  4. js-controller 5.0.x jetzt in der BETA
580 Beiträge 71 Kommentatoren 266.1k Aufrufe 67 Beobachtet
  • ChaotC Chaot
    @apollon77
    Der LGTV Adapter fällt aus wie erwartet (ist aber bei mir eher unwichtig)
    Dazu kommt noch eine Fehlermeldung:
    host.ioBroker
    2023-06-12 22:06:50.881	error	cannot call visUtils: Not exists
    Die Fehlermeldung blieb jetzt erstmal weg nachdem ich den VIS Adapter nochmal hochgeladen habe.
    Ansonsten scheint alles zu laufen.
    Edit:
    Scheinbar kommt doch noch was:
    host.ioBroker
    2023-06-12 22:20:00.903	error	instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    2023-06-12 22:20:00.903	error	Caught by controller[1]: at processImmediate (node:internal/timers:478:21)
    host.ioBroker
    2023-06-12 22:20:00.902	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9313:46)
    host.ioBroker
    2023-06-12 22:20:00.902	error	Caught by controller[1]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15)
    host.ioBroker
    2023-06-12 22:20:00.902	error	Caught by controller[1]: Error: The pattern "Montag<br>12.06.2023" is not a valid ID pattern
    host.ioBroker
    2023-06-12 22:20:00.902	error	Caught by controller[0]: at processImmediate (node:internal/timers:478:21)
    host.ioBroker
    2023-06-12 22:20:00.902	error	Caught by controller[0]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9313:46)
    host.ioBroker
    2023-06-12 22:20:00.901	error	Caught by controller[0]: at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15)
    host.ioBroker
    2023-06-12 22:20:00.899	error	Caught by controller[0]: Error: The pattern "Montag<br>12.06.2023" is not a valid ID pattern
    web.0
    2023-06-12 22:20:00.678	error	The pattern "Montag<br>12.06.2023" is not a valid ID pattern
    web.0
    2023-06-12 22:20:00.678	error	Error: The pattern "Montag<br>12.06.2023" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9313:46) at processImmediate (node:internal/timers:478:21)
    web.0
    2023-06-12 22:20:00.677	error	uncaught exception: The pattern "Montag<br>12.06.2023" is not a valid ID pattern
    web.0
    2023-06-12 22:20:00.638	error	The pattern "Montag<br>12.06.2023" is not a valid ID pattern
    web.0
    2023-06-12 22:20:00.637	error	Error: The pattern "Montag<br>12.06.2023" is not a valid ID pattern at Object.pattern2RegEx (/opt/iobroker/node_modules/@iobroker/js-controller-common/src/lib/common/tools.ts:2415:15) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9313:46) at processImmediate (node:internal/timers:478:21)
    web.0
    2023-06-12 22:20:00.631	error	uncaught exception: The pattern "Montag<br>12.06.2023" is not a valid ID pattern
    apollon77A
    apollon77A
    @chaot Also hier bitte web issue um die Fehler besser abzufangen und ansonsten such welches Widget mit solchen Daten hantiert weil das macht was komisches und versufht scheinbar DInge abzufragen die keine State IDs sind!! Also da ist eher in deiner Vis oder einem Widget was broken!
    • Merlin123M Merlin123
      Wenn ich in einem Blockly einen anderen DP auswählen will öffnet sich der Objektbaum, die Anzeige springt zum aktuellen DP und dann dreht sich nur noch der Wartekreis. Keine Chance, den DP wieder zu ändern.
      Versuche ich einen Reload der Seite ( http://192.168.0.251:8081/#tab-javascript ) kommt erstmal ein "Webseite nicht erreichbar".
      Muss dann so ne halbe bis ganze Minute warten, dann läd er die Seite wieder. Versuche ich den DP nochmal zu ändern gleiches Spiel.
      Alle Adapter auf den neusten Beta Stand.
      EDIT: Nach Downgrade auf 4.0.24 geht das wieder.
      apollon77A
      apollon77A
      @merlin123 Bitte Admin issue mit der relevanten Browser Konsole Fehlermeldung ... da müsste es eine geben
      • M Marty56
        Installation von js-controller 5.0.x ist möglich.
        Allerdings kann ich diverse Adapter nicht mehr upgraden.
        Ich bekomme die Fehlermeldung:
        js-controller (>=2.0.0): 5.0.2
        node (>=14.0.0):
        Meine Node Versionen sind größer als 14.00
         node -v
        v18.16.0
        npm -v
        9.5.1
        Update: nach iob fix funktionierte es wieder
        Folgende Ausfälle bei mir.
        Yakha (V1.03)
        host.iobroker
        2023-06-13 08:11:39.286	error	instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[26]: [Yahka-0 011F@Wasseralarm@Wasseralarm@Status Low Battery] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[25]: [Yahka-0 011F@Heizung im Kinderzimmer@KZ Heizung@Status Low Battery] characteristic value expected valid finite number and received "NaN" (number)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[24]: [Yahka-0 011F@Heizung im Kinderzimmer@KZ Heizung@Status Low Battery] characteristic value expected valid finite number and received "NaN" (number)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[23]: [Yahka-0 011F@Leuchtstreifen@Leuchtstreifen@Color Temperature] characteristic was supplied illegal value: number 0 exceeded minimum of 140
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[22]: [Yahka-0 011F@Leuchtstreifen@Leuchtstreifen@Color Temperature] characteristic was supplied illegal value: number 0 exceeded minimum of 140
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[21]: [Yahka-0 011F@nördliches Fenster K1@nördliches Fenster K1@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[20]: [Yahka-0 011F@südliche, rechte Fenster K3@südliche,rechteFenster K3@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[19]: [Yahka-0 011F@südliche, linke Fenster K3@südliche,linke Fenster K3@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[18]: [Yahka-0 011F@südliche, rechte Fenster im OG@südliche, rechte Fenster im OG@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[17]: [Yahka-0 011F@südliche, linke Fenster im OG@südliche, linke Fenster im OG@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[16]: [Yahka-0 011F@nördliches Fenster im Bad@nördliches Fenster im Bad@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[15]: [Yahka-0 011F@südliches Fenster OF@südliches Fenster OF@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.286	error	Caught by controller[14]: [Yahka-0 011F@südliches Fenster KZ@südliches Fenster KZ@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[13]: [Yahka-0 011F@westliches Fenster KZ@westliches Fenster KZ@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[12]: [Yahka-0 011F@westliches Fenster SZ@westliches Fenster SZ@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[11]: [Yahka-0 011F@nördliches Fenster SZ@nördliches Fenster SZ@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[10]: [Yahka-0 011F@Haustür@Haustür@Status Low Battery] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[9]: [Yahka-0 011F@Haustür@Haustür@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[8]: [Yahka-0 011F@westliche Tür@westliche Tür@Status Low Battery] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[7]: [Yahka-0 011F@westliche Tür@westliche Tür@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[6]: [Yahka-0 011F@Terrasse rechts@Terrassentür rechts@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[5]: [Yahka-0 011F@Terrasse links@Terrassentür links@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[4]: [Yahka-0 011F@Neue Post@Neue Post@On] characteristic value expected boolean and received undefined
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[4]: [Yahka-0 011F@Garage@Garage@Obstruction Detected] characteristic value expected boolean and received undefined
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[3]: [Yahka-0 011F@Lampe im Schlafzimmer@Nachttischlampe@Hue] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.285	error	Caught by controller[2]: [Yahka-0 011F@Lampe im Schlafzimmer@Nachttischlampe@Saturation] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.284	error	Caught by controller[1]: [Yahka-0 011F@Luftqual@Luftqualität@PM2.5 Density] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:39.284	error	Caught by controller[0]: [Yahka-0 011F@Justin@Justin@On] characteristic value expected boolean and received undefined
        yahka.0
        2023-06-13 08:11:38.555	error	Error The pattern "ObstructionDetectedObstructionDetectedObstructionDetectedObstructionDetected0_userdata.0.Garage.ObstructionDetected" is not a valid ID pattern
        yahka.0
        2023-06-13 08:11:38.555	error	ReplyError: Error The pattern "ObstructionDetectedObstructionDetectedObstructionDetectedObstructionDetected0_userdata.0.Garage.ObstructionDetected" is not a valid ID pattern at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12) at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
        yahka.0
        2023-06-13 08:11:38.544	error	unhandled promise rejection: Error The pattern "ObstructionDetectedObstructionDetectedObstructionDetectedObstructionDetected0_userdata.0.Garage.ObstructionDetected" is not a valid ID pattern
        yahka.0
        2023-06-13 08:11:38.536	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        host.iobroker
        2023-06-13 08:11:05.745	error	instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.iobroker
        2023-06-13 08:11:05.745	error	Caught by controller[26]: [Yahka-0 011F@Wasseralarm@Wasseralarm@Status Low Battery] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[25]: [Yahka-0 011F@Heizung im Kinderzimmer@KZ Heizung@Status Low Battery] characteristic value expected valid finite number and received "NaN" (number)
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[24]: [Yahka-0 011F@Heizung im Kinderzimmer@KZ Heizung@Status Low Battery] characteristic value expected valid finite number and received "NaN" (number)
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[23]: [Yahka-0 011F@Leuchtstreifen@Leuchtstreifen@Color Temperature] characteristic was supplied illegal value: number 0 exceeded minimum of 140
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[22]: [Yahka-0 011F@Leuchtstreifen@Leuchtstreifen@Color Temperature] characteristic was supplied illegal value: number 0 exceeded minimum of 140
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[21]: [Yahka-0 011F@nördliches Fenster K1@nördliches Fenster K1@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[20]: [Yahka-0 011F@südliche, rechte Fenster K3@südliche,rechteFenster K3@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[19]: [Yahka-0 011F@südliche, linke Fenster K3@südliche,linke Fenster K3@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        host.iobroker
        2023-06-13 08:11:05.744	error	Caught by controller[18]: [Yahka-0 011F@südliche, rechte Fenster im OG@südliche, rechte Fenster im OG@Contact Sensor State] characteristic value expected valid finite number and received "undefined" (undefined)
        VIS (V 1.4.16 ) Anzeige Web UI
        File index.html not found: {}
        Log File:
        vis.0
        2023-06-13 08:30:13.571	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        vis.0
        2023-06-13 08:30:13.063	error	Not exists
        vis.0
        2023-06-13 08:30:13.062	error	Error: Not exists at ObjectsInRedisClient._readFile (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:856:19) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:893:59) at process.processImmediate (node:internal/timers:478:21)
        vis.0
        2023-06-13 08:30:13.061	error	unhandled promise rejection: Not exists
        vis.0
        2023-06-13 08:30:13.059	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        apollon77A
        apollon77A
        @marty56 Bitte issue in yahka anlegen und "iob upload vis" machen. Danach ok? Auch issue in vis bitte dennich mit der Fehlermeldung
        M 2 Antworten Letzte Antwort
        • ChaotC Chaot
          @apollon77
          host.ioBroker
          Edit:
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          web.0
          web.0
          web.0
          web.0
          web.0
          web.0
          @chaot sagte in js-controller 5.0.x jetzt in der BETA:
          @apollon77
          Es gibt mittlerweile einen Fork von @basti4557 vom LG Adapter, Version 1.1.11, die funktioniert auch mit js-controller 5.x einwandfrei.
          https://github.com/basti4557/ioBroker.lgtvs
            @apollon77
            apollon77A
            apollon77A
            @ilovegym Ist das jetzt was anderes als
            lgtv from https://github.com/foxriver76/ioBroker.lgtv nutzen bis Entwickler angepasst hat ?!
            • apollon77A apollon77
              @apollon77
              eine Weiterentwicklung von @foxriver76 da LG Änderungen gemacht hat..
              • mcm1957M mcm1957
                @apollon77
                FHEM sollte auch auf die Liste der bekannten Adapterinkompatibilitäten:
                https://github.com/iobroker-community-adapters/ioBroker.fhem/issues/213
                sieht nach Problem analog zu stiebel-isg aus
                haselchenH
                haselchenH
                haselchen
                @apollon77
                @foxriver76
                2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:39.955Z"},"last_event":"short_release"},"id":"a3ffd014-1ce6-465f-b2ca-610336764b10","id_v1":"/sensors/72","owner":{"rid":"5e33ed7a-aef2-40ab-a1e2-11d1fdeb9e46","rtype":"device"},"type":"button"}
                2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"initial_press","updated":"2023-06-12T20:36:40.709Z"},"last_event":"initial_press"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
                2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:40.839Z"},"last_event":"short_release"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
                2023-06-12 22:36:54.785 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"initial_press","updated":"2023-06-12T20:36:54.587Z"},"last_event":"initial_press"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
                2023-06-12 22:36:54.785 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:54.723Z"},"last_event":"short_release"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
                2023-06-12 11:52:17.705 - warn: ws.0 (845) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
                2023-06-12 22:23:08.219 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
                2023-06-12 22:23:12.210 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
                2023-06-12 22:23:15.311 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
                2023-06-12 22:23:17.289 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
                2023-06-12 22:23:18.341 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
                2023-06-12 22:23:45.705 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
                HUE Adapter 3.9.0
                Shelly Adapter 6.4.1
                WS Adapter 2.3.6
                Weil das Log durchgehend mit den Warnmeldungen vollgespamt wurde, bin ich zurück auf 4.0.24
                Ich weiß, es sind nur Warnmeldungen, aber ich möchte schon sehen, was da im System los ist.
                Das sind leider nur Auszüge, die ich noch retten konnte, ich meine der Sonoff Adapter war auch dabei mit Warnmeldungen.
                Edit: Die/der Shelly war nicht offline. War ganz normal zu erreichen.
                foxriver76F apollon77A crunchipC 3 Antworten Letzte Antwort
                • haselchenH haselchen
                  @apollon77
                  @foxriver76
                  HUE Adapter 3.9.0
                  WS Adapter 2.3.6
                  foxriver76F
                  foxriver76F
                  foxriver76
                  @haselchen Hue Warnmeldungen kommen von hue 3.9.0 unabhängig von Controller
                  Videotutorials & mehr
                  • foxriver76F foxriver76
                    haselchenH
                    haselchenH
                    haselchen
                    @foxriver76
                    Diese Meldungen habe ich aber mit JS 4.0.24 nicht mehr.
                      @foxriver76
                      foxriver76F
                      foxriver76F
                      foxriver76
                      @haselchen würde mich sehr sehr stark wundern ^^
                        haselchenH
                        haselchenH
                        haselchen
                        @foxriver76
                        Sonst würde ich es nicht schreiben ;)
                        Edit: Das Log selber ist mit der 4.0.24 viel ruhiger bzw. mit "normalen" Warnmeldungen versehen.
                        Nachdem ich die 5.0.2 probiert hatte explodierte das Log förmlich.
                        Auch 2-3 Neustarts haben da nicht geholfen.
                          @apollon77
                          @foxriver76
                          HUE Adapter 3.9.0
                          WS Adapter 2.3.6
                          apollon77A
                          apollon77A
                          @haselchen ws bitte Issue anlegen, aber sollte nur einmalig beim start kommen.
                          Shelly... naja das device ist offline? Wüsste nicht wie das am controller liegen sollte
                            @foxriver76
                            foxriver76F
                            foxriver76F
                            foxriver76
                            @haselchen villt hast du das Loglevel auf error geändert. Schalte mal ne Lampe insofern noch 3.9.0 drauf ist.. aber ja off topic https://github.com/iobroker-community-adapters/ioBroker.hue/issues/413
                              haselchenH
                              haselchenH
                              haselchen
                              @apollon77
                              Ich gehe immer nach dem Ausschlussverfahren vor.
                              Wenn vorher diese Meldung nicht kam und nach einem Update da ist.....dann ist für MICH das Update die Ursache 😬
                              Wie gesagt, mit der JS Stable Version läuft alles am Schnürchen. Die Warnungen oder Hinweise aus 5.0.2 gibt es nicht.
                              Die WS Info kam vermutlich nach den Neustarts. Also wie Du sagst, 1 Mal.
                                haselchenH
                                haselchenH
                                haselchen
                                @foxriver76
                                Ich hab Debug als Loglevel.
                                Bin halt neugierig :)
                                Hab den Button auf dem Dimmer Switch gerade nochmal gedrückt.
                                Keine Meldung im Log. Lampen sind aber an wie es soll.
                                  @foxriver76
                                  foxriver76F
                                  foxriver76F
                                  foxriver76
                                  @haselchen oder du hast nicht die offizielle 3.9.0 sondern nochmal von GitHub aktualisiert, da ists nämlich auch schon weg.
                                    haselchenH
                                    haselchenH
                                    haselchen
                                    @foxriver76
                                    Das wurmt mich doch nen bisschen.
                                    Ich setz hier mal nen Test Raspi auf und nudel die 5.0.2 rauf und runter.
                                      @apollon77
                                      @foxriver76
                                      HUE Adapter 3.9.0
                                      WS Adapter 2.3.6
                                      crunchipC
                                      crunchipC
                                      Developer Global Moderator Most Active Forum Testing
                                      @haselchen also ich hatte bisher keine Probleme mit sonoff oder shelly, allerdings hab ich noch den js-controller alpha laufen
                                      Vllt liegt es eher an der Firmware der shelly's
                                        haselchenH
                                        haselchenH
                                        haselchen
                                        @crunchip
                                        Wie gesagt, ich guck mir das vor und nach einem Update an.
                                        Und vorher war alles tutti.
                                        Die Meldungen kamen nach dem Update (und habe ich so zum ersten Mal gesehen).
                                        Diese waren aber schlichtweg falsch, da ich sie erreichen konnte mit jedem anderen Medium.
                                          M
                                          M
                                          Marty56
                                          @apollon77 sagte in js-controller 5.0.x jetzt in der BETA:
                                          iob upload vis
                                          Hat leider nicht funktioniert.
                                          Issue in Yakha habe ich angelegt.
                                          HW:NUC (16 GB Ram)
                                          OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                                          83.9k
