  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    Da ist er:
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     14:13:55 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-11-03 14:13:55 CET
               Universal time: Sun 2024-11-03 13:13:55 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dogfight76
    HOME=/home/dogfight76
    GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        748M        2.5G        1.0M        499M        3.0G
    Swap:            99M          0B         99M
    Total:          3.9G        748M        2.6G
    Active iob-Instances:   9
             3794 M total memory
              748 M used memory
              197 M active memory
              938 M inactive memory
             2546 M free memory
               49 M buffer memory
              449 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 14:13:56 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
    Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.4 total,   2546.3 free,    748.5 used,    499.5 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2969.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G  6.8G   50G  13% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
    [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.0G    /var/
    1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
    1.1G    /var/log
    628M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    91M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    217M    /opt/iobroker/iobroker-data/
    169M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    40M     /opt/iobroker/iobroker-data/backup-objects
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    6.7M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    nodejs:                 N/A
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
         20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
     *** 16.20.2-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 62)
    Core adapters versions
    js-controller:  5.0.12
    admin:          7.1.5
    javascript:     7.1.4
    nodejs modules from github:     2
    +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
      system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
    Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
    Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
    Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        989
    States:         798
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 319
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16858      1495/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16851      1495/iobroker.js-co
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13941      537/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12826      563/sshd: /usr/sbin
    tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       17879      1572/io.mqtt.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16084      1514/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16168      1618/io.web.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13940      537/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12828      563/sshd: /usr/sbin
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14555      592/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14503      407/avahi-daemon: r
    udp        0      0 0.0.0.0:47112           0.0.0.0:*                           108        14505      407/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14504      407/avahi-daemon: r
    udp6       0      0 :::55098                :::*                                108        14506      407/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
    2024-11-03 14:13:51.363  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:13:51.388  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:01.389  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:01.390  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:01.406  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:11.408  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:11.409  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:11.419  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:21.419  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:21.420  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:21.432  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:28.419  - info: cloud.0 (1587) Trying to connect as system.user.admin to cloud
    2024-11-03 14:14:28.646  - info: cloud.0 (1587) Connection changed: connect
    2024-11-03 14:14:31.433  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:31.434  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:31.451  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:41.452  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:41.453  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:41.469  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:14:51.470  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:14:51.471  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:14:51.487  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    2024-11-03 14:15:01.488  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
    2024-11-03 14:15:01.489  - info: influxdb.0 (1553) Influx DB Version used: 1.x
    2024-11-03 14:15:01.501  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
    iob diag has finished.
    Press any key for a summary
    @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
    und
    sudo apt update
    iob stop
    sudo apt full-upgrade
    sudo reboot
    • dogfight76D Offline
      dogfight76D Offline
      dogfight76
      Nach dem Full-Upgrade Befehl kommt am Schluss:
      apt-listchanges: News
      cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
        This release addresses a security issue (CVE-2023-32360) which allows
        unauthorized users to fetch documents over local or remote networks.
        Since this is a configuration fix, it might be that it does not reach you if you
        are updating 'cups-daemon' (rather than doing a fresh installation).
        Please double check your /etc/cups/cupsd.conf file, whether it limits the access
        to CUPS-Get-Document with something like the following
        >  <Limit CUPS-Get-Document>
        >    AuthType Default
        >    Require user @OWNER @SYSTEM
        >    Order deny,allow
        >   </Limit>
        (The important line is the 'AuthType Default' in this section)
       -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
      (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
      E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
      dogfight76@iobroker:~ $
      Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
      Thomas BraunT dogfight76D 2 Antworten Letzte Antwort
          >    AuthType Default
          >    Order deny,allow
          >   </Limit>
        @dogfight76
        sudo apt update
        sagt?
          dogfight76D Offline
          dogfight76
          Da kommt das:
          dogfight76@iobroker:~ $ sudo apt update
          Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
          Reading package lists... Done
          320 packages can be upgraded. Run 'apt list --upgradable' to see them.
          dogfight76@iobroker:~ $ iob stop
          dogfight76@iobroker:~ $ sudo apt full-upgrade
            Da kommt das:
            @dogfight76
            Die 320 Updates müssen rein.
            Nach dem full-upgrade die Kiste sauber rebooten.
                >    AuthType Default
                >    Order deny,allow
                >   </Limit>
              dogfight76D Offline
              dogfight76D Offline
              dogfight76
              @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                >    AuthType Default
                >    Order deny,allow
                >   </Limit>
              Trotz der Meldung also den Reboot Befehl eingeben ?
                  >    AuthType Default
                  >    Order deny,allow
                  >   </Limit>
                Keine Ahnung warum apt-listchanges da bei dir rumzickt.
                Deinstallier das mal:
                sudo apt remove apt-listchanges
                sudo apt update
                sudo apt upgrade
                  dogfight76D Offline
                  dogfight76
                  Wollte ich jetzt eingeben, da steht das in Putty:
                  Calculating upgrade... Done
                  The following packages were automatically installed and are no longer required:
                    libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
                  Use 'sudo apt autoremove' to remove them.
                  The following NEW packages will be installed:
                    kms++-utils raspi-utils
                  The following packages will be upgraded:
                    adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
                    chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
                    cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
                    dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
                    exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                    ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
                    gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                    gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
                    libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
                    libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                    libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
                    libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                    libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
                    libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                    libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                    libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
                    libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                    libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
                    liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
                    libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
                    libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                    libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                    librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
                    libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
                    libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
                    libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
                    locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                    lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
                    mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
                    openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
                    python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
                    python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                    python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
                    raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
                    systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
                    vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
                    vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
                    xwayland
                  320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 0 B/488 MB of archives.
                  After this operation, 319 MB of additional disk space will be used.
                  Do you want to continue? [Y/n] y
                  Reading changelogs... Done
                      xwayland
                    @dogfight76
                    Ja, so soll das.
                    Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
                    Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
                      dogfight76D Offline
                      dogfight76
                      Das Update/Upgrade nach der deinstallation läuft.
                      Die Installation, gibt es da ein How-To hier im Forum ?
                        @dogfight76
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                          dogfight76D Offline
                          dogfight76
                          Nach dem Update und dem Upgrade Befehl kam das:
                          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                          Setting up libavahi-client-dev:arm64 (0.8-5+deb11u2) ...
                          Setting up libavahi-compat-libdnssd-dev:arm64 (0.8-5+deb11u2) ...
                          Processing triggers for libvlc-bin:arm64 (1:3.0.21-0+rpt2+deb11u1) ...
                          Processing triggers for libgdk-pixbuf-2.0-0:arm64 (2.42.2+dfsg-1+deb11u2) ...
                          dogfight76@iobroker:~ $ sudo apt upgrade
                            libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 python-apt-common python3-apt python3-debconf raspinfo
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            sudo apt autoremove
                            Dann ist dein Betriebssystem auf Stand und du kannst dich um Dinge wie den ioBroker kümmern.
                            iob update
                            iob upgrade all
                            iob stop
                            iob upgrade self
                            iob start
                            iob update
                            iob upgrade all
                              dogfight76D Offline
                              dogfight76
                              Bin dabei........
                                dogfight76D Offline
                                dogfight76
                                Ganz am Anfang und am Ende kommt dann trotzdem die rote Warnung bezüglich des js-controllers
                                dogfight76@iobroker:~ $ iob update
                                dogfight76@iobroker:~ $ iob upgrade all
                                Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                                This upgrade of "javascript" will at least introduce the following changes:
                                -> 8.8.3:
                                Fixed object selector in rules
                                -> 8.8.2:
                                updated dependencies
                                -> 8.8.1:
                                -> 8.8.0:
                                Added option to register notifications via scripts
                                Fixed sendTo block with empty name list
                                -> 8.7.7:
                                Fixed import scripts dialog
                                Allow to remove all custom packages (empty list)
                                -> 8.7.6:
                                fix error with subpath imports in scripts
                                -> 8.7.5:
                                Fixed right aligned script names when using multiple instances
                                added fallback for all require calls in scripts
                                BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                Would you like to upgrade javascript from @7.1.4 to @8.8.3 now? [(y)es, (n)o]: y
                                Update javascript from @7.1.4 to @8.8.3
                                NPM version: 10.8.2
                                Installing iobroker.javascript@8.8.3... (System call)
                                added 2 packages, removed 25 packages, and changed 10 packages in 1m
                                197 packages are looking for funding
                                  run `npm fund` for details
                                Update "system.adapter.javascript.0"
                                upload [1177] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                upload [1150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map custom/static/js/node_modules_mui_styled-engine_GlobalStyles_GlobalStyles_js-node_modules_mui_system_useThemeW-ca1f79.e4f8c64f.chunk.js.map application/json
                                upload [1100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly-9.3.3.tgz google-blockly/blockly-9.3.3.tgz false
                                upload [1050] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/field_oid.js google-blockly/own/field_oid.js application/javascript
                                upload [1000] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/102.23e64034.chunk.js.map static/js/102.23e64034.chunk.js.map application/json
                                upload [950] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/149.2197f5fc.chunk.js.LICENSE.txt static/js/149.2197f5fc.chunk.js.LICENSE.txt text/plain
                                upload [900] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/228.6096b27c.chunk.js.map static/js/228.6096b27c.chunk.js.map application/json
                                upload [850] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/274.47c324f3.chunk.js static/js/274.47c324f3.chunk.js application/javascript
                                upload [800] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/327.0f7eca59.chunk.js static/js/327.0f7eca59.chunk.js application/javascript
                                upload [750] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/409.2e64fd76.chunk.js static/js/409.2e64fd76.chunk.js application/javascript
                                upload [700] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/432.fb14e4f2.chunk.js.map static/js/432.fb14e4f2.chunk.js.map application/json
                                upload [650] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/568.f1b6e961.chunk.js static/js/568.f1b6e961.chunk.js application/javascript
                                upload [600] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/675.279d2690.chunk.js static/js/675.279d2690.chunk.js application/javascript
                                upload [550] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/772.a8a30056.chunk.js.LICENSE.txt static/js/772.a8a30056.chunk.js.LICENSE.txt text/plain
                                upload [500] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/838.92dfa026.chunk.js static/js/838.92dfa026.chunk.js application/javascript
                                upload [450] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/894.e378a23c.chunk.js.map static/js/894.e378a23c.chunk.js.map application/json
                                upload [400] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/982.2ba0e8b8.chunk.js.LICENSE.txt static/js/982.2ba0e8b8.chunk.js.LICENSE.txt text/plain
                                upload [350] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.567b63d3.js static/js/main.567b63d3.js application/javascript
                                upload [300] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.d79356b6.js static/js/main.d79356b6.js application/javascript
                                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Chandelier.0f30083487437c7e9414.svg static/media/Chandelier.0f30083487437c7e9414.svg image/svg+xml
                                upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Garden.51c2e94f62a74e20775d.svg static/media/Garden.51c2e94f62a74e20775d.svg image/svg+xml
                                upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Locker Room.09bd68885c505ed50641.svg static/media/Locker Room.09bd68885c505ed50641.svg image/svg+xml
                                upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.1b2e0a89e9b117740d6e.svg static/media/Speaker.1b2e0a89e9b117740d6e.svg image/svg+xml
                                upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Summer House.541a9fec69f01105e244.svg static/media/Summer House.541a9fec69f01105e244.svg image/svg+xml
                                upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg static/media/Wardrobe.bf8ae07cbc0e32dad8ad.svg image/svg+xml
                                upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.07a51f1a9a8384bbc5ae.svg static/media/Water.07a51f1a9a8384bbc5ae.svg image/svg+xml
                                upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
                                upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/html/html.js vs/basic-languages/html/html.js application/javascript
                                upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/README.md vsFont/README.md text/markdown
                                upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.json vsFont/codicon.json application/json
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/codicon.zip vsFont/codicon.zip application/zip
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vsFont/createJson.js vsFont/createJson.js application/javascript
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/words.js words.js application/javascript
                                This upgrade of "hm-rega" will at least introduce the following changes:
                                -> 5.1.0:
                                added notification if devices are low on battery
                                -> 5.0.0:
                                required node 18
                                -> 4.0.0:
                                required node 16 due to adapter-core 3.x.x
                                removed deprecated package - `request`
                                -> 3.0.47:
                                Updated packages
                                -> 3.0.46:
                                fix for controller v5 (closes #368)
                                -> 3.0.44:
                                compatibility of RSSI_DEVICE and RSSI_PEER for CCU update (closes #352)
                                also sync enums for maintenance channel of rfd devices (closes #320)
                                -> 3.0.43:
                                if LGW is not reachable we now set duty cycle to `null` instead of `-1` in all cases (closes #298)
                                Would you like to upgrade hm-rega from @3.0.40 to @5.1.0 now? [(y)es, (n)o]: y
                                Update hm-rega from @3.0.40 to @5.1.0
                                NPM version: 10.8.2
                                Installing iobroker.hm-rega@5.1.0... (System call)
                                added 1 package, removed 1 package, and changed 1 package in 10s
                                Update "system.adapter.hm-rega.0"
                                upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                                upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                                upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                                upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                                This upgrade of "fritzdect" will at least introduce the following changes:
                                -> 2.5.11:
                                update devDeps, linting error correction
                                -> 2.5.10:
                                more loggimg for issue #500 of restart loop
                                -> 2.5.9:
                                new message box, correction for statistics, password needs to be reentered in versions >2.5.4
                                Would you like to upgrade fritzdect from @2.2.6 to @2.5.11 now? [(y)es, (n)o]: y
                                Update fritzdect from @2.2.6 to @2.5.11
                                NPM version: 10.8.2
                                Installing iobroker.fritzdect@2.5.11... (System call)
                                added 181 packages, removed 8 packages, and changed 9 packages in 29s
                                208 packages are looking for funding
                                Adapter "system.adapter.vis.0" restarted.
                                Update "system.adapter.fritzdect.0"
                                upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                                upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                                upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                                upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                                This upgrade of "discovery" will at least introduce the following changes:
                                -> 5.0.0:
                                Packages updated
                                Minimum node.js version is 18.x
                                Updated licenses for knx and jarvis
                                -> 4.5.0:
                                Added Air-Q
                                -> 4.4.0:
                                Added WLED
                                Added LaMetric
                                Removed net-tools from proposals
                                -> 4.3.0:
                                Replaced vis with vis-2
                                -> 4.2.0:
                                Changed detection of myvbus and resol
                                -> 4.1.0:
                                Added detection of myvbus and resol
                                -> 4.0.0:
                                Added: frontier_silicon, sma-em, and speedwire
                                Dropped node14 support, refactoring
                                Would you like to upgrade discovery from @3.1.0 to @5.0.0 now? [(y)es, (n)o]: y
                                Update discovery from @3.1.0 to @5.0.0
                                NPM version: 10.8.2
                                Installing iobroker.discovery@5.0.0... (System call)
                                added 2 packages, removed 1 package, and changed 19 packages in 13s
                                210 packages are looking for funding
                                Update "system.adapter.discovery.0"
                                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                This upgrade of "chromecast" will introduce the following changes:
                                -> 3.4.1:
                                migrated binary state to file
                                -> 3.4.0:
                                Support for devices located in different subnets has been added. [#154, #160]
                                Dependencies have been updated
                                -> 3.3.0:
                                Adapter requires node.js 18 and js-controller >= 5 now
                                -> 3.2.0:
                                changed: Testing has been updated to use node.js 16/18/20
                                changed: Dependencies have been updated
                                YouTube videos are allowed now ([#75](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/75))
                                AppId has been added to status ([#151](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/151))
                                Storing of webserver settings has been corrected if web instance listens on only one address ([#145](https://github.com/iobroker-community-adapters/ioBroker.chromecast/issues/145))
                                -> 3.1.0:
                                Refactoring done
                                Removed dependency with nettools
                                Added support of web port other than 8082
                                -> 3.0.3:
                                Breaking change: Object IDs are now mac addresses instead names
                                set album name as song if provided in icy-name
                                Make compatible with Node.js 16+
                                Add Sentry for crash reporting
                                Would you like to upgrade chromecast from @2.3.1 to @3.4.1 now? [(y)es, (n)o]: y
                                Update chromecast from @2.3.1 to @3.4.1
                                NPM version: 10.8.2
                                Installing iobroker.chromecast@3.4.1... (System call)
                                added 3 packages, removed 232 packages, and changed 1 package in 12s
                                207 packages are looking for funding
                                Update "system.adapter.chromecast.0"
                                upload [13] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                                upload [12] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                                upload [11] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [10] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                upload [9] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                upload [8] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                upload [7] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                upload [6] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                upload [5] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                upload [4] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                                upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                                  -> 8.8.3:
                                  -> 8.8.2:
                                  -> 8.8.1:
                                  -> 8.8.0:
                                  -> 8.7.7:
                                  -> 8.7.6:
                                  -> 8.7.5:
                                  NPM version: 10.8.2
                                  -> 5.1.0:
                                  -> 5.0.0:
                                  required node 18
                                  -> 4.0.0:
                                  -> 3.0.47:
                                  Updated packages
                                  -> 3.0.46:
                                  -> 3.0.44:
                                  -> 3.0.43:
                                  NPM version: 10.8.2
                                  -> 2.5.11:
                                  -> 2.5.10:
                                  -> 2.5.9:
                                  NPM version: 10.8.2
                                  -> 5.0.0:
                                  Packages updated
                                  -> 4.5.0:
                                  Added Air-Q
                                  -> 4.4.0:
                                  Added WLED
                                  Added LaMetric
                                  -> 4.3.0:
                                  -> 4.2.0:
                                  -> 4.1.0:
                                  -> 4.0.0:
                                  NPM version: 10.8.2
                                  -> 3.4.1:
                                  -> 3.4.0:
                                  -> 3.3.0:
                                  -> 3.2.0:
                                  -> 3.1.0:
                                  Refactoring done
                                  -> 3.0.3:
                                  NPM version: 10.8.2
                                  hast du den noch nicht aktualisiert?
                                    -> 8.8.3:
                                    -> 8.8.2:
                                    -> 8.8.1:
                                    -> 8.8.0:
                                    -> 8.7.7:
                                    -> 8.7.6:
                                    -> 8.7.5:
                                    NPM version: 10.8.2
                                    -> 5.1.0:
                                    -> 5.0.0:
                                    required node 18
                                    -> 4.0.0:
                                    -> 3.0.47:
                                    Updated packages
                                    -> 3.0.46:
                                    -> 3.0.44:
                                    -> 3.0.43:
                                    NPM version: 10.8.2
                                    -> 2.5.11:
                                    -> 2.5.10:
                                    -> 2.5.9:
                                    NPM version: 10.8.2
                                    -> 5.0.0:
                                    Packages updated
                                    -> 4.5.0:
                                    Added Air-Q
                                    -> 4.4.0:
                                    Added WLED
                                    Added LaMetric
                                    -> 4.3.0:
                                    -> 4.2.0:
                                    -> 4.1.0:
                                    -> 4.0.0:
                                    NPM version: 10.8.2
                                    -> 3.4.1:
                                    -> 3.4.0:
                                    -> 3.3.0:
                                    -> 3.2.0:
                                    -> 3.1.0:
                                    Refactoring done
                                    -> 3.0.3:
                                    NPM version: 10.8.2
                                    @dogfight76
                                    Gib die Befehle in der Abfolge wie oben gepostet ein.
                                    Fehlermeldungen sind jetzt irrelevant und erwartet.
                                      dogfight76D Offline
                                      dogfight76
                                      Damit fing das Problem doch an........
                                      Ich wollte im ioBroker das Update des js-controller anstoßen
                                        @dogfight76
                                        dogfight76D Offline
                                        dogfight76D Offline
                                        dogfight76
                                        @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                        @dogfight76
                                        Hatte nicht gesehen das die letzte Antwort nicht von dir war.
                                        Arbeite die Befehlsliste gerade ab
                                          @dogfight76
                                          dogfight76D Offline
                                          dogfight76D Offline
                                          dogfight76
                                          @thomas-braun Fertig. Ohne Fehlermeldung
