  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • C Czarno13
    @djmarc75
    Aber es geht auch mit App:
    wird nur dann angezeigt, wenn Spotify läuft
    BravestarrB Offline
    BravestarrB Offline
    Bravestarr
    schrieb am zuletzt editiert von Bravestarr
    #958
    @czarno13 No the app is always active and does not disapear or appear when a song is played.
    What works is this:
    // Create a state change listener for spotify-premium.0.player.trackName
    on({ id: 'spotify-premium.0.player.trackName', change: 'ne', ack: true }, function (obj) {
        if (!obj || !obj.state || obj.state.val === null) {
            console.warn('Invalid trackName state object or null value.');
            return;
        const newTrackName = obj.state.val;
        const notificationText = `Now playing: ${newTrackName}`;
        if (newTrackName.trim() === '') {
            console.warn('Track name is empty.');
            return;
        // Send the notification to Awtrix display
        sendTo('awtrix-light', 'notification', { text: notificationText, repeat: 1, duration: 5, stack: true, wakeup: true }, (res) => {
            if (res && res.error) {
                console.error(res.error);
    C M 2 Antworten Letzte Antwort
    • BravestarrB Bravestarr
      What works is this:
              return;
              return;
      Czarno13
      schrieb am zuletzt editiert von Czarno13
      #959
      @bravestarr
      no, for me it works exactly like that, it only displays something when spotify is playing
      BravestarrB 1 Antwort Letzte Antwort
        What works is this:
                return;
                return;
        MCU
        #960
        @bravestarr Please set all of Code in Code Tags. Thanks.
        • C Czarno13
          @bravestarr
          BravestarrB Offline
          BravestarrB Offline
          Bravestarr
          #961
          @czarno13 said in Test Adapter Awtrix-Light:
          @bravestarr
          Yes, but what I wanted and accomplished with the notice triggered by the js adapter is when a songs starts its name is briefly displayed and disappears after 3 seconds. I do not want to keep the song visible while spotify is playing.
          BTW: how can I display an icon cia id in the js notice?
          • M MCU
            BravestarrB Offline
            BravestarrB Offline
            Bravestarr
            #962
            @mcu done
              @mcu done
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #963
              @bravestarr Warum eigentlich auf englisch ??? Du hast in Deinen vergangenen Beiträgen in deutsch geschrieben.... ist das Schikane oder ein Scherz ??
              Lehrling seit 1975 !!!
              • DJMarc75D DJMarc75
                BravestarrB Offline
                BravestarrB Offline
                Bravestarr
                #964
                @djmarc75 ich kann auch deutsch, aber so verstehen es mehr Leute. Das hilft ja auch anderen wenn ich dumme Fragen stelle
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #965
                  @bravestarr sagte in Test Adapter Awtrix-Light:
                  definitiv nicht - im deutschen Forum ;)
                  Das Blockly schon probiert ?
                  Das ist nämlich genau für so was vorgesehen.
                  • JB_SullivanJ JB_Sullivan
                    Uiiii - mit der 0.71 Firmware kann man auch Ringtone Dateien abspielen. Wird das der Adapter ggf. auch unterstützen?
                    haus-automatisierungH Offline
                    #966
                    @jb_sullivan sagte in Test Adapter Awtrix-Light:
                    Was ist daran neu in der Version?
                    📚 Meine Dokumentation
                      @thomas-braun sagte in Test Adapter Awtrix-Light:
                      @njdfg sagte in Test Adapter Awtrix-Light:
                      beim editieren bleiben die Buttons inaktiv.
                      Dann ist der Text nicht plausibel/zugelassen.
                      Nein würde ich nicht sagen - ich habe ein ähnliches/gleiches Problem. Es reicht, wenn man die Instanz Einstellungen öffnet. Ab diesem Moment sind die Buttons unten ausgegraut und haben einen roten Rahmen.
                      Wartet man 2-3 Minuten ohne jedwede Aktion, sind die roten Linien weg und die Buttons bedienbar.
                      Mir persönlich kommt es so vor, als ob der Adapter eine Art Datenbank nutzt, welche im Hintergrund eingelesen wird. Erst wenn dieses einlesen fertig ist kann man wieder Aktionen ausführen.
                      Ähnliches passiert, wenn man einen App Namen anlegt. Hier kann man zusehen, wie im 1,5 Sek. Takt Buchstabe für Buchstabe in die Eingabezeile rein geschrieben werden. In der Zeit sind die Buttons ebenfalls ausgegraut und haben einen roten Rahmen.
                      #967
                      Ich hab Dir das doch schon öfter hier erklärt: Der Adapter selbst macht hier gar nichts. Die komplette Konfigurationsseite kommt so aus dem Admin-Adapter. Also: Keine "Datenbank" o.ä. Das ist pures JavaScript im Frontend auf dem Client.
                      Du hast ja richtig viele Apps eingerichtet, oder? Ich könnte mir vorstellen, dass die Validierung der Felder nie für hunderte Felder getestet wurde. Eventuell ist das nicht sehr performant. Das wäre auch ein Issue für den Admin-Adapter und man müsste das mal genau untersuchen mit verschiedenen Clients/Browsern usw.
                      • Ben1983B Offline
                        Ben1983B Offline
                        Ben1983
                        #968
                        @haus-automatisierung bei mir tritt folgendes Verhalten manchmal auf:
                        Abends wird das Display mit power = false deaktivert.
                        der Adapter meldet ca. 2-4 min später:
                        2023-07-26 22:04:55.074 - warn: awtrix-light.0 (802) (custom?name=gridpower) Unable to update custom app "gridpower": AxiosError: timeout of 3000ms exceeded
                        2023-07-26 22:14:39.220 - error: awtrix-light.0 (802) Unable to perform action for indicator.1.active - API is not connected (device not reachable?)
                        2023-07-26 22:14:39.224 - error: awtrix-light.0 (802) Unable to perform action for indicator.3.active - API is not connected (device not reachable?)
                        2023-07-26 22:14:39.228 - error: awtrix-light.0 (802) Unable to perform action for apps.storagepower.visible - API is not connected (device not reachable?)
                        danach keine Fehlermeldung mehr.
                        Das Gerät wird morgens wieder aktiviert (display.power = true)
                        Daraufhin ca. 30s später:
                        2023-07-27 06:00:36.240 - error: awtrix-light.0 (802) Unable to perform action for display.power - API is not connected (device not reachable?)
                        dann ist ca. 30min Ruhe und dann fängt es so an:
                        2023-07-27 06:30:50.152 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:30:52.194 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:30:58.149 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:00.169 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:02.068 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:04.126 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:06.184 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:08.198 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:10.228 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:14.182 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        2023-07-27 06:31:16.174 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
                        Das Gerät ist aus.
                        Neustart und alles läuft einwandfrei.
                        Die Meldung, dass nicht conected ist, scheint also zu stimmen, aber keine Ahnung, ob das Gerät auch startet durch display.power = true
                        (Mit meinen manuellen Versuchen hat es bis jetzt geklappt, allerdings ist morgens das display, wenn ich ins Büro komme manchmal dunkel)=>(Geräthängt dauerhaft am USB)
                        arteckA NWHN 2 Antworten Letzte Antwort
                        • Ben1983B Ben1983
                          Das Gerät ist aus.
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #969
                          @ben1983 sagte in Test Adapter Awtrix-Light:
                          damit hängt es zusammen.... habs auch .. ich mach die dann auf brightness 0 ..
                          dann macht die kein disco.. scheint als ob die in Batterie schonmodus geht .. und macht das WIFI aus..
                          reconnected sich dann aber nicht
                          • arteckA arteck
                            Ben1983B Offline
                            Ben1983B Offline
                            Ben1983
                            #970
                            @arteck OK, allerdings ist dien "Brightness" ja nur readable.
                            • Ben1983B Ben1983
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #971
                              @ben1983 dann nimm den richtigen
                              • arteckA arteck
                                Ben1983B Offline
                                Ben1983B Offline
                                Ben1983
                                #972
                                @arteck Danke. Werde es umstellen und beobachten.
                                Scheint als dann wirklich ein sporadisches "Fehlverhalten" der Uhr zu sein, denn jeden Tag ist es nicht.
                                  BravestarrB Offline
                                  BravestarrB Offline
                                  Bravestarr
                                  #973
                                  @djmarc75 Oh sorry. Diese Seite wurde durch GitHub verlinkt vom Entwickler dieses Adapters.
                                  Blocky ist doch eine Klicky-Bunti Version im JS Adapter? Ich denke, dass JS selber hier viel mehr kann als man mit Blocky abbilden könnte.
                                  • BravestarrB Offline
                                    BravestarrB Offline
                                    Bravestarr
                                    #974
                                    Kann man ohne JS/Blocky auch mehrere Werte in einer custom app darstellen? Also Beispiel Spotify Artist + Song Titel über die Oberfläche des Awtrix Adapters? Oder geht immer nur ein Wert?
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #975
                                      @bravestarr konkatiniere es in eine eigene variable.und zeige die an..oder leg ein alias an.. mit den Werten
                                      • M Michaelnorge
                                        @mcu Genial, hat geklappt! 1000 Dank :-))))
                                        Kelzith
                                        #976
                                        @michaelnorge Anstatt eine veraltete Firmware zu nutzen, solltest du die Hintergrundeffekte nutzen. Dort findest du deine Augen wieder. Einen Punkt als Text mit Textfarbe schwarz und alles ist gut :-)
                                        • Ben1983B Ben1983
                                          Das Gerät ist aus.
                                          NWHN Offline
                                          NWHN Offline
                                          NWH
                                          #977
                                          @ben1983 Darf ich fragen, gibt es hierfür schon eine Lösung?
                                          Bei mir ist es so, dass ich per Adapter ein paar Werte die sich relative Rasch ändern anzeigen lasse. Das funktioniert soweit alles gut.
                                          Aber nach einer Zeit schaltet das Gerät einfach ab. Und ist nicht mehr erreichbar. Ich kann es nur manuell wieder anschalten.( Taste Links und Rechts 3s)
                                          Dann geht es wieder und das Spiel fängt von norne an.
                                          Das ist leider etwas nervig.
                                          Die Ulanzi ist gnaz neu und der Akku ist noch drinnen.
                                          Gibt es hierfür eine Lösung, dass das Gerät sich nicht immer ausschaltet?
                                          arteckA Ben1983B 2 Antworten Letzte Antwort
