  4. js-controller 5.0.x jetzt in der BETA
    apollon77A
580 Beiträge 71 Kommentatoren 267.9k Aufrufe 67 Beobachtet
  • haselchenH haselchen
    @apollon77
    @foxriver76
    2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:39.955Z"},"last_event":"short_release"},"id":"a3ffd014-1ce6-465f-b2ca-610336764b10","id_v1":"/sensors/72","owner":{"rid":"5e33ed7a-aef2-40ab-a1e2-11d1fdeb9e46","rtype":"device"},"type":"button"}
    2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"initial_press","updated":"2023-06-12T20:36:40.709Z"},"last_event":"initial_press"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
    2023-06-12 22:36:40.964 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:40.839Z"},"last_event":"short_release"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
    2023-06-12 22:36:54.785 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"initial_press","updated":"2023-06-12T20:36:54.587Z"},"last_event":"initial_press"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
    2023-06-12 22:36:54.785 - warn: hue.0 (452) Unknown update for type "button": {"button":{"button_report":{"event":"short_release","updated":"2023-06-12T20:36:54.723Z"},"last_event":"short_release"},"id":"b427bb8c-c890-42ab-beac-364383ef9378","id_v1":"/sensors/98","owner":{"rid":"ebc2d5e7-a972-4fd7-9290-45b2fa7c5562","rtype":"device"},"type":"button"}
    2023-06-12 11:52:17.705 - warn: ws.0 (845) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
    2023-06-12 22:23:08.219 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
    2023-06-12 22:23:12.210 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
    2023-06-12 22:23:15.311 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
    2023-06-12 22:23:17.289 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
    2023-06-12 22:23:18.341 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
    2023-06-12 22:23:45.705 - warn: shelly.0 (536) [http controlFunction] Unable to perform request - device 192.168.2.66 (shelly1 / shelly1- / SHSW-1##1) is offline
    HUE Adapter 3.9.0
    Shelly Adapter 6.4.1
    WS Adapter 2.3.6
    Weil das Log durchgehend mit den Warnmeldungen vollgespamt wurde, bin ich zurück auf 4.0.24
    Ich weiß, es sind nur Warnmeldungen, aber ich möchte schon sehen, was da im System los ist.
    Das sind leider nur Auszüge, die ich noch retten konnte, ich meine der Sonoff Adapter war auch dabei mit Warnmeldungen.
    Edit: Die/der Shelly war nicht offline. War ganz normal zu erreichen.
    foxriver76F
    foxriver76F
    foxriver76
    @haselchen Hue Warnmeldungen kommen von hue 3.9.0 unabhängig von Controller
    Videotutorials & mehr
    • foxriver76F foxriver76
      haselchenH
      haselchenH
      haselchen
      @foxriver76
      Diese Meldungen habe ich aber mit JS 4.0.24 nicht mehr.
        @foxriver76
        foxriver76F
        foxriver76F
        foxriver76
        @haselchen würde mich sehr sehr stark wundern ^^
          haselchenH
          haselchenH
          haselchen
          @foxriver76
          Sonst würde ich es nicht schreiben ;)
          Edit: Das Log selber ist mit der 4.0.24 viel ruhiger bzw. mit "normalen" Warnmeldungen versehen.
          Nachdem ich die 5.0.2 probiert hatte explodierte das Log förmlich.
          Auch 2-3 Neustarts haben da nicht geholfen.
            @apollon77
            @foxriver76
            HUE Adapter 3.9.0
            WS Adapter 2.3.6
            apollon77A
            apollon77A
            @haselchen ws bitte Issue anlegen, aber sollte nur einmalig beim start kommen.
            Shelly... naja das device ist offline? Wüsste nicht wie das am controller liegen sollte
              @foxriver76
              foxriver76F
              foxriver76F
              foxriver76
              @haselchen villt hast du das Loglevel auf error geändert. Schalte mal ne Lampe insofern noch 3.9.0 drauf ist.. aber ja off topic https://github.com/iobroker-community-adapters/ioBroker.hue/issues/413
              • apollon77A apollon77
                haselchenH
                haselchenH
                haselchen
                @apollon77
                Ich gehe immer nach dem Ausschlussverfahren vor.
                Wenn vorher diese Meldung nicht kam und nach einem Update da ist.....dann ist für MICH das Update die Ursache 😬
                Wie gesagt, mit der JS Stable Version läuft alles am Schnürchen. Die Warnungen oder Hinweise aus 5.0.2 gibt es nicht.
                Die WS Info kam vermutlich nach den Neustarts. Also wie Du sagst, 1 Mal.
                  haselchenH
                  haselchenH
                  haselchen
                  @foxriver76
                  Ich hab Debug als Loglevel.
                  Bin halt neugierig :)
                  Hab den Button auf dem Dimmer Switch gerade nochmal gedrückt.
                  Keine Meldung im Log. Lampen sind aber an wie es soll.
                    @foxriver76
                    foxriver76F
                    foxriver76F
                    foxriver76
                    @haselchen oder du hast nicht die offizielle 3.9.0 sondern nochmal von GitHub aktualisiert, da ists nämlich auch schon weg.
                      haselchenH
                      haselchenH
                      haselchen
                      @foxriver76
                      Das wurmt mich doch nen bisschen.
                      Ich setz hier mal nen Test Raspi auf und nudel die 5.0.2 rauf und runter.
                        @apollon77
                        @foxriver76
                        HUE Adapter 3.9.0
                        WS Adapter 2.3.6
                        crunchipC
                        crunchipC
                        Developer Global Moderator Most Active Forum Testing
                        @haselchen also ich hatte bisher keine Probleme mit sonoff oder shelly, allerdings hab ich noch den js-controller alpha laufen
                        Vllt liegt es eher an der Firmware der shelly's
                          haselchenH
                          haselchenH
                          haselchen
                          @crunchip
                          Wie gesagt, ich guck mir das vor und nach einem Update an.
                          Und vorher war alles tutti.
                          Die Meldungen kamen nach dem Update (und habe ich so zum ersten Mal gesehen).
                          Diese waren aber schlichtweg falsch, da ich sie erreichen konnte mit jedem anderen Medium.
                            @marty56 Bitte issue in yahka anlegen und "iob upload vis" machen. Danach ok? Auch issue in vis bitte dennich mit der Fehlermeldung
                            M
                            M
                            Marty56
                            @apollon77 sagte in js-controller 5.0.x jetzt in der BETA:
                            iob upload vis
                            Hat leider nicht funktioniert.
                            Issue in Yakha habe ich angelegt.
                            HW:NUC (16 GB Ram)
                            OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
                            • M
                              M
                              Megawaldi
                              Das Upgrade auf 5.0.2 lief ohne Probleme durch.
                              Ich hab nur noch Problemen mit dem Miio Adapter.
                              Denke der wird aber leider nicht mehr aktualisiert.
                              Vieleicht kann man den in die community übernehmen?
                              https://github.com/SchumyHao/ioBroker.miio
                              • B
                                B
                                bommel_030
                                Upgrade von 4.0.24 auf 5.0.2 und im Anschluss "iob fix" lief problemlos.
                                Bekomme seitdem von einigen CRON-getriggerten Adaptern Warnmeldungen die vorher nicht im LOG auftauchten:
                                dwd.0		warn	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                yr.0			warn	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                host.iobroker-master	warn	instance system.adapter.uv-protect.0 already running with pid 1652
                                daswetter.0	warn	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                Zusätzlich in unregelmäßigen Abständen:
                                host.iobroker-master	error	cannot call visUtils: Not exists
                                Und der km200 Adapter lässt sich nicht mehr starten.
                                km200 Initialization Error:TypeError: Cannot read properties of undefined (reading '_subscribeForeignStates') at subscribeStates (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:7382:21) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:111 at new Promise (<anonymous>) at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:830:20 at /opt/iobroker/node_modules/@frankjoke/myadapter/myAdapter.js:311:77
                                crunchipC mcm1957M 2 Antworten Letzte Antwort
                                • B bommel_030
                                  crunchipC
                                  crunchipC
                                  #66
                                  @bommel_030 sagte in js-controller 5.0.x jetzt in der BETA:
                                  iob stop vis
                                  iob upload vis
                                  iob start vis
                                  • M Megawaldi
                                    mcm1957M
                                    mcm1957M
                                    mcm1957
                                    #67
                                    @megawaldi said in js-controller 5.0.x jetzt in der BETA:
                                    In den Repos ist ein fork enthalten:
                                    https://github.com/smarthomefans/ioBroker.miio/issues
                                    Prinzipiell sollte es möglich sein den in die Community zu übernehmen sofern der jetzige Dev da nichts mehr machen nmöchte (bitte diesen zuerst mal kontaktieren/fragen) - ABER ohne dass es einen Entwickler gibt der zumindest die wichtigsten Aktualisierungen und Anpassungen vornehmen kann / will und das auch testen kann wird es schwierig.
                                    Falls sich hier jemand bereit erklären will zumindest die notwendigsten Anpassungen durchführen zu wollen kann ich gerne beim Verschieben des Adapters (= Anpassen der Umgebung) udn Fragen helfen. Mangels Testmöglichkeiten (und auch Zeit) macht es keine Sinn wenn ich das selbst zusage bzw. an mich reiße.
                                    Zusätzlich wäre ev. ein Issue bei Adapterrequests sinnvoll um den Wunsche / Bedarf in Evidenz zu halten.
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • B bommel_030
                                      mcm1957M
                                      mcm1957M
                                      mcm1957
                                      #68
                                      @bommel_030
                                      Bitte issue beim km200 Adapter (https://github.com/iobroker-community-adapters/ioBroker.km200)
                                      Und bitte kurz testen, ob das Problem mit der aktuellen github version noch existiert
                                      Der Adapter wurde in den community Bereich verschoben - aber soweit ich weiß noch nicht aktualisiert. Auch wenn es mit der GH Version geht, bitte ein Issue mit dieser INfo beim Adapter ablegen damit möglichst bald eine Version eingezogen wir.
                                      mcm1957M B 2 Antworten Letzte Antwort
                                      • mcm1957M mcm1957
                                        @bommel_030
                                        mcm1957M
                                        mcm1957M
                                        mcm1957
                                        #69
                                        @apollon77
                                        Weitere Adapter mit Problemen für die Liste:
                                        km200
                                        miio
                                        • M
                                          M
                                          Monger71
                                          #70
                                          Bis auf den Ping-Adapter läuft alles. Dieser bringt die Meldung
                                          "instance system.adapter.ping.0 terminated with code 1 (JS_CONTROLLER_STOPPED)"
                                          83.9k
