
      system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    latest 1      : http://iobroker.live/repo/sources-dist-latest.json
    default 1     : http://iobroker.live/repo/sources-dist.json
    Installed ioBroker-Instances
    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
    Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Controller "js-controller": 4.0.24   , installed 5.0.12
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Objects and States
    Objects: 	12920
    States: 	10849
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Get:5 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Fetched 4586 B in 2s (2521 B/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14906      1125/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16537      1125/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1545       550/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1547       550/sshd: /usr/sbin
    udp        0      0 0.0.0.0:43918           0.0.0.0:*                           108        1471       398/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1469       398/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14583      736/dhcpcd
    udp6       0      0 :::37280                :::*                                108        1472       398/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          1572       736/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        1470       398/avahi-daemon: r
    2023-08-29 22:39:35.403  - info: host.raspberrypi "system.adapter.vis.0" enabled
    2023-08-29 22:39:35.407  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
    2023-08-29 22:39:35.636  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.vis-metro created/updated
    2023-08-29 22:39:36.765  - info: host.raspberrypi iobroker npm-install: exit 0
    2023-08-29 22:39:37.766  - warn: host.raspberrypi startInstance cannot find adapter "vis-weather@2.5.6". Try to install it... 1 attempt
    2023-08-29 22:39:37.767  - info: host.raspberrypi iobroker install vis-weather@2.5.6 using installedFrom
    2023-08-29 22:39:42.728  - info: host.raspberrypi iobroker npm-install: NPM version: 9.6.7
    2023-08-29 22:39:42.731  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis-weather@2.5.6... (System call)
    2023-08-29 22:39:53.079  - info: host.raspberrypi iobroker npm-install:
    2023-08-29 22:39:53.081  - info: host.raspberrypi iobroker npm-install: added 1 package in 10s
    2023-08-29 22:39:53.083  - info: host.raspberrypi iobroker npm-install: 163 packages are looking for funding
    2023-08-29 22:39:53.085  - info: host.raspberrypi iobroker npm-install:   run `npm fund` for details
    2023-08-29 22:39:53.137  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter vis-weather@2.5.6
    2023-08-29 22:39:53.461  - info: host.raspberrypi iobroker npm-install: upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
    2023-08-29 22:39:53.485  - info: host.raspberrypi iobroker npm-install: upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
    2023-08-29 22:39:53.512  - info: host.raspberrypi iobroker npm-install: upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
    2023-08-29 22:39:53.539  - info: host.raspberrypi iobroker npm-install: upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
    2023-08-29 22:39:53.569  - info: host.raspberrypi iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not found! Nothing was uploaded or deleted.
    2023-08-29 22:39:53.657  - info: host.raspberrypi "system.adapter.vis.0" disabled
    2023-08-29 22:39:53.674  - info: host.raspberrypi "system.adapter.vis.0" enabled
    2023-08-29 22:39:53.677  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
    2023-08-29 22:39:54.003  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.vis-weather created/updated
    2023-08-29 22:39:55.125  - info: host.raspberrypi iobroker npm-install: exit 0
    2023-08-29 22:39:56.125  - warn: host.raspberrypi startInstance cannot find adapter "admin@6.3.5". Try to install it... 1 attempt
    2023-08-29 22:39:56.126  - info: host.raspberrypi iobroker install admin@6.3.5 using installedFrom
    verstehe ich das richtig dass die erforderlichen Instanzen web und Admin nicht gestartet wurden?
    Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
    M Thomas BraunT 2 Antworten Letzte Antwort
    • M michaelxhoffmann
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:	11
      Codename:	bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=65.7'C
      volt=0.8625V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
                446 M used memory
                545 M active memory
               2126 M free memory
                124 M buffer memory
               1096 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.5G	/var/
      1.1G	/var/log
      178M	/var/cache
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	12920
      States: 	10849
      Pending Updates: 0
      michaelxhoffmann
      @michaelxhoffmann mittlerweile läuft die Vorschaltete des Brokers. Auf die Adminseite komme ich allerdings noch immer nicht :( Ich warte mal ab bis morgen früh, vielleicht braucht der Kollege einfach mehr Zeit :))
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:	11
        Codename:	bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=65.7'C
        volt=0.8625V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 3794 M total memory
                  446 M used memory
                  545 M active memory
                 2126 M free memory
                  124 M buffer memory
                 1096 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.5G	/var/
        1.1G	/var/log
        178M	/var/cache
        /usr/bin/npm 		9.6.7
        /usr/bin/npx 		9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	12920
        States: 	10849
        Pending Updates: 0
        @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
        Richtig.
        iob start admin
        iob start web
          @glasfaser sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
          sudo -H -u iobroker npm install iobroker.js-controller
          Super Biobroker läuft wieder! Jetzt fehlt mir lediglich noch der Webadapter bzw. die Adminoberfläche. Die bekomme ich nämlich nicht angezeigt im Browser :(
          Super Biobroker
          Moin,
          ist mir schon von Anfang an aufgefallen, ioBroker ist biologisch wertvoll und heißt ab jetzt Biobroker.
          Sorry konnte nicht anders :)
          Bernd
          P.S.: @michaelxhoffmann den Titel, kannst Du anpassen, indem Du im ersten Post, einfach auf den Titel klickst und änderst.
            Super Biobroker
            Moin,
            Bernd
            michaelxhoffmann
            @dp20 Na klar alles Biologisch :) Aber ich komme an den Startartikel gar nicht mehr ran. Ich komme nicht auf die erste threadseite :) um den Titel zu ändern.
              michaelxhoffmann
              Ich danke Euch allen! Mein BIOBROKER ;) läuft wieder. Der Adminadapter ist wieder auf 6.3.5. Dabei werde ich es erst mal belassen. Vielleicht komme ich ja noch eine Zeit ohne 6.8 aus ;)
              • ? Offline
                Moin,
                zuerst einmal dp20eic nicht nur dp20 :)
                Dann, hä
                Aber ich komme an den Startartikel gar nicht mehr ran. Ich komme nicht auf die erste threadseite um den Titel zu ändern
                Du klickst einfach, hier
                oder
                Und freut mich, dass es wieder läuft.
                Bernd
                  Moin,
                  Dann, hä
                  oder
                  Bernd
                  michaelxhoffmann
                  schrieb am zuletzt editiert von michaelxhoffmann
                  @dp20eic LOL zu früh gefreut der web.0 Adapter läuft nicht. Er ist mit Gerät/Dienst verbunden aber nicht mit dem Host und ohne Lebenszeichen. Ergo meine Visualisierung wird nicht angezeigt. Instanz neu gestartet habe ich schon...Alles andere läuft wieder nur dieser eine Schei... Instanz will nicht so wie ich will Und wie ich gerade feststelle läuft die Socket.io Instanz ebenfalls nicht korrekt.
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @michaelxhoffmann zeig mal die Einstellung in der web Instanz
                      michaelxhoffmann
                      @crunchip web.0 bildschirm.pdf
                      Hoffe das funktioniert
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @michaelxhoffmann mach nen screen und hier direkt einfügen
                          michaelxhoffmann
                          crunchipC M 2 Antworten Letzte Antwort
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @michaelxhoffmann passt eigentlich
                            socketio ist da gar nicht ausgewählt, was heisst nicht korrekt
                              michaelxhoffmann
                              @michaelxhoffmann OK Jetzt wird's noch schlimmer :( IOBroker Weboberfläche öffnet nicht
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @michaelxhoffmann mach mal ein browser refresh(F5)
                                  michaelxhoffmann
                                  @crunchip Gesagt, getan! Oberfläche wieder da alle Instanzen starten gerade neu. Macht mir den Anschein als hätte der Broker neu gestartet? Socket.io und web.0 laufen allerdings noch immer nicht wieder
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    dann schau ins log
                                    iobroker logs --watch
                                    iob list instances
                                      dann schau ins log
                                      iob list instances
                                      michaelxhoffmann
                                      @crunchip
                                      ok Fehlermeldung zum Web.0:
                                      code_text2023-08-30 11:12:28.189  - error: host.raspberrypi instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2023-08-30 11:12:28.189  - info: host.raspberrypi Adapter system.adapter.web.0 needs rebuild and will be restarted afterwards.
                                      2023-08-30 11:12:28.189  - info: host.raspberrypi system.adapter.web.0 will be rebuilt
                                      2023-08-
                                        @crunchip
                                        2023-08-
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        iobroker rebuild web --install
                                          michaelxhoffmann
                                          @crunchip sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                                          Ja, habe ich gemacht. Ergebnis immer noch das gleiche. Web.0 und Socket.io laufen nicht. Muss ich die instanz löschen und neu installieren?
