Test Adapter Unifi Network
Ich habe deinen Adapter seit mehreren Monaten ohne Probleme wie ein Uhrwerk in Betrieb.
Läuft 100x besser, stabiler und zuverlässiger als der alte.
Allerdings taucht bei mir seit dem letzten UCG Update folgende Problematik auf:Ich erhalte folgende Fehlermeldung:
unifi-network.0 2026-07-11 08:25:29.666 error [NetworkApi._retrieve] Invalid login credentials given. Please check your login and password (code: 401, url: https://192.168.30.254/proxy/network/api/s/default/stat/sysinfo). unifi-network.0 2026-07-11 08:25:29.633 error [NetworkApi._retrieve] Invalid login credentials given. Please check your login and password (code: 401, url: https://192.168.30.254/proxy/network/v2/api/site/default/clients/history?includeUnifiDevices=true&withinHours=0). unifi-network.0 2026-07-11 08:25:29.595 error [NetworkApi._retrieve] Invalid login credentials given. Please check your login and password (code: 401, url: https://192.168.30.254/proxy/network/v2/api/site/default/device?separateUnmanaged=false&includeTrafficUsage=false). unifi-network.0 2026-07-11 08:25:29.564 error [NetworkApi.launchEventsWs] ws error: Unexpected server response: 401, stack: Error: Unexpected server response: 401 at ClientRequest.<anonymous> (/opt/iobroker/node_modules/ws/lib/websocket.js:918:7) at ClientRequest.emit (node:events:519:28) at HTTPParser.parserOnIncomingClient (node:_http_client:772:27) at HTTPParser.parserOnHeadersComplete (node:_http_common:122:17) at TLSSocket.socketOnData (node:_http_client:614:22) at TLSSocket.emit (node:events:519:28) at addChunk (node:internal/streams/readable:561:12) at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) at Readable.push (node:internal/streams/readable:392:5) at TLSWrap.onStreamRead (node:internal/stream_base_commons:189:23) unifi-network.0 2026-07-11 08:25:29.532 error [NetworkApi._retrieve] Invalid login credentials given. Please check your login and password (code: 401, url: https://192.168.30.254/proxy/network/api/s/default/stat/sysinfo).Diese FM wiederholt sich solange, bis ich einmal den Adapter neu starte, danach ist dann wieder für einen Tag Ruhe und es funktioniert alles wie gewünscht.
Am nächsten Tag das selbe Spiel von vorne... Steuerungsbefehle über den Adapter sind dann erst wieder nach Adapter Neustart möglich...
Ich habe keinerlei Credentials Einstellungen oder sonst etwas aktiv am Setup verändert.
Einzig das UCG hat ein Update auf 5.1.19 bzw. Network auf 10.4.57 durchgeführt.Hast du eine Idee wie ich das Thema lösen kann ?
Danke.
Beste Grüße
wollte jetzt auch mal den switch machen von uni zu unifi-network adapter. Leider bekomme ich ihn nicht zum Laufen.
Bin auf js controller 7.2.2 und node.js 22.23.1 auf Win11.
Adapter 1.5.0 aus der Repo lässt sich auch normal installieren aber dann kommt diese Fehlermeldung aktuell:
[onReady]: error: Error: Cannot find i18n directory in "C:\ioBroker\iobroker-data\node_modules\iobroker.unifi-network\admin\i18n", "C:\ioBroker\iobroker-data\node_modules\iobroker.unifi-network\admin\lib\i18n", stack: Error: Cannot find i18n directory in "C:\ioBroker\iobroker-data\node_modules\iobroker.unifi-network\admin\i18n", "C:\ioBroker\iobroker-data\node_modules\iobroker.unifi-network\admin\lib\i18n" at Module.init (file:///C:/ioBroker/node_modules/iobroker.unifi-network/node_modules/@iobroker/adapter-core/build/esm/i18n.js:33:15) at async UnifiNetwork.onReady (file:///C:/ioBroker/node_modules/iobroker.unifi-network/build/main.js:81:13)Hab einen local only -benutzer mit admin Rechten für iobroker.
Kann ich denn wie beim alten uni Adapter auch den PoE Staus ändern also gezielt PoE Aus und anschalten um zum AP Stromlos zu machen?
Moin, beim starten kommt immer diese Meldung, sonst funktioniert alles
unifi-network.0 2026-07-13 15:34:59.644 error [downloadImage]: API endpoint access error: 302 - Found -
Pino72 sagte:
Hab es selber gefixt, bei mir gibt es keinen Ordner node_modules im Ordner iobroker-data...der ist direkt im Hauptordner ioBroker.
Leider fehlt mir bei diesem Adapter die Möglichkeit die PoE Ports stromlos zu machen, gibt es eine Möglichkeit das zu implementieren? Ansonsten kommen die Daten sehr schnell an bei Änderungen, was zb. bei is_online super ist für die Anwesenheitserfassung.
