  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D Offline
    dogfight76D Offline
    dogfight76
    Bin dabei........
      dogfight76D Offline
      dogfight76
      Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
      dogfight76@iobroker:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 7.1.5    , installed 7.1.5
      Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
      Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
      Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
      Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
      Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
      Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
      Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
      Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      dogfight76@iobroker:~ $ iob upgrade all
      Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
      This upgrade of "javascript" will at least introduce the following changes:
      -> 8.8.3:
      Fixed object selector in rules
      -> 8.8.2:
      updated dependencies
      -> 8.8.1:
      -> 8.8.0:
      Added option to register notifications via scripts
      Fixed sendTo block with empty name list
      -> 8.7.7:
      Fixed import scripts dialog
      Allow to remove all custom packages (empty list)
      -> 8.7.6:
      fix error with subpath imports in scripts
      -> 8.7.5:
      Fixed right aligned script names when using multiple instances
      added fallback for all require calls in scripts
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
      Update javascript from @7.1.4 to @8.8.3
      NPM version: 10.8.2
      Installing iobroker.javascript@8.8.3... (System call)
      added 2 packages, removed 25 packages, and changed 10 packages in 1m
      197 packages are looking for funding
        run `npm fund` for details
      Update "system.adapter.javascript.0"
      upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
      upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
      upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
      upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
      upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
      upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
      upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
      upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
      upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
      upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
      upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
      upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
      upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
      upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
      upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
      upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
      upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
      upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
      upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
      upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
      upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
      upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
      This upgrade of "hm-rega" will at least introduce the following changes:
      -> 5.1.0:
      added notification if devices are low on battery
      -> 5.0.0:
      required node 18
      -> 4.0.0:
      required node 16 due to adapter-core 3.x.x
      removed deprecated package - `request`
      -> 3.0.47:
      Updated packages
      -> 3.0.46:
      fix for controller v5 (closes #368)
      -> 3.0.44:
      compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
      also sync enums for maintenance channel of rfd devices (closes #320)
      -> 3.0.43:
      if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
      Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
      Update hm-rega from @3.0.40 to @5.1.0
      NPM version: 10.8.2
      Installing iobroker.hm-rega@5.1.0... (System call)
      added 1 package, removed 1 package, and changed 1 package in 10s
      Update "system.adapter.hm-rega.0"
      upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
      upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
      upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
      upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
      This upgrade of "fritzdect" will at least introduce the following changes:
      -> 2.5.11:
      update devDeps, linting error correction
      -> 2.5.10:
      more loggimg for issue #500 of restart loop
      -> 2.5.9:
      new message box, correction for statistics, password needs to be reentered in versions >2.5.4
      Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
      Update fritzdect from @2.2.6 to @2.5.11
      NPM version: 10.8.2
      Installing iobroker.fritzdect@2.5.11... (System call)
      added 181 packages, removed 8 packages, and changed 9 packages in 29s
      208 packages are looking for funding
      Adapter "system.adapter.vis.0" restarted.
      Update "system.adapter.fritzdect.0"
      upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
      upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
      upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
      upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
      upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
      This upgrade of "discovery" will at least introduce the following changes:
      -> 5.0.0:
      Packages updated
      Minimum node.js version is 18.x
      Updated licenses for knx and jarvis
      -> 4.5.0:
      Added Air-Q
      -> 4.4.0:
      Added WLED
      Added LaMetric
      Removed net-tools from proposals
      -> 4.3.0:
      Replaced vis with vis-2
      -> 4.2.0:
      Changed detection of myvbus and resol
      -> 4.1.0:
      Added detection of myvbus and resol
      -> 4.0.0:
      Added: frontier_silicon, sma-em, and speedwire
      Dropped node14 support, refactoring
      Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
      Update discovery from @3.1.0 to @5.0.0
      NPM version: 10.8.2
      Installing iobroker.discovery@5.0.0... (System call)
      added 2 packages, removed 1 package, and changed 19 packages in 13s
      210 packages are looking for funding
      Update "system.adapter.discovery.0"
      upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
      upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
      upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
      upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
      upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      This upgrade of "chromecast" will introduce the following changes:
      -> 3.4.1:
      migrated binary state to file
      -> 3.4.0:
      Support for devices located in different subnets has been added. [#154, #160]
      Dependencies have been updated
      -> 3.3.0:
      Adapter requires node.js 18 and js-controller >= 5 now
      -> 3.2.0:
      changed: Testing has been updated to use node.js 16/18/20
      changed: Dependencies have been updated
      YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
      AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
      Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
      -> 3.1.0:
      Refactoring done
      Removed dependency with nettools
      Added support of web port other than 8082
      -> 3.0.3:
      Breaking change: Object IDs are now mac addresses instead names
      set album name as song if provided in icy-name
      Make compatible with Node.js 16+
      Add Sentry for crash reporting
      Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
      Update chromecast from @2.3.1 to @3.4.1
      NPM version: 10.8.2
      Installing iobroker.chromecast@3.4.1... (System call)
      added 3 packages, removed 232 packages, and changed 1 package in 12s
      207 packages are looking for funding
      Update "system.adapter.chromecast.0"
      upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
      upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
      upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
      upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
      • dogfight76D dogfight76
        -> 8.8.3:
        -> 8.8.2:
        -> 8.8.1:
        -> 8.8.0:
        -> 8.7.7:
        -> 8.7.6:
        -> 8.7.5:
        NPM version: 10.8.2
        -> 5.1.0:
        -> 5.0.0:
        required node 18
        -> 4.0.0:
        -> 3.0.47:
        Updated packages
        -> 3.0.46:
        -> 3.0.44:
        -> 3.0.43:
        NPM version: 10.8.2
        -> 2.5.11:
        -> 2.5.10:
        -> 2.5.9:
        NPM version: 10.8.2
        -> 5.0.0:
        Packages updated
        -> 4.5.0:
        Added Air-Q
        -> 4.4.0:
        Added WLED
        Added LaMetric
        -> 4.3.0:
        -> 4.2.0:
        -> 4.1.0:
        -> 4.0.0:
        NPM version: 10.8.2
        -> 3.4.1:
        -> 3.4.0:
        -> 3.3.0:
        -> 3.2.0:
        -> 3.1.0:
        Refactoring done
        -> 3.0.3:
        NPM version: 10.8.2
        @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
        hast du den noch nicht aktualisiert?
          -> 8.8.3:
          -> 8.8.2:
          -> 8.8.1:
          -> 8.8.0:
          -> 8.7.7:
          -> 8.7.6:
          -> 8.7.5:
          NPM version: 10.8.2
          -> 5.1.0:
          -> 5.0.0:
          required node 18
          -> 4.0.0:
          -> 3.0.47:
          Updated packages
          -> 3.0.46:
          -> 3.0.44:
          -> 3.0.43:
          NPM version: 10.8.2
          -> 2.5.11:
          -> 2.5.10:
          -> 2.5.9:
          NPM version: 10.8.2
          -> 5.0.0:
          Packages updated
          -> 4.5.0:
          Added Air-Q
          -> 4.4.0:
          Added WLED
          Added LaMetric
          -> 4.3.0:
          -> 4.2.0:
          -> 4.1.0:
          -> 4.0.0:
          NPM version: 10.8.2
          -> 3.4.1:
          -> 3.4.0:
          -> 3.3.0:
          -> 3.2.0:
          -> 3.1.0:
          Refactoring done
          -> 3.0.3:
          NPM version: 10.8.2
          @dogfight76
          Gib die Befehle in der Abfolge wie oben gepostet ein.
          Fehlermeldungen sind jetzt irrelevant und erwartet.
          dogfight76D 2 Antworten Letzte Antwort
            dogfight76D Offline
            dogfight76
            Damit fing das Problem doch an........
            Ich wollte im ioBroker das Update des js-controller anstoßen
              @dogfight76
              dogfight76D Offline
              dogfight76D Offline
              dogfight76
              @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
              @dogfight76
              Hatte nicht gesehen das die letzte Antwort nicht von dir war.
              Arbeite die Befehlsliste gerade ab
                @dogfight76
                dogfight76D Offline
                dogfight76D Offline
                dogfight76
                @thomas-braun Fertig. Ohne Fehlermeldung
                  da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                    @dogfight76
                    Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                    iob diag
                    anschauen.
                      dogfight76D Offline
                      dogfight76
                      Hier das Ergebnis:
                      ```bash
                      Script v.2024-10-19
                      *** BASE SYSTEM ***
                         Static hostname: iobroker
                               Icon name: computer
                        Operating System: Debian GNU/Linux 11 (bullseye)
                                  Kernel: Linux 5.15.61-v8+
                            Architecture: arm64
                      OS is similar to:
                      Model           : Raspberry Pi 4 Model B Rev 1.2
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      This system needs to be REBOOTED!
                      *** TIME AND TIMEZONES ***
                                     Local time: Sun 2024-11-03 15:20:43 CET
                                 Universal time: Sun 2024-11-03 14:20:43 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      dogfight76
                      HOME=/home/dogfight76
                      GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                      Swap:            99M        2.0M         97M
                      Total:          3.9G        804M        215M
                      Active iob-Instances:   11
                               3794 M total memory
                                802 M used memory
                                934 M active memory
                               2452 M inactive memory
                                117 M free memory
                                178 M buffer memory
                               2696 M swap cache
                                 99 M total swap
                                  2 M used swap
                                 97 M free swap
                      top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                      Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                      MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G  8.6G   48G  16% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     759M  1.2M  758M   1% /run
                      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                      [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                      Show mounted filesystems:
                      TARGET  SOURCE         FSTYPE OPTIONS
                      /       /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      2.0G    /var/
                      1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                      1.1G    /var/log
                      634M    /var/cache
                      Archived and active journals take up 1.0G in the file system.
                      /opt/iobroker/backups:
                      91M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      815M    /opt/iobroker/iobroker-data/
                      761M    /opt/iobroker/iobroker-data/files
                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.18.0
                      /usr/bin/node           v20.18.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.29.3
                      nodejs:
                        Installed: 20.18.0-1nodesource1
                        Candidate: 20.18.0-1nodesource1
                        Version table:
                       *** 20.18.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                           20.17.0-1nodesource1 1001
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           12.22.12~dfsg-1~deb11u5 500
                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                           12.22.12~dfsg-1~deb11u4 500
                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                      Core adapters versions
                      js-controller:  6.0.11
                      admin:          7.1.5
                      javascript:     8.8.3
                      nodejs modules from github:     2
                      +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                      Adapter State
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                        system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                        system.adapter.history.0                : history               : iobroker                                 - disabled
                        system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                        system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                        system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Instances
                      Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                      Controller "js-controller": 6.0.11   , installed 6.0.11
                      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                      Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                      Objects and States
                      Objects:        1050
                      States:         801
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                      tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                      udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                      udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                      udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                      2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                      2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                      2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                      2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                      iob diag has finished.
                      Press any key for a summary
                        Hier das Ergebnis:
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        dogfight76
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M        2.0M         97M
                                 3794 M total memory
                                  802 M used memory
                                  934 M active memory
                                  117 M free memory
                                  178 M buffer memory
                                 2696 M swap cache
                                   99 M total swap
                                    2 M used swap
                                   97 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.0G    /var/
                        1.1G    /var/log
                        634M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.1.5
                        javascript:     8.8.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        1050
                        States:         801
                        Pending Updates: 0
                          dogfight76D Offline
                          dogfight76
                          Reboot isr durch
                            Reboot isr durch
                            @dogfight76
                            Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
                            Mit
                            muss dir aber wer anders weiterhelfen.
                            Ich würde vorschlagen, in einem separaten Thread.
                              Reboot isr durch
                              @dogfight76
                              influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
                                dogfight76D Offline
                                dogfight76
                                InfluxDB war mal gedacht für die erweiterte grafische Darstellung/Auswertung. Das wird nur dafür benötigt, oder ?
                                Dann kann das ja deaktiviert werden. Ist das eine Instanz ?
                                Und dann weiter ?
                                  Und dann weiter ?
                                  Jein, das ist eine Datenbank, für die es einen iobroker.adapter gibt.
                                  Offenbar läuft die eigentliche Datenbank aber auch gar nicht, weswegen der Adapter da ins Leere schaut..
                                  Ob du das brauchst musst du selber entscheiden.
                                    dogfight76D Offline
                                    dogfight76
                                    Ok, jetzt noch das Update beovr das aktuelle OS-Lite (64bit) auf die microSD-Karte kommt ?
                                      Welches Update? Das Betriebssystem ist aktuell, ebenso wie der ioBroker.
                                      Mit der Basis kannst du jetzt umziehen.
                                        dogfight76D Offline
                                        dogfight76
                                        Sorry, natürlich war das Backup gemeint.
                                        Das muss ich dann ja noch von der SD-Karte auf meinen PC ziehen, um das dann wieder einzuspielen. Oder ?
                                          Ich würde eine der anderen Möglichkeiten das Backup zu verstauen vorziehen.
                                          Zur Not tut es aber auch das.
