  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D Offline
    dogfight76D Offline
    dogfight76
    Wollte ich jetzt eingeben, da steht das in Putty:
    dogfight76@iobroker:~ $ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages were automatically installed and are no longer required:
      libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
    Use 'sudo apt autoremove' to remove them.
    The following NEW packages will be installed:
      kms++-utils raspi-utils
    The following packages will be upgraded:
      adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
      chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
      cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
      dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
      exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
      ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
      gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
      gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
      libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
      libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
      libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
      libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
      libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
      libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
      libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
      libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
      libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
      libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
      liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
      libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
      libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
      libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
      librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
      libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
      libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
      libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
      locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
      lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
      mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
      openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
      python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
      python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
      python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
      raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
      systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
      vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
      vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
      xwayland
    320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/488 MB of archives.
    After this operation, 319 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Reading changelogs... Done
    • dogfight76D dogfight76
        xwayland
      @dogfight76
      Ja, so soll das.
      Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
      Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
        dogfight76D Offline
        dogfight76
        Das Update/Upgrade nach der deinstallation läuft.
        Die Installation, gibt es da ein How-To hier im Forum ?
          @dogfight76
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            dogfight76D Offline
            dogfight76
            Nach dem Update und dem Upgrade Befehl kam das:
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
            Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
            Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
            Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
            Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
            dogfight76@iobroker:~ $ sudo apt upgrade
              libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
              sudo apt autoremove
              Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
              iob update
              iob upgrade all
              iob stop
              iob upgrade self
              iob start
              iob update
              iob upgrade all
                dogfight76D Offline
                dogfight76
                Bin dabei........
                  dogfight76D Offline
                  dogfight76
                  Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                  dogfight76@iobroker:~ $ iob update
                  Used repository: stable
                  Adapter    "admin"        : 7.1.5    , installed 7.1.5
                  Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                  Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                  Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                  Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                  Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                  Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                  Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                  Adapter    "web"          : 6.2.5    , installed 6.2.5
                  dogfight76@iobroker:~ $ iob upgrade all
                  Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                  This upgrade of "javascript" will at least introduce the following changes:
                  -> 8.8.3:
                  Fixed object selector in rules
                  -> 8.8.2:
                  updated dependencies
                  -> 8.8.1:
                  -> 8.8.0:
                  Added option to register notifications via scripts
                  Fixed sendTo block with empty name list
                  -> 8.7.7:
                  Fixed import scripts dialog
                  Allow to remove all custom packages (empty list)
                  -> 8.7.6:
                  fix error with subpath imports in scripts
                  -> 8.7.5:
                  Fixed right aligned script names when using multiple instances
                  added fallback for all require calls in scripts
                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                  Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                  Update javascript from @7.1.4 to @8.8.3
                  NPM version: 10.8.2
                  Installing iobroker.javascript@8.8.3... (System call)
                  added 2 packages, removed 25 packages, and changed 10 packages in 1m
                  197 packages are looking for funding
                    run `npm fund` for details
                  Update "system.adapter.javascript.0"
                  upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                  upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                  upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                  upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                  upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                  upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                  upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                  upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                  upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                  upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                  upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                  upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                  upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                  upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                  upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                  upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                  upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                  upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                  upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                  upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                  upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                  upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                  This upgrade of "hm-rega" will at least introduce the following changes:
                  -> 5.1.0:
                  added notification if devices are low on battery
                  -> 5.0.0:
                  required node 18
                  -> 4.0.0:
                  required node 16 due to adapter-core 3.x.x
                  removed deprecated package - `request`
                  -> 3.0.47:
                  Updated packages
                  -> 3.0.46:
                  fix for controller v5 (closes #368)
                  -> 3.0.44:
                  compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                  also sync enums for maintenance channel of rfd devices (closes #320)
                  -> 3.0.43:
                  if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                  Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                  Update hm-rega from @3.0.40 to @5.1.0
                  NPM version: 10.8.2
                  Installing iobroker.hm-rega@5.1.0... (System call)
                  added 1 package, removed 1 package, and changed 1 package in 10s
                  Update "system.adapter.hm-rega.0"
                  upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                  upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                  upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                  upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                  This upgrade of "fritzdect" will at least introduce the following changes:
                  -> 2.5.11:
                  update devDeps, linting error correction
                  -> 2.5.10:
                  more loggimg for issue #500 of restart loop
                  -> 2.5.9:
                  new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                  Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                  Update fritzdect from @2.2.6 to @2.5.11
                  NPM version: 10.8.2
                  Installing iobroker.fritzdect@2.5.11... (System call)
                  added 181 packages, removed 8 packages, and changed 9 packages in 29s
                  208 packages are looking for funding
                  Adapter "system.adapter.vis.0" restarted.
                  Update "system.adapter.fritzdect.0"
                  upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                  upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                  upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                  upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                  upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                  upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                  This upgrade of "discovery" will at least introduce the following changes:
                  -> 5.0.0:
                  Packages updated
                  Minimum node.js version is 18.x
                  Updated licenses for knx and jarvis
                  -> 4.5.0:
                  Added Air-Q
                  -> 4.4.0:
                  Added WLED
                  Added LaMetric
                  Removed net-tools from proposals
                  -> 4.3.0:
                  Replaced vis with vis-2
                  -> 4.2.0:
                  Changed detection of myvbus and resol
                  -> 4.1.0:
                  Added detection of myvbus and resol
                  -> 4.0.0:
                  Added: frontier_silicon, sma-em, and speedwire
                  Dropped node14 support, refactoring
                  Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                  Update discovery from @3.1.0 to @5.0.0
                  NPM version: 10.8.2
                  Installing iobroker.discovery@5.0.0... (System call)
                  added 2 packages, removed 1 package, and changed 19 packages in 13s
                  210 packages are looking for funding
                  Update "system.adapter.discovery.0"
                  upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                  upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                  upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                  upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                  upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                  This upgrade of "chromecast" will introduce the following changes:
                  -> 3.4.1:
                  migrated binary state to file
                  -> 3.4.0:
                  Support for devices located in different subnets has been added. [#154, #160]
                  Dependencies have been updated
                  -> 3.3.0:
                  Adapter requires node.js 18 and js-controller >= 5 now
                  -> 3.2.0:
                  changed: Testing has been updated to use node.js 16/18/20
                  changed: Dependencies have been updated
                  YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                  AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                  Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                  -> 3.1.0:
                  Refactoring done
                  Removed dependency with nettools
                  Added support of web port other than 8082
                  -> 3.0.3:
                  Breaking change: Object IDs are now mac addresses instead names
                  set album name as song if provided in icy-name
                  Make compatible with Node.js 16+
                  Add Sentry for crash reporting
                  Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                  Update chromecast from @2.3.1 to @3.4.1
                  NPM version: 10.8.2
                  Installing iobroker.chromecast@3.4.1... (System call)
                  added 3 packages, removed 232 packages, and changed 1 package in 12s
                  207 packages are looking for funding
                  Update "system.adapter.chromecast.0"
                  upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                  upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                  upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                  upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                    -> 8.8.3:
                    -> 8.8.2:
                    -> 8.8.1:
                    -> 8.8.0:
                    -> 8.7.7:
                    -> 8.7.6:
                    -> 8.7.5:
                    NPM version: 10.8.2
                    -> 5.1.0:
                    -> 5.0.0:
                    required node 18
                    -> 4.0.0:
                    -> 3.0.47:
                    Updated packages
                    -> 3.0.46:
                    -> 3.0.44:
                    -> 3.0.43:
                    NPM version: 10.8.2
                    -> 2.5.11:
                    -> 2.5.10:
                    -> 2.5.9:
                    NPM version: 10.8.2
                    -> 5.0.0:
                    Packages updated
                    -> 4.5.0:
                    Added Air-Q
                    -> 4.4.0:
                    Added WLED
                    Added LaMetric
                    -> 4.3.0:
                    -> 4.2.0:
                    -> 4.1.0:
                    -> 4.0.0:
                    NPM version: 10.8.2
                    -> 3.4.1:
                    -> 3.4.0:
                    -> 3.3.0:
                    -> 3.2.0:
                    -> 3.1.0:
                    Refactoring done
                    -> 3.0.3:
                    NPM version: 10.8.2
                    hast du den noch nicht aktualisiert?
                      -> 8.8.3:
                      -> 8.8.2:
                      -> 8.8.1:
                      -> 8.8.0:
                      -> 8.7.7:
                      -> 8.7.6:
                      -> 8.7.5:
                      NPM version: 10.8.2
                      -> 5.1.0:
                      -> 5.0.0:
                      required node 18
                      -> 4.0.0:
                      -> 3.0.47:
                      Updated packages
                      -> 3.0.46:
                      -> 3.0.44:
                      -> 3.0.43:
                      NPM version: 10.8.2
                      -> 2.5.11:
                      -> 2.5.10:
                      -> 2.5.9:
                      NPM version: 10.8.2
                      -> 5.0.0:
                      Packages updated
                      -> 4.5.0:
                      Added Air-Q
                      -> 4.4.0:
                      Added WLED
                      Added LaMetric
                      -> 4.3.0:
                      -> 4.2.0:
                      -> 4.1.0:
                      -> 4.0.0:
                      NPM version: 10.8.2
                      -> 3.4.1:
                      -> 3.4.0:
                      -> 3.3.0:
                      -> 3.2.0:
                      -> 3.1.0:
                      Refactoring done
                      -> 3.0.3:
                      NPM version: 10.8.2
                      @dogfight76
                      Gib die Befehle in der Abfolge wie oben gepostet ein.
                      Fehlermeldungen sind jetzt irrelevant und erwartet.
                      dogfight76D 2 Antworten Letzte Antwort
                        dogfight76D Offline
                        dogfight76
                        Damit fing das Problem doch an........
                        Ich wollte im ioBroker das Update des js-controller anstoßen
                          @dogfight76
                          dogfight76D Offline
                          dogfight76D Offline
                          dogfight76
                          @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                          @dogfight76
                          Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                          Arbeite die Befehlsliste gerade ab
                            @dogfight76
                            dogfight76D Offline
                            dogfight76D Offline
                            dogfight76
                            @thomas-braun Fertig. Ohne Fehlermeldung
                              da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                                @dogfight76
                                Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                                iob diag
                                anschauen.
                                  dogfight76D Offline
                                  dogfight76
                                  Hier das Ergebnis:
                                  ```bash
                                  Script v.2024-10-19
                                  *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                           Icon name: computer
                                    Operating System: Debian GNU/Linux 11 (bullseye)
                                              Kernel: Linux 5.15.61-v8+
                                        Architecture: arm64
                                  OS is similar to:
                                  Model           : Raspberry Pi 4 Model B Rev 1.2
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  Systemuptime and Load:
                                   15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                  CPU threads: 4
                                  *** LIFE CYCLE STATUS ***
                                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  This system needs to be REBOOTED!
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Sun 2024-11-03 15:20:43 CET
                                             Universal time: Sun 2024-11-03 14:20:43 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  dogfight76
                                  HOME=/home/dogfight76
                                  GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  *** DISPLAY-SERVER SETUP ***
                                  Display-Server: false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                                  Swap:            99M        2.0M         97M
                                  Total:          3.9G        804M        215M
                                  Active iob-Instances:   11
                                           3794 M total memory
                                            802 M used memory
                                            934 M active memory
                                           2452 M inactive memory
                                            117 M free memory
                                            178 M buffer memory
                                           2696 M swap cache
                                             99 M total swap
                                              2 M used swap
                                             97 M free swap
                                  top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                  Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                                  MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  No critical errors detected
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       59G  8.6G   48G  16% /
                                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                  tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                  /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                  tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                  [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                  [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                  [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                  Show mounted filesystems:
                                  TARGET  SOURCE         FSTYPE OPTIONS
                                  /       /dev/mmcblk0p2 ext4   rw,noatime
                                  `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  2.0G    /var/
                                  1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                                  1.1G    /var/log
                                  634M    /var/cache
                                  Archived and active journals take up 1.0G in the file system.
                                  /opt/iobroker/backups:
                                  91M     /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  815M    /opt/iobroker/iobroker-data/
                                  761M    /opt/iobroker/iobroker-data/files
                                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                                  12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                  8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                  8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                  USB-Devices by-id:
                                  No Devices found 'by-id'
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v20.18.0
                                  /usr/bin/node           v20.18.0
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  /usr/bin/corepack       0.29.3
                                  nodejs:
                                    Installed: 20.18.0-1nodesource1
                                    Candidate: 20.18.0-1nodesource1
                                    Version table:
                                   *** 20.18.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                       20.17.0-1nodesource1 1001
                                       20.16.0-1nodesource1 1001
                                       20.15.1-1nodesource1 1001
                                       20.15.0-1nodesource1 1001
                                       20.14.0-1nodesource1 1001
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                       12.22.12~dfsg-1~deb11u5 500
                                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                       12.22.12~dfsg-1~deb11u4 500
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                                  Core adapters versions
                                  js-controller:  6.0.11
                                  admin:          7.1.5
                                  javascript:     8.8.3
                                  nodejs modules from github:     2
                                  +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                                  +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                  Adapter State
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                    system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                    system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                    system.adapter.history.0                : history               : iobroker                                 - disabled
                                    system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                                    system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                                    system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                                    system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                                  + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                    system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                    system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                                  + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                    system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                  + instance is alive
                                  ioBroker-Repositories
                                  Active repo(s): stable
                                  Upgrade policy: none
                                  Installed ioBroker-Instances
                                  Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                  Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                  Controller "js-controller": 6.0.11   , installed 6.0.11
                                  Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                  Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                  Objects and States
                                  Objects:        1050
                                  States:         801
                                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                  Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                                  tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                                  udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                                  udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                                  udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                                  2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                                  2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                  2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                  2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                                  iob diag has finished.
                                  Press any key for a summary
                                    Hier das Ergebnis:
                                    ```bash
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    dogfight76
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M        2.0M         97M
                                             3794 M total memory
                                              802 M used memory
                                              934 M active memory
                                              117 M free memory
                                              178 M buffer memory
                                             2696 M swap cache
                                               99 M total swap
                                                2 M used swap
                                               97 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    2.0G    /var/
                                    1.1G    /var/log
                                    634M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.1.5
                                    javascript:     8.8.3
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        1050
                                    States:         801
                                    Pending Updates: 0
                                      dogfight76D Offline
                                      dogfight76
                                      Reboot isr durch
                                        Reboot isr durch
                                        @dogfight76
                                        Ansonsten sieht das jetzt bis auf die Meldungen von influxdb aber solide aus.
                                        Mit
                                        muss dir aber wer anders weiterhelfen.
                                        Ich würde vorschlagen, in einem separaten Thread.
                                          Reboot isr durch
                                          @dogfight76
                                          influxdb ist auch aus meiner Sicht nicht ordentlich installiert. Jedenfalls fehlt dir das influx-Repo in deinem Setup.
