  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    Nach dem Update und dem Upgrade Befehl kam das:
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
    Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
    Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
    Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
    Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
    dogfight76@iobroker:~ $ sudo apt upgrade
    Reading package lists... Done
    Building dependency tree... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
    Use 'sudo apt autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    #41
    @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
    sudo apt autoremove
    Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
    iob update
    iob upgrade all
    iob stop
    iob upgrade self
    iob start
    iob update
    iob upgrade all
    • dogfight76D Offline
      dogfight76D Offline
      dogfight76
      #42
      Bin dabei........
        dogfight76D Offline
        dogfight76
        #43
        Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
        dogfight76@iobroker:~ $ iob update
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
        Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
        Adapter    "cloud"        : 5.0.1    , installed 5.0.1
        Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
        Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
        Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
        Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
        Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        dogfight76@iobroker:~ $ iob upgrade all
        Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
        This upgrade of "javascript" will at least introduce the following changes:
        -> 8.8.3:
        Fixed object selector in rules
        -> 8.8.2:
        updated dependencies
        -> 8.8.1:
        -> 8.8.0:
        Added option to register notifications via scripts
        Fixed sendTo block with empty name list
        -> 8.7.7:
        Fixed import scripts dialog
        Allow to remove all custom packages (empty list)
        -> 8.7.6:
        fix error with subpath imports in scripts
        -> 8.7.5:
        Fixed right aligned script names when using multiple instances
        added fallback for all require calls in scripts
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
        Update javascript from @7.1.4 to @8.8.3
        NPM version: 10.8.2
        Installing iobroker.javascript@8.8.3... (System call)
        added 2 packages, removed 25 packages, and changed 10 packages in 1m
        197 packages are looking for funding
          run `npm fund` for details
        Update "system.adapter.javascript.0"
        upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
        upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
        upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
        upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
        upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
        upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
        upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
        upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
        upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
        upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
        upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
        upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
        upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
        upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
        upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
        upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
        upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
        upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
        upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
        upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
        upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
        upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
        upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
        upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
        upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
        upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
        upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
        upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
        upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
        upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
        upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
        upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
        upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
        upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
        upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
        upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
        upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
        upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
        upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
        upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
        upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
        upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
        upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
        upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
        upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
        upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
        upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
        upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
        upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
        upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
        upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
        This upgrade of "hm-rega" will at least introduce the following changes:
        -> 5.1.0:
        added notification if devices are low on battery
        -> 5.0.0:
        required node 18
        -> 4.0.0:
        required node 16 due to adapter-core 3.x.x
        removed deprecated package - `request`
        -> 3.0.47:
        Updated packages
        -> 3.0.46:
        fix for controller v5 (closes #368)
        -> 3.0.44:
        compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
        also sync enums for maintenance channel of rfd devices (closes #320)
        -> 3.0.43:
        if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
        Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
        Update hm-rega from @3.0.40 to @5.1.0
        NPM version: 10.8.2
        Installing iobroker.hm-rega@5.1.0... (System call)
        added 1 package, removed 1 package, and changed 1 package in 10s
        Update "system.adapter.hm-rega.0"
        upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
        upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
        upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
        upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
        This upgrade of "fritzdect" will at least introduce the following changes:
        -> 2.5.11:
        update devDeps, linting error correction
        -> 2.5.10:
        more loggimg for issue #500 of restart loop
        -> 2.5.9:
        new message box, correction for statistics, password needs to be reentered in versions >2.5.4
        Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
        Update fritzdect from @2.2.6 to @2.5.11
        NPM version: 10.8.2
        Installing iobroker.fritzdect@2.5.11... (System call)
        added 181 packages, removed 8 packages, and changed 9 packages in 29s
        208 packages are looking for funding
        Adapter "system.adapter.vis.0" restarted.
        Update "system.adapter.fritzdect.0"
        upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
        upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
        upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
        upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
        upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
        upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
        This upgrade of "discovery" will at least introduce the following changes:
        -> 5.0.0:
        Packages updated
        Minimum node.js version is 18.x
        Updated licenses for knx and jarvis
        -> 4.5.0:
        Added Air-Q
        -> 4.4.0:
        Added WLED
        Added LaMetric
        Removed net-tools from proposals
        -> 4.3.0:
        Replaced vis with vis-2
        -> 4.2.0:
        Changed detection of myvbus and resol
        -> 4.1.0:
        Added detection of myvbus and resol
        -> 4.0.0:
        Added: frontier_silicon, sma-em, and speedwire
        Dropped node14 support, refactoring
        Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
        Update discovery from @3.1.0 to @5.0.0
        NPM version: 10.8.2
        Installing iobroker.discovery@5.0.0... (System call)
        added 2 packages, removed 1 package, and changed 19 packages in 13s
        210 packages are looking for funding
        Update "system.adapter.discovery.0"
        upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
        upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
        upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
        upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
        upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
        upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
        upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
        This upgrade of "chromecast" will introduce the following changes:
        -> 3.4.1:
        migrated binary state to file
        -> 3.4.0:
        Support for devices located in different subnets has been added. [#154, #160]
        Dependencies have been updated
        -> 3.3.0:
        Adapter requires node.js 18 and js-controller >= 5 now
        -> 3.2.0:
        changed: Testing has been updated to use node.js 16/18/20
        changed: Dependencies have been updated
        YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
        AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
        Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
        -> 3.1.0:
        Refactoring done
        Removed dependency with nettools
        Added support of web port other than 8082
        -> 3.0.3:
        Breaking change: Object IDs are now mac addresses instead names
        set album name as song if provided in icy-name
        Make compatible with Node.js 16+
        Add Sentry for crash reporting
        Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
        Update chromecast from @2.3.1 to @3.4.1
        NPM version: 10.8.2
        Installing iobroker.chromecast@3.4.1... (System call)
        added 3 packages, removed 232 packages, and changed 1 package in 12s
        207 packages are looking for funding
        Update "system.adapter.chromecast.0"
        upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
        upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
        upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
        upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
          -> 8.8.3:
          -> 8.8.2:
          -> 8.8.1:
          -> 8.8.0:
          -> 8.7.7:
          -> 8.7.6:
          -> 8.7.5:
          NPM version: 10.8.2
          -> 5.1.0:
          -> 5.0.0:
          required node 18
          -> 4.0.0:
          -> 3.0.47:
          Updated packages
          -> 3.0.46:
          -> 3.0.44:
          -> 3.0.43:
          NPM version: 10.8.2
          -> 2.5.11:
          -> 2.5.10:
          -> 2.5.9:
          NPM version: 10.8.2
          -> 5.0.0:
          Packages updated
          -> 4.5.0:
          Added Air-Q
          -> 4.4.0:
          Added WLED
          Added LaMetric
          -> 4.3.0:
          -> 4.2.0:
          -> 4.1.0:
          -> 4.0.0:
          NPM version: 10.8.2
          -> 3.4.1:
          -> 3.4.0:
          -> 3.3.0:
          -> 3.2.0:
          -> 3.1.0:
          Refactoring done
          -> 3.0.3:
          NPM version: 10.8.2
          HomoranH Offline
          HomoranH Offline
          #44
          hast du den noch nicht aktualisiert?
            -> 8.8.3:
            -> 8.8.2:
            -> 8.8.1:
            -> 8.8.0:
            -> 8.7.7:
            -> 8.7.6:
            -> 8.7.5:
            NPM version: 10.8.2
            -> 5.1.0:
            -> 5.0.0:
            required node 18
            -> 4.0.0:
            -> 3.0.47:
            Updated packages
            -> 3.0.46:
            -> 3.0.44:
            -> 3.0.43:
            NPM version: 10.8.2
            -> 2.5.11:
            -> 2.5.10:
            -> 2.5.9:
            NPM version: 10.8.2
            -> 5.0.0:
            Packages updated
            -> 4.5.0:
            Added Air-Q
            -> 4.4.0:
            Added WLED
            Added LaMetric
            -> 4.3.0:
            -> 4.2.0:
            -> 4.1.0:
            -> 4.0.0:
            NPM version: 10.8.2
            -> 3.4.1:
            -> 3.4.0:
            -> 3.3.0:
            -> 3.2.0:
            -> 3.1.0:
            Refactoring done
            -> 3.0.3:
            NPM version: 10.8.2
            #45
            @dogfight76
            Gib die Befehle in der Abfolge wie oben gepostet ein.
            Fehlermeldungen sind jetzt irrelevant und erwartet.
            dogfight76D 2 Antworten Letzte Antwort
              dogfight76D Offline
              dogfight76
              #46
              Damit fing das Problem doch an........
              Ich wollte im ioBroker das Update des js-controller anstoßen
                @dogfight76
                dogfight76D Offline
                dogfight76D Offline
                dogfight76
                #47
                @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                @dogfight76
                Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                Arbeite die Befehlsliste gerade ab
                  @dogfight76
                  dogfight76D Offline
                  dogfight76D Offline
                  dogfight76
                  #48
                  @thomas-braun Fertig. Ohne Fehlermeldung
                    HomoranH Offline
                    HomoranH Offline
                    #49
                    da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                      #50
                      @dogfight76
                      Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                      iob diag
                      anschauen.
                        dogfight76D Offline
                        dogfight76
                        #51
                        Hier das Ergebnis:
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                           Static hostname: iobroker
                                 Icon name: computer
                          Operating System: Debian GNU/Linux 11 (bullseye)
                                    Kernel: Linux 5.15.61-v8+
                              Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 4 Model B Rev 1.2
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        This system needs to be REBOOTED!
                        *** TIME AND TIMEZONES ***
                                       Local time: Sun 2024-11-03 15:20:43 CET
                                   Universal time: Sun 2024-11-03 14:20:43 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        dogfight76
                        HOME=/home/dogfight76
                        GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                        iobroker
                        HOME=/home/iobroker
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                        Swap:            99M        2.0M         97M
                        Total:          3.9G        804M        215M
                        Active iob-Instances:   11
                                 3794 M total memory
                                  802 M used memory
                                  934 M active memory
                                 2452 M inactive memory
                                  117 M free memory
                                  178 M buffer memory
                                 2696 M swap cache
                                   99 M total swap
                                    2 M used swap
                                   97 M free swap
                        top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                        Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                        MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  8.6G   48G  16% /
                        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                        tmpfs          tmpfs     759M  1.2M  758M   1% /run
                        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                        [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                        [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                        Show mounted filesystems:
                        TARGET  SOURCE         FSTYPE OPTIONS
                        /       /dev/mmcblk0p2 ext4   rw,noatime
                        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        2.0G    /var/
                        1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                        1.1G    /var/log
                        634M    /var/cache
                        Archived and active journals take up 1.0G in the file system.
                        /opt/iobroker/backups:
                        91M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        815M    /opt/iobroker/iobroker-data/
                        761M    /opt/iobroker/iobroker-data/files
                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        13M     /opt/iobroker/iobroker-data/objects.jsonl
                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.18.0
                        /usr/bin/node           v20.18.0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.3
                        nodejs:
                          Installed: 20.18.0-1nodesource1
                          Candidate: 20.18.0-1nodesource1
                          Version table:
                         *** 20.18.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                100 /var/lib/dpkg/status
                             20.17.0-1nodesource1 1001
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             12.22.12~dfsg-1~deb11u5 500
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                             12.22.12~dfsg-1~deb11u4 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                        Core adapters versions
                        js-controller:  6.0.11
                        admin:          7.1.5
                        javascript:     8.8.3
                        nodejs modules from github:     2
                        +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                        Adapter State
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                          system.adapter.history.0                : history               : iobroker                                 - disabled
                          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                          system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Instances
                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                        Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                        Controller "js-controller": 6.0.11   , installed 6.0.11
                        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                        Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                        Objects and States
                        Objects:        1050
                        States:         801
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                        tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                        udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                        udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                        udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                        udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                        2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                        2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                        2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                        2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                        iob diag has finished.
                        Press any key for a summary
                          Hier das Ergebnis:
                          ```bash
                          Script v.2024-10-19
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          dogfight76
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M        2.0M         97M
                                   3794 M total memory
                                    802 M used memory
                                    934 M active memory
                                    117 M free memory
                                    178 M buffer memory
                                   2696 M swap cache
                                     99 M total swap
                                      2 M used swap
                                     97 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.0G    /var/
                          1.1G    /var/log
                          634M    /var/cache
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.1.5
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        1050
                          States:         801
                          Pending Updates: 0
                          #52
                            dogfight76D Offline
                            dogfight76
                            #53
                            Reboot isr durch
                              Reboot isr durch
                              #54
                              @dogfight76
                              Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
                              Mit
                              muss dir aber wer anders weiterhelfen.
                              Ich würde vorschlagen, in einem separaten Thread.
                                Reboot isr durch
                                #55
                                @dogfight76
                                influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
                                  dogfight76D Offline
                                  dogfight76
                                  #56
                                  InfluxDB war mal gedacht für die erweiterte grafische Darstellung/Auswertung. Das wird nur dafür benötigt, oder ?
                                  Dann kann das ja deaktiviert werden. Ist das eine Instanz ?
                                  Und dann weiter ?
                                    Und dann weiter ?
                                    #57
                                    Jein, das ist eine Datenbank, für die es einen iobroker.adapter gibt.
                                    Offenbar läuft die eigentliche Datenbank aber auch gar nicht, weswegen der Adapter da ins Leere schaut..
                                    Ob du das brauchst musst du selber entscheiden.
                                      dogfight76D Offline
                                      dogfight76
                                      #58
                                      Ok, jetzt noch das Update beovr das aktuelle OS-Lite (64bit) auf die microSD-Karte kommt ?
                                        #59
                                        Welches Update? Das Betriebssystem ist aktuell, ebenso wie der ioBroker.
                                        Mit der Basis kannst du jetzt umziehen.
                                          dogfight76D Offline
                                          dogfight76
                                          #60
                                          Sorry, natürlich war das Backup gemeint.
                                          Das muss ich dann ja noch von der SD-Karte auf meinen PC ziehen, um das dann wieder einzuspielen. Oder ?
