  4. Absturz bei Aktualisierung - Neustart nicht möglich!
    5.2k
139 Beiträge 8 Kommentatoren 19.7k Aufrufe 7 Beobachtet
    @labamba sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
    buster
    Tot, Nachfolger installieren.
    X-Server: true
    Desktop: LXDE-pi
    Terminal: x11
    Desktop-Mumpitz AUSSCHALTEN.
    /usr/bin/nodejs v16.19.1
    nodejs@18 sauber installieren.
    LaBamba
    Fehlte noch was
    Installed ioBroker-Instances
    node:internal/modules/cjs/loader:1024
      throw err;
    Error: Cannot find module 'node-forge'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
        at Function.Module._load (node:internal/modules/cjs/loader:866:27)
        at Module.require (node:internal/modules/cjs/loader:1093:19)
        at require (node:internal/modules/cjs/helpers:108:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
        at Module._compile (node:internal/modules/cjs/loader:1191:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
        at Module.load (node:internal/modules/cjs/loader:1069:32)
        at Function.Module._load (node:internal/modules/cjs/loader:904:12)
        at Module.require (node:internal/modules/cjs/loader:1093:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Objects and States
    Objects: 	0
    States: 	0
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists...
    Pending Updates: 267
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17009      528/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18596      378/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17011      528/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18580      516/xrdp-sesman
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18595      378/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      110        17746      526/xrdp
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18691      454/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17716      449/cups-browsed
    udp        0      0 0.0.0.0:49817           0.0.0.0:*                           108        15678      372/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15676      372/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          18702      454/dhcpcd
    udp6       0      0 :::56893                :::*                                108        15679      372/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        15677      372/avahi-daemon: r
    2023-08-29 10:32:12.862  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.870  - info: sonoff.0 (20084) terminating
    2023-08-29 10:32:12.873  - info: sonoff.0 (20084) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-08-29 10:32:12.883  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.886  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.888  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.925  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.926  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.927  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.930  - info: node-red.0 (19816) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-08-29 10:32:12.960  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.961  - info: host.raspberrypi instance system.adapter.tankerkoenig.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.963  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:12.987  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:12.988  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:12.988  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:13.209  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
    2023-08-29 10:32:13.210  - info: host.raspberrypi instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-08-29 10:32:13.210  - info: host.raspberrypi All instances are stopped.
    2023-08-29 10:32:13.274  - info: history.0 (19692) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-08-29 10:32:13.283  - info: host.raspberrypi terminated
    2023-08-29 10:32:13.570  - info: simple-api.0 (30475) terminating http server on port 8087
    2023-08-29 10:32:15.117  - info: simple-api.0 (30475) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-08-29 10:32:17.686  - error: simple-api.0 (30475) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    2023-08-29 10:32:18.300  - warn: simple-api.0 (30475) get state error: Connection is closed.
    iob diag has finished.
      buster
      X-Server: true
      Desktop: LXDE-pi
      Terminal: x11
      LaBamba
      @thomas-braun said in Absturz bei Aktualisierung - Neustart nicht möglich!:
      Wie installiert man nodesjs @18 sauber?
      Bin auf Linux nicht ehr Anfänger
      CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
      • L LaBamba
        CodierknechtC Offline
        Codierknecht
        @labamba
        Schau in @Thomas-Braun 's Signatur.
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • L LaBamba
          Du willst zunächst mal die Basis runderneuern und auf Debian 11 'Bullseye' bringen.
          Und den Desktop ausschalten und dich per SSH an der Kiste anmelden.
          L 1 Antwort Letzte Antwort
            LaBamba
            Ich nehme an du meinst per putty
            Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
            • L LaBamba
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Model		: Raspberry Pi 4 Model B Rev 1.1
              Architecture    : armv7l
              Docker          : false
              Virtualization  : none
              Distributor ID:	Raspbian
              Description:	Raspbian GNU/Linux 10 (buster)
              Release:	10
              Codename:	buster
              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
              NAME="Raspbian GNU/Linux"
              VERSION_ID="10"
              VERSION="10 (buster)"
              VERSION_CODENAME=buster
              ID=raspbian
              ID_LIKE=debian
              HOME_URL="http://www.raspbian.org/"
              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
              Systemuptime and Load:
               12:40:11 up  1:36,  1 user,  load average: 0.06, 0.21, 0.18
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=36.5'C
              volt=0.8563V
              *** Time and Time Zones ***
                             Local time: Tue 2023-08-29 12:40:11 CEST
                         Universal time: Tue 2023-08-29 10:40:11 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server: 	true
              Desktop: 	LXDE-pi
              Terminal: 	x11
              Boot Target: 	graphical.target
              *** MEMORY ***
              Mem:           3.8G        188M        3.1G         72M        516M        3.4G
              Swap:           49M          0B         49M
              Total:         3.9G        188M        3.2G
                       3838 M total memory
                        188 M used memory
                        254 M active memory
                        370 M inactive memory
                       3134 M free memory
                        141 M buffer memory
                        375 M swap cache
                         49 M total swap
                          0 M used swap
                         49 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       29G   27G  1.1G  97% /
              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
              tmpfs          tmpfs     1.9G   41M  1.9G   3% /run
              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
              [Tue Aug 29 11:03:36 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:09:ED:BB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d9b3f436-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Tue Aug 29 11:03:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Tue Aug 29 11:03:40 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              TARGET                       SOURCE         FSTYPE            OPTIONS
              /                            /dev/mmcblk0p2 ext4              rw,noatime
              |-/sys/fs/bpf                none           bpf               rw,nosuid,nodev,noexec,relatime,mode=700
              |-/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              /var:
              517M	/var/
              287M	/var/cache
              274M	/var/cache/apt
              215M	/var/cache/apt/archives
              125M	/var/lib
              Archived and active journals take up 39.9M in the file system.
              /opt/iobroker/backups:
              12G	/opt/iobroker/backups/
              1.9M	/opt/iobroker/backups/scripte/common
              948K	/opt/iobroker/backups/scripte/common/Raffstore
              340K	/opt/iobroker/backups/scripte/common/Rolladen
              /opt/iobroker/iobroker-data:
              3.7G	/opt/iobroker/iobroker-data/
              2.7G	/opt/iobroker/iobroker-data/history
              750M	/opt/iobroker/iobroker-data/files
              154M	/opt/iobroker/iobroker-data/backup-objects
              78M	/opt/iobroker/iobroker-data/files/iobroker.icons-open-icon-library-png
              42M	/opt/iobroker/iobroker-data/states.jsonl
              41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              24M	/opt/iobroker/iobroker-data/objects.jsonl
              20M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
              *** NodeJS-Installation ***
              /usr/bin/node 		v16.19.1
              /usr/bin/npm 		9.8.1
              /usr/bin/npx 		9.8.1
              nodejs:
                Installed: 16.19.1-deb-1nodesource1
                Candidate: 16.20.0-deb-1nodesource1
                Version table:
                   16.20.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
               *** 16.19.1-deb-1nodesource1 100
                   10.24.0~dfsg-1~deb10u3 500
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
                throw err;
              Require stack:
                requireStack: [
                throw err;
              Require stack:
                requireStack: [
              Core adapters versions
                throw err;
              Require stack:
                requireStack: [
              js-controller:
                throw err;
              Require stack:
                requireStack: [
              admin:
                throw err;
              Require stack:
                requireStack: [
              javascript:
              *** FILESYSTEM ***
              Filesystem Type Size Used Avail Use% Mounted on
              Moin,
              hat jetzt erst einmal nichts mit Deinem Problem zu tun, aber in einem gesunden Körper, steckt auch ein gesunder Geist :)
              Leider ist Dein Output von iob diag nicht korrekt formatiert, sprich korrekt in den Code Tags, daher ist es nur schwer zu erkennen, aber Dir geht auch der Speicher aus, Du hast zwar eine 29 GB große Disk angelegt und 1.1 GB ist auch noch frei, aber trotz allem ist die zu 97 % voll, da solltest Du mal schauen, wer/wo da der Speicherplatz verschwendet wird.
              *** FILESYSTEM ***
              Bernd
              L crunchipC 2 Antworten Letzte Antwort
                *** FILESYSTEM ***
                Moin,
                *** FILESYSTEM ***
                Bernd
                LaBamba
                @dp20eic
                Danke für die Info!
                Ich bin wirklich kein Linux Experte ehr Anfänger.
                Zu Linux bin ich eigentlich nur durch den Iobroker gekommen.
                Dann habe ich meine Gebäudeautomatisierung immer weiter ausgebaut.
                Folglich sollte nicht viel unnötige Sachen auf dem Rechner sein.
                • L LaBamba
                  puTTY ist ein SSH-Client.
                    *** FILESYSTEM ***
                    Moin,
                    *** FILESYSTEM ***
                    Bernd
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @dp20eic sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                    • L LaBamba
                      Codierknecht
                      Entweder PuTTY oder mit der PowerShell.
                      ssh username@ip-des-iobroker
                        LaBamba
                        So putty läuft!
                          LaBamba
                          @crunchip said in Absturz bei Aktualisierung - Neustart nicht möglich!:
                          Sollte wieder Platz sein!
                            buster
                            X-Server: true
                            Desktop: LXDE-pi
                            Terminal: x11
                            LaBamba
                            pi@raspberrypi:~ $ sudo apt install nodejs=18.17.1-deb-1nodesource
                            E: Version »18.17.1-deb-1nodesource« für »nodejs« konnte nicht gefunden werden.
                            • L LaBamba
                              @labamba
                              nodejs18-Repo angelegt/angepasst?
                              sudo apt update
                              apt policy nodejs
                                @labamba
                                sudo apt update
                                apt policy nodejs
                                LaBamba
                                schrieb am zuletzt editiert von LaBamba
                                Bin noch bei version 16, da sich 18 nicht installieren lässt. Siehe oben!
                                • L LaBamba
                                  Warum nicht? HowTo aus meiner Signatur gelesen?
                                    LaBamba
                                    du meintest doch das?
                                    [HowTo] Nodejs-Installation und Upgrades unter Debian
                                    • L LaBamba
                                      @labamba
                                      Ja.
                                      L 2 Antworten Letzte Antwort
                                        @labamba
                                        Ja.
                                        LaBamba
                                        pi@raspberrypi:~ $ node -v
                                        v18.17.1
                                        Jedoch läuft der iobroker immer noch nicht!
                                        • L LaBamba
                                          v18.17.1
                                          v18.17.1
                                          iob diag full sagt?
