  4. Absturz bei Aktualisierung - Neustart nicht möglich!
    5.2k
139 Beiträge 8 Kommentatoren 19.7k Aufrufe 7 Beobachtet
    @labamba probier mal
    find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
    LaBamba
    @crunchip
    Passiert leider gar nichts
    pi@raspberrypi:~ $ find "/opt/iobroker/node_modules" -type d -iname ".*-????????" ! -iname ".local-chromium" -exec rm -rf "{}" \; &> /dev/null
    pi@raspberrypi:~ $
    • L LaBamba
      ich habe ein Problem.
      Nach einen Aktualisierung einer iobroker-instanz (backup) ist dieser völlig abgestürzt und lässt sich nicht mehr starten.
      Über Remote Desktop erhalte ich nur folgendes.
      pi@raspberrypi:~ $ iobroker
      node:internal/modules/cjs/loader:1024
        throw err;
      Error: Cannot find module 'node-forge'
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
      - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
          at Function.Module._load (node:internal/modules/cjs/loader:866:27)
          at Module.require (node:internal/modules/cjs/loader:1093:19)
          at require (node:internal/modules/cjs/helpers:108:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js:7:15)
          at Module._compile (node:internal/modules/cjs/loader:1191:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
          at Module.load (node:internal/modules/cjs/loader:1069:32)
          at Function.Module._load (node:internal/modules/cjs/loader:904:12)
          at Module.require (node:internal/modules/cjs/loader:1093:19) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
          '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
          '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      Vielleicht kann mir jemand helfen.
      @arteck
      @mickym
      CodierknechtC Offline
      Codierknecht
      @labamba sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
      Ist da tatsächlich ein Desktop installiert? Oder meinst Du eine SSH-Session?
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
      L 1 Antwort Letzte Antwort
      • CodierknechtC Codierknecht
        LaBamba
        @codierknecht
        Ich greife gerade per remote Desktop auf die raspberry pi zu. Ein Monitor ist nicht vorhanden.
        • L LaBamba
          Bringt leider auch nichts!
          pi@raspberrypi:~ $ sudo npm install node-forge
          npm ERR! code ENOTEMPTY
          npm ERR! syscall rename
          npm ERR! path /home/pi/node_modules/npm
          npm ERR! dest /home/pi/node_modules/.npm-03x6SkX9
          npm ERR! errno -39
          npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/node_modules/npm' -> '/home/pi/node_modules/.npm-03x6SkX9'
          npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-08-29T10_16_42_048Z-debug-0.log
          pi@raspberrypi:~ $
          @labamba
          Du stehst auch im falschen Verzeichnis für solche Aktionen.
          Lass die Finger von direkten npm-Kommandos.
          iob diag
          sagt?
          • L LaBamba
            @codierknecht
            Lass den Murks. Desktop ausschalten, per SSH auf die Kiste gehen.
              LaBamba
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Model		: Raspberry Pi 4 Model B Rev 1.1
              Architecture    : armv7l
              Docker          : false
              Virtualization  : none
              Distributor ID:	Raspbian
              Description:	Raspbian GNU/Linux 10 (buster)
              Release:	10
              Codename:	buster
              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
              NAME="Raspbian GNU/Linux"
              VERSION_ID="10"
              VERSION="10 (buster)"
              VERSION_CODENAME=buster
              ID=raspbian
              ID_LIKE=debian
              HOME_URL="http://www.raspbian.org/"
              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
              Systemuptime and Load:
               12:40:11 up  1:36,  1 user,  load average: 0.06, 0.21, 0.18
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              Other values than 0x0 hint to temperature/voltage problems
              temp=36.5'C
              volt=0.8563V
              *** Time and Time Zones ***
                             Local time: Tue 2023-08-29 12:40:11 CEST
                         Universal time: Tue 2023-08-29 10:40:11 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              *** User and Groups ***
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
              *** X-Server-Setup ***
              X-Server: 	true
              Desktop: 	LXDE-pi
              Terminal: 	x11
              Boot Target: 	graphical.target
              *** MEMORY ***
              Mem:           3.8G        188M        3.1G         72M        516M        3.4G
              Swap:           49M          0B         49M
              Total:         3.9G        188M        3.2G
                       3838 M total memory
                        188 M used memory
                        254 M active memory
                        370 M inactive memory
                       3134 M free memory
                        141 M buffer memory
                        375 M swap cache
                         49 M total swap
                          0 M used swap
                         49 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /dev/root      ext4       29G   27G  1.1G  97% /
              devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
              tmpfs          tmpfs     1.9G   41M  1.9G   3% /run
              tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
              [Tue Aug 29 11:03:36 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:09:ED:BB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d9b3f436-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): recovery complete
              [Tue Aug 29 11:03:37 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Tue Aug 29 11:03:37 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Tue Aug 29 11:03:40 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              TARGET                       SOURCE         FSTYPE            OPTIONS
              /                            /dev/mmcblk0p2 ext4              rw,noatime
              |-/sys/fs/bpf                none           bpf               rw,nosuid,nodev,noexec,relatime,mode=700
              |-/run/user/1000/gvfs        gvfsd-fuse     fuse.gvfsd-fuse   rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              |-/boot                      /dev/mmcblk0p1 vfat              rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              `-/home/pi/thinclient_drives xrdp-chansrv   fuse.xrdp-chansrv rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
              /var:
              517M	/var/
              287M	/var/cache
              274M	/var/cache/apt
              215M	/var/cache/apt/archives
              125M	/var/lib
              Archived and active journals take up 39.9M in the file system.
              /opt/iobroker/backups:
              12G	/opt/iobroker/backups/
              1.9M	/opt/iobroker/backups/scripte/common
              948K	/opt/iobroker/backups/scripte/common/Raffstore
              340K	/opt/iobroker/backups/scripte/common/Rolladen
              /opt/iobroker/iobroker-data:
              3.7G	/opt/iobroker/iobroker-data/
              2.7G	/opt/iobroker/iobroker-data/history
              750M	/opt/iobroker/iobroker-data/files
              154M	/opt/iobroker/iobroker-data/backup-objects
              78M	/opt/iobroker/iobroker-data/files/iobroker.icons-open-icon-library-png
              42M	/opt/iobroker/iobroker-data/states.jsonl
              41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
              24M	/opt/iobroker/iobroker-data/objects.jsonl
              20M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
              *** NodeJS-Installation ***
              /usr/bin/nodejs 	v16.19.1
              /usr/bin/node 		v16.19.1
              /usr/bin/npm 		9.8.1
              /usr/bin/npx 		9.8.1
              nodejs:
                Installed: 16.19.1-deb-1nodesource1
                Candidate: 16.20.0-deb-1nodesource1
                Version table:
                   16.20.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
               *** 16.19.1-deb-1nodesource1 100
                   10.24.0~dfsg-1~deb10u3 500
              No problems detected
              *** ioBroker-Installation ***
              ioBroker Status
                throw err;
              Require stack:
                requireStack: [
                throw err;
              Require stack:
                requireStack: [
              Core adapters versions
                throw err;
              Require stack:
                requireStack: [
              js-controller:
                throw err;
              Require stack:
                requireStack: [
              admin:
                throw err;
              Require stack:
                requireStack: [
              javascript:
              Thomas BraunT ? 2 Antworten Letzte Antwort
              • L LaBamba
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:	10
                Codename:	buster
                VERSION_ID="10"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=36.5'C
                volt=0.8563V
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server: 	true
                Desktop: 	LXDE-pi
                Terminal: 	x11
                *** MEMORY ***
                Swap:           49M          0B         49M
                         3838 M total memory
                          188 M used memory
                          254 M active memory
                         3134 M free memory
                          141 M buffer memory
                          375 M swap cache
                           49 M total swap
                            0 M used swap
                           49 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                517M	/var/
                287M	/var/cache
                274M	/var/cache/apt
                125M	/var/lib
                /usr/bin/npm 		9.8.1
                /usr/bin/npx 		9.8.1
                nodejs:
                  Version table:
                ioBroker Status
                  throw err;
                Require stack:
                  requireStack: [
                  throw err;
                Require stack:
                  requireStack: [
                  throw err;
                Require stack:
                  requireStack: [
                js-controller:
                  throw err;
                Require stack:
                  requireStack: [
                admin:
                  throw err;
                Require stack:
                  requireStack: [
                javascript:
                buster
                Tot, Nachfolger installieren.
                X-Server: true
                Desktop: LXDE-pi
                Terminal: x11
                Desktop-Mumpitz AUSSCHALTEN.
                nodejs@18 sauber installieren.
                L 3 Antworten Letzte Antwort
                  buster
                  X-Server: true
                  Desktop: LXDE-pi
                  Terminal: x11
                  LaBamba
                  Fehlte noch was
                  Installed ioBroker-Instances
                    throw err;
                  Require stack:
                    requireStack: [
                  Objects and States
                  Objects: 	0
                  States: 	0
                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Reading package lists...
                  Pending Updates: 267
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17009      528/sshd
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18596      378/cupsd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17011      528/sshd
                  tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18580      516/xrdp-sesman
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18595      378/cupsd
                  tcp6       0      0 :::3389                 :::*                    LISTEN      110        17746      526/xrdp
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18691      454/dhcpcd
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17716      449/cups-browsed
                  udp        0      0 0.0.0.0:49817           0.0.0.0:*                           108        15678      372/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15676      372/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          18702      454/dhcpcd
                  udp6       0      0 :::56893                :::*                                108        15679      372/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        15677      372/avahi-daemon: r
                  2023-08-29 10:32:12.862  - info: host.raspberrypi All instances are stopped.
                  2023-08-29 10:32:12.870  - info: sonoff.0 (20084) terminating
                  2023-08-29 10:32:12.873  - info: sonoff.0 (20084) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2023-08-29 10:32:12.883  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
                  2023-08-29 10:32:12.886  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-08-29 10:32:12.888  - info: host.raspberrypi All instances are stopped.
                  2023-08-29 10:32:12.925  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
                  2023-08-29 10:32:12.926  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-08-29 10:32:12.927  - info: host.raspberrypi All instances are stopped.
                  2023-08-29 10:32:12.930  - info: node-red.0 (19816) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2023-08-29 10:32:12.960  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
                  2023-08-29 10:32:12.961  - info: host.raspberrypi instance system.adapter.tankerkoenig.3 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-08-29 10:32:12.963  - info: host.raspberrypi All instances are stopped.
                  2023-08-29 10:32:12.987  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
                  2023-08-29 10:32:12.988  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-08-29 10:32:12.988  - info: host.raspberrypi All instances are stopped.
                  2023-08-29 10:32:13.209  - error: host.raspberrypi Cannot find view "system" for search "instance" : Connection is closed.
                  2023-08-29 10:32:13.210  - info: host.raspberrypi instance system.adapter.pushover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2023-08-29 10:32:13.210  - info: host.raspberrypi All instances are stopped.
                  2023-08-29 10:32:13.274  - info: history.0 (19692) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2023-08-29 10:32:13.283  - info: host.raspberrypi terminated
                  2023-08-29 10:32:13.570  - info: simple-api.0 (30475) terminating http server on port 8087
                  2023-08-29 10:32:15.117  - info: simple-api.0 (30475) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2023-08-29 10:32:17.686  - error: simple-api.0 (30475) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                  2023-08-29 10:32:18.300  - warn: simple-api.0 (30475) get state error: Connection is closed.
                  iob diag has finished.
                    buster
                    X-Server: true
                    Desktop: LXDE-pi
                    Terminal: x11
                    LaBamba
                    @thomas-braun said in Absturz bei Aktualisierung - Neustart nicht möglich!:
                    Wie installiert man nodesjs @18 sauber?
                    Bin auf Linux nicht ehr Anfänger
                    CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                    • L LaBamba
                      Codierknecht
                      @labamba
                      Schau in @Thomas-Braun 's Signatur.
                      • L LaBamba
                        Du willst zunächst mal die Basis runderneuern und auf Debian 11 'Bullseye' bringen.
                        Und den Desktop ausschalten und dich per SSH an der Kiste anmelden.
                          LaBamba
                          Ich nehme an du meinst per putty
                          Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                          • L LaBamba
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Docker          : false
                            Release:	10
                            Codename:	buster
                            VERSION_ID="10"
                            ID=raspbian
                            ID_LIKE=debian
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=36.5'C
                            volt=0.8563V
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server: 	true
                            Desktop: 	LXDE-pi
                            Terminal: 	x11
                            *** MEMORY ***
                            Swap:           49M          0B         49M
                                     3838 M total memory
                                      188 M used memory
                                      254 M active memory
                                     3134 M free memory
                                      141 M buffer memory
                                      375 M swap cache
                                       49 M total swap
                                        0 M used swap
                                       49 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            517M	/var/
                            287M	/var/cache
                            274M	/var/cache/apt
                            125M	/var/lib
                            /usr/bin/npm 		9.8.1
                            /usr/bin/npx 		9.8.1
                            nodejs:
                              Version table:
                            ioBroker Status
                              throw err;
                            Require stack:
                              requireStack: [
                              throw err;
                            Require stack:
                              requireStack: [
                              throw err;
                            Require stack:
                              requireStack: [
                            js-controller:
                              throw err;
                            Require stack:
                              requireStack: [
                            admin:
                              throw err;
                            Require stack:
                              requireStack: [
                            javascript:
                            *** FILESYSTEM ***
                            Filesystem Type Size Used Avail Use% Mounted on
                            Moin,
                            hat jetzt erst einmal nichts mit Deinem Problem zu tun, aber in einem gesunden Körper, steckt auch ein gesunder Geist :)
                            Leider ist Dein Output von iob diag nicht korrekt formatiert, sprich korrekt in den Code Tags, daher ist es nur schwer zu erkennen, aber Dir geht auch der Speicher aus, Du hast zwar eine 29 GB große Disk angelegt und 1.1 GB ist auch noch frei, aber trotz allem ist die zu 97 % voll, da solltest Du mal schauen, wer/wo da der Speicherplatz verschwendet wird.
                            *** FILESYSTEM ***
                            Bernd
                            L crunchipC 2 Antworten Letzte Antwort
                              *** FILESYSTEM ***
                              Moin,
                              *** FILESYSTEM ***
                              Bernd
                              LaBamba
                              @dp20eic
                              Danke für die Info!
                              Ich bin wirklich kein Linux Experte ehr Anfänger.
                              Zu Linux bin ich eigentlich nur durch den Iobroker gekommen.
                              Dann habe ich meine Gebäudeautomatisierung immer weiter ausgebaut.
                              Folglich sollte nicht viel unnötige Sachen auf dem Rechner sein.
                              • L LaBamba
                                puTTY ist ein SSH-Client.
                                  *** FILESYSTEM ***
                                  Moin,
                                  *** FILESYSTEM ***
                                  Bernd
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  @dp20eic sagte in Absturz bei Aktualisierung - Neustart nicht möglich!:
                                  • L LaBamba
                                    Codierknecht
                                    Entweder PuTTY oder mit der PowerShell.
                                    ssh username@ip-des-iobroker
                                      LaBamba
                                      So putty läuft!
                                        LaBamba
                                        @crunchip said in Absturz bei Aktualisierung - Neustart nicht möglich!:
                                        Sollte wieder Platz sein!
                                          buster
                                          X-Server: true
                                          Desktop: LXDE-pi
                                          Terminal: x11
                                          LaBamba
                                          pi@raspberrypi:~ $ sudo apt install nodejs=18.17.1-deb-1nodesource
                                          E: Version »18.17.1-deb-1nodesource« für »nodejs« konnte nicht gefunden werden.
