  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • Ben1983B Offline
    Ben1983B Offline
    Ben1983
    #968
    @haus-automatisierung bei mir tritt folgendes Verhalten manchmal auf:
    Abends wird das Display mit power = false deaktivert.
    der Adapter meldet ca. 2-4 min später:
    2023-07-26 22:04:55.074 - warn: awtrix-light.0 (802) (custom?name=gridpower) Unable to update custom app "gridpower": AxiosError: timeout of 3000ms exceeded
    2023-07-26 22:14:39.220 - error: awtrix-light.0 (802) Unable to perform action for indicator.1.active - API is not connected (device not reachable?)
    2023-07-26 22:14:39.224 - error: awtrix-light.0 (802) Unable to perform action for indicator.3.active - API is not connected (device not reachable?)
    2023-07-26 22:14:39.228 - error: awtrix-light.0 (802) Unable to perform action for apps.storagepower.visible - API is not connected (device not reachable?)
    danach keine Fehlermeldung mehr.
    Das Gerät wird morgens wieder aktiviert (display.power = true)
    Daraufhin ca. 30s später:
    2023-07-27 06:00:36.240 - error: awtrix-light.0 (802) Unable to perform action for display.power - API is not connected (device not reachable?)
    dann ist ca. 30min Ruhe und dann fängt es so an:
    2023-07-27 06:30:50.152 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:30:52.194 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:30:58.149 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:00.169 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:02.068 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:04.126 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:06.184 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:08.198 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:10.228 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:14.182 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    2023-07-27 06:31:16.174 - error: awtrix-light.0 (802) Unable to perform action for apps.pvpower.visible - API is not connected (device not reachable?)
    Das Gerät ist aus.
    Neustart und alles läuft einwandfrei.
    Die Meldung, dass nicht conected ist, scheint also zu stimmen, aber keine Ahnung, ob das Gerät auch startet durch display.power = true
    (Mit meinen manuellen Versuchen hat es bis jetzt geklappt, allerdings ist morgens das display, wenn ich ins Büro komme manchmal dunkel)=>(Geräthängt dauerhaft am USB)
    arteckA NWHN 2 Antworten Letzte Antwort
    • Ben1983B Ben1983
      Das Gerät ist aus.
      arteckA Offline
      arteckA Offline
      arteck
      #969
      @ben1983 sagte in Test Adapter Awtrix-Light:
      damit hängt es zusammen.... habs auch .. ich mach die dann auf brightness 0 ..
      dann macht die kein disco.. scheint als ob die in Batterie schonmodus geht .. und macht das WIFI aus..
      reconnected sich dann aber nicht
      • arteckA arteck
        Ben1983B Offline
        Ben1983B Offline
        Ben1983
        #970
        @arteck OK, allerdings ist dien "Brightness" ja nur readable.
        • Ben1983B Ben1983
          arteckA Offline
          arteckA Offline
          arteck
          #971
          @ben1983 dann nimm den richtigen
          • arteckA arteck
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            #972
            @arteck Danke. Werde es umstellen und beobachten.
            Scheint als dann wirklich ein sporadisches "Fehlverhalten" der Uhr zu sein, denn jeden Tag ist es nicht.
            • DJMarc75D DJMarc75
              @bravestarr sagte in Test Adapter Awtrix-Light:
              so verstehen es mehr Leute
              definitiv nicht - im deutschen Forum ;)
              Das Blockly schon probiert ?
              Das ist nämlich genau für so was vorgesehen.
              BravestarrB Offline
              BravestarrB Offline
              Bravestarr
              #973
              @djmarc75 Oh sorry. Diese Seite wurde durch GitHub verlinkt vom Entwickler dieses Adapters.
              Blocky ist doch eine Klicky-Bunti Version im JS Adapter? Ich denke, dass JS selber hier viel mehr kann als man mit Blocky abbilden könnte.
              • BravestarrB Offline
                BravestarrB Offline
                Bravestarr
                #974
                Kann man ohne JS/Blocky auch mehrere Werte in einer custom app darstellen? Also Beispiel Spotify Artist + Song Titel über die Oberfläche des Awtrix Adapters? Oder geht immer nur ein Wert?
                • BravestarrB Bravestarr
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #975
                  @bravestarr konkatiniere es in eine eigene variable.und zeige die an..oder leg ein alias an.. mit den Werten
                  • M Michaelnorge
                    @mcu Genial, hat geklappt! 1000 Dank :-))))
                    Kelzith
                    #976
                    @michaelnorge Anstatt eine veraltete Firmware zu nutzen, solltest du die Hintergrundeffekte nutzen. Dort findest du deine Augen wieder. Einen Punkt als Text mit Textfarbe schwarz und alles ist gut :-)
                    • Ben1983B Ben1983
                      Das Gerät ist aus.
                      NWHN Offline
                      NWHN Offline
                      NWH
                      #977
                      @ben1983 Darf ich fragen, gibt es hierfür schon eine Lösung?
                      Bei mir ist es so, dass ich per Adapter ein paar Werte die sich relative Rasch ändern anzeigen lasse. Das funktioniert soweit alles gut.
                      Aber nach einer Zeit schaltet das Gerät einfach ab. Und ist nicht mehr erreichbar. Ich kann es nur manuell wieder anschalten.( Taste Links und Rechts 3s)
                      Dann geht es wieder und das Spiel fängt von norne an.
                      Das ist leider etwas nervig.
                      Die Ulanzi ist gnaz neu und der Akku ist noch drinnen.
                      Gibt es hierfür eine Lösung, dass das Gerät sich nicht immer ausschaltet?
                      arteckA Ben1983B 2 Antworten Letzte Antwort
                      • K Kelzith
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #978
                        @kelzith sagte in Test Adapter Awtrix-Light:
                        Bitte um eine genau Erklärung denn es gibt im Adapter keine Datenpunkte wie "Hintergrundeffekte" oder Ähnliches.
                        Lehrling seit 1975 !!!
                        • NWHN NWH
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #979
                          @nwh sagte in Test Adapter Awtrix-Light:
                          und was hat das mit dem Adapter zu tun ??
                          NWHN 1 Antwort Letzte Antwort
                            Kelzith
                            schrieb am zuletzt editiert von Kelzith
                            #980
                            @djmarc75 siehe aktuelles Changelog:
                            0.6.02023-07-26
                            Updated recommended firmware version to 0.71
                            klein0rAdded option for background effects* (klein0r) Setting default of repeat to 0
                            klein0rDropped timer support (removed in firmware 0.71)* (klein0r) Removed native app "eyes" (removed in firmware 0.71)
                            Sieht dann so aus:
                            Alle Hintergrundeffekte sind hier beschrieben -> https://blueforcer.github.io/awtrix-light/#/effects
                            • arteckA arteck
                              NWHN Offline
                              NWHN Offline
                              NWH
                              #981
                              @arteck Keine Ahnung ob es was damit zu tun hat. Vielleicht gibt es eine möglichkeit was einzustellen damit eben das nicht passiert,
                              Kann sein das ich was übersehen od. überlesen habe.
                              • K Kelzith
                                0.6.02023-07-26
                                Sieht dann so aus:
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                #982
                                0.6.02023-07-26
                                ok, aber dann bitte immer auf die Version vom Adapter hinweisen, denn nicht bei jedem hier kommen AdapterUpdates über das Repo sofort rein.
                                Bei mir eben erst nach einem manuellen RepoUpdate.
                                Und JA, in der 0.6.0 gibt es jetzt diese Option.
                                • SKBS Offline
                                  SKBS Offline
                                  SKB
                                  #983
                                  Da ich den Adapter aktuell nicht testen kann, weil ich das admin 6.6 aus dem beta Kanal nicht nutzen möchte, die Frage, ob man schon unterschiedliche Farben/Icons bei unterschiedlichen Werten nutzen kann?
                                  • SKBS SKB
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    #984
                                    @skb sagte in Test Adapter Awtrix-Light:
                                    Jawoll
                                    SKBS haus-automatisierungH 2 Antworten Letzte Antwort
                                      Jawoll
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      #985
                                      @djmarc75 Danke für die Auskunft :)
                                      Ich bleibe trotzdem noch bei meinem Skript für die Uhr, da ich so den beta Admin umgehen kann und zusätzlich noch ein wenig flexibler bin :)
                                        Jawoll
                                        haus-automatisierungH Offline
                                        #986
                                        @djmarc75 Mh, da müsste ich mal noch eine Prüfung einbauen, ob die Konfiguration wirklich sinnig ist :) Bei 9,95 würden ja nun beide Regeln bei Dir treffen.
                                        EDIT: Momentan "gewinnt" die "kleiner als"-Regel
                                        📚 Meine Dokumentation
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          #987
                                          @haus-automatisierung sagte in Test Adapter Awtrix-Light:
                                          Nein, da ich in dem Fall schon den Wert auf eine Nachkommastelle im OriginalDP setze :)
