  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    Damit fing das Problem doch an........
    Ich wollte im ioBroker das Update des js-controller anstoßen
    @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
    da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
      @thomas-braun Fertig. Ohne Fehlermeldung
      @dogfight76
      Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
      iob diag
      anschauen.
      • dogfight76D Offline
        dogfight76D Offline
        dogfight76
        Hier das Ergebnis:
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.15.61-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        This system needs to be REBOOTED!
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2024-11-03 15:20:43 CET
                   Universal time: Sun 2024-11-03 14:20:43 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        dogfight76
        HOME=/home/dogfight76
        GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
        Swap:            99M        2.0M         97M
        Total:          3.9G        804M        215M
        Active iob-Instances:   11
                 3794 M total memory
                  802 M used memory
                  934 M active memory
                 2452 M inactive memory
                  117 M free memory
                  178 M buffer memory
                 2696 M swap cache
                   99 M total swap
                    2 M used swap
                   97 M free swap
        top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
        Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
        MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       59G  8.6G   48G  16% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
        [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.0G    /var/
        1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
        1.1G    /var/log
        634M    /var/cache
        Archived and active journals take up 1.0G in the file system.
        /opt/iobroker/backups:
        91M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        815M    /opt/iobroker/iobroker-data/
        761M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        13M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.0-1nodesource1
          Version table:
         *** 20.18.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
        Core adapters versions
        js-controller:  6.0.11
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     2
        +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
        +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
        Adapter State
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
          system.adapter.history.0                : history               : iobroker                                 - disabled
          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
          system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.5    , installed 7.1.5
        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
        Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects:        1050
        States:         801
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
        tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
        udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
        udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
        udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
        2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
        2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
        2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
        2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
        iob diag has finished.
        Press any key for a summary
          Hier das Ergebnis:
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          dogfight76
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M        2.0M         97M
                   3794 M total memory
                    802 M used memory
                    934 M active memory
                    117 M free memory
                    178 M buffer memory
                   2696 M swap cache
                     99 M total swap
                      2 M used swap
                     97 M free swap
          *** FILESYSTEM ***
          /var:
          2.0G    /var/
          1.1G    /var/log
          634M    /var/cache
          USB-Devices by-id:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.1.5
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        1050
          States:         801
          Pending Updates: 0
            dogfight76D Offline
            dogfight76
            Reboot isr durch
              Reboot isr durch
              @dogfight76
              Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
              Mit
              muss dir aber wer anders weiterhelfen.
              Ich würde vorschlagen, in einem separaten Thread.
                Reboot isr durch
                @dogfight76
                influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
                  dogfight76D Offline
                  dogfight76
                  InfluxDB war mal gedacht für die erweiterte grafische Darstellung/Auswertung. Das wird nur dafür benötigt, oder ?
                  Dann kann das ja deaktiviert werden. Ist das eine Instanz ?
                  Und dann weiter ?
                    Und dann weiter ?
                    Jein, das ist eine Datenbank, für die es einen iobroker.adapter gibt.
                    Offenbar läuft die eigentliche Datenbank aber auch gar nicht, weswegen der Adapter da ins Leere schaut..
                    Ob du das brauchst musst du selber entscheiden.
                      dogfight76D Offline
                      dogfight76
                      Ok, jetzt noch das Update beovr das aktuelle OS-Lite (64bit) auf die microSD-Karte kommt ?
                        Welches Update? Das Betriebssystem ist aktuell, ebenso wie der ioBroker.
                        Mit der Basis kannst du jetzt umziehen.
                          dogfight76D Offline
                          dogfight76
                          Sorry, natürlich war das Backup gemeint.
                          Das muss ich dann ja noch von der SD-Karte auf meinen PC ziehen, um das dann wieder einzuspielen. Oder ?
                            Ich würde eine der anderen Möglichkeiten das Backup zu verstauen vorziehen.
                            Zur Not tut es aber auch das.
                              dogfight76D Offline
                              dogfight76
                              Und wie ?
                              Das Backup-Tool aus ioBroker nutzen ?
                                Und wie ?
                                Das würde ich ohnehin nutzen.
                                  dogfight76D Offline
                                  dogfight76
                                  Ok,das Backup habe ich dann auf meinem PC gespeichert. Die Datei Namens:
                                  iobroker_2024_11_03-15_52_56_backupiobroker.tar
                                  Dann jetzt nach der Anleitung von deinem Link erstmal das OS auf eine 128GB microSD schreiben. (die lag hier noch so rum)
                                  Aber das mache ich nächstes WE
                                  Vielen dank !!!!!!!
