  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D Offline
    dogfight76D Offline
    dogfight76
    Da kommt das:
    dogfight76@iobroker:~ $ sudo apt update
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    320 packages can be upgraded. Run 'apt list --upgradable' to see them.
    dogfight76@iobroker:~ $ iob stop
    dogfight76@iobroker:~ $ sudo apt full-upgrade
    • dogfight76D dogfight76
      Da kommt das:
      @dogfight76
      Die 320 Updates müssen rein.
      Nach dem full-upgrade die Kiste sauber rebooten.
        Nach dem Full-Upgrade Befehl kommt am Schluss:
        apt-listchanges: News
        cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
          This release addresses a security issue (CVE-2023-32360) which allows
          unauthorized users to fetch documents over local or remote networks.
          Since this is a configuration fix, it might be that it does not reach you if you
          are updating 'cups-daemon' (rather than doing a fresh installation).
          Please double check your /etc/cups/cupsd.conf file, whether it limits the access
          to CUPS-Get-Document with something like the following
          >  <Limit CUPS-Get-Document>
          >    AuthType Default
          >    Require user @OWNER @SYSTEM
          >    Order deny,allow
          >   </Limit>
          (The important line is the 'AuthType Default' in this section)
         -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
        (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
        E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
        Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
        dogfight76D Offline
        dogfight76D Offline
        dogfight76
        @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
          >    AuthType Default
          >    Order deny,allow
          >   </Limit>
        Trotz der Meldung also den Reboot Befehl eingeben ?
            >    AuthType Default
            >    Order deny,allow
            >   </Limit>
          @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
          Keine Ahnung warum apt-listchanges da bei dir rumzickt.
          Deinstallier das mal:
          sudo apt remove apt-listchanges
          sudo apt update
          sudo apt upgrade
            dogfight76D Offline
            dogfight76
            Wollte ich jetzt eingeben, da steht das in Putty:
            Calculating upgrade... Done
            The following packages were automatically installed and are no longer required:
              libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
            Use 'sudo apt autoremove' to remove them.
            The following NEW packages will be installed:
              kms++-utils raspi-utils
            The following packages will be upgraded:
              adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
              chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
              cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
              dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
              exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
              ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
              gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
              gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
              libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
              libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
              libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
              libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
              libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
              libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
              libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
              libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
              libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
              libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
              liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
              libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
              libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
              libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
              librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
              libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
              libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
              libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
              locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
              lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
              mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
              openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
              python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
              python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
              python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
              raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
              systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
              vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
              vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
              xwayland
            320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
            Need to get 0 B/488 MB of archives.
            After this operation, 319 MB of additional disk space will be used.
            Do you want to continue? [Y/n] y
            Reading changelogs... Done
                xwayland
              @dogfight76
              Ja, so soll das.
              Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
              Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
                dogfight76D Offline
                dogfight76
                Das Update/Upgrade nach der deinstallation läuft.
                Die Installation, gibt es da ein How-To hier im Forum ?
                  @dogfight76
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    dogfight76D Offline
                    dogfight76
                    Nach dem Update und dem Upgrade Befehl kam das:
                    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                    Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                    Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                    Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                    Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                    dogfight76@iobroker:~ $ sudo apt upgrade
                      libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      sudo apt autoremove
                      Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                      iob update
                      iob upgrade all
                      iob stop
                      iob upgrade self
                      iob start
                      iob update
                      iob upgrade all
                        dogfight76D Offline
                        dogfight76
                        Bin dabei........
                          dogfight76D Offline
                          dogfight76
                          Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                          dogfight76@iobroker:~ $ iob update
                          Used repository: stable
                          Adapter    "admin"        : 7.1.5    , installed 7.1.5
                          Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
                          Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
                          Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                          Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
                          Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
                          Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
                          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                          Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
                          Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
                          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                          Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
                          Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
                          Adapter    "web"          : 6.2.5    , installed 6.2.5
                          dogfight76@iobroker:~ $ iob upgrade all
                          Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                          This upgrade of "javascript" will at least introduce the following changes:
                          -> 8.8.3:
                          Fixed object selector in rules
                          -> 8.8.2:
                          updated dependencies
                          -> 8.8.1:
                          -> 8.8.0:
                          Added option to register notifications via scripts
                          Fixed sendTo block with empty name list
                          -> 8.7.7:
                          Fixed import scripts dialog
                          Allow to remove all custom packages (empty list)
                          -> 8.7.6:
                          fix error with subpath imports in scripts
                          -> 8.7.5:
                          Fixed right aligned script names when using multiple instances
                          added fallback for all require calls in scripts
                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                          Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                          Update javascript from @7.1.4 to @8.8.3
                          NPM version: 10.8.2
                          Installing iobroker.javascript@8.8.3... (System call)
                          added 2 packages, removed 25 packages, and changed 10 packages in 1m
                          197 packages are looking for funding
                            run `npm fund` for details
                          Update "system.adapter.javascript.0"
                          upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                          upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                          upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                          upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                          upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                          upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                          upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                          upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                          upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                          upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                          upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                          upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                          upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                          upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                          upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                          upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                          upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                          upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                          upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                          upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                          upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                          upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                          This upgrade of "hm-rega" will at least introduce the following changes:
                          -> 5.1.0:
                          added notification if devices are low on battery
                          -> 5.0.0:
                          required node 18
                          -> 4.0.0:
                          required node 16 due to adapter-core 3.x.x
                          removed deprecated package - `request`
                          -> 3.0.47:
                          Updated packages
                          -> 3.0.46:
                          fix for controller v5 (closes #368)
                          -> 3.0.44:
                          compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                          also sync enums for maintenance channel of rfd devices (closes #320)
                          -> 3.0.43:
                          if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                          Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                          Update hm-rega from @3.0.40 to @5.1.0
                          NPM version: 10.8.2
                          Installing iobroker.hm-rega@5.1.0... (System call)
                          added 1 package, removed 1 package, and changed 1 package in 10s
                          Update "system.adapter.hm-rega.0"
                          upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                          upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                          upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                          upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                          This upgrade of "fritzdect" will at least introduce the following changes:
                          -> 2.5.11:
                          update devDeps, linting error correction
                          -> 2.5.10:
                          more loggimg for issue #500 of restart loop
                          -> 2.5.9:
                          new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                          Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                          Update fritzdect from @2.2.6 to @2.5.11
                          NPM version: 10.8.2
                          Installing iobroker.fritzdect@2.5.11... (System call)
                          added 181 packages, removed 8 packages, and changed 9 packages in 29s
                          208 packages are looking for funding
                          Adapter "system.adapter.vis.0" restarted.
                          Update "system.adapter.fritzdect.0"
                          upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                          upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                          upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                          upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                          upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                          upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                          This upgrade of "discovery" will at least introduce the following changes:
                          -> 5.0.0:
                          Packages updated
                          Minimum node.js version is 18.x
                          Updated licenses for knx and jarvis
                          -> 4.5.0:
                          Added Air-Q
                          -> 4.4.0:
                          Added WLED
                          Added LaMetric
                          Removed net-tools from proposals
                          -> 4.3.0:
                          Replaced vis with vis-2
                          -> 4.2.0:
                          Changed detection of myvbus and resol
                          -> 4.1.0:
                          Added detection of myvbus and resol
                          -> 4.0.0:
                          Added: frontier_silicon, sma-em, and speedwire
                          Dropped node14 support, refactoring
                          Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                          Update discovery from @3.1.0 to @5.0.0
                          NPM version: 10.8.2
                          Installing iobroker.discovery@5.0.0... (System call)
                          added 2 packages, removed 1 package, and changed 19 packages in 13s
                          210 packages are looking for funding
                          Update "system.adapter.discovery.0"
                          upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                          upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                          upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                          upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                          upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                          upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                          upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                          This upgrade of "chromecast" will introduce the following changes:
                          -> 3.4.1:
                          migrated binary state to file
                          -> 3.4.0:
                          Support for devices located in different subnets has been added. [#154, #160]
                          Dependencies have been updated
                          -> 3.3.0:
                          Adapter requires node.js 18 and js-controller >= 5 now
                          -> 3.2.0:
                          changed: Testing has been updated to use node.js 16/18/20
                          changed: Dependencies have been updated
                          YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                          AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                          Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                          -> 3.1.0:
                          Refactoring done
                          Removed dependency with nettools
                          Added support of web port other than 8082
                          -> 3.0.3:
                          Breaking change: Object IDs are now mac addresses instead names
                          set album name as song if provided in icy-name
                          Make compatible with Node.js 16+
                          Add Sentry for crash reporting
                          Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                          Update chromecast from @2.3.1 to @3.4.1
                          NPM version: 10.8.2
                          Installing iobroker.chromecast@3.4.1... (System call)
                          added 3 packages, removed 232 packages, and changed 1 package in 12s
                          207 packages are looking for funding
                          Update "system.adapter.chromecast.0"
                          upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                          upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                          upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                          upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                            -> 8.8.3:
                            -> 8.8.2:
                            -> 8.8.1:
                            -> 8.8.0:
                            -> 8.7.7:
                            -> 8.7.6:
                            -> 8.7.5:
                            NPM version: 10.8.2
                            -> 5.1.0:
                            -> 5.0.0:
                            required node 18
                            -> 4.0.0:
                            -> 3.0.47:
                            Updated packages
                            -> 3.0.46:
                            -> 3.0.44:
                            -> 3.0.43:
                            NPM version: 10.8.2
                            -> 2.5.11:
                            -> 2.5.10:
                            -> 2.5.9:
                            NPM version: 10.8.2
                            -> 5.0.0:
                            Packages updated
                            -> 4.5.0:
                            Added Air-Q
                            -> 4.4.0:
                            Added WLED
                            Added LaMetric
                            -> 4.3.0:
                            -> 4.2.0:
                            -> 4.1.0:
                            -> 4.0.0:
                            NPM version: 10.8.2
                            -> 3.4.1:
                            -> 3.4.0:
                            -> 3.3.0:
                            -> 3.2.0:
                            -> 3.1.0:
                            Refactoring done
                            -> 3.0.3:
                            NPM version: 10.8.2
                            hast du den noch nicht aktualisiert?
                              -> 8.8.3:
                              -> 8.8.2:
                              -> 8.8.1:
                              -> 8.8.0:
                              -> 8.7.7:
                              -> 8.7.6:
                              -> 8.7.5:
                              NPM version: 10.8.2
                              -> 5.1.0:
                              -> 5.0.0:
                              required node 18
                              -> 4.0.0:
                              -> 3.0.47:
                              Updated packages
                              -> 3.0.46:
                              -> 3.0.44:
                              -> 3.0.43:
                              NPM version: 10.8.2
                              -> 2.5.11:
                              -> 2.5.10:
                              -> 2.5.9:
                              NPM version: 10.8.2
                              -> 5.0.0:
                              Packages updated
                              -> 4.5.0:
                              Added Air-Q
                              -> 4.4.0:
                              Added WLED
                              Added LaMetric
                              -> 4.3.0:
                              -> 4.2.0:
                              -> 4.1.0:
                              -> 4.0.0:
                              NPM version: 10.8.2
                              -> 3.4.1:
                              -> 3.4.0:
                              -> 3.3.0:
                              -> 3.2.0:
                              -> 3.1.0:
                              Refactoring done
                              -> 3.0.3:
                              NPM version: 10.8.2
                              @dogfight76
                              Gib die Befehle in der Abfolge wie oben gepostet ein.
                              Fehlermeldungen sind jetzt irrelevant und erwartet.
                              dogfight76D 2 Antworten Letzte Antwort
                                dogfight76D Offline
                                dogfight76
                                Damit fing das Problem doch an........
                                Ich wollte im ioBroker das Update des js-controller anstoßen
                                  @dogfight76
                                  dogfight76D Offline
                                  dogfight76D Offline
                                  dogfight76
                                  @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                  @dogfight76
                                  Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                                  Arbeite die Befehlsliste gerade ab
                                    @dogfight76
                                    dogfight76D Offline
                                    dogfight76D Offline
                                    dogfight76
                                    @thomas-braun Fertig. Ohne Fehlermeldung
                                      da war aber wahrscheinlich das Betriebssystem noch nicht reif dafür
                                        @dogfight76
                                        Dann kannst du dir dein Meisterwerk ja jetzt nochmal in Gänze per
                                        iob diag
                                        anschauen.
                                          dogfight76D Offline
                                          dogfight76
                                          Hier das Ergebnis:
                                          ```bash
                                          Script v.2024-10-19
                                          *** BASE SYSTEM ***
                                             Static hostname: iobroker
                                                   Icon name: computer
                                            Operating System: Debian GNU/Linux 11 (bullseye)
                                                      Kernel: Linux 5.15.61-v8+
                                                Architecture: arm64
                                          OS is similar to:
                                          Model           : Raspberry Pi 4 Model B Rev 1.2
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          Systemuptime and Load:
                                           15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                          CPU threads: 4
                                          *** LIFE CYCLE STATUS ***
                                          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                          *** RASPBERRY THROTTLING ***
                                          Current issues:
                                          Previously detected issues:
                                          This system needs to be REBOOTED!
                                          *** TIME AND TIMEZONES ***
                                                         Local time: Sun 2024-11-03 15:20:43 CET
                                                     Universal time: Sun 2024-11-03 14:20:43 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** Users and Groups ***
                                          User that called 'iob diag':
                                          dogfight76
                                          HOME=/home/dogfight76
                                          GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          *** DISPLAY-SERVER SETUP ***
                                          Display-Server: false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.8G        802M        117M        1.0M        2.9G        2.9G
                                          Swap:            99M        2.0M         97M
                                          Total:          3.9G        804M        215M
                                          Active iob-Instances:   11
                                                   3794 M total memory
                                                    802 M used memory
                                                    934 M active memory
                                                   2452 M inactive memory
                                                    117 M free memory
                                                    178 M buffer memory
                                                   2696 M swap cache
                                                     99 M total swap
                                                      2 M used swap
                                                     97 M free swap
                                          top - 15:20:43 up  1:14,  2 users,  load average: 0.73, 0.74, 0.80
                                          Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3794.4 total,    117.5 free,    802.3 used,   2874.6 buff/cache
                                          MiB Swap:    100.0 total,     98.0 free,      2.0 used.   2915.6 avail Mem
                                          *** FAILED SERVICES ***
                                          0 loaded units listed.
                                          *** DMESG CRITICAL ERRORS ***
                                          No critical errors detected
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       59G  8.6G   48G  16% /
                                          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                          tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                          tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                                          [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                          [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                          Show mounted filesystems:
                                          TARGET  SOURCE         FSTYPE OPTIONS
                                          /       /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          2.0G    /var/
                                          1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
                                          1.1G    /var/log
                                          634M    /var/cache
                                          Archived and active journals take up 1.0G in the file system.
                                          /opt/iobroker/backups:
                                          91M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          815M    /opt/iobroker/iobroker-data/
                                          761M    /opt/iobroker/iobroker-data/files
                                          617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                          13M     /opt/iobroker/iobroker-data/objects.jsonl
                                          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                          USB-Devices by-id:
                                          No Devices found 'by-id'
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v20.18.0
                                          /usr/bin/node           v20.18.0
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.29.3
                                          nodejs:
                                            Installed: 20.18.0-1nodesource1
                                            Candidate: 20.18.0-1nodesource1
                                            Version table:
                                           *** 20.18.0-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                               20.17.0-1nodesource1 1001
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               12.22.12~dfsg-1~deb11u5 500
                                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                               12.22.12~dfsg-1~deb11u4 500
                                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                          No problems detected
                                          Errors in npm tree: 0
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobroker            iobroker (version: 6.0.11, hostname: iobroker      , alive, uptime: 333)
                                          Core adapters versions
                                          js-controller:  6.0.11
                                          admin:          7.1.5
                                          javascript:     8.8.3
                                          nodejs modules from github:     2
                                          +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                                          +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
                                          Adapter State
                                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                            system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
                                          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                            system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
                                            system.adapter.history.0                : history               : iobroker                                 - disabled
                                            system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
                                            system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
                                            system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
                                            system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
                                          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                            system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                                          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                            system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                            system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
                                          + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                                            system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                                          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Upgrade policy: none
                                          Installed ioBroker-Instances
                                          Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                          Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                                          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                          Controller "js-controller": 6.0.11   , installed 6.0.11
                                          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                                          Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                                          Objects and States
                                          Objects:        1050
                                          States:         801
                                          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       53719      21821/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       53714      21821/iobroker.js-c
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          44849      15025/cupsd
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          44289      14260/sshd: /usr/sb
                                          tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       54447      21916/io.mqtt.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54360      21842/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55495      21973/io.web.0
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          44848      15025/cupsd
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          44291      14260/sshd: /usr/sb
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        43779      14911/avahi-daemon:
                                          udp        0      0 0.0.0.0:44664           0.0.0.0:*                           108        43781      14911/avahi-daemon:
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        43780      14911/avahi-daemon:
                                          udp6       0      0 :::59103                :::*                                108        43782      14911/avahi-daemon:
                                          udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                                          2024-11-03 15:20:12.989  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:20:22.990  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:20:22.991  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:20:22.999  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:20:32.999  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:20:33.000  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:20:33.013  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:20:43.014  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:20:43.015  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:20:43.022  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:20:53.023  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:20:53.024  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:20:53.032  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:21:03.032  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:21:03.033  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:21:03.040  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:21:13.041  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:21:13.042  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:21:13.053  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:21:23.054  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:21:23.055  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:21:23.061  - error: influxdb.0 (21907) AggregateError
                                          2024-11-03 15:21:33.062  - info: influxdb.0 (21907) Connecting http://localhost:8086/ ...
                                          2024-11-03 15:21:33.063  - info: influxdb.0 (21907) Influx DB Version used: 1.x
                                          2024-11-03 15:21:33.071  - error: influxdb.0 (21907) AggregateError
                                          iob diag has finished.
                                          Press any key for a summary
