  4. Iobroker startet nicht mehr nach Ubuntu update
31 Beiträge 6 Kommentatoren 4.3k Aufrufe
  • paul53P Offline
    Nimm diese Datei, nach dem Entfernen von .txt am Ende des Dateinamen.
    493_reinstall.sh.txt
      sveni_lee
      so, alles gemacht aber noch kein erfolg…
      2017-11-17 22:05:40.282  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
      2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
      2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
      2017-11-17 22:05:40.289  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxxx
      2017-11-17 22:05:40.337  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
      2017-11-17 22:05:40.358  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
      2017-11-17 22:05:40.365  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
      2017-11-17 22:05:40.367  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
      2017-11-17 22:05:40.371  - ^[[32minfo^[[39m: host.Gotham-City no instances found
      2017-11-17 22:05:40.381  - ^[[31merror^[[39m: uncaught exception: logger is not defined
      2017-11-17 22:05:40.383  - ^[[31merror^[[39m: ReferenceError: logger is not defined
          at Object.decryptPhrase (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:77:9)
          at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:128:27
          at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
          at ontimeout (timers.js:386:11)
          at tryOnTimeout (timers.js:250:5)
          at Timer.listOnTimeout (timers.js:214:5)
      2017-11-17 22:05:40.388  - ^[[32minfo^[[39m: host.Gotham-City terminated
      2017-11-17 22:05:40.396  - ^[[32minfo^[[39m: iobroker _restart
      2017-11-17 22:05:40.652  - ^[[32minfo^[[39m: iobroker Starting node restart.js
      2017-11-17 22:05:40.662  - ^[[32minfo^[[39m: iobroker exit 0
      2017-11-17 22:05:40.776  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
      2017-11-17 22:05:40.777  - ^[[32minfo^[[39m: host.Gotham-City terminated
      einen Fehler gab es doch beim reinstall
      iobroker.core@0.1.0 /opt/iobroker
      └── (empty)
      npm ERR! code 1
      FAIL iobroker.socketio
        sveni_lee
        kannes sein, das das Problem der iobroker.core ist?
        └── (empty)
        npm ERR! code 1
          sveni_lee
          Also ich bekomme iobroker einfach nicht mehr ans laufen… es läuft immer wieder auf den selben Fehler hinaus.
          Da bei reinstall immer wieder der Fehler bei socketio auftritt habe ich versucht dieses Modul per Hand zu installieren-
          Leider auch ohne erfolg
          ! svenilee@Gotham-City:/opt/iobroker$ sudo npm install iobroker.socketio --loglevel verbose npm info it worked if it ends with ok npm verb cli [ '/usr/bin/node', npm verb cli '/usr/bin/npm', npm verb cli 'install', npm verb cli 'iobroker.socketio', npm verb cli '--loglevel', npm verb cli 'verbose' ] npm info using npm@3.10.10 npm info using node@v6.12.0 npm verb request uri https://registry.npmjs.org/iobroker.socketio npm verb request no auth needed npm info attempt registry request try #1 at 17:24:10 npm verb request id 7d087b006a900a50 npm verb etag W/"59f82d29-1200c" npm verb lastModified Tue, 31 Oct 2017 07:58:33 GMT npm http request GET https://registry.npmjs.org/iobroker.socketio npm http 304 https://registry.npmjs.org/iobroker.socketio npm verb headers { date: 'Sun, 19 Nov 2017 16:24:10 GMT', npm verb headers via: '1.1 varnish', npm verb headers 'cache-control': 'max-age=300', npm verb headers etag: 'W/"59f82d29-1200c"', npm verb headers age: '232', npm verb headers connection: 'keep-alive', npm verb headers 'x-served-by': 'cache-hhn1533-HHN', npm verb headers 'x-cache': 'HIT', npm verb headers 'x-cache-hits': '1', npm verb headers 'x-timer': 'S1511108650.285039,VS0,VE1', npm verb headers vary: 'Accept-Encoding, Accept' } npm verb etag https://registry.npmjs.org/iobroker.socketio from cache npm verb get saving iobroker.socketio to /home/svenilee/.npm/registry.npmjs.org/iobroker.socketio/.cache.json npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb cache add spec iobroker.socketio npm verb addNamed "latest" is being treated as a dist-tag for iobroker.socketio npm info addNameTag [ 'iobroker.socketio', 'latest' ] npm verb addNameTag registry:https://registry.npmjs.org/iobroker.socketio not in flight; fetching npm verb get https://registry.npmjs.org/iobroker.socketio not expired, no request npm verb addNamed "1.8.6" is a plain semver version for iobroker.socketio npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json not in flight; writing npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json written npm verb correctMkdir /home/svenilee/.npm/_locks correctMkdir not in flight; initializing npm verb lock using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging npm verb unbuild node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb tar unpack /home/svenilee/.npm/iobroker.socketio/1.8.6/package.tgz npm verb tar unpacking to /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c/node_modules npm info lifecycle iobroker.socketio@1.8.6~preinstall: iobroker.socketio@1.8.6 npm verb unbuild node_modules/iobroker.socketio npm info lifecycle iobroker.socketio@1.8.6~preuninstall: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~uninstall: iobroker.socketio@1.8.6 npm verb unbuild rmStuff iobroker.socketio@1.8.6 from /opt/iobroker/node_modules npm info lifecycle iobroker.socketio@1.8.6~postuninstall: iobroker.socketio@1.8.6 npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.socketio npm info linkStuff iobroker.socketio@1.8.6 npm verb linkBins iobroker.socketio@1.8.6 npm verb linkMans iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~install: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~postinstall: iobroker.socketio@1.8.6 npm verb unlock done using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging iobroker.core@0.1.0 /opt/iobroker └── (empty) ! npm verb exit [ 0, true ] npm ERR! code 1 svenilee@Gotham-City:/opt/iobroker$ !
          • BluefoxB Offline
            BluefoxB Offline
            Ich empfehle die neuste js-controller vom github zu installieren:
            cd /opt/iobroker
            iobroker stop
            npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
            iobroker start
            Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren.
              sveni_lee
              hallo Bluefox,
              hab ich Probiert:
              ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker stop
              [sudo] Passwort für svenilee:
              iobroker controller daemon is not running
              svenilee@Gotham-City:/opt/iobroker$ sudo npm i https://github.com/ioBroker/ioBroker.js … all/master --production
              npm WARN deprecated tar.gz@1.0.7: <emoji seq="26a0">⚠️</emoji> WARNING <emoji seq="26a0">⚠️</emoji> tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
              npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
              iobroker.js-controller@1.2.1 install /opt/iobroker/node_modules/iobroker.js-controller
              node iobroker.js setup first
              └── iobroker.js-controller@1.2.1
              svenilee@Gotham-City:/opt/iobroker$ sudo iobroker start
              Starting iobroker controller daemon...
              iobroker controller daemon started. PID: 13515 `
              log:
              ` > 2017-11-19 20:45:53.635 - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.1 js-controller starting
              2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City Copyright © 2014-2017 bluefox, 2014 hobbyquaker
              2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
              2017-11-19 20:45:53.641 - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 fd2d:5cf3:5594:0:be5f:f4ff:fe7d:a73c fe80::be5f:f4ff:fe7d:a$
              2017-11-19 20:45:53.691 - ^[[32minfo^[[39m: host.Gotham-City inMem-states listening on port 9000
              2017-11-19 20:45:53.711 - ^[[32minfo^[[39m: host.Gotham-City inMem-objects listening on port 9001
              2017-11-19 20:45:53.718 - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
              2017-11-19 20:45:53.720 - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
              2017-11-19 20:45:53.725 - ^[[32minfo^[[39m: host.Gotham-City no instances found
              2017-11-19 20:45:53.746 - ^[[33mwarn^[[39m: host.Gotham-City multihost service started on 0.0.0.0:50005 `
              sollte laufen…
              ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker status
              iobroker is running `
              ist aber unter port 8081 nicht erreichbar
              muß ich noch einen reinstall ausführen?
              • BluefoxB Offline
                BluefoxB Offline
                @sveni_lee:
                hallo Bluefox,
                hab ich Probiert:
                log:
                sollte laufen…
                muß ich noch einen reinstall ausführen? `
                Wo sind deine Einstellungen? Die datei /opt/iobroker-data/objects.json lehr oder default.
                  sveni_lee
                  ich würde sagen default…
                  steht fast überall was drin
                  • BluefoxB Offline
                    BluefoxB Offline
                    Ich wollte damit sagen, dass die Einstellungen weg sind.
                      sveni_lee
                      sorry… versteh nicht was Du meinst?
                      die Datei ist doch da?
                      oder Anders... wie bekomme ich diese wieder?
                        sveni_lee
                        so, ich habe jetzt eine Image-Sicherung vom Server genommen und den iobroker-ordner in
                        mein aktuelles Image kopiert. Danach funktioniert es schon einmal wieder…
                        Aber wie bekomme ich jetzt meinen aktuellen Datenstand dort rein, einfach den iobroker-data ordner wieder zurück
                        kopieren?
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          @sveni_lee:
                          kopieren? `
                          Definiere Datenstand, history Daten oder?
                          Send from mobile device
                            sveni_lee
                            Objektpunkte, Skripte, Adaptereinstellungen
                            Edit: hat nicht funktioniert…
                            Gibt es einen Ordner in dem die Skripte abgelegt werden, do das ich wenigstens diese wieder herstellen kann?
