  4. BackItUp - InfluxDB2 - Grafana
    1.0k
62 Beiträge 7 Kommentatoren 8.9k Aufrufe 5 Beobachtet
    @friedhofsblond sagte in BackItUp - InfluxDB2 - Grafana:
    kommt das
    wo?
    keine Timestamps bei den Meldungen?
    FriedhofsblondF Offline
    Friedhofsblond
    schrieb am zuletzt editiert von Friedhofsblond
    2023-06-07 15:34:40.514 - info: host.debian stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-06-07 15:34:40.521 - info: backitup.0 (2022) Got terminate signal TERMINATE_YOURSELF
    2023-06-07 15:34:40.523 - info: backitup.0 (2022) cleaned everything up...
    2023-06-07 15:34:40.525 - info: backitup.0 (2022) terminating
    2023-06-07 15:34:40.526 - info: backitup.0 (2022) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-07 15:34:40.560 - info: host.debian stopInstance system.adapter.backitup.0 send kill signal
    2023-06-07 15:34:41.081 - info: host.debian instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-07 15:34:43.613 - info: host.debian instance system.adapter.backitup.0 started with pid 2044
    2023-06-07 15:34:44.591 - info: backitup.0 (2044) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-06-07 15:34:44.650 - info: backitup.0 (2044) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-06-07 15:34:53.221 - info: host.debian stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-06-07 15:34:53.227 - info: backitup.0 (2044) Got terminate signal TERMINATE_YOURSELF
    2023-06-07 15:34:53.230 - info: backitup.0 (2044) cleaned everything up...
    2023-06-07 15:34:53.231 - info: backitup.0 (2044) terminating
    2023-06-07 15:34:53.233 - info: backitup.0 (2044) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-07 15:34:53.268 - info: host.debian stopInstance system.adapter.backitup.0 send kill signal
    2023-06-07 15:34:53.800 - info: host.debian instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-07 15:34:56.348 - info: host.debian instance system.adapter.backitup.0 started with pid 2059
    2023-06-07 15:34:57.335 - info: backitup.0 (2059) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-06-07 15:34:57.395 - info: backitup.0 (2059) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-06-07 15:35:06.438 - error: backitup.0 (2059) [iobroker/grafana] cannot found Grafana Backup files
    2023-06-07 15:37:19.757 - info: admin.0 (1247) <== Disconnect system.user.admin from ::ffff:192.168.115.175
    2023-06-07 15:37:32.542 - info: admin.0 (1247) ==> Connected system.user.admin from ::ffff:192.168.115.175
    2023-06-07 15:37:39.757 - info: host.debian stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-06-07 15:37:39.767 - info: backitup.0 (2059) Got terminate signal TERMINATE_YOURSELF
    2023-06-07 15:37:39.770 - info: backitup.0 (2059) cleaned everything up...
    2023-06-07 15:37:39.771 - info: backitup.0 (2059) terminating
    2023-06-07 15:37:39.772 - info: backitup.0 (2059) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-06-07 15:37:39.808 - info: host.debian stopInstance system.adapter.backitup.0 send kill signal
    2023-06-07 15:37:39.903 - info: admin.0 (1247) <== Disconnect system.user.admin from ::ffff:192.168.115.175
    2023-06-07 15:37:40.321 - info: host.debian instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-06-07 15:37:42.860 - info: host.debian instance system.adapter.backitup.0 started with pid 2086
    2023-06-07 15:37:43.825 - info: backitup.0 (2086) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
    2023-06-07 15:37:43.883 - info: backitup.0 (2086) [iobroker] backup will be activated at 02:40 every 1 day(s)
    2023-06-07 15:37:45.746 - info: admin.0 (1247) ==> Connected system.user.admin from ::ffff:192.168.115.175
    2023-06-07 15:37:56.744 - error: backitup.0 (2086) [iobroker/grafana] cannot found Grafana Backup files
    2023-06-07 15:38:41.031 - info: admin.0 (1247) <== Disconnect system.user.admin from ::ffff:192.168.115.175
    locale speicherung:
    • HomoranH Offline
      HomoranH Offline
      @friedhofsblond danke!
      wenn du jetzt noch die Instanz auf Logstufe debug schaltest, kann man noch mehr sehen
      FriedhofsblondF 1 Antwort Letzte Antwort
        Friedhofsblond
        das ist doch so viel ... :
        Started iobroker ...
        [DEBUG] [iobroker] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.115.30","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.debian 2212 states saved
        [DEBUG] [iobroker] - host.debian 3010 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_06_07-15_48_05_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [grafana] - Start Grafana Backup ...
        [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Created dashboard directory
        [DEBUG] [grafana] - Created dashboards_manually_restore directory
        [DEBUG] [grafana] - Created datasource directory
        [DEBUG] [grafana] - start Grafana request ...
        [DEBUG] [grafana] - Grafana is available ... Status: 200
        [DEBUG] [grafana] - start Grafana backup compress ...
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        [ERROR] [grafana] - cannot found Grafana Backup files
        [DEBUG] [grafana] - done
        [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
        [DEBUG] [clean] - done
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyHTML] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.115.30","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"07. Juni 2023 um 15:48 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [historyJSON] start with {"type":"creator","workDir":"/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js","time":"02:40","debugging":true,"slaveBackup":"Single","everyXDays":"1","deleteBackupAfter":0,"ignoreErrors":false,"dir":"/opt/iobroker","grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21","secure":false,"ignoreErrors":false},"cifs":{"enabled":false,"mountType":"NFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****","ignoreErrors":false},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","dropboxAccessJson":"","dropboxTokenType":"custom","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false},"onedrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"onedriveAccessJson":"****","ownDir":false,"dir":"backupDir","dirMinimal":"backupDir/iobroker","ignoreErrors":false},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","signedCertificates":true,"ignoreErrors":false},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"newToken":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"accessJson":"****"},"host":"192.168.115.30","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****","nameSuffix":"","slaveSuffix":"","hostType":"Single","ignoreErrors":false,"signedCertificates":true},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","ignoreErrors":false,"systemLang":"de","time":"07. Juni 2023 um 15:48 Uhr"},"signal":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"backupDir":"/opt/iobroker/backups","influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[]}
        [EXIT] 0
        2023-06-07 15:47:57.507 - debug: backitup.0 (2124) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2023-06-07 15:47:57.528 - debug: backitup.0 (2124) Objects client ready ... initialize now
        2023-06-07 15:47:57.529 - debug: backitup.0 (2124) Objects create System PubSub Client
        2023-06-07 15:47:57.530 - debug: backitup.0 (2124) Objects create User PubSub Client
        2023-06-07 15:47:57.547 - debug: backitup.0 (2124) Objects client initialize lua scripts
        2023-06-07 15:47:57.551 - debug: backitup.0 (2124) Objects connected to redis: 127.0.0.1:9001
        2023-06-07 15:47:57.566 - debug: backitup.0 (2124) Redis States: Use Redis connection: 127.0.0.1:9000
        2023-06-07 15:47:57.572 - debug: backitup.0 (2124) States create System PubSub Client
        2023-06-07 15:47:57.572 - debug: backitup.0 (2124) States create User PubSub Client
        2023-06-07 15:47:57.624 - debug: backitup.0 (2124) States connected to redis: 127.0.0.1:9000
        2023-06-07 15:47:57.712 - debug: backitup.0 (2124) Plugin sentry Do not initialize Plugin (enabled=false)
        2023-06-07 15:47:57.716 - debug: backitup.0 (2124) Plugin sentry destroyed because not initialized correctly
        2023-06-07 15:47:57.796 - info: backitup.0 (2124) starting. Version 2.6.19 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.16.0, js-controller: 4.0.24
        2023-06-07 15:47:57.825 - debug: backitup.0 (2124) Backitup has recognized a linux system
        2023-06-07 15:47:57.856 - info: backitup.0 (2124) [iobroker] backup will be activated at 02:40 every 1 day(s)
        2023-06-07 15:47:57.899 - debug: backitup.0 (2124) [iobroker] 10 40 02 */1 * *
        2023-06-07 15:47:57.902 - debug: backitup.0 (2124) No backup file was found
        2023-06-07 15:47:59.802 - info: admin.0 (1247) ==> Connected system.user.admin from ::ffff:192.168.115.175
        2023-06-07 15:48:00.015 - debug: backitup.0 (2124) The local storage check was completed successfully. On the host "debian" are currently 219563 MB free space available!
        2023-06-07 15:48:04.494 - debug: backitup.0 (2124) The local storage check was completed successfully. On the host "debian" are currently 219563 MB free space available!
        2023-06-07 15:48:04.925 - debug: backitup.0 (2124) Backup has started ...
        2023-06-07 15:48:06.374 - debug: backitup.0 (2124) [iobroker/iobroker] host.debian 2212 states saved
        2023-06-07 15:48:06.411 - debug: backitup.0 (2124) [iobroker/iobroker] host.debian 3010 objects saved
        2023-06-07 15:48:07.377 - debug: backitup.0 (2124) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2023_06_07-15_48_05_backupiobroker.tar.gz
        2023-06-07 15:48:08.408 - debug: backitup.0 (2124) [iobroker/iobroker] done
        2023-06-07 15:48:09.768 - debug: backitup.0 (2124) [iobroker/grafana] Start Grafana Backup ...
        2023-06-07 15:48:09.773 - debug: backitup.0 (2124) [iobroker/grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
        2023-06-07 15:48:09.775 - debug: backitup.0 (2124) [iobroker/grafana] Created dashboard directory
        2023-06-07 15:48:09.779 - debug: backitup.0 (2124) [iobroker/grafana] Created dashboards_manually_restore directory
        2023-06-07 15:48:09.782 - debug: backitup.0 (2124) [iobroker/grafana] Created datasource directory
        2023-06-07 15:48:09.783 - debug: backitup.0 (2124) [iobroker/grafana] start Grafana request ...
        2023-06-07 15:48:09.862 - debug: backitup.0 (2124) [iobroker/grafana] Grafana is available ... Status: 200
        2023-06-07 15:48:09.971 - debug: backitup.0 (2124) [iobroker/grafana] start Grafana backup compress ...
        2023-06-07 15:48:09.974 - debug: backitup.0 (2124) [iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        2023-06-07 15:48:09.981 - debug: backitup.0 (2124) [iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        2023-06-07 15:48:09.981 - error: backitup.0 (2124) [iobroker/grafana] cannot found Grafana Backup files
        2023-06-07 15:48:09.982 - debug: backitup.0 (2124) [iobroker/grafana] done
        2023-06-07 15:48:11.791 - debug: backitup.0 (2124) [iobroker/clean] No older backup files are deleted, because this backup was started manually
        2023-06-07 15:48:11.793 - debug: backitup.0 (2124) [iobroker/clean] done
        2023-06-07 15:48:12.932 - debug: backitup.0 (2124) [iobroker/historyHTML] new history html values created
        2023-06-07 15:48:12.988 - debug: backitup.0 (2124) [iobroker/historyHTML] done
        2023-06-07 15:48:13.157 - debug: backitup.0 (2124) [iobroker/historyJSON] new history json values created
        2023-06-07 15:48:13.158 - debug: backitup.0 (2124) [iobroker/historyJSON] done
        2023-06-07 15:48:13.461 - debug: backitup.0 (2124) [iobroker] exec: done
        2023-06-07 15:48:52.361 - info: admin.0 (1247) <== Disconnect system.user.admin from ::ffff:192.168.115.175
        • FriedhofsblondF Friedhofsblond
          [EXIT] 0
          HomoranH Offline
          HomoranH Offline
          aber nichts wirklich neues.
          lediglich
          warum auch immer
            lediglich
            warum auch immer
            Friedhofsblond
            ich habe ja den normalen benutzer zum login in der Gui.
            Dann nochmal den serviceaccount.
            dazu noch den Token für den Serviceaccount.
            Welche kombi ist die richtige?
            Welche Rechte soll der SA haben?
            HomoranH simatecS 2 Antworten Letzte Antwort
              HomoranH Offline
              HomoranH Offline
              @friedhofsblond Da bin ich raus!
              Grafana gehört nicht zu ioBroker.
              Da muss jemand anders helfen
                Friedhofsblond
                @homoran 😧 😖
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @friedhofsblond Der Service-Account muss die Role admin haben und die Benutzerdaten in Backitup müssen die vom admin sein.
                  Ein User hat nicht genug Rechte für ein Backup über die API
                  • Besuche meine Github Seite
                  • HowTo Restore ioBroker
                    @friedhofsblond
                    So moin,
                    bin noch nicht viel weiter 🙄
                    Die Daten landen in der DB und werden auch gesichert:
                    Habe zwei Probleme ich kann wohl kein Backup von Grafana machen, weil die Verbindung von Influxdb zu Grafana nicht klappt ... denke ich:
                    1. Was soll ich hier einstellen?:
                      Ich habe alles mögliche versucht mit Passwort Token usw ...
                    2. Und hier die Daten für das Backup?.
                    Die Datenbank für iobroker heißt iobrokerdb
                    62d078e6-8a72-4f15-946d-372a87ecef28-image.png 13a34f0c-6aa2-452b-b07e-ddb9aebe8140-image.png
                    Moin,
                    das hat ja, nach meinem dafür, nichts mit dem Backup zu tun.
                    Das sind doch die Einstellungen, um von Grafana auf die influxDB zuzugreifen.
                    Wie hast Du die Datenbank, das Bucket, angelegt, als influxDBVersion V1.x mit der Abfragesprache influxQL oder als V 2.x mit Abfrage in FLUX?
                    Für FLUXsieht das so aus, wenn Du Datenquellen unter Grafana einrichtest.
                    Bernd
                    P.S.: zu BackitUp, kann ich nichts sagen, da ich es nicht nutze.
                      Moin,
                      Bernd
                      Friedhofsblond
                      @dp20eic
                      Ja das ist dann mein Problem 2 ;)
                      Ich habe ein frisch installiertes influxdb2, iobroker, influx und grafana alles auf einer Kiste.
                      So wie oben meine Bilder von Grafana.
                        @dp20eic
                        Friedhofsblond
                        @friedhofsblond
                        mit flux funktioniert die Abfrage von der DB - aber da müßte ich mich erstmal einfluxen in Grafana. Wo man die Daten findet ...
                          @friedhofsblond
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @friedhofsblond Ich denke erstmal hier nicht die Themen mischen ... Laut Titel geht es um Backitup für Grafana und Influx.
                          Influx geht ja nun. Nun setze den Service-Account in Grafana wie weiter oben geschrieben und als User admin
                          • simatecS simatec
                            Friedhofsblond
                            @simatec
                            so Backup läuft jetzt - man muß wohl erst ein Dashboard anlegen damit auch was gesichert werden kann - das weiß ein alter Zausel wie ich natürlich nicht. 🙄
                            Nun wäre es mir lieb in Grafana wieder von flux auf influx zu gehen, weil ich mit flux keine Daten für ein Diagramm o.ä finde,
                            @simatec - du bist damit raus 👍 😊
                              @simatec
                              HomoranH Offline
                              HomoranH Offline
                              nein!
                              du bist hier raus!
                              @simatec sagte in BackItUp - InfluxDB2 - Grafana:
                              @Friedhofsblond
                              Also jetzt einen neuen Thread mit passendem Threadtitel aufmachen!
                              FriedhofsblondF crunchipC 2 Antworten Letzte Antwort
                                nein!
                                du bist hier raus!
                                @Friedhofsblond
                                Friedhofsblond
                                OKok - war nicht böse gemeint - bin ja über jede Hilfe dankbar.
                                Habe in Inet schon viel über diese Verbindung gelesen - aber noch nicht schlau draus geworden.
                                Also Backup ist somit erstmal fertig - ich danke Euch 👏 👏 😊
                                  HomoranH Offline
                                  HomoranH Offline
                                  das war (mir) klar!
                                  wenn du jetzt meinen Link wirklich gelesen hast, weisst du wie es von mir gemeint war
                                    nein!
                                    du bist hier raus!
                                    @Friedhofsblond
                                    crunchipC Offline
                                    crunchipC Offline
                                    @homoran sagte in BackItUp - InfluxDB2 - Grafana:
                                    @Friedhofsblond
                                    vllt hilft`s
                                    https://www.influxdata.com/blog/how-grafana-dashboard-influxdb-flux-influxql/
                                      @Friedhofsblond
                                      vllt hilft`s
                                      Friedhofsblond
                                      @crunchip
                                      hier im Forum
