  4. Iobroker startet nicht mehr nach Ubuntu update
    3.2k
31 Beiträge 6 Kommentatoren 3.9k Aufrufe
    sveni_lee
    ich habe iobroker auf meinem Ubuntu-Server 16.04.02 installiert. gestern habe ich ein update gemacht und den Server neu gestartet. Seit dem startet iobroker nicht mehr..
    iobroker-log
    <code>2017-11-16 22:31:53.309  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
    2017-11-16 22:31:53.313  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
    2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v4.8.6
    2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxx.xxxx.x.x.xxxx
    2017-11-16 22:31:53.354  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
    2017-11-16 22:31:53.366  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
    2017-11-16 22:31:53.373  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
    2017-11-16 22:31:53.374  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
    2017-11-16 22:31:53.379  - ^[[32minfo^[[39m: host.Gotham-City no instances found
    2017-11-16 22:31:53.390  - ^[[31merror^[[39m: uncaught exception: logger is not defined
    2017-11-16 22:31:53.393  - ^[[31merror^[[39m: ReferenceError: logger is not defined
        at Object.decryptPhrase (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:77:9)
        at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:128:27
        at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
        at Timer.listOnTimeout (timers.js:92:15)
    2017-11-16 22:31:53.395  - ^[[32minfo^[[39m: host.Gotham-City terminated
    2017-11-16 22:31:53.404  - ^[[32minfo^[[39m: iobroker _restart
    2017-11-16 22:31:53.678  - ^[[32minfo^[[39m: iobroker Starting node restart.js
    2017-11-16 22:31:53.685  - ^[[32minfo^[[39m: iobroker exit 0
    2017-11-16 22:31:53.824  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
    2017-11-16 22:31:53.825  - ^[[32minfo^[[39m: host.Gotham-City terminated[/code]</code>
    • HomoranH Offline
      HomoranH Offline
      @sveni_lee:
      gestern habe ich ein update gemacht `
      Wovon?
      @sveni_lee:
      iobroker-log `
      Was ist da ausgeixt?
      Ist das ein Multihost-System?
        sveni_lee
        hier mal ohne xxxx
        2017-11-16 22:31:53.314  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 + IPv6 Adressen
        Updates waren ganz normale systemupdates von Linux
        ja, es ist ein Multihost
        • HomoranH Offline
          HomoranH Offline
          ich wollte die Werte nicht sehen, nur wissen was es ist.
          Habe die IPv6 Adressen unkenntlich gemacht.
          @sveni_lee:
          ja, es ist ein Multihost `
          deswegen wahrscheinlich auch die @sveni_lee:
          IP address is for states is 0.0.0.0 `
          die er jetzt anmeckert, Warum auch immer.
          Findet das Ganze etwa in einer virtuellen Maschine statt?
            sveni_lee
            Nein, keine virtuelle Umgebung…
            Nach dem Neustart lies sich iobroker nicht mehr starten...
            • DutchmanD Offline
              DutchmanD Offline
              Dutchman
              @sveni_lee:
              Gesendet von iPhone mit Tapatalk Pro `
              Hat sich da eventuell ein node update mit eingeschlichen was die das System zermurkst hat?
              Dan könnte es helfen die reinstall.sh aus zu führen.
              Was sagt node -v und npm -v
              ~Dutch
              Send from mobile device
                sveni_lee
                svenilee@Gotham-City:~$ node -v
                v4.8.6
                svenilee@Gotham-City:~$ npm -v
                2.15.11
                wie kann ich die reinstall ausführen?
                svenilee@Gotham-City:/opt/iobroker$ sudo ./reinstall.sh
                sudo: unable to execute ./reinstall.sh: No such file or directory
                Aufgelegt
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  Dein npm ist recht alt.
                  Aktualisiere mal bitte (Hilfe gibt es hier ==> http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs)
                  Gruß,
                  Eric
                  Gesendet von iPad mit Tapatalk
                    sveni_lee
                    so, update habe ich gemacht… ist aber alles unverändert
                    svenilee@Gotham-City:/opt/iobroker$ node -v
                    v6.12.0
                    svenilee@Gotham-City:/opt/iobroker$ npm -v
                    3.10.10
                    • DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      Die Datei reinstall.sh ist aber in den Verzeichnis?
                        sveni_lee
                        ja, ist da…
                        svenilee@Gotham-City:/opt/iobroker$ ls -la
                        insgesamt 44
                        drwxrwxrwx  6 root     root     4096 Mai 21 10:49 .
                        drwxr-xr-x  4 root     root     4096 Sep 27 09:25 ..
                        drwxrwxrwx  2 root     root     4096 Mai 21 10:48 etc
                        -rwxrwxrwx  1 root     root      297 Mai 21 10:49 install.sh
                        -rwxrwxrwx  1 root     root       67 Mai 21 10:49 iobroker
                        drwxrwxrwx  3 root     root     4096 Sep 22 17:02 iobroker-data
                        -rwxrwxrwx  1 root     root       92 Nov 17 08:41 killall.sh
                        drwxrwxrwx  2 root     root     4096 Nov 17 19:17 log
                        drwxrwxrwx 31 svenilee svenilee 4096 Nov 17 08:41 node_modules
                        -rwxrwxrwx  1 root     root      116 Mai 21 10:49 package.json
                        -rwxrwxrwx  1 root     root      688 Nov 17 08:41 reinstall.sh
                        • DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          Und wenn du in den Verzeichnis bist und das ./ Mal weck läst?
                          • paul53P Offline
                            Wie man an der Dateigröße (688 Byte) sieht, hat reinstall.sh DOS-Format (CR/LF anstelle LF) und muss erst in das http://forum.iobroker.net/viewtopic.php?f=17&t=8530&p=94147#p94110.
                              sveni_lee
                              funktioniert bei mir nicht…
                              nach
                              tr -d '\r' < /opt/iobroker/reinstall.sh > /opt/iobroker/reinstall.sh
                              ist die Größe null
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Evtl. weil Du die Datei überschreibst?
                                Mal mit einem neuen Ziel-Dateinamen probiert?
                                Gruß,
                                Eric
                                  sveni_lee
                                  Yeep… das wars
                                  Dann mach ich mal nen reinstall.
                                    sveni_lee
                                    ist nicht ganz sauber durchgelaufen…
                                    DONE iobroker.javascript
                                    npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated and your application is vulnerable. Please use tar module instead: https://npmjs.com/tar
                                    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
                                    npm WARN prefer global npm@2.15.12 should be installed with -g
                                    > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                                    > node-gyp rebuild
                                    gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/svenilee/.node-gyp/6.12.0"
                                    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
                                    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird betreten
                                      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                      COPY Release/unix_dgram.node
                                    make: Verzeichnis „/opt/iobroker/node_modules/unix-dgram/build“ wird verlassen
                                    > ursa@0.9.4 install /opt/iobroker/node_modules/ursa
                                    > node-gyp rebuild
                                    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/ursa/.node-gyp"
                                    make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird betreten
                                      CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
                                      SOLINK_MODULE(target) Release/obj.target/ursaNative.node
                                      COPY Release/ursaNative.node
                                    make: Verzeichnis „/opt/iobroker/node_modules/ursa/build“ wird verlassen
                                    npm ERR! code 1
                                    FAIL iobroker.socketio
                                    iobroker@1.0.0 /opt/iobroker
                                    └─┬ iobroker.tankerkoenig@1.0.4
                                      └─┬ xml2js@0.2.8
                                        └── sax@0.5.8
                                    DONE iobroker.tankerkoenig
                                    npm WARN deprecated to-iso-string@0.0.2: to-iso-string has been deprecated, use @segment/to-iso-string instead.
                                    npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
                                    npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                    npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
                                    npm WARN deprecated tough-cookie@2.2.2: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
                                    ./reinstall.sh: Zeile 34: Dateiende beim Suchen nach »"« erreicht.
                                    ./reinstall.sh: Zeile 37: Syntaxfehler: Unerwartetes Dateiende.
                                    • eric2905E Offline
                                      eric2905E Offline
                                      eric2905
                                      Ggf. das Original-reinstall.sh mal mit einem FTP vom Linux ziehen und die Datei mit einem "vernünftiges" Editor wieder umkonvertierten.
                                      Gruß,
                                      Eric
                                      • paul53P Offline
                                        Nimm diese Datei, nach dem Entfernen von .txt am Ende des Dateinamen.
                                        493_reinstall.sh.txt
                                          sveni_lee
                                          so, alles gemacht aber noch kein erfolg…
                                          2017-11-17 22:05:40.282  - ^[[32minfo^[[39m: host.Gotham-City iobroker.js-controller version 1.2.0 js-controller starting
                                          2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City Copyright (c) 2014-2017 bluefox, hobbyquaker
                                          2017-11-17 22:05:40.288  - ^[[32minfo^[[39m: host.Gotham-City hostname: Gotham-City, node: v6.12.0
                                          2017-11-17 22:05:40.289  - ^[[32minfo^[[39m: host.Gotham-City ip addresses: 192.168.1.142 xxxxx
                                          2017-11-17 22:05:40.337  - ^[[32minfo^[[39m: host.Gotham-City  inMem-states listening on port 9000
                                          2017-11-17 22:05:40.358  - ^[[32minfo^[[39m: host.Gotham-City  inMem-objects listening on port 9001
                                          2017-11-17 22:05:40.365  - ^[[32minfo^[[39m: host.Gotham-City InMemoryDB connected
                                          2017-11-17 22:05:40.367  - ^[[33mwarn^[[39m: Host on this system is not possible, because IP address is for states is 0.0.0.0
                                          2017-11-17 22:05:40.371  - ^[[32minfo^[[39m: host.Gotham-City no instances found
                                          2017-11-17 22:05:40.381  - ^[[31merror^[[39m: uncaught exception: logger is not defined
                                          2017-11-17 22:05:40.383  - ^[[31merror^[[39m: ReferenceError: logger is not defined
                                              at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2102:21)
                                              at ontimeout (timers.js:386:11)
                                              at tryOnTimeout (timers.js:250:5)
                                              at Timer.listOnTimeout (timers.js:214:5)
                                          2017-11-17 22:05:40.388  - ^[[32minfo^[[39m: host.Gotham-City terminated
                                          2017-11-17 22:05:40.396  - ^[[32minfo^[[39m: iobroker _restart
                                          2017-11-17 22:05:40.652  - ^[[32minfo^[[39m: iobroker Starting node restart.js
                                          2017-11-17 22:05:40.662  - ^[[32minfo^[[39m: iobroker exit 0
                                          2017-11-17 22:05:40.776  - ^[[32minfo^[[39m: host.Gotham-City received SIGTERM
                                          2017-11-17 22:05:40.777  - ^[[32minfo^[[39m: host.Gotham-City terminated
                                          einen Fehler gab es doch beim reinstall
                                          iobroker.core@0.1.0 /opt/iobroker
                                          └── (empty)
                                          npm ERR! code 1
