  4. Iobroker startet nicht mehr nach Ubuntu update
31 Beiträge 6 Kommentatoren 4.3k Aufrufe
    sveni_lee
    Also ich bekomme iobroker einfach nicht mehr ans laufen… es läuft immer wieder auf den selben Fehler hinaus.
    Da bei reinstall immer wieder der Fehler bei socketio auftritt habe ich versucht dieses Modul per Hand zu installieren-
    Leider auch ohne erfolg
    ! svenilee@Gotham-City:/opt/iobroker$ sudo npm install iobroker.socketio --loglevel verbose npm info it worked if it ends with ok npm verb cli [ '/usr/bin/node', npm verb cli '/usr/bin/npm', npm verb cli 'install', npm verb cli 'iobroker.socketio', npm verb cli '--loglevel', npm verb cli 'verbose' ] npm info using npm@3.10.10 npm info using node@v6.12.0 npm verb request uri https://registry.npmjs.org/iobroker.socketio npm verb request no auth needed npm info attempt registry request try #1 at 17:24:10 npm verb request id 7d087b006a900a50 npm verb etag W/"59f82d29-1200c" npm verb lastModified Tue, 31 Oct 2017 07:58:33 GMT npm http request GET https://registry.npmjs.org/iobroker.socketio npm http 304 https://registry.npmjs.org/iobroker.socketio npm verb headers { date: 'Sun, 19 Nov 2017 16:24:10 GMT', npm verb headers via: '1.1 varnish', npm verb headers 'cache-control': 'max-age=300', npm verb headers etag: 'W/"59f82d29-1200c"', npm verb headers age: '232', npm verb headers connection: 'keep-alive', npm verb headers 'x-served-by': 'cache-hhn1533-HHN', npm verb headers 'x-cache': 'HIT', npm verb headers 'x-cache-hits': '1', npm verb headers 'x-timer': 'S1511108650.285039,VS0,VE1', npm verb headers vary: 'Accept-Encoding, Accept' } npm verb etag https://registry.npmjs.org/iobroker.socketio from cache npm verb get saving iobroker.socketio to /home/svenilee/.npm/registry.npmjs.org/iobroker.socketio/.cache.json npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb cache add spec iobroker.socketio npm verb addNamed "latest" is being treated as a dist-tag for iobroker.socketio npm info addNameTag [ 'iobroker.socketio', 'latest' ] npm verb addNameTag registry:https://registry.npmjs.org/iobroker.socketio not in flight; fetching npm verb get https://registry.npmjs.org/iobroker.socketio not expired, no request npm verb addNamed "1.8.6" is a plain semver version for iobroker.socketio npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json not in flight; writing npm verb correctMkdir /home/svenilee/.npm correctMkdir not in flight; initializing npm verb afterAdd /home/svenilee/.npm/iobroker.socketio/1.8.6/package/package.json written npm verb correctMkdir /home/svenilee/.npm/_locks correctMkdir not in flight; initializing npm verb lock using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging npm verb unbuild node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb tar unpack /home/svenilee/.npm/iobroker.socketio/1.8.6/package.tgz npm verb tar unpacking to /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/.staging/iobroker.socketio-0c17e29c/node_modules npm info lifecycle iobroker.socketio@1.8.6~preinstall: iobroker.socketio@1.8.6 npm verb unbuild node_modules/iobroker.socketio npm info lifecycle iobroker.socketio@1.8.6~preuninstall: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~uninstall: iobroker.socketio@1.8.6 npm verb unbuild rmStuff iobroker.socketio@1.8.6 from /opt/iobroker/node_modules npm info lifecycle iobroker.socketio@1.8.6~postuninstall: iobroker.socketio@1.8.6 npm verb gentlyRm don't care about contents; nuking /opt/iobroker/node_modules/iobroker.socketio npm info linkStuff iobroker.socketio@1.8.6 npm verb linkBins iobroker.socketio@1.8.6 npm verb linkMans iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~install: iobroker.socketio@1.8.6 npm info lifecycle iobroker.socketio@1.8.6~postinstall: iobroker.socketio@1.8.6 npm verb unlock done using /home/svenilee/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging iobroker.core@0.1.0 /opt/iobroker └── (empty) ! npm verb exit [ 0, true ] npm ERR! code 1 svenilee@Gotham-City:/opt/iobroker$ !
    • BluefoxB Offline
      BluefoxB Offline
      Ich empfehle die neuste js-controller vom github zu installieren:
      cd /opt/iobroker
      iobroker stop
      npm i https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
      iobroker start
      Danach sollte js-controller alle fehlende Pakete selbst nachinstallieren.
        sveni_lee
        hallo Bluefox,
        hab ich Probiert:
        ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker stop
        [sudo] Passwort für svenilee:
        iobroker controller daemon is not running
        svenilee@Gotham-City:/opt/iobroker$ sudo npm i https://github.com/ioBroker/ioBroker.js … all/master --production
        npm WARN deprecated tar.gz@1.0.7: <emoji seq="26a0">⚠️</emoji> WARNING <emoji seq="26a0">⚠️</emoji> tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
        npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
        iobroker.js-controller@1.2.1 install /opt/iobroker/node_modules/iobroker.js-controller
        node iobroker.js setup first
        └── iobroker.js-controller@1.2.1
        svenilee@Gotham-City:/opt/iobroker$ sudo iobroker start
        Starting iobroker controller daemon...
        iobroker controller daemon started. PID: 13515 `
        log:
        ` > 2017-11-19 20:45:53.635 - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.1 js-controller starting
        2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City Copyright © 2014-2017 bluefox, 2014 hobbyquaker
        2017-11-19 20:45:53.640 - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
        2017-11-19 20:45:53.641 - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 fd2d:5cf3:5594:0:be5f:f4ff:fe7d:a73c fe80::be5f:f4ff:fe7d:a$
        2017-11-19 20:45:53.691 - ^[[32minfo^[[39m: host.Gotham-City inMem-states listening on port 9000
        2017-11-19 20:45:53.711 - ^[[32minfo^[[39m: host.Gotham-City inMem-objects listening on port 9001
        2017-11-19 20:45:53.718 - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
        2017-11-19 20:45:53.720 - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
        2017-11-19 20:45:53.725 - ^[[32minfo^[[39m: host.Gotham-City no instances found
        2017-11-19 20:45:53.746 - ^[[33mwarn^[[39m: host.Gotham-City multihost service started on 0.0.0.0:50005 `
        sollte laufen…
        ` > svenilee@Gotham-City:/opt/iobroker$ sudo iobroker status
        iobroker is running `
        ist aber unter port 8081 nicht erreichbar
        muß ich noch einen reinstall ausführen?
        • BluefoxB Offline
          BluefoxB Offline
          @sveni_lee:
          hallo Bluefox,
          hab ich Probiert:
          log:
          sollte laufen…
          muß ich noch einen reinstall ausführen? `
          Wo sind deine Einstellungen? Die datei /opt/iobroker-data/objects.json lehr oder default.
            sveni_lee
            ich würde sagen default…
            steht fast überall was drin
            • BluefoxB Offline
              BluefoxB Offline
              Ich wollte damit sagen, dass die Einstellungen weg sind.
                sveni_lee
                sorry… versteh nicht was Du meinst?
                die Datei ist doch da?
                oder Anders... wie bekomme ich diese wieder?
                  sveni_lee
                  so, ich habe jetzt eine Image-Sicherung vom Server genommen und den iobroker-ordner in
                  mein aktuelles Image kopiert. Danach funktioniert es schon einmal wieder…
                  Aber wie bekomme ich jetzt meinen aktuellen Datenstand dort rein, einfach den iobroker-data ordner wieder zurück
                  kopieren?
                  • DutchmanD Offline
                    DutchmanD Offline
                    Dutchman
                    @sveni_lee:
                    kopieren? `
                    Definiere Datenstand, history Daten oder?
                    Send from mobile device
                      sveni_lee
                      Objektpunkte, Skripte, Adaptereinstellungen
                      Edit: hat nicht funktioniert…
                      Gibt es einen Ordner in dem die Skripte abgelegt werden, do das ich wenigstens diese wieder herstellen kann?
