Adapter für Ecoflow Einbindung
@waly_de Läuft alles! Edit: Habe nun mein Skript mit deinen laufenden Daten gefühlt. setAC wird jede Minute neu berechnet und gesetzt. Endlich kann man auch in 1er Schritten und nicht nur in 10er Schritten die Leistung verstellen. Und endlich habe ich eine permanente 0-Einspeisung! :)
@applepro
Super das es klappt
hier eine neue Version. Es gab noch ein Problem beim anlegen der States.
Und ich versuche hier ein Phänomen zu beseitigen: Der MQTT hört auf Nachrichten zu senden, wenn man die App auf dem Handy beendet... Bin noch nicht sicher ob es jetzt durchläuft.../** * ecoflow-iobroker-connector.js * Version: 0.4 * Release date: 29.06.2023 * Autor: Waly_de * Forum: https://forum.iobroker.net/topic/54929/adapter-für-ecoflow-einbindung/155 * * * This JavaScript file establishes a simple connection between IOBroker and EcoFlow. * It automatically creates known states under 0_userdata. * * Please note that adjustments in the ConfigData section are required. Here, you need to enter your access credentials * used for the EcoFlow app, as well as the serial numbers of your devices. * * Important: The second serial number entry should always correspond to the Powerstream as it is associated with control functions. * * If you have a state that displays the current power consumption (SmartmeterID), please provide it as well. * Configure a history for this state so that the script can determine the lowest power consumption in the last 10 minutes (configurable). * This value will be used to dynamically adjust the Powerstream's feed-in power. * * Not all parameters of the Powerstream data are known yet. All known parameters will be automatically created as states. * By modifying the "protoSource" constant, newly discovered data will also be automatically created. * * The raw data of the interface is logged as a HEX string. * * Please exercise caution as this is the initial version of the script. Use it at your own risk! * * Requirements: * - Install protobuf using the command "npm install protobufjs" from the terminal console. * - The "Paho MQTT Client" is also required. If not already installed, use the command "npm install mqtt". * * Note: It is encouraged to discover and publish missing data definitions to improve the script. * Suggestions, optimizations, and extensions are welcome at any time. * * Special thanks to all contributors for their valuable input and support. * * Changelog: * ----------------------------------------------------------- * (0.4) 29.06.2023 * Da der MQTT von ecoflow regelmäßig aufhört zu senden, vor allem, wenn die App genutzt und komplett geschlossen wird, * habe ich eine Überwachung der letzten ankommenden Nachrichten eingebaut. Kommt 5 Minuten lang nichts neues vom PowerStream, * Wird die Verbindung zum MQTT kompett neu aufgebaut. * * Ein Fehler bei der Erstellung der States wurde beseitigt * ----------------------------------------------------------- * */ /******* YOUR DATA HERE **************** var ConfigData = { email: "your@mail.com", passwort: "yourAppPasswort!", seriennummern: [ { seriennummer: "XXXXXXXXXXXXX", name: "PowerStream" }, //1. has to be your PowerStream, you can add more devices... { seriennummer: "XXXXXXXXXXXXX", name: "DELTA Max" } ], SmartmeterID: "sonoff.0.Stromzaehler1.MT175_P", //State, das den aktuellen Gesamtverbrauch in Watt enthält BasePowerOffset: 50, //wird vom aktuellen Verbrauch abgezogen um die Einspeiseleistung zu berechnen MaxPower: 600, //Der höchst mögliche wert in Watt für die Einspeiseleistung MinValueMin: 10, //Der Zeitraum in Minuten, aus dem der letzte Gesamtverbrauchs-Minimalwert geholt werden soll ReconnectMin: 30, //Zeit in Minuten, nach der die Anwendung neu gestartet wird, wenn keine neuen Daten eintreffen statesPrefix: "0_userdata.0.ecoflow", Debug: true }; //***************************************/ const protoSource = ` syntax = "proto3"; message PowerItem { optional Meta meta = 1; optional uint32 src = 2; optional uint32 dest = 3; optional uint32 unknown1 = 4; optional uint32 unknown2 = 5; optional uint32 unknown3 = 6; optional uint32 unknown4 = 7; optional uint32 cmdFunc = 8; optional CmdFunction cmdId = 9; optional uint32 unknown5 = 10; optional uint32 needAck = 11; uint64 timestamp = 14; optional uint32 unknown6 = 16; //3 Byte? optional uint32 unknown7 = 17; //3 Byte? optional string OS = 23; optional string serialNumber = 25; } message PowerMessage { PowerItem item = 1; } message Meta { optional int32 value = 1; optional int32 plugPower = 10; optional int32 M_Unknown7 = 14; // bei Prio-änderung gesehen optional int32 M_Unknown8 = 15; //bei Prio-änderung gesehen optional int32 PV1_Power = 19; optional int32 M_Unknown1 = 21; optional int32 PV2_Power = 24; optional int32 From_Bat_Power = 29; optional int32 Batt_Poz = 31; optional int32 M_Unknown2 = 33; optional int32 M_Unknown3 = 35; optional int32 M_Unknown6 = 37; optional int32 ToHome_Power = 38; optional int32 M_Unknown9 = 43; //prio Power von summe PVx_Power abziehen ? optional int32 Needed_Power = 48; optional int32 M_Unknown4 = 59; optional int32 Bat_Minutes = 60; } enum CmdFunction { Unknown = 0; PermanentWattsPack = 129; SupplyPriorityPack = 130; } `; const mqtt = require('mqtt'); const https = require('https'); const protobuf = require("protobufjs"); const mqttDaten = { UserID: '', User: '', Passwort: '', URL: '', Port: '', protocol: '', clientID: '' } /*======================================================= ========= Timer ============ =======================================================*/ //alle 5 minuten schedule('*/1 * * * *', function () { CheckforReconnect(function () { SetBasePower(); }); }); await getEcoFlowMqttData(ConfigData.email, ConfigData.passwort) async function getEcoFlowMqttData(email, password) { const options = { hostname: 'api.ecoflow.com', path: '/auth/login', method: 'POST', headers: { 'Host': 'api.ecoflow.com', 'lang': 'de-de', 'platform': 'android', 'sysversion': '11', 'version': '4.1.2.02', 'phonemodel': 'SM-X200', 'content-type': 'application/json', 'user-agent': 'okhttp/3.14.9' } }; const data = { appVersion: "4.1.2.02", email: email, os: "android", osVersion: "30", password: Buffer.from(password).toString('base64'), scene: "IOT_APP", userType: "ECOFLOW" }; function httpsRequest(options, data) { return new Promise((resolve, reject) => { const req = https.request(options, res => { let data = ''; res.on('data', chunk => { data += chunk; }); res.on('end', () => { resolve(data); }); }); req.on('error', error => { reject(error); }); if (data) { req.write(JSON.stringify(data)); } req.end(); }); } function uuidv4() { return 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function (c) { var r = Math.random() * 16 | 0, v = c === 'x' ? r : (r & 0x3 | 0x8); return v.toString(16); }); } let response = await httpsRequest(options, data); try { let token = JSON.parse(response).data.token; let userid = JSON.parse(response).data.user.userId; } catch (error) { log(response) throw new Error("Ein Fehler bei der Ermittlung der Zugangsdaten ist aufgetreten. Bitte prüfe die Zugangsdaten."); } let token = JSON.parse(response).data.token; let userid = JSON.parse(response).data.user.userId; options.path = `/iot-auth/app/certification?userId=${userid}`; options.method = 'GET'; options.headers.authorization = `Bearer ${token}`; response = await httpsRequest(options); try { mqttDaten.Passwort = JSON.parse(response).data.certificatePassword mqttDaten.Port = JSON.parse(response).data.port mqttDaten.UserID = userid mqttDaten.User = JSON.parse(response).data.certificateAccount mqttDaten.URL = JSON.parse(response).data.url mqttDaten.protocol = JSON.parse(response).data.protocol mqttDaten.clientID = "ANDROID_" + uuidv4() + "_" + userid } catch (error) { log(response) throw new Error("Ein Fehler bei der Ermittlung der Zugangsdaten ist aufgetreten. Bitte prüfe die Zugangsdaten."); } /* console.log("UserID: " + userid); console.log("User: " + JSON.parse(response).data.certificateAccount); console.log("Passwort: " + JSON.parse(response).data.certificatePassword); console.log("URL: " + JSON.parse(response).data.url); console.log("Port: " + JSON.parse(response).data.port); console.log("protocol: " + JSON.parse(response).data.protocol); console.log("clientID: ANDROID_" + uuidv4() + "_" + userid); */ } await createMyState("LastTopic") //################ MQTT Verbindung ################## function setupMQTTConnection() { // Verbindung herstellen const options = { port: mqttDaten.Port, clientId: mqttDaten.clientID, username: mqttDaten.User, password: mqttDaten.Passwort, protocol: mqttDaten.protocol }; const client = mqtt.connect("mqtt://" + mqttDaten.URL, options); // Event-Handler für Verbindungsaufbau client.on('connect', function () { console.log('Verbunden mit dem Ecoflow MQTT-Broker'); SubscribeEco(); }); // Event-Handler für Fehler client.on('error', function (error) { console.log('Fehler bei der Ecoflow MQTT-Verbindung: ' + error); }); function SubscribeEco() { ConfigData.seriennummern.forEach(item => { client.subscribe('/app/' + mqttDaten.UserID + '/' + item.seriennummer + '/thing/property/set'); client.subscribe('/app/' + mqttDaten.UserID + '/' + item.seriennummer + '/thing/property/get'); client.subscribe('/app/device/property/' + item.seriennummer); setmusterGetPS(); }); } // Auf Nachricht empfangen Ereignis reagieren client.on('message', async function (topic, message) { var jsonMessage = "" const mqState = topic.replace(/^\//, '').replace(/\//g, '_') await createMyState(mqState + ".RAW") setState(ConfigData.statesPrefix + ".LastTopic", topic) try { jsonMessage = JSON.parse(message); if (ConfigData.Debug) log('JSON-Nachricht empfangen:' + topic + ':' + JSON.stringify(jsonMessage)); setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", JSON.stringify(jsonMessage)) generateAndSyncSub("data", jsonMessage, false, ConfigData.statesPrefix + '.' + mqState) } catch (error) { if (ConfigData.Debug) log('Binäre Nachricht empfangen:' + topic + ':' + message.toString('hex')); await createMyState(mqState + ".RAW_HEX") setState(ConfigData.statesPrefix + '.' + mqState + ".RAW_HEX", message.toString('hex')) //log('Decodierte Nachricht:' + decodeAndPrint(message.toString('hex'))) const messagedecoded = decodeAndPrint(message.toString('hex')) setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", messagedecoded) generateAndSyncSub("data", JSON.parse(messagedecoded), false, ConfigData.statesPrefix + '.' + mqState) } }); // Callback für Fehler client.on('error', function (error) { log('Fehler bei der Ecoflow MQTT-Verbindung:' + error, 'warn'); }); client.on('reconnect', function () { console.log('Reconnecting to Ecoflow MQTT broker...'); }); // Weitere Event-Handler hier... return client; } // Verbindung herstellen let client = setupMQTTConnection(); // Funktion zum Trennen und Neuaufbau der Verbindung function reconnect() { client.end(); // Verbindung trennen setTimeout(function () { client = setupMQTTConnection(); // Neue Verbindung herstellen //log("Ecoflow neuverbindung"); }, 2000); // Wartezeit } // close connection if script stopped onStop(function (callback) { if (client) { // close connection client.end(); log("Ecoflow MQTT-Client beendet") } callback(); }, 2000); function CheckforReconnect(callback) { if (getState(ConfigData.statesPrefix + ".LastTopic")?.ts < Date.now() - ConfigData.ReconnectMin * 60 * 1000) { console.log("Der letzte Eintrag ist älter als " + ConfigData.ReconnectMin + " Minuten. Versuche Neustart."); setState(ConfigData.statesPrefix + ".LastTopic", "Last Action Restart:" + new Date().toLocaleString()) runScript(); return; // Wenn letzte Powerstream-Meldung älter als 5 min ist, schicke Lebenszeichen } else if (getState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX')?.ts < Date.now() - 5 * 60 * 1000) { log("Reconnect zu Ecoflow MQTT für PowerStream - Daten") //setmusterGetPS() //.ts Updaten const oldvalue = getState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX').val setState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX', oldvalue) reconnect(); return; //runScript(); } else { callback(); } } //*/ async function createMyState(name) { if (!(await existsObjectAsync(ConfigData.statesPrefix + '.' + name))) { await createStateAsync(ConfigData.statesPrefix + '.' + name, { name: name.split('.').pop(), role: 'state', type: 'string', read: true, write: true }); } } function decodeAndPrint(hexString) { const root = protobuf.parse(protoSource).root; const PowerMessage = root.lookupType("PowerMessage"); const message = PowerMessage.decode(Buffer.from(hexString, "hex")); const object = PowerMessage.toObject(message, { defaults: false }); return JSON.stringify(object); } function SendProto(protomsg, topic) { const root = protobuf.parse(protoSource).root; const PowerMessage = root.lookupType("PowerMessage"); const message = PowerMessage.create(JSON.parse(protomsg)); const messageBuffer = PowerMessage.encode(message).finish(); //log("Modifizierter Hex-String:" + Buffer.from(messageBuffer).toString("hex")); //log("topic:" + topic); client.publish(topic, messageBuffer, { qos: 1 }, function (error) { if (error) { console.error('Fehler beim Veröffentlichen der MQTT-Nachricht:', error); } else { if (ConfigData.Debug) log('Die MQTT-Nachricht wurde erfolgreich veröffentlicht.'); } }); } //############ Funktionen zum Setzen von Werten const musterSetAC = ` { "item": { "meta": { "value": 1300 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 20, "cmdId": 129, "unknown5": 3, "needAck": 1, "timestamp": { "low": 35061401, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" } } ` const musterSetAC2 = ` { "item": { "meta": { "value": 17477 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 32, "cmdId": 11, "unknown5": 4, "needAck": 1, "timestamp": { "low": 105187935, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" } } ` const musterGetPS = ` { "item": { "src": 32, "dest": 32, "timestamp": { "low": 95816611, "high": 0, "unsigned": true }, "OS": "ios" } } ` await createMyState('app_' + mqttDaten.UserID + '_' + ConfigData.seriennummern[0].seriennummer + '_thing_property_set.setAC') on({ id: ConfigData.statesPrefix + '.app_' + mqttDaten.UserID + '_' + ConfigData.seriennummern[0].seriennummer + '_thing_property_set.setAC', change: "any", ack: false }, function (obj) { setAC(Number(obj.state.val)) setState(obj.id, obj.state.val, true); }); // Einstellen der Einspeiseleistung function setAC(Value = 1000) { const updatedMusterSetAC = JSON.parse(musterSetAC); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); updatedMusterSetAC.item.meta.value = Value updatedMusterSetAC.item.serialNumber = ConfigData.seriennummern[0].seriennummer SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/set'); } //Anmeldenachrichten der APP function setmusterGetPS() { var updatedMusterSetAC = JSON.parse(musterGetPS); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/get'); updatedMusterSetAC = JSON.parse(musterSetAC2); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); updatedMusterSetAC.item.serialNumber = ConfigData.seriennummern[0].seriennummer SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/set'); } function generateAndSyncSub(id, JElements, sub = false, preset = "0_userdata.0") { if (!JElements || typeof JElements !== 'object') { log('Ungültige JElements übergeben!'); return; } for (var JElement in JElements) { var AktVal; if (typeof JElements[JElement] === "object") { generateAndSyncSub(id + "." + JElement, JElements[JElement], true, preset); } else { try { if (isState2(preset + "." + id + "." + JElement)) AktVal = getState(preset + "." + id + "." + JElement).val; else AktVal = null } catch (e) { log("Fehler: " + e); } if (AktVal == null) { createState(preset + "." + id + "." + JElement, JElements[JElement], false); AktVal = JElements[JElement]; } if (AktVal != JElements[JElement]) { if (isState2(preset + "." + id + "." + JElement)) setState(preset + "." + id + "." + JElement, JElements[JElement]); } } } } /** * Checks if a a given state or part of state is existing. * This is a workaround, as getObject() or getState() throw warnings in the log. * Set strict to true if the state shall match exactly. If it is false, it will add a wildcard * to the end. * See: https://forum.iobroker.net/topic/11354/ * @param {string} strStatePath Input string of state, like 'javascript.0.switches.Osram.Bedroom' * @param {boolean} [strict=false] Optional: if true, it will work strict, if false, it will add a wildcard * to the end of the string * @return {boolean} true if state exists, false if not */ function isState2(strStatePath, strict = true) { let mSelector; if (strict) { mSelector = $(strStatePath); } else { mSelector = $(strStatePath + "*"); } if (mSelector.length > 0) { return true; } else { return false; } } // ########### Grundbedarf steuern // Es müssen Historydaten für den Wert des Smartmeters vorhanden sein, damit der niedrigeste wert der letzten x Minuten ermittelt werden kann function getLowestValue(id, minuten = 120) { return new Promise((resolve, reject) => { const now = new Date().getTime(); const range = minuten * 60 * 1000; var myresult = 0; getHistory(0, { id: id, start: now - range, end: now, aggregate: 'minmax' }, function (err, result) { if (err) { reject(err); } else if (result.length) { let lowestValue = result[0].val; for (let i = 1; i < result.length; i++) { if (result[i].val < lowestValue) { lowestValue = result[i].val; } } myresult = Number(lowestValue); resolve(myresult); } else { reject(new Error('No data')); } }); }); } var OldNewValue = 0 function SetBasePower() { if (isState2(ConfigData.SmartmeterID)) { getLowestValue(ConfigData.SmartmeterID, ConfigData.MinValueMin) .then(lowestValue => { if (lowestValue > 0) { if (ConfigData.Debug) log("Tiefster Wert der letzten " + ConfigData.MinValueMin + " Minuten: " + lowestValue); var AndereVerbraucher = 0 const ToHomeId = ConfigData.statesPrefix + ".app_device_property_" + ConfigData.seriennummern[0].seriennummer + ".data.item.meta.ToHome_Power" if (isState2(ToHomeId)) { AndereVerbraucher = Number(getState(ToHomeId).val) / 10 var NewValue = lowestValue + AndereVerbraucher - ConfigData.BasePowerOffset if (NewValue > ConfigData.MaxPower) NewValue = ConfigData.MaxPower if (ConfigData.Debug) { log("AndereVerbraucher: " + AndereVerbraucher) log("Macht : " + (lowestValue + AndereVerbraucher) + "W Grundbedarf") log("- Offset von: " + ConfigData.BasePowerOffset + " W = " + (NewValue) + " W Grundbedarf") } if (OldNewValue != NewValue) setAC(NewValue * 10) OldNewValue = NewValue } } }) .catch(error => { log("Fehler beim Abrufen des niedrigsten Werts: " + error); }); } } -
@applepro
Super das es klappt
Und ich versuche hier ein Phänomen zu beseitigen: Der MQTT hört auf Nachrichten zu senden, wenn man die App auf dem Handy beendet... Bin noch nicht sicher ob es jetzt durchläuft.../** * ecoflow-iobroker-connector.js * Version: 0.4 * Release date: 29.06.2023 * Autor: Waly_de * Forum: https://forum.iobroker.net/topic/54929/adapter-für-ecoflow-einbindung/155 * * * This JavaScript file establishes a simple connection between IOBroker and EcoFlow. * It automatically creates known states under 0_userdata. * * Please note that adjustments in the ConfigData section are required. Here, you need to enter your access credentials * used for the EcoFlow app, as well as the serial numbers of your devices. * * Important: The second serial number entry should always correspond to the Powerstream as it is associated with control functions. * * If you have a state that displays the current power consumption (SmartmeterID), please provide it as well. * Configure a history for this state so that the script can determine the lowest power consumption in the last 10 minutes (configurable). * This value will be used to dynamically adjust the Powerstream's feed-in power. * * Not all parameters of the Powerstream data are known yet. All known parameters will be automatically created as states. * By modifying the "protoSource" constant, newly discovered data will also be automatically created. * * The raw data of the interface is logged as a HEX string. * * Please exercise caution as this is the initial version of the script. Use it at your own risk! * * Requirements: * - Install protobuf using the command "npm install protobufjs" from the terminal console. * - The "Paho MQTT Client" is also required. If not already installed, use the command "npm install mqtt". * * Note: It is encouraged to discover and publish missing data definitions to improve the script. * Suggestions, optimizations, and extensions are welcome at any time. * * Special thanks to all contributors for their valuable input and support. * * Changelog: * ----------------------------------------------------------- * (0.4) 29.06.2023 * Da der MQTT von ecoflow regelmäßig aufhört zu senden, vor allem, wenn die App genutzt und komplett geschlossen wird, * habe ich eine Überwachung der letzten ankommenden Nachrichten eingebaut. Kommt 5 Minuten lang nichts neues vom PowerStream, * Wird die Verbindung zum MQTT kompett neu aufgebaut. * * Ein Fehler bei der Erstellung der States wurde beseitigt * ----------------------------------------------------------- * */ /******* YOUR DATA HERE **************** var ConfigData = { email: "your@mail.com", passwort: "yourAppPasswort!", seriennummern: [ { seriennummer: "XXXXXXXXXXXXX", name: "PowerStream" }, //1. has to be your PowerStream, you can add more devices... { seriennummer: "XXXXXXXXXXXXX", name: "DELTA Max" } ], SmartmeterID: "sonoff.0.Stromzaehler1.MT175_P", //State, das den aktuellen Gesamtverbrauch in Watt enthält BasePowerOffset: 50, //wird vom aktuellen Verbrauch abgezogen um die Einspeiseleistung zu berechnen MaxPower: 600, //Der höchst mögliche wert in Watt für die Einspeiseleistung MinValueMin: 10, //Der Zeitraum in Minuten, aus dem der letzte Gesamtverbrauchs-Minimalwert geholt werden soll ReconnectMin: 30, //Zeit in Minuten, nach der die Anwendung neu gestartet wird, wenn keine neuen Daten eintreffen statesPrefix: "0_userdata.0.ecoflow", Debug: true }; //***************************************/ const protoSource = ` syntax = "proto3"; message PowerItem { optional Meta meta = 1; optional uint32 src = 2; optional uint32 dest = 3; optional uint32 unknown1 = 4; optional uint32 unknown2 = 5; optional uint32 unknown3 = 6; optional uint32 unknown4 = 7; optional uint32 cmdFunc = 8; optional CmdFunction cmdId = 9; optional uint32 unknown5 = 10; optional uint32 needAck = 11; uint64 timestamp = 14; optional uint32 unknown6 = 16; //3 Byte? optional uint32 unknown7 = 17; //3 Byte? optional string OS = 23; optional string serialNumber = 25; } message PowerMessage { PowerItem item = 1; } message Meta { optional int32 value = 1; optional int32 plugPower = 10; optional int32 M_Unknown7 = 14; // bei Prio-änderung gesehen optional int32 M_Unknown8 = 15; //bei Prio-änderung gesehen optional int32 PV1_Power = 19; optional int32 M_Unknown1 = 21; optional int32 PV2_Power = 24; optional int32 From_Bat_Power = 29; optional int32 Batt_Poz = 31; optional int32 M_Unknown2 = 33; optional int32 M_Unknown3 = 35; optional int32 M_Unknown6 = 37; optional int32 ToHome_Power = 38; optional int32 M_Unknown9 = 43; //prio Power von summe PVx_Power abziehen ? optional int32 Needed_Power = 48; optional int32 M_Unknown4 = 59; optional int32 Bat_Minutes = 60; } enum CmdFunction { Unknown = 0; PermanentWattsPack = 129; SupplyPriorityPack = 130; } `; const mqtt = require('mqtt'); const https = require('https'); const protobuf = require("protobufjs"); const mqttDaten = { UserID: '', User: '', Passwort: '', URL: '', Port: '', protocol: '', clientID: '' } /*======================================================= ========= Timer ============ =======================================================*/ //alle 5 minuten schedule('*/1 * * * *', function () { CheckforReconnect(function () { SetBasePower(); }); }); await getEcoFlowMqttData(ConfigData.email, ConfigData.passwort) async function getEcoFlowMqttData(email, password) { const options = { hostname: 'api.ecoflow.com', path: '/auth/login', method: 'POST', headers: { 'Host': 'api.ecoflow.com', 'lang': 'de-de', 'platform': 'android', 'sysversion': '11', 'version': '4.1.2.02', 'phonemodel': 'SM-X200', 'content-type': 'application/json', 'user-agent': 'okhttp/3.14.9' } }; const data = { appVersion: "4.1.2.02", email: email, os: "android", osVersion: "30", password: Buffer.from(password).toString('base64'), scene: "IOT_APP", userType: "ECOFLOW" }; function httpsRequest(options, data) { return new Promise((resolve, reject) => { const req = https.request(options, res => { let data = ''; res.on('data', chunk => { data += chunk; }); res.on('end', () => { resolve(data); }); }); req.on('error', error => { reject(error); }); if (data) { req.write(JSON.stringify(data)); } req.end(); }); } function uuidv4() { return 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function (c) { var r = Math.random() * 16 | 0, v = c === 'x' ? r : (r & 0x3 | 0x8); return v.toString(16); }); } let response = await httpsRequest(options, data); try { let token = JSON.parse(response).data.token; let userid = JSON.parse(response).data.user.userId; } catch (error) { log(response) throw new Error("Ein Fehler bei der Ermittlung der Zugangsdaten ist aufgetreten. Bitte prüfe die Zugangsdaten."); } let token = JSON.parse(response).data.token; let userid = JSON.parse(response).data.user.userId; options.path = `/iot-auth/app/certification?userId=${userid}`; options.method = 'GET'; options.headers.authorization = `Bearer ${token}`; response = await httpsRequest(options); try { mqttDaten.Passwort = JSON.parse(response).data.certificatePassword mqttDaten.Port = JSON.parse(response).data.port mqttDaten.UserID = userid mqttDaten.User = JSON.parse(response).data.certificateAccount mqttDaten.URL = JSON.parse(response).data.url mqttDaten.protocol = JSON.parse(response).data.protocol mqttDaten.clientID = "ANDROID_" + uuidv4() + "_" + userid } catch (error) { log(response) throw new Error("Ein Fehler bei der Ermittlung der Zugangsdaten ist aufgetreten. Bitte prüfe die Zugangsdaten."); } /* console.log("UserID: " + userid); console.log("User: " + JSON.parse(response).data.certificateAccount); console.log("Passwort: " + JSON.parse(response).data.certificatePassword); console.log("URL: " + JSON.parse(response).data.url); console.log("Port: " + JSON.parse(response).data.port); console.log("protocol: " + JSON.parse(response).data.protocol); console.log("clientID: ANDROID_" + uuidv4() + "_" + userid); */ } await createMyState("LastTopic") //################ MQTT Verbindung ################## function setupMQTTConnection() { // Verbindung herstellen const options = { port: mqttDaten.Port, clientId: mqttDaten.clientID, username: mqttDaten.User, password: mqttDaten.Passwort, protocol: mqttDaten.protocol }; const client = mqtt.connect("mqtt://" + mqttDaten.URL, options); // Event-Handler für Verbindungsaufbau client.on('connect', function () { console.log('Verbunden mit dem Ecoflow MQTT-Broker'); SubscribeEco(); }); // Event-Handler für Fehler client.on('error', function (error) { console.log('Fehler bei der Ecoflow MQTT-Verbindung: ' + error); }); function SubscribeEco() { ConfigData.seriennummern.forEach(item => { client.subscribe('/app/' + mqttDaten.UserID + '/' + item.seriennummer + '/thing/property/set'); client.subscribe('/app/' + mqttDaten.UserID + '/' + item.seriennummer + '/thing/property/get'); client.subscribe('/app/device/property/' + item.seriennummer); setmusterGetPS(); }); } // Auf Nachricht empfangen Ereignis reagieren client.on('message', async function (topic, message) { var jsonMessage = "" const mqState = topic.replace(/^\//, '').replace(/\//g, '_') await createMyState(mqState + ".RAW") setState(ConfigData.statesPrefix + ".LastTopic", topic) try { jsonMessage = JSON.parse(message); if (ConfigData.Debug) log('JSON-Nachricht empfangen:' + topic + ':' + JSON.stringify(jsonMessage)); setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", JSON.stringify(jsonMessage)) generateAndSyncSub("data", jsonMessage, false, ConfigData.statesPrefix + '.' + mqState) } catch (error) { if (ConfigData.Debug) log('Binäre Nachricht empfangen:' + topic + ':' + message.toString('hex')); await createMyState(mqState + ".RAW_HEX") setState(ConfigData.statesPrefix + '.' + mqState + ".RAW_HEX", message.toString('hex')) //log('Decodierte Nachricht:' + decodeAndPrint(message.toString('hex'))) const messagedecoded = decodeAndPrint(message.toString('hex')) setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", messagedecoded) generateAndSyncSub("data", JSON.parse(messagedecoded), false, ConfigData.statesPrefix + '.' + mqState) } }); // Callback für Fehler client.on('error', function (error) { log('Fehler bei der Ecoflow MQTT-Verbindung:' + error, 'warn'); }); client.on('reconnect', function () { console.log('Reconnecting to Ecoflow MQTT broker...'); }); // Weitere Event-Handler hier... return client; } // Verbindung herstellen let client = setupMQTTConnection(); // Funktion zum Trennen und Neuaufbau der Verbindung function reconnect() { client.end(); // Verbindung trennen setTimeout(function () { client = setupMQTTConnection(); // Neue Verbindung herstellen //log("Ecoflow neuverbindung"); }, 2000); // Wartezeit } // close connection if script stopped onStop(function (callback) { if (client) { // close connection client.end(); log("Ecoflow MQTT-Client beendet") } callback(); }, 2000); function CheckforReconnect(callback) { if (getState(ConfigData.statesPrefix + ".LastTopic")?.ts < Date.now() - ConfigData.ReconnectMin * 60 * 1000) { console.log("Der letzte Eintrag ist älter als " + ConfigData.ReconnectMin + " Minuten. Versuche Neustart."); setState(ConfigData.statesPrefix + ".LastTopic", "Last Action Restart:" + new Date().toLocaleString()) runScript(); return; // Wenn letzte Powerstream-Meldung älter als 5 min ist, schicke Lebenszeichen } else if (getState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX')?.ts < Date.now() - 5 * 60 * 1000) { log("Reconnect zu Ecoflow MQTT für PowerStream - Daten") //setmusterGetPS() //.ts Updaten const oldvalue = getState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX').val setState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX', oldvalue) reconnect(); return; //runScript(); } else { callback(); } } //*/ async function createMyState(name) { if (!(await existsObjectAsync(ConfigData.statesPrefix + '.' + name))) { await createStateAsync(ConfigData.statesPrefix + '.' + name, { name: name.split('.').pop(), role: 'state', type: 'string', read: true, write: true }); } } function decodeAndPrint(hexString) { const root = protobuf.parse(protoSource).root; const PowerMessage = root.lookupType("PowerMessage"); const message = PowerMessage.decode(Buffer.from(hexString, "hex")); const object = PowerMessage.toObject(message, { defaults: false }); return JSON.stringify(object); } function SendProto(protomsg, topic) { const root = protobuf.parse(protoSource).root; const PowerMessage = root.lookupType("PowerMessage"); const message = PowerMessage.create(JSON.parse(protomsg)); const messageBuffer = PowerMessage.encode(message).finish(); //log("Modifizierter Hex-String:" + Buffer.from(messageBuffer).toString("hex")); //log("topic:" + topic); client.publish(topic, messageBuffer, { qos: 1 }, function (error) { if (error) { console.error('Fehler beim Veröffentlichen der MQTT-Nachricht:', error); } else { if (ConfigData.Debug) log('Die MQTT-Nachricht wurde erfolgreich veröffentlicht.'); } }); } //############ Funktionen zum Setzen von Werten const musterSetAC = ` { "item": { "meta": { "value": 1300 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 20, "cmdId": 129, "unknown5": 3, "needAck": 1, "timestamp": { "low": 35061401, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" } } ` const musterSetAC2 = ` { "item": { "meta": { "value": 17477 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 32, "cmdId": 11, "unknown5": 4, "needAck": 1, "timestamp": { "low": 105187935, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" } } ` const musterGetPS = ` { "item": { "src": 32, "dest": 32, "timestamp": { "low": 95816611, "high": 0, "unsigned": true }, "OS": "ios" } } ` await createMyState('app_' + mqttDaten.UserID + '_' + ConfigData.seriennummern[0].seriennummer + '_thing_property_set.setAC') on({ id: ConfigData.statesPrefix + '.app_' + mqttDaten.UserID + '_' + ConfigData.seriennummern[0].seriennummer + '_thing_property_set.setAC', change: "any", ack: false }, function (obj) { setAC(Number(obj.state.val)) setState(obj.id, obj.state.val, true); }); // Einstellen der Einspeiseleistung function setAC(Value = 1000) { const updatedMusterSetAC = JSON.parse(musterSetAC); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); updatedMusterSetAC.item.meta.value = Value updatedMusterSetAC.item.serialNumber = ConfigData.seriennummern[0].seriennummer SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/set'); } //Anmeldenachrichten der APP function setmusterGetPS() { var updatedMusterSetAC = JSON.parse(musterGetPS); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/get'); updatedMusterSetAC = JSON.parse(musterSetAC2); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); updatedMusterSetAC.item.serialNumber = ConfigData.seriennummern[0].seriennummer SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/set'); } function generateAndSyncSub(id, JElements, sub = false, preset = "0_userdata.0") { if (!JElements || typeof JElements !== 'object') { log('Ungültige JElements übergeben!'); return; } for (var JElement in JElements) { var AktVal; if (typeof JElements[JElement] === "object") { generateAndSyncSub(id + "." + JElement, JElements[JElement], true, preset); } else { try { if (isState2(preset + "." + id + "." + JElement)) AktVal = getState(preset + "." + id + "." + JElement).val; else AktVal = null } catch (e) { log("Fehler: " + e); } if (AktVal == null) { createState(preset + "." + id + "." + JElement, JElements[JElement], false); AktVal = JElements[JElement]; } if (AktVal != JElements[JElement]) { if (isState2(preset + "." + id + "." + JElement)) setState(preset + "." + id + "." + JElement, JElements[JElement]); } } } } /** * Checks if a a given state or part of state is existing. * This is a workaround, as getObject() or getState() throw warnings in the log. * Set strict to true if the state shall match exactly. If it is false, it will add a wildcard * to the end. * See: https://forum.iobroker.net/topic/11354/ * @param {string} strStatePath Input string of state, like 'javascript.0.switches.Osram.Bedroom' * @param {boolean} [strict=false] Optional: if true, it will work strict, if false, it will add a wildcard * to the end of the string * @return {boolean} true if state exists, false if not */ function isState2(strStatePath, strict = true) { let mSelector; if (strict) { mSelector = $(strStatePath); } else { mSelector = $(strStatePath + "*"); } if (mSelector.length > 0) { return true; } else { return false; } } // ########### Grundbedarf steuern // Es müssen Historydaten für den Wert des Smartmeters vorhanden sein, damit der niedrigeste wert der letzten x Minuten ermittelt werden kann function getLowestValue(id, minuten = 120) { return new Promise((resolve, reject) => { const now = new Date().getTime(); const range = minuten * 60 * 1000; var myresult = 0; getHistory(0, { id: id, start: now - range, end: now, aggregate: 'minmax' }, function (err, result) { if (err) { reject(err); } else if (result.length) { let lowestValue = result[0].val; for (let i = 1; i < result.length; i++) { if (result[i].val < lowestValue) { lowestValue = result[i].val; } } myresult = Number(lowestValue); resolve(myresult); } else { reject(new Error('No data')); } }); }); } var OldNewValue = 0 function SetBasePower() { if (isState2(ConfigData.SmartmeterID)) { getLowestValue(ConfigData.SmartmeterID, ConfigData.MinValueMin) .then(lowestValue => { if (lowestValue > 0) { if (ConfigData.Debug) log("Tiefster Wert der letzten " + ConfigData.MinValueMin + " Minuten: " + lowestValue); var AndereVerbraucher = 0 const ToHomeId = ConfigData.statesPrefix + ".app_device_property_" + ConfigData.seriennummern[0].seriennummer + ".data.item.meta.ToHome_Power" if (isState2(ToHomeId)) { AndereVerbraucher = Number(getState(ToHomeId).val) / 10 var NewValue = lowestValue + AndereVerbraucher - ConfigData.BasePowerOffset if (NewValue > ConfigData.MaxPower) NewValue = ConfigData.MaxPower if (ConfigData.Debug) { log("AndereVerbraucher: " + AndereVerbraucher) log("Macht : " + (lowestValue + AndereVerbraucher) + "W Grundbedarf") log("- Offset von: " + ConfigData.BasePowerOffset + " W = " + (NewValue) + " W Grundbedarf") } if (OldNewValue != NewValue) setAC(NewValue * 10) OldNewValue = NewValue } } }) .catch(error => { log("Fehler beim Abrufen des niedrigsten Werts: " + error); }); } }@waly_de ich habe deine Version 0.3 mal einspielt und seit gestern Mittag laufen. Dabei ist mir aufgefallen, das sich trotz minütlicher Änderung des AC-Wertes, ein Wert außerhalb der Range einschleicht. Dies passiert ca. alle 5-15min. AC Wert wird dann auf 1.747w eingestellt, also max 600w. Ich habe darauf mal dein Skript durch geschaut und an folgender Stellen diesen Wert gefunden. Es handelt sich um den Wert: 17477. Ich habe diesen gegen 1400 = 140w getauscht. Aktuell läuft es seit 16h ohne das verstellen des AC-Wertes auf 17477. Kannst ja mal bei bedarf schauen. Vlt habe aber auch ich irgendwo einen Rechenfehler, der sich eingeschlichen hat.
const musterSetAC2 = ` { "item": { "meta": { "value": 17477 //getauscht gegen 1400 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 32, "cmdId": 11, "unknown5": 4, "needAck": 1, "timestamp": { "low": 105187935, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" }``` Gruß Jannick -
@applepro
Super das es klappt
Und ich versuche hier ein Phänomen zu beseitigen: Der MQTT hört auf Nachrichten zu senden, wenn man die App auf dem Handy beendet... Bin noch nicht sicher ob es jetzt durchläuft.../** * ecoflow-iobroker-connector.js * Version: 0.4 * Release date: 29.06.2023 * Autor: Waly_de * Forum: https://forum.iobroker.net/topic/54929/adapter-für-ecoflow-einbindung/155 * * * This JavaScript file establishes a simple connection between IOBroker and EcoFlow. * It automatically creates known states under 0_userdata. * * Please note that adjustments in the ConfigData section are required. Here, you need to enter your access credentials * used for the EcoFlow app, as well as the serial numbers of your devices. * * Important: The second serial number entry should always correspond to the Powerstream as it is associated with control functions. * * If you have a state that displays the current power consumption (SmartmeterID), please provide it as well. * Configure a history for this state so that the script can determine the lowest power consumption in the last 10 minutes (configurable). * This value will be used to dynamically adjust the Powerstream's feed-in power. * * Not all parameters of the Powerstream data are known yet. All known parameters will be automatically created as states. * By modifying the "protoSource" constant, newly discovered data will also be automatically created. * * The raw data of the interface is logged as a HEX string. * * Please exercise caution as this is the initial version of the script. Use it at your own risk! * * Requirements: * - Install protobuf using the command "npm install protobufjs" from the terminal console. * - The "Paho MQTT Client" is also required. If not already installed, use the command "npm install mqtt". * * Note: It is encouraged to discover and publish missing data definitions to improve the script. * Suggestions, optimizations, and extensions are welcome at any time. * * Special thanks to all contributors for their valuable input and support. * * Changelog: * ----------------------------------------------------------- * (0.4) 29.06.2023 * Da der MQTT von ecoflow regelmäßig aufhört zu senden, vor allem, wenn die App genutzt und komplett geschlossen wird, * habe ich eine Überwachung der letzten ankommenden Nachrichten eingebaut. Kommt 5 Minuten lang nichts neues vom PowerStream, * Wird die Verbindung zum MQTT kompett neu aufgebaut. * * Ein Fehler bei der Erstellung der States wurde beseitigt * ----------------------------------------------------------- * */ /******* YOUR DATA HERE **************** var ConfigData = { email: "your@mail.com", passwort: "yourAppPasswort!", seriennummern: [ { seriennummer: "XXXXXXXXXXXXX", name: "PowerStream" }, //1. has to be your PowerStream, you can add more devices... { seriennummer: "XXXXXXXXXXXXX", name: "DELTA Max" } ], SmartmeterID: "sonoff.0.Stromzaehler1.MT175_P", //State, das den aktuellen Gesamtverbrauch in Watt enthält BasePowerOffset: 50, //wird vom aktuellen Verbrauch abgezogen um die Einspeiseleistung zu berechnen MaxPower: 600, //Der höchst mögliche wert in Watt für die Einspeiseleistung MinValueMin: 10, //Der Zeitraum in Minuten, aus dem der letzte Gesamtverbrauchs-Minimalwert geholt werden soll ReconnectMin: 30, //Zeit in Minuten, nach der die Anwendung neu gestartet wird, wenn keine neuen Daten eintreffen statesPrefix: "0_userdata.0.ecoflow", Debug: true }; //***************************************/ const protoSource = ` syntax = "proto3"; message PowerItem { optional Meta meta = 1; optional uint32 src = 2; optional uint32 dest = 3; optional uint32 unknown1 = 4; optional uint32 unknown2 = 5; optional uint32 unknown3 = 6; optional uint32 unknown4 = 7; optional uint32 cmdFunc = 8; optional CmdFunction cmdId = 9; optional uint32 unknown5 = 10; optional uint32 needAck = 11; uint64 timestamp = 14; optional uint32 unknown6 = 16; //3 Byte? optional uint32 unknown7 = 17; //3 Byte? optional string OS = 23; optional string serialNumber = 25; } message PowerMessage { PowerItem item = 1; } message Meta { optional int32 value = 1; optional int32 plugPower = 10; optional int32 M_Unknown7 = 14; // bei Prio-änderung gesehen optional int32 M_Unknown8 = 15; //bei Prio-änderung gesehen optional int32 PV1_Power = 19; optional int32 M_Unknown1 = 21; optional int32 PV2_Power = 24; optional int32 From_Bat_Power = 29; optional int32 Batt_Poz = 31; optional int32 M_Unknown2 = 33; optional int32 M_Unknown3 = 35; optional int32 M_Unknown6 = 37; optional int32 ToHome_Power = 38; optional int32 M_Unknown9 = 43; //prio Power von summe PVx_Power abziehen ? optional int32 Needed_Power = 48; optional int32 M_Unknown4 = 59; optional int32 Bat_Minutes = 60; } enum CmdFunction { Unknown = 0; PermanentWattsPack = 129; SupplyPriorityPack = 130; } `; const mqtt = require('mqtt'); const https = require('https'); const protobuf = require("protobufjs"); const mqttDaten = { UserID: '', User: '', Passwort: '', URL: '', Port: '', protocol: '', clientID: '' } /*======================================================= ========= Timer ============ =======================================================*/ //alle 5 minuten schedule('*/1 * * * *', function () { CheckforReconnect(function () { SetBasePower(); }); }); await getEcoFlowMqttData(ConfigData.email, ConfigData.passwort) async function getEcoFlowMqttData(email, password) { const options = { hostname: 'api.ecoflow.com', path: '/auth/login', method: 'POST', headers: { 'Host': 'api.ecoflow.com', 'lang': 'de-de', 'platform': 'android', 'sysversion': '11', 'version': '4.1.2.02', 'phonemodel': 'SM-X200', 'content-type': 'application/json', 'user-agent': 'okhttp/3.14.9' } }; const data = { appVersion: "4.1.2.02", email: email, os: "android", osVersion: "30", password: Buffer.from(password).toString('base64'), scene: "IOT_APP", userType: "ECOFLOW" }; function httpsRequest(options, data) { return new Promise((resolve, reject) => { const req = https.request(options, res => { let data = ''; res.on('data', chunk => { data += chunk; }); res.on('end', () => { resolve(data); }); }); req.on('error', error => { reject(error); }); if (data) { req.write(JSON.stringify(data)); } req.end(); }); } function uuidv4() { return 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function (c) { var r = Math.random() * 16 | 0, v = c === 'x' ? r : (r & 0x3 | 0x8); return v.toString(16); }); } let response = await httpsRequest(options, data); try { let token = JSON.parse(response).data.token; let userid = JSON.parse(response).data.user.userId; } catch (error) { log(response) throw new Error("Ein Fehler bei der Ermittlung der Zugangsdaten ist aufgetreten. Bitte prüfe die Zugangsdaten."); } let token = JSON.parse(response).data.token; let userid = JSON.parse(response).data.user.userId; options.path = `/iot-auth/app/certification?userId=${userid}`; options.method = 'GET'; options.headers.authorization = `Bearer ${token}`; response = await httpsRequest(options); try { mqttDaten.Passwort = JSON.parse(response).data.certificatePassword mqttDaten.Port = JSON.parse(response).data.port mqttDaten.UserID = userid mqttDaten.User = JSON.parse(response).data.certificateAccount mqttDaten.URL = JSON.parse(response).data.url mqttDaten.protocol = JSON.parse(response).data.protocol mqttDaten.clientID = "ANDROID_" + uuidv4() + "_" + userid } catch (error) { log(response) throw new Error("Ein Fehler bei der Ermittlung der Zugangsdaten ist aufgetreten. Bitte prüfe die Zugangsdaten."); } /* console.log("UserID: " + userid); console.log("User: " + JSON.parse(response).data.certificateAccount); console.log("Passwort: " + JSON.parse(response).data.certificatePassword); console.log("URL: " + JSON.parse(response).data.url); console.log("Port: " + JSON.parse(response).data.port); console.log("protocol: " + JSON.parse(response).data.protocol); console.log("clientID: ANDROID_" + uuidv4() + "_" + userid); */ } await createMyState("LastTopic") //################ MQTT Verbindung ################## function setupMQTTConnection() { // Verbindung herstellen const options = { port: mqttDaten.Port, clientId: mqttDaten.clientID, username: mqttDaten.User, password: mqttDaten.Passwort, protocol: mqttDaten.protocol }; const client = mqtt.connect("mqtt://" + mqttDaten.URL, options); // Event-Handler für Verbindungsaufbau client.on('connect', function () { console.log('Verbunden mit dem Ecoflow MQTT-Broker'); SubscribeEco(); }); // Event-Handler für Fehler client.on('error', function (error) { console.log('Fehler bei der Ecoflow MQTT-Verbindung: ' + error); }); function SubscribeEco() { ConfigData.seriennummern.forEach(item => { client.subscribe('/app/' + mqttDaten.UserID + '/' + item.seriennummer + '/thing/property/set'); client.subscribe('/app/' + mqttDaten.UserID + '/' + item.seriennummer + '/thing/property/get'); client.subscribe('/app/device/property/' + item.seriennummer); setmusterGetPS(); }); } // Auf Nachricht empfangen Ereignis reagieren client.on('message', async function (topic, message) { var jsonMessage = "" const mqState = topic.replace(/^\//, '').replace(/\//g, '_') await createMyState(mqState + ".RAW") setState(ConfigData.statesPrefix + ".LastTopic", topic) try { jsonMessage = JSON.parse(message); if (ConfigData.Debug) log('JSON-Nachricht empfangen:' + topic + ':' + JSON.stringify(jsonMessage)); setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", JSON.stringify(jsonMessage)) generateAndSyncSub("data", jsonMessage, false, ConfigData.statesPrefix + '.' + mqState) } catch (error) { if (ConfigData.Debug) log('Binäre Nachricht empfangen:' + topic + ':' + message.toString('hex')); await createMyState(mqState + ".RAW_HEX") setState(ConfigData.statesPrefix + '.' + mqState + ".RAW_HEX", message.toString('hex')) //log('Decodierte Nachricht:' + decodeAndPrint(message.toString('hex'))) const messagedecoded = decodeAndPrint(message.toString('hex')) setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", messagedecoded) generateAndSyncSub("data", JSON.parse(messagedecoded), false, ConfigData.statesPrefix + '.' + mqState) } }); // Callback für Fehler client.on('error', function (error) { log('Fehler bei der Ecoflow MQTT-Verbindung:' + error, 'warn'); }); client.on('reconnect', function () { console.log('Reconnecting to Ecoflow MQTT broker...'); }); // Weitere Event-Handler hier... return client; } // Verbindung herstellen let client = setupMQTTConnection(); // Funktion zum Trennen und Neuaufbau der Verbindung function reconnect() { client.end(); // Verbindung trennen setTimeout(function () { client = setupMQTTConnection(); // Neue Verbindung herstellen //log("Ecoflow neuverbindung"); }, 2000); // Wartezeit } // close connection if script stopped onStop(function (callback) { if (client) { // close connection client.end(); log("Ecoflow MQTT-Client beendet") } callback(); }, 2000); function CheckforReconnect(callback) { if (getState(ConfigData.statesPrefix + ".LastTopic")?.ts < Date.now() - ConfigData.ReconnectMin * 60 * 1000) { console.log("Der letzte Eintrag ist älter als " + ConfigData.ReconnectMin + " Minuten. Versuche Neustart."); setState(ConfigData.statesPrefix + ".LastTopic", "Last Action Restart:" + new Date().toLocaleString()) runScript(); return; // Wenn letzte Powerstream-Meldung älter als 5 min ist, schicke Lebenszeichen } else if (getState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX')?.ts < Date.now() - 5 * 60 * 1000) { log("Reconnect zu Ecoflow MQTT für PowerStream - Daten") //setmusterGetPS() //.ts Updaten const oldvalue = getState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX').val setState(ConfigData.statesPrefix + '.app_device_property_' + ConfigData.seriennummern[0].seriennummer + '.RAW_HEX', oldvalue) reconnect(); return; //runScript(); } else { callback(); } } //*/ async function createMyState(name) { if (!(await existsObjectAsync(ConfigData.statesPrefix + '.' + name))) { await createStateAsync(ConfigData.statesPrefix + '.' + name, { name: name.split('.').pop(), role: 'state', type: 'string', read: true, write: true }); } } function decodeAndPrint(hexString) { const root = protobuf.parse(protoSource).root; const PowerMessage = root.lookupType("PowerMessage"); const message = PowerMessage.decode(Buffer.from(hexString, "hex")); const object = PowerMessage.toObject(message, { defaults: false }); return JSON.stringify(object); } function SendProto(protomsg, topic) { const root = protobuf.parse(protoSource).root; const PowerMessage = root.lookupType("PowerMessage"); const message = PowerMessage.create(JSON.parse(protomsg)); const messageBuffer = PowerMessage.encode(message).finish(); //log("Modifizierter Hex-String:" + Buffer.from(messageBuffer).toString("hex")); //log("topic:" + topic); client.publish(topic, messageBuffer, { qos: 1 }, function (error) { if (error) { console.error('Fehler beim Veröffentlichen der MQTT-Nachricht:', error); } else { if (ConfigData.Debug) log('Die MQTT-Nachricht wurde erfolgreich veröffentlicht.'); } }); } //############ Funktionen zum Setzen von Werten const musterSetAC = ` { "item": { "meta": { "value": 1300 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 20, "cmdId": 129, "unknown5": 3, "needAck": 1, "timestamp": { "low": 35061401, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" } } ` const musterSetAC2 = ` { "item": { "meta": { "value": 17477 }, "src": 32, "dest": 53, "unknown1": 1, "unknown2": 1, "unknown4": 3, "cmdFunc": 32, "cmdId": 11, "unknown5": 4, "needAck": 1, "timestamp": { "low": 105187935, "high": 0, "unsigned": true }, "unknown6": 19, "unknown7": 1, "OS": "ios", "serialNumber": "ABCxxxxxxx123" } } ` const musterGetPS = ` { "item": { "src": 32, "dest": 32, "timestamp": { "low": 95816611, "high": 0, "unsigned": true }, "OS": "ios" } } ` await createMyState('app_' + mqttDaten.UserID + '_' + ConfigData.seriennummern[0].seriennummer + '_thing_property_set.setAC') on({ id: ConfigData.statesPrefix + '.app_' + mqttDaten.UserID + '_' + ConfigData.seriennummern[0].seriennummer + '_thing_property_set.setAC', change: "any", ack: false }, function (obj) { setAC(Number(obj.state.val)) setState(obj.id, obj.state.val, true); }); // Einstellen der Einspeiseleistung function setAC(Value = 1000) { const updatedMusterSetAC = JSON.parse(musterSetAC); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); updatedMusterSetAC.item.meta.value = Value updatedMusterSetAC.item.serialNumber = ConfigData.seriennummern[0].seriennummer SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/set'); } //Anmeldenachrichten der APP function setmusterGetPS() { var updatedMusterSetAC = JSON.parse(musterGetPS); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/get'); updatedMusterSetAC = JSON.parse(musterSetAC2); updatedMusterSetAC.item.timestamp.low = Date.now().toString(); updatedMusterSetAC.item.serialNumber = ConfigData.seriennummern[0].seriennummer SendProto(JSON.stringify(updatedMusterSetAC), '/app/' + mqttDaten.UserID + '/' + ConfigData.seriennummern[0].seriennummer + '/thing/property/set'); } function generateAndSyncSub(id, JElements, sub = false, preset = "0_userdata.0") { if (!JElements || typeof JElements !== 'object') { log('Ungültige JElements übergeben!'); return; } for (var JElement in JElements) { var AktVal; if (typeof JElements[JElement] === "object") { generateAndSyncSub(id + "." + JElement, JElements[JElement], true, preset); } else { try { if (isState2(preset + "." + id + "." + JElement)) AktVal = getState(preset + "." + id + "." + JElement).val; else AktVal = null } catch (e) { log("Fehler: " + e); } if (AktVal == null) { createState(preset + "." + id + "." + JElement, JElements[JElement], false); AktVal = JElements[JElement]; } if (AktVal != JElements[JElement]) { if (isState2(preset + "." + id + "." + JElement)) setState(preset + "." + id + "." + JElement, JElements[JElement]); } } } } /** * Checks if a a given state or part of state is existing. * This is a workaround, as getObject() or getState() throw warnings in the log. * Set strict to true if the state shall match exactly. If it is false, it will add a wildcard * to the end. * See: https://forum.iobroker.net/topic/11354/ * @param {string} strStatePath Input string of state, like 'javascript.0.switches.Osram.Bedroom' * @param {boolean} [strict=false] Optional: if true, it will work strict, if false, it will add a wildcard * to the end of the string * @return {boolean} true if state exists, false if not */ function isState2(strStatePath, strict = true) { let mSelector; if (strict) { mSelector = $(strStatePath); } else { mSelector = $(strStatePath + "*"); } if (mSelector.length > 0) { return true; } else { return false; } } // ########### Grundbedarf steuern // Es müssen Historydaten für den Wert des Smartmeters vorhanden sein, damit der niedrigeste wert der letzten x Minuten ermittelt werden kann function getLowestValue(id, minuten = 120) { return new Promise((resolve, reject) => { const now = new Date().getTime(); const range = minuten * 60 * 1000; var myresult = 0; getHistory(0, { id: id, start: now - range, end: now, aggregate: 'minmax' }, function (err, result) { if (err) { reject(err); } else if (result.length) { let lowestValue = result[0].val; for (let i = 1; i < result.length; i++) { if (result[i].val < lowestValue) { lowestValue = result[i].val; } } myresult = Number(lowestValue); resolve(myresult); } else { reject(new Error('No data')); } }); }); } var OldNewValue = 0 function SetBasePower() { if (isState2(ConfigData.SmartmeterID)) { getLowestValue(ConfigData.SmartmeterID, ConfigData.MinValueMin) .then(lowestValue => { if (lowestValue > 0) { if (ConfigData.Debug) log("Tiefster Wert der letzten " + ConfigData.MinValueMin + " Minuten: " + lowestValue); var AndereVerbraucher = 0 const ToHomeId = ConfigData.statesPrefix + ".app_device_property_" + ConfigData.seriennummern[0].seriennummer + ".data.item.meta.ToHome_Power" if (isState2(ToHomeId)) { AndereVerbraucher = Number(getState(ToHomeId).val) / 10 var NewValue = lowestValue + AndereVerbraucher - ConfigData.BasePowerOffset if (NewValue > ConfigData.MaxPower) NewValue = ConfigData.MaxPower if (ConfigData.Debug) { log("AndereVerbraucher: " + AndereVerbraucher) log("Macht : " + (lowestValue + AndereVerbraucher) + "W Grundbedarf") log("- Offset von: " + ConfigData.BasePowerOffset + " W = " + (NewValue) + " W Grundbedarf") } if (OldNewValue != NewValue) setAC(NewValue * 10) OldNewValue = NewValue } } }) .catch(error => { log("Fehler beim Abrufen des niedrigsten Werts: " + error); }); } }@waly_de Wenn der SetAC Wert sich im Objekt Baum nicht ändert: was kann da das Problem sein? Das Objekt für die aktuelle Einspeisung habe ich konfiguriert.
@mattenausohz SetAC ändert sich nur, wenn Du ihn änderst. Im Moment dient er nur zum manuellen Schreiben des Wertes, wenn kein Stromzähler konfiguriert ist. Den aktuellen Wert für die eingestellte Einspeiseleistung (Leistungsbedarf am AC) findest du hier:
0_userdata.0.ecoflow.app_device_property_<Seriennummer>.data.item.meta.Needed_PowerUnd das was grade wirklich in Haus geht hier:
0_userdata.0.ecoflow.app_device_property_<Seriennummer>.data.item.meta.ToHome_Power -
0_userdata.0.ecoflow.app_device_property_<Seriennummer>.data.item.meta.ToHome_Power@waly_de Ah ok, verstanden. Danke! :) Noch ein paar Fragen:
- Kannst Du noch mal kurz erläutern was es mit dem BasePower Offset auf sich hat?
- Ich habe derzeit zu 80% einen negativen Netzbezug meist um die -40 bis -50. Habe alle Werte im Standard gelassen. Woran kann das liegen?
- Die Produktion (PV1 und PV2) aktualisieren sich im Vergleich zur App extrem selten und passen auch nicht wirklich zum Gesamt-Wert. PV1 + PV2 scheint nicht die "Solar-Summe" auf der App zu sein.
- Habe jetzt den Herd laufen. Gesamt werden über 1500 W dauerhaft verbraucht. Die Einspeisung steigt aber nicht auf 600 sondern schwankt weiterhin (die vor der Nutzung des Herds) um 500 W herum.
Nun sehe ich das auch noch:
19:46:30.583 error javascript.0 (788087) Script script.js.common.ecoFlow_PowerStream is calling setState more than 600 times per minute! Stopping Script now! Please check your script! -
19:46:30.583 error javascript.0 (788087) Script script.js.common.ecoFlow_PowerStream is calling setState more than 600 times per minute! Stopping Script now! Please check your script!-
BasePower Offset ist das, was bei der Berechnung der Einspeiseleistung abgezogen wird. Also wenn Ermittelt wird, dass Dein Verbrauch gerade 400W ist und der Offset auf 50 eingestellt ist, dann wird 350W als Einspeiseleistung eingestellt. Dein Stromzähler sollte also im Idealfall dann 50 W anzeigen.
Dann stimmt etwas nicht. Der Wert sollte eher oberhalb des Offset liegen. Es wird ja immer der niedrigste Verbrauchswert der letzten <MinValueMin> Minuten ermittelt und davon der Offset abgezogen...
Ja die Werte weichen ab. Ich habe noch keine Erklärung bzw. keine Methode gefunden um das 100% gleich zu ziehen. Im Moment ziehe ich von den PV1 und PV2 Werten je 18W ab um die Summe zu errechnen. Das kam den Werten der App am nächsten. 100% Ist das aber nicht. Vielleicht findet einer von Euch ja raus, wie der Wert genau berechnet werden kann. Wenn du die App benutzt während das Skript läuft, kann es sein das der Empfang der Nachrichten im Skript abbricht. Ich Monitor das schon und starte das Skript neu.. aber das dauert. Wenn Du selbst neu startest, sollte es wieder schneller Daten geben.
Denk dran.. es wird der niedrigste wert der letzten <MinValueMin> Minuten ermittelt. daher muss die Leistung von 1500W mindestens <MinValueMin> Minuten dauerhaft anliegen, damit die Einspeisung angehoben wird. (Hast du auch die History für den Verbrauch aktiviert?)
Oha.. ja, es kommen eben sehr viele Updates vom MQTT. Ich hatte das auch, aber mit mehr als 1000. Ist aber kein Fehler, sondern leider die Realität. Ich hab das Limit in den Einstellungen des Javascript Adapters auf 5000 Erhöht.... Alternativ könntest du den Empfang der nicht codierten Meldungen (Delta 2 oder Max) abstellen. Die werden für die Funktionalität nicht gebraucht. Dazu muss nur eine Zeile im Script auskommentiert werden. Hier die Funktion mit der auskommentieren Anweisung:
// Auf Nachricht empfangen Ereignis reagieren client.on('message', async function (topic, message) { var jsonMessage = "" const mqState = topic.replace(/^\//, '').replace(/\//g, '_') await createMyState(mqState + ".RAW") setState(ConfigData.statesPrefix + ".LastTopic", topic) try { jsonMessage = JSON.parse(message); if (ConfigData.Debug) log('JSON-Nachricht empfangen:' + topic + ':' + JSON.stringify(jsonMessage)); setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", JSON.stringify(jsonMessage)) //generateAndSyncSub("data", jsonMessage, false, ConfigData.statesPrefix + '.' + mqState) } catch (error) { if (ConfigData.Debug) log('Binäre Nachricht empfangen:' + topic + ':' + message.toString('hex')); await createMyState(mqState + ".RAW_HEX") setState(ConfigData.statesPrefix + '.' + mqState + ".RAW_HEX", message.toString('hex')) if (ConfigData.Debug) log('Decodierte Nachricht:' + decodeAndPrint(message.toString('hex'))) const messagedecoded = decodeAndPrint(message.toString('hex')) setState(ConfigData.statesPrefix + '.' + mqState + ".RAW", messagedecoded) generateAndSyncSub("data", JSON.parse(messagedecoded), false, ConfigData.statesPrefix + '.' + mqState) } });übrigens, nach diesem Eintrag im Log steht das Script so lange, bis du es Manuell neu startest. Also danach wird nichts mehr getan.
PS: Ich arbeite noch an der Sache. Hab einiges schon ergänzt und verbessert, vor allem die Berechnung der Einspeiseleistung. Aber ist noch nicht reif zum Posten.. dauert noch ein paar Tage...
@waly_de Ich hatte übrigens gestern nur an PV1 ein Modul und trotzdem wurden beide Felder mit Werten befüllt. Jetzt noch mal ne Frage zum Script: BasePower wird ja nur neu berechnet wenn "lowestValue" >0 ist. Das heißt, dass wenn ich einen Überschuss habe am Hausanschluss wird nicht runter geregelt. Das ist ok solange man nicht einen Akku noch laden will, richtig? Hab die Abfrage jetzt mal rausgenommen mit dem ">0". Man müsste nun noch den Akkustand mit integrieren:
Statt:
if (lowestValue > 0)könnte man sowas wie
if (getState(ConfigData.PowerStreamAkkuStandID).val<100){nehmen. Oder?
ich bräuchte Hilfe beim einbinden eines Smartplugs
Ich habe hier verschiedene Daten vom MQTT Broker bekommen
es kommen bei /app/device/property/HW52ZDH4SF5J6396 immer zwei verschiedene datensätze:Der mit der Energiemessung: Zum beispiel hier die muss mit 14W sein (mann muss hier wieder /10 machen):
Field number 10 hat dort den wert 140 -> 140/10 = 10W
0a 2e 0a 03 50 8c 01 10 35 18 20 20 01 28 01 40 02 48 01 50 03 58 01 80 01 03 88 01 03 ca 01 10 48 57 35 32 5a 44 48 34 53 46 35 4a 36 33 39 36Und einen mit generellen infos?:
0a780a4c08ffff0312220880c28da50610051a1803030000000000000000000000000000000000000000000012220880c28da50610061a18163700000000000000000000000000000000000000000000103518202001280140fe014820504c5801800103880103ca0110485735325a4448345346354a36333936Das wird immer angefragt bei /app/<userid>/HW52ZDH4SF5J6396/thing/property/get:
Das war bis jetzt immer derselbe datensatz0a0d1020182070b424ba0103617070Das wird beim ein und ausschalten von der App auf /app/<userid>/HW52ZDH4SF5J6396/thing/property/set gepublished:
AUS:0a 22 10 20 18 35 40 02 48 81 01 58 01 70 8f eb 2b ca 01 10 48 57 35 32 5a 44 48 34 53 46 35 4a 36 33 39 36AN:
0a 28 0a 02 08 01 10 20 18 35 40 02 48 81 01 50 02 58 01 70 9f ac 1f ca 01 10 48 57 35 32 5a 44 48 34 53 46 35 4a 36 33 39 36Wie seit ihr auf die .proto files gekommen?
habt ihr die im code der app gefunden?
könnte man für die steckdosen auch eine .proto machen?Vielen Dank
@felixcrafter83 Darf ich fragen wozu Du noch SmartPlugs brauchst wenn Du doch die "echte" Last live nutzen kannst?
@mattenausohz ich habe diesen smartplug bei einem Ecoflow gewinnspiel gewonnen.
ich möchte mit dem etwas rumspielen, also für etwas anderes benutzen und ich habe ja noch kein powerstream.
Da hast du recht, smart plugs braucht man mit den scripten natürlich nicht mehr, wenn man die leistung am stromzähler abgreift.
Ich hätte mir sonst keinen gekauft.
Habe nämlich auch schon ein smartmeter -
@felixcrafter83 Siehe den Beitrag weiter oben.
Wenn man sich die Ecoflow APK (Android App) genauer ansieht wie die Codetechnisch funktioniert fällt zum einen Auf das ein import zu Googles Protobuf drinnen ist.
Ist aber sehr mühselig etwas herauszufinden. -
Ist aber sehr mühselig etwas herauszufinden.Ich hab dem Script mal einen eigenen Beitrag spendiert:
https://forum.iobroker.net/topic/66743/ecoflow-connector-script-zur-dynamischen-leistungsanpassung
@FelixCrafter83 Die meisten Deiner Daten kenn ich schon und sind im neuen Script verwendet. Was ich nicht kenne wird als State: X_Unknown_X angelegt. Funfact: ich hab auch einen Smartplug gewonnen ;-D hab ich aber noch nicht hier.
@mattenausohz Die Funktion wurde überarbeitet und sollte jetzt besser laufen.
Ich habe heute etwas rumgetüftelt und habe die Proto files in der App gefunden.
nur sind die komisch codiert, ich habe dann chatgpt zur hilfe genommen, das mir dann es in klartext ausgegeben hat.
Jetzt ist die Frage, ob jemand weiß, wie man von der einen darstellung auf die klartext dartstellung kommt:Hier mal das, was ich in der App gefunden habe:
\n\u0016wn511_socket_sys.proto\"\u00ca\u0001\n\brtc_data\u0012\u0011\n\u0004week\u0018\u0001 \u0001(\u0005H\u0000\u0088\u0001\u0001\u0012\u0010\n\u0003sec\u0018\u0002 \u0001(\u0005H\u0001\u0088\u0001\u0001\u0012\u0010\n\u0003min\u0018\u0003 \u0001(\u0005H\u0002\u0088\u0001\u0001\u0012\u0011\n\u0004hour\u0018\u0004 \u0001(\u0005H\u0003\u0088\u0001\u0001\u0012\u0010\n\u0003day\u0018\u0005 \u0001(\u0005H\u0004\u0088\u0001\u0001\u0012\u0012\n\u0005month\u0018\u0006 \u0001(\u0005H\u0005\u0088\u0001\u0001\u0012\u0011\n\u0004year\u0018\u0007 \u0001(\u0005H\u0006\u0088\u0001\u0001B\u0007\n\u0005_weekB\u0006\n\u0004_secB\u0006\n\u0004_minB\u0007\n\u0005_hourB\u0006\n\u0004_dayB\b\n\u0006_monthB\u0007\n\u0005_year\"\u009e\u0001\n\u0013time_range_strategy\u0012\u0011\n\tis_config\u0018\u0001 \u0001(\b\u0012\u0011\n\tis_enable\u0018\u0002 \u0001(\b\u0012\u0011\n\ttime_mode\u0018\u0003 \u0001(\u0005\u0012\u0011\n\ttime_data\u0018\u0004 \u0001(\u0005\u0012\u001d\n\nstart_time\u0018\u0005 \u0001(\u000b2\t.rtc_data\u0012\u001c\n\tstop_time\u0018\u0006 \u0001(\u000b2\t.rtc_data\"\u001f\n\u0010plug_ack_message\u0012\u000b\n\u0003ack\u0018\u0001 \u0001(\r\"\u00a5\u0004\n\u0013plug_heartbeat_pack\u0012\u0015\n\berr_code\u0018\u0001 \u0001(\rH\u0000\u0088\u0001\u0001\u0012\u0016\n\twarn_code\u0018\u0002 \u0001(\rH\u0001\u0088\u0001\u0001\u0012\u0014\n\u0007country\u0018\u0003 \u0001(\rH\u0002\u0088\u0001\u0001\u0012\u0011\n\u0004town\u0018\u0004 \u0001(\rH\u0003\u0088\u0001\u0001\u0012\u0014\n\u0007max_cur\u0018\u0005 \u0001(\u0005H\u0004\u0088\u0001\u0001\u0012\u0011\n\u0004temp\u0018\u0006 \u0001(\u0005H\u0005\u0088\u0001\u0001\u0012\u0011\n\u0004freq\u0018\u0007 \u0001(\u0005H\u0006\u0088\u0001\u0001\u0012\u0014\n\u0007current\u0018\b \u0001(\u0005H\u0007\u0088\u0001\u0001\u0012\u0011\n\u0004volt\u0018\t \u0001(\u0005H\b\u0088\u0001\u0001\u0012\u0012\n\u0005watts\u0018\n \u0001(\u0005H\t\u0088\u0001\u0001\u0012\u0013\n\u0006switch\u0018\u000b \u0001(\bH\n\u0088\u0001\u0001\u0012\u0017\n\nbrightness\u0018\f \u0001(\u0005H\u000b\u0088\u0001\u0001\u0012\u0016\n\tmax_watts\u0018\r \u0001(\u0005H\f\u0088\u0001\u0001\u0012 \n\u0013heartbeat_frequency\u0018\u000e \u0001(\u0005H\r\u0088\u0001\u0001\u0012\u0018\n\u000bmesh_enable\u0018\u000f \u0001(\u0005H\u000e\u0088\u0001\u0001B\u000b\n\t_err_codeB\f\n\n_warn_codeB\n\n\b_countryB\u0007\n\u0005_townB\n\n\b_max_curB\u0007\n\u0005_tempB\u0007\n\u0005_freqB\n\n\b_currentB\u0007\n\u0005_voltB\b\n\u0006_wattsB\t\n\u0007_switchB\r\n\u000b_brightnessB\f\n\n_max_wattsB\u0016\n\u0014_heartbeat_frequencyB\u000e\n\f_mesh_enable\"*\n\u0013plug_switch_message\u0012\u0013\n\u000bplug_switch\u0018\u0001 \u0001(\r\"%\n\u000fbrightness_pack\u0012\u0012\n\nbrightness\u0018\u0001 \u0001(\u0005\"\u001f\n\fmax_cur_pack\u0012\u000f\n\u0007max_cur\u0018\u0001 \u0001(\u0005\"]\n\u0010time_task_config\u0012\u0011\n\ttask_name\u0018\u0001 \u0001(\t\u0012(\n\ntime_range\u0018\u0002 \u0001(\u000b2\u0014.time_range_strategy\u0012\f\n\u0004type\u0018\u0003 \u0001(\u0005\"N\n\u0015time_task_config_post\u0012\r\n\u0005index\u0018\u0001 \u0001(\u0005\u0012&\n\u000btask_config\u0018\u0002 \u0001(\u000b2\u0011.time_task_config\"D\n\tPowerItem\u0012\u0011\n\ttimestamp\u0018\u0001 \u0001(\r\u0012\u0010\n\btimezone\u0018\u0002 \u0001(\u0011\u0012\u0012\n\nplug_power\u0018\u0003 \u0001(\r\"B\n\tPowerPack\u0012\u000f\n\u0007sys_seq\u0018\u0001 \u0001(\r\u0012$\n\u0010sys_power_stream\u0018\u0002 \u0003(\u000b2\n.PowerItem\"\u001f\n\fPowerAckPack\u0012\u000f\n\u0007sys_seq\u0018\u0001 \u0001(\r\"#\n\u000emax_watts_pack\u0012\u0011\n\tmax_watts\u0018\u0001 \u0001(\u0005\"%\n\u000emesh_ctrl_pack\u0012\u0013\n\u000bmesh_enable\u0018\u0001 \u0001(\r\"\u001b\n\bret_pack\u0012\u000f\n\u0007ret_sta\u0018\u0001 \u0001(\bb\u0006proto3So sieht das dann in klartext aus:
wn511_socket_sys.protosyntax = "proto3"; message rtc_data { optional int32 week = 1 [default = 1]; optional int32 sec = 2 [default = 1]; optional int32 min = 3 [default = 1]; optional int32 hour = 4 [default = 1]; optional int32 day = 5 [default = 1]; optional int32 month = 6 [default = 1]; optional int32 year = 7 [default = 1]; } message time_range_strategy { optional bool is_config = 1; optional bool is_enable = 2; optional int32 time_mode = 3; optional int32 time_data = 4; optional rtc_data start_time = 5; optional rtc_data stop_time = 6; } message plug_ack_message { optional int32 ack = 1; } message plug_heartbeat_pack { optional int32 err_code = 1 [default = 1]; optional int32 warn_code = 2 [default = 1]; optional int32 country = 3 [default = 1]; optional int32 town = 4 [default = 1]; optional int32 max_cur = 5 [default = 1]; optional int32 temp = 6 [default = 1]; optional int32 freq = 7 [default = 1]; optional int32 current = 8 [default = 1]; optional int32 volt = 9 [default = 1]; optional int32 watts = 10 [default = 1]; optional bool switch = 11; optional int32 brightness = 12 [default = 1]; optional int32 max_watts = 13 [default = 1]; optional int32 heartbeat_frequency = 14 [default = 1]; optional bool mesh_enable = 15; } message plug_switch_message { optional int32 plug_switch = 1; } message brightness_pack { optional int32 brightness = 1; } message max_cur_pack { optional int32 max_cur = 1; } message time_task_config { optional string task_name = 1; optional time_range_strategy time_range = 2; optional int32 type = 3; } message time_task_config_post { optional int32 index = 1; optional time_task_config task_config = 2; } message PowerItem { optional int64 timestamp = 1; optional string timezone = 2; optional int32 plug_power = 3; } message PowerPack { optional int32 sys_seq = 1; repeated PowerItem sys_power_stream = 2; } message PowerAckPack { optional int32 sys_seq = 1; } message max_watts_pack { optional int32 max_watts = 1; } message mesh_ctrl_pack { optional int32 mesh_enable = 1; } message ret_pack { optional bool ret_sta = 1; } -
wn511_socket_sys.protosyntax = "proto3"; message rtc_data { optional int32 week = 1 [default = 1]; optional int32 sec = 2 [default = 1]; optional int32 min = 3 [default = 1]; optional int32 hour = 4 [default = 1]; optional int32 day = 5 [default = 1]; optional int32 month = 6 [default = 1]; optional int32 year = 7 [default = 1]; } message time_range_strategy { optional bool is_config = 1; optional bool is_enable = 2; optional int32 time_mode = 3; optional int32 time_data = 4; optional rtc_data start_time = 5; optional rtc_data stop_time = 6; } message plug_ack_message { optional int32 ack = 1; } message plug_heartbeat_pack { optional int32 err_code = 1 [default = 1]; optional int32 warn_code = 2 [default = 1]; optional int32 country = 3 [default = 1]; optional int32 town = 4 [default = 1]; optional int32 max_cur = 5 [default = 1]; optional int32 temp = 6 [default = 1]; optional int32 freq = 7 [default = 1]; optional int32 current = 8 [default = 1]; optional int32 volt = 9 [default = 1]; optional int32 watts = 10 [default = 1]; optional bool switch = 11; optional int32 brightness = 12 [default = 1]; optional int32 max_watts = 13 [default = 1]; optional int32 heartbeat_frequency = 14 [default = 1]; optional bool mesh_enable = 15; } message plug_switch_message { optional int32 plug_switch = 1; } message brightness_pack { optional int32 brightness = 1; } message max_cur_pack { optional int32 max_cur = 1; } message time_task_config { optional string task_name = 1; optional time_range_strategy time_range = 2; optional int32 type = 3; } message time_task_config_post { optional int32 index = 1; optional time_task_config task_config = 2; } message PowerItem { optional int64 timestamp = 1; optional string timezone = 2; optional int32 plug_power = 3; } message PowerPack { optional int32 sys_seq = 1; repeated PowerItem sys_power_stream = 2; } message PowerAckPack { optional int32 sys_seq = 1; } message max_watts_pack { optional int32 max_watts = 1; } message mesh_ctrl_pack { optional int32 mesh_enable = 1; } message ret_pack { optional bool ret_sta = 1; }Ich habe es geschafft alles in Klartext darzustellen hier eine txt Datei:ProtobufsDecoded.txt
Das müssten alle aus der App sein.
Mann muss sie sich nur etwas zusammenbasteln. -
Ich versuche diese Anleitung hier nachzustellen:
https://haus-automatisierung.com/hardware/2023/02/13/ecoflow-river-2-usv-batteriespeicher.htmWie kommt man denn an die UUID? Irgendwie stehe ich auf dem Schlauch.
@xfirf sagte in Adapter für Ecoflow Einbindung:
Du meinst für die Client-ID? Die kann man sich ausdenken soweit ich mich erinnere. Hauptsache deine userId am Ende stimmt.
@xfirf ich habe hier mal eine funktion für z.B Node-Red:
function uuidv4() { return 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function (c) { var r = Math.random() * 16 | 0, v = c === 'x' ? r : (r & 0x3 | 0x8); return v.toString(16); }); } msg.payload = uuidv4(); return msg;
