  4. Iobroker startet nicht mehr nach Ubuntu update
31 Beiträge 6 Kommentatoren 4.3k Aufrufe
    sveni_lee
    kannes sein, das das Problem der iobroker.core ist?
    iobroker.core@0.1.0 /opt/iobroker
    └── (empty)
    npm ERR! code 1
      sveni_lee
      Also ich bekomme iobroker einfach nicht mehr ans laufen… es läuft immer wieder auf den selben Fehler hinaus.
      Da bei reinstall immer wieder der Fehler bei socketio auftritt habe ich versucht dieses Modul per Hand zu installieren-
      Leider auch ohne erfolg
      ! svenilee@Gotham-City:/opt/iobroker$ sudo npm install iobroker.socketio --loglevel verbose npm info it worked if it ends with ok npm verb cli [ '/usr/bin/node', npm verb cli '/usr/bin/npm', npm verb cli 'install', npm verb cli 'iobroker.socketio', npm verb cli '--loglevel', npm verb cli 'verbose' ] npm info using npm@3.10.10 npm info using node@v6.12.0 npm verb request uri https://registry.npmjs.org/iobroker.socketio npm verb request no auth needed npm info attempt registry request try #1 at 17:24:10 npm verb request id 7d087b006a900a50 npm verb etag W/"59f82d29-1200c" npm verb lastModified Tue, 31 Oct 2017 07:58:33 GMT npm http request GET https://registry.npmjs.org/iobroker.socketio npm http 304 https://registry.npmjs.org/iobroker.socketio npm verb headers { date: 'Sun, 19 Nov 2017 16:24:10 GMT', npm verb headers via: '1.1 varnish', npm verb headers 'cache-control': 'max-age=300', npm verb headers etag: 'W/"59f82d29-1200c"', npm verb headers age: '232', npm verb headers connection: 'keep-alive', npm verb headers 'x-served-by': 'cache-hhn1533-HHN', npm verb headers 'x-cache': 'HIT', npm verb headers 'x-cache-hits': '1', npm verb headers 'x-timer': 'S1511108650.285039,VS0,VE1', npm verb headers vary: 'Accept-Encoding, Accept' } npm verb etag https://registry.npmjs.org/iobroker.socketio from cache npm verb get saving iobroker.socketio to /home/svenilee/.npm/registry.npmjs.org/iobroker.socketio/.cache.json npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb cache add spec iobroker.socketio npm verb addNamed "latest" is being treated as a dist-tag for iobroker.socketio npm info addNameTag [ 'iobroker.socketio', 'latest' ] npm verb addNameTag registry:https://registry.npmjs.org/iobroker.socketio not in flight; fetching npm verb get https://registry.npmjs.org/iobroker.socketio not expired, no request npm verb addNamed "1.8.6" is a plain semver version for iobroker.socketio npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json not in flight; writing npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json written npm verb correctMkdir /home/svenilee/.npm/_locks correctMkdir not in flight; initializing npm verb lock using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging npm verb unbuild node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb tar unpack /home/svenilee/.npm/iobroker.socketio/1.8.6/package.tgz npm verb tar unpacking to /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c/node_modules npm info lifecycle iobroker.socketio@1.8.6~preinstall: iobroker.socketio@1.8.6 npm verb unbuild node_modules/iobroker.socketio npm info lifecycle iobroker.socketio@1.8.6~preuninstall: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~uninstall: iobroker.socketio@1.8.6 npm verb unbuild rmStuff iobroker.socketio@1.8.6 from /opt/iobroker/node_modules npm info lifecycle iobroker.socketio@1.8.6~postuninstall: iobroker.socketio@1.8.6 npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.socketio npm info linkStuff iobroker.socketio@1.8.6 npm verb linkBins iobroker.socketio@1.8.6 npm verb linkMans iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~install: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~postinstall: iobroker.socketio@1.8.6 npm verb unlock done using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging iobroker.core@0.1.0 /opt/iobroker └── (empty) ! npm verb exit [ 0, true ] npm ERR! code 1 svenilee@Gotham-City:/opt/iobroker$ !
      • BluefoxB Offline
        BluefoxB Offline
        Ich empfehle die neuste js-controller vom github zu installieren:
        cd /opt/iobroker
        iobroker stop
        npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
        iobroker start
        Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren.
          sveni_lee
          hallo Bluefox,
          hab ich Probiert:
          ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker stop
          [sudo] Passwort für svenilee:
          iobroker controller daemon is not running
          svenilee@Gotham-City:/opt/iobroker$ sudo npm i https://github.com/ioBroker/ioBroker.js … all/master --production
          npm WARN deprecated tar.gz@1.0.7: <emoji seq="26a0">⚠️</emoji> WARNING <emoji seq="26a0">⚠️</emoji> tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
          npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
          iobroker.js-controller@1.2.1 install /opt/iobroker/node_modules/iobroker.js-controller
          node iobroker.js setup first
          └── iobroker.js-controller@1.2.1
          svenilee@Gotham-City:/opt/iobroker$ sudo iobroker start
          Starting iobroker controller daemon...
          iobroker controller daemon started. PID: 13515 `
          log:
          ` > 2017-11-19 20:45:53.635 - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.1 js-controller starting
          2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City Copyright © 2014-2017 bluefox, 2014 hobbyquaker
          2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
          2017-11-19 20:45:53.641 - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 fd2d:5cf3:5594:0:be5f:f4ff:fe7d:a73c fe80::be5f:f4ff:fe7d:a$
          2017-11-19 20:45:53.691 - ^[[32minfo^[[39m: host.Gotham-City inMem-states listening on port 9000
          2017-11-19 20:45:53.711 - ^[[32minfo^[[39m: host.Gotham-City inMem-objects listening on port 9001
          2017-11-19 20:45:53.718 - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
          2017-11-19 20:45:53.720 - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
          2017-11-19 20:45:53.725 - ^[[32minfo^[[39m: host.Gotham-City no instances found
          2017-11-19 20:45:53.746 - ^[[33mwarn^[[39m: host.Gotham-City multihost service started on 0.0.0.0:50005 `
          sollte laufen…
          ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker status
          iobroker is running `
          ist aber unter port 8081 nicht erreichbar
          muß ich noch einen reinstall ausführen?
          • BluefoxB Offline
            BluefoxB Offline
            @sveni_lee:
            hallo Bluefox,
            hab ich Probiert:
            log:
            sollte laufen…
            muß ich noch einen reinstall ausführen? `
            Wo sind deine Einstellungen? Die datei /opt/iobroker-data/objects.json lehr oder default.
              sveni_lee
              ich würde sagen default…
              steht fast überall was drin
              • BluefoxB Offline
                BluefoxB Offline
                Ich wollte damit sagen, dass die Einstellungen weg sind.
                  sveni_lee
                  sorry… versteh nicht was Du meinst?
                  die Datei ist doch da?
                  oder Anders... wie bekomme ich diese wieder?
                    sveni_lee
                    so, ich habe jetzt eine Image-Sicherung vom Server genommen und den iobroker-ordner in
                    mein aktuelles Image kopiert. Danach funktioniert es schon einmal wieder…
                    Aber wie bekomme ich jetzt meinen aktuellen Datenstand dort rein, einfach den iobroker-data ordner wieder zurück
                    kopieren?
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @sveni_lee:
                      kopieren? `
                      Definiere Datenstand, history Daten oder?
                      Send from mobile device
                        sveni_lee
                        Objektpunkte, Skripte, Adaptereinstellungen
                        Edit: hat nicht funktioniert…
                        Gibt es einen Ordner in dem die Skripte abgelegt werden, do das ich wenigstens diese wieder herstellen kann?
