  4. Iobroker startet nicht mehr nach Ubuntu update
31 Beiträge 6 Kommentatoren 4.3k Aufrufe
    sveni_lee
    ich habe iobroker auf meinem Ubuntu-Server 16.04.02 installiert. gestern habe ich ein update gemacht und den Server neu gestartet. Seit dem startet iobroker nicht mehr..
    iobroker-log
    <code>2017-11-16 22:31:53.309  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
    2017-11-16 22:31:53.313  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
    2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v4.8.6
    2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxx.xxxx.x.x.xxxx
    2017-11-16 22:31:53.354  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
    2017-11-16 22:31:53.366  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
    2017-11-16 22:31:53.373  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
    2017-11-16 22:31:53.374  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
    2017-11-16 22:31:53.379  - ^[[32minfo^[[39m: host.Gotham-City no instances found
    2017-11-16 22:31:53.390  - ^[[31merror^[[39m: uncaught exception: logger is not defined
    2017-11-16 22:31:53.393  - ^[[31merror^[[39m: ReferenceError: logger is not defined
        at Object.decryptPhrase (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:77:9)
        at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:128:27
        at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
        at Timer.listOnTimeout (timers.js:92:15)
    2017-11-16 22:31:53.395  - ^[[32minfo^[[39m: host.Gotham-City terminated
    2017-11-16 22:31:53.404  - ^[[32minfo^[[39m: iobroker _restart
    2017-11-16 22:31:53.678  - ^[[32minfo^[[39m: iobroker Starting node restart.js
    2017-11-16 22:31:53.685  - ^[[32minfo^[[39m: iobroker exit 0
    2017-11-16 22:31:53.824  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
    2017-11-16 22:31:53.825  - ^[[32minfo^[[39m: host.Gotham-City terminated[/code]</code>
      @sveni_lee:
      gestern habe ich ein update gemacht `
      Wovon?
      @sveni_lee:
      iobroker-log `
      Was ist da ausgeixt?
      Ist das ein Multihost-System?
      Rainer
        sveni_lee
        hier mal ohne xxxx
        2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 + IPv6 Adressen
        Updates waren ganz normale systemupdates von Linux
        ja, es ist ein Multihost
          ich wollte die Werte nicht sehen, nur wissen was es ist.
          Habe die IPv6 Adressen unkenntlich gemacht.
          @sveni_lee:
          ja, es ist ein Multihost `
          deswegen wahrscheinlich auch die @sveni_lee:
          IP address is for states is 0.0.0.0 `
          die er jetzt anmeckert, Warum auch immer.
          Findet das Ganze etwa in einer virtuellen Maschine statt?
          Rainer
            sveni_lee
            Nein, keine virtuelle Umgebung…
            Nach dem Neustart lies sich iobroker nicht mehr starten...
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              @sveni_lee:
              Gesendet von iPhone mit Tapatalk Pro `
              Hat sich da eventuell ein node update mit eingeschlichen was die das System zermurkst hat?
              Dan könnte es helfen die reinstall.sh aus zu führen.
              Was sagt node -v und npm -v
              ~Dutch
              Send from mobile device
                sveni_lee
                svenilee@Gotham-City:~$ node -v
                v4.8.6
                svenilee@Gotham-City:~$ npm -v
                2.15.11
                wie kann ich die reinstall ausführen?
                svenilee@Gotham-City:/opt/iobroker$ sudo ./reinstall.sh
                sudo: unable to execute ./reinstall.sh: No such file or directory
                Aufgelegt
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  Dein npm ist recht alt.
                  Aktualisiere mal bitte (Hilfe gibt es hier ==> http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs)
                  Gruß,
                  Eric
                  Gesendet von iPad mit Tapatalk
                    sveni_lee
                    so, update habe ich gemacht… ist aber alles unverändert
                    svenilee@Gotham-City:/opt/iobroker$ node -v
                    v6.12.0
                    svenilee@Gotham-City:/opt/iobroker$ npm -v
                    3.10.10
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      Die Datei reinstall.sh ist aber in den Verzeichnis?
                        sveni_lee
                        ja, ist da…
                        svenilee@Gotham-City:/opt/iobroker$ ls -la
                        insgesamt 44
                        drwxrwxrwx  6 root     root     4096 Mai 21 10:49 .
                        drwxr-xr-x  4 root     root     4096 Sep 27 09:25 ..
                        drwxrwxrwx  2 root     root     4096 Mai 21 10:48 etc
                        -rwxrwxrwx  1 root     root      297 Mai 21 10:49 install.sh
                        -rwxrwxrwx  1 root     root       67 Mai 21 10:49 iobroker
                        drwxrwxrwx  3 root     root     4096 Sep 22 17:02 iobroker-data
                        -rwxrwxrwx  1 root     root       92 Nov 17 08:41 killall.sh
                        drwxrwxrwx  2 root     root     4096 Nov 17 19:17 log
                        drwxrwxrwx 31 svenilee svenilee 4096 Nov 17 08:41 node_modules
                        -rwxrwxrwx  1 root     root      116 Mai 21 10:49 package.json
                        -rwxrwxrwx  1 root     root      688 Nov 17 08:41 reinstall.sh
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Und wenn du in den Verzeichnis bist und das ./ Mal weck läst?
                          • paul53P Offline
                            Wie man an der Dateigröße (688 Byte) sieht, hat reinstall.sh DOS-Format (CR/LF anstelle LF) und muss erst in das http://forum.iobroker.net/viewtopic.php?f=17&t=8530&p=94147#p94110.
                              sveni_lee
                              funktioniert bei mir nicht…
                              nach
                              tr -d '\r' < /opt/iobroker/reinstall.sh > /opt/iobroker/reinstall.sh
                              ist die Größe null
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Evtl. weil Du die Datei überschreibst?
                                Mal mit einem neuen Ziel-Dateinamen probiert?
                                Gruß,
                                Eric
                                  sveni_lee
                                  Yeep… das wars
                                  Dann mach ich mal nen reinstall.
                                    sveni_lee
                                    ist nicht ganz sauber durchgelaufen…
                                    DONE iobroker.javascript
                                    npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
                                    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
                                    npm WARN prefer global npm@2.15.12 should be installed with -g
                                    > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/svenilee/.node-gyp/6.12.0"
                                    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
                                    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                                      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                      COPY Release/unix_dgram.node
                                    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                                    > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
                                    > node-gyp rebuild
                                    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp"
                                    make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird betreten
                                      CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
                                      SOLINK_MODULE(target) Release/obj.target/ursaNative.node
                                      COPY Release/ursaNative.node
                                    make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird verlassen
                                    npm ERR! code 1
                                    FAIL iobroker.socketio
                                    iobroker@1.0.0 /opt/iobroker
                                    └─┬ iobroker.tankerkoenig@1.0.4
                                      └─┬ xml2js@0.2.8
                                        └── sax@0.5.8
                                    DONE iobroker.tankerkoenig
                                    npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead.
                                    npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                                    npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                    npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
                                    npm WARN deprecated tough-cookie@2.2.2: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
                                    ./reinstall.sh: Zeile 34: Dateiende beim Suchen nach »"« erreicht.
                                    ./reinstall.sh: Zeile 37: Syntaxfehler: Unerwartetes Dateiende.
                                    • eric2905E Offline
                                      eric2905E Offline
                                      eric2905
                                      Ggf. das Original-reinstall.sh mal mit einem FTP vom Linux ziehen und die Datei mit einem "vernünftiges" Editor wieder umkonvertierten.
                                      Gruß,
                                      Eric
                                      • paul53P Offline
                                        Nimm diese Datei, nach dem Entfernen von .txt am Ende des Dateinamen.
                                        493_reinstall.sh.txt
                                          sveni_lee
                                          so, alles gemacht aber noch kein erfolg…
                                          2017-11-17 22:05:40.282  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
                                          2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
                                          2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
                                          2017-11-17 22:05:40.289  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxxx
                                          2017-11-17 22:05:40.337  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
                                          2017-11-17 22:05:40.358  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
                                          2017-11-17 22:05:40.365  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
                                          2017-11-17 22:05:40.367  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
                                          2017-11-17 22:05:40.371  - ^[[32minfo^[[39m: host.Gotham-City no instances found
                                          2017-11-17 22:05:40.381  - ^[[31merror^[[39m: uncaught exception: logger is not defined
                                          2017-11-17 22:05:40.383  - ^[[31merror^[[39m: ReferenceError: logger is not defined
                                              at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
                                              at ontimeout (timers.js:386:11)
                                              at tryOnTimeout (timers.js:250:5)
                                              at Timer.listOnTimeout (timers.js:214:5)
                                          2017-11-17 22:05:40.388  - ^[[32minfo^[[39m: host.Gotham-City terminated
                                          2017-11-17 22:05:40.396  - ^[[32minfo^[[39m: iobroker _restart
                                          2017-11-17 22:05:40.652  - ^[[32minfo^[[39m: iobroker Starting node restart.js
                                          2017-11-17 22:05:40.662  - ^[[32minfo^[[39m: iobroker exit 0
                                          2017-11-17 22:05:40.776  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
                                          2017-11-17 22:05:40.777  - ^[[32minfo^[[39m: host.Gotham-City terminated
                                          einen Fehler gab es doch beim reinstall
                                          iobroker.core@0.1.0 /opt/iobroker
                                          └── (empty)
                                          npm ERR! code 1
