  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
  • R Rushmed
    ich habe generell Verbinbdungsprobleme mit dem Adapter und der Ulanzi.
    Hier ein Log von mehreren Adapterneustarts:
    awtrix-light.0
    2023-06-10 12:50:43.954	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    awtrix-light.0
    2023-06-10 12:50:43.952	info	terminating
    awtrix-light.0
    2023-06-10 12:50:43.931	error	Exception-Code: ECONNABORTED: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:50:43.930	error	AxiosError: timeout of 3000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.awtrix-light/node_modules/axios/dist/node/axios.cjs:3047:16) at RedirectableRequest.emit (node:events:513:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
    awtrix-light.0
    2023-06-10 12:50:43.929	error	unhandled promise rejection: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:50:43.928	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    awtrix-light.0
    2023-06-10 12:50:43.877	info	error ECONNABORTED from /api/apps: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:50:40.744	warn	You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
    awtrix-light.0
    2023-06-10 12:49:42.626	info	error ECONNABORTED from /api/stats: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:49:39.501	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
    awtrix-light.0
    2023-06-10 12:49:03.865	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    awtrix-light.0
    2023-06-10 12:49:03.864	info	terminating
    awtrix-light.0
    2023-06-10 12:49:03.859	error	Exception-Code: ECONNABORTED: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:49:03.858	error	AxiosError: timeout of 3000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.awtrix-light/node_modules/axios/dist/node/axios.cjs:3047:16) at RedirectableRequest.emit (node:events:513:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
    awtrix-light.0
    2023-06-10 12:49:03.858	error	unhandled promise rejection: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:49:03.857	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    awtrix-light.0
    2023-06-10 12:49:03.803	info	error ECONNABORTED from /api/apps: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:49:00.693	warn	You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
    awtrix-light.0
    2023-06-10 12:49:00.339	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
    awtrix-light.0
    2023-06-10 12:48:54.009	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
    awtrix-light.0
    2023-06-10 12:48:53.728	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    awtrix-light.0
    2023-06-10 12:48:53.726	info	terminating
    awtrix-light.0
    2023-06-10 12:48:53.223	info	Got terminate signal TERMINATE_YOURSELF
    awtrix-light.0
    2023-06-10 12:48:18.468	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    awtrix-light.0
    2023-06-10 12:48:18.466	info	terminating
    awtrix-light.0
    2023-06-10 12:48:18.456	error	Exception-Code: ECONNABORTED: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:48:18.456	error	AxiosError: timeout of 3000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/iobroker.awtrix-light/node_modules/axios/dist/node/axios.cjs:3047:16) at RedirectableRequest.emit (node:events:513:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:164:12) at listOnTimeout (node:internal/timers:569:17) at process.processTimers (node:internal/timers:512:7)
    awtrix-light.0
    2023-06-10 12:48:18.455	error	unhandled promise rejection: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:48:18.455	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    awtrix-light.0
    2023-06-10 12:48:18.397	info	error ECONNABORTED from /api/apps: timeout of 3000ms exceeded
    awtrix-light.0
    2023-06-10 12:48:14.533	warn	You should update your Awtrix Light - supported version of this adapter is 0.68 (or later). Your current version is 0.67
    awtrix-light.0
    2023-06-10 12:48:14.156	info	starting. Version 0.0.13 (non-npm: klein0r/ioBroker.awtrix-light#b8ad47fdc5391c97e3c9470d606a277322cf2777) in /opt/iobroker/node_modules/iobroker.awtrix-light, node: v18.16.0, js-controller: 4.0.24
    awtrix-light.0
    2023-06-10 12:48:06.825	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    awtrix-light.0
    2023-06-10 12:48:06.823	info	terminating
    awtrix-light.0
    2023-06-10 12:48:06.818	info	Got terminate signal TERMINATE_YOURSELF
    Adapterversion 0.0.13
    AWTRIX light sollte 0.68 sein aber 0.67 wird angezeigt. Das Problem ist ja bekannt.
    Die Verbindung hat auch schonmal geklappt aber hielt dann nicht lange.
    Das WebUI von AWTRIX ist erreich- und steuerbar.
    Die Steuerung per MQTT funktioniert auch nicht aber die DPs werden erstellt.
    Was mache ich falsch? Was kann ich tun?
    haus-automatisierungH Offline
    #484
    @rushmed sagte in Test Adapter Awtrix-Light:
    Das ist ja ein Netzwerk / WLAN-Thema und da kann der Adapter ja erstmal nichts für. Ich würde mal einen anderen Standort probieren. Ansonsten hatte irgendjemand hier im Thread auch mal über Probleme gesprochen, wenn das 5GHz Netz die gleiche SSID hat. Ich habe damit keinerlei Probleme im UniFi Umfeld.
    📚 Meine Dokumentation
    R 2 Antworten Letzte Antwort
    • AtomicIXA AtomicIX
      @haus-automatisierung
      Sorry, hatte ich eben aktualisiert:
      iobroker@ioBroker:~$ iobroker state get 0_userdata.0.Aussentemp
      {"val":25.6,"ack":true,"ts":1686393064341,"q":0,"c":"script.js.Garten.Test.Aussentemp","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1686393064341}
      #485
      @atomicix sagte in Test Adapter Awtrix-Light:
      Das sieht ja richtig aus. Aber warum mixed? Muss mit number (Zahl) genauso funktionieren.
      Und was hat es jetzt mit dem Geheimnisvollen Alias auf sich? Darf den niemand sehen?
      AtomicIXA 1 Antwort Letzte Antwort
        AtomicIXA Offline
        AtomicIXA Offline
        AtomicIX
        #486
        @haus-automatisierung Wenn ich auf Zahl stelle, bekomme ich wieder "Undefined"
        Der Alias ist ein DP, der über ein Blockly einfach nur vom Netatmo DP Aktualisiert wird:
          Rushmed
          schrieb am zuletzt editiert von Rushmed
          #487
          @haus-automatisierung Danke für die Antwort.
          Ich glaube nicht dass es ein Netzwerproblem ist. Wie geasgt, das WebUI ist erreich und steuerbar und über die Ulanzi kann ich auch Updates laden.
          Lt. UDM sieht die Verbindung auch gut aus, da habe ich deutlich schlechtere Devices ohne probleme laufen:
          Ich probier trotzdem mal mit dem Standort rum.
          Diese Meldung kommt auch häufig:
          DJMarc75D haus-automatisierungH 2 Antworten Letzte Antwort
          • R Rushmed
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #488
            @rushmed Vertraue niemals Werten einer GUI ;)
            Lehrling seit 1975 !!!
            • R Rushmed
              #489
              Und Du hast nur die IP konfiguriert? Manche haben hier schon eine komplette URL mit http:// angegeben. Das ist natürlich falsch.
              R 1 Antwort Letzte Antwort
                Rushmed
                #490
                @haus-automatisierung Jepp, nur die IP.
                • R Rushmed
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #491
                  @rushmed unter Umständen ist Dein System auch nicht ganz "grade" ?!
                  schau Dir mal
                  iob diag
                  an...
                  hat aber hier dann im Thread nix zu suchen ;)
                  • DJMarc75D DJMarc75
                    schau Dir mal
                    iob diag
                    an...
                    Rushmed
                    #492
                    @djmarc75 Das sieht gut aus.
                    • R Rushmed
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #493
                      Das sieht gut aus.
                      Meine Frau auch ... aber von meiner Frau poste ich hier nicht die Ausgabe 😀
                      Die Ausgabe von Dir (iob diag) wäre trotzdem interessant zu sehen aber ist hier leider nicht im Beitrag sinnvoll da hier getestet wird und jeder Tester eigentlich auf einem sauberen und aktuellem System unterwegs sein sollte - und auch weiss was er macht.
                        Das sieht gut aus.
                        Rushmed
                        #494
                        @djmarc75 Marc, das hab ich doch verstanden. Deswegen hab ich die Ausgabe hier nicht gepostet.
                        • tobasiumT Offline
                          tobasiumT Offline
                          tobasium
                          #495
                          Hallo Zusammen,
                          ich kann irgendwie die ganzen apps nicht deaktivieren.
                          Bsp:
                          App hum deaktivieren:
                          App wird nicht deaktiviert im Log erscheint:
                          Versuch 2:
                          nichts passiert im Log.
                          App bleibt aktiviert.
                          Hat hier jemand einen Tip was ich falsch mache.
                          haus-automatisierungH Ben1983B 2 Antworten Letzte Antwort
                          • tobasiumT tobasium
                            Hallo Zusammen,
                            Bsp:
                            Versuch 2:
                            #496
                            @tobasium true senden. Der state hat die Rolle button. Mach doch mal den Expertenmodus aus 😉
                            Und natürlich nur unbestätigte Werte setzen. ioBroker Grundlagen anschauen!
                            tobasiumT 1 Antwort Letzte Antwort
                              Hallo Zusammen,
                              Bsp:
                              Versuch 2:
                              Ben1983B Offline
                              Ben1983B Offline
                              Ben1983
                              schrieb am zuletzt editiert von Ben1983
                              #497
                              @tobasium Das "active" aktiviert nur die anzeige auf der Uhr, also holt die App in den Vordergrund. sie wird dadurch nicht wirklich aktiviert / deaktiviert.
                              • Ben1983B Ben1983
                                tobasiumT Offline
                                tobasiumT Offline
                                tobasium
                                #498
                                @ben1983 wie deaktiviere ich die ganzen Apps dann? Da es den State visible ja nicht mehr gibt?
                                Vielen Dank vorab.
                                  tobasiumT Offline
                                  tobasiumT Offline
                                  tobasium
                                  #499
                                  @haus-automatisierung Vielen Dank. Ich bin aber auch blöd. Ich wollte die Apps deaktivieren hab das mit dem visible state vertauscht. Den gibt es ja nicht mehr.
                                    Vielen Dank vorab.
                                    #500
                                    @tobasium Aktivieren = in den Vordergrund holen. Es wird ja immer nur eine App angezeigt. Einfach eine andere aktivieren.
                                    Native apps komplett entfernen geht nur über das onscreen menu der uhr. Siehe doku der Firmware
                                      tobasiumT Offline
                                      tobasiumT Offline
                                      tobasium
                                      #501
                                      @haus-automatisierung Danke. Das war dann doch relativ einfach.
                                        Michaelnorge
                                        #502
                                        Kurze Frage:
                                        Ist dies hier das richtige Format für eine Soundausgabe?
                                        Bei mir steht dann im Log ein 404 Fehler, auch wenn ich "20fox.txt" schreibe.
                                        Die Datei ist vorhanden:
                                        • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
                                        H 1 Antwort Letzte Antwort
                                        • M Michaelnorge
                                          Kurze Frage:
                                          H Online
                                          H Online
                                          holgerwolf
                                          #503
                                          @michaelnorge Du musst die Sound Text Files unter Melodies packen. Bei dir sind sie im Haputverzeichnis.
