  3. Einsteigerfragen
  4. Anzeige Zeit/Datum - Fehler bei Update & InfluxDB
    5.4k
64 Beiträge 3 Kommentatoren 8.1k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    Langversion:
    ```bash
    Script v.2024-10-19
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v8+
          Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     13:39:34 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release '' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-11-03 13:39:34 CET
               Universal time: Sun 2024-11-03 12:39:34 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dogfight76
    HOME=/home/dogfight76
    GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            3.8G        573M        962M         35M        2.3G        3.1G
    Swap:            99M          0B         99M
    Total:          3.9G        573M        1.1G
    Active iob-Instances:   1
             3794 M total memory
              573 M used memory
              799 M active memory
             1661 M inactive memory
              961 M free memory
              232 M buffer memory
             2025 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 13:39:35 up 385 days, 17:02,  3 users,  load average: 0.25, 0.27, 0.41
    Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  4.3 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3794.4 total,    961.7 free,    574.0 used,   2258.7 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   3054.2 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G  6.4G   50G  12% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.2M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  12% /boot
    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
    [Sat Oct 14 21:37:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Oct 14 21:37:18 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Oct 14 21:37:18 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Oct 14 21:37:20 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    1.1G    /var/log/journal/7d1338ad4ea145258230302c11232948
    1.1G    /var/log
    259M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    91M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    216M    /opt/iobroker/iobroker-data/
    169M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    40M     /opt/iobroker/iobroker-data/backup-objects
    34M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
    7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.f22de4ab.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
    6.4M    /opt/iobroker/iobroker-data/objects.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    *** NodeJS-Installation ***
    nodejs:                 N/A
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 20.18.0-1nodesource1
      Version table:
         20.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
     *** 16.20.2-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u5 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 197)
    Core adapters versions
    js-controller:  5.0.12
    admin:          7.1.5
    javascript:     7.1.4
    nodejs modules from github:     2
    +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.chromecast.0             : chromecast            : iobroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
      system.adapter.history.0                : history               : iobroker                                 - disabled
      system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
      system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.jarvis.0                 : jarvis                : iobroker                                 - disabled
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
      system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
      system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "backitup"     : 3.0.25   , installed 2.5.10 [Updatable]
    Adapter    "chromecast"   : 3.4.1    , installed 2.3.1  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "fritzdect"    : 2.5.11   , installed 2.2.6  [Updatable]
    Adapter    "hm-rega"      : 5.1.0    , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 2.0.2    , installed 1.15.16 [Updatable]
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 7.1.4  [Updatable]
    Controller "js-controller": 6.0.11   , installed 5.0.12 [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "net-tools"    : 1.0.11   , installed 0.2.0  [Updatable]
    Adapter    "solarlog"     : 2.3.0    , installed 2.2.5  [Updatable]
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        989
    States:         790
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 319
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11229      559/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18069559   3929826/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11240      559/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18069558   3929826/cupsd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11154      399/avahi-daemon: r
    udp        0      0 0.0.0.0:53292           0.0.0.0:*                           108        11156      399/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13063      479/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18068882   3929827/cups-browse
    udp6       0      0 :::48058                :::*                                108        11157      399/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        11155      399/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          17537999   479/dhcpcd
    2024-11-03 13:26:15.900  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
    2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
    2024-11-03 13:26:15.901  - info: host.iobroker stopInstance system.adapter.vis-inventwo.0 send kill signal
    2024-11-03 13:26:15.902  - info: host.iobroker stopInstance system.adapter.time-switch.0 send kill signal
    2024-11-03 13:26:15.904  - info: mqtt.0 (3937682) Terminated (NO_ERROR): Without reason
    2024-11-03 13:26:16.249  - info: cloud.0 (3937725) terminating
    2024-11-03 13:26:16.259  - info: vis-inventwo.0 (3937817) terminating
    2024-11-03 13:26:16.259  - info: backitup.0 (3937750) terminating
    2024-11-03 13:26:16.267  - info: web.0 (3937775) terminating
    2024-11-03 13:26:16.266  - info: admin.0 (3937625) terminating
    2024-11-03 13:26:16.270  - info: web.0 (3937775) Terminated (NO_ERROR): Without reason
    2024-11-03 13:26:16.273  - info: time-switch.0 (3937843) terminating
    2024-11-03 13:26:16.275  - info: mqtt.0 (3937682) terminating
    2024-11-03 13:26:16.276  - info: javascript.0 (3937647) terminating
    2024-11-03 13:26:16.601  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.603  - info: host.iobroker instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.604  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.644  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.727  - info: host.iobroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.729  - info: host.iobroker instance system.adapter.time-switch.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.753  - info: host.iobroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.831  - info: host.iobroker instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
    2024-11-03 13:26:16.831  - info: host.iobroker All instances are stopped.
    2024-11-03 13:26:17.064  - info: host.iobroker terminated
    iob diag has finished.
    Press any key for a summary
    @dogfight76
    Bring das ganze Ding beizeiten auf das aktuelle Release 'Bookworm'.
    Geht aber bei RaspberryOS nur per kompletter Neuinstallation.
    Die Zeit ist jedenfalls richtig konfiguriert.
    Warum nicht?
    sudo systemctl set-default multi-user.target
    Glückwunsch... Dein Betriebssystem möchte so dann und wann mal etwas Pflege erfahren...
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Wenn die Kiste wieder läuft:
    iob update
    iob upgrade all -y
    iob stop
    iob upgrade self
    iob start
    dogfight76D 1 Antwort Letzte Antwort
      @dogfight76
      Warum nicht?
      sudo apt update
      sudo reboot
      iob update
      iob upgrade all -y
      iob stop
      iob upgrade self
      iob start
      dogfight76D Offline
      dogfight76D Offline
      dogfight76
      @thomas-braun said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
      Dann kam das hier:
      dogfight76@iobroker:~ $ sudo systemctl set-default multi-user.target
      Removed /etc/systemd/system/default.target.
      Created symlink /etc/systemd/system/default.target → /lib/systemd/system/multi-user.target.
        Dann kam das hier:
        @dogfight76
        Ja, das ist richtig.
        • dogfight76D Offline
          dogfight76D Offline
          dogfight76
          Dann ist der PI jetzt beim full-upgrade !
          Werde den Rest dann so abarbeiten. Dann ist alles erledigt ?
            @dogfight76
            Wenn du damit durch bist nochmal die Langfassung posten.
              dogfight76D Offline
              dogfight76
              schrieb am zuletzt editiert von dogfight76
              Es kam jetzt das hier:
              Fetched 387 MB in 1min 21s (4,757 kB/s)
              Reading changelogs... Done
              apt-listchanges: News
              cups (2.3.3op2-3+deb11u4) bullseye; urgency=medium
                This release addresses a security issue (CVE-2023-32360) which allows
                unauthorized users to fetch documents over local or remote networks.
                Since this is a configuration fix, it might be that it does not reach you if you
                are updating 'cups-daemon' (rather than doing a fresh installation).
                Please double check your /etc/cups/cupsd.conf file, whether it limits the access
                to CUPS-Get-Document with something like the following
                >  <Limit CUPS-Get-Document>
                >    AuthType Default
                >    Require user @OWNER @SYSTEM
                >    Order deny,allow
                >   </Limit>
                (The important line is the 'AuthType Default' in this section)
               -- Thorsten Alteholz <debian@alteholz.de>  Tue, 19 Sep 2023 21:20:27 +0200
              (press q to quit)E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 received signal 2.
              E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
              Trotzdem deine Liste weiter abarebiten ?
                  >    AuthType Default
                  >    Order deny,allow
                  >   </Limit>
                @dogfight76 sagte in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                Ja, das ist eines der von dir vernachlässigten Sicherheitsupdates...
                Und ganz eigentlich sollte CUPS auch gar nicht auf dem System laufen, außer du betreibst da einen Drucker dran.
                  dogfight76D Offline
                  dogfight76
                  Nein, kein Drucker angeschlossen.
                  Nach Abschluss aller Befehle:
                  upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                  upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                  Update chromecast from @2.3.1 to @3.4.1
                  NPM version: 8.19.4
                  Installing iobroker.chromecast@3.4.1... (System call)
                  Adapter "system.adapter.vis.0" restarted.
                  upload [3] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/chromecast.png chromecast.png image/png
                  upload [2] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/home.png home.png image/png
                  upload [1] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/index_m.html index_m.html text/html
                  upload [0] chromecast.admin /opt/iobroker/node_modules/iobroker.chromecast/admin/words.js words.js application/javascript
                  Cannot check dependencies: Invalid version of "js-controller". Installed "5.0.12", required ">=5.0.19
                  dogfight76@iobroker:~ $ iob stop
                  dogfight76@iobroker:~ $ iob upgrade self
                  Update js-controller from @5.0.12 to @6.0.11
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 8.19.4
                  Installing iobroker.js-controller@6.0.11... (System call)
                  dogfight76@iobroker:~ $ iob start
                    NPM version: 8.19.4
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 8.19.4
                    ...möchte ich einen frischen Lauf von iob diag sehen.
                      dogfight76D Offline
                      dogfight76
                      Da ist er:
                      ```bash
                      Script v.2024-10-19
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       14:13:55 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                      CPU threads: 4
                      Current issues:
                                     Local time: Sun 2024-11-03 14:13:55 CET
                                 Universal time: Sun 2024-11-03 13:13:55 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      dogfight76
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        748M        2.5G        1.0M        499M        3.0G
                      Swap:            99M          0B         99M
                      Total:          3.9G        748M        2.6G
                      Active iob-Instances:   9
                               3794 M total memory
                                748 M used memory
                                197 M active memory
                                938 M inactive memory
                               2546 M free memory
                                 49 M buffer memory
                                449 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      top - 14:13:56 up 7 min,  2 users,  load average: 1.21, 0.93, 0.51
                      Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  2.9 us,  1.4 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3794.4 total,   2546.3 free,    748.5 used,    499.5 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2969.2 avail Mem
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G  6.8G   50G  13% /
                      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
                      [Sun Nov  3 14:06:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Sun Nov  3 14:06:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sun Nov  3 14:06:02 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sun Nov  3 14:06:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                      /var:
                      2.0G    /var/
                      1.1G    /var/log
                      628M    /var/cache
                      217M    /opt/iobroker/iobroker-data/
                      6.7M    /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      nodejs:                 N/A
                      /usr/bin/npm            8.19.4
                      /usr/bin/npx            8.19.4
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 5.0.12, hostname: iobroker      , alive, uptime: 62)
                      admin:          7.1.5
                      javascript:     7.1.4
                      Adapter State
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      + instance is alive
                      Objects and States
                      Objects:        989
                      States:         798
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16858      1495/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16851      1495/iobroker.js-co
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13941      537/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12826      563/sshd: /usr/sbin
                      tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       17879      1572/io.mqtt.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16084      1514/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16168      1618/io.web.0
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13940      537/cupsd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12828      563/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14555      592/cups-browsed
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14503      407/avahi-daemon: r
                      udp        0      0 0.0.0.0:47112           0.0.0.0:*                           108        14505      407/avahi-daemon: r
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14638      497/dhcpcd
                      udp6       0      0 :::5353                 :::*                                108        14504      407/avahi-daemon: r
                      udp6       0      0 :::55098                :::*                                108        14506      407/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          12280      497/dhcpcd
                      2024-11-03 14:13:51.363  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:13:51.388  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:14:01.389  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:14:01.390  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:14:01.406  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:14:11.408  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:14:11.409  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:14:11.419  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:14:21.419  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:14:21.420  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:14:21.432  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:14:28.419  - info: cloud.0 (1587) Trying to connect as system.user.admin to cloud
                      2024-11-03 14:14:28.646  - info: cloud.0 (1587) Connection changed: connect
                      2024-11-03 14:14:31.433  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:14:31.434  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:14:31.451  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:14:41.452  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:14:41.453  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:14:41.469  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:14:51.470  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:14:51.471  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:14:51.487  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                      2024-11-03 14:15:01.488  - info: influxdb.0 (1553) Connecting http://localhost:8086/ ...
                      2024-11-03 14:15:01.489  - info: influxdb.0 (1553) Influx DB Version used: 1.x
                      2024-11-03 14:15:01.501  - error: influxdb.0 (1553) Error: connect ECONNREFUSED 127.0.0.1:8086
                        Da ist er:
                        ```bash
                        Script v.2024-10-19
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        dogfight76
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                 3794 M total memory
                                  748 M used memory
                                  197 M active memory
                                 2546 M free memory
                                   49 M buffer memory
                                  449 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.0G    /var/
                        1.1G    /var/log
                        628M    /var/cache
                        USB-Devices by-id:
                        nodejs:                 N/A
                        /usr/bin/npm            8.19.4
                        /usr/bin/npx            8.19.4
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.1.5
                        javascript:     7.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        989
                        States:         798
                        und
                        sudo apt update
                        iob stop
                        sudo reboot
                          dogfight76D Offline
                          dogfight76
                          Nach dem Full-Upgrade Befehl kommt am Schluss:
                            >    AuthType Default
                            >    Order deny,allow
                            >   </Limit>
                          Das ist korrekt so ? Dann mit reboot den Neustart einleiten ?
                          Thomas BraunT dogfight76D 2 Antworten Letzte Antwort
                              >    AuthType Default
                              >    Order deny,allow
                              >   </Limit>
                            @dogfight76
                            sudo apt update
                            sagt?
                              dogfight76D Offline
                              dogfight76
                              Da kommt das:
                              dogfight76@iobroker:~ $ sudo apt update
                              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:2 http://deb.debian.org/debian bullseye InRelease
                              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Reading package lists... Done
                              320 packages can be upgraded. Run 'apt list --upgradable' to see them.
                              dogfight76@iobroker:~ $ sudo apt full-upgrade
                                Da kommt das:
                                @dogfight76
                                Die 320 Updates müssen rein.
                                Nach dem full-upgrade die Kiste sauber rebooten.
                                    >    AuthType Default
                                    >    Order deny,allow
                                    >   </Limit>
                                  dogfight76D Offline
                                  dogfight76D Offline
                                  dogfight76
                                  @dogfight76 said in Anzeige Zeit/Datum - Fehler bei Update & InfluxDB:
                                    >    AuthType Default
                                    >    Order deny,allow
                                    >   </Limit>
                                  Trotz der Meldung also den Reboot Befehl eingeben ?
                                      >    AuthType Default
                                      >    Order deny,allow
                                      >   </Limit>
                                    Keine Ahnung warum apt-listchanges da bei dir rumzickt.
                                    Deinstallier das mal:
                                    sudo apt remove apt-listchanges
                                    sudo apt update
                                    sudo apt upgrade
                                      dogfight76D Offline
                                      dogfight76
                                      Wollte ich jetzt eingeben, da steht das in Putty:
                                      Calculating upgrade... Done
                                      The following packages were automatically installed and are no longer required:
                                        libfuse2 libwpe-1.0-1 libwpebackend-fdo-1.0-1 raspinfo
                                      Use 'sudo apt autoremove' to remove them.
                                      The following NEW packages will be installed:
                                        kms++-utils raspi-utils
                                      The following packages will be upgraded:
                                        adduser agnostics arandr avahi-daemon base-files bind9-host bind9-libs bluez bluez-firmware bsdextrautils bsdutils
                                        chromium-browser chromium-browser-l10n chromium-codecs-ffmpeg-extra cifs-utils cpio cups cups-browsed cups-client
                                        cups-common cups-core-drivers cups-daemon cups-filters cups-filters-core-drivers cups-ipp-utils cups-ppdc cups-server-common
                                        dbus dbus-user-session dbus-x11 debian-archive-keyring dhcpcd5 distro-info-data dns-root-data dpkg dpkg-dev e2fsprogs eject
                                        exfatprogs fdisk ffmpeg file firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek
                                        ghostscript gir1.2-gdkpixbuf-2.0 gir1.2-gtk-3.0 gir1.2-rsvg-2.0 git git-man gldriver-test grep gstreamer1.0-alsa
                                        gstreamer1.0-plugins-bad gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-x gtk-update-icon-cache
                                        gtk2-engines-pixbuf gui-pkinst isc-dhcp-client isc-dhcp-common less libaom0 libatspi2.0-0 libavahi-client-dev
                                        libavahi-client3 libavahi-common-data libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
                                        libavahi-compat-libdnssd1 libavahi-core7 libavahi-glib1 libavcodec58 libavdevice58 libavfilter7 libavformat58 libavresample4
                                        libavutil56 libblas3 libblkid-dev libblkid1 libbluetooth3 libbluray2 libbsd0 libc-bin libc-dev-bin libc-devtools libc-l10n
                                        libc6 libc6-dbg libc6-dev libcamera-apps libcamera-tools libcamera0 libcom-err2 libcups2 libcupsfilters1 libcupsimage2
                                        libcurl3-gnutls libdav1d4 libdbus-1-3 libdbus-1-dev libde265-0 libdpkg-perl libegl-mesa0 libexpat1 libexpat1-dev libext2fs2
                                        libfdisk1 libflac8 libfontembed1 libgbm1 libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin
                                        libgdk-pixbuf2.0-common libgl1-mesa-dri libglapi-mesa libgles2-mesa libglib2.0-0 libglib2.0-bin libglib2.0-data
                                        libglib2.0-dev libglib2.0-dev-bin libglx-mesa0 libgnutls30 libgs9 libgs9-common libgssapi-krb5-2 libgstreamer-gl1.0-0
                                        libgstreamer-plugins-bad1.0-0 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-common libgtk2.0-0 libgtk2.0-bin
                                        libgtk2.0-common libimlib2 libjavascriptcoregtk-4.0-18 libjson-c5 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libksba8
                                        liblapack3 libmagic-mgc libmagic1 libmount-dev libmount1 libmutter-7-0 libncurses6 libncursesw6 libndp0 libnftables1
                                        libnghttp2-14 libnss3 libntfs-3g883 libopenexr25 libpam-systemd libperl5.32 libpostproc55 libprotobuf-lite23
                                        libqt5concurrent5 libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5printsupport5 libqt5sql5 libqt5sql5-sqlite
                                        libqt5test5 libqt5widgets5 libqt5xml5 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 librsvg2-2
                                        librsvg2-common librsvg2-dev libsepol1 libsepol1-dev libsmartcols1 libsmbclient libsqlite3-0 libss2 libssh-gcrypt-4
                                        libssh2-1 libssl1.1 libswresample3 libswscale5 libsynctex2 libsystemd0 libtasn1-6 libtiff5 libtinfo6 libudev-dev libudev1
                                        libuuid1 libuv1 libvlc-bin libvlc5 libvlccore9 libvncclient1 libvpx6 libwbclient0 libwebkit2gtk-4.0-37 libwebp6
                                        libwebpdemux2 libwebpmux3 libx11-6 libx11-data libx11-dev libx11-xcb1 libxml2 libxpm4 libzbar0 libzmq5 linux-libc-dev
                                        locales logrotate logsave lxplug-bluetooth lxplug-cputemp lxplug-ejecter lxplug-magnifier lxplug-menu lxplug-netman
                                        lxplug-network lxplug-ptbatt lxplug-updater lxplug-volumepulse lxtask mesa-va-drivers mesa-vdpau-drivers mount mutter
                                        mutter-common nano ncurses-base ncurses-bin ncurses-term net-tools nfs-common nftables nodejs ntfs-3g openssh-client
                                        openssh-server openssh-sftp-server openssl perl perl-base perl-modules-5.32 piclone pprompt python3-cryptography
                                        python3-flask python3-idna python3-kms++ python3-libcamera python3-picamera2 python3-pil python3-pkg-resources
                                        python3-renderpm python3-reportlab python3-reportlab-accel python3-sense-hat python3-setuptools python3-v4l2
                                        python3-werkzeug qt5-gtk-platformtheme raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspberrypi-ui-mods
                                        raspi-config raspinfo realvnc-vnc-server rfkill rp-bookshelf rp-prefapps rpi-eeprom rpi-imager samba-libs ssh sudo systemd
                                        systemd-sysv systemd-timesyncd tar thonny tzdata udev usb.ids util-linux uuid-dev vlc vlc-bin vlc-data vlc-l10n
                                        vlc-plugin-access-extra vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba vlc-plugin-skins2
                                        vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization wpasupplicant xserver-common xserver-xorg-core
                                        xwayland
                                      320 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
                                      Need to get 0 B/488 MB of archives.
                                      After this operation, 319 MB of additional disk space will be used.
                                      Do you want to continue? [Y/n] y
                                          xwayland
                                        @dogfight76
                                        Ja, so soll das.
                                        Und ca. die Hälfte der Updates sind nur notwendig, weil du da den vollen Desktop mitschleifst....
                                        Aber da du ja ohnehin nach der Aktion ein Backup des ioBroker machst und dann damit in ein frisch neuinstalliertes System umziehst kannst du da ja gleich auf den ganzen Overhead bei der Installation schon verzichten.
                                          dogfight76D Offline
                                          dogfight76
                                          Das Update/Upgrade nach der deinstallation läuft.
                                          Die Installation, gibt es da ein How-To hier im Forum ?
