  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D Offline
    dogfight76D Offline
    dogfight76
    Da ist er:
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:13:55 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-11-03 14:13:55 CET
               Universal time: Sun 2024-11-03 13:13:55 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dogfight76
    HOME=/home/dogfight76
    GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        748M        2.5G        1.0M        499M        3.0G
    Swap:            99M          0B         99M
    Total:          3.9G        748M        2.6G
    Active iob-Instances:   9
             3794 M total memory
              748 M used memory
              197 M active memory
              938 M inactive memory
             2546 M free memory
               49 M buffer memory
              449 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 14:13:56 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
    Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.4 total,   2546.3 free,    748.5 used,    499.5 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2969.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G  6.8G   50G  13% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.0G    /var/
    1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
    1.1G    /var/log
    628M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    91M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    217M    /opt/iobroker/iobroker-data/
    169M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    40M     /opt/iobroker/iobroker-data/backup-objects
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    6.7M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    nodejs:                 N/A
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
         20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
     *** 16.20.2-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 62)
    Core adapters versions
    js-controller:  5.0.12
    admin:          7.1.5
    javascript:     7.1.4
    nodejs modules from github:     2
    +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
      system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
    Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
    Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
    Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        989
    States:         798
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 319
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16858      1495/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16851      1495/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13941      537/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12826      563/sshd: /usr/sbin
    tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       17879      1572/io.mqtt.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16084      1514/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16168      1618/io.web.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13940      537/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12828      563/sshd: /usr/sbin
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14555      592/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14503      407/avahi-daemon: r
    udp        0      0 0.0.0.0:47112           0.0.0.0:*                           108        14505      407/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14504      407/avahi-daemon: r
    udp6       0      0 :::55098                :::*                                108        14506      407/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
    2024-11-03 14:13:51.363  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:13:51.388  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:01.389  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:01.390  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:01.406  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:11.408  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:11.409  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:11.419  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:21.419  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:21.420  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:21.432  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:28.419  - info: cloud.0 (1587) Trying to connect as system.user.admin to cloud
    2024-11-03 14:14:28.646  - info: cloud.0 (1587) Connection changed: connect
    2024-11-03 14:14:31.433  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:31.434  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:31.451  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:41.452  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:41.453  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:41.469  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:51.470  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:51.471  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:51.487  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:15:01.488  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:15:01.489  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:15:01.501  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    iob diag has finished.
    Press any key for a summary
    • dogfight76D dogfight76
      Da ist er:
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      dogfight76
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
                748 M used memory
                197 M active memory
               2546 M free memory
                 49 M buffer memory
                449 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /var:
      2.0G    /var/
      1.1G    /var/log
      628M    /var/cache
      USB-Devices by-id:
      nodejs:                 N/A
      /usr/bin/npm            8.19.4
      /usr/bin/npx            8.19.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.1.5
      javascript:     7.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        989
      States:         798
      @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
      und
      sudo apt update
      iob stop
      sudo apt full-upgrade
      sudo reboot
        dogfight76D Offline
        dogfight76
        Nach dem Full-Upgrade Befehl kommt am Schluss:
        apt-listchanges: News
        cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
          This release addresses a security issue (CVE-2023-32360) which allows
          unauthorized users to fetch documents over local or remote networks.
          Since this is a configuration fix, it might be that it does not reach you if you
          are updating 'cups-daemon' (rather than doing a fresh installation).
          Please double check your /etc/cups/cupsd.conf file, whether it limits the access
          to CUPS-Get-Document with something like the following
          >  <Limit CUPS-Get-Document>
          >    AuthType Default
          >    Require user @OWNER @SYSTEM
          >    Order deny,allow
          >   </Limit>
          (The important line is the 'AuthType Default' in this section)
         -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
        (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
        E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
        dogfight76@iobroker:~ $
        Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
        Thomas BraunT dogfight76D 2 Antworten Letzte Antwort
            >    AuthType Default
            >    Order deny,allow
            >   </Limit>
          @dogfight76
          sudo apt update
          sagt?
            dogfight76D Offline
            dogfight76
            Da kommt das:
            dogfight76@iobroker:~ $ sudo apt update
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
            Reading package lists... Done
            320 packages can be upgraded. Run 'apt list --upgradable' to see them.
            dogfight76@iobroker:~ $ iob stop
            dogfight76@iobroker:~ $ sudo apt full-upgrade
              Da kommt das:
              @dogfight76
              Die 320 Updates müssen rein.
              Nach dem full-upgrade die Kiste sauber rebooten.
                  >    AuthType Default
                  >    Order deny,allow
                  >   </Limit>
                dogfight76D Offline
                dogfight76D Offline
                dogfight76
                @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                  >    AuthType Default
                  >    Order deny,allow
                  >   </Limit>
                Trotz der Meldung also den Reboot Befehl eingeben ?
                    >    AuthType Default
                    >    Order deny,allow
                    >   </Limit>
                  Keine Ahnung warum apt-listchanges da bei dir rumzickt.
                  Deinstallier das mal:
                  sudo apt remove apt-listchanges
                  sudo apt update
                  sudo apt upgrade
                    dogfight76D Offline
                    dogfight76
                    Wollte ich jetzt eingeben, da steht das in Putty:
                    Calculating upgrade... Done
                    The following packages were automatically installed and are no longer required:
                      libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
                    Use 'sudo apt autoremove' to remove them.
                    The following NEW packages will be installed:
                      kms++-utils raspi-utils
                    The following packages will be upgraded:
                      adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
                      chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
                      cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
                      dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
                      exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                      ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
                      gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                      gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
                      libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
                      libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                      libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
                      libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                      libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
                      libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                      libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                      libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
                      libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                      libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
                      liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
                      libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
                      libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                      libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                      librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
                      libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
                      libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
                      libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
                      locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                      lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
                      mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
                      openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
                      python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
                      python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                      python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
                      raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
                      systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
                      vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
                      vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
                      xwayland
                    320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 0 B/488 MB of archives.
                    After this operation, 319 MB of additional disk space will be used.
                    Do you want to continue? [Y/n] y
                    Reading changelogs... Done
                        xwayland
                      @dogfight76
                      Ja, so soll das.
                      Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
                      Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
                        dogfight76D Offline
                        dogfight76
                        Das Update/Upgrade nach der deinstallation läuft.
                        Die Installation, gibt es da ein How-To hier im Forum ?
                          @dogfight76
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                            dogfight76D Offline
                            dogfight76
                            Nach dem Update und dem Upgrade Befehl kam das:
                            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                            Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                            Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                            Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                            Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                            dogfight76@iobroker:~ $ sudo apt upgrade
                              libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                              sudo apt autoremove
                              Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                              iob update
                              iob upgrade all
                              iob stop
                              iob upgrade self
                              iob start
                              iob update
                              iob upgrade all
                                dogfight76D Offline
                                dogfight76
                                Bin dabei........
                                  dogfight76D Offline
                                  dogfight76
                                  Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                                  dogfight76@iobroker:~ $ iob update
                                  dogfight76@iobroker:~ $ iob upgrade all
                                  Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                                  This upgrade of "javascript" will at least introduce the following changes:
                                  -> 8.8.3:
                                  Fixed object selector in rules
                                  -> 8.8.2:
                                  updated dependencies
                                  -> 8.8.1:
                                  -> 8.8.0:
                                  Added option to register notifications via scripts
                                  Fixed sendTo block with empty name list
                                  -> 8.7.7:
                                  Fixed import scripts dialog
                                  Allow to remove all custom packages (empty list)
                                  -> 8.7.6:
                                  fix error with subpath imports in scripts
                                  -> 8.7.5:
                                  Fixed right aligned script names when using multiple instances
                                  added fallback for all require calls in scripts
                                  BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                  Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                                  Update javascript from @7.1.4 to @8.8.3
                                  NPM version: 10.8.2
                                  Installing iobroker.javascript@8.8.3... (System call)
                                  added 2 packages, removed 25 packages, and changed 10 packages in 1m
                                  197 packages are looking for funding
                                    run `npm fund` for details
                                  Update "system.adapter.javascript.0"
                                  upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                  upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                                  upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                                  upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                                  upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                                  upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                                  upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                                  upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                                  upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                                  upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                                  upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                                  upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                                  upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                                  upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                                  upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                                  upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                                  upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                                  upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                                  upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                                  upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                                  upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                                  upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                  This upgrade of "hm-rega" will at least introduce the following changes:
                                  -> 5.1.0:
                                  added notification if devices are low on battery
                                  -> 5.0.0:
                                  required node 18
                                  -> 4.0.0:
                                  required node 16 due to adapter-core 3.x.x
                                  removed deprecated package - `request`
                                  -> 3.0.47:
                                  Updated packages
                                  -> 3.0.46:
                                  fix for controller v5 (closes #368)
                                  -> 3.0.44:
                                  compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                                  also sync enums for maintenance channel of rfd devices (closes #320)
                                  -> 3.0.43:
                                  if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                                  Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                                  Update hm-rega from @3.0.40 to @5.1.0
                                  NPM version: 10.8.2
                                  Installing iobroker.hm-rega@5.1.0... (System call)
                                  added 1 package, removed 1 package, and changed 1 package in 10s
                                  Update "system.adapter.hm-rega.0"
                                  upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                                  upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                                  upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                                  upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                                  This upgrade of "fritzdect" will at least introduce the following changes:
                                  -> 2.5.11:
                                  update devDeps, linting error correction
                                  -> 2.5.10:
                                  more loggimg for issue #500 of restart loop
                                  -> 2.5.9:
                                  new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                                  Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                                  Update fritzdect from @2.2.6 to @2.5.11
                                  NPM version: 10.8.2
                                  Installing iobroker.fritzdect@2.5.11... (System call)
                                  added 181 packages, removed 8 packages, and changed 9 packages in 29s
                                  208 packages are looking for funding
                                  Adapter "system.adapter.vis.0" restarted.
                                  Update "system.adapter.fritzdect.0"
                                  upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                  upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                                  upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                                  upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                                  upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                  upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                                  This upgrade of "discovery" will at least introduce the following changes:
                                  -> 5.0.0:
                                  Packages updated
                                  Minimum node.js version is 18.x
                                  Updated licenses for knx and jarvis
                                  -> 4.5.0:
                                  Added Air-Q
                                  -> 4.4.0:
                                  Added WLED
                                  Added LaMetric
                                  Removed net-tools from proposals
                                  -> 4.3.0:
                                  Replaced vis with vis-2
                                  -> 4.2.0:
                                  Changed detection of myvbus and resol
                                  -> 4.1.0:
                                  Added detection of myvbus and resol
                                  -> 4.0.0:
                                  Added: frontier_silicon, sma-em, and speedwire
                                  Dropped node14 support, refactoring
                                  Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                                  Update discovery from @3.1.0 to @5.0.0
                                  NPM version: 10.8.2
                                  Installing iobroker.discovery@5.0.0... (System call)
                                  added 2 packages, removed 1 package, and changed 19 packages in 13s
                                  210 packages are looking for funding
                                  Update "system.adapter.discovery.0"
                                  upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                  upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                  upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                  upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                  upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                  This upgrade of "chromecast" will introduce the following changes:
                                  -> 3.4.1:
                                  migrated binary state to file
                                  -> 3.4.0:
                                  Support for devices located in different subnets has been added. [#154, #160]
                                  Dependencies have been updated
                                  -> 3.3.0:
                                  Adapter requires node.js 18 and js-controller >= 5 now
                                  -> 3.2.0:
                                  changed: Testing has been updated to use node.js 16/18/20
                                  changed: Dependencies have been updated
                                  YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                                  AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                                  Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                                  -> 3.1.0:
                                  Refactoring done
                                  Removed dependency with nettools
                                  Added support of web port other than 8082
                                  -> 3.0.3:
                                  Breaking change: Object IDs are now mac addresses instead names
                                  set album name as song if provided in icy-name
                                  Make compatible with Node.js 16+
                                  Add Sentry for crash reporting
                                  Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                                  Update chromecast from @2.3.1 to @3.4.1
                                  NPM version: 10.8.2
                                  Installing iobroker.chromecast@3.4.1... (System call)
                                  added 3 packages, removed 232 packages, and changed 1 package in 12s
                                  207 packages are looking for funding
                                  Update "system.adapter.chromecast.0"
                                  upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                  upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                  upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                  upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                    -> 8.8.3:
                                    -> 8.8.2:
                                    -> 8.8.1:
                                    -> 8.8.0:
                                    -> 8.7.7:
                                    -> 8.7.6:
                                    -> 8.7.5:
                                    NPM version: 10.8.2
                                    -> 5.1.0:
                                    -> 5.0.0:
                                    required node 18
                                    -> 4.0.0:
                                    -> 3.0.47:
                                    Updated packages
                                    -> 3.0.46:
                                    -> 3.0.44:
                                    -> 3.0.43:
                                    NPM version: 10.8.2
                                    -> 2.5.11:
                                    -> 2.5.10:
                                    -> 2.5.9:
                                    NPM version: 10.8.2
                                    -> 5.0.0:
                                    Packages updated
                                    -> 4.5.0:
                                    Added Air-Q
                                    -> 4.4.0:
                                    Added WLED
                                    Added LaMetric
                                    -> 4.3.0:
                                    -> 4.2.0:
                                    -> 4.1.0:
                                    -> 4.0.0:
                                    NPM version: 10.8.2
                                    -> 3.4.1:
                                    -> 3.4.0:
                                    -> 3.3.0:
                                    -> 3.2.0:
                                    -> 3.1.0:
                                    Refactoring done
                                    -> 3.0.3:
                                    NPM version: 10.8.2
                                    hast du den noch nicht aktualisiert?
                                      -> 8.8.3:
                                      -> 8.8.2:
                                      -> 8.8.1:
                                      -> 8.8.0:
                                      -> 8.7.7:
                                      -> 8.7.6:
                                      -> 8.7.5:
                                      NPM version: 10.8.2
                                      -> 5.1.0:
                                      -> 5.0.0:
                                      required node 18
                                      -> 4.0.0:
                                      -> 3.0.47:
                                      Updated packages
                                      -> 3.0.46:
                                      -> 3.0.44:
                                      -> 3.0.43:
                                      NPM version: 10.8.2
                                      -> 2.5.11:
                                      -> 2.5.10:
                                      -> 2.5.9:
                                      NPM version: 10.8.2
                                      -> 5.0.0:
                                      Packages updated
                                      -> 4.5.0:
                                      Added Air-Q
                                      -> 4.4.0:
                                      Added WLED
                                      Added LaMetric
                                      -> 4.3.0:
                                      -> 4.2.0:
                                      -> 4.1.0:
                                      -> 4.0.0:
                                      NPM version: 10.8.2
                                      -> 3.4.1:
                                      -> 3.4.0:
                                      -> 3.3.0:
                                      -> 3.2.0:
                                      -> 3.1.0:
                                      Refactoring done
                                      -> 3.0.3:
                                      NPM version: 10.8.2
                                      @dogfight76
                                      Gib die Befehle in der Abfolge wie oben gepostet ein.
                                      Fehlermeldungen sind jetzt irrelevant und erwartet.
                                        dogfight76D Offline
                                        dogfight76
                                        Damit fing das Problem doch an........
                                        Ich wollte im ioBroker das Update des js-controller anstoßen
                                          @dogfight76
                                          dogfight76D Offline
                                          dogfight76D Offline
                                          dogfight76
                                          @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                          @dogfight76
                                          Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                                          Arbeite die Befehlsliste gerade ab
